[PATCH v1 0/2] mtd: spinand: add support for ESMT F50x1G41LB
This series ports ESMT NAND support from Linux. Since both ESMT and Gigadevice use the same manufacturer ID, core part of SPI NAND framework should be updated as well to allow for such chips detection. Currently all detect() ops return an error code when chip's manufacturer ID matches, but device ID does not. This forces spinand_manufacturer_detect function to stop and report an error. Porting a rework from Linux allows us to fix this issue and keep u-boot and kernel in sync.
Igor Prusov (2): mtd: spinand: rework detect procedure for different READ_ID operation mtd: spinand: add support for ESMT F50x1G41LB
drivers/mtd/nand/spi/Makefile | 2 +- drivers/mtd/nand/spi/core.c | 86 ++++++++++++++----- drivers/mtd/nand/spi/esmt.c | 137 ++++++++++++++++++++++++++++++ drivers/mtd/nand/spi/gigadevice.c | 30 ++----- drivers/mtd/nand/spi/macronix.c | 45 ++++------ drivers/mtd/nand/spi/micron.c | 50 +++++------ drivers/mtd/nand/spi/toshiba.c | 66 +++++++------- drivers/mtd/nand/spi/winbond.c | 34 ++------ include/linux/mtd/spinand.h | 67 ++++++++++----- 9 files changed, 325 insertions(+), 192 deletions(-) create mode 100644 drivers/mtd/nand/spi/esmt.c
Adaptation of Linux commit f1541773af49.
Currently there are 3 different variants of read_id implementation: 1. opcode only. Found in GD5FxGQ4xF. 2. opcode + 1 addr byte. Found in GD5GxGQ4xA/E 3. opcode + 1 dummy byte. Found in other currently supported chips.
Original implementation was for variant 1 and let detect function of chips with variant 2 and 3 to ignore the first byte. This isn't robust:
1. For chips of variant 2, if SPI master doesn't keep MOSI low during read, chip will get a random id offset, and the entire id buffer will shift by that offset, causing detect failure.
2. For chips of variant 1, if it happens to get a devid that equals to manufacture id of variant 2 or 3 chips, it'll get incorrectly detected.
This patch reworks detect procedure to address problems above. New logic do detection for all variants separatedly, in 1-2-3 order. Since all current detect methods do exactly the same id matching procedure, unify them into core.c and remove detect method from manufacture_ops.
Signed-off-by: Chuanhong Guo gch981213@gmail.com Signed-off-by: Igor Prusov ivprusov@salutedevices.com --- drivers/mtd/nand/spi/core.c | 85 +++++++++++++++++++++++-------- drivers/mtd/nand/spi/gigadevice.c | 30 +++-------- drivers/mtd/nand/spi/macronix.c | 45 ++++++---------- drivers/mtd/nand/spi/micron.c | 50 ++++++++---------- drivers/mtd/nand/spi/toshiba.c | 66 +++++++++++------------- drivers/mtd/nand/spi/winbond.c | 34 +++---------- include/linux/mtd/spinand.h | 66 ++++++++++++++++-------- 7 files changed, 185 insertions(+), 191 deletions(-)
diff --git a/drivers/mtd/nand/spi/core.c b/drivers/mtd/nand/spi/core.c index 4ee11e812d..3ea746fd13 100644 --- a/drivers/mtd/nand/spi/core.c +++ b/drivers/mtd/nand/spi/core.c @@ -17,6 +17,7 @@ #include <linux/mtd/spinand.h> #include <linux/of.h> #include <linux/slab.h> +#include <linux/string.h> #include <linux/spi/spi.h> #include <linux/spi/spi-mem.h> #else @@ -452,10 +453,11 @@ out: return status & STATUS_BUSY ? -ETIMEDOUT : 0; }
-static int spinand_read_id_op(struct spinand_device *spinand, u8 *buf) +static int spinand_read_id_op(struct spinand_device *spinand, u8 naddr, + u8 ndummy, u8 *buf) { - struct spi_mem_op op = SPINAND_READID_OP(0, spinand->scratchbuf, - SPINAND_MAX_ID_LEN); + struct spi_mem_op op = SPINAND_READID_OP( + naddr, ndummy, spinand->scratchbuf, SPINAND_MAX_ID_LEN); int ret;
ret = spi_mem_exec_op(spinand->slave, &op); @@ -837,24 +839,63 @@ static const struct spinand_manufacturer *spinand_manufacturers[] = { &winbond_spinand_manufacturer, };
-static int spinand_manufacturer_detect(struct spinand_device *spinand) +static int spinand_manufacturer_match(struct spinand_device *spinand, + enum spinand_readid_method rdid_method) { + u8 *id = spinand->id.data; unsigned int i; int ret;
for (i = 0; i < ARRAY_SIZE(spinand_manufacturers); i++) { - ret = spinand_manufacturers[i]->ops->detect(spinand); - if (ret > 0) { - spinand->manufacturer = spinand_manufacturers[i]; - return 0; - } else if (ret < 0) { - return ret; - } + const struct spinand_manufacturer *manufacturer = + spinand_manufacturers[i]; + + if (id[0] != manufacturer->id) + continue; + + ret = spinand_match_and_init(spinand, + manufacturer->chips, + manufacturer->nchips, + rdid_method); + if (ret < 0) + continue; + + spinand->manufacturer = manufacturer; + return 0; }
return -ENOTSUPP; }
