[U-Boot] [PATCH v2] include: usb: Rename USB controller base address mapping
Remove Soc specific defines and use generic chasis specific defines for USB controller base address mapping.
Signed-off-by: Rajesh Bhagat rajesh.bhagat@nxp.com --- Changes in v2: - Rebased patch for latest u-boot
.../include/asm/arch-fsl-layerscape/immap_lsch2.h | 6 +++--- .../include/asm/arch-fsl-layerscape/immap_lsch3.h | 4 ++-- arch/arm/include/asm/arch-ls102xa/config.h | 6 ++---- include/linux/usb/xhci-fsl.h | 20 ++++++++------------ include/usb/ehci-ci.h | 2 +- 5 files changed, 16 insertions(+), 22 deletions(-)
diff --git a/arch/arm/include/asm/arch-fsl-layerscape/immap_lsch2.h b/arch/arm/include/asm/arch-fsl-layerscape/immap_lsch2.h index e98e055..0c87c2f 100644 --- a/arch/arm/include/asm/arch-fsl-layerscape/immap_lsch2.h +++ b/arch/arm/include/asm/arch-fsl-layerscape/immap_lsch2.h @@ -31,9 +31,9 @@ #define CONFIG_SYS_NS16550_COM2 (CONFIG_SYS_IMMR + 0x011c0600) #define CONFIG_SYS_NS16550_COM3 (CONFIG_SYS_IMMR + 0x011d0500) #define CONFIG_SYS_NS16550_COM4 (CONFIG_SYS_IMMR + 0x011d0600) -#define CONFIG_SYS_LS1043A_XHCI_USB1_ADDR (CONFIG_SYS_IMMR + 0x01f00000) -#define CONFIG_SYS_LS1043A_XHCI_USB2_ADDR (CONFIG_SYS_IMMR + 0x02000000) -#define CONFIG_SYS_LS1043A_XHCI_USB3_ADDR (CONFIG_SYS_IMMR + 0x02100000) +#define CONFIG_SYS_XHCI_USB1_ADDR (CONFIG_SYS_IMMR + 0x01f00000) +#define CONFIG_SYS_XHCI_USB2_ADDR (CONFIG_SYS_IMMR + 0x02000000) +#define CONFIG_SYS_XHCI_USB3_ADDR (CONFIG_SYS_IMMR + 0x02100000) #define CONFIG_SYS_PCIE1_ADDR (CONFIG_SYS_IMMR + 0x2400000) #define CONFIG_SYS_PCIE2_ADDR (CONFIG_SYS_IMMR + 0x2500000) #define CONFIG_SYS_PCIE3_ADDR (CONFIG_SYS_IMMR + 0x2600000) diff --git a/arch/arm/include/asm/arch-fsl-layerscape/immap_lsch3.h b/arch/arm/include/asm/arch-fsl-layerscape/immap_lsch3.h index 65b3357..2dc9e5c 100644 --- a/arch/arm/include/asm/arch-fsl-layerscape/immap_lsch3.h +++ b/arch/arm/include/asm/arch-fsl-layerscape/immap_lsch3.h @@ -51,8 +51,8 @@ #define I2C3_BASE_ADDR (CONFIG_SYS_IMMR + 0x01020000) #define I2C4_BASE_ADDR (CONFIG_SYS_IMMR + 0x01030000)
-#define CONFIG_SYS_LS2080A_XHCI_USB1_ADDR (CONFIG_SYS_IMMR + 0x02100000) -#define CONFIG_SYS_LS2080A_XHCI_USB2_ADDR (CONFIG_SYS_IMMR + 0x02110000) +#define CONFIG_SYS_XHCI_USB1_ADDR (CONFIG_SYS_IMMR + 0x02100000) +#define CONFIG_SYS_XHCI_USB2_ADDR (CONFIG_SYS_IMMR + 0x02110000)
