[PATCH v6 00/12] handling all DM watchdogs in watchdog_reset()
This series is an attempt at expanding the wdt-uclass provided watchdog_reset() to handle all DM watchdogs, not just the first one. Some of the ad hoc work done for the first DM watchdog in initr_watchdog() is now moved to a .pre_probe hook so it is automatically done for all devices.
It also includes a patch adding a driver for a gpio-petted watchdog device (and a sandbox test of that) - it is included here because that also gives a relatively easy way to have more than one (kind of) watchdog device in the sandbox, which is then used at the end to test that watchdog_reset() behaves as expected.
v2: https://lore.kernel.org/u-boot/20210527220017.1266765-1-rasmus.villemoes@pre...
v3: https://lore.kernel.org/u-boot/20210702124510.124401-1-rasmus.villemoes@prev...
v4: https://lore.kernel.org/u-boot/20210802150016.588750-1-rasmus.villemoes@prev...
v5: https://lore.kernel.org/u-boot/20210811124800.2593226-1-rasmus.villemoes@pre...
Changes in v6: Make wdt_stop_all() return the first error encountered (if any), yet still visit all watchdog devices.
Rasmus Villemoes (12): watchdog: wdt-uclass.c: use wdt_start() in wdt_expire_now() watchdog: wdt-uclass.c: introduce struct wdt_priv watchdog: wdt-uclass.c: neaten UCLASS_DRIVER definition watchdog: wdt-uclass.c: refactor initr_watchdog() watchdog: wdt-uclass.c: keep track of each device's running state sandbox: disable CONFIG_WATCHDOG_AUTOSTART watchdog: wdt-uclass.c: add wdt_stop_all() helper board: x530: switch to wdt_stop_all() watchdog: wdt-uclass.c: handle all DM watchdogs in watchdog_reset() watchdog: add gpio watchdog driver sandbox: add test of wdt_gpio driver sandbox: add test of wdt-uclass' watchdog_reset()
arch/sandbox/dts/test.dts | 8 + board/alliedtelesis/x530/x530.c | 5 +- configs/sandbox64_defconfig | 2 + configs/sandbox_defconfig | 2 + .../watchdog/gpio-wdt.txt | 19 ++ drivers/watchdog/Kconfig | 9 + drivers/watchdog/Makefile | 1 + drivers/watchdog/gpio_wdt.c | 68 +++++++ drivers/watchdog/wdt-uclass.c | 192 +++++++++++++----- include/asm-generic/global_data.h | 6 - include/wdt.h | 8 + test/dm/wdt.c | 90 +++++++- 12 files changed, 349 insertions(+), 61 deletions(-) create mode 100644 doc/device-tree-bindings/watchdog/gpio-wdt.txt create mode 100644 drivers/watchdog/gpio_wdt.c
wdt_start() does the "no ->start? return -ENOSYS" check, don't open-code that in wdt_expire_now().
Also, wdt_start() maintains some global (and later some per-device) state, which would get out of sync with this direct method call - not that it matters much here since the board is supposed to reset very soon.
Reviewed-by: Simon Glass sjg@chromium.org Reviewed-by: Stefan Roese sr@denx.de Signed-off-by: Rasmus Villemoes rasmus.villemoes@prevas.dk --- drivers/watchdog/wdt-uclass.c | 4 +--- 1 file changed, 1 insertion(+), 3 deletions(-)
diff --git a/drivers/watchdog/wdt-uclass.c b/drivers/watchdog/wdt-uclass.c index 17334dbda6..df8164da2a 100644 --- a/drivers/watchdog/wdt-uclass.c +++ b/drivers/watchdog/wdt-uclass.c @@ -120,10 +120,8 @@ int wdt_expire_now(struct udevice *dev, ulong flags) if (ops->expire_now) { return ops->expire_now(dev, flags); } else { - if (!ops->start) - return -ENOSYS; + ret = wdt_start(dev, 1, flags);
- ret = ops->start(dev, 1, flags); if (ret < 0) return ret;
As preparation for having the wdt-uclass provided watchdog_reset() function handle all DM watchdog devices, and not just the first such, introduce a uclass-owned struct to hold the reset_period and next_reset, so these become per-device instead of being static variables.
No functional change intended.
Reviewed-by: Simon Glass sjg@chromium.org Reviewed-by: Stefan Roese sr@denx.de Signed-off-by: Rasmus Villemoes rasmus.villemoes@prevas.dk --- drivers/watchdog/wdt-uclass.c | 74 +++++++++++++++++++++++++---------- 1 file changed, 54 insertions(+), 20 deletions(-)
diff --git a/drivers/watchdog/wdt-uclass.c b/drivers/watchdog/wdt-uclass.c index df8164da2a..b29d214724 100644 --- a/drivers/watchdog/wdt-uclass.c +++ b/drivers/watchdog/wdt-uclass.c @@ -20,15 +20,24 @@ DECLARE_GLOBAL_DATA_PTR;
#define WATCHDOG_TIMEOUT_SECS (CONFIG_WATCHDOG_TIMEOUT_MSECS / 1000)
-/* - * Reset every 1000ms, or however often is required as indicated by a - * hw_margin_ms property. - */ -static ulong reset_period = 1000; +struct wdt_priv { + /* Timeout, in seconds, to configure this device to. */ + u32 timeout; + /* + * Time, in milliseconds, between calling the device's ->reset() + * method from watchdog_reset(). + */ + ulong reset_period; + /* + * Next time (as returned by get_timer(0)) to call + * ->reset(). + */ + ulong next_reset; +};
int initr_watchdog(void) { - u32 timeout = WATCHDOG_TIMEOUT_SECS; + struct wdt_priv *priv; int ret;
/* @@ -44,28 +53,21 @@ int initr_watchdog(void) return 0; } } - - if (CONFIG_IS_ENABLED(OF_CONTROL) && !CONFIG_IS_ENABLED(OF_PLATDATA)) { - timeout = dev_read_u32_default(gd->watchdog_dev, "timeout-sec", - WATCHDOG_TIMEOUT_SECS); - reset_period = dev_read_u32_default(gd->watchdog_dev, - "hw_margin_ms", - 4 * reset_period) / 4; - } + priv = dev_get_uclass_priv(gd->watchdog_dev);
if (!IS_ENABLED(CONFIG_WATCHDOG_AUTOSTART)) { printf("WDT: Not starting\n"); return 0; }