+static int spinand_id_detect(struct spinand_device *spinand) +{ + u8 *id = spinand->id.data; + int ret; + + ret = spinand_read_id_op(spinand, 0, 0, id); + if (ret) + return ret; + ret = spinand_manufacturer_match(spinand, SPINAND_READID_METHOD_OPCODE); + if (!ret) + return 0; + + ret = spinand_read_id_op(spinand, 1, 0, id); + if (ret) + return ret; + ret = spinand_manufacturer_match(spinand, + SPINAND_READID_METHOD_OPCODE_ADDR); + if (!ret) + return 0; + + ret = spinand_read_id_op(spinand, 0, 1, id); + if (ret) + return ret; + ret = spinand_manufacturer_match(spinand, + SPINAND_READID_METHOD_OPCODE_DUMMY); + + return ret; +} + static int spinand_manufacturer_init(struct spinand_device *spinand) { if (spinand->manufacturer->ops->init) @@ -910,9 +951,9 @@ spinand_select_op_variant(struct spinand_device *spinand, * @spinand: SPI NAND object * @table: SPI NAND device description table * @table_size: size of the device description table + * @rdid_method: read id method to match * - * Should be used by SPI NAND manufacturer drivers when they want to find a - * match between a device ID retrieved through the READ_ID command and an ++ * Match between a device ID retrieved through the READ_ID command and an * entry in the SPI NAND description table. If a match is found, the spinand * object will be initialized with information provided by the matching * spinand_info entry. @@ -921,8 +962,10 @@ spinand_select_op_variant(struct spinand_device *spinand, */ int spinand_match_and_init(struct spinand_device *spinand, const struct spinand_info *table, - unsigned int table_size, u8 devid) + unsigned int table_size, + enum spinand_readid_method rdid_method) { + u8 *id = spinand->id.data; struct nand_device *nand = spinand_to_nand(spinand); unsigned int i;
@@ -930,13 +973,17 @@ int spinand_match_and_init(struct spinand_device *spinand, const struct spinand_info *info = &table[i]; const struct spi_mem_op *op;
- if (devid != info->devid) + if (rdid_method != info->devid.method) + continue; + + if (memcmp(id + 1, info->devid.id, info->devid.len)) continue;
nand->memorg = table[i].memorg; nand->eccreq = table[i].eccreq; spinand->eccinfo = table[i].eccinfo; spinand->flags = table[i].flags; + spinand->id.len = 1 + table[i].devid.len; spinand->select_target = table[i].select_target;
op = spinand_select_op_variant(spinand, @@ -972,13 +1019,7 @@ static int spinand_detect(struct spinand_device *spinand) if (ret) return ret;
- ret = spinand_read_id_op(spinand, spinand->id.data); - if (ret) - return ret; - - spinand->id.len = SPINAND_MAX_ID_LEN; - - ret = spinand_manufacturer_detect(spinand); + ret = spinand_id_detect(spinand); if (ret) { dev_err(spinand->slave->dev, "unknown raw ID %02x %02x %02x %02x\n", spinand->id.data[0], spinand->id.data[1], diff --git a/drivers/mtd/nand/spi/gigadevice.c b/drivers/mtd/nand/spi/gigadevice.c index a2c93486f4..affd764e54 100644 --- a/drivers/mtd/nand/spi/gigadevice.c +++ b/drivers/mtd/nand/spi/gigadevice.c @@ -158,7 +158,8 @@ static const struct mtd_ooblayout_ops gd5fxgqxxexxg_ooblayout = { };
static const struct spinand_info gigadevice_spinand_table[] = { - SPINAND_INFO("GD5F1GQ4UExxG", 0xd1, + SPINAND_INFO("GD5F1GQ4UExxG", + SPINAND_ID(SPINAND_READID_METHOD_OPCODE_ADDR, 0xd1), NAND_MEMORG(1, 2048, 128, 64, 1024, 1, 1, 1), NAND_ECCREQ(8, 512), SPINAND_INFO_OP_VARIANTS(&gd5fxgq4_read_cache_variants, @@ -167,7 +168,8 @@ static const struct spinand_info gigadevice_spinand_table[] = { 0, SPINAND_ECCINFO(&gd5fxgqxxexxg_ooblayout, gd5fxgq4xexxg_ecc_get_status)), - SPINAND_INFO("GD5F1GQ5UExxG", 0x51, + SPINAND_INFO("GD5F1GQ5UExxG", + SPINAND_ID(SPINAND_READID_METHOD_OPCODE_ADDR, 0x51), NAND_MEMORG(1, 2048, 128, 64, 1024, 1, 1, 1), NAND_ECCREQ(4, 512), SPINAND_INFO_OP_VARIANTS(&gd5f1gq5_read_cache_variants, @@ -178,33 +180,13 @@ static const struct spinand_info gigadevice_spinand_table[] = { gd5fxgq5xexxg_ecc_get_status)), };
-static int gigadevice_spinand_detect(struct spinand_device *spinand) -{ - u8 *id = spinand->id.data; - int ret; - - /* - * For GD NANDs, There is an address byte needed to shift in before IDs - * are read out, so the first byte in raw_id is dummy. - */ - if (id[1] != SPINAND_MFR_GIGADEVICE) - return 0; - - ret = spinand_match_and_init(spinand, gigadevice_spinand_table, - ARRAY_SIZE(gigadevice_spinand_table), - id[2]); - if (ret) - return ret; - - return 1; -} - static const struct spinand_manufacturer_ops gigadevice_spinand_manuf_ops = { - .detect = gigadevice_spinand_detect, };
const struct spinand_manufacturer gigadevice_spinand_manufacturer = { .id = SPINAND_MFR_GIGADEVICE, .name = "GigaDevice", + .chips = gigadevice_spinand_table, + .nchips = ARRAY_SIZE(gigadevice_spinand_table), .ops = &gigadevice_spinand_manuf_ops, }; diff --git a/drivers/mtd/nand/spi/macronix.c b/drivers/mtd/nand/spi/macronix.c index 6d643a8000..08f7d69d8c 100644 --- a/drivers/mtd/nand/spi/macronix.c +++ b/drivers/mtd/nand/spi/macronix.c @@ -105,7 +105,8 @@ static int mx35lf1ge4ab_ecc_get_status(struct spinand_device *spinand, }
