[U-Boot] [PATCH 1/4] ata: fsl_ahci: Add sata DM support for Freescale powerpc socs
This patch is to support Freescale sata driver with dts initialized. Also resolved the following problems.
===================== WARNING ====================== This board does not use CONFIG_DM_SCSI. Please update the storage controller to use CONFIG_DM_SCSI before the v2019.07 release. Failure to update by the deadline may result in board removal. See doc/driver-model/MIGRATION.txt for more info. ====================================================
Signed-off-by: Peng Ma peng.ma@nxp.com --- depends on: - https://patchwork.ozlabs.org/project/uboot/list/?series=99168 - https://patchwork.ozlabs.org/project/uboot/list/?series=99167
drivers/ata/Kconfig | 10 + drivers/ata/Makefile | 1 + drivers/ata/fsl_ahci.c | 1030 ++++++++++++++++++++++++++++++++++++++++ drivers/ata/fsl_sata.h | 1 + 4 files changed, 1042 insertions(+) create mode 100644 drivers/ata/fsl_ahci.c
diff --git a/drivers/ata/Kconfig b/drivers/ata/Kconfig index 49a056e941..efac29c709 100644 --- a/drivers/ata/Kconfig +++ b/drivers/ata/Kconfig @@ -59,6 +59,16 @@ config DWC_AHCI Enable this driver to support Sata devices through Synopsys DWC AHCI module.
+config FSL_AHCI + bool "Enable Freescale AHCI driver support" + select SCSI_AHCI + depends on AHCI + depends on DM_SCSI + help + Enable this driver to support Sata devices found in + some Freescale PowerPC SoCs. + + config DWC_AHSATA bool "Enable DWC AHSATA driver support" select LIBATA diff --git a/drivers/ata/Makefile b/drivers/ata/Makefile index 10bed53bb3..93aabf34c7 100644 --- a/drivers/ata/Makefile +++ b/drivers/ata/Makefile @@ -4,6 +4,7 @@ # Wolfgang Denk, DENX Software Engineering, wd@denx.de.
obj-$(CONFIG_DWC_AHCI) += dwc_ahci.o +obj-$(CONFIG_FSL_AHCI) += fsl_ahci.o obj-$(CONFIG_AHCI) += ahci-uclass.o obj-$(CONFIG_AHCI_PCI) += ahci-pci.o obj-$(CONFIG_SCSI_AHCI) += ahci.o diff --git a/drivers/ata/fsl_ahci.c b/drivers/ata/fsl_ahci.c new file mode 100644 index 0000000000..16c6f7a335 --- /dev/null +++ b/drivers/ata/fsl_ahci.c @@ -0,0 +1,1030 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * NXP PPC SATA platform driver + * + * (C) Copyright 2019 NXP, Inc. + * + */ +#include <common.h> +#include <asm/fsl_serdes.h> +#include <dm/lists.h> +#include <dm.h> +#include <ahci.h> +#include <scsi.h> +#include <libata.h> +#include <sata.h> +#include <malloc.h> +#include <memalign.h> +#include <fis.h> + +#include "fsl_sata.h" + +struct fsl_ahci_priv { + u32 base; + u32 flag; + u32 number; + fsl_sata_t *fsl_sata; +}; + +static int fsl_ahci_bind(struct udevice *dev) +{ + return device_bind_driver(dev, "fsl_ahci_scsi", "fsl_ahci_scsi", NULL); +} + +static int fsl_ahci_ofdata_to_platdata(struct udevice *dev) +{ + struct fsl_ahci_priv *priv = dev_get_priv(dev); + + priv->number = dev_read_u32_default(dev, "sata-number", -1); + priv->flag = dev_read_u32_default(dev, "sata-fpdma", -1); + + priv->base = dev_read_addr(dev); + if (priv->base == FDT_ADDR_T_NONE) + return -EINVAL; + + return 0; +} + +static int ata_wait_register(unsigned __iomem *addr, u32 mask, + u32 val, u32 timeout_msec) +{ + int i; + + for (i = 0; ((in_le32(addr) & mask) != val) && i < timeout_msec; i++) + mdelay(1); + + return (i < timeout_msec) ? 0 : -1; +} + +static void fsl_sata_dump_sfis(struct sata_fis_d2h *s) +{ + printf("Status FIS dump:\n\r"); + printf("fis_type: %02x\n\r", s->fis_type); + printf("pm_port_i: %02x\n\r", s->pm_port_i); + printf("status: %02x\n\r", s->status); + printf("error: %02x\n\r", s->error); + printf("lba_low: %02x\n\r", s->lba_low); + printf("lba_mid: %02x\n\r", s->lba_mid); + printf("lba_high: %02x\n\r", s->lba_high); + printf("device: %02x\n\r", s->device); + printf("lba_low_exp: %02x\n\r", s->lba_low_exp); + printf("lba_mid_exp: %02x\n\r", s->lba_mid_exp); + printf("lba_high_exp: %02x\n\r", s->lba_high_exp); + printf("res1: %02x\n\r", s->res1); + printf("sector_count: %02x\n\r", s->sector_count); + printf("sector_count_exp: %02x\n\r", s->sector_count_exp); +} + +static void fsl_sata_dump_regs(fsl_sata_reg_t __iomem *reg) +{ + printf("\n\rSATA: %08x\n\r", (u32)reg); + printf("CQR: %08x\n\r", in_le32(®->cqr)); + printf("CAR: %08x\n\r", in_le32(®->car)); + printf("CCR: %08x\n\r", in_le32(®->ccr)); + printf("CER: %08x\n\r", in_le32(®->cer)); + printf("CQR: %08x\n\r", in_le32(®->cqr)); + printf("DER: %08x\n\r", in_le32(®->der)); + printf("CHBA: %08x\n\r", in_le32(®->chba)); + printf("HStatus: %08x\n\r", in_le32(®->hstatus)); + printf("HControl: %08x\n\r", in_le32(®->hcontrol)); + printf("CQPMP: %08x\n\r", in_le32(®->cqpmp)); + printf("SIG: %08x\n\r", in_le32(®->sig)); + printf("ICC: %08x\n\r", in_le32(®->icc)); + printf("SStatus: %08x\n\r", in_le32(®->sstatus)); + printf("SError: %08x\n\r", in_le32(®->serror)); + printf("SControl: %08x\n\r", in_le32(®->scontrol)); + printf("SNotification: %08x\n\r", in_le32(®->snotification)); + printf("TransCfg: %08x\n\r", in_le32(®->transcfg)); + printf("TransStatus: %08x\n\r", in_le32(®->transstatus)); + printf("LinkCfg: %08x\n\r", in_le32(®->linkcfg)); + printf("LinkCfg1: %08x\n\r", in_le32(®->linkcfg1)); + printf("LinkCfg2: %08x\n\r", in_le32(®->linkcfg2)); + printf("LinkStatus: %08x\n\r", in_le32(®->linkstatus)); + printf("LinkStatus1: %08x\n\r", in_le32(®->linkstatus1)); + printf("PhyCtrlCfg: %08x\n\r", in_le32(®->phyctrlcfg)); + printf("SYSPR: %08x\n\r", in_be32(®->syspr)); +} + +static int init_sata(struct fsl_ahci_priv *priv) +{ + int i; + u32 cda; + u32 val32; + u32 sig; + fsl_sata_t *sata; + u32 length, align; + cmd_hdr_tbl_t *cmd_hdr; + fsl_sata_reg_t __iomem *reg; + + int dev = priv->number; + + if (dev < 0 || dev > (CONFIG_SYS_SATA_MAX_DEVICE - 1)) { + printf("the sata index %d is out of ranges\n\r", dev); + return -EINVAL; + } + +#ifdef CONFIG_MPC85xx + if (dev == 0 && (!is_serdes_configured(SATA1))) { + printf("SATA%d [dev = %d] is not enabled\n", dev + 1, dev); + return -EINVAL; + } + if (dev == 1 && (!is_serdes_configured(SATA2))) { + printf("SATA%d [dev = %d] is not enabled\n", dev + 1, dev); + return -EINVAL; + } +#endif + + /* Allocate SATA device driver struct */ + sata = (fsl_sata_t *)malloc(sizeof(fsl_sata_t)); + if (!sata) { + printf("alloc the sata device struct failed\n\r"); + return -ENOMEM; + } + /* Zero all of the device driver struct */ + memset((void *)sata, 0, sizeof(fsl_sata_t)); + + sata->dma_flag = priv->flag; + snprintf(sata->name, 12, "SATA%d", dev); + + /* Set the controller register base address to device struct */ + reg = (fsl_sata_reg_t *)priv->base; + sata->reg_base = reg; + + /* Allocate the command header table, 4 bytes aligned */ + length = sizeof(struct cmd_hdr_tbl); + align = SATA_HC_CMD_HDR_TBL_ALIGN; + sata->cmd_hdr_tbl_offset = (void *)malloc(length + align); + if (!sata->cmd_hdr_tbl_offset) { + printf("alloc the command header failed\n\r"); + return -ENOMEM; + } + + cmd_hdr = (cmd_hdr_tbl_t *)(((u32)sata->cmd_hdr_tbl_offset + align) + & ~(align - 1)); + sata->cmd_hdr = cmd_hdr; + + /* Zero all of the command header table */ + memset((void *)sata->cmd_hdr_tbl_offset, 0, length + align); + + /* Allocate command descriptor for all command */ + length = sizeof(struct cmd_desc) * SATA_HC_MAX_CMD; + align = SATA_HC_CMD_DESC_ALIGN; + sata->cmd_desc_offset = (void *)malloc(length + align); + if (!sata->cmd_desc_offset) { + printf("alloc the command descriptor failed\n\r"); + return -ENOMEM; + } + sata->cmd_desc = (cmd_desc_t *)(((u32)sata->cmd_desc_offset + align) + & ~(align - 1)); + /* Zero all of command descriptor */ + memset((void *)sata->cmd_desc_offset, 0, length + align); + + /* Link the command descriptor to command header */ + for (i = 0; i < SATA_HC_MAX_CMD; i++) { + cda = ((u32)sata->cmd_desc + SATA_HC_CMD_DESC_SIZE * i) + & ~(CMD_HDR_CDA_ALIGN - 1); + cmd_hdr->cmd_slot[i].cda = cpu_to_le32(cda); + } + + /* To have safe state, force the controller offline */ + val32 = in_le32(®->hcontrol); + val32 &= ~HCONTROL_ONOFF; + val32 |= HCONTROL_FORCE_OFFLINE; + out_le32(®->hcontrol, val32); + + /* Wait the controller offline */ + ata_wait_register(®->hstatus, HSTATUS_ONOFF, 0, 1000); + + /* Set the command header base address to CHBA register to tell DMA */ + out_le32(®->chba, (u32)cmd_hdr & ~0x3); + + /* Snoop for the command header */ + val32 = in_le32(®->hcontrol); + val32 |= HCONTROL_HDR_SNOOP; + out_le32(®->hcontrol, val32); + + /* Disable all of interrupts */ + val32 = in_le32(®->hcontrol); + val32 &= ~HCONTROL_INT_EN_ALL; + out_le32(®->hcontrol, val32); + + /* Clear all of interrupts */ + val32 = in_le32(®->hstatus); + out_le32(®->hstatus, val32); + + /* Set the ICC, no interrupt coalescing */ + out_le32(®->icc, 0x01000000); + + /* No PM attatched, the SATA device direct connect */ + out_le32(®->cqpmp, 0); + + /* Clear SError register */ + val32 = in_le32(®->serror); + out_le32(®->serror, val32); + + /* Clear CER register */ + val32 = in_le32(®->cer); + out_le32(®->cer, val32); + + /* Clear DER register */ + val32 = in_le32(®->der); + out_le32(®->der, val32); + + /* No device detection or initialization action requested */ + out_le32(®->scontrol, 0x00000300); + + /* Configure the transport layer, default value */ + out_le32(®->transcfg, 0x08000016); + + /* Configure the link layer, default value */ + out_le32(®->linkcfg, 0x0000ff34); + + /* Bring the controller online */ + val32 = in_le32(®->hcontrol); + val32 |= HCONTROL_ONOFF; + out_le32(®->hcontrol, val32); + + mdelay(100); + + /* print sata device name */ + printf("%s ", sata->name); + + /* Wait PHY RDY signal changed for 500ms */ + ata_wait_register(®->hstatus, HSTATUS_PHY_RDY, + HSTATUS_PHY_RDY, 500); + + /* Check PHYRDY */ + val32 = in_le32(®->hstatus); + if (val32 & HSTATUS_PHY_RDY) { + sata->link = 1; + } else { + sata->link = 0; + printf("(No RDY)\n\r"); + return -EINVAL; + } + + /* Wait for signature updated, which is 1st D2H */ + ata_wait_register(®->hstatus, HSTATUS_SIGNATURE, + HSTATUS_SIGNATURE, 10000); + + if (val32 & HSTATUS_SIGNATURE) { + sig = in_le32(®->sig); + debug("Signature updated, the sig =%08x\n\r", sig); + sata->ata_device_type = ata_dev_classify(sig); + } + + /* Check the speed */ + val32 = in_le32(®->sstatus); + if ((val32 & SSTATUS_SPD_MASK) == SSTATUS_SPD_GEN1) + printf("(1.5 Gbps)\n\r"); + else if ((val32 & SSTATUS_SPD_MASK) == SSTATUS_SPD_GEN2) + printf("(3 Gbps)\n\r"); + + priv->fsl_sata = sata; + + return 0; +} + +static int fsl_ata_exec_ata_cmd(struct fsl_sata *sata, + struct sata_fis_h2d *cfis, + int is_ncq, int tag, + u8 *buffer, u32 len) +{ + cmd_hdr_entry_t *cmd_hdr; + cmd_desc_t *cmd_desc; + sata_fis_h2d_t *h2d; + prd_entry_t *prde; + u32 ext_c_ddc; + u32 prde_count; + u32 val32; + u32 ttl; + u32 der; + int i; + + fsl_sata_reg_t *reg = sata->reg_base; + + /* Check xfer length */ + if (len > SATA_HC_MAX_XFER_LEN) { + printf("max transfer length is 64MB\n\r"); + return 0; + } + + /* Setup the command descriptor */ + cmd_desc = sata->cmd_desc + tag; + + /* Get the pointer cfis of command descriptor */ + h2d = (sata_fis_h2d_t *)cmd_desc->cfis; + + /* Zero the cfis of command descriptor */ + memset((void *)h2d, 0, SATA_HC_CMD_DESC_CFIS_SIZE); + + /* Copy the cfis from user to command descriptor */ + h2d->fis_type = cfis->fis_type; + h2d->pm_port_c = cfis->pm_port_c; + h2d->command = cfis->command; + + h2d->features = cfis->features; + h2d->features_exp = cfis->features_exp; + + h2d->lba_low = cfis->lba_low; + h2d->lba_mid = cfis->lba_mid; + h2d->lba_high = cfis->lba_high; + h2d->lba_low_exp = cfis->lba_low_exp; + h2d->lba_mid_exp = cfis->lba_mid_exp; + h2d->lba_high_exp = cfis->lba_high_exp; + + if (!is_ncq) { + h2d->sector_count = cfis->sector_count; + h2d->sector_count_exp = cfis->sector_count_exp; + } else { /* NCQ */ + h2d->sector_count = (u8)(tag << 3); + } + + h2d->device = cfis->device; + h2d->control = cfis->control; + + /* Setup the PRD table */ + prde = (prd_entry_t *)cmd_desc->prdt; + memset((void *)prde, 0, sizeof(struct prdt)); + + prde_count = 0; + ttl = len; + for (i = 0; i < SATA_HC_MAX_PRD_DIRECT; i++) { + if (!len) + break; + prde->dba = cpu_to_le32((u32)buffer & ~0x3); + debug("dba = %08x\n\r", (u32)buffer); + + if (len < PRD_ENTRY_MAX_XFER_SZ) { + ext_c_ddc = PRD_ENTRY_DATA_SNOOP | len; + debug("ext_c_ddc1 = %08x, len = %08x\n\r", + ext_c_ddc, len); + prde->ext_c_ddc = cpu_to_le32(ext_c_ddc); + prde_count++; + prde++; + } else { + ext_c_ddc = PRD_ENTRY_DATA_SNOOP; /* 4M bytes */ + debug("ext_c_ddc2 = %08x, len = %08x\n\r", + ext_c_ddc, len); + prde->ext_c_ddc = cpu_to_le32(ext_c_ddc); + buffer += PRD_ENTRY_MAX_XFER_SZ; + len -= PRD_ENTRY_MAX_XFER_SZ; + prde_count++; + prde++; + } + } + + /* Setup the command slot of cmd hdr */ + cmd_hdr = (cmd_hdr_entry_t *)&sata->cmd_hdr->cmd_slot[tag]; + + cmd_hdr->cda = cpu_to_le32((u32)cmd_desc & ~0x3); + + val32 = prde_count << CMD_HDR_PRD_ENTRY_SHIFT; + val32 |= sizeof(sata_fis_h2d_t); + cmd_hdr->prde_fis_len = cpu_to_le32(val32); + + cmd_hdr->ttl = cpu_to_le32(ttl); + + if (!is_ncq) + val32 = CMD_HDR_ATTR_RES | CMD_HDR_ATTR_SNOOP; + else + val32 = CMD_HDR_ATTR_RES | CMD_HDR_ATTR_SNOOP | + CMD_HDR_ATTR_FPDMA; + + tag &= CMD_HDR_ATTR_TAG; + val32 |= tag; + + debug("attribute = %08x\n\r", val32); + cmd_hdr->attribute = cpu_to_le32(val32); + + /* Make sure cmd desc and cmd slot valid before command issue */ + sync(); + + /* PMP*/ + val32 = (u32)(h2d->pm_port_c & 0x0f); + out_le32(®->cqpmp, val32); + + /* Wait no active */ + if (ata_wait_register(®->car, (1 << tag), 0, 10000)) + printf("Wait no active time out\n\r"); + + /* Issue command */ + if (!(in_le32(®->cqr) & (1 << tag))) { + val32 = 1 << tag; + out_le32(®->cqr, val32); + } + + /* Wait command completed for 10s */ + if (ata_wait_register(®->ccr, (1 << tag), (1 << tag), 10000)) { + if (!is_ncq) + printf("Non-NCQ command time out\n\r"); + else + printf("NCQ command time out\n\r"); + } + + val32 = in_le32(®->cer); + + if (val32) { + fsl_sata_dump_sfis((struct sata_fis_d2h *)cmd_desc->sfis); + printf("CE at device\n\r"); + fsl_sata_dump_regs(reg); + der = in_le32(®->der); + out_le32(®->cer, val32); + out_le32(®->der, der); + } + + /* Clear complete flags */ + val32 = in_le32(®->ccr); + out_le32(®->ccr, val32); + + return len; +} + +static int fsl_sata_exec_cmd(struct fsl_sata *sata, struct sata_fis_h2d *cfis, + enum cmd_type command_type, int tag, u8 *buffer, + u32 len) +{ + int rc; + + if (tag > SATA_HC_MAX_CMD || tag < 0) { + printf("tag is out of range, tag=%d\n\r", tag); + return -1; + } + + switch (command_type) { + case CMD_ATA: + rc = fsl_ata_exec_ata_cmd(sata, cfis, 0, tag, buffer, len); + return rc; + case CMD_NCQ: + rc = fsl_ata_exec_ata_cmd(sata, cfis, 1, tag, buffer, len); + return rc; + case CMD_ATAPI: + case CMD_VENDOR_BIST: + case CMD_BIST: + printf("not support now\n\r"); + return -1; + default: + break; + } + + return -1; +} + +static void fsl_sata_identify(fsl_sata_t *sata, u16 *id) +{ + struct sata_fis_h2d h2d, *cfis = &h2d; + + memset(cfis, 0, sizeof(struct sata_fis_h2d)); + + cfis->fis_type = SATA_FIS_TYPE_REGISTER_H2D; + cfis->pm_port_c = 0x80; /* is command */ + cfis->command = ATA_CMD_ID_ATA; + + fsl_sata_exec_cmd(sata, cfis, CMD_ATA, 0, (u8 *)id, ATA_ID_WORDS * 2); + ata_swap_buf_le16(id, ATA_ID_WORDS); +} + +static void fsl_sata_xfer_mode(fsl_sata_t *sata, u16 *id) +{ + sata->pio = id[ATA_ID_PIO_MODES]; + sata->mwdma = id[ATA_ID_MWDMA_MODES]; + sata->udma = id[ATA_ID_UDMA_MODES]; + debug("pio %04x, mwdma %04x, udma %04x\n\r", sata->pio, + sata->mwdma, sata->udma); +} + +static void fsl_sata_init_wcache(fsl_sata_t *sata, u16 *id) +{ + if (ata_id_has_wcache(id) && ata_id_wcache_enabled(id)) + sata->wcache = 1; + if (ata_id_has_flush(id)) + sata->flush = 1; + if (ata_id_has_flush_ext(id)) + sata->flush_ext = 1; +} + +static void fsl_sata_set_features(fsl_sata_t *sata) +{ + struct sata_fis_h2d h2d, *cfis = &h2d; + u8 udma_cap; + + memset(cfis, 0, sizeof(struct sata_fis_h2d)); + + cfis->fis_type = SATA_FIS_TYPE_REGISTER_H2D; + cfis->pm_port_c = 0x80; /* is command */ + cfis->command = ATA_CMD_SET_FEATURES; + cfis->features = SETFEATURES_XFER; + + /* First check the device capablity */ + udma_cap = (u8)(sata->udma & 0xff); + debug("udma_cap %02x\n\r", udma_cap); + + if (udma_cap == ATA_UDMA6) + cfis->sector_count = XFER_UDMA_6; + if (udma_cap == ATA_UDMA5) + cfis->sector_count = XFER_UDMA_5; + if (udma_cap == ATA_UDMA4) + cfis->sector_count = XFER_UDMA_4; + if (udma_cap == ATA_UDMA3) + cfis->sector_count = XFER_UDMA_3; + + fsl_sata_exec_cmd(sata, cfis, CMD_ATA, 0, NULL, 0); +} + +static u32 fsl_sata_rw_cmd(fsl_sata_t *sata, u32 start, u32 blkcnt, + u8 *buffer, int is_write) +{ + struct sata_fis_h2d h2d, *cfis = &h2d; + u32 block; + + block = start; + + memset(cfis, 0, sizeof(struct sata_fis_h2d)); + + cfis->fis_type = SATA_FIS_TYPE_REGISTER_H2D; + cfis->pm_port_c = 0x80; /* is command */ + cfis->command = (is_write) ? ATA_CMD_WRITE : ATA_CMD_READ; + cfis->device = ATA_LBA; + + cfis->device |= (block >> 24) & 0xf; + cfis->lba_high = (block >> 16) & 0xff; + cfis->lba_mid = (block >> 8) & 0xff; + cfis->lba_low = block & 0xff; + cfis->sector_count = (u8)(blkcnt & 0xff); + + fsl_sata_exec_cmd(sata, cfis, CMD_ATA, 0, buffer, + ATA_SECT_SIZE * blkcnt); + return blkcnt; +} + +static void fsl_sata_flush_cache(fsl_sata_t *sata) +{ + struct sata_fis_h2d h2d, *cfis = &h2d; + + memset(cfis, 0, sizeof(struct sata_fis_h2d)); + + cfis->fis_type = SATA_FIS_TYPE_REGISTER_H2D; + cfis->pm_port_c = 0x80; /* is command */ + cfis->command = ATA_CMD_FLUSH; + + fsl_sata_exec_cmd(sata, cfis, CMD_ATA, 0, NULL, 0); +} + +static u32 