[U-Boot-Users] [GIT PULL] MIPS updates
Please pull MIPS updates to pick up the following patches.
The following changes since commit 8155efbd7ae9c65564ca98affe94631d612ae088: Wolfgang Denk (1): Merge branch 'master' of ssh://mercury/home/wd/git/u-boot/master
git://git.denx.de/u-boot-mips.git master
Shinya Kuribayashi (8): [MIPS] lib_mips/time.c: Replace CP0 access functions with existing macros [MIPS] lib_mips/time.c: Fix udelay [MIPS] lib_mips/time.c: Fix CP0 count register usage and timer routines [MIPS] Kill unused <version.h> inclusions [MIPS] mips_config.mk: Misc fixes [MIPS] Update <asm/addrspace.h> header [MIPS] Rename Alchemy processor configs into CONFIGO_SOC_* [MIPS] cpu/mips/Makefile: Split [CS]OBJS onto separate lines
board/dbau1x00/lowlevel_init.S | 1 - board/gth2/gth2.c | 2 +- board/gth2/lowlevel_init.S | 1 - board/incaip/incaip.c | 2 +- board/incaip/lowlevel_init.S | 1 - board/pb1x00/lowlevel_init.S | 1 - board/purple/lowlevel_init.S | 1 - board/purple/purple.c | 14 ++-- board/qemu-mips/lowlevel_init.S | 1 - board/tb0229/lowlevel_init.S | 1 - board/tb0229/vr4131-pci.c | 56 ++++++------ cpu/mips/Makefile | 15 ++-- cpu/mips/asc_serial.c | 3 - cpu/mips/au1x00_eth.c | 12 +-- cpu/mips/au1x00_serial.c | 4 - cpu/mips/au1x00_usb_ohci.c | 2 +- cpu/mips/cache.S | 7 +- cpu/mips/incaip_wdt.S | 1 - cpu/mips/start.S | 1 - drivers/net/inca-ip_sw.c | 28 +++--- include/asm-mips/addrspace.h | 173 +++++++++++++++++++++++++++++---------- include/asm-mips/au1x00.h | 6 +- include/asm-mips/io.h | 4 +- include/configs/dbau1x00.h | 14 ++-- include/configs/gth2.h | 8 +- include/configs/incaip.h | 4 +- include/configs/pb1x00.h | 12 ++- include/configs/purple.h | 3 +- include/configs/qemu-mips.h | 4 +- include/configs/tb0229.h | 4 +- lib_mips/time.c | 57 ++++++------- mips_config.mk | 7 +- 32 files changed, 263 insertions(+), 187 deletions(-)
diff --git a/board/dbau1x00/lowlevel_init.S b/board/dbau1x00/lowlevel_init.S index 27b51f7..13e6bfc 100644 --- a/board/dbau1x00/lowlevel_init.S +++ b/board/dbau1x00/lowlevel_init.S @@ -1,7 +1,6 @@ /* Memory sub-system initialization code */
#include <config.h> -#include <version.h> #include <asm/regdef.h> #include <asm/au1x00.h> #include <asm/mipsregs.h> diff --git a/board/gth2/gth2.c b/board/gth2/gth2.c index 9bc4d3f..3e56678 100644 --- a/board/gth2/gth2.c +++ b/board/gth2/gth2.c @@ -36,7 +36,7 @@ static int wdi_status = 0; #define SDRAM_SIZE ((64*1024*1024)-(12*4096))
-#define SERIAL_LOG_BUFFER KSEG1ADDR(SDRAM_SIZE + (8*4096)) +#define SERIAL_LOG_BUFFER CKSEG1ADDR(SDRAM_SIZE + (8*4096))
void inline log_serial_char(char c){ char *serial_log_buffer = (char*)SERIAL_LOG_BUFFER; diff --git a/board/gth2/lowlevel_init.S b/board/gth2/lowlevel_init.S index bf615c1..4c4f0eb 100644 --- a/board/gth2/lowlevel_init.S +++ b/board/gth2/lowlevel_init.S @@ -1,7 +1,6 @@ /* Memory sub-system initialization code */
#include <config.h> -#include <version.h> #include <asm/regdef.h> #include <asm/au1x00.h> #include <asm/mipsregs.h> diff --git a/board/incaip/incaip.c b/board/incaip/incaip.c index c624b3d..dc51373 100644 --- a/board/incaip/incaip.c +++ b/board/incaip/incaip.c @@ -63,7 +63,7 @@ long int initdram(int board_type)
/* Can't probe for RAM size unless we are running from Flash. */ - if (PHYSADDR(our_address) < PHYSADDR(PHYS_FLASH_1)) + if (CPHYSADDR(our_address) < CPHYSADDR(PHYS_FLASH_1)) { return max_sdram_size(); } diff --git a/board/incaip/lowlevel_init.S b/board/incaip/lowlevel_init.S index 08f7f21..fe525ec 100644 --- a/board/incaip/lowlevel_init.S +++ b/board/incaip/lowlevel_init.S @@ -23,7 +23,6 @@ */
diff --git a/board/pb1x00/lowlevel_init.S b/board/pb1x00/lowlevel_init.S index 98bb394..b145e43 100644 --- a/board/pb1x00/lowlevel_init.S +++ b/board/pb1x00/lowlevel_init.S @@ -1,7 +1,6 @@ /* Memory sub-system initialization code */
#include <config.h> -#include <version.h> #include <asm/regdef.h> #include <asm/au1x00.h> #include <asm/mipsregs.h> diff --git a/board/purple/lowlevel_init.S b/board/purple/lowlevel_init.S index b9d03fc..1bd3edb 100644 --- a/board/purple/lowlevel_init.S +++ b/board/purple/lowlevel_init.S @@ -23,7 +23,6 @@ */