static const struct spinand_info macronix_spinand_table[] = { - SPINAND_INFO("MX35LF1GE4AB", 0x12, + SPINAND_INFO("MX35LF1GE4AB", + SPINAND_ID(SPINAND_READID_METHOD_OPCODE_DUMMY, 0x12), NAND_MEMORG(1, 2048, 64, 64, 1024, 1, 1, 1), NAND_ECCREQ(4, 512), SPINAND_INFO_OP_VARIANTS(&read_cache_variants, @@ -114,7 +115,8 @@ static const struct spinand_info macronix_spinand_table[] = { SPINAND_HAS_QE_BIT, SPINAND_ECCINFO(&mx35lfxge4ab_ooblayout, mx35lf1ge4ab_ecc_get_status)), - SPINAND_INFO("MX35LF2GE4AB", 0x22, + SPINAND_INFO("MX35LF2GE4AB", + SPINAND_ID(SPINAND_READID_METHOD_OPCODE_DUMMY, 0x22), NAND_MEMORG(1, 2048, 64, 64, 2048, 2, 1, 1), NAND_ECCREQ(4, 512), SPINAND_INFO_OP_VARIANTS(&read_cache_variants, @@ -122,7 +124,8 @@ static const struct spinand_info macronix_spinand_table[] = { &update_cache_variants), SPINAND_HAS_QE_BIT, SPINAND_ECCINFO(&mx35lfxge4ab_ooblayout, NULL)), - SPINAND_INFO("MX35UF4GE4AD", 0xb7, + SPINAND_INFO("MX35UF4GE4AD", + SPINAND_ID(SPINAND_READID_METHOD_OPCODE_DUMMY, 0xb7), NAND_MEMORG(1, 4096, 256, 64, 2048, 1, 1, 1), NAND_ECCREQ(8, 512), SPINAND_INFO_OP_VARIANTS(&read_cache_variants, @@ -131,7 +134,8 @@ static const struct spinand_info macronix_spinand_table[] = { SPINAND_HAS_QE_BIT, SPINAND_ECCINFO(&mx35lfxge4ab_ooblayout, mx35lf1ge4ab_ecc_get_status)), - SPINAND_INFO("MX35UF2GE4AD", 0xa6, + SPINAND_INFO("MX35UF2GE4AD", + SPINAND_ID(SPINAND_READID_METHOD_OPCODE_DUMMY, 0xa6), NAND_MEMORG(1, 2048, 128, 64, 2048, 1, 1, 1), NAND_ECCREQ(8, 512), SPINAND_INFO_OP_VARIANTS(&read_cache_variants, @@ -140,7 +144,8 @@ static const struct spinand_info macronix_spinand_table[] = { SPINAND_HAS_QE_BIT, SPINAND_ECCINFO(&mx35lfxge4ab_ooblayout, mx35lf1ge4ab_ecc_get_status)), - SPINAND_INFO("MX35UF2GE4AC", 0xa2, + SPINAND_INFO("MX35UF2GE4AC", + SPINAND_ID(SPINAND_READID_METHOD_OPCODE_DUMMY, 0xa2), NAND_MEMORG(1, 2048, 64, 64, 2048, 1, 1, 1), NAND_ECCREQ(4, 512), SPINAND_INFO_OP_VARIANTS(&read_cache_variants, @@ -149,7 +154,8 @@ static const struct spinand_info macronix_spinand_table[] = { SPINAND_HAS_QE_BIT, SPINAND_ECCINFO(&mx35lfxge4ab_ooblayout, mx35lf1ge4ab_ecc_get_status)), - SPINAND_INFO("MX35UF1GE4AD", 0x96, + SPINAND_INFO("MX35UF1GE4AD", + SPINAND_ID(SPINAND_READID_METHOD_OPCODE_DUMMY, 0x96), NAND_MEMORG(1, 2048, 128, 64, 1024, 1, 1, 1), NAND_ECCREQ(8, 512), SPINAND_INFO_OP_VARIANTS(&read_cache_variants, @@ -158,7 +164,8 @@ static const struct spinand_info macronix_spinand_table[] = { SPINAND_HAS_QE_BIT, SPINAND_ECCINFO(&mx35lfxge4ab_ooblayout, mx35lf1ge4ab_ecc_get_status)), - SPINAND_INFO("MX35UF1GE4AC", 0x92, + SPINAND_INFO("MX35UF1GE4AC", + SPINAND_ID(SPINAND_READID_METHOD_OPCODE_DUMMY, 0x92), NAND_MEMORG(1, 2048, 64, 64, 1024, 1, 1, 1), NAND_ECCREQ(4, 512), SPINAND_INFO_OP_VARIANTS(&read_cache_variants, @@ -170,33 +177,13 @@ static const struct spinand_info macronix_spinand_table[] = {
-static int macronix_spinand_detect(struct spinand_device *spinand) -{ - u8 *id = spinand->id.data; - int ret; - - /* - * Macronix SPI NAND read ID needs a dummy byte, so the first byte in - * raw_id is garbage. - */ - if (id[1] != SPINAND_MFR_MACRONIX) - return 0; - - ret = spinand_match_and_init(spinand, macronix_spinand_table, - ARRAY_SIZE(macronix_spinand_table), - id[2]); - if (ret) - return ret; - - return 1; -} - static const struct spinand_manufacturer_ops macronix_spinand_manuf_ops = { - .detect = macronix_spinand_detect, };
const struct spinand_manufacturer macronix_spinand_manufacturer = { .id = SPINAND_MFR_MACRONIX, .name = "Macronix", + .chips = macronix_spinand_table, + .nchips = ARRAY_SIZE(macronix_spinand_table), .ops = ¯onix_spinand_manuf_ops, }; diff --git a/drivers/mtd/nand/spi/micron.c b/drivers/mtd/nand/spi/micron.c index 6bacf14aaf..cecd3db958 100644 --- a/drivers/mtd/nand/spi/micron.c +++ b/drivers/mtd/nand/spi/micron.c @@ -120,7 +120,8 @@ static int micron_8_ecc_get_status(struct spinand_device *spinand,
static const struct spinand_info micron_spinand_table[] = { /* M79A 2Gb 3.3V */ - SPINAND_INFO("MT29F2G01ABAGD", 0x24, + SPINAND_INFO("MT29F2G01ABAGD", + SPINAND_ID(SPINAND_READID_METHOD_OPCODE_DUMMY, 0x24), NAND_MEMORG(1, 2048, 128, 64, 2048, 2, 1, 1), NAND_ECCREQ(8, 512), SPINAND_INFO_OP_VARIANTS(&read_cache_variants, @@ -130,7 +131,8 @@ static const struct spinand_info micron_spinand_table[] = { SPINAND_ECCINFO(µn_8_ooblayout, micron_8_ecc_get_status)), /* M79A 2Gb 1.8V */ - SPINAND_INFO("MT29F2G01ABBGD", 0x25, + SPINAND_INFO("MT29F2G01ABBGD", + SPINAND_ID(SPINAND_READID_METHOD_OPCODE_DUMMY, 0x25), NAND_MEMORG(1, 2048, 128, 64, 2048, 2, 1, 1), NAND_ECCREQ(8, 512), SPINAND_INFO_OP_VARIANTS(&read_cache_variants, @@ -140,7 +142,8 @@ static const struct spinand_info micron_spinand_table[] = { SPINAND_ECCINFO(µn_8_ooblayout, micron_8_ecc_get_status)), /* M78A 1Gb 3.3V */ - SPINAND_INFO("MT29F1G01ABAFD", 0x14, + SPINAND_INFO("MT29F1G01ABAFD", + SPINAND_ID(SPINAND_READID_METHOD_OPCODE_DUMMY, 0x14), NAND_MEMORG(1, 2048, 128, 64, 1024, 1, 1, 1), NAND_ECCREQ(8, 512), SPINAND_INFO_OP_VARIANTS(&read_cache_variants, @@ -150,7 +153,8 @@ static const struct spinand_info micron_spinand_table[] = { SPINAND_ECCINFO(µn_8_ooblayout, micron_8_ecc_get_status)), /* M78A 1Gb 1.8V */ - SPINAND_INFO("MT29F1G01ABAFD", 0x15, + SPINAND_INFO("MT29F1G01ABAFD", + SPINAND_ID(SPINAND_READID_METHOD_OPCODE_DUMMY, 0x15), NAND_MEMORG(1, 2048, 128, 64, 1024, 1, 1, 1), NAND_ECCREQ(8, 512), SPINAND_INFO_OP_VARIANTS(&read_cache_variants, @@ -160,7 +164,8 @@ static