[U-Boot] [PATCH] power: regulator: Add support for gpio regulators
Add support for gpio regulators. As of now this driver caters to gpio regulators with one gpio. Supports setting voltage values to gpio regulators and retrieving the values.
Signed-off-by: Keerthy j-keerthy@ti.com --- drivers/power/regulator/Kconfig | 8 ++ drivers/power/regulator/Makefile | 1 + drivers/power/regulator/gpio-regulator.c | 136 +++++++++++++++++++++++++++++++ include/power/regulator.h | 1 + 4 files changed, 146 insertions(+) create mode 100644 drivers/power/regulator/gpio-regulator.c
diff --git a/drivers/power/regulator/Kconfig b/drivers/power/regulator/Kconfig index 2510474..4776011 100644 --- a/drivers/power/regulator/Kconfig +++ b/drivers/power/regulator/Kconfig @@ -58,6 +58,14 @@ config DM_REGULATOR_FIXED features for fixed value regulators. The driver implements get/set api for enable and get only for voltage value.
+config DM_REGULATOR_GPIO + bool "Enable Driver Model for GPIO REGULATOR" + depends on DM_REGULATOR + ---help--- + This config enables implementation of driver-model regulator uclass + features for gpio regulators. The driver implements get/set for + voltage value. + config REGULATOR_RK808 bool "Enable driver for RK808 regulators" depends on DM_REGULATOR && PMIC_RK808 diff --git a/drivers/power/regulator/Makefile b/drivers/power/regulator/Makefile index 2093048..2d350cb 100644 --- a/drivers/power/regulator/Makefile +++ b/drivers/power/regulator/Makefile @@ -10,6 +10,7 @@ obj-$(CONFIG_REGULATOR_ACT8846) += act8846.o obj-$(CONFIG_DM_REGULATOR_MAX77686) += max77686.o obj-$(CONFIG_DM_REGULATOR_PFUZE100) += pfuze100.o obj-$(CONFIG_$(SPL_)DM_REGULATOR_FIXED) += fixed.o +obj-$(CONFIG_$(SPL_)DM_REGULATOR_GPIO) += gpio-regulator.o obj-$(CONFIG_REGULATOR_RK808) += rk808.o obj-$(CONFIG_REGULATOR_S5M8767) += s5m8767.o obj-$(CONFIG_DM_REGULATOR_SANDBOX) += sandbox.o diff --git a/drivers/power/regulator/gpio-regulator.c b/drivers/power/regulator/gpio-regulator.c new file mode 100644 index 0000000..9c8832e --- /dev/null +++ b/drivers/power/regulator/gpio-regulator.c @@ -0,0 +1,136 @@ +/* + * (C) Copyright 2016 Texas Instruments Incorporated, <www.ti.com> + * Keerthy j-keerthy@ti.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <fdtdec.h> +#include <errno.h> +#include <dm.h> +#include <i2c.h> +#include <asm/gpio.h> +#include <power/pmic.h> +#include <power/regulator.h> + +DECLARE_GLOBAL_DATA_PTR; + +struct gpio_regulator_platdata { + struct gpio_desc gpio; /* GPIO for regulator voltage control */ + int gpio_low_uV; + int gpio_high_uV; +}; + +static int gpio_regulator_ofdata_to_platdata(struct udevice *dev) +{ + struct dm_regulator_uclass_platdata *uc_pdata; + struct gpio_regulator_platdata *dev_pdata; + struct gpio_desc *gpio; + const void *blob = gd->fdt_blob; + int node = dev->of_offset; + int ret, count, i; + u32 states_array[8]; + + dev_pdata = dev_get_platdata(dev); + uc_pdata = dev_get_uclass_platdata(dev); + if (!uc_pdata) + return -ENXIO; + + /* Set type to gpio */ + uc_pdata->type = REGULATOR_TYPE_GPIO; + + /* + * Get gpio regulator gpio desc + * Assuming one GPIO per regulator. + * Can be extended later to multiple GPIOs + * per gpio-regulator. As of now no instance with multiple + * gpios is presnt + */ + gpio = &dev_pdata->gpio; + ret = gpio_request_by_name(dev, "gpios", 0, gpio, GPIOD_IS_OUT); + if (ret) + debug("regulator gpio - not found! Error: %d", ret); + + count = fdtdec_get_int_array_count(blob, node, "states", + states_array, 8); + + if (!count) + return -EINVAL; + + for (i = 0; i < count; i += 2) { + if (states_array[i + 1] == 0) + dev_pdata->gpio_low_uV = states_array[i]; + else + dev_pdata->gpio_high_uV = states_array[i]; + } + + return 0; +} + +static int gpio_regulator_get_value(struct udevice *dev) +{ + struct dm_regulator_uclass_platdata *uc_pdata; + struct gpio_regulator_platdata *dev_pdata = dev_get_platdata(dev); + int enable; + + if (!dev_pdata->gpio.dev) + return -ENOSYS; + + uc_pdata = dev_get_uclass_platdata(dev); + if (uc_pdata->min_uV > uc_pdata->max_uV) { + debug("Invalid constraints for: %s\n", uc_pdata->name); + return -EINVAL; + } + + enable = dm_gpio_get_value(&dev_pdata->gpio); + if (enable) + return dev_pdata->gpio_high_uV; + else + return dev_pdata->gpio_low_uV; +} + +static int gpio_regulator_set_value(struct udevice *dev, int uV) +{ + struct gpio_regulator_platdata *dev_pdata = dev_get_platdata(dev); + int ret; + bool enable; + + if (!dev_pdata->gpio.dev) + return -ENOSYS; + + if (uV == dev_pdata->gpio_high_uV) + enable = 1; + else if (uV == dev_pdata->gpio_low_uV) + enable = 0; + else + return -EINVAL; + + ret = dm_gpio_set_value(&dev_pdata->gpio, enable); + if (ret) { + error("Can't set regulator : %s gpio to: %d\n", dev->name, + enable); + return ret; + } + + return 0; +} + +static const struct dm_regulator_ops gpio_regulator_ops = { + .get_value = gpio_regulator_get_value, + .set_value = gpio_regulator_set_value, +}; + +static const struct udevice_id gpio_regulator_ids[] = { + { .compatible = "regulator-gpio" }, + { }, +}; + +U_BOOT_DRIVER(gpio_regulator) = { + .name = "gpio regulator", + .id = UCLASS_REGULATOR, + .ops = &gpio_regulator_ops, + .of_match = gpio_regulator_ids, + .ofdata_to_platdata = gpio_regulator_ofdata_to_platdata, + .platdata_auto_alloc_size = sizeof(struct gpio_regulator_platdata), +}; diff --git a/include/power/regulator.h b/include/power/regulator.h index 8ae6b14..5d327e6 100644 --- a/include/power/regulator.h +++ b/include/power/regulator.h @@ -108,6 +108,7 @@ enum regulator_type { REGULATOR_TYPE_BUCK, REGULATOR_TYPE_DVS, REGULATOR_TYPE_FIXED, + REGULATOR_TYPE_GPIO, REGULATOR_TYPE_OTHER, };
Hello Keerthy,
- bool "Enable Driver Model for GPIO REGULATOR"
- depends on DM_REGULATOR
- ---help---
- This config enables implementation of driver-model regulator uclass
- features for gpio regulators. The driver implements get/set for
- voltage value.
- config REGULATOR_RK808 bool "Enable driver for RK808 regulators" depends on DM_REGULATOR && PMIC_RK808
- (C) Copyright 2016 Texas Instruments Incorporated, <www.ti.com>
- Keerthy j-keerthy@ti.com
- struct gpio_desc gpio; /* GPIO for regulator voltage control */
- int gpio_low_uV;
- int gpio_high_uV;
The low/high values can be provided by regulator's uclass driver in struct of type "dm_regulator_uclass_platdata", as for other regulators.
But as I can see in the Linux, this driver should provide a structure for the gpio states.
- struct dm_regulator_uclass_platdata *uc_pdata;
- struct gpio_regulator_platdata *dev_pdata;
- struct gpio_desc *gpio;
- const void *blob = gd->fdt_blob;
- int node = dev->of_offset;
- int ret, count, i;
- u32 states_array[8];
- dev_pdata = dev_get_platdata(dev);
- uc_pdata = dev_get_uclass_platdata(dev);
- if (!uc_pdata)
return -ENXIO;
- /* Set type to gpio */
- uc_pdata->type = REGULATOR_TYPE_GPIO;
* gpios is presnt
- gpio = &dev_pdata->gpio;
- ret = gpio_request_by_name(dev, "gpios", 0, gpio, GPIOD_IS_OUT);
- if (ret)
- count = fdtdec_get_int_array_count(blob, node, "states",
states_array, 8);
- if (!count)
return -EINVAL;
- for (i = 0; i < count; i += 2) {
The below condition is valid for most devices.
In Linux we can find dts for some ARMs in which I can find at least two boards, with inverted meaning of state/voltage, so "0", can be also valid for the high uV.