#define MC_IOGP 0xBF800800 diff --git a/board/purple/purple.c b/board/purple/purple.c index 89cb906..72d5734 100644 --- a/board/purple/purple.c +++ b/board/purple/purple.c @@ -85,16 +85,16 @@ static void sdram_timing_init (ulong size) while (p4 < 32 && done == 0) { WRITE_MC_IOGP_1;
- for (addr = KSEG1 + 0x4000; - addr < KSEG1ADDR (size); + for (addr = CKSEG1 + 0x4000; + addr < CKSEG1ADDR (size); addr = addr + 4) { *(uint *) addr = 0xaa55aa55; }
pass = 1;
- for (addr = KSEG1 + 0x4000; - addr < KSEG1ADDR (size) && pass == 1; + for (addr = CKSEG1 + 0x4000; + addr < CKSEG1ADDR (size) && pass == 1; addr = addr + 4) { if (*(uint *) addr != 0xaa55aa55) pass = 0; @@ -138,7 +138,7 @@ long int initdram(int board_type) ulong size = (1 << (rows + cols)) * (1 << (dw - 1)) * CFG_NB; void (* sdram_init) (ulong);
- sdram_init = (void (*)(ulong)) KSEG0ADDR(&sdram_timing_init); + sdram_init = (void (*)(ulong)) CKSEG0ADDR(&sdram_timing_init);
sdram_init(0x10000);
@@ -260,14 +260,14 @@ void copy_code (ulong dest_addr) /* flush caches */
- start = KSEG0; + start = CKSEG0; end = start + CFG_DCACHE_SIZE; while(start < end) { cache_unroll(start,Index_Writeback_Inv_D); start += CFG_CACHELINE_SIZE; }
- start = KSEG0; + start = CKSEG0; end = start + CFG_ICACHE_SIZE; while(start < end) { cache_unroll(start,Index_Invalidate_I); diff --git a/board/qemu-mips/lowlevel_init.S b/board/qemu-mips/lowlevel_init.S index 836e027..b0f7072 100644 --- a/board/qemu-mips/lowlevel_init.S +++ b/board/qemu-mips/lowlevel_init.S @@ -1,7 +1,6 @@ /* Memory sub-system initialization code */
#include <config.h> -#include <version.h> #include <asm/regdef.h> #include <asm/mipsregs.h>
diff --git a/board/tb0229/lowlevel_init.S b/board/tb0229/lowlevel_init.S index df31806..5fce856 100644 --- a/board/tb0229/lowlevel_init.S +++ b/board/tb0229/lowlevel_init.S @@ -10,7 +10,6 @@ */
diff --git a/board/tb0229/vr4131-pci.c b/board/tb0229/vr4131-pci.c index 0ee4bf3..4c91923 100644 --- a/board/tb0229/vr4131-pci.c +++ b/board/tb0229/vr4131-pci.c @@ -13,34 +13,34 @@ #include <pci.h> #include <asm/addrspace.h>
-#define VR4131_PCIMMAW1REG (volatile unsigned int*)(KSEG1 + 0x0f000c00) -#define VR4131_PCIMMAW2REG (volatile unsigned int*)(KSEG1 + 0x0f000c04) -#define VR4131_PCITAW1REG (volatile unsigned int*)(KSEG1 + 0x0f000c08) -#define VR4131_PCITAW2REG (volatile unsigned int*)(KSEG1 + 0x0f000c0c) -#define VR4131_PCIMIOAWREG (volatile unsigned int*)(KSEG1 + 0x0f000c10) -#define VR4131_PCICONFDREG (volatile unsigned int*)(KSEG1 + 0x0f000c14) -#define VR4131_PCICONFAREG (volatile unsigned int*)(KSEG1 + 0x0f000c18) -#define VR4131_PCIMAILREG (volatile unsigned int*)(KSEG1 + 0x0f000c1c) -#define VR4131_BUSERRADREG (volatile unsigned int*)(KSEG1 + 0x0f000c24) -#define VR4131_INTCNTSTAREG (volatile unsigned int*)(KSEG1 + 0x0f000c28) -#define VR4131_PCIEXACCREG (volatile unsigned int*)(KSEG1 + 0x0f000c2c) -#define VR4131_PCIRECONTREG (volatile unsigned int*)(KSEG1 + 0x0f000c30) -#define VR4131_PCIENREG (volatile unsigned int*)(KSEG1 + 0x0f000c34) -#define VR4131_PCICLKSELREG (volatile unsigned int*)(KSEG1 + 0x0f000c38) -#define VR4131_PCITRDYREG (volatile unsigned int*)(KSEG1 + 0x0f000c3c) -#define VR4131_PCICLKRUNREG (volatile unsigned int*)(KSEG1 + 0x0f000c60) -#define VR4131_PCIHOSTCONFIG (volatile unsigned int*)(KSEG1 + 0x0f000d00) -#define VR4131_VENDORIDREG (volatile unsigned int*)(KSEG1 + 0x0f000d00) -#define VR4131_DEVICEIDREG (volatile unsigned int*)(KSEG1 + 0x0f000d00) -#define VR4131_COMMANDREG (volatile unsigned int*)(KSEG1 + 0x0f000d04) -#define VR4131_STATUSREG (volatile unsigned int*)(KSEG1 + 0x0f000d04) -#define VR4131_REVREG (volatile unsigned int*)(KSEG1 + 0x0f000d08) -#define VR4131_CLASSREG (volatile unsigned int*)(KSEG1 + 0x0f000d08) -#define VR4131_CACHELSREG (volatile unsigned int*)(KSEG1 + 0x0f000d0c) -#define VR4131_LATTIMERRG (volatile unsigned int*)(KSEG1 + 0x0f000d0c) -#define VR4131_MAILBAREG (volatile unsigned int*)(KSEG1 + 0x0f000d10) -#define VR4131_PCIMBA1REG (volatile unsigned int*)(KSEG1 + 0x0f000d14) -#define VR4131_PCIMBA2REG (volatile unsigned int*)(KSEG1 + 0x0f000d18) +#define VR4131_PCIMMAW1REG (volatile unsigned int *)(CKSEG1 + 0x0f000c00) +#define VR4131_PCIMMAW2REG (volatile unsigned int *)(CKSEG1 + 0x0f000c04) +#define VR4131_PCITAW1REG (volatile unsigned int *)(CKSEG1 + 0x0f000c08) +#define VR4131_PCITAW2REG (volatile unsigned int *)(CKSEG1 + 0x0f000c0c) +#define VR4131_PCIMIOAWREG (volatile unsigned int *)(CKSEG1 + 0x0f000c10) +#define VR4131_PCICONFDREG (volatile unsigned int *)(CKSEG1 + 0x0f000c14) +#define VR4131_PCICONFAREG (volatile unsigned int *)(CKSEG1 + 0x0f000c18) +#define VR4131_PCIMAILREG (volatile unsigned int *)(CKSEG1 + 0x0f000c1c) +#define VR4131_BUSERRADREG (volatile unsigned int *)(CKSEG1 + 0x0f000c24) +#define VR4131_INTCNTSTAREG (volatile unsigned int *)(CKSEG1 + 0x0f000c28) +#define VR4131_PCIEXACCREG (volatile unsigned int *)(CKSEG1 + 0x0f000c2c) +#define VR4131_PCIRECONTREG (volatile unsigned int *)(CKSEG1 + 0x0f000c30) +#define VR4131_PCIENREG (volatile unsigned int *)(CKSEG1 + 0x0f000c34) +#define VR4131_PCICLKSELREG (volatile unsigned int *)(CKSEG1 + 0x0f000c38) +#define VR4131_PCITRDYREG (volatile unsigned int *)(CKSEG1 + 0x0f000c3c) +#define VR4131_PCICLKRUNREG (volatile unsigned int *)(CKSEG1 + 0x0f000c60) +#define VR4131_PCIHOSTCONFIG (volatile unsigned int *)(CKSEG1 + 0x0f000d00) +#define VR4131_VENDORIDREG (volatile unsigned int *)(CKSEG1 + 0x0f000d00) +#define VR4131_DEVICEIDREG (volatile unsigned int *)(CKSEG1 + 0x0f000d00) +#define VR4131_COMMANDREG (volatile unsigned int *)(CKSEG1 + 0x0f000d04) +#define VR4131_STATUSREG (volatile unsigned int *)(CKSEG1 + 0x0f000d04) +#define VR4131_REVREG (volatile unsigned int *)(CKSEG1 + 0x0f000d08) +#define VR4131_CLASSREG (volatile unsigned int *)(CKSEG1 + 0x0f000d08) +#define VR4131_CACHELSREG (volatile unsigned int *)(CKSEG1 + 0x0f000d0c) +#define VR4131_LATTIMERRG (volatile unsigned int *)(CKSEG1 + 0x0f000d0c) +#define VR4131_MAILBAREG (volatile unsigned int *)(CKSEG1 + 0x0f000d10) +#define VR4131_PCIMBA1REG (volatile unsigned int *)(CKSEG1 + 0x0f000d14) +#define VR4131_PCIMBA2REG (volatile unsigned int *)(CKSEG1 + 0x0f000d18)
/*#define VR41XX_PCIIRQ_OFFSET (VR41XX_IRQ_MAX + 1) */ /*#define VR41XX_PCIIRQ_MAX (VR41XX_IRQ_MAX + 12) */ diff --git a/cpu/mips/Makefile b/cpu/mips/Makefile index 92dcc16..5091781 100644 --- a/cpu/mips/Makefile +++ b/cpu/mips/Makefile @@ -25,13 +25,16 @@ include $(TOPDIR)/config.mk
LIB = $(obj)lib$(CPU).a
-START = start.o -COBJS = asc_serial.o au1x00_serial.o au1x00_eth.o au1x00_usb_ohci.o \ - cpu.o interrupts.o incaip_clock.o -SOBJS = incaip_wdt.o cache.o +SOBJS-y = cache.o +COBJS-y = cpu.o interrupts.o
-SRCS := $(START:.o=.S) $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(SOBJS) $(COBJS)) +SOBJS-$(CONFIG_INCA_IP) += incaip_wdt.o +COBJS-$(CONFIG_INCA_IP) += asc_serial.o incaip_clock.o +COBJS-$(CONFIG_PURPLE) += asc_serial.o +COBJS-$(CONFIG_SOC_AU1X00) += au1x00_eth.o au1x00_serial.o au1x00_usb_ohci.o + +SRCS := $(START:.o=.S) $(SOBJS-y:.o=.S) $(COBJS-y:.o=.c) +OBJS := $(addprefix $(obj),$(SOBJS-y) $(COBJS-y)) START := $(addprefix $(obj),$(START))
all: $(obj).depend $(START) $(LIB) diff --git a/cpu/mips/asc_serial.c b/cpu/mips/asc_serial.c index 3498b61..be686c2 100644 --- a/cpu/mips/asc_serial.c +++ b/cpu/mips/asc_serial.c @@ -4,8 +4,6 @@
#include <config.h>
-#if defined(CONFIG_PURPLE) || defined(CONFIG_INCA_IP) - #ifdef CONFIG_PURPLE #define serial_init asc_serial_init #define serial_putc asc_serial_putc @@ -368,4 +366,3 @@ int serial_tstc (void)
return res; } -#endif /* CONFIG_PURPLE || CONFIG_INCA_IP */ diff --git a/cpu/mips/au1x00_eth.c b/cpu/mips/au1x00_eth.c index d70c5fe..d0cf8e0 100644 --- a/cpu/mips/au1x00_eth.c +++ b/cpu/mips/au1x00_eth.c @@ -23,8 +23,6 @@ */ #include <config.h>
-#ifdef CONFIG_AU1X00 - #if defined(CFG_DISCOVER_PHY) #error "PHY not supported yet" /* We just assume that we are running 100FD for now */ @@ -33,20 +31,20 @@
/* I assume ethernet behaves like au1000 */
