[U-Boot] [PATCH] [sensor]: Make the LM75 MULTI_BUS compatible.
also fix CodingStyle issues for the LM75
Signed-off-by: Heiko Schocher hs@denx.de --- drivers/hwmon/lm75.c | 228 +++++++++++++++++++++++--------------------------- 1 files changed, 105 insertions(+), 123 deletions(-)
diff --git a/drivers/hwmon/lm75.c b/drivers/hwmon/lm75.c index 67a18f6..b95601d 100644 --- a/drivers/hwmon/lm75.c +++ b/drivers/hwmon/lm75.c @@ -50,159 +50,141 @@
int dtt_read(int sensor, int reg) { - int dlen; - uchar data[2]; + int dlen; + uchar data[2];
#ifdef CONFIG_DTT_AD7414 - /* - * On AD7414 the first value upon bootup is not read correctly. - * This is most likely because of the 800ms update time of the - * temp register in normal update mode. To get current values - * each time we issue the "dtt" command including upon powerup - * we switch into one-short mode. - * - * Issue one-shot mode command - */ - dtt_write(sensor, DTT_CONFIG, 0x64); + /* + * On AD7414 the first value upon bootup is not read correctly. + * This is most likely because of the 800ms update time of the + * temp register in normal update mode. To get current values + * each time we issue the "dtt" command including upon powerup + * we switch into one-short mode. + * + * Issue one-shot mode command + */ + dtt_write(sensor, DTT_CONFIG, 0x64); #endif
- /* - * Validate 'reg' param - */ - if((reg < 0) || (reg > 3)) - return -1; - - /* - * Calculate sensor address and register. - */ - sensor = DTT_I2C_DEV_CODE + (sensor & 0x07); /* calculate address of lm75 */ - - /* - * Prepare to handle 2 byte result. - */ - if ((reg == DTT_READ_TEMP) || - (reg == DTT_TEMP_HYST) || - (reg == DTT_TEMP_SET)) - dlen = 2; - else - dlen = 1; - - /* - * Now try to read the register. - */ - if (i2c_read(sensor, reg, 1, data, dlen) != 0) - return -1; - - /* - * Handle 2 byte result. - */ - if (dlen == 2) - return ((int)((short)data[1] + (((short)data[0]) << 8))); - - - return (int)data[0]; + /* Validate 'reg' param */ + if((reg < 0) || (reg > 3)) + return -1; + + /* Calculate sensor address and register. */ + sensor = DTT_I2C_DEV_CODE + (sensor & 0x07); + + /* Prepare to handle 2 byte result. */ + if ((reg == DTT_READ_TEMP) || + (reg == DTT_TEMP_HYST) || + (reg == DTT_TEMP_SET)) + dlen = 2; + else + dlen = 1; + + /* Now try to read the register. */ + if (i2c_read(sensor, reg, 1, data, dlen) != 0) + return -1; + + /* Handle 2 byte result. */ + if (dlen == 2) + return ((int)((short)data[1] + (((short)data[0]) << 8))); + + return (int)data[0]; } /* dtt_read() */
int dtt_write(int sensor, int reg, int val) { - int dlen; - uchar data[2]; - - /* - * Validate 'reg' param - */ - if ((reg < 0) || (reg > 3)) - return 1; - - /* - * Calculate sensor address and register. - */ - sensor = DTT_I2C_DEV_CODE + (sensor & 0x07); /* calculate address of lm75 */ - - /* - * Handle 2 byte values. - */ - if ((reg == DTT_READ_TEMP) || - (reg == DTT_TEMP_HYST) || - (reg == DTT_TEMP_SET)) { - dlen = 2; - data[0] = (char)((val >> 8) & 0xff); /* MSB first */ - data[1] = (char)(val & 0xff); - } else { - dlen = 1; - data[0] = (char)(val & 0xff); - } - - /* - * Write value to register. - */ - if (i2c_write(sensor, reg, 1, data, dlen) != 0) - return 1; - - return 0; + int dlen; + uchar data[2]; + + /* Validate 'reg' param */ + if ((reg < 0) || (reg > 3)) + return 1; + + /* Calculate sensor address and register. */ + sensor = DTT_I2C_DEV_CODE + (sensor & 0x07); + + /* Handle 2 byte values. */ + if ((reg == DTT_READ_TEMP) || + (reg == DTT_TEMP_HYST) || + (reg == DTT_TEMP_SET)) { + dlen = 2; + data[0] = (char)((val >> 8) & 0xff); /* MSB first */ + data[1] = (char)(val & 0xff); + } else { + dlen = 1; + data[0] = (char)(val & 0xff); + } + + /* Write value to register. */ + if (i2c_write(sensor, reg, 1, data, dlen) != 0) + return 1; + + return 0; } /* dtt_write() */
