[U-Boot] Kconfig bug (optional choice deselected by following option)
-----BEGIN PGP SIGNED MESSAGE----- Hash: SHA256
Hi all,
I have found weird feature of Kconfig. If I misused something, please let me know - I found at least one place where the same error occurs.
Let's consider the following Kconfig (you can put it anywhere in the source tree): <-------------- copy -----------------> menu "Testmenu" choice prompt "Problem to solve" optional default n help Solve one of great world problems
config SOLVE_HUNGER bool "Hunger"
config SOLVE_WARS bool "Wars"
config CURE_CANCER bool "Cancer"
endchoice
config TREES default n bool "Plant trees in garden" endmenu
config BLAH default n bool "Totally unrelated option"
<------------- paste ------------------->
Now, select HUNGER important problem to solve; Warning - select it with space, _not_ enter + selection from list; Then select either TREES or BLAH.
Weird thing is - SOLVE_HUNGER is unselected.
It doesn't happen when you select (anything) by entering selection menu (i.e. enter). Even if you deselect option and then select it with space.
It happens both in menuconfig and nconfig.
It happens both in recent U-Boot b57843e6 and Linux kernel ece62678.
Unfortunately my knowledge of Kconfig is very limited so your help would be appreciated.
Best Regards, Mateusz
Hi Mateusz, (CCing linux-kbuild, which I think the best place to discuss this topic)
I think "default n" in the choice entry is weird because the choice is not boolean.
Without it, the weird thing you saw did not happen on my box.
Anyway, I'd like Kconfig to say something if it is really a syntax error.
I hope comments from Kconfig experts.
2016-01-17 20:39 GMT+09:00 Mateusz Kulikowski mateusz.kulikowski@gmail.com:
Hi all,
endchoice
Best Regards, Mateusz -----BEGIN PGP SIGNATURE----- Version: GnuPG v2
iQEcBAEBCAAGBQJWm31YAAoJELvtohmVtQzB7dEH/0/9BMe6+Oq38UVSUcjmNzaH GqUdkK9MN9tYD6euHTcynlT0HZRkDTYCOFmQjG68Lj1Ejx0/Si2KYe6NKexvkysB HAshC0+rGkbOgW0fkBByL2HY8PGAxtNbSbcwzC7xnhRMCkiPp2xiMy1pwRSOI7tN dDzXEuuTvGxsGHUm8dSuxGE9Wd96MY71BDzO+vQrP+CiCV7IeKYMfiYhngN6FEBz Sq5YCljVsSIvsZuBIaJlPuU7vnS64x2RnxkPskln9k4M9gv6GQOAcRb+YZ0PKLOs qSdzBTvQsEMBdsJBk2nGgBIXUcFSPbAAQwl1FyepFlgm4d6152Wf9BQxFJBNij4= =zry6 -----END PGP SIGNATURE----- _______________________________________________ U-Boot mailing list U-Boot@lists.denx.de http://lists.denx.de/mailman/listinfo/u-boot
I retract my previous replay.
With/without the "default n" in the choice menu, I confirmed the problem happened (in the latest Linux as well as U-Boot).
I hope somebody follows up...
2016-01-18 5:29 GMT+09:00 Masahiro Yamada yamada.masahiro@socionext.com:
Hi all,
endchoice
-- Best Regards Masahiro Yamada
Hi All,
Just a small update from my side;
I used bisect-foo and offending commit (@Linux) seems to be:
commit 5d09598d488f081e3be23f885ed65cbbe2d073b5 Author: Arnaud Lacombe lacombar@gmail.com Date: Mon Jan 23 17:29:05 2012 -0500
kconfig: fix new choices being skipped upon config update
2016-01-17 20:39 GMT+09:00 Mateusz Kulikowski mateusz.kulikowski@gmail.com: Hi all,
endchoice
Masahiro Yamada
Mateusz Kulikowski
