[U-Boot] [PATCH v3 1/7] tegra: Rework Tamonten support
This commit uses the common Tegra board implementation instead of duplicating a lot of the code. In addition, the Plutux and Medcom specific board files can be removed as the MMC/SD setup is common among all Tamonten-based boards.
Signed-off-by: Thierry Reding thierry.reding@avionic-design.de Acked-by: Stephen Warren swarren@wwwdotorg.org --- Changes in v3: - none
Changes in v2: - new patch
board/avionic-design/common/tamonten.c | 49 +++++--------------------------- board/avionic-design/common/tamonten.h | 32 --------------------- board/avionic-design/medcom/Makefile | 6 ++-- board/avionic-design/medcom/medcom.c | 45 ----------------------------- board/avionic-design/plutux/Makefile | 6 ++-- board/avionic-design/plutux/plutux.c | 45 ----------------------------- 6 files changed, 13 insertions(+), 170 deletions(-) delete mode 100644 board/avionic-design/common/tamonten.h delete mode 100644 board/avionic-design/medcom/medcom.c delete mode 100644 board/avionic-design/plutux/plutux.c
diff --git a/board/avionic-design/common/tamonten.c b/board/avionic-design/common/tamonten.c index f23b657..d9ecd23 100644 --- a/board/avionic-design/common/tamonten.c +++ b/board/avionic-design/common/tamonten.c @@ -1,7 +1,7 @@ /* * (C) Copyright 2010,2011 * NVIDIA Corporation <www.nvidia.com> - * (C) Copyright 2011 + * (C) Copyright 2011-2012 * Avionic Design GmbH <www.avionic-design.de> * * See file CREDITS for list of people who contributed to this @@ -36,25 +36,17 @@ #include <asm/arch/pinmux.h> #include <asm/arch/uart.h> #include <asm/arch/mmc.h> -#include "tamonten.h"
#ifdef CONFIG_TEGRA2_MMC #include <mmc.h> #endif
-DECLARE_GLOBAL_DATA_PTR; - -const struct tegra2_sysinfo sysinfo = { - CONFIG_TEGRA2_BOARD_STRING -}; - /* - * Routine: timer_init - * Description: init the timestamp and lastinc value + * Routine: gpio_config_uart + * Description: Does nothing on Tamonten - no conflict w/SPI. */ -int timer_init(void) +void gpio_config_uart(void) { - return 0; }
#ifdef CONFIG_TEGRA2_MMC @@ -65,46 +57,19 @@ int timer_init(void) static void pin_mux_mmc(void) { funcmux_select(PERIPH_ID_SDMMC4, FUNCMUX_SDMMC4_ATB_GMA_GME_8_BIT); + /* for CD GPIO PH2 */ + pinmux_tristate_disable(PINGRP_ATD); } -#endif - -/* - * Routine: board_init - * Description: Early hardware init. - */ -int board_init(void) -{ - clock_init(); - clock_verify(); - - /* boot param addr */ - gd->bd->bi_boot_params = (NV_PA_SDRAM_BASE + 0x100);
- return 0; -} - -#ifdef CONFIG_TEGRA2_MMC /* this is a weak define that we are overriding */ int board_mmc_init(bd_t *bd) { - debug("board_mmc_init called\n"); /* Enable muxes, etc. for SDMMC controllers */ pin_mux_mmc(); - gpio_config_mmc();
- debug("board_mmc_init: init eMMC\n"); - /* init dev 0, eMMC chip, with 4-bit bus */ + /* init dev 0, SD slot, with 4-bit bus */ tegra2_mmc_init(0, 4, -1, GPIO_PH2);