const struct spinand_info micron_spinand_table[] = { SPINAND_ECCINFO(µn_8_ooblayout, micron_8_ecc_get_status)), /* M79A 4Gb 3.3V */ - SPINAND_INFO("MT29F4G01ADAGD", 0x36, + SPINAND_INFO("MT29F4G01ADAGD", + SPINAND_ID(SPINAND_READID_METHOD_OPCODE_DUMMY, 0x36), NAND_MEMORG(1, 2048, 128, 64, 2048, 2, 1, 2), NAND_ECCREQ(8, 512), SPINAND_INFO_OP_VARIANTS(&read_cache_variants, @@ -171,7 +176,8 @@ static const struct spinand_info micron_spinand_table[] = { micron_8_ecc_get_status), SPINAND_SELECT_TARGET(micron_select_target)), /* M70A 4Gb 3.3V */ - SPINAND_INFO("MT29F4G01ABAFD", 0x34, + SPINAND_INFO("MT29F4G01ABAFD", + SPINAND_ID(SPINAND_READID_METHOD_OPCODE_DUMMY, 0x34), NAND_MEMORG(1, 4096, 256, 64, 2048, 1, 1, 1), NAND_ECCREQ(8, 512), SPINAND_INFO_OP_VARIANTS(&read_cache_variants, @@ -181,7 +187,8 @@ static const struct spinand_info micron_spinand_table[] = { SPINAND_ECCINFO(µn_8_ooblayout, micron_8_ecc_get_status)), /* M70A 4Gb 1.8V */ - SPINAND_INFO("MT29F4G01ABBFD", 0x35, + SPINAND_INFO("MT29F4G01ABBFD", + SPINAND_ID(SPINAND_READID_METHOD_OPCODE_DUMMY, 0x35), NAND_MEMORG(1, 4096, 256, 64, 2048, 1, 1, 1), NAND_ECCREQ(8, 512), SPINAND_INFO_OP_VARIANTS(&read_cache_variants, @@ -191,7 +198,8 @@ static const struct spinand_info micron_spinand_table[] = { SPINAND_ECCINFO(µn_8_ooblayout, micron_8_ecc_get_status)), /* M70A 8Gb 3.3V */ - SPINAND_INFO("MT29F8G01ADAFD", 0x46, + SPINAND_INFO("MT29F8G01ADAFD", + SPINAND_ID(SPINAND_READID_METHOD_OPCODE_DUMMY, 0x46), NAND_MEMORG(1, 4096, 256, 64, 2048, 1, 1, 2), NAND_ECCREQ(8, 512), SPINAND_INFO_OP_VARIANTS(&read_cache_variants, @@ -202,7 +210,8 @@ static const struct spinand_info micron_spinand_table[] = { micron_8_ecc_get_status), SPINAND_SELECT_TARGET(micron_select_target)), /* M70A 8Gb 1.8V */ - SPINAND_INFO("MT29F8G01ADBFD", 0x47, + SPINAND_INFO("MT29F8G01ADBFD", + SPINAND_ID(SPINAND_READID_METHOD_OPCODE_DUMMY, 0x47), NAND_MEMORG(1, 4096, 256, 64, 2048, 1, 1, 2), NAND_ECCREQ(8, 512), SPINAND_INFO_OP_VARIANTS(&read_cache_variants, @@ -214,26 +223,6 @@ static const struct spinand_info micron_spinand_table[] = { SPINAND_SELECT_TARGET(micron_select_target)), };
-static int micron_spinand_detect(struct spinand_device *spinand) -{ - u8 *id = spinand->id.data; - int ret; - - /* - * Micron SPI NAND read ID need a dummy byte, - * so the first byte in raw_id is dummy. - */ - if (id[1] != SPINAND_MFR_MICRON) - return 0; - - ret = spinand_match_and_init(spinand, micron_spinand_table, - ARRAY_SIZE(micron_spinand_table), id[2]); - if (ret) - return ret; - - return 1; -} - static int micron_spinand_init(struct spinand_device *spinand) { /* @@ -248,12 +237,13 @@ static int micron_spinand_init(struct spinand_device *spinand) }
static const struct spinand_manufacturer_ops micron_spinand_manuf_ops = { - .detect = micron_spinand_detect, .init = micron_spinand_init, };
const struct spinand_manufacturer micron_spinand_manufacturer = { .id = SPINAND_MFR_MICRON, .name = "Micron", + .chips = micron_spinand_table, + .nchips = ARRAY_SIZE(micron_spinand_table), .ops = µn_spinand_manuf_ops, }; diff --git a/drivers/mtd/nand/spi/toshiba.c b/drivers/mtd/nand/spi/toshiba.c index c2cd3b426b..e057b08c70 100644 --- a/drivers/mtd/nand/spi/toshiba.c +++ b/drivers/mtd/nand/spi/toshiba.c @@ -111,7 +111,8 @@ static int tx58cxgxsxraix_ecc_get_status(struct spinand_device *spinand,
static const struct spinand_info toshiba_spinand_table[] = { /* 3.3V 1Gb (1st generation) */ - SPINAND_INFO("TC58CVG0S3HRAIG", 0xC2, + SPINAND_INFO("TC58CVG0S3HRAIG", + SPINAND_ID(SPINAND_READID_METHOD_OPCODE_DUMMY, 0xC2), NAND_MEMORG(1, 2048, 128, 64, 1024, 1, 1, 1), NAND_ECCREQ(8, 512), SPINAND_INFO_OP_VARIANTS(&read_cache_variants, @@ -121,7 +122,8 @@ static const struct spinand_info toshiba_spinand_table[] = { SPINAND_ECCINFO(&tx58cxgxsxraix_ooblayout, tx58cxgxsxraix_ecc_get_status)), /* 3.3V 2Gb (1st generation) */ - SPINAND_INFO("TC58CVG1S3HRAIG", 0xCB, + SPINAND_INFO("TC58CVG1S3HRAIG", + SPINAND_ID(SPINAND_READID_METHOD_OPCODE_DUMMY, 0xCB), NAND_MEMORG(1, 2048, 128, 64, 2048, 1, 1, 1), NAND_ECCREQ(8, 512), SPINAND_INFO_OP_VARIANTS(&read_cache_variants, @@ -131,7 +133,8 @@ static const struct spinand_info toshiba_spinand_table[] = { SPINAND_ECCINFO(&tx58cxgxsxraix_ooblayout, tx58cxgxsxraix_ecc_get_status)), /* 3.3V 4Gb (1st generation) */ - SPINAND_INFO("TC58CVG2S0HRAIG", 0xCD, + SPINAND_INFO("TC58CVG2S0HRAIG", + SPINAND_ID(SPINAND_READID_METHOD_OPCODE_DUMMY, 0xCD), NAND_MEMORG(1, 4096, 256, 64, 2048, 1, 1, 1), NAND_ECCREQ(8, 512), SPINAND_INFO_OP_VARIANTS(&read_cache_variants, @@ -141,7 +144,8 @@ static const struct spinand_info toshiba_spinand_table[] = { SPINAND_ECCINFO(&tx58cxgxsxraix_ooblayout, tx58cxgxsxraix_ecc_get_status)), /* 1.8V 1Gb (1st generation) */ - SPINAND_INFO("TC58CYG0S3HRAIG", 0xB2, + SPINAND_INFO("TC58CYG0S3HRAIG", + SPINAND_ID(SPINAND_READID_METHOD_OPCODE_DUMMY, 0xB2), NAND_MEMORG(1, 2048, 128, 64, 1024, 1, 1, 1), NAND_ECCREQ(8, 512), SPINAND_INFO_OP_VARIANTS(&read_cache_variants, @@ -151,7 +155,8 @@ static const struct