[U-Boot-Users] relocate_code problem
Hi all,
I try to get up U-Boot 1.1.1 on a "home brewed" board with MPC8280 and have problems with the relocation of code. It crashes after the call of in_ram. It seems that it calculates the address of in_ram correctly, but the copied code is somehow shifted. Is there anyone who can point me to the function that copies the code into RAM? Sorry, but the assembler code is not my favorite thing.
Thanks in advance, Oliver
---- some extra info:
symbol in_ram is linked to 0xfff03404 relocate_code is called: relocate_code( 03fbdf48, 03fbdf6c, 03fdf000) relocate_ram jumps to 0x03fe2404 // there is code, but not in_ram
Maybe it just looks shifted or repeated?
RTFM - http://www.denx.de/twiki/bin/view/DULG/UBootCrashAfterRelocation
You don't need much knowledge about assembler code. "grep" will just do fine (hint: search for "relocate_code", and probably you want to searchin the relevant directory with CPU specific code, i. e. "cpu/mpc8260/").
From: Wolfgang Denk wd@denx.de Date sent: Tue, 06 Jul 2004 10:06:21 +0200
You are right. It was hard to accept the idea that the seen code was not within the RAM.
It was not the problem to find relocate_code. I was not smart enough to recognize the nice little loop. Because the destination content did not change during relocate_code, I thought it was done elsewhere.
Thanks, Oliver Fuchs
Probably your SDRAM init sequence is broken.
Well, check your RAM init code.
Oliver Fuchs