/* TZ Address Space Controller Definitions */ #define TZASC1_BASE 0x01100000 /* as per CCSR map. */ diff --git a/arch/arm/include/asm/arch-ls102xa/config.h b/arch/arm/include/asm/arch-ls102xa/config.h index 04abec4..67a4311 100644 --- a/arch/arm/include/asm/arch-ls102xa/config.h +++ b/arch/arm/include/asm/arch-ls102xa/config.h @@ -35,13 +35,11 @@ #define CONFIG_SYS_NS16550_COM1 (CONFIG_SYS_IMMR + 0x011c0500) #define CONFIG_SYS_NS16550_COM2 (CONFIG_SYS_IMMR + 0x011d0500) #define CONFIG_SYS_DCU_ADDR (CONFIG_SYS_IMMR + 0x01ce0000) -#define CONFIG_SYS_LS102XA_XHCI_USB1_ADDR (CONFIG_SYS_IMMR + 0x02100000) -#define CONFIG_SYS_LS102XA_USB1_ADDR \ - (CONFIG_SYS_IMMR + CONFIG_SYS_LS102XA_USB1_OFFSET) +#define CONFIG_SYS_XHCI_USB1_ADDR (CONFIG_SYS_IMMR + 0x02100000) +#define CONFIG_SYS_EHCI_USB1_ADDR (CONFIG_SYS_IMMR + 0x07600000)
#define CONFIG_SYS_FSL_SEC_OFFSET 0x00700000 #define CONFIG_SYS_FSL_JR0_OFFSET 0x00710000 -#define CONFIG_SYS_LS102XA_USB1_OFFSET 0x07600000 #define CONFIG_SYS_TSEC1_OFFSET 0x01d10000 #define CONFIG_SYS_TSEC2_OFFSET 0x01d50000 #define CONFIG_SYS_TSEC3_OFFSET 0x01d90000 diff --git a/include/linux/usb/xhci-fsl.h b/include/linux/usb/xhci-fsl.h index 253eddf..199f366 100644 --- a/include/linux/usb/xhci-fsl.h +++ b/include/linux/usb/xhci-fsl.h @@ -51,22 +51,18 @@ struct fsl_xhci { struct dwc3 *dwc3_reg; };
-#if defined(CONFIG_LS102XA) -#define CONFIG_SYS_FSL_XHCI_USB1_ADDR CONFIG_SYS_LS102XA_XHCI_USB1_ADDR +#if defined(CONFIG_LS102XA) || defined(CONFIG_LS1012A) +#define CONFIG_SYS_FSL_XHCI_USB1_ADDR CONFIG_SYS_XHCI_USB1_ADDR #define CONFIG_SYS_FSL_XHCI_USB2_ADDR 0 #define CONFIG_SYS_FSL_XHCI_USB3_ADDR 0 #elif defined(CONFIG_LS2080A) -#define CONFIG_SYS_FSL_XHCI_USB1_ADDR CONFIG_SYS_LS2080A_XHCI_USB1_ADDR -#define CONFIG_SYS_FSL_XHCI_USB2_ADDR CONFIG_SYS_LS2080A_XHCI_USB2_ADDR -#define CONFIG_SYS_FSL_XHCI_USB3_ADDR 0 -#elif defined(CONFIG_LS1043A) || defined(CONFIG_LS1012A) -#define CONFIG_SYS_FSL_XHCI_USB1_ADDR CONFIG_SYS_LS1043A_XHCI_USB1_ADDR -#define CONFIG_SYS_FSL_XHCI_USB2_ADDR CONFIG_SYS_LS1043A_XHCI_USB2_ADDR -#define CONFIG_SYS_FSL_XHCI_USB3_ADDR CONFIG_SYS_LS1043A_XHCI_USB3_ADDR -#elif defined(CONFIG_LS1012A) -#define CONFIG_SYS_FSL_XHCI_USB1_ADDR