return 0; } #endif - -#ifdef CONFIG_BOARD_EARLY_INIT_F -int board_early_init_f(void) -{ - /* Initialize selected UARTs */ - board_init_uart_f(); - return 0; -} -#endif /* EARLY_INIT */ diff --git a/board/avionic-design/common/tamonten.h b/board/avionic-design/common/tamonten.h deleted file mode 100644 index 0e60b0f..0000000 --- a/board/avionic-design/common/tamonten.h +++ /dev/null @@ -1,32 +0,0 @@ -/* - * (C) Copyright 2010,2011 - * NVIDIA Corporation <www.nvidia.com> - * (C) Copyright 2011 - * Avionic Design GmbH <www.avionic-design.de> - * - * See file CREDITS for list of people who contributed to this - * project. - * - * This program is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License as - * published by the Free Software Foundation; either version 2 of - * the License, or (at your option) any later version. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public License - * along with this program; if not, write to the Free Software - * Foundation, Inc., 59 Temple Place, Suite 330, Boston, - * MA 02111-1307 USA - */ - -#ifndef _TAMONTEN_H_ -#define _TAMONTEN_H_ - -void tegra2_start(void); -void gpio_config_mmc(void); - -#endif /* TAMONTEN_H */ diff --git a/board/avionic-design/medcom/Makefile b/board/avionic-design/medcom/Makefile index b0c318c..d96d043 100644 --- a/board/avionic-design/medcom/Makefile +++ b/board/avionic-design/medcom/Makefile @@ -1,7 +1,7 @@ # # (C) Copyright 2010,2011 # NVIDIA Corporation <www.nvidia.com> -# (C) Copyright 2011 +# (C) Copyright 2011,2012 # Avionic Design GmbH <www.avionic-design.de> # # See file CREDITS for list of people who contributed to this @@ -26,12 +26,12 @@ include $(TOPDIR)/config.mk
ifneq ($(OBJTREE),$(SRCTREE)) -$(shell mkdir -p $(obj)../common) +$(shell mkdir -p $(obj)../common $(obj)../../nvidia/common) endif
LIB = $(obj)lib$(BOARD).o
-COBJS := $(BOARD).o +COBJS := ../../nvidia/common/board.o COBJS += ../common/tamonten.o
SRCS := $(COBJS:.o=.c) diff --git a/board/avionic-design/medcom/medcom.c b/board/avionic-design/medcom/medcom.c deleted file mode 100644 index 42c8094..0000000 --- a/board/avionic-design/medcom/medcom.c +++ /dev/null @@ -1,45 +0,0 @@ -/* - * (C) Copyright 2010,2011 - * NVIDIA Corporation <www.nvidia.com> - * (C) Copyright 2011 - * Avionic Design GmbH <www.avionic-design.de> - * - * See file CREDITS for list of people who contributed to this - * project. - * - * This program is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License as - * published by the Free Software Foundation; either version 2 of - * the License, or (at your option) any later version. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public License - * along with this program; if not, write to the Free Software - * Foundation, Inc., 59 Temple Place, Suite 330, Boston, - * MA 02111-1307 USA - */ - -#include <common.h> -#include <asm/io.h> -#include <asm/gpio.h> -#include <asm/arch/tegra2.h> -#ifdef CONFIG_TEGRA2_MMC -#include <mmc.h> -#endif - -#ifdef CONFIG_TEGRA2_MMC -/* - * Routine: gpio_config_mmc - * Description: Set GPIOs for SD card - */ -void gpio_config_mmc(void) -{ - /* configure pin as input for card detect */ - gpio_request(GPIO_PH2, "SD4 CD"); - gpio_direction_input(GPIO_PH2); -} -#endif diff --git a/board/avionic-design/plutux/Makefile b/board/avionic-design/plutux/Makefile index b0c318c..d96d043 100644 --- a/board/avionic-design/plutux/Makefile +++ b/board/avionic-design/plutux/Makefile @@ -1,7 +1,7 @@ # # (C) Copyright 2010,2011 # NVIDIA Corporation <www.nvidia.com> -# (C) Copyright 2011 +# (C) Copyright 2011,2012 # Avionic Design GmbH <www.avionic-design.de> # # See file CREDITS for list of people who contributed to this @@ -26,12 +26,12 @@ include $(TOPDIR)/config.mk