spinand_info toshiba_spinand_table[] = { SPINAND_ECCINFO(&tx58cxgxsxraix_ooblayout, tx58cxgxsxraix_ecc_get_status)), /* 1.8V 2Gb (1st generation) */ - SPINAND_INFO("TC58CYG1S3HRAIG", 0xBB, + SPINAND_INFO("TC58CYG1S3HRAIG", + SPINAND_ID(SPINAND_READID_METHOD_OPCODE_DUMMY, 0xBB), NAND_MEMORG(1, 2048, 128, 64, 2048, 1, 1, 1), NAND_ECCREQ(8, 512), SPINAND_INFO_OP_VARIANTS(&read_cache_variants, @@ -161,7 +166,8 @@ static const struct spinand_info toshiba_spinand_table[] = { SPINAND_ECCINFO(&tx58cxgxsxraix_ooblayout, tx58cxgxsxraix_ecc_get_status)), /* 1.8V 4Gb (1st generation) */ - SPINAND_INFO("TC58CYG2S0HRAIG", 0xBD, + SPINAND_INFO("TC58CYG2S0HRAIG", + SPINAND_ID(SPINAND_READID_METHOD_OPCODE_DUMMY, 0xBD), NAND_MEMORG(1, 4096, 256, 64, 2048, 1, 1, 1), NAND_ECCREQ(8, 512), SPINAND_INFO_OP_VARIANTS(&read_cache_variants, @@ -176,7 +182,8 @@ static const struct spinand_info toshiba_spinand_table[] = { * QE_BIT. */ /* 3.3V 1Gb (2nd generation) */ - SPINAND_INFO("TC58CVG0S3HRAIJ", 0xE2, + SPINAND_INFO("TC58CVG0S3HRAIJ", + SPINAND_ID(SPINAND_READID_METHOD_OPCODE_DUMMY, 0xE2), NAND_MEMORG(1, 2048, 128, 64, 1024, 1, 1, 1), NAND_ECCREQ(8, 512), SPINAND_INFO_OP_VARIANTS(&read_cache_variants, @@ -186,7 +193,8 @@ static const struct spinand_info toshiba_spinand_table[] = { SPINAND_ECCINFO(&tx58cxgxsxraix_ooblayout, tx58cxgxsxraix_ecc_get_status)), /* 3.3V 2Gb (2nd generation) */ - SPINAND_INFO("TC58CVG1S3HRAIJ", 0xEB, + SPINAND_INFO("TC58CVG1S3HRAIJ", + SPINAND_ID(SPINAND_READID_METHOD_OPCODE_DUMMY, 0xEB), NAND_MEMORG(1, 2048, 128, 64, 2048, 1, 1, 1), NAND_ECCREQ(8, 512), SPINAND_INFO_OP_VARIANTS(&read_cache_variants, @@ -196,7 +204,8 @@ static const struct spinand_info toshiba_spinand_table[] = { SPINAND_ECCINFO(&tx58cxgxsxraix_ooblayout, tx58cxgxsxraix_ecc_get_status)), /* 3.3V 4Gb (2nd generation) */ - SPINAND_INFO("TC58CVG2S0HRAIJ", 0xED, + SPINAND_INFO("TC58CVG2S0HRAIJ", + SPINAND_ID(SPINAND_READID_METHOD_OPCODE_DUMMY, 0xED), NAND_MEMORG(1, 4096, 256, 64, 2048, 1, 1, 1), NAND_ECCREQ(8, 512), SPINAND_INFO_OP_VARIANTS(&read_cache_variants, @@ -206,7 +215,8 @@ static const struct spinand_info toshiba_spinand_table[] = { SPINAND_ECCINFO(&tx58cxgxsxraix_ooblayout, tx58cxgxsxraix_ecc_get_status)), /* 3.3V 8Gb (2nd generation) */ - SPINAND_INFO("TH58CVG3S0HRAIJ", 0xE4, + SPINAND_INFO("TH58CVG3S0HRAIJ", + SPINAND_ID(SPINAND_READID_METHOD_OPCODE_DUMMY, 0xE4), NAND_MEMORG(1, 4096, 256, 64, 4096, 1, 1, 1), NAND_ECCREQ(8, 512), SPINAND_INFO_OP_VARIANTS(&read_cache_variants, @@ -216,7 +226,8 @@ static const struct spinand_info toshiba_spinand_table[] = { SPINAND_ECCINFO(&tx58cxgxsxraix_ooblayout, tx58cxgxsxraix_ecc_get_status)), /* 1.8V 1Gb (2nd generation) */ - SPINAND_INFO("TC58CYG0S3HRAIJ", 0xD2, + SPINAND_INFO("TC58CYG0S3HRAIJ", + SPINAND_ID(SPINAND_READID_METHOD_OPCODE_DUMMY, 0xD2), NAND_MEMORG(1, 2048, 128, 64, 1024, 1, 1, 1), NAND_ECCREQ(8, 512), SPINAND_INFO_OP_VARIANTS(&read_cache_variants, @@ -226,7 +237,8 @@ static const struct spinand_info toshiba_spinand_table[] = { SPINAND_ECCINFO(&tx58cxgxsxraix_ooblayout, tx58cxgxsxraix_ecc_get_status)), /* 1.8V 2Gb (2nd generation) */ - SPINAND_INFO("TC58CYG1S3HRAIJ", 0xDB, + SPINAND_INFO("TC58CYG1S3HRAIJ", + SPINAND_ID(SPINAND_READID_METHOD_OPCODE_DUMMY, 0xDB), NAND_MEMORG(1, 2048, 128, 64, 2048, 1, 1, 1), NAND_ECCREQ(8, 512), SPINAND_INFO_OP_VARIANTS(&read_cache_variants, @@ -236,7 +248,8 @@ static const struct spinand_info toshiba_spinand_table[] = { SPINAND_ECCINFO(&tx58cxgxsxraix_ooblayout, tx58cxgxsxraix_ecc_get_status)), /* 1.8V 4Gb (2nd generation) */ - SPINAND_INFO("TC58CYG2S0HRAIJ", 0xDD, + SPINAND_INFO("TC58CYG2S0HRAIJ", + SPINAND_ID(SPINAND_READID_METHOD_OPCODE_DUMMY, 0xDD), NAND_MEMORG(1, 4096, 256, 64, 2048, 1, 1, 1), NAND_ECCREQ(8, 512), SPINAND_INFO_OP_VARIANTS(&read_cache_variants, @@ -246,7 +259,8 @@ static const struct spinand_info toshiba_spinand_table[] = { SPINAND_ECCINFO(&tx58cxgxsxraix_ooblayout, tx58cxgxsxraix_ecc_get_status)), /* 1.8V 8Gb (2nd generation) */ - SPINAND_INFO("TH58CYG3S0HRAIJ", 0xD4, + SPINAND_INFO("TH58CYG3S0HRAIJ", + SPINAND_ID(SPINAND_READID_METHOD_OPCODE_DUMMY, 0xD4), NAND_MEMORG(1, 4096, 256, 64, 4096, 1, 1, 1), NAND_ECCREQ(8, 512), SPINAND_INFO_OP_VARIANTS(&read_cache_variants, @@ -257,33 +271,13 @@ static const struct spinand_info toshiba_spinand_table[] = { tx58cxgxsxraix_ecc_get_status)), };
-static int toshiba_spinand_detect(struct spinand_device *spinand) -{ - u8 *id = spinand->id.data; - int ret; - - /* - * Toshiba SPI NAND read ID needs a dummy byte, - * so the first byte in id is garbage. - */ - if (id[1] != SPINAND_MFR_TOSHIBA) - return 0; - - ret = spinand_match_and_init(spinand, toshiba_spinand_table, - ARRAY_SIZE(toshiba_spinand_table), - id[2]); - if (ret) - return ret; - - return 1; -} - static const struct spinand_manufacturer_ops toshiba_spinand_manuf_ops = { - .detect = toshiba_spinand_detect, };