CONFIG_SYS_LS1043A_XHCI_USB1_ADDR -#define CONFIG_SYS_FSL_XHCI_USB2_ADDR 0 +#define CONFIG_SYS_FSL_XHCI_USB1_ADDR CONFIG_SYS_XHCI_USB1_ADDR +#define CONFIG_SYS_FSL_XHCI_USB2_ADDR CONFIG_SYS_XHCI_USB2_ADDR #define CONFIG_SYS_FSL_XHCI_USB3_ADDR 0 +#elif defined(CONFIG_LS1043A) +#define CONFIG_SYS_FSL_XHCI_USB1_ADDR CONFIG_SYS_XHCI_USB1_ADDR +#define CONFIG_SYS_FSL_XHCI_USB2_ADDR CONFIG_SYS_XHCI_USB2_ADDR +#define CONFIG_SYS_FSL_XHCI_USB3_ADDR CONFIG_SYS_XHCI_USB3_ADDR #endif
#define FSL_USB_XHCI_ADDR {CONFIG_SYS_FSL_XHCI_USB1_ADDR, \ diff --git a/include/usb/ehci-ci.h b/include/usb/ehci-ci.h index 586d32a..882aed4 100644 --- a/include/usb/ehci-ci.h +++ b/include/usb/ehci-ci.h @@ -160,7 +160,7 @@ #define CONFIG_SYS_FSL_USB1_ADDR CONFIG_SYS_MPC512x_USB1_ADDR #define CONFIG_SYS_FSL_USB2_ADDR 0 #elif defined(CONFIG_LS102XA) -#define CONFIG_SYS_FSL_USB1_ADDR CONFIG_SYS_LS102XA_USB1_ADDR +#define CONFIG_SYS_FSL_USB1_ADDR CONFIG_SYS_EHCI_USB1_ADDR #define CONFIG_SYS_FSL_USB2_ADDR 0 #endif
Changes in v2:
<snip>
Do you plan to consolidate the above section?
York
-----Original Message----- From: york sun Sent: Thursday, June 16, 2016 9:13 PM To: Rajesh Bhagat rajesh.bhagat@nxp.com; u-boot@lists.denx.de Cc: Qianyu.Gong@freescale.com; Mingkai.hu@freescale.com; prabhakar@freescale.com Subject: Re: [PATCH v2] include: usb: Rename USB controller base address mapping
Changes in v2:
<snip>
-#if defined(CONFIG_LS102XA) -#define CONFIG_SYS_FSL_XHCI_USB1_ADDR CONFIG_SYS_LS102XA_XHCI_USB1_ADDR +#if defined(CONFIG_LS102XA) || defined(CONFIG_LS1012A) #define +CONFIG_SYS_FSL_XHCI_USB1_ADDR CONFIG_SYS_XHCI_USB1_ADDR #define CONFIG_SYS_FSL_XHCI_USB2_ADDR 0 #define CONFIG_SYS_FSL_XHCI_USB3_ADDR 0 #elif defined(CONFIG_LS2080A) -#define CONFIG_SYS_FSL_XHCI_USB1_ADDR CONFIG_SYS_LS2080A_XHCI_USB1_ADDR -#define CONFIG_SYS_FSL_XHCI_USB2_ADDR CONFIG_SYS_LS2080A_XHCI_USB2_ADDR -#define CONFIG_SYS_FSL_XHCI_USB3_ADDR 0 -#elif defined(CONFIG_LS1043A) || defined(CONFIG_LS1012A) -#define CONFIG_SYS_FSL_XHCI_USB1_ADDR CONFIG_SYS_LS1043A_XHCI_USB1_ADDR -#define CONFIG_SYS_FSL_XHCI_USB2_ADDR CONFIG_SYS_LS1043A_XHCI_USB2_ADDR -#define CONFIG_SYS_FSL_XHCI_USB3_ADDR CONFIG_SYS_LS1043A_XHCI_USB3_ADDR -
#elif
Hello York,
Do you mean making the macro defines common as below?
