[U-Boot] [PATCH 1/2] dm: video: Add a temporary work-around for old stdout var
Boards with a saved environment may use 'lcd' in their stdout environment variable, expecting that this will enable output to the LCD. When the board moves to use driver model for video, this will no-longer work. Add a work-around to fix this. A warning messages is printed, and we will remove the work-around at the end of 2016.
common/console.c | 8 ++++++++ drivers/video/Kconfig | 10 ++++++++++ 2 files changed, 18 insertions(+)
diff --git a/common/console.c b/common/console.c index b3f5fdc..6a0d11b 100644 --- a/common/console.c +++ b/common/console.c @@ -650,6 +650,10 @@ struct stdio_dev *search_device(int flags, const char *name) struct stdio_dev *dev;
dev = stdio_get_by_name(name); +#ifdef CONFIG_VIDCONSOLE_AS_LCD + if (!dev && !strcmp(name, "lcd")) + dev = stdio_get_by_name("vidconsole"); +#endif
if (dev && (dev->flags & flags)) return dev; @@ -795,6 +799,10 @@ done: #ifndef CONFIG_SYS_CONSOLE_INFO_QUIET stdio_print_current_devices(); #endif /* CONFIG_SYS_CONSOLE_INFO_QUIET */ +#ifdef CONFIG_VIDCONSOLE_AS_LCD + if (strstr(stdoutname, "lcd")) + printf("Warning: Please change 'lcd' to 'vidconsole' in stdout/stderr environment vars\n"); +#endif
#ifdef CONFIG_SYS_CONSOLE_ENV_OVERWRITE /* set the environment variables (will overwrite previous env settings) */ diff --git a/drivers/video/Kconfig b/drivers/video/Kconfig index 981ba8b..ae6c244 100644 --- a/drivers/video/Kconfig +++ b/drivers/video/Kconfig @@ -57,6 +57,16 @@ config VIDEO_ROTATION struct video_priv: 0=unrotated, 1=90 degrees clockwise, 2=180 degrees, 3=270 degrees.
+config VIDCONSOLE_AS_LCD + bool "Use 'vidconsole' when 'lcd' is seen in stdout" + depends on DM_VIDEO + help + This is a work-around for boards which have 'lcd' in their stdout + environment variable, but have moved to use driver model for video. + In this case the console will no-longer work. While it is possible + to update the environment, the breakage may be confusing for users. + This option will be removed around the end of 2016. + config VIDEO_VESA bool "Enable VESA video driver support" default n
Enable this option on all tegra boards.
arch/arm/mach-tegra/Kconfig | 1 + 1 file changed, 1 insertion(+)
diff --git a/arch/arm/mach-tegra/Kconfig b/arch/arm/mach-tegra/Kconfig index 66298d5..3540eda 100644 --- a/arch/arm/mach-tegra/Kconfig +++ b/arch/arm/mach-tegra/Kconfig @@ -14,6 +14,7 @@ config TEGRA_COMMON select DM_SPI select DM_SPI_FLASH select OF_CONTROL + select VIDCONSOLE_AS_LCD
config TEGRA_ARMV7_COMMON bool "Tegra 32-bit common options"
Acked-by: Anatolij Gustschin agust@denx.de
applied to u-boot-video/master, thanks!
-- Anatolij
Hi Simon,
-- Anatolij
I tested u-boot-dm/tegra-working which I assume is the same as these patches, so the series,
Tested-by: Stephen Warren swarren@nvidia.com
But...
- bool "Use 'vidconsole' when 'lcd' is seen in stdout"
- depends on DM_VIDEO
- help
Removing this option at the end of 2016 is simply going to cause the exact same problem then. Is there any harm in simply not deprecating this feature? I suppose at least there's a warning that people should convert over, so perhaps they will and so the chances of people getting bitten by this well be less by then.
Hi Stephen,
But...
depends on DM_VIDEO
help
stdout
video.
possible
users.
Also we do need people to keep up with things to some extent. Otherwise we end up with cruft that confuses people. There is a prominent run-time message that people will see in the meantime.
What's the status of this series now? I'd like to see if it can be applied.
Hi Simon,
-- Anatolij
Anatolij Gustschin
Stephen Warren
