[U-boot,0/2] Enable mt7531 switch support for MT7629
This patch series enable MT7629 sgmii mode with mt7531 switch support, 1. enable mt7629 sgmii mode support in mediatek eth driver 2. enable mt7629 ethernet dts node with sgmii mode and mt7531 switch support
MarkLee (2): eth: mtk-eth: enable mt7629 sgmii mode support in mediatek eth driver arm: dts: mediatek: enable sgmii mode and mt7531 switch for mt7629
arch/arm/dts/mt7629-rfb.dts | 12 +++++++----- drivers/net/mtk_eth.h | 5 +++++ 2 files changed, 12 insertions(+), 5 deletions(-)
The sgmii mode init flow is almost the same for all mediatek SoC, the only difference is the register offset(SGMSYS_GEN2_SPEED) is 0x2028 for old chip(mt7622) but changed to 0x128 for newer chip(mt7629 and the following chips).
Signed-off-by: MarkLee Mark-MC.Lee@mediatek.com --- drivers/net/mtk_eth.h | 5 +++++ 1 file changed, 5 insertions(+)
diff --git a/drivers/net/mtk_eth.h b/drivers/net/mtk_eth.h index f2940c9996..3c85eab91a 100644 --- a/drivers/net/mtk_eth.h +++ b/drivers/net/mtk_eth.h @@ -44,7 +44,12 @@ #define SGMSYS_QPHY_PWR_STATE_CTRL 0xe8 #define SGMII_PHYA_PWD BIT(4)
+#if defined(CONFIG_TARGET_MT7622) #define SGMSYS_GEN2_SPEED 0x2028 +#else +#define SGMSYS_GEN2_SPEED 0x128 +#endif + #define SGMSYS_SPEED_2500 BIT(2)
/* Frame Engine Registers */
Hi MarkLee,
You can't check #ifdefs in drivers. You should use a compatible string, then device_get_driver_data() to decide what the value is here.
Or if this is board-specific you could add it to the device-tree node as a property, if it is in the binding.
On Sun, 2020-05-31 at 08:08 -0600, Simon Glass wrote:
Hi MarkLee,
Thanks for your review and suggestion, will change to use private data from dts to decide the value in the following V2 patch.
This patch enable sgmii mode and mt7531 switch support in mt7629 ethernet dts node.
Signed-off-by: MarkLee Mark-MC.Lee@mediatek.com --- arch/arm/dts/mt7629-rfb.dts | 12 +++++++----- 1 file changed, 7 insertions(+), 5 deletions(-)
diff --git a/arch/arm/dts/mt7629-rfb.dts b/arch/arm/dts/mt7629-rfb.dts index 687fe1c029..5864f5551b 100644 --- a/arch/arm/dts/mt7629-rfb.dts +++ b/arch/arm/dts/mt7629-rfb.dts @@ -24,12 +24,14 @@
ð { status = "okay"; - mediatek,gmac-id = <1>; - phy-mode = "gmii"; - phy-handle = <&phy0>; + mediatek,gmac-id = <0>; + phy-mode = "sgmii"; + mediatek,switch = "mt7531"; + reset-gpios = <&gpio 28 GPIO_ACTIVE_HIGH>;
- phy0: ethernet-phy@0 { - reg = <0>; + fixed-link { + speed = <1000>; + full-duplex; }; };
Mark-MC.Lee
MarkLee