static int _dtt_init(int sensor) { - int val; - - /* - * Setup TSET ( trip point ) register - */ - val = ((CFG_DTT_MAX_TEMP * 2) << 7) & 0xff80; /* trip */ - if (dtt_write(sensor, DTT_TEMP_SET, val) != 0) - return 1; - - /* - * Setup THYST ( untrip point ) register - Hysteresis - */ - val = (((CFG_DTT_MAX_TEMP - CFG_DTT_HYSTERESIS) * 2) << 7) & 0xff80; - if (dtt_write(sensor, DTT_TEMP_HYST, val) != 0) - return 1; - - /* - * Setup configuraton register - */ + int val; + + /* Setup TSET ( trip point ) register */ + val = ((CFG_DTT_MAX_TEMP * 2) << 7) & 0xff80; /* trip */ + if (dtt_write(sensor, DTT_TEMP_SET, val) != 0) + return 1; + + /* Setup THYST ( untrip point ) register - Hysteresis */ + val = (((CFG_DTT_MAX_TEMP - CFG_DTT_HYSTERESIS) * 2) << 7) & 0xff80; + if (dtt_write(sensor, DTT_TEMP_HYST, val) != 0) + return 1; + + /* Setup configuraton register */ #ifdef CONFIG_DTT_AD7414 - /* config = alert active low and disabled */ - val = 0x60; + /* config = alert active low and disabled */ + val = 0x60; #else - /* config = 6 sample integration, int mode, active low, and enable */ - val = 0x18; + /* config = 6 sample integration, int mode, active low, and enable */ + val = 0x18; #endif - if (dtt_write(sensor, DTT_CONFIG, val) != 0) - return 1; + if (dtt_write(sensor, DTT_CONFIG, val) != 0) + return 1;
- return 0; + return 0; } /* _dtt_init() */
int dtt_init (void) { - int i; - unsigned char sensors[] = CONFIG_DTT_SENSORS; - const char *const header = "DTT: "; + int i; + unsigned char sensors[] = CONFIG_DTT_SENSORS; + const char *const header = "DTT: "; + int old_bus; + + /* switch to correct I2C bus */ + old_bus = I2C_GET_BUS(); + I2C_SET_BUS(CFG_DTT_BUS_NUM);
- for (i = 0; i < sizeof(sensors); i++) { + for (i = 0; i < sizeof(sensors); i++) { if (_dtt_init(sensors[i]) != 0) - printf("%s%d FAILED INIT\n", header, i+1); + printf("%s%d FAILED INIT\n", header, i+1); else - printf("%s%d is %i C\n", header, i+1, - dtt_get_temp(sensors[i])); - } + printf("%s%d is %i C\n", header, i+1, + dtt_get_temp(sensors[i])); + } + /* switch back to original I2C bus */ + I2C_SET_BUS(old_bus);
- return (0); + return (0); } /* dtt_init() */
int dtt_get_temp(int sensor) { - int const ret = dtt_read(sensor, DTT_READ_TEMP); + int const ret = dtt_read(sensor, DTT_READ_TEMP);
- if (ret < 0) { - printf("DTT temperature read failed.\n"); - return 0; - } - return (int)((int16_t) ret / 256); + if (ret < 0) { + printf("DTT temperature read failed.\n"); + return 0; + } + return (int)((int16_t) ret / 256); } /* dtt_get_temp() */
Hi Heiko,
Please don't mix functional changes and coding style changes into one patch. I suggest that you first send a coding style cleanup patch and then a functional patch on top of this.
Thanks.
Best regards, Stefan
Dear Heiko Schocher,
- int dlen;
- uchar data[2];
- int dlen;
- uchar data[2];
Please split your additions and any code clean up into separate patches. As is, it's impossible to see what you actually changed.
Heiko Schocher
Stefan Roese