-#ifdef CONFIG_AU1000 +#ifdef CONFIG_SOC_AU1000 /* Base address differ between cpu:s */ #define ETH0_BASE AU1000_ETH0_BASE #define MAC0_ENABLE AU1000_MAC0_ENABLE #else -#ifdef CONFIG_AU1100 +#ifdef CONFIG_SOC_AU1100 #define ETH0_BASE AU1100_ETH0_BASE #define MAC0_ENABLE AU1100_MAC0_ENABLE #else -#ifdef CONFIG_AU1500 +#ifdef CONFIG_SOC_AU1500 #define ETH0_BASE AU1500_ETH0_BASE #define MAC0_ENABLE AU1500_MAC0_ENABLE #else -#ifdef CONFIG_AU1550 +#ifdef CONFIG_SOC_AU1550 #define ETH0_BASE AU1550_ETH0_BASE #define MAC0_ENABLE AU1550_MAC0_ENABLE #else @@ -307,5 +305,3 @@ int au1x00_enet_initialize(bd_t *bis){
return 1; } - -#endif /* CONFIG_AU1X00 */ diff --git a/cpu/mips/au1x00_serial.c b/cpu/mips/au1x00_serial.c index 42c668e..6309794 100644 --- a/cpu/mips/au1x00_serial.c +++ b/cpu/mips/au1x00_serial.c @@ -26,9 +26,6 @@ */
#include <config.h> - -#ifdef CONFIG_AU1X00 - #include <common.h> #include <asm/au1x00.h>
@@ -132,4 +129,3 @@ int serial_tstc (void) } return 0; } -#endif /* CONFIG_SERIAL_AU1X00 */ diff --git a/cpu/mips/au1x00_usb_ohci.c b/cpu/mips/au1x00_usb_ohci.c index dbf72dc..1ca8aaf 100644 --- a/cpu/mips/au1x00_usb_ohci.c +++ b/cpu/mips/au1x00_usb_ohci.c @@ -35,7 +35,7 @@
#include <config.h>
-#if defined(CONFIG_AU1X00) && defined(CONFIG_USB_OHCI) +#ifdef CONFIG_USB_OHCI
/* #include <pci.h> no PCI on the AU1x00 */
diff --git a/cpu/mips/cache.S b/cpu/mips/cache.S index 1b0efc3..ee5d411 100644 --- a/cpu/mips/cache.S +++ b/cpu/mips/cache.S @@ -23,7 +23,6 @@ */
#include <config.h> -#include <version.h> #include <asm/asm.h> #include <asm/regdef.h> #include <asm/mipsregs.h> @@ -41,7 +40,7 @@ */ #define MIPS_MAX_CACHE_SIZE 0x10000
-#define INDEX_BASE KSEG0 +#define INDEX_BASE CKSEG0
.macro cache_op op addr .set push @@ -219,7 +218,7 @@ NESTED(mips_cache_reset, 0, ra) /* * Now clear that much memory starting from zero. */ - PTR_LI a0, KSEG1 + PTR_LI a0, CKSEG1 PTR_ADDU a1, a0, v0 2: PTR_ADDIU a0, 64 f_fill64 a0, -64, zero @@ -319,7 +318,7 @@ LEAF(dcache_enable) .globl mips_cache_lock .ent mips_cache_lock mips_cache_lock: - li a1, K0BASE - CACHE_LOCK_SIZE + li a1, CKSEG0 - CACHE_LOCK_SIZE addu a0, a1 li a2, CACHE_LOCK_SIZE li a3, CFG_CACHELINE_SIZE diff --git a/cpu/mips/incaip_wdt.S b/cpu/mips/incaip_wdt.S index 329386b..3ade3cd 100644 --- a/cpu/mips/incaip_wdt.S +++ b/cpu/mips/incaip_wdt.S @@ -24,7 +24,6 @@
diff --git a/cpu/mips/start.S b/cpu/mips/start.S index d881879..09e4aab 100644 --- a/cpu/mips/start.S +++ b/cpu/mips/start.S @@ -23,7 +23,6 @@ */
diff --git a/drivers/net/inca-ip_sw.c b/drivers/net/inca-ip_sw.c index e4aaed6..a079b60 100644 --- a/drivers/net/inca-ip_sw.c +++ b/drivers/net/inca-ip_sw.c @@ -234,7 +234,7 @@ static int inca_switch_init(struct eth_device *dev, bd_t * bis) /* Initialize the descriptor rings. */ for (i = 0; i < NUM_RX_DESC; i++) { - inca_rx_descriptor_t * rx_desc = KSEG1ADDR(&rx_ring[i]); + inca_rx_descriptor_t * rx_desc = (inca_rx_descriptor_t *)CKSEG1ADDR(&rx_ring[i]); memset(rx_desc, 0, sizeof(rx_ring[i]));
/* Set maximum size of receive buffer. @@ -252,14 +252,14 @@ static int inca_switch_init(struct eth_device *dev, bd_t * bis) /* Let the last descriptor point to the first * one. */ - rx_desc->nextRxDescPtr = KSEG1ADDR((u32)rx_ring); + rx_desc->nextRxDescPtr = (u32)CKSEG1ADDR(rx_ring); } else { /* Set the address of the next descriptor. */ - rx_desc->nextRxDescPtr = (u32)KSEG1ADDR(&rx_ring[i+1]); + rx_desc->nextRxDescPtr = (u32)CKSEG1ADDR(&rx_ring[i+1]); }
- rx_desc->RxDataPtr = (u32)KSEG1ADDR(NetRxPackets[i]); + rx_desc->RxDataPtr = (u32)CKSEG1ADDR(NetRxPackets[i]); }
#if 0 @@ -268,7 +268,7 @@ static int inca_switch_init(struct eth_device *dev, bd_t * bis) #endif
for (i = 0; i < NUM_TX_DESC; i++) { - inca_tx_descriptor_t * tx_desc = KSEG1ADDR(&tx_ring[i]); + inca_tx_descriptor_t * tx_desc = (inca_tx_descriptor_t *)CKSEG1ADDR(&tx_ring[i]);
memset(tx_desc, 0, sizeof(tx_ring[i]));
@@ -282,11 +282,11 @@ static int inca_switch_init(struct eth_device *dev, bd_t * bis) /* Let the last descriptor point to the * first one. */ - tx_desc->nextTxDescPtr = KSEG1ADDR((u32)tx_ring); + tx_desc->nextTxDescPtr = (u32)CKSEG1ADDR(tx_ring); } else { /* Set the address of the next descriptor. */ - tx_desc->nextTxDescPtr = (u32)KSEG1ADDR(&tx_ring[i+1]); + tx_desc->nextTxDescPtr = (u32)CKSEG1ADDR(&tx_ring[i+1]); } }
