[U-Boot] [PATCH] net: e1000: support 'write_hwaddr' in DM
This commit ports the existing (non-DM) function for writing the MAC- address into the shadow ram (and flash) for DM.
Signed-off-by: Hannes Schmelzer hannes.schmelzer@br-automation.com ---
drivers/net/e1000.c | 89 +++++++++++++++++++++++++++++------------------------ 1 file changed, 48 insertions(+), 41 deletions(-)
diff --git a/drivers/net/e1000.c b/drivers/net/e1000.c index a34f697..939e23e 100644 --- a/drivers/net/e1000.c +++ b/drivers/net/e1000.c @@ -862,7 +862,6 @@ e1000_read_eeprom(struct e1000_hw *hw, uint16_t offset, return E1000_SUCCESS; }
-#ifndef CONFIG_DM_ETH /****************************************************************************** * e1000_write_eeprom_srwr - Write to Shadow Ram using EEWR * @hw: pointer to the HW structure @@ -1028,7 +1027,6 @@ static int32_t e1000_update_eeprom_checksum_i210(struct e1000_hw *hw) out: return ret_val; } -#endif
/****************************************************************************** * Verifies that the EEPROM has a valid checksum @@ -5649,45 +5647,6 @@ e1000_poll(struct eth_device *nic) return len ? 1 : 0; }
-static int e1000_write_hwaddr(struct eth_device *dev) -{ -#ifndef CONFIG_E1000_NO_NVM - unsigned char *mac = dev->enetaddr; - unsigned char current_mac[6]; - struct e1000_hw *hw = dev->priv; - uint16_t data[3]; - int ret_val, i; - - DEBUGOUT("%s: mac=%pM\n", __func__, mac); - - memset(current_mac, 0, 6); - - /* Read from EEPROM, not from registers, to make sure - * the address is persistently configured - */ - ret_val = e1000_read_mac_addr_from_eeprom(hw, current_mac); - DEBUGOUT("%s: current mac=%pM\n", __func__, current_mac); - - /* Only write to EEPROM if the given address is different or - * reading the current address failed - */ - if (!ret_val && memcmp(current_mac, mac, 6) == 0) - return 0; - - for (i = 0; i < 3; ++i) - data[i] = mac[i * 2 + 1] << 8 | mac[i * 2]; - - ret_val = e1000_write_eeprom_srwr(hw, 0x0, 3, data); - - if (!ret_val) - ret_val = e1000_update_eeprom_checksum_i210(hw); - - return ret_val; -#else - return 0; -#endif -} - /************************************************************************** PROBE - Look for an adapter, this routine's visible to the outside You should omit the last argument struct pci_device * for a non-PCI NIC @@ -5756,6 +5715,53 @@ struct e1000_hw *e1000_find_card(unsigned int cardnum) } #endif /* !CONFIG_DM_ETH */
+#ifndef CONFIG_DM_ETH +static int e1000_write_hwaddr(struct eth_device *dev) +#else +static int e1000_write_hwaddr(struct udevice *dev) +#endif +{ +#ifndef CONFIG_E1000_NO_NVM +#ifndef CONFIG_DM_ETH + unsigned char *mac = dev->enetaddr; + struct e1000_hw *hw = dev->priv; +#else + struct eth_pdata *plat = dev_get_platdata(dev); + unsigned char *mac = plat->enetaddr; + struct e1000_hw *hw = dev_get_priv(dev); +#endif + unsigned char current_mac[6]; + u16 data[3]; + int ret_val, i; + + DEBUGOUT("%s: mac=%pM\n", __func__, mac); + + memset(current_mac, 0, 6); + + /* Read from EEPROM, not from registers, to make sure + * the address is persistently configured + */ + ret_val = e1000_read_mac_addr_from_eeprom(hw, current_mac); + DEBUGOUT("%s: current mac=%pM\n", __func__, current_mac); + + /* Only write to EEPROM if the given address is different or + * reading the current address failed + */ + if (!ret_val && memcmp(current_mac, mac, 6) == 0) + return 0; + + for (i = 0; i < 3; ++i) + data[i] = mac[i * 2 + 1] << 8 | mac[i * 2]; + + ret_val = e1000_write_eeprom_srwr(hw, 0x0, 3, data); + if (!ret_val) + ret_val = e1000_update_eeprom_checksum_i210(hw); + return ret_val; +#else /* CONFIG_E1000_NO_NVM */ + return 0; +#endif +} + #ifdef CONFIG_CMD_E1000 static int do_e1000(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) @@ -5914,6 +5920,7 @@ static const struct eth_ops e1000_eth_ops = { .recv = e1000_eth_recv, .stop = e1000_eth_stop, .free_pkt = e1000_free_pkt, + .write_hwaddr = e1000_write_hwaddr, };
static const struct udevice_id e1000_eth_ids[] = {
On Thu, Oct 11, 2018 at 12:43 AM Hannes Schmelzer hannes.schmelzer@br-automation.com wrote:
Hi Hannes,
-----Original Message----- From: Hannes Schmelzer hannes.schmelzer@br-automation.com Sent: Thursday, October 11, 2018 12:42 AM To: u-boot@lists.denx.de Cc: Hannes Schmelzer hannes.schmelzer@br-automation.com; Joseph Hershberger joseph.hershberger@ni.com Subject: [PATCH] net: e1000: support 'write_hwaddr' in DM
This seems to break many boards. Please build boards that failed and address the break.
https://travis-ci.org/jhershbe/u-boot/builds/444858982
Thanks, -Joe
On 24.10.2018 20:42, Joseph Hershberger wrote:
Hi Hannes,
Hi Joe,
Sorry for inconvenience, i fixed that and sent a V2 to the mailinglist. Made also a travis build: https://travis-ci.org/oe5hpm/u-boot/jobs/446070290
Thanks, -Joe
cheers, Hannes
Hannes Schmelzer
Hannes Schmelzer
Joe Hershberger
Joseph Hershberger
