[U-Boot] Canyonlands does not build anymore
The following commit modified include/asm-ppc/config.h so that config_canyonlands has CONFIG_FSL_DMA active (because of CONFIG_DDR_ECC), which is probably not intended. I'm not sure how to fix this properly, maybe some Freescale guru could comment.
Cheers Dirk
commit e94e460c6e8741f42dab6d8dd4b596ba5d9d79ae Author: Peter Tyser ptyser@xes-inc.com Date: Tue Jun 30 17:15:51 2009 -0500
83xx: Add support for fsl_dma driver
Signed-off-by: Peter Tyser ptyser@xes-inc.com Reviewed-by: Ira W. Snyder iws@ovro.caltech.edu Tested-by: Ira W. Snyder iws@ovro.caltech.edu Acked-by: Kim Phillips kim.phillips@freescale.com Signed-off-by: Kumar Gala galak@kernel.crashing.org
Dirk,
I already pointed this out a few days ago. Peter sent a new patchset with a fix for this. It's just not pushed into mainline yet.
Here a quick fix for you to being able to build Canyonlands again:
diff --git a/include/asm-ppc/config.h b/include/asm-ppc/config.h index ca143c7..00a7208 100644 --- a/include/asm-ppc/config.h +++ b/include/asm-ppc/config.h @@ -29,10 +29,9 @@ #endif #endif
-#ifndef CONFIG_FSL_DMA -#if ((!defined CONFIG_MPC83xx && defined(CONFIG_DDR_ECC) && \ - !defined(CONFIG_ECC_INIT_VIA_DDRCONTROLLER)) || \ - (defined(CONFIG_MPC83xx) && defined(CONFIG_DDR_ECC_INIT_VIA_DMA))) +#if (defined(CONFIG_MPC83xx) || defined(CONFIG_MPC85xx) || \ + defined(CONFIG_MPC86xx)) && !defined CONFIG_FSL_DMA +#if (defined(CONFIG_DDR_ECC) && !defined(CONFIG_ECC_INIT_VIA_DDRCONTROLLER)) #define CONFIG_FSL_DMA
Best regards, Stefan
Eibach, Dirk
Stefan Roese