I think, this driver should keep possible states in platdata.
else
- struct gpio_regulator_platdata *dev_pdata = dev_get_platdata(dev);
- int enable;
- if (!dev_pdata->gpio.dev)
return -ENOSYS;
- if (uc_pdata->min_uV > uc_pdata->max_uV) {
return -EINVAL;
- enable = dm_gpio_get_value(&dev_pdata->gpio);
The returned value (enable) should be compared to the states kept in platdata.
- if (enable)
- else
- int ret;
- bool enable;
return -ENOSYS;
- if (uV == dev_pdata->gpio_high_uV)
enable = 1;
- else if (uV == dev_pdata->gpio_low_uV)
enable = 0;
- else
return -EINVAL;
And also here you should get the "enable" value from states kept in platdata.
- ret = dm_gpio_set_value(&dev_pdata->gpio, enable);
- if (ret) {
enable);
return ret;
- .get_value = gpio_regulator_get_value,
- .set_value = gpio_regulator_set_value,
- { .compatible = "regulator-gpio" },
- .name = "gpio regulator",
- .id = UCLASS_REGULATOR,
- .ops = &gpio_regulator_ops,
- .of_match = gpio_regulator_ids,
- .ofdata_to_platdata = gpio_regulator_ofdata_to_platdata,
- .platdata_auto_alloc_size = sizeof(struct gpio_regulator_platdata),
- REGULATOR_TYPE_GPIO, REGULATOR_TYPE_OTHER, };
On Thursday 15 September 2016 03:04 PM, Przemyslaw Marczak wrote:
Hello Keerthy,
diff --git a/drivers/power/regulator/Kconfig b/drivers/power/regulator/Kconfig index 2510474..4776011 100644 --- a/drivers/power/regulator/Kconfig +++ b/drivers/power/regulator/Kconfig @@ -58,6 +58,14 @@ config DM_REGULATOR_FIXED features for fixed value regulators. The driver implements get/set api for enable and get only for voltage value. +config DM_REGULATOR_GPIO
- ---help---
- voltage value.
- int gpio_low_uV;
- int gpio_high_uV;
min_uV, max_uV represent the minimum and maximum voltages in dm_regulator_uclass_platdata. I would not use them here.
Yes so i am keeping the voltage values for 0 and 1 states in a driver specific struct.
- if (!uc_pdata)
return -ENXIO;
* gpios is presnt
- if (ret)
states_array, 8);
- if (!count)
return -EINVAL;
Okay. I get the point. So i will have both states and corresponding states voltages stored in gpio_regulator_platdata structure and set states corresponding to requested voltages.
else
- int enable;
return -ENOSYS;
return -EINVAL;
Sure.
- if (enable)
- else
- int ret;
- bool enable;
return -ENOSYS;
enable = 1;
enable = 0;
- else
return -EINVAL;
Okay.
- if (ret) {
enable);
return ret;
Thanks for the review, - Keerthy
Hello Keerthy,
- ---help---
uclass
- voltage value.
- int gpio_low_uV;
- int gpio_high_uV;
Ah right, sorry I just get wrong the name of those variables above - as min/max uV, but your point was about the GPIO lo/hi state.
- if (!uc_pdata)
return -ENXIO;
* gpios is presnt
- if (ret)
states_array, 8);
- if (!count)
return -EINVAL;
Yes, so actually the only issue is low/high interpretation.
Maybe the easiest way is a simple array with the voltage, since there are only two states. But maybe the name of gpio_low/hi.. is quite misleading. What about an array gpio_state_uV[2] or something like that?
Then you can use GPIO state's true/false as array index for get method.
else
- int enable;
return -ENOSYS;
return -EINVAL;
Sure.
- if (enable)
- else
- int ret;
- bool enable;
return -ENOSYS;
enable = 1;
enable = 0;
- else
return -EINVAL;
Okay.
- if (ret) {
enable);
return ret;
- Keerthy
You are welcome
Hello Keerthy,
- ---help---
uclass
- voltage value.
- int gpio_low_uV;
- int gpio_high_uV;
- if (!uc_pdata)
return -ENXIO;
* gpios is presnt
- if (ret)
states_array, 8);
- if (!count)
return -EINVAL;
Yes. I sent a V2 :-) with your comments fixed.
else
- int enable;
return -ENOSYS;
return -EINVAL;
Sure.
- if (enable)
- else
- int ret;
- bool enable;
return -ENOSYS;
enable = 1;
enable = 0;
- else
return -EINVAL;
Okay.
- if (ret) {
enable);
return ret;
- Keerthy
You are welcome
Keerthy
Keerthy
Przemyslaw Marczak