fsl_sata_rw_cmd_ext(fsl_sata_t *sata, u32 start, + u32 blkcnt, u8 *buffer, int is_write) +{ + struct sata_fis_h2d h2d, *cfis = &h2d; + u64 block; + + block = (u64)start; + + memset(cfis, 0, sizeof(struct sata_fis_h2d)); + + cfis->fis_type = SATA_FIS_TYPE_REGISTER_H2D; + cfis->pm_port_c = 0x80; /* is command */ + + cfis->command = (is_write) ? ATA_CMD_WRITE_EXT + : ATA_CMD_READ_EXT; + + cfis->lba_high_exp = (block >> 40) & 0xff; + cfis->lba_mid_exp = (block >> 32) & 0xff; + cfis->lba_low_exp = (block >> 24) & 0xff; + cfis->lba_high = (block >> 16) & 0xff; + cfis->lba_mid = (block >> 8) & 0xff; + cfis->lba_low = block & 0xff; + cfis->device = ATA_LBA; + cfis->sector_count_exp = (blkcnt >> 8) & 0xff; + cfis->sector_count = blkcnt & 0xff; + + fsl_sata_exec_cmd(sata, cfis, CMD_ATA, 0, buffer, + ATA_SECT_SIZE * blkcnt); + return blkcnt; +} + +static u32 fsl_sata_rw_ncq_cmd(fsl_sata_t *sata, u32 start, u32 blkcnt, + u8 *buffer, + int is_write) +{ + struct sata_fis_h2d h2d, *cfis = &h2d; + int ncq_channel; + u64 block; + + if (sata->lba48 != 1) { + printf("execute FPDMA command on non-LBA48 hard disk\n\r"); + return -1; + } + + block = (u64)start; + + memset(cfis, 0, sizeof(struct sata_fis_h2d)); + + cfis->fis_type = SATA_FIS_TYPE_REGISTER_H2D; + cfis->pm_port_c = 0x80; /* is command */ + + cfis->command = (is_write) ? ATA_CMD_FPDMA_WRITE + : ATA_CMD_FPDMA_READ; + + cfis->lba_high_exp = (block >> 40) & 0xff; + cfis->lba_mid_exp = (block >> 32) & 0xff; + cfis->lba_low_exp = (block >> 24) & 0xff; + cfis->lba_high = (block >> 16) & 0xff; + cfis->lba_mid = (block >> 8) & 0xff; + cfis->lba_low = block & 0xff; + + cfis->device = ATA_LBA; + cfis->features_exp = (blkcnt >> 8) & 0xff; + cfis->features = blkcnt & 0xff; + + if (sata->queue_depth >= SATA_HC_MAX_CMD) + ncq_channel = SATA_HC_MAX_CMD - 1; + else + ncq_channel = sata->queue_depth - 1; + + /* Use the latest queue */ + fsl_sata_exec_cmd(sata, cfis, CMD_NCQ, ncq_channel, buffer, + ATA_SECT_SIZE * blkcnt); + return blkcnt; +} + +static void fsl_sata_flush_cache_ext(fsl_sata_t *sata) +{ + struct sata_fis_h2d h2d, *cfis = &h2d; + + memset(cfis, 0, sizeof(struct sata_fis_h2d)); + + cfis->fis_type = SATA_FIS_TYPE_REGISTER_H2D; + cfis->pm_port_c = 0x80; /* is command */ + cfis->command = ATA_CMD_FLUSH_EXT; + + fsl_sata_exec_cmd(sata, cfis, CMD_ATA, 0, NULL, 0); +} + +static u32 ata_low_level_rw_lba48(fsl_sata_t *sata, u32 blknr, lbaint_t blkcnt, + const void *buffer, int is_write) +{ + u32 start, blks; + u8 *addr; + int max_blks; + + start = blknr; + blks = blkcnt; + addr = (u8 *)buffer; + + max_blks = ATA_MAX_SECTORS_LBA48; + do { + if (blks > max_blks) { + if (sata->dma_flag != FLAGS_FPDMA) + fsl_sata_rw_cmd_ext(sata, start, max_blks, + addr, is_write); + else + fsl_sata_rw_ncq_cmd(sata, start, max_blks, + addr, is_write); + start += max_blks; + blks -= max_blks; + addr += ATA_SECT_SIZE * max_blks; + } else { + if (sata->dma_flag != FLAGS_FPDMA) + fsl_sata_rw_cmd_ext(sata, start, blks, + addr, is_write); + else + fsl_sata_rw_ncq_cmd(sata, start, blks, + addr, is_write); + start += blks; + blks = 0; + addr += ATA_SECT_SIZE * blks; + } + } while (blks != 0); + + return blks; +} + +static u32 ata_low_level_rw_lba28(fsl_sata_t *sata, u32 blknr, u32 blkcnt, + const void *buffer, int is_write) +{ + u32 start, blks; + u8 *addr; + int max_blks; + + start = blknr; + blks = blkcnt; + addr = (u8 *)buffer; + + max_blks = ATA_MAX_SECTORS; + do { + if (blks > max_blks) { + fsl_sata_rw_cmd(sata, start, max_blks, addr, is_write); + start += max_blks; + blks -= max_blks; + addr += ATA_SECT_SIZE * max_blks; + } else { + fsl_sata_rw_cmd(sata, start, blks, addr, is_write); + start += blks; + blks = 0; + addr += ATA_SECT_SIZE * blks; + } + } while (blks != 0); + + return blks; +} + +/* + * SATA interface between low level driver and command layer + */ +static int sata_read(fsl_sata_t *sata, ulong blknr, lbaint_t blkcnt, + void *buffer) +{ + u32 rc; + + if (sata->lba48) + rc = ata_low_level_rw_lba48(sata, blknr, blkcnt, buffer, + READ_CMD); + else + rc = ata_low_level_rw_lba28(sata, blknr, blkcnt, buffer, + READ_CMD); + return rc; +} + +static int sata_write(fsl_sata_t *sata, ulong blknr, lbaint_t blkcnt, + const void *buffer) +{ + u32 rc; + + if (sata->lba48) { + rc = ata_low_level_rw_lba48(sata, blknr, blkcnt, buffer, + WRITE_CMD); + if (sata->wcache && sata->flush_ext) + fsl_sata_flush_cache_ext(sata); + } else { + rc = ata_low_level_rw_lba28(sata, blknr, blkcnt, buffer, + WRITE_CMD); + if (sata->wcache && sata->flush) + fsl_sata_flush_cache(sata); + } + + return rc; +} + +int sata_getinfo(fsl_sata_t *sata, u16 *id) +{ + /* if no detected link */ + if (!sata->link) + return -EINVAL; + +#ifdef CONFIG_LBA48 + /* Check if support LBA48 */ + if (ata_id_has_lba48(id)) { + sata->lba48 = 1; + debug("Device support LBA48\n\r"); + } else { + debug("Device supports LBA28\n\r"); + } +#endif + + /* Get the NCQ queue depth from device */ + sata->queue_depth = ata_id_queue_depth(id); + + /* Get the xfer mode from device */ + fsl_sata_xfer_mode(sata, id); + + /* Get the write cache status from device */ + fsl_sata_init_wcache(sata, id); + + /* Set the xfer mode to highest speed */ + fsl_sata_set_features(sata); + + return 0; +} + +static int fsl_scsi_exec(fsl_sata_t *sata, struct scsi_cmd *pccb, + bool is_write) +{ + int ret; + u32 temp; + u16 blocks = 0; + lbaint_t start = 0; + u8 *buffer = pccb->pdata; + + /* Retrieve the base LBA number from the ccb structure. */ + if (pccb->cmd[0] == SCSI_READ16) { + memcpy(&start, pccb->cmd + 2, 8); + start = be64_to_cpu(start); + } else { + memcpy(&temp, pccb->cmd + 2, 4); + start = be32_to_cpu(temp); + } + + if (pccb->cmd[0] == SCSI_READ16) + blocks = (((u16)pccb->cmd[13]) << 8) | ((u16)pccb->cmd[14]); + else + blocks = (((u16)pccb->cmd[7]) << 8) | ((u16)pccb->cmd[8]); + + debug("scsi_ahci: %s %u blocks starting from lba 0x" LBAFU "\n", + is_write ? "write" : "read", blocks, start); + + if (is_write) + ret = sata_write(sata, start, blocks, buffer); + else + ret = sata_read(sata, start, blocks, buffer); + + return ret; +} + +static char *fsl_ata_id_strcpy(u16 *target, u16 *src, int len) +{ + int i; + + for (i = 0; i < len / 2; i++) + target[i] = src[i]; + + return (char *)target; +} + +static int fsl_ata_scsiop_inquiry(struct ahci_uc_priv *uc_priv, + struct scsi_cmd *pccb, + fsl_sata_t *sata) +{ + u8 port; + u16 *idbuf; + + ALLOC_CACHE_ALIGN_BUFFER(u16, tmpid, ATA_ID_WORDS); + + /* Clean ccb data buffer */ + memset(pccb->pdata, 0, pccb->datalen); + + if (pccb->datalen <= 35) + return 0; + + /* Read id from sata */ + port = pccb->target; + + fsl_sata_identify(sata, (u16 *)tmpid); + + if (!uc_priv->ataid[port]) { + uc_priv->ataid[port] = malloc(ATA_ID_WORDS * 2); + if (!uc_priv->ataid[port]) { + printf("%s: No memory for ataid[port]\n", __func__); + return -ENOMEM; + } + } + + idbuf = uc_priv->ataid[port]; + + memcpy(idbuf, tmpid, ATA_ID_WORDS * 2); + + memcpy(&pccb->pdata[8], "ATA ", 8); + fsl_ata_id_strcpy((u16 *)&pccb->pdata[16], &idbuf[ATA_ID_PROD], 16); + fsl_ata_id_strcpy((u16 *)&pccb->pdata[32], &idbuf[ATA_ID_FW_REV], 4); + + sata_getinfo(sata, (u16 *)idbuf); +#ifdef DEBUG + ata_dump_id(idbuf); +#endif + return 0; +} + +/* + * SCSI READ CAPACITY10 command operation. + */ +static int fsl_ata_scsiop_read_capacity10(struct ahci_uc_priv *uc_priv, + struct scsi_cmd *pccb) +{ + u32 cap; + u64 cap64; + u32 block_size; + + if (!uc_priv->ataid[pccb->target]) { + printf("scsi_ahci: SCSI READ CAPACITY10 command failure." + "\tNo ATA info!\n" + "\tPlease run SCSI command INQUIRY first!\n"); + return -EPERM; + } + + cap64 = ata_id_n_sectors(uc_priv->ataid[pccb->target]); + if (cap64 > 0x100000000ULL) + cap64 = 0xffffffff; + + cap = cpu_to_be32(cap64); + memcpy(pccb->pdata, &cap, sizeof(cap)); + + block_size = cpu_to_be32((u32)512); + memcpy(&pccb->pdata[4], &block_size, 4); + + return 0; +} + +/* + * SCSI READ CAPACITY16 command operation. + */ +static int fsl_ata_scsiop_read_capacity16(struct ahci_uc_priv *uc_priv, + struct scsi_cmd *pccb) +{ + u64 cap; + u64 block_size; + + if (!uc_priv->ataid[pccb->target]) { + printf("scsi_ahci: SCSI READ CAPACITY16 command failure." + "\tNo ATA info!\n" + "\tPlease run SCSI command INQUIRY first!\n"); + return -EPERM; + } + + cap = ata_id_n_sectors(uc_priv->ataid[pccb->target]); + cap = cpu_to_be64(cap); + memcpy(pccb->pdata, &cap, sizeof(cap)); + + block_size = cpu_to_be64((u64)512); + memcpy(&pccb->pdata[8], &block_size, 8); + + return 0; +} + +/* + * SCSI TEST UNIT READY command operation. + */ +static int fsl_ata_scsiop_test_unit_ready(struct ahci_uc_priv *uc_priv, + struct scsi_cmd *pccb) +{ + return (uc_priv->ataid[pccb->target]) ? 