#define CONFIG_SYS_FSL_XHCI_USB1_ADDR 0 #define CONFIG_SYS_FSL_XHCI_USB2_ADDR 0 #define CONFIG_SYS_FSL_XHCI_USB3_ADDR 0
#if defined(CONFIG_LS102XA) || defined(CONFIG_LS1012A) || defined(CONFIG_LS2080A) || defined(CONFIG_LS2085A) || defined(CONFIG_LS1043A) #undef CONFIG_SYS_FSL_XHCI_USB1_ADDR #define CONFIG_SYS_FSL_XHCI_USB1_ADDR CONFIG_SYS_XHCI_USB1_ADDR #endif
#if defined(CONFIG_LS2080A) || defined(CONFIG_LS2085A) || defined(CONFIG_LS1043A) #undef CONFIG_SYS_FSL_XHCI_USB2_ADDR #define CONFIG_SYS_FSL_XHCI_USB2_ADDR CONFIG_SYS_XHCI_USB2_ADDR #endif
#if defined(CONFIG_LS1043A) #undef CONFIG_SYS_FSL_XHCI_USB3_ADDR #define CONFIG_SYS_FSL_XHCI_USB3_ADDR CONFIG_SYS_XHCI_USB3_ADDR #endif
Best Regards, Rajesh Bhagat
York
Changes in v2:
<snip>
#elif
Hello York,
No. I mean to replace this section as
#ifndef CONFIG_SYS_FSL_XHCI_USB1_ADDR #define CONFIG_SYS_FSL_XHCI_USB1_ADDR 0 #endif #ifndef CONFIG_SYS_FSL_XHCI_USB2_ADD #define CONFIG_SYS_FSL_XHCI_USB2_ADD 0 #endif #ifndef CONFIG_SYS_FSL_XHCI_USB3_ADD #define CONFIG_SYS_FSL_XHCI_USB3_ADD 0 #endif
Then you don't need to check SoC macros at all.
York
-----Original Message----- From: york sun Sent: Friday, June 17, 2016 9:07 AM To: Rajesh Bhagat rajesh.bhagat@nxp.com; u-boot@lists.denx.de Cc: Qianyu.Gong@freescale.com; Mingkai.hu@freescale.com; prabhakar@freescale.com Subject: Re: [PATCH v2] include: usb: Rename USB controller base address mapping
Changes in v2:
<snip>
#elif
#endif
Hello York,
0
#endif
Hello York,
Actually, we are trying to re-use macros defined in chasis specific files for other platform of same chasis i.e. LS1012A. For example,
File: arch/arm/include/asm/arch-fsl-layerscape/immap_lsch2.h
Original: #define CONFIG_SYS_LS1043A_XHCI_USB1_ADDR (CONFIG_SYS_IMMR + 0x01f00000) #define CONFIG_SYS_LS1043A_XHCI_USB2_ADDR (CONFIG_SYS_IMMR + 0x02000000) #define CONFIG_SYS_LS1043A_XHCI_USB3_ADDR (CONFIG_SYS_IMMR + 0x02100000)
Proposed (Made macros common): #define CONFIG_SYS_XHCI_USB1_ADDR (CONFIG_SYS_IMMR + 0x01f00000) #define CONFIG_SYS_XHCI_USB2_ADDR (CONFIG_SYS_IMMR + 0x02000000) #define CONFIG_SYS_XHCI_USB3_ADDR (CONFIG_SYS_IMMR + 0x02100000)
Now, LS1012A has same address as chasis is same but number of USB controllers in only one. Board specific decision for controller count is take in file include/linux/usb/xhci-fsl.h in above code.
Hence, if I take implementation suggested by you I need to use Soc specific flags in file arch/arm/include/asm/arch-fsl-layerscape/immap_lsch2.h which I was trying to avoid.
York
<snip>
#elif
#endif
Hello York,
0
#endif
Hello York,
OK. You need to use ifdef somewhere. You can keep it your way.
York
-----Original Message----- From: york sun Sent: Monday, June 27, 2016 8:58 PM To: Rajesh Bhagat rajesh.bhagat@nxp.com; u-boot@lists.denx.de Cc: Qianyu.Gong@freescale.com; Mingkai.hu@freescale.com; prabhakar@freescale.com Subject: Re: [PATCH v2] include: usb: Rename USB controller base address mapping
<snip>
#elif
#endif
Hello York,
0
#define
#endif
Hello York,
0
0x01f00000)
0x02000000)
0x02100000)
0x01f00000)
0x02000000)
0x02100000)
only one.
Hello York,
Are you planning to pick this?
York
On 07/08/2016 10:02 PM, Rajesh Bhagat wrote:
Hello York,
Yes, I will pick it after 07 release.
York
Changes in v2:
Applied to fsl-qoriq master. Awaiting upstream. Thanks.
York
Rajesh Bhagat
york sun