SRCS := $(COBJS:.o=.c) diff --git a/board/avionic-design/plutux/plutux.c b/board/avionic-design/plutux/plutux.c deleted file mode 100644 index 42c8094..0000000 --- a/board/avionic-design/plutux/plutux.c +++ /dev/null @@ -1,45 +0,0 @@ -/* - * (C) Copyright 2010,2011 - * NVIDIA Corporation <www.nvidia.com> - * (C) Copyright 2011 - * Avionic Design GmbH <www.avionic-design.de> - * - * See file CREDITS for list of people who contributed to this - * project. - * - * This program is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License as - * published by the Free Software Foundation; either version 2 of - * the License, or (at your option) any later version. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public License - * along with this program; if not, write to the Free Software - * Foundation, Inc., 59 Temple Place, Suite 330, Boston, - * MA 02111-1307 USA - */ - -#include <common.h> -#include <asm/io.h> -#include <asm/gpio.h> -#include <asm/arch/tegra2.h> -#ifdef CONFIG_TEGRA2_MMC -#include <mmc.h> -#endif - -#ifdef CONFIG_TEGRA2_MMC -/* - * Routine: gpio_config_mmc - * Description: Set GPIOs for SD card - */ -void gpio_config_mmc(void) -{ - /* configure pin as input for card detect */ - gpio_request(GPIO_PH2, "SD4 CD"); - gpio_direction_input(GPIO_PH2); -} -#endif
Device tree support is required for working USB host support, which in turn enables ethernet support.
Changes in v2: - drop chosen and sdhci@c8000600 nodes from DTS - drop CONFIG_USB_ETHER_ASIX from configuration
board/avionic-design/dts/tegra2-medcom.dts | 58 ++++++++++++++++++++++++++++ include/configs/medcom.h | 21 +++++++++- 2 files changed, 78 insertions(+), 1 deletion(-) create mode 100644 board/avionic-design/dts/tegra2-medcom.dts
diff --git a/board/avionic-design/dts/tegra2-medcom.dts b/board/avionic-design/dts/tegra2-medcom.dts new file mode 100644 index 0000000..fc52f9c --- /dev/null +++ b/board/avionic-design/dts/tegra2-medcom.dts @@ -0,0 +1,58 @@ +/dts-v1/; + +/include/ ARCH_CPU_DTS + +/ { + model = "Avionic Design Medcom-Wide"; + compatible = "avionic-design,medcom", "nvidia,tegra20"; + + aliases { + usb0 = "/usb@c5008000"; + }; + + memory { + reg = <0x00000000 0x20000000>; + }; + + clocks { + clk_32k: clk_32k { + clock-frequency = <32000>; + }; + + osc { + clock-frequency = <12000000>; + }; + }; + + clock@60006000 { + clocks = <&clk_32k &osc>; + }; + + serial@70006300 { + clock-frequency = <216000000>; + }; + + i2c@7000c000 { + status = "disabled"; + }; + + i2c@7000c400 { + status = "disabled"; + }; + + i2c@7000c500 { + status = "disabled"; + }; + + i2c@7000d000 { + status = "disabled"; + }; + + usb@c5000000 { + status = "disabled"; + }; + + usb@c5004000 { + status = "disabled"; + }; +}; diff --git a/include/configs/medcom.h b/include/configs/medcom.h index bdea7c9..c84db03 100644 --- a/include/configs/medcom.h +++ b/include/configs/medcom.h @@ -1,7 +1,7 @@ /* * (C) Copyright 2010,2011 * NVIDIA Corporation <www.nvidia.com> - * (C) Copyright 2011 + * (C) Copyright 2011-2012 * Avionic Design GmbH <www.avionic-design.de> * * See file CREDITS for list of people who contributed to this @@ -28,6 +28,11 @@