- ret = wdt_start(gd->watchdog_dev, timeout * 1000, 0); + ret = wdt_start(gd->watchdog_dev, priv->timeout * 1000, 0); if (ret != 0) { printf("WDT: Failed to start\n"); return 0; }
printf("WDT: Started with%s servicing (%ds timeout)\n", - IS_ENABLED(CONFIG_WATCHDOG) ? "" : "out", timeout); + IS_ENABLED(CONFIG_WATCHDOG) ? "" : "out", priv->timeout);
return 0; } @@ -139,18 +141,21 @@ int wdt_expire_now(struct udevice *dev, ulong flags) */ void watchdog_reset(void) { - static ulong next_reset; + struct wdt_priv *priv; + struct udevice *dev; ulong now;
/* Exit if GD is not ready or watchdog is not initialized yet */ if (!gd || !(gd->flags & GD_FLG_WDT_READY)) return;
+ dev = gd->watchdog_dev; + priv = dev_get_uclass_priv(dev); /* Do not reset the watchdog too often */ now = get_timer(0); - if (time_after_eq(now, next_reset)) { - next_reset = now + reset_period; - wdt_reset(gd->watchdog_dev); + if (time_after_eq(now, priv->next_reset)) { + priv->next_reset = now + priv->reset_period; + wdt_reset(dev); } } #endif @@ -177,9 +182,38 @@ static int wdt_post_bind(struct udevice *dev) return 0; }
+static int wdt_pre_probe(struct udevice *dev) +{ + u32 timeout = WATCHDOG_TIMEOUT_SECS; + /* + * Reset every 1000ms, or however often is required as + * indicated by a hw_margin_ms property. + */ + ulong reset_period = 1000; + struct wdt_priv *priv; + + if (CONFIG_IS_ENABLED(OF_CONTROL) && !CONFIG_IS_ENABLED(OF_PLATDATA)) { + timeout = dev_read_u32_default(dev, "timeout-sec", timeout); + reset_period = dev_read_u32_default(dev, "hw_margin_ms", + 4 * reset_period) / 4; + } + priv = dev_get_uclass_priv(dev); + priv->timeout = timeout; + priv->reset_period = reset_period; + /* + * Pretend this device was last reset "long" ago so the first + * watchdog_reset will actually call its ->reset method. + */ + priv->next_reset = get_timer(0); + + return 0; +} + UCLASS_DRIVER(wdt) = { .id = UCLASS_WDT, .name = "watchdog", .flags = DM_UC_FLAG_SEQ_ALIAS, .post_bind = wdt_post_bind, + .pre_probe = wdt_pre_probe, + .per_device_auto = sizeof(struct wdt_priv), };
The addition of .pre_probe and .per_device_auto made this look bad. Fix it.
Reviewed-by: Simon Glass sjg@chromium.org Reviewed-by: Stefan Roese sr@denx.de Signed-off-by: Rasmus Villemoes rasmus.villemoes@prevas.dk --- drivers/watchdog/wdt-uclass.c | 8 ++++---- 1 file changed, 4 insertions(+), 4 deletions(-)
diff --git a/drivers/watchdog/wdt-uclass.c b/drivers/watchdog/wdt-uclass.c index b29d214724..81287c759a 100644 --- a/drivers/watchdog/wdt-uclass.c +++ b/drivers/watchdog/wdt-uclass.c @@ -210,10 +210,10 @@ static int wdt_pre_probe(struct udevice *dev) }
UCLASS_DRIVER(wdt) = { - .id = UCLASS_WDT, - .name = "watchdog", - .flags = DM_UC_FLAG_SEQ_ALIAS, - .post_bind = wdt_post_bind, + .id = UCLASS_WDT, + .name = "watchdog", + .flags = DM_UC_FLAG_SEQ_ALIAS, + .post_bind = wdt_post_bind, .pre_probe = wdt_pre_probe, .per_device_auto = sizeof(struct wdt_priv), };
In preparation for handling all DM watchdogs in watchdog_reset(), pull out the code which handles starting (or not) the gd->watchdog_dev device.
Include the device name in various printfs.
Reviewed-by: Simon Glass sjg@chromium.org Reviewed-by: Stefan Roese sr@denx.de Signed-off-by: Rasmus Villemoes rasmus.villemoes@prevas.dk --- drivers/watchdog/wdt-uclass.c | 37 ++++++++++++++++++++--------------- 1 file changed, 21 insertions(+), 16 deletions(-)
diff --git a/drivers/watchdog/wdt-uclass.c b/drivers/watchdog/wdt-uclass.c index 81287c759a..0a1f43771c 100644 --- a/drivers/watchdog/wdt-uclass.c +++ b/drivers/watchdog/wdt-uclass.c @@ -35,11 +35,30 @@ struct wdt_priv { ulong next_reset; };
-int initr_watchdog(void) +static void init_watchdog_dev(struct udevice *dev) { struct wdt_priv *priv; int ret;
+ priv = dev_get_uclass_priv(dev); + + if (!IS_ENABLED(CONFIG_WATCHDOG_AUTOSTART)) { + printf("WDT: Not starting %s\n", dev->name); + return; + } + + ret = wdt_start(dev, priv->timeout * 1000, 0); + if (ret != 0) { + printf("WDT: Failed to start %s\n", dev->name); + return; + } + + printf("WDT: Started %s with%s servicing (%ds timeout)\n", dev->name, + IS_ENABLED(CONFIG_WATCHDOG) ? "" : "out", priv->timeout); +} + +int initr_watchdog(void) +{ /* * Init watchdog: This will call the probe function of the * watchdog driver, enabling the use of the device @@ -53,21 +72,7 @@ int initr_watchdog(void) return 0; } } - priv = dev_get_uclass_priv(gd->watchdog_dev); - - if (!IS_ENABLED(CONFIG_WATCHDOG_AUTOSTART)) { - printf("WDT: Not starting\n"); - return 0; - } - - ret = wdt_start(gd->watchdog_dev, priv->timeout * 1000, 0); - if (ret != 0) { - printf("WDT: Failed to start\n"); - return 0; - } - - printf("WDT: Started with%s servicing (%ds timeout)\n", - IS_ENABLED(CONFIG_WATCHDOG) ? "" : "out", priv->timeout); + init_watchdog_dev(gd->watchdog_dev);
return 0; }
As a step towards handling all DM watchdogs in watchdog_reset(), use a per-device flag to keep track of whether the device has been started instead of a bit in gd->flags.
We will still need that bit to know whether we are past initr_watchdog() and hence have populated gd->watchdog_dev - incidentally, that is how it was used prior to commit 9c44ff1c5f3c.