0 : -EPERM; +} + +static int fsl_ahci_scsi_exec(struct udevice *dev, struct scsi_cmd *pccb) +{ + struct ahci_uc_priv *uc_priv = dev_get_uclass_priv(dev->parent); + struct fsl_ahci_priv *priv = dev_get_priv(dev->parent); + fsl_sata_t *sata = priv->fsl_sata; + int ret; + + switch (pccb->cmd[0]) { + case SCSI_READ16: + case SCSI_READ10: + ret = fsl_scsi_exec(sata, pccb, 0); + break; + case SCSI_WRITE10: + ret = fsl_scsi_exec(sata, pccb, 1); + break; + case SCSI_RD_CAPAC10: + ret = fsl_ata_scsiop_read_capacity10(uc_priv, pccb); + break; + case SCSI_RD_CAPAC16: + ret = fsl_ata_scsiop_read_capacity16(uc_priv, pccb); + break; + case SCSI_TST_U_RDY: + ret = fsl_ata_scsiop_test_unit_ready(uc_priv, pccb); + break; + case SCSI_INQUIRY: + ret = fsl_ata_scsiop_inquiry(uc_priv, pccb, sata); + break; + default: + printf("Unsupport SCSI command 0x%02x\n", pccb->cmd[0]); + return -ENOTSUPP; + } + + if (ret) { + debug("SCSI command 0x%02x ret errno %d\n", pccb->cmd[0], ret); + return ret; + } + + return 0; +} + +static int fsl_ahci_probe(struct udevice *dev) +{ + struct fsl_ahci_priv *priv = dev_get_priv(dev); + struct udevice *child_dev; + struct scsi_platdata *uc_plat; + + device_find_first_child(dev, &child_dev); + if (!child_dev) + return -ENODEV; + uc_plat = dev_get_uclass_platdata(child_dev); + uc_plat->base = priv->base; + uc_plat->max_lun = 1; + uc_plat->max_id = 1; + + return init_sata(priv); +} + +struct scsi_ops fsl_scsi_ops = { + .exec = fsl_ahci_scsi_exec, +}; + +static const struct udevice_id fsl_ahci_ids[] = { + { .compatible = "fsl,pq-sata-v2" }, + { } +}; + +U_BOOT_DRIVER(fsl_ahci_scsi) = { + .name = "fsl_ahci_scsi", + .id = UCLASS_SCSI, + .ops = &fsl_scsi_ops, +}; + +U_BOOT_DRIVER(fsl_ahci) = { + .name = "fsl_ahci", + .id = UCLASS_AHCI, + .of_match = fsl_ahci_ids, + .bind = fsl_ahci_bind, + .ofdata_to_platdata = fsl_ahci_ofdata_to_platdata, + .probe = fsl_ahci_probe, + .priv_auto_alloc_size = sizeof(struct fsl_ahci_priv), +}; diff --git a/drivers/ata/fsl_sata.h b/drivers/ata/fsl_sata.h index 1e2da10b02..a4ee83d187 100644 --- a/drivers/ata/fsl_sata.h +++ b/drivers/ata/fsl_sata.h @@ -312,6 +312,7 @@ typedef struct fsl_sata { int wcache; int flush; int flush_ext; + u32 dma_flag; } fsl_sata_t;
#define READ_CMD 0
This patch is to add sata node for t2080qds
arch/powerpc/dts/t2080.dtsi | 16 ++++++++++++++++ 1 file changed, 16 insertions(+)
diff --git a/arch/powerpc/dts/t2080.dtsi b/arch/powerpc/dts/t2080.dtsi index 666601ed49..d2bebb08b6 100644 --- a/arch/powerpc/dts/t2080.dtsi +++ b/arch/powerpc/dts/t2080.dtsi @@ -87,5 +87,21 @@ dr_mode = "host"; phy_type = "utmi"; }; + + sata0: sata@220000 { + compatible = "fsl,pq-sata-v2"; + reg = <0x220000 0x1000>; + interrupts = <68 0x2 0 0>; + sata-number = <0x0>; + sata-fpdma = <0x0>; + }; + + sata1: sata@221000 { + compatible = "fsl,pq-sata-v2"; + reg = <0x221000 0x1000>; + interrupts = <69 0x2 0 0>; + sata-number = <0x0>; + sata-fpdma = <0x0>; + }; }; };
-----Original Message----- From: Peng Ma Sent: Wednesday, March 27, 2019 2:53 PM To: Prabhakar Kushwaha prabhakar.kushwaha@nxp.com; Shengzhou Liu shengzhou.liu@nxp.com; Ruchika Gupta ruchika.gupta@nxp.com Cc: Yinbo Zhu yinbo.zhu@nxp.com; sjg@chromium.org; Jagdish Gediya jagdish.gediya@nxp.com; York Sun york.sun@nxp.com; bmeng.cn@gmail.com; sr@denx.de; make@marvell.com; Andy Tang andy.tang@nxp.com; u-boot@lists.denx.de; Peng Ma peng.ma@nxp.com Subject: [PATCH 2/4] ppc: t2080qds: add sata node
This patch has been applied to u-boot-mpc85xx, awaiting upstream.
--pk
arch/powerpc/cpu/mpc85xx/Kconfig | 4 +--- 1 file changed, 1 insertion(+), 3 deletions(-)
diff --git a/arch/powerpc/cpu/mpc85xx/Kconfig b/arch/powerpc/cpu/mpc85xx/Kconfig index 0057f195b3..aebf168a89 100644 --- a/arch/powerpc/cpu/mpc85xx/Kconfig +++ b/arch/powerpc/cpu/mpc85xx/Kconfig @@ -352,7 +352,6 @@ config TARGET_T2080QDS select PHYS_64BIT select FSL_DDR_FIRST_SLOT_QUAD_CAPABLE select FSL_DDR_INTERACTIVE - imply CMD_SATA
config TARGET_T2080RDB bool "Support T2080RDB" @@ -361,6 +360,7 @@ config TARGET_T2080RDB select SUPPORT_SPL select PHYS_64BIT imply CMD_SATA + imply FSL_SATA imply PANIC_HANG
config TARGET_T2081QDS @@ -1081,10 +1081,8 @@ config ARCH_T2080 select SYS_FSL_SEC_COMPAT_4 select SYS_PPC64 select FSL_IFC - imply CMD_SATA imply CMD_NAND imply CMD_REGINFO - imply FSL_SATA
config ARCH_T2081 bool
-----Original Message----- From: Peng Ma Sent: Wednesday, March 27, 2019 2:54 PM To: Prabhakar Kushwaha prabhakar.kushwaha@nxp.com; Shengzhou Liu shengzhou.liu@nxp.com; Ruchika Gupta ruchika.gupta@nxp.com Cc: Yinbo Zhu yinbo.zhu@nxp.com; sjg@chromium.org; Jagdish Gediya jagdish.gediya@nxp.com; York Sun york.sun@nxp.com; bmeng.cn@gmail.com; sr@denx.de; make@marvell.com; Andy Tang andy.tang@nxp.com; u-boot@lists.denx.de; Peng Ma peng.ma@nxp.com Subject: [PATCH 3/4] powerpc: mpc85xx: delete FSL_SATA for T2080QDS board.
--pk
This patch is to enable sata DM for T2080QDS in uboot
configs/T2080QDS_NAND_defconfig | 11 +++++++---- configs/T2080QDS_SDCARD_defconfig | 11 +++++++---- configs/T2080QDS_SECURE_BOOT_defconfig | 16 +++++++++------- configs/T2080QDS_SPIFLASH_defconfig | 11 +++++++---- configs/T2080QDS_SRIO_PCIE_BOOT_defconfig | 18 ++++++++++-------- configs/T2080QDS_defconfig | 11 +++++++---- 6 files changed, 47 insertions(+), 31 deletions(-)
diff --git a/configs/T2080QDS_NAND_defconfig b/configs/T2080QDS_NAND_defconfig index bbd2f3e781..e67a50251a 100644 --- a/configs/T2080QDS_NAND_defconfig +++ b/configs/T2080QDS_NAND_defconfig @@ -7,6 +7,7 @@ CONFIG_SPL_DRIVERS_MISC_SUPPORT=y CONFIG_SPL=y CONFIG_MPC85xx=y CONFIG_TARGET_T2080QDS=y +CONFIG_AHCI=y CONFIG_FIT=y CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y @@ -38,7 +39,10 @@ CONFIG_MTDPARTS_DEFAULT="mtdparts=fe8000000.nor:1m(uboot),5m(kernel),128k(dtb),9 CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="t2080qds" CONFIG_ENV_IS_IN_NAND=y +CONFIG_DM=y +CONFIG_FSL_AHCI=y CONFIG_FSL_CAAM=y +CONFIG_DM_MMC=y CONFIG_FSL_ESDHC=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y @@ -56,12 +60,11 @@ CONFIG_PHYLIB=y CONFIG_PHY_AQUANTIA=y CONFIG_E1000=y CONFIG_MII=y +CONFIG_SCSI=y +CONFIG_DM_SCSI=y CONFIG_SYS_NS16550=y CONFIG_SPI=y CONFIG_FSL_ESPI=y CONFIG_USB=y -CONFIG_USB_STORAGE=y CONFIG_DM_USB=y -CONFIG_DM_MMC=y -CONFIG_BLK=y -CONFIG_DM=y +CONFIG_USB_STORAGE=y diff --git a/configs/T2080QDS_SDCARD_defconfig b/configs/T2080QDS_SDCARD_defconfig index df66599475..5f681d6d0f 100644 --- a/configs/T2080QDS_SDCARD_defconfig +++ b/configs/T2080QDS_SDCARD_defconfig @@ -8,6 +8,7 @@ CONFIG_SPL_DRIVERS_MISC_SUPPORT=y CONFIG_SPL=y CONFIG_MPC85xx=y CONFIG_TARGET_T2080QDS=y +CONFIG_AHCI=y CONFIG_FIT=y CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y @@ -38,7 +39,10 @@ CONFIG_MTDPARTS_DEFAULT="mtdparts=fe8000000.nor:1m(uboot),5m(kernel),128k(dtb),9 CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="t2080qds" CONFIG_ENV_IS_IN_MMC=y +CONFIG_DM=y +CONFIG_FSL_AHCI=y CONFIG_FSL_CAAM=y +CONFIG_DM_MMC=y CONFIG_FSL_ESDHC=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y @@ -55,12 +59,11 @@ CONFIG_PHYLIB=y CONFIG_PHY_AQUANTIA=y CONFIG_E1000=y CONFIG_MII=y +CONFIG_SCSI=y +CONFIG_DM_SCSI=y CONFIG_SYS_NS16550=y CONFIG_SPI=y CONFIG_FSL_ESPI=y CONFIG_USB=y -CONFIG_USB_STORAGE=y CONFIG_DM_USB=y -CONFIG_DM_MMC=y -CONFIG_BLK=y -CONFIG_DM=y +CONFIG_USB_STORAGE=y diff --git a/configs/T2080QDS_SECURE_BOOT_defconfig b/configs/T2080QDS_SECURE_BOOT_defconfig index 766ee7c4ac..f6284fede0 100644 --- a/configs/T2080QDS_SECURE_BOOT_defconfig +++ b/configs/T2080QDS_SECURE_BOOT_defconfig @@ -3,6 +3,8 @@ CONFIG_SYS_TEXT_BASE=0xEFF40000 CONFIG_SECURE_BOOT=y CONFIG_MPC85xx=y CONFIG_TARGET_T2080QDS=y +CONFIG_MPC85XX_HAVE_RESET_VECTOR=y +CONFIG_AHCI=y # CONFIG_SYS_MALLOC_F is not set CONFIG_FIT=y CONFIG_FIT_VERBOSE=y @@ -26,7 +28,11 @@ CONFIG_CMD_FAT=y CONFIG_CMD_MTDPARTS=y CONFIG_MTDIDS_DEFAULT="nor0=fe8000000.nor,nand0=fff800000.flash,spi0=spife110000.0" CONFIG_MTDPARTS_DEFAULT="mtdparts=fe8000000.nor:1m(uboot),5m(kernel),128k(dtb),96m(fs),-(user);fff800000.flash:1m(uboot),5m(kernel),128k(dtb),96m(fs),-(user);spife110000.0:1m(uboot),5m(kernel),128k(dtb),-(user)" +CONFIG_OF_CONTROL=y +CONFIG_DEFAULT_DEVICE_TREE="t2080qds" CONFIG_DM=y +CONFIG_FSL_AHCI=y +CONFIG_DM_MMC=y CONFIG_FSL_ESDHC=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y @@ -43,18 +49,14 @@ CONFIG_PHYLIB=y CONFIG_PHY_AQUANTIA=y CONFIG_E1000=y CONFIG_MII=y +CONFIG_SCSI=y +CONFIG_DM_SCSI=y CONFIG_SYS_NS16550=y CONFIG_SPI=y CONFIG_FSL_ESPI=y CONFIG_USB=y -CONFIG_USB_STORAGE=y CONFIG_DM_USB=y +CONFIG_USB_STORAGE=y CONFIG_RSA=y CONFIG_SPL_RSA=y CONFIG_RSA_SOFTWARE_EXP=y -CONFIG_OF_LIBFDT=y -CONFIG_MPC85XX_HAVE_RESET_VECTOR=y -CONFIG_DEFAULT_DEVICE_TREE="t2080qds" -CONFIG_DM_MMC=y -CONFIG_BLK=y -CONFIG_OF_CONTROL=y diff --git a/configs/T2080QDS_SPIFLASH_defconfig b/configs/T2080QDS_SPIFLASH_defconfig index 43c50fb27b..4fe737ddb5 100644 --- a/configs/T2080QDS_SPIFLASH_defconfig +++ b/configs/T2080QDS_SPIFLASH_defconfig @@ -9,6 +9,7 @@ CONFIG_SPL_SPI_FLASH_SUPPORT=y CONFIG_SPL_SPI_SUPPORT=y CONFIG_MPC85xx=y CONFIG_TARGET_T2080QDS=y +CONFIG_AHCI=y CONFIG_FIT=y CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y @@ -39,7 +40,10 @@ CONFIG_MTDPARTS_DEFAULT="mtdparts=fe8000000.nor:1m(uboot),5m(kernel),128k(dtb),9 CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="t2080qds" CONFIG_ENV_IS_IN_SPI_FLASH=y +CONFIG_DM=y +CONFIG_FSL_AHCI=y CONFIG_FSL_CAAM=y +CONFIG_DM_MMC=y CONFIG_FSL_ESDHC=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y @@ -56,12 +60,11 @@ CONFIG_PHYLIB=y CONFIG_PHY_AQUANTIA=y CONFIG_E1000=y CONFIG_MII=y +CONFIG_SCSI=y +CONFIG_DM_SCSI=y CONFIG_SYS_NS16550=y CONFIG_SPI=y CONFIG_FSL_ESPI=y CONFIG_USB=y -CONFIG_USB_STORAGE=y CONFIG_DM_USB=y -CONFIG_DM_MMC=y -CONFIG_BLK=y -CONFIG_DM=y +CONFIG_USB_STORAGE=y diff --git a/configs/T2080QDS_SRIO_PCIE_BOOT_defconfig b/configs/T2080QDS_SRIO_PCIE_BOOT_defconfig index 869f203160..f18759f9fd 100644 --- a/configs/T2080QDS_SRIO_PCIE_BOOT_defconfig +++ b/configs/T2080QDS_SRIO_PCIE_BOOT_defconfig @@ -2,6 +2,8 @@ CONFIG_PPC=y CONFIG_SYS_TEXT_BASE=0xFFF40000 CONFIG_MPC85xx=y CONFIG_TARGET_T2080QDS=y +CONFIG_MPC85XX_HAVE_RESET_VECTOR=y +CONFIG_AHCI=y CONFIG_FIT=y CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y @@ -22,8 +24,13 @@ CONFIG_CMD_PING=y CONFIG_MP=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +CONFIG_OF_CONTROL=y +CONFIG_DEFAULT_DEVICE_TREE="t2080qds" CONFIG_ENV_IS_IN_REMOTE=y +CONFIG_DM=y +CONFIG_FSL_AHCI=y CONFIG_FSL_CAAM=y +CONFIG_DM_MMC=y CONFIG_FSL_ESDHC=y CONFIG_SPI_FLASH=y CONFIG_SF_DEFAULT_MODE=0 @@ -35,16 +42,11 @@ CONFIG_PHYLIB=y CONFIG_PHY_AQUANTIA=y CONFIG_E1000=y CONFIG_MII=y +CONFIG_SCSI=y +CONFIG_DM_SCSI=y CONFIG_SYS_NS16550=y CONFIG_SPI=y CONFIG_FSL_ESPI=y CONFIG_USB=y -CONFIG_USB_STORAGE=y CONFIG_DM_USB=y -CONFIG_OF_LIBFDT=y -CONFIG_MPC85XX_HAVE_RESET_VECTOR=y -CONFIG_OF_CONTROL=y -CONFIG_DEFAULT_DEVICE_TREE="t2080qds" -CONFIG_DM_MMC=y -CONFIG_BLK=y -CONFIG_DM=y +CONFIG_USB_STORAGE=y diff --git a/configs/T2080QDS_defconfig b/configs/T2080QDS_defconfig index 28dad83302..8166c13b17 100644 --- a/configs/T2080QDS_defconfig +++ b/configs/T2080QDS_defconfig @@ -3,6 +3,7 @@ CONFIG_SYS_TEXT_BASE=0xEFF40000 CONFIG_MPC85xx=y CONFIG_TARGET_T2080QDS=y CONFIG_MPC85XX_HAVE_RESET_VECTOR=y +CONFIG_AHCI=y CONFIG_FIT=y CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y @@ -28,7 +29,10 @@ CONFIG_MTDPARTS_DEFAULT="mtdparts=fe8000000.nor:1m(uboot),5m(kernel),128k(dtb),9 CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="t2080qds" CONFIG_ENV_IS_IN_FLASH=y +CONFIG_DM=y +CONFIG_FSL_AHCI=y CONFIG_FSL_CAAM=y +CONFIG_DM_MMC=y CONFIG_FSL_ESDHC=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y @@ -45,12 +49,11 @@ CONFIG_PHYLIB=y CONFIG_PHY_AQUANTIA=y CONFIG_E1000=y CONFIG_MII=y +CONFIG_SCSI=y +CONFIG_DM_SCSI=y CONFIG_SYS_NS16550=y CONFIG_SPI=y CONFIG_FSL_ESPI=y CONFIG_USB=y -CONFIG_USB_STORAGE=y -CONFIG_DM_MMC=y -CONFIG_BLK=y -CONFIG_DM=y CONFIG_DM_USB=y +CONFIG_USB_STORAGE=y
-----Original Message----- From: Peng Ma Sent: Wednesday, March 27, 2019 2:54 PM To: Prabhakar Kushwaha prabhakar.kushwaha@nxp.com; Shengzhou Liu shengzhou.liu@nxp.com; Ruchika Gupta ruchika.gupta@nxp.com Cc: Yinbo Zhu yinbo.zhu@nxp.com; sjg@chromium.org; Jagdish Gediya jagdish.gediya@nxp.com; York Sun york.sun@nxp.com; bmeng.cn@gmail.com; sr@denx.de; make@marvell.com; Andy Tang andy.tang@nxp.com; u-boot@lists.denx.de; Peng Ma peng.ma@nxp.com Subject: [PATCH 4/4] configs: enable sata device module in T2080QDS
--pk
depends on:
Will this patch series replace the old fsl_sata.c driver? If yes, could you remove this driver as well in this series?
Thanks, Stefan
+config FSL_AHCI
- bool "Enable Freescale AHCI driver support"
- select SCSI_AHCI
- depends on AHCI
- depends on DM_SCSI
- help
- config DWC_AHSATA bool "Enable DWC AHSATA driver support" select LIBATA
- NXP PPC SATA platform driver
- (C) Copyright 2019 NXP, Inc.
- u32 base;
- u32 flag;
- u32 number;
- fsl_sata_t *fsl_sata;
- return device_bind_driver(dev, "fsl_ahci_scsi", "fsl_ahci_scsi", NULL);
- struct fsl_ahci_priv *priv = dev_get_priv(dev);
- priv->number = dev_read_u32_default(dev, "sata-number", -1);
- priv->flag = dev_read_u32_default(dev, "sata-fpdma", -1);
- priv->base = dev_read_addr(dev);
- if (priv->base == FDT_ADDR_T_NONE)
return -EINVAL;
- int i;
- for (i = 0; ((in_le32(addr) & mask) != val) && i < timeout_msec; i++)
mdelay(1);
- return (i < timeout_msec) ? 0 : -1;
- printf("Status FIS dump:\n\r");
- printf("fis_type: %02x\n\r", s->fis_type);
- printf("pm_port_i: %02x\n\r", s->pm_port_i);
- printf("status: %02x\n\r", s->status);
- printf("error: %02x\n\r", s->error);
- printf("lba_low: %02x\n\r", s->lba_low);
- printf("lba_mid: %02x\n\r", s->lba_mid);
- printf("lba_high: %02x\n\r", s->lba_high);
- printf("device: %02x\n\r", s->device);
- printf("lba_low_exp: %02x\n\r", s->lba_low_exp);
- printf("lba_mid_exp: %02x\n\r", s->lba_mid_exp);
- printf("lba_high_exp: %02x\n\r", s->lba_high_exp);
- printf("res1: %02x\n\r", s->res1);
- printf("sector_count: %02x\n\r", s->sector_count);
- printf("sector_count_exp: %02x\n\r", s->sector_count_exp);
- printf("\n\rSATA: %08x\n\r", (u32)reg);
- printf("CQR: %08x\n\r", in_le32(®->cqr));
- printf("CAR: %08x\n\r", in_le32(®->car));
- printf("CCR: %08x\n\r", in_le32(®->ccr));
- printf("CER: %08x\n\r", in_le32(®->cer));
- printf("DER: %08x\n\r", in_le32(®->der));
- printf("CHBA: %08x\n\r", in_le32(®->chba));
- printf("HStatus: %08x\n\r", in_le32(®->hstatus));
- printf("HControl: %08x\n\r", in_le32(®->hcontrol));
- printf("CQPMP: %08x\n\r", in_le32(®->cqpmp));
- printf("SIG: %08x\n\r", in_le32(®->sig));
- printf("ICC: %08x\n\r", in_le32(®->icc));
- printf("SStatus: %08x\n\r", in_le32(®->sstatus));
- printf("SError: %08x\n\r", in_le32(®->serror));
- printf("SControl: %08x\n\r", in_le32(®->scontrol));
- printf("SNotification: %08x\n\r", in_le32(®->snotification));
- printf("TransCfg: %08x\n\r", in_le32(®->transcfg));
- printf("TransStatus: %08x\n\r", in_le32(®->transstatus));
- printf("LinkCfg: %08x\n\r", in_le32(®->linkcfg));
- printf("LinkCfg1: %08x\n\r", in_le32(®->linkcfg1));
- printf("LinkCfg2: %08x\n\r", in_le32(®->linkcfg2));
- printf("LinkStatus: %08x\n\r", in_le32(®->linkstatus));
- printf("LinkStatus1: %08x\n\r", in_le32(®->linkstatus1));
- printf("PhyCtrlCfg: %08x\n\r", in_le32(®->phyctrlcfg));
- printf("SYSPR: %08x\n\r", in_be32(®->syspr));
- int i;
- u32 cda;
- u32 val32;
- u32 sig;
- fsl_sata_t *sata;
- u32 length, align;
- cmd_hdr_tbl_t *cmd_hdr;
- fsl_sata_reg_t __iomem *reg;
- int dev = priv->number;
- if (dev < 0 || dev > (CONFIG_SYS_SATA_MAX_DEVICE - 1)) {
return -EINVAL;
- if (dev == 0 && (!is_serdes_configured(SATA1))) {
return -EINVAL;
- if (dev == 1 && (!is_serdes_configured(SATA2))) {
return -EINVAL;
- /* Allocate SATA device driver struct */
- sata = (fsl_sata_t *)malloc(sizeof(fsl_sata_t));
- if (!sata) {
return -ENOMEM;
- /* Zero all of the device driver struct */
- memset((void *)sata, 0, sizeof(fsl_sata_t));
- sata->dma_flag = priv->flag;
- snprintf(sata->name, 12, "SATA%d", dev);
- /* Set the controller register base address to device struct */
- reg = (fsl_sata_reg_t *)priv->base;
- sata->reg_base = reg;
- /* Allocate the command header table, 4 bytes aligned */
- length = sizeof(struct cmd_hdr_tbl);
- align = SATA_HC_CMD_HDR_TBL_ALIGN;
- sata->cmd_hdr_tbl_offset = (void *)malloc(length + align);
- if (!sata->cmd_hdr_tbl_offset) {
return -ENOMEM;
- cmd_hdr = (cmd_hdr_tbl_t *)(((u32)sata->cmd_hdr_tbl_offset + align)
& ~(align - 1));
- sata->cmd_hdr = cmd_hdr;
- /* Zero all of the command header table */
- memset((void *)sata->cmd_hdr_tbl_offset, 0, length + align);
- /* Allocate command descriptor for all command */
- length = sizeof(struct cmd_desc) * SATA_HC_MAX_CMD;
- align = SATA_HC_CMD_DESC_ALIGN;
- sata->cmd_desc_offset = (void *)malloc(length + align);
- if (!sata->cmd_desc_offset) {
return -ENOMEM;
- sata->cmd_desc = (cmd_desc_t *)(((u32)sata->cmd_desc_offset + align)
& ~(align - 1));
- /* Zero all of command descriptor */
- memset((void *)sata->cmd_desc_offset, 0, length + align);
- /* Link the command descriptor to command header */
- for (i = 0; i < SATA_HC_MAX_CMD; i++) {
- /* To have safe state, force the controller offline */
- val32 = in_le32(®->hcontrol);
- val32 &= ~HCONTROL_ONOFF;
- val32 |= HCONTROL_FORCE_OFFLINE;
- out_le32(®->hcontrol, val32);
- /* Wait the controller offline */
- ata_wait_register(®->hstatus, HSTATUS_ONOFF, 0, 1000);
- /* Set the command header base address to CHBA register to tell DMA */
- out_le32(®->chba, (u32)cmd_hdr & ~0x3);
- /* Snoop for the command header */
- val32 |= HCONTROL_HDR_SNOOP;
- /* Disable all of interrupts */
