[U-Boot] [PATCH] mx6sabresd: Add SPI NOR support
mx6sabre board has a m25p32 SPI NOR connected to ECSPI1 port.
Add support for it.
This patch allows the SPI NOR flash to be succesfully detected:
=> sf probe SF: Detected M25P32 with page size 256 Bytes, erase size 64 KiB, total 4 MiB
Signed-off-by: Fabio Estevam fabio.estevam@freescale.com --- board/freescale/mx6sabresd/mx6sabresd.c | 19 +++++++++++++++++++ include/configs/mx6sabre_common.h | 11 +++++++++++ 2 files changed, 30 insertions(+)
diff --git a/board/freescale/mx6sabresd/mx6sabresd.c b/board/freescale/mx6sabresd/mx6sabresd.c index ba1f289..f6d6379 100644 --- a/board/freescale/mx6sabresd/mx6sabresd.c +++ b/board/freescale/mx6sabresd/mx6sabresd.c @@ -37,6 +37,9 @@ DECLARE_GLOBAL_DATA_PTR; #define ENET_PAD_CTRL (PAD_CTL_PUS_100K_UP | \ PAD_CTL_SPEED_MED | PAD_CTL_DSE_40ohm | PAD_CTL_HYS)
+#define SPI_PAD_CTRL (PAD_CTL_HYS | PAD_CTL_SPEED_MED | \ + PAD_CTL_DSE_40ohm | PAD_CTL_SRE_FAST) + int dram_init(void) { gd->ram_size = get_ram_size((void *)PHYS_SDRAM, PHYS_SDRAM_SIZE); @@ -120,6 +123,18 @@ iomux_v3_cfg_t const usdhc4_pads[] = { MX6_PAD_SD4_DAT7__USDHC4_DAT7 | MUX_PAD_CTRL(USDHC_PAD_CTRL), };
+iomux_v3_cfg_t const ecspi1_pads[] = { + MX6_PAD_KEY_COL0__ECSPI1_SCLK | MUX_PAD_CTRL(SPI_PAD_CTRL), + MX6_PAD_KEY_COL1__ECSPI1_MISO | MUX_PAD_CTRL(SPI_PAD_CTRL), + MX6_PAD_KEY_ROW0__ECSPI1_MOSI | MUX_PAD_CTRL(SPI_PAD_CTRL), + MX6_PAD_KEY_ROW1__GPIO_4_9 | MUX_PAD_CTRL(NO_PAD_CTRL), +}; + +static void setup_spi(void) +{ + imx_iomux_v3_setup_multiple_pads(ecspi1_pads, ARRAY_SIZE(ecspi1_pads)); +} + static void setup_iomux_uart(void) { imx_iomux_v3_setup_multiple_pads(uart1_pads, ARRAY_SIZE(uart1_pads)); @@ -454,6 +469,10 @@ int board_init(void) /* address of boot parameters */ gd->bd->bi_boot_params = PHYS_SDRAM + 0x100;
+#ifdef CONFIG_MXC_SPI + setup_spi(); +#endif + return 0; }
diff --git a/include/configs/mx6sabre_common.h b/include/configs/mx6sabre_common.h index bf6113b..cfd3e48 100644 --- a/include/configs/mx6sabre_common.h +++ b/include/configs/mx6sabre_common.h @@ -60,6 +60,17 @@ #define CONFIG_PHYLIB #define CONFIG_PHY_ATHEROS
+#define CONFIG_CMD_SF +#ifdef CONFIG_CMD_SF +#define CONFIG_SPI_FLASH +#define CONFIG_SPI_FLASH_STMICRO +#define CONFIG_MXC_SPI +#define CONFIG_SF_DEFAULT_BUS 0 +#define CONFIG_SF_DEFAULT_CS (0 | (IMX_GPIO_NR(4, 9) << 8)) +#define CONFIG_SF_DEFAULT_SPEED 20000000 +#define CONFIG_SF_DEFAULT_MODE SPI_MODE_0 +#endif + /* allow to overwrite serial and ethaddr */ #define CONFIG_ENV_OVERWRITE #define CONFIG_CONS_INDEX 1
Add support for it.
Applied to u-boot-imx, thanks.
Best regards, Stefano Babic
Fabio Estevam
Stefano Babic