@@ -346,7 +346,7 @@ static int inca_switch_send(struct eth_device *dev, volatile void *packet, int l int res = -1; u32 command; u32 regValue; - inca_tx_descriptor_t * tx_desc = KSEG1ADDR(&tx_ring[tx_new]); + inca_tx_descriptor_t * tx_desc = (inca_tx_descriptor_t *)CKSEG1ADDR(&tx_ring[tx_new]);
#if 0 printf("Entered inca_switch_send()\n"); @@ -365,7 +365,7 @@ static int inca_switch_send(struct eth_device *dev, volatile void *packet, int l }
if (tx_old_hold >= 0) { - KSEG1ADDR(&tx_ring[tx_old_hold])->params.field.HOLD = 1; + ((inca_tx_descriptor_t *)CKSEG1ADDR(&tx_ring[tx_old_hold]))->params.field.HOLD = 1; } tx_old_hold = tx_hold;
@@ -376,7 +376,7 @@ static int inca_switch_send(struct eth_device *dev, volatile void *packet, int l tx_desc->TxDataPtr = (u32)packet; tx_desc->params.field.NBA = length;
- KSEG1ADDR(&tx_ring[tx_hold])->params.field.HOLD = 0; + ((inca_tx_descriptor_t *)CKSEG1ADDR(&tx_ring[tx_hold]))->params.field.HOLD = 0;
tx_hold = tx_new; tx_new = (tx_new + 1) % NUM_TX_DESC; @@ -397,7 +397,7 @@ static int inca_switch_send(struct eth_device *dev, volatile void *packet, int l DMA_WRITE_REG(INCA_IP_DMA_DMA_TXCCR0, regValue);
#if 1 - for(i = 0; KSEG1ADDR(&tx_ring[tx_hold])->C == 0; i++) { + for(i = 0; ((inca_tx_descriptor_t *)CKSEG1ADDR(&tx_ring[tx_hold]))->C == 0; i++) { if (i >= TOUT_LOOP) { printf("%s: tx buffer not ready\n", dev->name); goto Done; @@ -423,7 +423,7 @@ static int inca_switch_recv(struct eth_device *dev) #endif
for (;;) { - rx_desc = KSEG1ADDR(&rx_ring[rx_new]); + rx_desc = (inca_rx_descriptor_t *)CKSEG1ADDR(&rx_ring[rx_new]);
if (rx_desc->status.field.C == 0) { break; @@ -456,7 +456,7 @@ static int inca_switch_recv(struct eth_device *dev) #if 0 printf("Received %d bytes\n", length); #endif - NetReceive((void*)KSEG1ADDR(NetRxPackets[rx_new]), length - 4); + NetReceive((void*)CKSEG1ADDR(NetRxPackets[rx_new]), length - 4); } else { #if 1 printf("Zero length!!!\n"); @@ -464,7 +464,7 @@ static int inca_switch_recv(struct eth_device *dev) }
- KSEG1ADDR(&rx_ring[rx_hold])->params.field.HOLD = 0; + ((inca_rx_descriptor_t *)CKSEG1ADDR(&rx_ring[rx_hold]))->params.field.HOLD = 0;
rx_hold = rx_new;
diff --git a/include/asm-mips/addrspace.h b/include/asm-mips/addrspace.h index 0e6abd7..3a1e6d6 100644 --- a/include/asm-mips/addrspace.h +++ b/include/asm-mips/addrspace.h @@ -3,16 +3,94 @@ * License. See the file "COPYING" in the main directory of this archive * for more details. * - * Copyright (C) 1996 by Ralf Baechle - * Copyright (C) 2000 by Maciej W. Rozycki - * - * Defitions for the address spaces of the MIPS CPUs. + * Copyright (C) 1996, 99 Ralf Baechle + * Copyright (C) 2000, 2002 Maciej W. Rozycki + * Copyright (C) 1990, 1999 by Silicon Graphics, Inc. + */ +#ifndef _ASM_ADDRSPACE_H +#define _ASM_ADDRSPACE_H + +/* + * Configure language + */ +#ifdef __ASSEMBLY__ +#define _ATYPE_ +#define _ATYPE32_ +#define _ATYPE64_ +#define _CONST64_(x) x +#else +#define _ATYPE_ __PTRDIFF_TYPE__ +#define _ATYPE32_ int +#define _ATYPE64_ __s64 +#ifdef CONFIG_64BIT +#define _CONST64_(x) x ## L +#else +#define _CONST64_(x) x ## LL +#endif +#endif + +/* + * 32-bit MIPS address spaces + */ +#ifdef __ASSEMBLY__ +#define _ACAST32_ +#define _ACAST64_ +#else +#define _ACAST32_ (_ATYPE_)(_ATYPE32_) /* widen if necessary */ +#define _ACAST64_ (_ATYPE64_) /* do _not_ narrow */ +#endif + +/* + * Returns the kernel segment base of a given address + */ +#define KSEGX(a) ((_ACAST32_ (a)) & 0xe0000000) + +/* + * Returns the physical address of a CKSEGx / XKPHYS address + */ +#define CPHYSADDR(a) ((_ACAST32_(a)) & 0x1fffffff) +#define XPHYSADDR(a) ((_ACAST64_(a)) & \ + _CONST64_(0x000000ffffffffff)) + +#ifdef CONFIG_64BIT + +/* + * Memory segments (64bit kernel mode addresses) + * The compatibility segments use the full 64-bit sign extended value. Note + * the R8000 doesn't have them so don't reference these in generic MIPS code. + */ +#define XKUSEG _CONST64_(0x0000000000000000) +#define XKSSEG _CONST64_(0x4000000000000000) +#define XKPHYS _CONST64_(0x8000000000000000) +#define XKSEG _CONST64_(0xc000000000000000) +#define CKSEG0 _CONST64_(0xffffffff80000000) +#define CKSEG1 _CONST64_(0xffffffffa0000000) +#define CKSSEG _CONST64_(0xffffffffc0000000) +#define