Reviewed-by: Simon Glass sjg@chromium.org Reviewed-by: Stefan Roese sr@denx.de Signed-off-by: Rasmus Villemoes rasmus.villemoes@prevas.dk --- drivers/watchdog/wdt-uclass.c | 20 ++++++++++++++++---- 1 file changed, 16 insertions(+), 4 deletions(-)
diff --git a/drivers/watchdog/wdt-uclass.c b/drivers/watchdog/wdt-uclass.c index 0a1f43771c..358fc68e27 100644 --- a/drivers/watchdog/wdt-uclass.c +++ b/drivers/watchdog/wdt-uclass.c @@ -33,6 +33,8 @@ struct wdt_priv { * ->reset(). */ ulong next_reset; + /* Whether watchdog_start() has been called on the device. */ + bool running; };
static void init_watchdog_dev(struct udevice *dev) @@ -74,6 +76,7 @@ int initr_watchdog(void) } init_watchdog_dev(gd->watchdog_dev);
+ gd->flags |= GD_FLG_WDT_READY; return 0; }
@@ -86,8 +89,11 @@ int wdt_start(struct udevice *dev, u64 timeout_ms, ulong flags) return -ENOSYS;
ret = ops->start(dev, timeout_ms, flags); - if (ret == 0) - gd->flags |= GD_FLG_WDT_READY; + if (ret == 0) { + struct wdt_priv *priv = dev_get_uclass_priv(dev); + + priv->running = true; + }
return ret; } @@ -101,8 +107,11 @@ int wdt_stop(struct udevice *dev) return -ENOSYS;
ret = ops->stop(dev); - if (ret == 0) - gd->flags &= ~GD_FLG_WDT_READY; + if (ret == 0) { + struct wdt_priv *priv = dev_get_uclass_priv(dev); + + priv->running = false; + }
return ret; } @@ -156,6 +165,9 @@ void watchdog_reset(void)
dev = gd->watchdog_dev; priv = dev_get_uclass_priv(dev); + if (!priv->running) + return; + /* Do not reset the watchdog too often */ now = get_timer(0); if (time_after_eq(now, priv->next_reset)) {
Dear Rasmus,
please check your patches for proper error handling.
- if (ret == 0)
- if (ret == 0) {
dev_get_uclass_priv() can return NULL, in which case you would be dereferencing a NULL pointer...
- if (ret == 0)
- if (ret == 0) {
Same here.
- if (!priv->running)
return;
And here again.
For the unit tests, it is more convenient if the tests are in charge of when the watchdog devices are started and stopped, so prevent wdt-uclass from doing it automatically.
Reviewed-by: Simon Glass sjg@chromium.org Reviewed-by: Stefan Roese sr@denx.de Signed-off-by: Rasmus Villemoes rasmus.villemoes@prevas.dk --- configs/sandbox64_defconfig | 1 + configs/sandbox_defconfig | 1 + 2 files changed, 2 insertions(+)
diff --git a/configs/sandbox64_defconfig b/configs/sandbox64_defconfig index f7098b4969..3627a066b4 100644 --- a/configs/sandbox64_defconfig +++ b/configs/sandbox64_defconfig @@ -223,6 +223,7 @@ CONFIG_OSD=y CONFIG_SANDBOX_OSD=y CONFIG_SPLASH_SCREEN_ALIGN=y CONFIG_VIDEO_BMP_RLE8=y +# CONFIG_WATCHDOG_AUTOSTART is not set CONFIG_WDT=y CONFIG_WDT_SANDBOX=y CONFIG_FS_CBFS=y diff --git a/configs/sandbox_defconfig b/configs/sandbox_defconfig index bcd82f76ff..34b749b47b 100644 --- a/configs/sandbox_defconfig +++ b/configs/sandbox_defconfig @@ -282,6 +282,7 @@ CONFIG_W1=y CONFIG_W1_GPIO=y CONFIG_W1_EEPROM=y CONFIG_W1_EEPROM_SANDBOX=y +# CONFIG_WATCHDOG_AUTOSTART is not set CONFIG_WDT=y CONFIG_WDT_SANDBOX=y CONFIG_FS_CBFS=y
Since the watchdog_dev member of struct global_data is going away in favor of the wdt-uclass handling all watchdog devices, prepare for that by adding a helper to call wdt_stop() on all known devices.
If an error is encountered, still do wdt_stop() on remaining devices, but remember and return the first error seen.
Initially, this will only be used in one single place (board/alliedtelesis/x530/x530.c).
Signed-off-by: Rasmus Villemoes rasmus.villemoes@prevas.dk --- drivers/watchdog/wdt-uclass.c | 25 +++++++++++++++++++++++++ include/wdt.h | 8 ++++++++ 2 files changed, 33 insertions(+)
diff --git a/drivers/watchdog/wdt-uclass.c b/drivers/watchdog/wdt-uclass.c index 358fc68e27..5b1c0df5d6 100644 --- a/drivers/watchdog/wdt-uclass.c +++ b/drivers/watchdog/wdt-uclass.c @@ -116,6 +116,31 @@ int wdt_stop(struct udevice *dev) return ret; }
+int wdt_stop_all(void) +{ + struct wdt_priv *priv; + struct udevice *dev; + struct uclass *uc; + int ret, err; + + ret = uclass_get(UCLASS_WDT, &uc); + if (ret) + return ret; + + uclass_foreach_dev(dev, uc) { + if (!device_active(dev)) + continue; + priv = dev_get_uclass_priv(dev); + if (!priv->running) + continue; + err = wdt_stop(dev); + if (!ret) + ret = err; + } + + return ret; +} + int wdt_reset(struct udevice *dev) { const struct wdt_ops *ops = device_get_ops(dev); diff --git a/include/wdt.h b/include/wdt.h index bc242c2eb2..baaa9db08a 100644 --- a/include/wdt.h +++ b/include/wdt.h @@ -37,6 +37,14 @@ int wdt_start(struct udevice *dev, u64 timeout_ms, ulong flags); */ int wdt_stop(struct udevice *dev);
+/* + * Stop all registered watchdog devices. + * + * @return: 0 if ok, first error encountered otherwise (but wdt_stop() + * is still called on following devices) + */ +int wdt_stop_all(void); + /* * Reset the timer, typically restoring the counter to * the value configured by start()
Dear Rasmus,
again: error handling.