const struct spinand_manufacturer toshiba_spinand_manufacturer = { .id = SPINAND_MFR_TOSHIBA, .name = "Toshiba", + .chips = toshiba_spinand_table, + .nchips = ARRAY_SIZE(toshiba_spinand_table), .ops = &toshiba_spinand_manuf_ops, }; diff --git a/drivers/mtd/nand/spi/winbond.c b/drivers/mtd/nand/spi/winbond.c index c119486efb..0ce53d3041 100644 --- a/drivers/mtd/nand/spi/winbond.c +++ b/drivers/mtd/nand/spi/winbond.c @@ -79,7 +79,8 @@ static int w25m02gv_select_target(struct spinand_device *spinand, }
static const struct spinand_info winbond_spinand_table[] = { - SPINAND_INFO("W25M02GV", 0xAB, + SPINAND_INFO("W25M02GV", + SPINAND_ID(SPINAND_READID_METHOD_OPCODE_DUMMY, 0xAB), NAND_MEMORG(1, 2048, 64, 64, 1024, 1, 1, 2), NAND_ECCREQ(1, 512), SPINAND_INFO_OP_VARIANTS(&read_cache_variants, @@ -88,7 +89,8 @@ static const struct spinand_info winbond_spinand_table[] = { 0, SPINAND_ECCINFO(&w25m02gv_ooblayout, NULL), SPINAND_SELECT_TARGET(w25m02gv_select_target)), - SPINAND_INFO("W25N01GV", 0xAA, + SPINAND_INFO("W25N01GV", + SPINAND_ID(SPINAND_READID_METHOD_OPCODE_DUMMY, 0xAA), NAND_MEMORG(1, 2048, 64, 64, 1024, 1, 1, 1), NAND_ECCREQ(1, 512), SPINAND_INFO_OP_VARIANTS(&read_cache_variants, @@ -98,31 +100,6 @@ static const struct spinand_info winbond_spinand_table[] = { SPINAND_ECCINFO(&w25m02gv_ooblayout, NULL)), };
-/** - * winbond_spinand_detect - initialize device related part in spinand_device - * struct if it is a Winbond device. - * @spinand: SPI NAND device structure - */ -static int winbond_spinand_detect(struct spinand_device *spinand) -{ - u8 *id = spinand->id.data; - int ret; - - /* - * Winbond SPI NAND read ID need a dummy byte, - * so the first byte in raw_id is dummy. - */ - if (id[1] != SPINAND_MFR_WINBOND) - return 0; - - ret = spinand_match_and_init(spinand, winbond_spinand_table, - ARRAY_SIZE(winbond_spinand_table), id[2]); - if (ret) - return ret; - - return 1; -} - static int winbond_spinand_init(struct spinand_device *spinand) { struct nand_device *nand = spinand_to_nand(spinand); @@ -142,12 +119,13 @@ static int winbond_spinand_init(struct spinand_device *spinand) }
static const struct spinand_manufacturer_ops winbond_spinand_manuf_ops = { - .detect = winbond_spinand_detect, .init = winbond_spinand_init, };
const struct spinand_manufacturer winbond_spinand_manufacturer = { .id = SPINAND_MFR_WINBOND, .name = "Winbond", + .chips = winbond_spinand_table, + .nchips = ARRAY_SIZE(winbond_spinand_table), .ops = &winbond_spinand_manuf_ops, }; diff --git a/include/linux/mtd/spinand.h b/include/linux/mtd/spinand.h index 15bcd59f34..3a2d55ac45 100644 --- a/include/linux/mtd/spinand.h +++ b/include/linux/mtd/spinand.h @@ -39,9 +39,9 @@ SPI_MEM_OP_NO_DUMMY, \ SPI_MEM_OP_NO_DATA)
-#define SPINAND_READID_OP(ndummy, buf, len) \ +#define SPINAND_READID_OP(naddr, ndummy, buf, len) \ SPI_MEM_OP(SPI_MEM_OP_CMD(0x9f, 1), \ - SPI_MEM_OP_NO_ADDR, \ + SPI_MEM_OP_ADDR(naddr, 0, 1), \ SPI_MEM_OP_DUMMY(ndummy, 1), \ SPI_MEM_OP_DATA_IN(len, buf, 1))
@@ -153,37 +153,46 @@ struct spinand_device; * @data: buffer containing the id bytes. Currently 4 bytes large, but can * be extended if required * @len: ID length - * - * struct_spinand_id->data contains all bytes returned after a READ_ID command, - * including dummy bytes if the chip does not emit ID bytes right after the - * READ_ID command. The responsibility to extract real ID bytes is left to - * struct_manufacurer_ops->detect(). */ struct spinand_id { u8 data[SPINAND_MAX_ID_LEN]; int len; };
+enum spinand_readid_method { + SPINAND_READID_METHOD_OPCODE, + SPINAND_READID_METHOD_OPCODE_ADDR, + SPINAND_READID_METHOD_OPCODE_DUMMY, +}; + +/** + * struct spinand_devid - SPI NAND device id structure + * @id: device id of current chip + * @len: number of bytes in device id + * @method: method to read chip id + * There are 3 possible variants: + * SPINAND_READID_METHOD_OPCODE: chip id is returned immediately + * after read_id opcode. + * SPINAND_READID_METHOD_OPCODE_ADDR: chip id is returned after + * read_id opcode + 1-byte address. + * SPINAND_READID_METHOD_OPCODE_DUMMY: chip id is returned after + * read_id opcode + 1 dummy byte. + */ +struct spinand_devid { + const u8 *id; + const u8 len; + const enum spinand_readid_method method; +}; + /** * struct manufacurer_ops - SPI NAND manufacturer specific operations - * @detect: detect a SPI NAND device. Every time a SPI NAND device is probed - * the core calls the struct_manufacurer_ops->detect() hook of each - * registered manufacturer until one of them return 1. Note that - * the first thing to check in this hook is that the manufacturer ID - * in struct_spinand_device->id matches the manufacturer whose - * ->detect() hook has been called. Should return 1 if there's a - * match, 0 if the manufacturer ID does not match and a negative - * error code otherwise. When true is returned, the core assumes - * that properties of the NAND chip (spinand->base.memorg and - * spinand->base.eccreq) have been filled * @init: initialize a SPI NAND device * @cleanup: cleanup a SPI NAND device * * Each SPI NAND manufacturer driver should implement this interface so that - * NAND chips coming from