CKSEG3 _CONST64_(0xffffffffe0000000) + +#define CKSEG0ADDR(a) (CPHYSADDR(a) | CKSEG0) +#define CKSEG1ADDR(a) (CPHYSADDR(a) | CKSEG1) +#define CKSEG2ADDR(a) (CPHYSADDR(a) | CKSEG2) +#define CKSEG3ADDR(a) (CPHYSADDR(a) | CKSEG3) + +#else + +#define CKSEG0ADDR(a) (CPHYSADDR(a) | KSEG0) +#define CKSEG1ADDR(a) (CPHYSADDR(a) | KSEG1) +#define CKSEG2ADDR(a) (CPHYSADDR(a) | KSEG2) +#define CKSEG3ADDR(a) (CPHYSADDR(a) | KSEG3) + +/* + * Map an address to a certain kernel segment */ -#ifndef __ASM_MIPS_ADDRSPACE_H -#define __ASM_MIPS_ADDRSPACE_H +#define KSEG0ADDR(a) (CPHYSADDR(a) | KSEG0) +#define KSEG1ADDR(a) (CPHYSADDR(a) | KSEG1) +#define KSEG2ADDR(a) (CPHYSADDR(a) | KSEG2) +#define KSEG3ADDR(a) (CPHYSADDR(a) | KSEG3)
/* * Memory segments (32bit kernel mode addresses) + * These are the traditional names used in the 32-bit universe. */ #define KUSEG 0x00000000 #define KSEG0 0x80000000 @@ -20,63 +98,68 @@ #define KSEG2 0xc0000000 #define KSEG3 0xe0000000
-#define K0BASE KSEG0 +#define CKUSEG 0x00000000 +#define CKSEG0 0x80000000 +#define CKSEG1 0xa0000000 +#define CKSEG2 0xc0000000 +#define CKSEG3 0xe0000000 + +#endif
/* - * Returns the kernel segment base of a given address + * Cache modes for XKPHYS address conversion macros */ -#ifndef __ASSEMBLY__ -#define KSEGX(a) (((unsigned long)(a)) & 0xe0000000) -#else -#define KSEGX(a) ((a) & 0xe0000000) -#endif +#define K_CALG_COH_EXCL1_NOL2 0 +#define K_CALG_COH_SHRL1_NOL2 1 +#define K_CALG_UNCACHED 2 +#define K_CALG_NONCOHERENT 3 +#define K_CALG_COH_EXCL 4 +#define K_CALG_COH_SHAREABLE 5 +#define K_CALG_NOTUSED 6 +#define K_CALG_UNCACHED_ACCEL 7
/* - * Returns the physical address of a KSEG0/KSEG1 address + * 64-bit address conversions */ -#ifndef __ASSEMBLY__ -#define PHYSADDR(a) (((unsigned long)(a)) & 0x1fffffff) -#else -#define PHYSADDR(a) ((a) & 0x1fffffff) -#endif +#define PHYS_TO_XKSEG_UNCACHED(p) PHYS_TO_XKPHYS(K_CALG_UNCACHED, (p)) +#define PHYS_TO_XKSEG_CACHED(p) PHYS_TO_XKPHYS(K_CALG_COH_SHAREABLE, (p)) +#define XKPHYS_TO_PHYS(p) ((p) & TO_PHYS_MASK) +#define PHYS_TO_XKPHYS(cm, a) (_CONST64_(0x8000000000000000) | \ + (_CONST64_(cm) << 59) | (a))
/* * Returns the uncached address of a sdram address */ #ifndef __ASSEMBLY__ -#if defined(CONFIG_AU1X00) || defined(CONFIG_TB0229) +#if defined(CONFIG_SOC_AU1X00) || defined(CONFIG_TB0229) /* We use a 36 bit physical address map here and cannot access physical memory directly from core */ #define UNCACHED_SDRAM(a) (((unsigned long)(a)) | 0x20000000) -#else /* !CONFIG_AU1X00 */ +#else /* !CONFIG_SOC_AU1X00 */ #define UNCACHED_SDRAM(a) KSEG1ADDR(a) -#endif /* CONFIG_AU1X00 */ +#endif /* CONFIG_SOC_AU1X00 */ #endif /* __ASSEMBLY__ */ + /* - * Map an address to a certain kernel segment + * The ultimate limited of the 64-bit MIPS architecture: 2 bits for selecting + * the region, 3 bits for the CCA mode. This leaves 59 bits of which the + * R8000 implements most with its 48-bit physical address space. */ -#ifndef __ASSEMBLY__ -#define KSEG0ADDR(a) ((__typeof__(a))(((unsigned long)(a) & 0x1fffffff) | KSEG0)) -#define KSEG1ADDR(a) ((__typeof__(a))(((unsigned long)(a) & 0x1fffffff) | KSEG1)) -#define KSEG2ADDR(a) ((__typeof__(a))(((unsigned long)(a) & 0x1fffffff) | KSEG2)) -#define KSEG3ADDR(a) ((__typeof__(a))(((unsigned long)(a) & 0x1fffffff) | KSEG3)) -#else -#define KSEG0ADDR(a) (((a) & 0x1fffffff) | KSEG0) -#define KSEG1ADDR(a) (((a) & 0x1fffffff) | KSEG1) -#define KSEG2ADDR(a) (((a) & 0x1fffffff) | KSEG2) -#define KSEG3ADDR(a) (((a) & 0x1fffffff) | KSEG3) -#endif +#define TO_PHYS_MASK _CONST64_(0x07ffffffffffffff) /* 2^^59 - 1 */ + +#ifndef CONFIG_CPU_R8000
