[U-Boot] [PATCH] sunxi: TZX-Q8-713B7 support
This patch adds support for the TZX-Q8-713B7 tablet as described at: http://linux-sunxi.org/TZX-Q8-713B7
All the things that are expected to work are going just fine, even host USB OTG with the MUSB driver worked with both storage and a USB keyboard.
The DRAM configuration was not directly imported from the legacy u-boot-sunxi tree. Instead, this uses dram_sun5i_auto with appropriate configuration. The resulting DRAM config is not exactly the same, but things appear to work just fine with dram_sun5i_auto (when booting a kernel and a full graphical session).
The LCD mode configuration (CONFIG_VIDEO_LCD_MODE) only has fields that could be determined reliably. Other fields (such as le,ri,up,lo and hs,vs) are left to default values. Despite this, the LCD appears to be working just fine.
Signed-off-by: Paul Kocialkowski contact@paulk.fr --- board/sunxi/Kconfig | 4 ++++ board/sunxi/MAINTAINERS | 5 +++++ board/sunxi/Makefile | 1 + configs/TZX-Q8-713B7_defconfig | 15 +++++++++++++++ 4 files changed, 25 insertions(+) create mode 100644 configs/TZX-Q8-713B7_defconfig
diff --git a/board/sunxi/Kconfig b/board/sunxi/Kconfig index 738b55e..5c78cdf 100644 --- a/board/sunxi/Kconfig +++ b/board/sunxi/Kconfig @@ -147,6 +147,10 @@ config TARGET_R7DONGLE bool "R7DONGLE" depends on MACH_SUN5I
+config TARGET_TZX_Q8_713B7 + bool "TZX-Q8-713B7" + depends on MACH_SUN5I + endchoice
config SYS_BOARD diff --git a/board/sunxi/MAINTAINERS b/board/sunxi/MAINTAINERS index 743e7f5..da5419c 100644 --- a/board/sunxi/MAINTAINERS +++ b/board/sunxi/MAINTAINERS @@ -100,3 +100,8 @@ MELE M5 BOARD M: Ian Campbell ijc@hellion.org.uk S: Maintained F: configs/Mele_M5_defconfig + +TZX-Q8-713B7 BOARD +M: Paul Kocialkowski contact@paulk.fr +S: Maintained +F: configs/TZX-Q8-713B7_defconfig diff --git a/board/sunxi/Makefile b/board/sunxi/Makefile index 71edb83..b14a8b2 100644 --- a/board/sunxi/Makefile +++ b/board/sunxi/Makefile @@ -20,3 +20,4 @@ obj-$(CONFIG_TARGET_A13_OLINUXINOM) += dram_a13_oli_micro.o obj-$(CONFIG_TARGET_AUXTEK_T004) += dram_a10s_olinuxino_m.o obj-$(CONFIG_TARGET_MK802_A10S) += dram_sun5i_auto.o obj-$(CONFIG_TARGET_R7DONGLE) += dram_r7dongle.o +obj-$(CONFIG_TARGET_TZX_Q8_713B7) += dram_sun5i_auto.o diff --git a/configs/TZX-Q8-713B7_defconfig b/configs/TZX-Q8-713B7_defconfig new file mode 100644 index 0000000..8696bdf --- /dev/null +++ b/configs/TZX-Q8-713B7_defconfig @@ -0,0 +1,15 @@ +CONFIG_SPL=y +CONFIG_SYS_EXTRA_OPTIONS="CONS_INDEX=2,AXP209_POWER" +CONFIG_USB_MUSB_SUNXI=y +CONFIG_USB0_VBUS_PIN="PG12" +CONFIG_VIDEO_LCD_MODE="x:800,y:480,depth:24,pclk_khz:33000,sync:3,vmode:0" +CONFIG_VIDEO_LCD_POWER="AXP0-0" +CONFIG_VIDEO_LCD_BL_EN="AXP0-1" +CONFIG_VIDEO_LCD_BL_PWM="PB2" ++S:CONFIG_ARM=y ++S:CONFIG_ARCH_SUNXI=y ++S:CONFIG_MACH_SUN5I=y ++S:CONFIG_TARGET_TZX_Q8_713B7=y ++S:CONFIG_DRAM_CLK=408 ++S:CONFIG_DRAM_ZQ=123 ++S:CONFIG_DRAM_EMR1=4
Thanks, I've merged this with a number of changes: - Fixed op the CONFIG_VIDEO_LCD_MODE to also properly define left/right and top/bottom margins. See: http://linux-sunxi.org/LCD - Added a "CONFIG_FDTFILE="sun5i-a13-tzx-q8-713b7.dtb" line, so that when future upstream kernels get a dtb file for this board things will just work. When submitting a dts file upstream for this board please use the same name :)
Talking about upstream dts files, it would be great if you could write one. Note that we've recently adapted a new style for upstream dts files, so it is best to use one of the recent added boards as example, e.g. :
https://git.kernel.org/cgit/linux/kernel/git/mripard/linux.git/commit/?h=sun...
Regards,
Hans
bool "TZX-Q8-713B7"
endchoice
config SYS_BOARD
Wow, that's great, this is exactly what I was looking for. I guess I hadn't been looking hard enough for it!
I was a little unsure about adding it or not, thanks for taking the decision. I will certainly try to add mainline support for the tablet at some point in the future, even though I will be using it with sunxi-3.4 on Replicant in the near future.
Thanks!
Regards,
Hans
bool "TZX-Q8-713B7"
endchoice
config SYS_BOARD
Hans de Goede
Paul Kocialkowski