this vendor can be detected and initialized properly. + * NAND chips coming from this vendor can be initialized properly. */ struct spinand_manufacturer_ops { - int (*detect)(struct spinand_device *spinand); int (*init)(struct spinand_device *spinand); void (*cleanup)(struct spinand_device *spinand); }; @@ -193,10 +202,15 @@ struct spinand_manufacturer_ops { * @id: manufacturer ID * @name: manufacturer name * @ops: manufacturer operations + * @devid_len: number of bytes in device ID + * @chips: supported SPI NANDs under current manufacturer + * @nchips: number of SPI NANDs available in chips array */ struct spinand_manufacturer { u8 id; char *name; + const struct spinand_info *chips; + const size_t nchips; const struct spinand_manufacturer_ops *ops; };
@@ -268,7 +282,7 @@ struct spinand_ecc_info { */ struct spinand_info { const char *model; - u8 devid; + struct spinand_devid devid; u32 flags; struct nand_memory_organization memorg; struct nand_ecc_req eccreq; @@ -282,6 +296,13 @@ struct spinand_info { unsigned int target); };
+#define SPINAND_ID(__method, ...) \ + { \ + .id = (const u8[]){ __VA_ARGS__ }, \ + .len = sizeof((u8[]){ __VA_ARGS__ }), \ + .method = __method, \ + } + #define SPINAND_INFO_OP_VARIANTS(__read, __write, __update) \ { \ .read_cache = __read, \ @@ -440,9 +461,10 @@ static inline void spinand_set_ofnode(struct spinand_device *spinand, } #endif /* __UBOOT__ */
-int spinand_match_and_init(struct spinand_device *dev, +int spinand_match_and_init(struct spinand_device *spinand, const struct spinand_info *table, - unsigned int table_size, u8 devid); + unsigned int table_size, + enum spinand_readid_method rdid_method);
int spinand_upd_cfg(struct spinand_device *spinand, u8 mask, u8 val); int spinand_select_target(struct spinand_device *spinand, unsigned int target);
- opcode only. Found in GD5FxGQ4xF.
- opcode + 1 addr byte. Found in GD5GxGQ4xA/E
- opcode + 1 dummy byte. Found in other currently supported chips.
- For chips of variant 2, if SPI master doesn't keep MOSI low
- For chips of variant 1, if it happens to get a devid that equals
An adaptation of this patch was already sent long ago [1] and Dario also picked it up in nand-next [2]. Though it looks like this was never merged upstream as there wasn't any pull request sent to Tom, right?
Dario, as you already seem to have rebased nand-next recently, can you please sent the changes to Tom for picking them up? As the merge window is open at the moment it would be good to get it done soon. Thanks!
[1] https://patchwork.ozlabs.org/project/uboot/patch/20230110115843.391630-1-fri... [2] https://source.denx.de/u-boot/custodians/u-boot-nand-flash/-/commits/nand-ne...
Hi Frieder,
Thanks for pointing this out, looks like this rework made it to upstream, so I'll drop it in v2.
Adaptation of Linux commit d74c36480a67
This patch adds support for ESMT F50L1G41LB and F50D1G41LB. It seems that ESMT likes to use random JEDEC ID from other vendors. Their 1G chips uses 0xc8 from GigaDevice and 2G/4G chips uses 0x2c from Micron. For this reason, the ESMT entry is named esmt_c8 with explicit JEDEC ID in variable name.
Datasheets: https://www.esmt.com.tw/upload/pdf/ESMT/datasheets/F50L1G41LB(2M).pdf https://www.esmt.com.tw/upload/pdf/ESMT/datasheets/F50D1G41LB(2M).pdf
Signed-off-by: Igor Prusov ivprusov@salutedevices.com Signed-off-by: Chuanhong Guo gch981213@gmail.com Signed-off-by: Martin Kurbanov mmkurbanov@sberdevices.ru Signed-off-by: Dmitry Rokosov ddrokosov@sberdevices.ru Tested-by: Martin Kurbanov mmkurbanov@sberdevices.ru --- drivers/mtd/nand/spi/Makefile | 2 +- drivers/mtd/nand/spi/core.c | 1 + drivers/mtd/nand/spi/esmt.c | 137 ++++++++++++++++++++++++++++++++++ include/linux/mtd/spinand.h | 1 + 4 files changed, 140 insertions(+), 1 deletion(-) create mode 100644 drivers/mtd/nand/spi/esmt.c
diff --git a/drivers/mtd/nand/spi/Makefile b/drivers/mtd/nand/spi/Makefile index 6c65b187e8..0585fe8e67 100644 --- a/drivers/mtd/nand/spi/Makefile +++ b/drivers/mtd/nand/spi/Makefile @@ -1,4 +1,4 @@ # SPDX-License-Identifier: GPL-2.0
-spinand-objs := core.o gigadevice.o macronix.o micron.o toshiba.o winbond.o +spinand-objs := core.o gigadevice.o macronix.o micron.o toshiba.o winbond.o esmt.o obj-$(CONFIG_MTD_SPI_NAND) += spinand.o diff --git a/drivers/mtd/nand/spi/core.c b/drivers/mtd/nand/spi/core.c index 3ea746fd13..b84df30bff 100644 --- a/drivers/mtd/nand/spi/core.c +++ b/drivers/mtd/nand/spi/core.c @@ -837,6 +837,7 @@ static const struct spinand_manufacturer *spinand_manufacturers[] = { µn_spinand_manufacturer, &toshiba_spinand_manufacturer, &winbond_spinand_manufacturer, + &esmt_c8_spinand_manufacturer, };