/* - * Memory segments (64bit kernel mode addresses) + * The R8000 doesn't have the 32-bit compat spaces so we don't define them + * in order to catch bugs in the source code. */ -#define XKUSEG 0x0000000000000000 -#define XKSSEG 0x4000000000000000 -#define XKPHYS 0x8000000000000000 -#define XKSEG 0xc000000000000000 -#define CKSEG0 0xffffffff80000000 -#define CKSEG1 0xffffffffa0000000 -#define CKSSEG 0xffffffffc0000000 -#define CKSEG3 0xffffffffe0000000 - -#endif /* __ASM_MIPS_ADDRSPACE_H */ + +#define COMPAT_K1BASE32 _CONST64_(0xffffffffa0000000) +#define PHYS_TO_COMPATK1(x) ((x) | COMPAT_K1BASE32) /* 32-bit compat k1 */ + +#endif + +#define KDM_TO_PHYS(x) (_ACAST64_ (x) & TO_PHYS_MASK) +#define PHYS_TO_K0(x) (_ACAST64_ (x) | CAC_BASE) + +#endif /* _ASM_ADDRSPACE_H */ diff --git a/include/asm-mips/au1x00.h b/include/asm-mips/au1x00.h index 6a33197..2a948e8 100644 --- a/include/asm-mips/au1x00.h +++ b/include/asm-mips/au1x00.h @@ -137,7 +137,7 @@ static __inline__ int au_ffs(int x) #define CP0_DEBUG $23
/* SDRAM Controller */ -#ifdef CONFIG_AU1550 +#ifdef CONFIG_SOC_AU1550
#define MEM_SDMODE0 0xB4000800 #define MEM_SDMODE1 0xB4000808 @@ -156,7 +156,7 @@ static __inline__ int au_ffs(int x) #define MEM_SDWRMD1 0xB4000888 #define MEM_SDWRMD2 0xB4000890
-#else /* CONFIG_AU1550 */ +#else /* CONFIG_SOC_AU1550 */
#define MEM_SDMODE0 0xB4000000 #define MEM_SDMODE1 0xB4000004 @@ -174,7 +174,7 @@ static __inline__ int au_ffs(int x) #define MEM_SDWRMD1 0xB4000028 #define MEM_SDWRMD2 0xB400002C
-#endif /* CONFIG_AU1550 */ +#endif /* CONFIG_SOC_AU1550 */
#define MEM_SDSLEEP 0xB4000030 #define MEM_SDSMCKE 0xB4000034 diff --git a/include/asm-mips/io.h b/include/asm-mips/io.h index 7137072..3a0f33f 100644 --- a/include/asm-mips/io.h +++ b/include/asm-mips/io.h @@ -120,7 +120,7 @@ static inline void set_io_port_base(unsigned long base) */ extern inline unsigned long virt_to_phys(volatile void * address) { - return PHYSADDR(address); + return CPHYSADDR(address); }
extern inline void * phys_to_virt(unsigned long address) @@ -133,7 +133,7 @@ extern inline void * phys_to_virt(unsigned long address) */ extern inline unsigned long virt_to_bus(volatile void * address) { - return PHYSADDR(address); + return CPHYSADDR(address); }
extern inline void * bus_to_virt(unsigned long address) diff --git a/include/configs/dbau1x00.h b/include/configs/dbau1x00.h index b2f606f..0e10396 100644 --- a/include/configs/dbau1x00.h +++ b/include/configs/dbau1x00.h @@ -30,21 +30,21 @@
#define CONFIG_MIPS32 1 /* MIPS32 CPU core */ #define CONFIG_DBAU1X00 1 -#define CONFIG_AU1X00 1 /* alchemy series cpu */ +#define CONFIG_SOC_AU1X00 1 /* alchemy series cpu */
#ifdef CONFIG_DBAU1000 /* Also known as Merlot */ -#define CONFIG_AU1000 1 +#define CONFIG_SOC_AU1000 1 #else #ifdef CONFIG_DBAU1100 -#define CONFIG_AU1100 1 +#define CONFIG_SOC_AU1100 1 #else #ifdef CONFIG_DBAU1500 -#define CONFIG_AU1500 1 +#define CONFIG_SOC_AU1500 1 #else #ifdef CONFIG_DBAU1550 /* Cabernet */ -#define CONFIG_AU1550 1 +#define CONFIG_SOC_AU1550 1 #else #error "No valid board set" #endif @@ -148,7 +148,9 @@ #error "Invalid CPU frequency - must be multiple of 12!" #endif
-#define CFG_HZ (CFG_MHZ * 1000000) /* FIXME causes overflow in net.c */ +#define CFG_MIPS_TIMER_FREQ (CFG_MHZ * 1000000) + +#define CFG_HZ 1000
#define CFG_SDRAM_BASE 0x80000000 /* Cached addr */
diff --git a/include/configs/gth2.h b/include/configs/gth2.h index c2a50c1..c2d6ca7 100644 --- a/include/configs/gth2.h +++ b/include/configs/gth2.h @@ -30,9 +30,9 @@
#define CONFIG_MIPS32 1 /* MIPS32 CPU core */ #define CONFIG_GTH2 1 -#define CONFIG_AU1X00 1 /* alchemy series cpu */ +#define CONFIG_SOC_AU1X00 1 /* alchemy series cpu */
#define CONFIG_MISC_INIT_R 1
@@ -118,7 +118,9 @@
#define CFG_MHZ 500
diff --git a/include/configs/incaip.h b/include/configs/incaip.h index 5ca00b3..2e4ee66 100644 --- a/include/configs/incaip.h +++ b/include/configs/incaip.h @@ -118,7 +118,9 @@
#define CFG_BOOTPARAMS_LEN 128*1024
-#define CFG_HZ (incaip_get_cpuclk() / 2) +#define CFG_MIPS_TIMER_FREQ (incaip_get_cpuclk() / 2) + +#define CFG_HZ 1000
diff --git a/include/configs/pb1x00.h b/include/configs/pb1x00.h index 810e0f0..2caa641 100644 --- a/include/configs/pb1x00.h +++ b/include/configs/pb1x00.h @@ -30,16 +30,16 @@
#define CONFIG_MIPS32 1 /* MIPS32 CPU core */ #define CONFIG_PB1X00 1 -#define CONFIG_AU1X00 1 /* alchemy series cpu */ +#define CONFIG_SOC_AU1X00 1 /* alchemy series cpu */
#ifdef CONFIG_PB1000 -#define CONFIG_AU1000 1 +#define CONFIG_SOC_AU1000 1 #else #ifdef CONFIG_PB1100 -#define CONFIG_AU1100 1 +#define CONFIG_SOC_AU1100 1 #else #ifdef CONFIG_PB1500 -#define CONFIG_AU1500 1 +#define CONFIG_SOC_AU1500 1 #else #error "No valid board set" #endif @@ -81,7 +81,9 @@