- val32 &= ~HCONTROL_INT_EN_ALL;
- /* Clear all of interrupts */
- val32 = in_le32(®->hstatus);
- out_le32(®->hstatus, val32);
- /* Set the ICC, no interrupt coalescing */
- out_le32(®->icc, 0x01000000);
- /* No PM attatched, the SATA device direct connect */
- out_le32(®->cqpmp, 0);
- /* Clear SError register */
- val32 = in_le32(®->serror);
- out_le32(®->serror, val32);
- /* Clear CER register */
- val32 = in_le32(®->cer);
- out_le32(®->cer, val32);
- /* Clear DER register */
- val32 = in_le32(®->der);
- out_le32(®->der, val32);
- /* No device detection or initialization action requested */
- out_le32(®->scontrol, 0x00000300);
- /* Configure the transport layer, default value */
- out_le32(®->transcfg, 0x08000016);
- /* Configure the link layer, default value */
- out_le32(®->linkcfg, 0x0000ff34);
- /* Bring the controller online */
- val32 |= HCONTROL_ONOFF;
- mdelay(100);
- /* print sata device name */
- printf("%s ", sata->name);
- /* Wait PHY RDY signal changed for 500ms */
- ata_wait_register(®->hstatus, HSTATUS_PHY_RDY,
- /* Check PHYRDY */
- if (val32 & HSTATUS_PHY_RDY) {
sata->link = 1;
- } else {
sata->link = 0;
return -EINVAL;
- /* Wait for signature updated, which is 1st D2H */
- ata_wait_register(®->hstatus, HSTATUS_SIGNATURE,
- if (val32 & HSTATUS_SIGNATURE) {
- /* Check the speed */
- val32 = in_le32(®->sstatus);
- if ((val32 & SSTATUS_SPD_MASK) == SSTATUS_SPD_GEN1)
- else if ((val32 & SSTATUS_SPD_MASK) == SSTATUS_SPD_GEN2)
- priv->fsl_sata = sata;
- cmd_hdr_entry_t *cmd_hdr;
- cmd_desc_t *cmd_desc;
- sata_fis_h2d_t *h2d;
- prd_entry_t *prde;
- u32 ext_c_ddc;
- u32 prde_count;
- u32 val32;
- u32 ttl;
- u32 der;
- int i;
- fsl_sata_reg_t *reg = sata->reg_base;
- /* Check xfer length */
- if (len > SATA_HC_MAX_XFER_LEN) {
- /* Setup the command descriptor */
- cmd_desc = sata->cmd_desc + tag;
- /* Get the pointer cfis of command descriptor */
- h2d = (sata_fis_h2d_t *)cmd_desc->cfis;
- /* Zero the cfis of command descriptor */
- memset((void *)h2d, 0, SATA_HC_CMD_DESC_CFIS_SIZE);
- /* Copy the cfis from user to command descriptor */
- h2d->fis_type = cfis->fis_type;
- h2d->pm_port_c = cfis->pm_port_c;
- h2d->command = cfis->command;
- h2d->features = cfis->features;
- h2d->features_exp = cfis->features_exp;
- h2d->lba_low = cfis->lba_low;
- h2d->lba_mid = cfis->lba_mid;
- h2d->lba_high = cfis->lba_high;
- h2d->lba_low_exp = cfis->lba_low_exp;
- h2d->lba_mid_exp = cfis->lba_mid_exp;
- h2d->lba_high_exp = cfis->lba_high_exp;
- if (!is_ncq) {
- } else { /* NCQ */
- h2d->device = cfis->device;
- h2d->control = cfis->control;
- /* Setup the PRD table */
- prde = (prd_entry_t *)cmd_desc->prdt;
- memset((void *)prde, 0, sizeof(struct prdt));
- prde_count = 0;
- ttl = len;
- for (i = 0; i < SATA_HC_MAX_PRD_DIRECT; i++) {
if (!len)
break;
ext_c_ddc, len);
prde_count++;
prde++;
} else {
ext_c_ddc, len);
prde_count++;
prde++;
- /* Setup the command slot of cmd hdr */
- cmd_hdr = (cmd_hdr_entry_t *)&sata->cmd_hdr->cmd_slot[tag];
- cmd_hdr->cda = cpu_to_le32((u32)cmd_desc & ~0x3);
- val32 = prde_count << CMD_HDR_PRD_ENTRY_SHIFT;
- val32 |= sizeof(sata_fis_h2d_t);
- cmd_hdr->prde_fis_len = cpu_to_le32(val32);
- cmd_hdr->ttl = cpu_to_le32(ttl);
- if (!is_ncq)
- else
CMD_HDR_ATTR_FPDMA;
- tag &= CMD_HDR_ATTR_TAG;
- val32 |= tag;
- debug("attribute = %08x\n\r", val32);
- cmd_hdr->attribute = cpu_to_le32(val32);
- /* Make sure cmd desc and cmd slot valid before command issue */
- sync();
- /* PMP*/
- val32 = (u32)(h2d->pm_port_c & 0x0f);
- out_le32(®->cqpmp, val32);
- /* Wait no active */
- if (ata_wait_register(®->car, (1 << tag), 0, 10000))
- /* Issue command */
- if (!(in_le32(®->cqr) & (1 << tag))) {
val32 = 1 << tag;
- /* Wait command completed for 10s */
- if (ata_wait_register(®->ccr, (1 << tag), (1 << tag), 10000)) {
if (!is_ncq)
else
- if (val32) {
- /* Clear complete flags */
- val32 = in_le32(®->ccr);
- out_le32(®->ccr, val32);
- return len;
u32 len)
- int rc;
- if (tag > SATA_HC_MAX_CMD || tag < 0) {
return -1;
- switch (command_type) {
- case CMD_ATA:
return rc;
- case CMD_NCQ:
return rc;
- case CMD_ATAPI:
- case CMD_VENDOR_BIST:
- case CMD_BIST:
return -1;
- default:
break;
- return -1;
- struct sata_fis_h2d h2d, *cfis = &h2d;
- memset(cfis, 0, sizeof(struct sata_fis_h2d));
- cfis->fis_type = SATA_FIS_TYPE_REGISTER_H2D;
- cfis->pm_port_c = 0x80; /* is command */
- cfis->command = ATA_CMD_ID_ATA;
- fsl_sata_exec_cmd(sata, cfis, CMD_ATA, 0, (u8 *)id, ATA_ID_WORDS * 2);
- ata_swap_buf_le16(id, ATA_ID_WORDS);
- sata->pio = id[ATA_ID_PIO_MODES];
- sata->mwdma = id[ATA_ID_MWDMA_MODES];
- sata->udma = id[ATA_ID_UDMA_MODES];
- debug("pio %04x, mwdma %04x, udma %04x\n\r", sata->pio,
- if (ata_id_has_wcache(id) && ata_id_wcache_enabled(id))
sata->wcache = 1;
- if (ata_id_has_flush(id))
sata->flush = 1;
- if (ata_id_has_flush_ext(id))
- u8 udma_cap;
- cfis->command = ATA_CMD_SET_FEATURES;
- cfis->features = SETFEATURES_XFER;
- /* First check the device capablity */
- udma_cap = (u8)(sata->udma & 0xff);
- debug("udma_cap %02x\n\r", udma_cap);
- if (udma_cap == ATA_UDMA6)
- if (udma_cap == ATA_UDMA5)
- if (udma_cap == ATA_UDMA4)
- if (udma_cap == ATA_UDMA3)
- fsl_sata_exec_cmd(sata, cfis, CMD_ATA, 0, NULL, 0);
- u32 block;
- block = start;
- cfis->command = (is_write) ? ATA_CMD_WRITE : ATA_CMD_READ;
- cfis->device = ATA_LBA;
- cfis->device |= (block >> 24) & 0xf;
- cfis->lba_high = (block >> 16) & 0xff;
- cfis->lba_mid = (block >> 8) & 0xff;
- cfis->lba_low = block & 0xff;
- cfis->sector_count = (u8)(blkcnt & 0xff);
- fsl_sata_exec_cmd(sata, cfis, CMD_ATA, 0, buffer,
- return blkcnt;
- cfis->command = ATA_CMD_FLUSH;
- u64 block;
- block = (u64)start;
- cfis->command = (is_write) ? ATA_CMD_WRITE_EXT
: ATA_CMD_READ_EXT;
- cfis->lba_high_exp = (block >> 40) & 0xff;
- cfis->lba_mid_exp = (block >> 32) & 0xff;
- cfis->lba_low_exp = (block >> 24) & 0xff;
- cfis->sector_count_exp = (blkcnt >> 8) & 0xff;
- cfis->sector_count = blkcnt & 0xff;
- return blkcnt;
u8 *buffer,
int is_write)
- int ncq_channel;
- u64 block;
- if (sata->lba48 != 1) {
return -1;
- cfis->command = (is_write) ? ATA_CMD_FPDMA_WRITE
- cfis->features_exp = (blkcnt >> 8) & 0xff;
- cfis->features = blkcnt & 0xff;
- if (sata->queue_depth >= SATA_HC_MAX_CMD)
- else
- /* Use the latest queue */
- fsl_sata_exec_cmd(sata, cfis, CMD_NCQ, ncq_channel, buffer,
- return blkcnt;
- cfis->command = ATA_CMD_FLUSH_EXT;
- u32 start, blks;
- u8 *addr;
- int max_blks;
- start = blknr;
- blks = blkcnt;
- addr = (u8 *)buffer;
- max_blks = ATA_MAX_SECTORS_LBA48;
- do {
addr, is_write);
else
addr, is_write);
start += max_blks;
blks -= max_blks;
} else {
addr, is_write);
else
addr, is_write);
start += blks;
blks = 0;
- } while (blks != 0);
- return blks;
- u32 start, blks;
- u8 *addr;
- int max_blks;
- start = blknr;
- blks = blkcnt;
- max_blks = ATA_MAX_SECTORS;
- do {
start += max_blks;
blks -= max_blks;
} else {
start += blks;
blks = 0;
- return blks;
- SATA interface between low level driver and command layer
void *buffer)
- u32 rc;
- if (sata->lba48)
READ_CMD);
- else
READ_CMD);
- return rc;
const void *buffer)
- u32 rc;
- if (sata->lba48) {
WRITE_CMD);
- } else {
WRITE_CMD);
- return rc;
- /* if no detected link */
- if (!sata->link)
return -EINVAL;
- /* Check if support LBA48 */
- if (ata_id_has_lba48(id)) {
sata->lba48 = 1;
- } else {
- /* Get the NCQ queue depth from device */
- sata->queue_depth = ata_id_queue_depth(id);
- /* Get the xfer mode from device */
- fsl_sata_xfer_mode(sata, id);
- /* Get the write cache status from device */
- fsl_sata_init_wcache(sata, id);
- /* Set the xfer mode to highest speed */
- fsl_sata_set_features(sata);
bool is_write)
- int ret;
- u32 temp;
- u16 blocks = 0;
- lbaint_t start = 0;
- u8 *buffer = pccb->pdata;
- /* Retrieve the base LBA number from the ccb structure. */
- if (pccb->cmd[0] == SCSI_READ16) {
- } else {
- else
- debug("scsi_ahci: %s %u blocks starting from lba 0x" LBAFU "\n",
- if (is_write)
- else
- return ret;
- int i;
- for (i = 0; i < len / 2; i++)
target[i] = src[i];
- return (char *)target;
fsl_sata_t *sata)
- u8 port;
- u16 *idbuf;
- ALLOC_CACHE_ALIGN_BUFFER(u16, tmpid, ATA_ID_WORDS);
- /* Clean ccb data buffer */
- memset(pccb->pdata, 0, pccb->datalen);
- if (pccb->datalen <= 35)
- /* Read id from sata */
- port = pccb->target;
- fsl_sata_identify(sata, (u16 *)tmpid);
- if (!uc_priv->ataid[port]) {
return -ENOMEM;
- idbuf = uc_priv->ataid[port];
- memcpy(idbuf, tmpid, ATA_ID_WORDS * 2);
- memcpy(&pccb->pdata[8], "ATA ", 8);
- fsl_ata_id_strcpy((u16 *)&pccb->pdata[16], &idbuf[ATA_ID_PROD], 16);
- fsl_ata_id_strcpy((u16 *)&pccb->pdata[32], &idbuf[ATA_ID_FW_REV], 4);
- sata_getinfo(sata, (u16 *)idbuf);
+#ifdef DEBUG
- ata_dump_id(idbuf);
- SCSI READ CAPACITY10 command operation.