#include "tegra2-common.h"
+/* Enable fdt support for Medcom. Flash the image in u-boot-dtb.bin */ +#define CONFIG_DEFAULT_DEVICE_TREE tegra2-medcom +#define CONFIG_OF_CONTROL +#define CONFIG_OF_SEPARATE + /* High-level configuration options */ #define V_PROMPT "Tegra2 (Medcom) # " #define CONFIG_TEGRA2_BOARD_STRING "Avionic Design Medcom" @@ -47,6 +52,20 @@ #define CONFIG_TEGRA_MMC #define CONFIG_CMD_MMC
+/* USB host support */ +#define CONFIG_USB_EHCI +#define CONFIG_USB_EHCI_TEGRA +#define CONFIG_USB_STORAGE +#define CONFIG_CMD_USB + +/* USB networking support */ +#define CONFIG_USB_HOST_ETHER +#define CONFIG_USB_ETHER_SMSC95XX + +/* General networking support */ +#define CONFIG_CMD_NET +#define CONFIG_CMD_DHCP + #define CONFIG_DOS_PARTITION #define CONFIG_EFI_PARTITION #define CONFIG_CMD_EXT2
board/avionic-design/dts/tegra2-plutux.dts | 58 ++++++++++++++++++++++++++++ include/configs/plutux.h | 21 +++++++++- 2 files changed, 78 insertions(+), 1 deletion(-) create mode 100644 board/avionic-design/dts/tegra2-plutux.dts
diff --git a/board/avionic-design/dts/tegra2-plutux.dts b/board/avionic-design/dts/tegra2-plutux.dts new file mode 100644 index 0000000..cef49ad --- /dev/null +++ b/board/avionic-design/dts/tegra2-plutux.dts @@ -0,0 +1,58 @@ +/dts-v1/; + +/include/ ARCH_CPU_DTS + +/ { + model = "Avionic Design Plutux"; + compatible = "avionic-design,plutux", "nvidia,tegra20"; + + aliases { + usb0 = "/usb@c5008000"; + }; + + memory { + reg = <0x00000000 0x20000000>; + }; + + clocks { + clk_32k: clk_32k { + clock-frequency = <32000>; + }; + + osc { + clock-frequency = <12000000>; + }; + }; + + clock@60006000 { + clocks = <&clk_32k &osc>; + }; + + serial@70006300 { + clock-frequency = <216000000>; + }; + + i2c@7000c000 { + status = "disabled"; + }; + + i2c@7000c400 { + status = "disabled"; + }; + + i2c@7000c500 { + status = "disabled"; + }; + + i2c@7000d000 { + status = "disabled"; + }; + + usb@c5000000 { + status = "disabled"; + }; + + usb@c5004000 { + status = "disabled"; + }; +}; diff --git a/include/configs/plutux.h b/include/configs/plutux.h index 6397eb1..9870590 100644 --- a/include/configs/plutux.h +++ b/include/configs/plutux.h @@ -1,7 +1,7 @@ /* * (C) Copyright 2010,2011 * NVIDIA Corporation <www.nvidia.com> - * (C) Copyright 2011 + * (C) Copyright 2011-2012 * Avionic Design GmbH <www.avionic-design.de> * * See file CREDITS for list of people who contributed to this @@ -28,6 +28,11 @@
+/* Enable fdt support for Plutux. Flash the image in u-boot-dtb.bin */ +#define CONFIG_DEFAULT_DEVICE_TREE tegra2-plutux +#define CONFIG_OF_CONTROL +#define CONFIG_OF_SEPARATE + /* High-level configuration options */ #define V_PROMPT "Tegra2 (Plutux) # " #define CONFIG_TEGRA2_BOARD_STRING "Avionic Design Plutux" @@ -47,6 +52,20 @@ #define CONFIG_TEGRA_MMC #define CONFIG_CMD_MMC
The new gpio_early_init() function, which does nothing by default, can be overridden by boards to configure GPIOs at an early stage.
