[U-Boot] Question: is SZ_* going to be removed or not?
Hello Wolfgang,
I heard rumors that the SZ_* defines are going to be outphased.
If so, new submissions should not use them anymore, right?
Best Regards, Reinhard
Dear Reinhard Meyer,
I's on my personal hate list, indeed.
Right.
Hi Wolfgang,
Right.
so what is the recommended way to write size ?
Thanks, Eric
Dear =?ISO-8859-1?Q?Eric_B=E9nard?=,
In a readable way.
If you need 2k, write it as 2000 or 2*1000 or similar.
If you need 2 Ki, write it as 2048 or 2*1024 or (2 << 10) or similar.
Dear Wolfgang Denk,
Right.
OK, I can understand that for having a define for each of the 64 possible values (1<<0) .. (1<<63) can be annoying.
Will the preffered methods be xx << 10 for KiB xx << 20 for MiB xx << 30 for GiB and so on?
Or might we have a few macros like
#define KiB(x) ((x) << 10) #define MiB(x) ((x) << 20) and so on?
That would reduce all to about 6 defines.
Please note that the binary prefixes kibi and mebi not might be used for other things than bytes as well. And if we were trying to be precise, wie might want to use "octets" instead of bytes anyway ;-)
I think it's largely a matter of taste and experience whether you prefer (2 << 30) or (2 * 1024 * 1024 * 1024). It depends a lot on how much you work with such numbers - I prefer (2 << 30) because it's shorter, others find the "* 1024" notation easier to read.
But no matter what you prefer - at least both variants are readable.
Why should we use any such macros at all? Just write the plain numbers in the code so everybody can understand it without having to look up the definition.
Eric Bénard
Reinhard Meyer