- u32 cap;
- u64 cap64;
- u32 block_size;
- if (!uc_priv->ataid[pccb->target]) {
"\tNo ATA info!\n"
return -EPERM;
- cap64 = ata_id_n_sectors(uc_priv->ataid[pccb->target]);
- if (cap64 > 0x100000000ULL)
cap64 = 0xffffffff;
- cap = cpu_to_be32(cap64);
- memcpy(pccb->pdata, &cap, sizeof(cap));
- block_size = cpu_to_be32((u32)512);
- memcpy(&pccb->pdata[4], &block_size, 4);
- SCSI READ CAPACITY16 command operation.
- u64 cap;
- u64 block_size;
"\tNo ATA info!\n"
return -EPERM;
- cap = ata_id_n_sectors(uc_priv->ataid[pccb->target]);
- cap = cpu_to_be64(cap);
- block_size = cpu_to_be64((u64)512);
- memcpy(&pccb->pdata[8], &block_size, 8);
- SCSI TEST UNIT READY command operation.
- return (uc_priv->ataid[pccb->target]) ? 0 : -EPERM;
- struct ahci_uc_priv *uc_priv = dev_get_uclass_priv(dev->parent);
- struct fsl_ahci_priv *priv = dev_get_priv(dev->parent);
- fsl_sata_t *sata = priv->fsl_sata;
- int ret;
- switch (pccb->cmd[0]) {
- case SCSI_READ16:
- case SCSI_READ10:
break;
- case SCSI_WRITE10:
break;
- case SCSI_RD_CAPAC10:
break;
- case SCSI_RD_CAPAC16:
break;
- case SCSI_TST_U_RDY:
break;
- case SCSI_INQUIRY:
break;
- default:
return -ENOTSUPP;
- if (ret) {
return ret;
- struct udevice *child_dev;
- struct scsi_platdata *uc_plat;
- device_find_first_child(dev, &child_dev);
- if (!child_dev)
return -ENODEV;
- uc_plat = dev_get_uclass_platdata(child_dev);
- uc_plat->base = priv->base;
- uc_plat->max_lun = 1;
- uc_plat->max_id = 1;
- return init_sata(priv);
- .exec = fsl_ahci_scsi_exec,
- { .compatible = "fsl,pq-sata-v2" },
- .name = "fsl_ahci_scsi",
- .id = UCLASS_SCSI,
- .ops = &fsl_scsi_ops,
- .name = "fsl_ahci",
- .id = UCLASS_AHCI,
- .of_match = fsl_ahci_ids,
- .bind = fsl_ahci_bind,
- .ofdata_to_platdata = fsl_ahci_ofdata_to_platdata,
- .probe = fsl_ahci_probe,
- .priv_auto_alloc_size = sizeof(struct fsl_ahci_priv),
#define READ_CMD 0
Viele Grüße, Stefan
-----Original Message----- From: Stefan Roese sr@denx.de Sent: 2019年3月27日 18:01 To: Peng Ma peng.ma@nxp.com; Prabhakar Kushwaha prabhakar.kushwaha@nxp.com; Shengzhou Liu shengzhou.liu@nxp.com; Ruchika Gupta ruchika.gupta@nxp.com Cc: Yinbo Zhu yinbo.zhu@nxp.com; sjg@chromium.org; Jagdish Gediya jagdish.gediya@nxp.com; York Sun york.sun@nxp.com; bmeng.cn@gmail.com; make@marvell.com; Andy Tang andy.tang@nxp.com; u-boot@lists.denx.de Subject: Re: [PATCH 1/4] ata: fsl_ahci: Add sata DM support for Freescale powerpc socs
does
depends on:
https://eur01.safelinks.protection.outlook.com/?url=https%3A%2F%2Fpatchw ork.ozlabs.org%2Fproject%2Fuboot%2Flist%2F%3Fseries%3D99168&data =02%7C01%7Cpeng.ma%40nxp.com%7C71e43bd30bf24799586f08d6b29b1ef 3%7C686ea1d3bc2b4c6fa92cd99c5c301635%7C0%7C0%7C636892776652072 966&sdata=3Z33Z5raG%2BnbtSUpz2kPCGpefk1byOgy0%2Br3R4DUFU8% 3D&reserved=0
hwork.ozlabs.org%2Fproject%2Fuboot%2Flist%2F%3Fseries%3D99167&d ata
a1d3bc2b4c6fa92cd99c5c301635%7C0%7C0%7C636892776652072966& sdata=sr
%2BCh4UioJw0kuhOiLhc3F6keRhIH8Wflt%2BvMJnHtsY%3D&reserved=
0
[Peng Ma] Hi Stefan,
fsl_sata.c used to Non DM sata driver for some powerpc socs. Currently We only have one board that supports dts initialization. I will remove this old driver When all of our powerpc socs support DM.
Best Regards, Peng
Thanks, Stefan
+config FSL_AHCI
- select SCSI_AHCI
- depends on AHCI
- help
- u32 base;
- u32 flag;
- u32 number;
+static int fsl_ahci_bind(struct udevice *dev) {
+NULL); }
+static int fsl_ahci_ofdata_to_platdata(struct udevice *dev) {
return -EINVAL;
- int i;
mdelay(1);
+static void fsl_sata_dump_sfis(struct sata_fis_d2h *s) {
+static void fsl_sata_dump_regs(fsl_sata_reg_t __iomem *reg) {
+static int init_sata(struct fsl_ahci_priv *priv) {
- int i;
- u32 cda;
- u32 val32;
- u32 sig;
- fsl_sata_t *sata;
return -EINVAL;
return -EINVAL;
return -EINVAL;
- if (!sata) {
return -ENOMEM;
return -ENOMEM;
& ~(align - 1));
return -ENOMEM;
& ~(align - 1));
- mdelay(100);
sata->link = 1;
- } else {
sata->link = 0;
return -EINVAL;
- u32 ext_c_ddc;
- u32 prde_count;
- u32 val32;
- u32 ttl;
- u32 der;
- int i;
- if (!is_ncq) {
- prde_count = 0;
- ttl = len;
if (!len)
break;
ext_c_ddc, len);
prde_count++;
prde++;
} else {
ext_c_ddc, len);
prde_count++;
prde++;
- if (!is_ncq)
- else
CMD_HDR_ATTR_FPDMA;
- val32 |= tag;
- sync();
- /* PMP*/
val32 = 1 << tag;
if (!is_ncq)
else
- if (val32) {
- return len;
u32 len)
- int rc;
return -1;
- case CMD_ATA:
return rc;
- case CMD_NCQ:
return rc;
- case CMD_ATAPI:
- case CMD_BIST:
return -1;
- default:
break;
- return -1;
+static void fsl_sata_identify(fsl_sata_t *sata, u16 *id) {
- ata_swap_buf_le16(id, ATA_ID_WORDS); }
+static void fsl_sata_xfer_mode(fsl_sata_t *sata, u16 *id) {
+static void fsl_sata_init_wcache(fsl_sata_t *sata, u16 *id) {
sata->wcache = 1;
sata->flush = 1;
+static void fsl_sata_set_features(fsl_sata_t *sata) {
- u8 udma_cap;
- fsl_sata_exec_cmd(sata, cfis, CMD_ATA, 0, NULL, 0); }
- u32 block;
- block = start;
- return blkcnt;
+static void fsl_sata_flush_cache(fsl_sata_t *sata) {
u32 blkcnt, u8 *buffer, int is_write) {
- u64 block;
: ATA_CMD_READ_EXT;
- return blkcnt;
u8 *buffer,
int is_write)
- int ncq_channel;
- u64 block;
return -1;
- else
- return blkcnt;
+static void fsl_sata_flush_cache_ext(fsl_sata_t *sata) {
blkcnt,
const void *buffer, int is_write) {
- u32 start, blks;
- u8 *addr;
- int max_blks;
- start = blknr;
- blks = blkcnt;
- do {
addr, is_write);
else
addr, is_write);
start += max_blks;
blks -= max_blks;
} else {
addr, is_write);
else
addr, is_write);
start += blks;
blks = 0;
- return blks;
- u32 start, blks;
- u8 *addr;
- int max_blks;
- start = blknr;
- blks = blkcnt;
- do {
start += max_blks;
blks -= max_blks;
} else {
start += blks;
blks = 0;
- return blks;
- SATA interface between low level driver and command layer */
void *buffer)
- u32 rc;
- if (sata->lba48)
READ_CMD);
- else
READ_CMD);
- return rc;
const void *buffer)
- u32 rc;
WRITE_CMD);
- } else {
WRITE_CMD);
- return rc;
+int sata_getinfo(fsl_sata_t *sata, u16 *id) {
- if (!sata->link)
return -EINVAL;
sata->lba48 = 1;
- } else {
bool is_write)
- int ret;
- u32 temp;
- u16 blocks = 0;
- } else {
- else
- if (is_write)
- else
- return ret;
+static char *fsl_ata_id_strcpy(u16 *target, u16 *src, int len) {
- int i;
target[i] = src[i];
fsl_sata_t *sata)
- u8 port;
- u16 *idbuf;
return -ENOMEM;
+4);
+#ifdef DEBUG
- u32 cap;
- u64 cap64;
- u32 block_size;
"\tNo ATA info!\n"
return -EPERM;
cap64 = 0xffffffff;
- u64 cap;
- u64 block_size;
"\tNo ATA info!\n"
return -EPERM;
- return (uc_priv->ataid[pccb->target]) ? 0 : -EPERM; }
+static int fsl_ahci_scsi_exec(struct udevice *dev, struct scsi_cmd +*pccb) {
- int ret;
- case SCSI_READ16:
- case SCSI_READ10:
break;
break;
break;
break;
break;
break;
- default:
return -ENOTSUPP;
- if (ret) {
return ret;
+static int fsl_ahci_probe(struct udevice *dev) {
- if (!child_dev)
return -ENODEV;
- .priv_auto_alloc_size = sizeof(struct fsl_ahci_priv), };
#define READ_CMD 0
Viele Grüße, Stefan
-- DENX Software Engineering GmbH, Managing Director: Wolfgang Denk HRB 165235 Munich, Office: Kirchenstr.5, D-82194 Groebenzell, Germany Phone: (+49)-8142-66989-51 Fax: (+49)-8142-66989-80 Email: sr@denx.de
does
depends on:
0
I see, thanks. I just wanted to know, if this new SATA driver is a meant as a replacement for the old non-DM driver.