static int spinand_manufacturer_match(struct spinand_device *spinand, diff --git a/drivers/mtd/nand/spi/esmt.c b/drivers/mtd/nand/spi/esmt.c new file mode 100644 index 0000000000..6dacb8d981 --- /dev/null +++ b/drivers/mtd/nand/spi/esmt.c @@ -0,0 +1,137 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Author: + * Chuanhong Guo gch981213@gmail.com - the main driver logic + * Martin Kurbanov mmkurbanov@sberdevices.ru - OOB layout + */ + +#ifndef __UBOOT__ +#include <linux/device.h> +#include <linux/kernel.h> +#endif +#include <linux/mtd/spinand.h> + +/* ESMT uses GigaDevice 0xc8 JECDEC ID on some SPI NANDs */ +#define SPINAND_MFR_ESMT_C8 0xc8 + +static SPINAND_OP_VARIANTS(read_cache_variants, + SPINAND_PAGE_READ_FROM_CACHE_X4_OP(0, 1, NULL, 0), + SPINAND_PAGE_READ_FROM_CACHE_X2_OP(0, 1, NULL, 0), + SPINAND_PAGE_READ_FROM_CACHE_OP(true, 0, 1, NULL, 0), + SPINAND_PAGE_READ_FROM_CACHE_OP(false, 0, 1, NULL, 0)); + +static SPINAND_OP_VARIANTS(write_cache_variants, + SPINAND_PROG_LOAD_X4(true, 0, NULL, 0), + SPINAND_PROG_LOAD(true, 0, NULL, 0)); + +static SPINAND_OP_VARIANTS(update_cache_variants, + SPINAND_PROG_LOAD_X4(false, 0, NULL, 0), + SPINAND_PROG_LOAD(false, 0, NULL, 0)); + +/* + * OOB spare area map (64 bytes) + * + * Bad Block Markers + * filled by HW and kernel Reserved + * | +-----------------------+-----------------------+ + * | | | | + * | | OOB free data Area |non ECC protected | + * | +-------------|-----+-----------------|-----+-----------------|-----+ + * | | | | | | | | + * +-|---|----------+--|-----|--------------+--|-----|--------------+--|-----|--------------+ + * | | | section0 | | | section1 | | | section2 | | | section3 | + * +-v-+-v-+---+----+--v--+--v--+-----+-----+--v--+--v--+-----+-----+--v--+--v--+-----+-----+ + * | | | | | | | | | | | | | | | | | + * |0:1|2:3|4:7|8:15|16:17|18:19|20:23|24:31|32:33|34:35|36:39|40:47|48:49|50:51|52:55|56:63| + * | | | | | | | | | | | | | | | | | + * +---+---+-^-+--^-+-----+-----+--^--+--^--+-----+-----+--^--+--^--+-----+-----+--^--+--^--+ + * | | | | | | | | + * | +----------------|-----+-----------------|-----+-----------------|-----+ + * | ECC Area|(Main + Spare) - filled|by ESMT NAND HW | + * | | | | + * +---------------------+-----------------------+-----------------------+ + * OOB ECC protected Area - not used due to + * partial programming from some filesystems + * (like JFFS2 with cleanmarkers) + */ + +#define ESMT_OOB_SECTION_COUNT 4 +#define ESMT_OOB_SECTION_SIZE(nand) \ + (nanddev_per_page_oobsize(nand) / ESMT_OOB_SECTION_COUNT) +#define ESMT_OOB_FREE_SIZE(nand) \ + (ESMT_OOB_SECTION_SIZE(nand) / 2) +#define ESMT_OOB_ECC_SIZE(nand) \ + (ESMT_OOB_SECTION_SIZE(nand) - ESMT_OOB_FREE_SIZE(nand)) +#define ESMT_OOB_BBM_SIZE 2 + +static int f50l1g41lb_ooblayout_ecc(struct mtd_info *mtd, int section, + struct mtd_oob_region *region) +{ + struct nand_device *nand = mtd_to_nanddev(mtd); + + if (section >= ESMT_OOB_SECTION_COUNT) + return -ERANGE; + + region->offset = section * ESMT_OOB_SECTION_SIZE(nand) + + ESMT_OOB_FREE_SIZE(nand); + region->length = ESMT_OOB_ECC_SIZE(nand); + + return 0; +} + +static int f50l1g41lb_ooblayout_free(struct mtd_info *mtd, int section, + struct mtd_oob_region *region) +{ + struct nand_device *nand = mtd_to_nanddev(mtd); + + if (section >= ESMT_OOB_SECTION_COUNT) + return -ERANGE; + + /* + * Reserve space for bad blocks markers (section0) and + * reserved bytes (sections 1-3) + */ + region->offset = section * ESMT_OOB_SECTION_SIZE(nand) + 2; + + /* Use only 2 non-protected ECC bytes per each OOB section */ + region->length = 2; + + return 0; +} + +static const struct mtd_ooblayout_ops f50l1g41lb_ooblayout = { + .ecc = f50l1g41lb_ooblayout_ecc, + .rfree = f50l1g41lb_ooblayout_free, +}; + +static const struct spinand_info esmt_c8_spinand_table[] = { + SPINAND_INFO("F50L1G41LB", + SPINAND_ID(SPINAND_READID_METHOD_OPCODE_ADDR, 0x01), + NAND_MEMORG(1, 2048, 64, 64, 1024, 1, 1, 1), + NAND_ECCREQ(1, 512), + SPINAND_INFO_OP_VARIANTS(&read_cache_variants, + &write_cache_variants, + &update_cache_variants), + 0, + SPINAND_ECCINFO(&f50l1g41lb_ooblayout, NULL)), + SPINAND_INFO("F50D1G41LB", + SPINAND_ID(SPINAND_READID_METHOD_OPCODE_ADDR, 0x11), + NAND_MEMORG(1, 2048, 64, 64, 1024, 1, 1, 1), + NAND_ECCREQ(1, 512), + SPINAND_INFO_OP_VARIANTS(&read_cache_variants, + &write_cache_variants, + &update_cache_variants), + 0, + SPINAND_ECCINFO(&f50l1g41lb_ooblayout, NULL)), +}; + +static const struct spinand_manufacturer_ops esmt_spinand_manuf_ops = { +}; + +const struct spinand_manufacturer esmt_c8_spinand_manufacturer = { + .id = SPINAND_MFR_ESMT_C8, + .name = "ESMT", + .chips = esmt_c8_spinand_table, + .nchips = ARRAY_SIZE(esmt_c8_spinand_table), + .ops = &esmt_spinand_manuf_ops, +}; diff --git a/include/linux/mtd/spinand.h b/include/linux/mtd/spinand.h index 3a2d55ac45..85c273a1e4 100644 --- a/include/linux/mtd/spinand.h +++ b/include/linux/mtd/spinand.h @@ -220,6 +220,7 @@ extern const struct spinand_manufacturer macronix_spinand_manufacturer; extern const struct spinand_manufacturer micron_spinand_manufacturer; extern const struct spinand_manufacturer toshiba_spinand_manufacturer; extern const struct spinand_manufacturer winbond_spinand_manufacturer; +extern const struct spinand_manufacturer esmt_c8_spinand_manufacturer;
/** * struct spinand_op_variants - SPI NAND operation variants
Frieder Schrempf
Igor Prusov
