[PATCH] Makefile: Sort u-boot-initial-env output
For a better overview and better comparison sort the initial environment as the get_default_env.sh script does. We need to preserve the order of equal variable names. So only sort by the variable name, and disable the last-resort comparison. Also remove blank lines before sorting.
Signed-off-by: Christoph Niedermaier cniedermaier@dh-electronics.com Cc: Stefano Babic sbabic@denx.de Cc: Simon Glass sjg@chromium.org Cc: Marek Behún marek.behun@nic.cz To: u-boot@lists.denx.de --- Makefile | 3 ++- 1 file changed, 2 insertions(+), 1 deletion(-)
diff --git a/Makefile b/Makefile index 4b152249ca..67ed4edc1a 100644 --- a/Makefile +++ b/Makefile @@ -2439,7 +2439,8 @@ endif
quiet_cmd_genenv = GENENV $@ cmd_genenv = $(OBJCOPY) --dump-section .rodata.default_environment=$@ env/common.o; \ - sed --in-place -e 's/\x00/\x0A/g' $@ + sed --in-place -e 's/\x00/\x0A/g' $@; sed --in-place -e '/^\s*$$/d' $@; \ + sort --field-separator== -k1,1 --stable $@ -o $@
u-boot-initial-env: u-boot.bin $(call if_changed,genenv)
Reviewed-by: Stefano Babic sbabic@denx.de Tested-by: Stefano Babic sbabic@denx.de
Best regards, Stefano Babic
Hi Christoph,
On Wed, 23 Feb 2022 at 02:33, Christoph Niedermaier cniedermaier@dh-electronics.com wrote:
Does this sort the text environment too?
u-boot-initial-env: u-boot.bin $(call if_changed,genenv) -- 2.11.0
From: Simon Glass [mailto:sjg@chromium.org] Sent: Wednesday, February 23, 2022 11:59 PM
Hi Christoph,
Hi Simon,
It sorts only the generated file "u-boot-initial-env" which comes from the default environment. What exactly do you mean by "text environment"?
Regards Christoph
Hi Christoph,
On Thu, 24 Feb 2022 at 02:59, Christoph Niedermaier cniedermaier@dh-electronics.com wrote:
Hi Christoph,
Hi Simon,
https://u-boot.readthedocs.io/en/latest/usage/environment.html#text-based-en...
Can you please expand your commit message a bit to explain exactly what this affects? Also how about an update to the above page that describes how the env is sorted.
From: Simon Glass [mailto:sjg@chromium.org] Sent: Friday, February 25, 2022 12:54 AM
Hi Christoph,
Hi Simon,
Hi Christoph,
Hi Simon,
I will make a V2 of the patch with a better commit message.
The sorting only affects the u-boot-initial-env file for the userspace tools [1]. The environments of the bootloader are sorted if printed by printenv. I think mentioning the u-boot-initial-env file in the page above will lead to more confusion. It think it belongs more to the userspace tools [1].
[1] https://github.com/sbabic/libubootenv
Regards Christoph
Stefano Babic