- struct wdt_priv *priv;
- struct udevice *dev;
- struct uclass *uc;
- int ret, err;
- ret = uclass_get(UCLASS_WDT, &uc);
- if (ret)
return ret;
- uclass_foreach_dev(dev, uc) {
continue;
if (!priv->running)
continue;
Potential NULL pointer dereferencing.
Since the gd->watchdog_dev member is going away, switch to using the new wdt_stop_all() helper.
While here, clean up the preprocessor conditional: The ->watchdog_dev member is actually guarded by CONFIG_WDT [disabling that in x530_defconfig while keeping CONFIG_WATCHDOG breaks the build], and in the new world order so is the existence of the wdt_stop_all() function.
Actually, existence of wdt_stop_all() depends on CONFIG_${SPL_}WDT, so really spell the condition using CONFIG_IS_ENABLED, and make it a C rather than cpp if.
Signed-off-by: Rasmus Villemoes rasmus.villemoes@prevas.dk --- board/alliedtelesis/x530/x530.c | 5 ++--- 1 file changed, 2 insertions(+), 3 deletions(-)
diff --git a/board/alliedtelesis/x530/x530.c b/board/alliedtelesis/x530/x530.c index 7bcfa828d7..8b31045a07 100644 --- a/board/alliedtelesis/x530/x530.c +++ b/board/alliedtelesis/x530/x530.c @@ -121,9 +121,8 @@ int board_init(void)
void arch_preboot_os(void) { -#ifdef CONFIG_WATCHDOG - wdt_stop(gd->watchdog_dev); -#endif + if (CONFIG_IS_ENABLED(WDT)) + wdt_stop_all(); }
static int led_7seg_init(unsigned int segments)
A board can have and make use of more than one watchdog device, say one built into the SOC and an external gpio-petted one. Having wdt-uclass only handle the first is both a little arbitrary and unexpected.
So change initr_watchdog() so we visit (probe) all DM watchdog devices, and call the init_watchdog_dev helper for each.
Similarly let watchdog_reset() loop over the whole uclass - each having their own ratelimiting metadata, and a separate "is this device running" flag.
This gets rid of the watchdog_dev member of struct global_data. We do, however, still need the GD_FLG_WDT_READY set in initr_watchdog(). This is because watchdog_reset() can get called before DM is ready, and I don't think we can call uclass_get() that early.
The current code just returns 0 if "getting" the first device fails - that can of course happen because there are no devices, but it could also happen if its ->probe call failed. In keeping with that, continue with the handling of the remaining devices even if one fails to probe. This is also why we cannot use uclass_probe_all().
If desired, it's possible to later add a per-device "u-boot,autostart" boolean property, so that one can do CONFIG_WATCHDOG_AUTOSTART per-device.
Reviewed-by: Simon Glass sjg@chromium.org Reviewed-by: Stefan Roese sr@denx.de Signed-off-by: Rasmus Villemoes rasmus.villemoes@prevas.dk --- drivers/watchdog/wdt-uclass.c | 56 ++++++++++++++++++++----------- include/asm-generic/global_data.h | 6 ---- 2 files changed, 36 insertions(+), 26 deletions(-)
diff --git a/drivers/watchdog/wdt-uclass.c b/drivers/watchdog/wdt-uclass.c index 5b1c0df5d6..7570710c4d 100644 --- a/drivers/watchdog/wdt-uclass.c +++ b/drivers/watchdog/wdt-uclass.c @@ -61,20 +61,24 @@ static void init_watchdog_dev(struct udevice *dev)
int initr_watchdog(void) { - /* - * Init watchdog: This will call the probe function of the - * watchdog driver, enabling the use of the device - */ - if (uclass_get_device_by_seq(UCLASS_WDT, 0, - (struct udevice **)&gd->watchdog_dev)) { - debug("WDT: Not found by seq!\n"); - if (uclass_get_device(UCLASS_WDT, 0, - (struct udevice **)&gd->watchdog_dev)) { - printf("WDT: Not found!\n"); - return 0; + struct udevice *dev; + struct uclass *uc; + int ret; + + ret = uclass_get(UCLASS_WDT, &uc); + if (ret) { + log_debug("Error getting UCLASS_WDT: %d\n", ret); + return 0; + } + + uclass_foreach_dev(dev, uc) { + ret = device_probe(dev); + if (ret) { + log_debug("Error probing %s: %d\n", dev->name, ret); + continue; } + init_watchdog_dev(dev); } - init_watchdog_dev(gd->watchdog_dev);
gd->flags |= GD_FLG_WDT_READY; return 0; @@ -182,22 +186,34 @@ void watchdog_reset(void) { struct wdt_priv *priv; struct udevice *dev; + struct uclass *uc; ulong now;
- dev = gd->watchdog_dev; - priv = dev_get_uclass_priv(dev); - if (!priv->running) + if (uclass_get(UCLASS_WDT, &uc)) return;
- /* Do not reset the watchdog too often */ - now = get_timer(0); - if (time_after_eq(now, priv->next_reset)) { - priv->next_reset = now + priv->reset_period; - wdt_reset(dev); + /* + * All devices bound to the wdt uclass should have been probed + * in initr_watchdog(). But just in case something went wrong, + * check device_active() before accessing the uclass private + * data. + */ + uclass_foreach_dev(dev, uc) { + if (!device_active(dev)) + continue; + priv = dev_get_uclass_priv(dev); + if (!priv->running) + continue; + /* Do not reset the watchdog too often */ + now = get_timer(0); + if (time_after_eq(now, priv->next_reset)) { + priv->next_reset = now + priv->reset_period; + wdt_reset(dev); + } } } #endif diff --git a/include/asm-generic/global_data.h b/include/asm-generic/global_data.h index e55070303f..28d749538c 100644 --- a/include/asm-generic/global_data.h +++ b/include/asm-generic/global_data.h @@ -447,12 +447,6 @@ struct global_data { */ fdt_addr_t translation_offset; #endif -#if CONFIG_IS_ENABLED(WDT) - /** - * @watchdog_dev: watchdog device - */ - struct udevice *watchdog_dev; -#endif #ifdef CONFIG_GENERATE_ACPI_TABLE /** * @acpi_ctx: ACPI context pointer
Dear Rasmus,
- if (ret) {
if (ret) {
}continue;
As discussed - errors need to be shown to the user, and not only in images with debugging enabled.
- if (uclass_get(UCLASS_WDT, &uc)) return;
Do I see this crrectly that you remove here the code which you just added in patch 02 of this series?
Why not doing it right from the beginning?
continue;
if (!priv->running)
continue;
Potential NULL pointer dereference.
