[U-Boot] Pull request: u-boot-arm/master
Hello Tom,
The following changes since commit 572886af5984febafa6f083e6b8af0465f4f5764:
socfpga: Adding pin mux handoff files (2013-10-07 19:32:30 +0200)
git://git.denx.De/u-boot-arm master
for you to fetch changes up to 5a9120439416a9101dec7c7dc65bb75a5ff09c4e:
Merge branch 'u-boot-samsung/master' into 'u-boot-arm/master' (2013-10-11 14:47:25 +0200)
Albert ARIBAUD (1): Merge branch 'u-boot-samsung/master' into 'u-boot-arm/master'
Piotr Wilczek (4): drivers:power:max77693: add support for new multi function pmic max77693 power:battery: add battery support for Trats2 board samsung:common:i2c: add definions for third soft I2C adapter for Trats2 board samsung: trats2: add support for new board Trats2
Makefile | 1 + board/samsung/common/multi_i2c.c | 12 + board/samsung/trats2/Makefile | 34 +++ board/samsung/trats2/trats2.c | 513 +++++++++++++++++++++++++++++++++++++ boards.cfg | 1 + drivers/power/battery/Makefile | 1 + drivers/power/battery/bat_trats2.c | 65 +++++ drivers/power/mfd/Makefile | 33 +++ drivers/power/mfd/fg_max77693.c | 139 ++++++++++ drivers/power/mfd/muic_max77693.c | 77 ++++++ drivers/power/mfd/pmic_max77693.c | 96 +++++++ include/configs/trats2.h | 311 ++++++++++++++++++++++ include/power/max77693_fg.h | 49 ++++ include/power/max77693_muic.h | 74 ++++++ include/power/max77693_pmic.h | 43 ++++ 15 files changed, 1449 insertions(+) create mode 100644 board/samsung/trats2/Makefile create mode 100644 board/samsung/trats2/trats2.c create mode 100644 drivers/power/battery/bat_trats2.c create mode 100644 drivers/power/mfd/Makefile create mode 100644 drivers/power/mfd/fg_max77693.c create mode 100644 drivers/power/mfd/muic_max77693.c create mode 100644 drivers/power/mfd/pmic_max77693.c create mode 100644 include/configs/trats2.h create mode 100644 include/power/max77693_fg.h create mode 100644 include/power/max77693_muic.h create mode 100644 include/power/max77693_pmic.h
Amicalement,
On Fri, Oct 11, 2013 at 04:33:18PM +0200, Albert ARIBAUD wrote:
Hello Tom,
Albert ARIBAUD