Changes in v2: - new patch required for TEC support
board/nvidia/common/board.c | 7 +++++++ board/nvidia/common/board.h | 1 + 2 files changed, 8 insertions(+)
diff --git a/board/nvidia/common/board.c b/board/nvidia/common/board.c index 2e22133..a159deb 100644 --- a/board/nvidia/common/board.c +++ b/board/nvidia/common/board.c @@ -132,11 +132,18 @@ int board_init(void) }
#ifdef CONFIG_BOARD_EARLY_INIT_F +static void __gpio_early_init(void) +{ +} + +void gpio_early_init(void) __attribute__((weak, alias("__gpio_early_init"))); + int board_early_init_f(void) { board_init_uart_f();
/* Initialize periph GPIOs */ + gpio_early_init(); #ifdef CONFIG_SPI_UART_SWITCH gpio_early_init_uart(); #else diff --git a/board/nvidia/common/board.h b/board/nvidia/common/board.h index 09fb158..dada4c4 100644 --- a/board/nvidia/common/board.h +++ b/board/nvidia/common/board.h @@ -25,6 +25,7 @@ #define _BOARD_H_
void gpio_config_uart(void); +void gpio_early_init(void); void gpio_early_init_uart(void);
The PI4 GPIO is used on Tamonten to reset carrier board peripherals. Power sequencing hardware on the carrier pulls the reset low before powering up the Tegra, and the CPU is supposed to signal readiness, and therefore bring peripherals out of reset by pulling PI4 high.
Signed-off-by: Thierry Reding thierry.reding@avionic-design.de Acked-by: Stephen Warren swarren@wwwdotorg.org --- Changes in v3: - do not free PI4 GPIO after configuring it
board/avionic-design/common/tamonten.c | 8 ++++++++ 1 file changed, 8 insertions(+)
diff --git a/board/avionic-design/common/tamonten.c b/board/avionic-design/common/tamonten.c index d9ecd23..915247c 100644 --- a/board/avionic-design/common/tamonten.c +++ b/board/avionic-design/common/tamonten.c @@ -49,6 +49,14 @@ void gpio_config_uart(void) { }
+#ifdef CONFIG_BOARD_EARLY_INIT_F +void gpio_early_init(void) +{ + gpio_request(GPIO_PI4, NULL); + gpio_direction_output(GPIO_PI4, 1); +} +#endif + #ifdef CONFIG_TEGRA2_MMC /* * Routine: pin_mux_mmc
GPIO PI6 can be used to obtain the write-protect status of an SD card inserted into the SD slot.
board/avionic-design/common/tamonten.c | 4 +++- 1 file changed, 3 insertions(+), 1 deletion(-)
diff --git a/board/avionic-design/common/tamonten.c b/board/avionic-design/common/tamonten.c index 915247c..610f188 100644 --- a/board/avionic-design/common/tamonten.c +++ b/board/avionic-design/common/tamonten.c @@ -65,6 +65,8 @@ void gpio_early_init(void) static void pin_mux_mmc(void) { funcmux_select(PERIPH_ID_SDMMC4, FUNCMUX_SDMMC4_ATB_GMA_GME_8_BIT); + /* for write-protect GPIO PI6 */ + pinmux_tristate_disable(PINGRP_ATA); /* for CD GPIO PH2 */ pinmux_tristate_disable(PINGRP_ATD); } @@ -76,7 +78,7 @@ int board_mmc_init(bd_t *bd) pin_mux_mmc();
/* init dev 0, SD slot, with 4-bit bus */ - tegra2_mmc_init(0, 4, -1, GPIO_PH2); + tegra2_mmc_init(0, 4, GPIO_PI6, GPIO_PH2);
return 0; }
The Tamonten Evaluation Carrier is an evaluation board for the Tamonten processor board. More information is available here:
http://www.avionic-design.de/en/products/nvidia-tegra-tamonten-system-en/nvi...