A rather common kind of external watchdog circuit is one that is kept alive by toggling a gpio. Add a driver for handling such a watchdog.
The corresponding linux driver apparently has support for some watchdog circuits which can be disabled by tri-stating the gpio, but I have never actually encountered such a chip in the wild; the whole point of adding an external watchdog is usually that it is not in any way under software control. For forward-compatibility, and to make DT describe the hardware, the current driver only supports devices that have the always-running property. I went a little back and forth on whether I should fail ->probe or only ->start, and ended up deciding ->start was the right place.
The compatible string is probably a little odd as it has nothing to do with linux per se - however, I chose that to make .dts snippets reusable between device trees used with U-Boot and linux, and this is the (only) compatible string that linux' corresponding driver and DT binding accepts. I have asked whether one should/could add "wdt-gpio" to that binding, but the answer was no:
https://lore.kernel.org/lkml/CAL_JsqKEGaFpiFV_oAtE+S_bnHkg4qry+bhx2EDs=NSbVf...
If someone feels strongly about this, I can certainly remove the "linux," part from the string - it probably wouldn't the only place where one can't reuse a DT snippet as-is between linux and U-Boot.
Reviewed-by: Simon Glass sjg@chromium.org Reviewed-by: Stefan Roese sr@denx.de Signed-off-by: Rasmus Villemoes rasmus.villemoes@prevas.dk --- .../watchdog/gpio-wdt.txt | 19 ++++++ drivers/watchdog/Kconfig | 9 +++ drivers/watchdog/Makefile | 1 + drivers/watchdog/gpio_wdt.c | 68 +++++++++++++++++++ 4 files changed, 97 insertions(+) create mode 100644 doc/device-tree-bindings/watchdog/gpio-wdt.txt create mode 100644 drivers/watchdog/gpio_wdt.c
diff --git a/doc/device-tree-bindings/watchdog/gpio-wdt.txt b/doc/device-tree-bindings/watchdog/gpio-wdt.txt new file mode 100644 index 0000000000..c9a8559a3e --- /dev/null +++ b/doc/device-tree-bindings/watchdog/gpio-wdt.txt @@ -0,0 +1,19 @@ +GPIO watchdog timer + +Describes a simple watchdog timer which is reset by toggling a gpio. + +Required properties: + +- compatible: Must be "linux,wdt-gpio". +- gpios: gpio to toggle when wdt driver reset method is called. +- always-running: Boolean property indicating that the watchdog cannot + be disabled. At present, U-Boot only supports this kind of GPIO + watchdog. + +Example: + + gpio-wdt { + gpios = <&gpio0 1 0>; + compatible = "linux,wdt-gpio"; + always-running; + }; diff --git a/drivers/watchdog/Kconfig b/drivers/watchdog/Kconfig index f0ff2612a6..6fbb5c1b6d 100644 --- a/drivers/watchdog/Kconfig +++ b/drivers/watchdog/Kconfig @@ -147,6 +147,15 @@ config WDT_CORTINA This driver support all CPU ISAs supported by Cortina Access CAxxxx SoCs.
+config WDT_GPIO + bool "External gpio watchdog support" + depends on WDT + depends on DM_GPIO + help + Support for external watchdog fed by toggling a gpio. See + doc/device-tree-bindings/watchdog/gpio-wdt.txt for + information on how to describe the watchdog in device tree. + config WDT_MPC8xx bool "MPC8xx watchdog timer support" depends on WDT && MPC8xx diff --git a/drivers/watchdog/Makefile b/drivers/watchdog/Makefile index 5c7ef593fe..f14415bb8e 100644 --- a/drivers/watchdog/Makefile +++ b/drivers/watchdog/Makefile @@ -25,6 +25,7 @@ obj-$(CONFIG_WDT_BOOKE) += booke_wdt.o obj-$(CONFIG_WDT_CORTINA) += cortina_wdt.o obj-$(CONFIG_WDT_ORION) += orion_wdt.o obj-$(CONFIG_WDT_CDNS) += cdns_wdt.o +obj-$(CONFIG_WDT_GPIO) += gpio_wdt.o obj-$(CONFIG_WDT_MPC8xx) += mpc8xx_wdt.o obj-$(CONFIG_WDT_MT7620) += mt7620_wdt.o obj-$(CONFIG_WDT_MT7621) += mt7621_wdt.o diff --git a/drivers/watchdog/gpio_wdt.c b/drivers/watchdog/gpio_wdt.c new file mode 100644 index 0000000000..982a66b3f9 --- /dev/null +++ b/drivers/watchdog/gpio_wdt.c @@ -0,0 +1,68 @@ +// SPDX-License-Identifier: GPL-2.0+ + +#include <dm.h> +#include <dm/device_compat.h> +#include <wdt.h> +#include <asm/gpio.h> + +struct gpio_wdt_priv { + struct gpio_desc gpio; + bool always_running; + int state; +}; + +static int gpio_wdt_reset(struct udevice *dev) +{ + struct gpio_wdt_priv *priv = dev_get_priv(dev); + + priv->state = !priv->state; + + return dm_gpio_set_value(&priv->gpio, priv->state); +} + +static int gpio_wdt_start(struct udevice *dev, u64 timeout, ulong flags) +{ + struct gpio_wdt_priv *priv = dev_get_priv(dev); + + if (priv->always_running) + return 0; + + return -ENOSYS; +} + +static int dm_probe(struct udevice *dev) +{ + struct gpio_wdt_priv *priv = dev_get_priv(dev); + int ret; + + priv->always_running = dev_read_bool(dev, "always-running"); + ret = gpio_request_by_name(dev, "gpios", 0, &priv->gpio, GPIOD_IS_OUT); + if (ret < 0) { + dev_err(dev, "Request for wdt gpio failed: %d\n", ret); + return ret; + } + + if (priv->always_running) + ret = gpio_wdt_reset(dev); + + return ret; +} + +static const struct wdt_ops gpio_wdt_ops = { + .start = gpio_wdt_start, + .reset = gpio_wdt_reset, +}; + +static const struct udevice_id gpio_wdt_ids[] = { + { .compatible = "linux,wdt-gpio" }, + {} +}; + +U_BOOT_DRIVER(wdt_gpio) = { + .name = "wdt_gpio", + .id = UCLASS_WDT, + .of_match = gpio_wdt_ids, + .ops = &gpio_wdt_ops, + .probe = dm_probe, + .priv_auto = sizeof(struct gpio_wdt_priv), +};
Dear Rasmus,
- struct gpio_desc gpio;
- bool always_running;
- int state;
- struct gpio_wdt_priv *priv = dev_get_priv(dev);
- priv->state = !priv->state;
- if (priv->always_running)
Ditto.