-#define CFG_HZ 396000000 /* FIXME causes overflow in net.c */ +#define CFG_MIPS_TIMER_FREQ 396000000 + +#define CFG_HZ 1000
diff --git a/include/configs/purple.h b/include/configs/purple.h index 1be4e05..ef92637 100644 --- a/include/configs/purple.h +++ b/include/configs/purple.h @@ -114,7 +114,8 @@ #define CFG_PROMPT "PURPLE # " /* Monitor Command Prompt */ #define CFG_CBSIZE 256 /* Console I/O Buffer Size */ #define CFG_PBSIZE (CFG_CBSIZE+sizeof(CFG_PROMPT)+16) /* Print Buffer Size */ -#define CFG_HZ (CPU_CLOCK_RATE/2) +#define CFG_MIPS_TIMER_FREQ (CPU_CLOCK_RATE/2) +#define CFG_HZ 1000 #define CFG_MAXARGS 16 /* max number of command args*/
#define CFG_LOAD_ADDR 0x80500000 /* default load address */ diff --git a/include/configs/qemu-mips.h b/include/configs/qemu-mips.h index d6bcc8e..3dfd218 100644 --- a/include/configs/qemu-mips.h +++ b/include/configs/qemu-mips.h @@ -120,7 +120,9 @@
#define CFG_MHZ 132
-#define CFG_HZ (CFG_MHZ * 1000000) +#define CFG_MIPS_TIMER_FREQ (CFG_MHZ * 1000000) + +#define CFG_HZ 1000
diff --git a/include/configs/tb0229.h b/include/configs/tb0229.h index dadf5d3..fc2357d 100644 --- a/include/configs/tb0229.h +++ b/include/configs/tb0229.h @@ -122,7 +122,9 @@
-#define CFG_HZ (CPU_TCLOCK_RATE/4) +#define CFG_MIPS_TIMER_FREQ (CPU_TCLOCK_RATE/4) + +#define CFG_HZ 1000
diff --git a/lib_mips/time.c b/lib_mips/time.c index cd8dc72..1e92789 100644 --- a/lib_mips/time.c +++ b/lib_mips/time.c @@ -22,26 +22,12 @@ */
#include <common.h> +#include <asm/mipsregs.h>
+static unsigned long timestamp;
-static inline void mips_compare_set(u32 v) -{ - asm volatile ("mtc0 %0, $11" : : "r" (v)); -} - -static inline void mips_count_set(u32 v) -{ - asm volatile ("mtc0 %0, $9" : : "r" (v)); -} - - -static inline u32 mips_count_get(void) -{ - u32 count; - - asm volatile ("mfc0 %0, $9" : "=r" (count) :); - return count; -} +/* how many counter cycles in a jiffy */ +#define CYCLES_PER_JIFFY (CFG_MIPS_TIMER_FREQ + CFG_HZ / 2) / CFG_HZ
/* * timer without interrupts @@ -49,34 +35,47 @@ static inline u32 mips_count_get(void)
int timer_init(void) { - mips_compare_set(0); - mips_count_set(0); + /* Set up the timer for the first expiration. */ + timestamp = 0; + write_c0_compare(read_c0_count() + CYCLES_PER_JIFFY);
return 0; }
void reset_timer(void) { - mips_count_set(0); + timestamp = 0; + write_c0_compare(read_c0_count() + CYCLES_PER_JIFFY); }
ulong get_timer(ulong base) { - return mips_count_get() - base; + unsigned int count; + unsigned int expirelo = read_c0_compare(); + + /* Check to see if we have missed any timestamps. */ + count = read_c0_count(); + while ((count - expirelo) < 0x7fffffff) { + expirelo += CYCLES_PER_JIFFY; + timestamp++; + } + write_c0_compare(expirelo); + + return (timestamp - base); }
void set_timer(ulong t) { - mips_count_set(t); + timestamp = t; + write_c0_compare(read_c0_count() + CYCLES_PER_JIFFY); }
-void udelay (unsigned long usec) +void udelay(unsigned long usec) { - ulong tmo; - ulong start = get_timer(0); + unsigned int tmo;
- tmo = usec * (CFG_HZ / 1000000); - while ((ulong)((mips_count_get() - start)) < tmo) + tmo = read_c0_count() + (usec * (CFG_MIPS_TIMER_FREQ / 1000000)); + while ((tmo - read_c0_count()) < 0x7fffffff) /*NOP*/; }
@@ -86,7 +85,7 @@ void udelay (unsigned long usec) */ unsigned long long get_ticks(void) { - return mips_count_get(); + return get_timer(0); }
/* diff --git a/mips_config.mk b/mips_config.mk index 67fb67d..05eb05d 100644 --- a/mips_config.mk +++ b/mips_config.mk @@ -40,10 +40,9 @@ PLATFORM_CPPFLAGS += -DCONFIG_MIPS -D__MIPS__ # LDFLAGS_vmlinux += -G 0 -static -n -nostdlib # MODFLAGS += -mlong-calls # - -# -# Meanwhile, U-Boot rely on PIC. We add proper switches explicitly. +# On the other hand, we want PIC in the U-Boot code to relocate it from ROM +# to RAM. $28 is always used as gp. # -PLATFORM_CPPFLAGS += -G 0 -mabicalls -fpic -pipe +PLATFORM_CPPFLAGS += -G 0 -mabicalls -fpic PLATFORM_CPPFLAGS += -msoft-float PLATFORM_LDFLAGS += -G 0 -static -n -nostdlib
Applied, thanks.
Shinya Kuribayashi