Signed-off-by: Thierry Reding thierry.reding@avionic-design.de Acked-by: Stephen Warren swarren@wwwdotorg.org --- Changes in v3: - drop obsolete TEGRA2_SYSMEM definition - rename CONFIG_TEGRA2_MMC to CONFIG_TEGRA_MMC - add MAINTAINERS entry
MAINTAINERS | 1 + board/avionic-design/dts/tegra2-tec.dts | 58 ++++++++++++++++++++++ board/avionic-design/tec/Makefile | 50 +++++++++++++++++++ boards.cfg | 1 + include/configs/tec.h | 82 +++++++++++++++++++++++++++++++ 5 files changed, 192 insertions(+) create mode 100644 board/avionic-design/dts/tegra2-tec.dts create mode 100644 board/avionic-design/tec/Makefile create mode 100644 include/configs/tec.h
diff --git a/MAINTAINERS b/MAINTAINERS index 9d35c0e..52e3909 100644 --- a/MAINTAINERS +++ b/MAINTAINERS @@ -806,6 +806,7 @@ Thierry Reding thierry.reding@avionic-design.de
plutux Tegra2 (ARM7 & A9 Dual Core) medcom Tegra2 (ARM7 & A9 Dual Core) + tec Tegra2 (ARM7 & A9 Dual Core)
Christian Riesch christian.riesch@omicron.at Manfred Rudigier manfred.rudigier@omicron.at diff --git a/board/avionic-design/dts/tegra2-tec.dts b/board/avionic-design/dts/tegra2-tec.dts new file mode 100644 index 0000000..9faebd8 --- /dev/null +++ b/board/avionic-design/dts/tegra2-tec.dts @@ -0,0 +1,58 @@ +/dts-v1/; + +/include/ ARCH_CPU_DTS + +/ { + model = "Avionic Design Tamonten Evaluation Carrier"; + compatible = "avionic-design,tec", "nvidia,tegra20"; + + aliases { + usb0 = "/usb@c5008000"; + }; + + memory { + reg = <0x00000000 0x20000000>; + }; + + clocks { + clk_32k: clk_32k { + clock-frequency = <32000>; + }; + + osc { + clock-frequency = <12000000>; + }; + }; + + clock@60006000 { + clocks = <&clk_32k &osc>; + }; + + serial@70006300 { + clock-frequency = <216000000>; + }; + + i2c@7000c000 { + status = "disabled"; + }; + + i2c@7000c400 { + status = "disabled"; + }; + + i2c@7000c500 { + status = "disabled"; + }; + + i2c@7000d000 { + status = "disabled"; + }; + + usb@c5000000 { + status = "disabled"; + }; + + usb@c5004000 { + status = "disabled"; + }; +}; diff --git a/board/avionic-design/tec/Makefile b/board/avionic-design/tec/Makefile new file mode 100644 index 0000000..d96d043 --- /dev/null +++ b/board/avionic-design/tec/Makefile @@ -0,0 +1,50 @@ +# +# (C) Copyright 2010,2011 +# NVIDIA Corporation <www.nvidia.com> +# (C) Copyright 2011,2012 +# Avionic Design GmbH <www.avionic-design.de> +# +# See file CREDITS for list of people who contributed to this +# project. +# +# This program is free software; you can redistribute it and/or +# modify it under the terms of the GNU General Public License as +# published by the Free Software Foundation; either version 2 of +# the License, or (at your option) any later version. +# +# This program is distributed in the hope that it will be useful, +# but WITHOUT ANY WARRANTY; without even the implied warranty of +# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# GNU General Public License for more details. +# +# You should have received a copy of the GNU General Public License +# along with this program; if not, write to the Free Software +# Foundation, Inc., 59 Temple Place, Suite 330, Boston, +# MA 02111-1307 USA +# + +include $(TOPDIR)/config.mk + +ifneq ($(OBJTREE),$(SRCTREE)) +$(shell mkdir -p $(obj)../common $(obj)../../nvidia/common) +endif + +LIB = $(obj)lib$(BOARD).o + +COBJS := ../../nvidia/common/board.o +COBJS += ../common/tamonten.o + +SRCS := $(COBJS:.o=.c) +OBJS := $(addprefix $(obj),$(COBJS)) + +$(LIB): $(obj).depend $(OBJS) + $(call cmd_link_o_target, $(OBJS)) + +######################################################################### + +# defines $(obj).depend target +include $(SRCTREE)/rules.mk + +sinclude $(obj).depend + +######################################################################### diff --git a/boards.cfg b/boards.cfg index e983b05..7138279 100644 --- a/boards.cfg +++ b/boards.cfg @@ -259,6 +259,7 @@ colibri_pxa270 arm pxa - toradex jornada arm sa1100 plutux arm armv7 plutux avionic-design tegra2 medcom arm armv7 medcom avionic-design tegra2 +tec arm armv7 tec avionic-design tegra2 paz00 arm armv7 paz00 compal tegra2 trimslice arm armv7 trimslice compulab tegra2 atngw100 avr32 at32ap - atmel at32ap700x diff --git a/include/configs/tec.h b/include/configs/tec.h new file mode 100644 index 0000000..3d0a788 --- /dev/null +++ b/include/configs/tec.h @@ -0,0 +1,82 @@ +/* + * (C) Copyright 2010,2011 + * NVIDIA Corporation <www.nvidia.com> + * (C) Copyright 2011-2012 + * Avionic Design GmbH <www.avionic-design.de> + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#ifndef __CONFIG_H +#define __CONFIG_H + +#include "tegra2-common.h" + +/* Enable fdt support for TEC. Flash the image in u-boot-dtb.bin */ +#define CONFIG_DEFAULT_DEVICE_TREE tegra2-tec +#define CONFIG_OF_CONTROL +#define CONFIG_OF_SEPARATE + +/* High-level configuration options */ +#define V_PROMPT "Tegra2 (TEC) # " +#define CONFIG_TEGRA2_BOARD_STRING "Avionic Design Tamonten Evaluation Carrier" +#define CONFIG_SYS_BOARD_ODMDATA 0x2b0d8011 + +/* Board-specific serial config */ +#define CONFIG_SERIAL_MULTI +#define CONFIG_TEGRA2_ENABLE_UARTD /* UARTD: debug UART */ +#define CONFIG_SYS_NS16550_COM1 NV_PA_APB_UARTD_BASE + +#define CONFIG_BOARD_EARLY_INIT_F + +#define CONFIG_ENV_IS_NOWHERE + +/* SD/MMC */ +#define CONFIG_MMC +#define CONFIG_GENERIC_MMC +#define CONFIG_TEGRA_MMC +#define CONFIG_CMD_MMC + +/* USB host support */ +#define CONFIG_USB_EHCI +#define CONFIG_USB_EHCI_TEGRA +#define CONFIG_USB_STORAGE +#define CONFIG_CMD_USB + +/* USB networking support */ +#define CONFIG_USB_HOST_ETHER +#define CONFIG_USB_ETHER_SMSC95XX + +/* General networking support */ +#define CONFIG_CMD_NET +#define CONFIG_CMD_DHCP + +#define CONFIG_DOS_PARTITION +#define CONFIG_EFI_PARTITION +#define CONFIG_CMD_EXT2 +#define CONFIG_CMD_FAT + +#define CONFIG_FIT + +#define CONFIG_BOOTCOMMAND \ + "mmc rescan;" \ + "ext2load mmc 0 0x17000000 /boot/uImage;" \ + "bootm" + +#endif /* __CONFIG_H */
http://www.avionic-design.de/en/products/nvidia-tegra-tamonten-system-en/nvidia-tegra-tamonten-evboard-en.html
"mmc rescan;" \
"bootm"
You're not including "tegra2-common-post.h" here, is that on purpose? I think it's preferable if all tegra boards include both tegra2-common and tegra2-common-post to make it easier to apply changes across the board.
-Allen
"mmc rescan;" \
"bootm"
Yes, that was on purpose. I still need to figure out if I want to use Stephen's boot commands as defined in tegra2-common-post.h. But I just realized that since our boards define CONFIG_BOOTCOMMAND, including it won't hurt much anyway. I also just noticed that Stephen added it for Medcom and Plutux already and I'm fine with you carrying the TEC change in your series.
Thierry
Allen Martin
Thierry Reding