- int ret;
- priv->always_running = dev_read_bool(dev, "always-running");
Ditto.
- ret = gpio_request_by_name(dev, "gpios", 0, &priv->gpio, GPIOD_IS_OUT);
- if (ret < 0) {
return ret;
Ditto.
On 19/08/2021 13.46, Wolfgang Denk wrote:
Dear Rasmus,
- int state;
No, no and no. If allocation of the (driver or uclass) private data fails, the device probe would have failed, so this code can never get called with such a struct udevice.
Perhaps try doing a
git grep -10 -E 'dev_get(_uclass)?_priv'
and see how many cases you can find where that is followed by a NULL check?
Rasmus
Dear Rasmus,
Famous last words...
Perhaps try doing a
The existence of bad code is not a justification to add more of it.
On Thu, Aug 19, 2021 at 02:32:01PM +0200, Wolfgang Denk wrote:
Dear Rasmus,
Perhaps try doing a
Since I literally just sent this in another email you couldn't have seen yet, I'll repeat it here. Feel free to follow up to this with a series to further update things, Wolfgang.
Dear Tom,
So we have now a policy to wave through code, and ask others to clean it up later? That's ... sad.
On Thu, Aug 19, 2021 at 03:03:46PM +0200, Wolfgang Denk wrote:
Dear Tom,
No, we continue to have the policy of expecting reviewers to follow the whole discussion and relevant subsystems. Changing _every_ caller of dev_get_priv to check for NULL and then, what? is clearly not the right answer. If you think you see a problem here please go audit the DM code itself more and propose some changes.
Dear Tom,
Once upon a time there has also been a policy that if a function might return error codes, these need to be checked and handled.
Then what is the right answer in your opinion?
I mean, look at the implementation of dev_get_priv():
628 void *dev_get_priv(const struct udevice *dev) 629 { 630 if (!dev) { 631 dm_warn("%s: null device\n", __func__); 632 return NULL; 633 } 634 635 return dm_priv_to_rw(dev->priv_); 636 }
If there is guaranteed no way that dev_get_priv() can return a NULL pointer, that means that it must be guaranteed that the "dev" argument can never be a NULL pointer, either. So why do we check it at all?
The same applies for all functions in "drivers/core/device.c" - they all check for valid input parameters, like any code should do.
I can see that the DM code itself implements proper error checking and reporting; it's the callers where negligent code prevails.
If you are consequent, you must decide what you want:
- Either we want robust and reliable code - then we have to handle the error codes which functions like dev_get_priv() etc. return.
- Or you don't care about software quality, then we can omit such handling, but then it would also be consequent to remove all the error checking from "drivers/core/device.c" etc. - hey, that would even save a few hundred bytes of code size.
Sugarcoating code which fails to handle error codes because "these errors can never happen" does not seem to be a clever approach to software engineering to me.
I stop here. You know my opinion. You are the maintainer.
On Thu, 19 Aug 2021 at 08:16, Wolfgang Denk wd@denx.de wrote:
Dear Tom,
Note that we should not check these calls, as the priv data is allocated by driver model and a device cannot be probed until it gets past this step.
I know that sometimes people add this check, but whenever I see it I ask them to remove it. It is pointless and confusing, since it suggests that driver model may not have allocated it yet. This sort of confusion can really make things hard to understand for new people.
If a device is probed, you can rely on the priv data being set up. The only way to access a probed device is via the device-internal.h or uclass-internal.h APIs. Be careful with those if you must use them.
I think did a series on this many years ago - a way to turn on checks for this and that the right struct is obtained when you call dev_get_priv(), etc. We could certainly add this with a CONFIG option for debugging purposes. The runtime cost is actually not terrible but it does require collusion with malloc() to be efficient.
There is a wider issue here about arrg checking. We sometimes use assert but at present that only appears in the code if DEBUG is enabled. Also it just halts.
OTOH if we add arg checking everywhere it cluttles the code and can substantially increase the size (I know of a project where it doubled the size). I like to distinguish between:
- programming errors - security errors where user input is insufficiently checked
IMO the former should not be present if you have sufficient tests and trying to catch them in the field at runtime is not very kind to your users.
Dear Simon,
In message CAPnjgZ0aVwo2mq9BNw-9xz+xPZVm6Negf9sQxnTAr9GHTTxPxQ@mail.gmail.com you wrote:
Wow.
I think I'll add this to my signature database:
| "Trying to catch [programming errors] in the field at runtime is not | very kind to your users." | | - Simon Glass in CAPnjgZ0aVwo2mq9BNw-9xz+xPZVm6Negf9sQxnTAr9GHTTxPxQ@mail.gmail.com
Hi Wolfgang,
On Thu, 19 Aug 2021 at 08:58, Wolfgang Denk wd@denx.de wrote:
Dear Simon,
Wow.
Well you've taken it out of context :-) It would make more sense if you mention the need for tests
Dear Simon,
In message CAPnjgZ3-k4sGn0G-7tiGixsBxT77s9bDNXeTf-86Fj18oWSaaQ@mail.gmail.com you wrote:
Wow.
Testing can show the presense of bugs, but not their absence. -- Edsger Dijkstr
Hi Wolfgang,
On Mon, 23 Aug 2021 at 05:07, Wolfgang Denk wd@denx.de wrote:
Dear Simon,
Wow.
Indeed, although that is really just a truism. If this were a philosophy channel and I had actually studied it properly, I would go on about evidence of absence at this point.
From a s/w POV, there is always one more bug.
Regards, SImon
Obviously true and I agree.
However, it is at the same time completely irrelevant in this context, because the pattern of using the return value of dev_get_priv() without a NULL check is neither bad or wrong, as has now been explained to you several times.
If you really think checking the return value of dev_get_priv() must be done religiously, perhaps you could tap Stefan (737c3de09984), Marek (7e1f1e16fe75), or Heiko (6e31c62a175c) on the shoulder and tell them to stop cranking out "bad" code.
There's another logical fallacy right here. Sure, you've found an input value for which dev_get_priv() would return NULL. But any caller who knows they're not passing a NULL dev also know they won't follow that code path.
A driver which doesn't populate the priv field by via a non-zero .priv_auto field may need to check the return value of dev_get_priv(). I'm not claiming that checking that is always redundant. However, neither is it anywhere near true that checking is always required.