Thanks, Stefan
-----Original Message----- From: Stefan Roese sr@denx.de Sent: 2019年3月27日 18:48 To: Peng Ma peng.ma@nxp.com; Prabhakar Kushwaha prabhakar.kushwaha@nxp.com; Shengzhou Liu shengzhou.liu@nxp.com; Ruchika Gupta ruchika.gupta@nxp.com Cc: Yinbo Zhu yinbo.zhu@nxp.com; sjg@chromium.org; Jagdish Gediya jagdish.gediya@nxp.com; York Sun york.sun@nxp.com; bmeng.cn@gmail.com; make@marvell.com; Andy Tang andy.tang@nxp.com; u-boot@lists.denx.de Subject: Re: [PATCH 1/4] ata: fsl_ahci: Add sata DM support for Freescale powerpc socs
This patch is to support Freescale sata driver with dts initialized. Also resolved the following problems.
===================== WARNING ====================== This
board
does
not use CONFIG_DM_SCSI. Please update the storage controller to use CONFIG_DM_SCSI before the v2019.07 release. Failure to update by the deadline may result in board removal. See doc/driver-model/MIGRATION.txt for more info. ====================================================
Signed-off-by: Peng Ma peng.ma@nxp.com
depends on:
https://eur01.safelinks.protection.outlook.com/?url=https%3A%2F%2Fpat chw
3D&reserved=0
https://eur01.safelinks.protection.outlook.com/?url=https%3A%2F%2Fpa tc
ata
3%7C686e
sdata=sr
d=
0
drivers/ata/Kconfig | 10 + drivers/ata/Makefile | 1 + drivers/ata/fsl_ahci.c | 1030
drivers/ata/fsl_sata.h | 1 + 4 files changed, 1042 insertions(+) create mode 100644 drivers/ata/fsl_ahci.c
I am so sorry to reply late, Other Non dts powerpc board need the old sata driver, so the new Sata driver does not replace the so far.
Best Regards, Peng
Thanks, Stefan
board
does
depends on:
3D&reserved=0
ata
3%7C686e
sdata=sr
d=
0
Just curious: Which are the "other non dts powerpc boards"? Are there still many? Is there a plan to move them to DT as well? Or should they perhaps be dropped from mainline if not converted to DT? What's stopping the conversion here?
Thanks, Stefan
-----Original Message----- From: Stefan Roese sr@denx.de Sent: 2019年5月15日 17:23 To: Peng Ma peng.ma@nxp.com; Prabhakar Kushwaha prabhakar.kushwaha@nxp.com; Shengzhou Liu shengzhou.liu@nxp.com; Ruchika Gupta ruchika.gupta@nxp.com Cc: Yinbo Zhu yinbo.zhu@nxp.com; sjg@chromium.org; Jagdish Gediya jagdish.gediya@nxp.com; York Sun york.sun@nxp.com; bmeng.cn@gmail.com; make@marvell.com; Andy Tang andy.tang@nxp.com; u-boot@lists.denx.de Subject: [EXT] Re: [PATCH 1/4] ata: fsl_ahci: Add sata DM support for Freescale powerpc socs
Caution: EXT Email
board
does
depends on:
https://eur01.safelinks.protection.outlook.com/?url=https%3A%2F%2Fp at chw
3D&reserved=0
https://eur01.safelinks.protection.outlook.com/?url=https%3A%2F%2F pa tc
ata
3%7C686e
sdata=sr
ve
d=
0
[Peng Ma] 1: There is some platforms still with non dts such as: T1024QDS, T1024RDB, T1040D4RDB etc. 2: I do not know the plan to move them to DT, we only support one platform named T2080QDS so far. 3:Before all of them support DT, we should not delete old sata driver.
Thanks. Best Regards, Peng
Thanks, Stefan
Hi Prabhakar,
I see our platforms with powerpc. We only support T2080QDS with DTS. Is there a plan to move them to DT as well? Please let Stefan Know. Thanks.
Best Regards, Peng
Caution: EXT Email
board
does
depends on:
3D&reserved=0
ata
3%7C686e
sdata=sr
ve
d=
0
Thanks, Stefan
Hi Stefan,
Do you have any questions about this patch? Plese let me know. Thanks.
Best Regars, Peng
Caution: EXT Email
board
does
depends on:
3D&reserved=0
ata
3%7C686e
sdata=sr
ve
d=
0
Thanks, Stefan
Hi Stefan,
-----Original Message----- From: Stefan Roese sr@denx.de Sent: Wednesday, May 15, 2019 2:53 PM To: Peng Ma peng.ma@nxp.com; Prabhakar Kushwaha prabhakar.kushwaha@nxp.com; Shengzhou Liu shengzhou.liu@nxp.com; Ruchika Gupta ruchika.gupta@nxp.com Cc: Yinbo Zhu yinbo.zhu@nxp.com; sjg@chromium.org; Jagdish Gediya jagdish.gediya@nxp.com; York Sun york.sun@nxp.com; bmeng.cn@gmail.com; make@marvell.com; Andy Tang andy.tang@nxp.com; u-boot@lists.denx.de Subject: Re: [PATCH 1/4] ata: fsl_ahci: Add sata DM support for Freescale powerpc socs
board
does
depends on:
3D&reserved=0
ata
3%7C686e
sdata=sr
d=
0
There are too many powerpc platforms which are not migrated to DT.
My suggestion will be to have sata driver supporting both. Once all PowerPC platform using this SATA driver migrated, it can be dropped.
--pk.
On 23.05.19 06:58, Prabhakar Kushwaha wrote:
<snip>
> drivers/ata/Kconfig | 10 + > drivers/ata/Makefile | 1 + > drivers/ata/fsl_ahci.c | 1030 ++++++++++++++++++++++++++++++++++++++++ > drivers/ata/fsl_sata.h | 1 + > 4 files changed, 1042 insertions(+) > create mode 100644 drivers/ata/fsl_ahci.c
I'm fine with this. Please go ahead.
Thanks, Stefan
Hi Stefan,
-----Original Message----- From: Stefan Roese sr@denx.de Sent: 2019年5月23日 13:09 To: Prabhakar Kushwaha prabhakar.kushwaha@nxp.com; Peng Ma peng.ma@nxp.com; Shengzhou Liu shengzhou.liu@nxp.com; Ruchika Gupta ruchika.gupta@nxp.com Cc: Yinbo Zhu yinbo.zhu@nxp.com; sjg@chromium.org; Jagdish Gediya jagdish.gediya@nxp.com; York Sun york.sun@nxp.com; bmeng.cn@gmail.com; make@marvell.com; Andy Tang andy.tang@nxp.com; u-boot@lists.denx.de Subject: [EXT] Re: [PATCH 1/4] ata: fsl_ahci: Add sata DM support for Freescale powerpc socs
Caution: EXT Email
<snip>
>> drivers/ata/Kconfig | 10 + >> drivers/ata/Makefile | 1 + >> drivers/ata/fsl_ahci.c | 1030 > ++++++++++++++++++++++++++++++++++++++++ >> drivers/ata/fsl_sata.h | 1 + >> 4 files changed, 1042 insertions(+) >> create mode 100644 drivers/ata/fsl_ahci.c > > Will this patch series replace the old fsl_sata.c driver? If yes, > could you remove this driver as well in this series? [Peng Ma] Hi Stefan,
Ok, thanks for your review.
Best Regards, Peng
Thanks, Stefan
Dear Peng,
-----Original Message----- From: Peng Ma Sent: Thursday, May 23, 2019 12:37 PM To: Stefan Roese sr@denx.de; Prabhakar Kushwaha prabhakar.kushwaha@nxp.com; Shengzhou Liu shengzhou.liu@nxp.com; Ruchika Gupta ruchika.gupta@nxp.com Cc: Yinbo Zhu yinbo.zhu@nxp.com; sjg@chromium.org; Jagdish Gediya jagdish.gediya@nxp.com; York Sun york.sun@nxp.com; bmeng.cn@gmail.com; make@marvell.com; Andy Tang andy.tang@nxp.com; u-boot@lists.denx.de Subject: RE: [EXT] Re: [PATCH 1/4] ata: fsl_ahci: Add sata DM support for Freescale powerpc socs
Hi Stefan,
Gupta
Caution: EXT Email
<snip>
>>> drivers/ata/Kconfig | 10 + >>> drivers/ata/Makefile | 1 + >>> drivers/ata/fsl_ahci.c | 1030 >> ++++++++++++++++++++++++++++++++++++++++ >>> drivers/ata/fsl_sata.h | 1 + >>> 4 files changed, 1042 insertions(+) >>> create mode 100644 drivers/ata/fsl_ahci.c >> >> Will this patch series replace the old fsl_sata.c driver? If >> yes, could you remove this driver as well in this series? > [Peng Ma] > Hi Stefan, > > fsl_sata.c used to Non DM sata driver for some powerpc socs. > Currently We only have one board that supports dts initialization. > I will remove this old driver When all of our powerpc socs support DM.
I am seeing build errors in drivers/ata/fsl_sata.c with this patch. Something may have changed from the time the patch has submitted and till I am trying to incorporate.
Can you please fix and provide updated patch on top of the tree as early as possible
--pk
-----Original Message----- From: Peng Ma Sent: Wednesday, March 27, 2019 2:53 PM To: Prabhakar Kushwaha prabhakar.kushwaha@nxp.com; Shengzhou Liu shengzhou.liu@nxp.com; Ruchika Gupta ruchika.gupta@nxp.com Cc: Yinbo Zhu yinbo.zhu@nxp.com; sjg@chromium.org; Jagdish Gediya jagdish.gediya@nxp.com; York Sun york.sun@nxp.com; bmeng.cn@gmail.com; sr@denx.de; make@marvell.com; Andy Tang andy.tang@nxp.com; u-boot@lists.denx.de; Peng Ma peng.ma@nxp.com Subject: [PATCH 1/4] ata: fsl_ahci: Add sata DM support for Freescale powerpc socs
===================== WARNING ====================== This board does not use CONFIG_DM_SCSI. Please update the storage controller to use CONFIG_DM_SCSI before the v2019.07 release. Failure to update by the deadline may result in board removal. See doc/driver-model/MIGRATION.txt for more info. ====================================================
depends on:
- https://patchwork.ozlabs.org/project/uboot/list/?series=99168
- https://patchwork.ozlabs.org/project/uboot/list/?series=99167
drivers/ata/Kconfig | 10 + drivers/ata/Makefile | 1 + drivers/ata/fsl_ahci.c | 1030 ++++++++++++++++++++++++++++++++++++++++ drivers/ata/fsl_sata.h | 1 + 4 files changed, 1042 insertions(+) create mode 100644 drivers/ata/fsl_ahci.c
New driver is getting added in drivers/ata.
I request driver/ata maintainer to review
--pk
--pk
Peng Ma
Prabhakar Kushwaha
Stefan Roese