Rasmus
Hi Rasmus,
On Fri, 20 Aug 2021 at 00:22, Rasmus Villemoes rasmus.villemoes@prevas.dk wrote:
Just on this point, drivers should use the priv pointer without priv_auto. If we do introduce run-time checks, it would fail with those.
It seems that no other test has claimed gpio_a:7 yet, so use that.
The only small wrinkle is modifying the existing wdt test to use uclass_get_device_by_driver() since we now have two UCLASS_WDT instances in play, so it's a little more robust to fetch the device by driver and not merely uclass+index.
Reviewed-by: Simon Glass sjg@chromium.org Reviewed-by: Stefan Roese sr@denx.de Signed-off-by: Rasmus Villemoes rasmus.villemoes@prevas.dk --- arch/sandbox/dts/test.dts | 6 ++++++ configs/sandbox64_defconfig | 1 + configs/sandbox_defconfig | 1 + test/dm/wdt.c | 36 +++++++++++++++++++++++++++++++++++- 4 files changed, 43 insertions(+), 1 deletion(-)
diff --git a/arch/sandbox/dts/test.dts b/arch/sandbox/dts/test.dts index d5976318d1..fe5ac6ecd9 100644 --- a/arch/sandbox/dts/test.dts +++ b/arch/sandbox/dts/test.dts @@ -779,6 +779,12 @@ }; };
+ gpio-wdt { + gpios = <&gpio_a 7 0>; + compatible = "linux,wdt-gpio"; + always-running; + }; + mbox: mbox { compatible = "sandbox,mbox"; #mbox-cells = <1>; diff --git a/configs/sandbox64_defconfig b/configs/sandbox64_defconfig index 3627a066b4..6cad90b03e 100644 --- a/configs/sandbox64_defconfig +++ b/configs/sandbox64_defconfig @@ -225,6 +225,7 @@ CONFIG_SPLASH_SCREEN_ALIGN=y CONFIG_VIDEO_BMP_RLE8=y # CONFIG_WATCHDOG_AUTOSTART is not set CONFIG_WDT=y +CONFIG_WDT_GPIO=y CONFIG_WDT_SANDBOX=y CONFIG_FS_CBFS=y CONFIG_FS_CRAMFS=y diff --git a/configs/sandbox_defconfig b/configs/sandbox_defconfig index 34b749b47b..4a8b4f220d 100644 --- a/configs/sandbox_defconfig +++ b/configs/sandbox_defconfig @@ -284,6 +284,7 @@ CONFIG_W1_EEPROM=y CONFIG_W1_EEPROM_SANDBOX=y # CONFIG_WATCHDOG_AUTOSTART is not set CONFIG_WDT=y +CONFIG_WDT_GPIO=y CONFIG_WDT_SANDBOX=y CONFIG_FS_CBFS=y CONFIG_FS_CRAMFS=y diff --git a/test/dm/wdt.c b/test/dm/wdt.c index 24b991dff6..abff853a02 100644 --- a/test/dm/wdt.c +++ b/test/dm/wdt.c @@ -6,6 +6,7 @@ #include <common.h> #include <dm.h> #include <wdt.h> +#include <asm/gpio.h> #include <asm/state.h> #include <asm/test.h> #include <dm/test.h> @@ -19,7 +20,8 @@ static int dm_test_wdt_base(struct unit_test_state *uts) struct udevice *dev; const u64 timeout = 42;
- ut_assertok(uclass_get_device(UCLASS_WDT, 0, &dev)); + ut_assertok(uclass_get_device_by_driver(UCLASS_WDT, + DM_DRIVER_GET(wdt_sandbox), &dev)); ut_assertnonnull(dev); ut_asserteq(0, state->wdt.counter); ut_asserteq(false, state->wdt.running); @@ -39,3 +41,35 @@ static int dm_test_wdt_base(struct unit_test_state *uts) return 0; } DM_TEST(dm_test_wdt_base, UT_TESTF_SCAN_PDATA | UT_TESTF_SCAN_FDT); + +static int dm_test_wdt_gpio(struct unit_test_state *uts) +{ + /* + * The sandbox wdt gpio is "connected" to gpio bank a, offset + * 7. Use the sandbox back door to verify that the gpio-wdt + * driver behaves as expected. + */ + struct udevice *wdt, *gpio; + const u64 timeout = 42; + const int offset = 7; + int val; + + ut_assertok(uclass_get_device_by_driver(UCLASS_WDT, + DM_DRIVER_GET(wdt_gpio), &wdt)); + ut_assertnonnull(wdt); + + ut_assertok(uclass_get_device_by_name(UCLASS_GPIO, "base-gpios", &gpio)); + ut_assertnonnull(gpio); + ut_assertok(wdt_start(wdt, timeout, 0)); + + val = sandbox_gpio_get_value(gpio, offset); + ut_assertok(wdt_reset(wdt)); + ut_asserteq(!val, sandbox_gpio_get_value(gpio, offset)); + ut_assertok(wdt_reset(wdt)); + ut_asserteq(val, sandbox_gpio_get_value(gpio, offset)); + + ut_asserteq(-ENOSYS, wdt_stop(wdt)); + + return 0; +} +DM_TEST(dm_test_wdt_gpio, UT_TESTF_SCAN_FDT);
Check that the watchdog_reset() implementation in wdt-uclass behaves as expected:
- resets all activated watchdog devices - leaves unactivated/stopped devices alone - that the rate-limiting works, with a per-device threshold
Reviewed-by: Simon Glass sjg@chromium.org Reviewed-by: Stefan Roese sr@denx.de Signed-off-by: Rasmus Villemoes rasmus.villemoes@prevas.dk --- arch/sandbox/dts/test.dts | 2 ++ test/dm/wdt.c | 54 +++++++++++++++++++++++++++++++++++++++ 2 files changed, 56 insertions(+)
diff --git a/arch/sandbox/dts/test.dts b/arch/sandbox/dts/test.dts index fe5ac6ecd9..bafc2e9494 100644 --- a/arch/sandbox/dts/test.dts +++ b/arch/sandbox/dts/test.dts @@ -782,6 +782,7 @@ gpio-wdt { gpios = <&gpio_a 7 0>; compatible = "linux,wdt-gpio"; + hw_margin_ms = <100>; always-running; };
@@ -1264,6 +1265,7 @@
wdt0: wdt@0 { compatible = "sandbox,wdt"; + hw_margin_ms = <200>; };
axi: axi@0 { diff --git a/test/dm/wdt.c b/test/dm/wdt.c index abff853a02..ee615f0e14 100644 --- a/test/dm/wdt.c +++ b/test/dm/wdt.c @@ -12,6 +12,8 @@ #include <dm/test.h> #include <test/test.h> #include <test/ut.h> +#include <linux/delay.h> +#include <watchdog.h>
/* Test that watchdog driver functions are called */ static int dm_test_wdt_base(struct unit_test_state *uts) @@ -73,3 +75,55 @@ static int dm_test_wdt_gpio(struct unit_test_state *uts) return 0; } DM_TEST(dm_test_wdt_gpio, UT_TESTF_SCAN_FDT); + +static int dm_test_wdt_watchdog_reset(struct unit_test_state *uts) +{ + struct sandbox_state *state = state_get_current(); + struct udevice *gpio_wdt, *sandbox_wdt; + struct udevice *gpio; + const u64 timeout = 42; + const int offset = 7; + uint reset_count; + int val; + + ut_assertok(uclass_get_device_by_driver(UCLASS_WDT, + DM_DRIVER_GET(wdt_gpio), &gpio_wdt)); + ut_assertnonnull(gpio_wdt); + ut_assertok(uclass_get_device_by_driver(UCLASS_WDT, + DM_DRIVER_GET(wdt_sandbox), &sandbox_wdt)); + ut_assertnonnull(sandbox_wdt); + ut_assertok(uclass_get_device_by_name(UCLASS_GPIO, "base-gpios", &gpio)); + ut_assertnonnull(gpio); + + /* Neither device should be "started", so watchdog_reset() should be a no-op. */ + reset_count = state->wdt.reset_count; + val = sandbox_gpio_get_value(gpio, offset); + watchdog_reset(); + ut_asserteq(reset_count, state->wdt.reset_count); + ut_asserteq(val, sandbox_gpio_get_value(gpio, offset)); + + /* Start both devices. */ + ut_assertok(wdt_start(gpio_wdt, timeout, 0)); + ut_assertok(wdt_start(sandbox_wdt, timeout, 0)); + + /* Make sure both devices have just been pinged. */ + timer_test_add_offset(100); + watchdog_reset(); + reset_count = state->wdt.reset_count; + val = sandbox_gpio_get_value(gpio, offset); + + /* The gpio watchdog should be pinged, the sandbox one not. */ + timer_test_add_offset(30); + watchdog_reset(); + ut_asserteq(reset_count, state->wdt.reset_count); + ut_asserteq(!val, sandbox_gpio_get_value(gpio, offset)); + + /* After another ~30ms, both devices should get pinged. */ + timer_test_add_offset(30); + watchdog_reset(); + ut_asserteq(reset_count + 1, state->wdt.reset_count); + ut_asserteq(val, sandbox_gpio_get_value(gpio, offset)); + + return 0; +} +DM_TEST(dm_test_wdt_watchdog_reset, UT_TESTF_SCAN_FDT);
Hi Rasmus,
I've pulled this patchset now into next [1] and have run it through CI via Azure. Here an error occurs:
https://dev.azure.com/sr0718/u-boot/_build/results?buildId=109&view=logs...
Could you please take a look at this?
Thanks, Stefan
[1] https://source.denx.de/u-boot/custodians/u-boot-marvell/-/commits/next
always-running; };hw_margin_ms = <100>;
axi: axi@0 {
- struct sandbox_state *state = state_get_current();
- struct udevice *gpio_wdt, *sandbox_wdt;
- struct udevice *gpio;
- const u64 timeout = 42;
- const int offset = 7;
- uint reset_count;
- int val;
- ut_assertok(uclass_get_device_by_driver(UCLASS_WDT,
- ut_assertnonnull(gpio_wdt);
- ut_assertnonnull(sandbox_wdt);
- ut_assertok(uclass_get_device_by_name(UCLASS_GPIO, "base-gpios", &gpio));
- ut_assertnonnull(gpio);
- /* Neither device should be "started", so watchdog_reset() should be a no-op. */
- reset_count = state->wdt.reset_count;
- val = sandbox_gpio_get_value(gpio, offset);
- watchdog_reset();
- ut_asserteq(reset_count, state->wdt.reset_count);
- ut_asserteq(val, sandbox_gpio_get_value(gpio, offset));
- /* Start both devices. */
- ut_assertok(wdt_start(gpio_wdt, timeout, 0));
- ut_assertok(wdt_start(sandbox_wdt, timeout, 0));
- /* Make sure both devices have just been pinged. */
- timer_test_add_offset(100);
- watchdog_reset();
- /* The gpio watchdog should be pinged, the sandbox one not. */
- timer_test_add_offset(30);
- watchdog_reset();
- ut_asserteq(!val, sandbox_gpio_get_value(gpio, offset));
- /* After another ~30ms, both devices should get pinged. */
- watchdog_reset();
- ut_asserteq(reset_count + 1, state->wdt.reset_count);
Viele Grüße, Stefan
On 31/08/2021 10.17, Stefan Roese wrote:
Hi Rasmus,
I'm pretty confident that has nothing to do with my patches, but is a broken (or, to put it more gently, fragile) test.
It does
// fetch the emulated device's current base_time value, setting it to 0 old_base_time = sandbox_i2c_rtc_get_set_base_time(emul, 0);
// fetch the emuluated device's current base_time value, don't (-1) set // a new value, check that we got 0 ut_asserteq(0, sandbox_i2c_rtc_get_set_base_time(emul, -1));
// call the device's ->reset method /* Resetting the RTC should put he base time back to normal */ ut_assertok(dm_rtc_reset(dev)); // fetch the new base_time value, without altering it base_time = sandbox_i2c_rtc_get_set_base_time(emul, -1); // and check that the base time was put back to "normal" ut_asserteq(old_base_time, base_time);
The thing is, the ->reset method does
static void reset_time(struct udevice *dev) { struct sandbox_i2c_rtc_plat_data *plat = dev_get_plat(dev); struct rtc_time now;
os_localtime(&now); plat->base_time = rtc_mktime(&now);
It's inevitable that this will cause occasional spurious failures. I can trivially reproduce it with
=> while ut dm rtc_reset ; do echo . ; done
it fails after a few screenfuls of successes.
Rasmus
Hi Rasmus,
It does
Yes, this test fails sometimes and just needs to be re-run. Currently we even have code in the test framework to allow for a little bit of wiggle room in the value, but perhaps it needs to be bumped up slightly.
Hi Rasmus,
It does
Thanks for looking into this.
Thanks, Stefan
participants (5)
Rasmus Villemoes
Stefan Roese
