[U-Boot] [PATCH v4 00/11] binman: A tool for creating firmware images
This series introduces binman, a tool designed to create firmware images. It provides a way to bring together various binaries and place them in an image, at particular positions and with configurable alignment.
Packaging of firmware is quite a different task from building the various parts. In many cases the various binaries which go into the image come from separate build systems. For example, ARM Trusted Firmware is used on ARMv8 devices but is not built in the U-Boot tree. If a Linux kernel is included in the firmware image, it is built elsewhere.
It is of course possible to add more and more build rules to the U-Boot build system to cover these cases. It can shell out to other Makefiles and build scripts. But it seems better to create a clear divide between building software and packaging it.
U-Boot supports a very large number of boards. Many of these have their own specific rules for how an image should be put together so that it boots correctly. At present these rules are described by manual instructions, different for each board. By turning these instructions into a standard format, we can support making valid images for any board without manual effort, lots of READMEs, etc.
Images consist of a number of entries which are combined to make up the final image. The image is described in the device tree for the board, meaning that it can be accessed at run-time if desired.
Binman is an extensible tool. A set of standard entries is provides, but new entries can be created fairly easily. Entries can be as simple as providing the name of a file to include. They can also handle more complex requirements, such as adjusting the input file or reading header information from one entry to control the position of another.
U-Boot's mkimage builds FIT images and various other binaries. Binman augments this by allowing these binaries to be packed together. While FIT should be used where possible, it cannot be used everywhere. For example, many devices require executable code at a particular offset in the image. X86 machines require lots of binary blobs at particular places, and a microcode collection easily accessible at boot.
So far binman has enough functionality to be useful, so sunxi and x86 boards are switched over to use it, as examples.
The series is available at u-boot-dm/binman-working
Future work and missing features are documented in the README.
Changes in v4: - Add an option to bring in an soc .dtsi file also - Add new patch to support building x86 images with FSP/CMC - Fix incorrect comments at the top of intel_*.py - Fix up rule to #include on "/ {" rather than "/dts-v1/;" - Remove RFC tag - Rename binman_dtsi variable to u-boot-dtsi - Update sunxi rule to depend on u-boot.dtb - Use binman for all sunxi boards - Use binman for all x86 boards
Changes in v3: - Add a new patch to automatically include a U-Boot .dtsi file - Put the binman definition in u-boot.dtsi - Use a <dts>-u-boot.dtsi file for the binman changes
Changes in v2: - Add automated test coverage - Add test for code coverage - Fix the -b option - Put the binman definition in a common file for x86 - Various changes and improvements based on using this tool for a while - drop the unused __len__() method
Simon Glass (11): binman: Introduce binman, a tool for building binary images binman: Add basic entry types for U-Boot binman: Add support for building x86 ROMs binman: Add support for u-boot.img as an input binary binman: Add support for building x86 ROMs with SPL binman: Add support for building x86 images with FSP/CMC binman: Add a build rule for binman binman: Allow configuration options to be used in .dts files binman: Automatically include a U-Boot .dtsi file sunxi: Use binman for sunxi boards x86: Use binman all x86 boards
Makefile | 57 +- arch/arm/dts/sunxi-u-boot.dtsi | 14 + arch/x86/dts/u-boot.dtsi | 62 ++ scripts/Makefile.lib | 22 +- tools/binman/.gitignore | 1 + tools/binman/README | 491 +++++++++++++ tools/binman/binman | 1 + tools/binman/binman.py | 116 +++ tools/binman/cmdline.py | 53 ++ tools/binman/control.py | 118 ++++ tools/binman/entry_test.py | 27 + tools/binman/etype/_testing.py | 26 + tools/binman/etype/blob.py | 37 + tools/binman/etype/entry.py | 190 +++++ tools/binman/etype/intel_cmc.py | 17 + tools/binman/etype/intel_descriptor.py | 55 ++ tools/binman/etype/intel_fsp.py | 17 + tools/binman/etype/intel_me.py | 17 + tools/binman/etype/intel_mrc.py | 17 + tools/binman/etype/intel_vga.py | 17 + tools/binman/etype/u_boot.py | 17 + tools/binman/etype/u_boot_dtb.py | 17 + tools/binman/etype/u_boot_dtb_with_ucode.py | 72 ++ tools/binman/etype/u_boot_img.py | 17 + tools/binman/etype/u_boot_nodtb.py | 17 + tools/binman/etype/u_boot_spl.py | 17 + tools/binman/etype/u_boot_spl_bss_pad.py | 26 + tools/binman/etype/u_boot_spl_with_ucode_ptr.py | 28 + tools/binman/etype/u_boot_ucode.py | 77 ++ tools/binman/etype/u_boot_with_ucode_ptr.py | 73 ++ tools/binman/etype/x86_start16.py | 17 + tools/binman/etype/x86_start16_spl.py | 17 + tools/binman/fdt_test.py | 48 ++ tools/binman/func_test.py | 777 +++++++++++++++++++++ tools/binman/image.py | 229 ++++++ tools/binman/test/01_invalid.dts | 5 + tools/binman/test/02_missing_node.dts | 6 + tools/binman/test/03_empty.dts | 9 + tools/binman/test/04_invalid_entry.dts | 11 + tools/binman/test/05_simple.dts | 11 + tools/binman/test/06_dual_image.dts | 22 + tools/binman/test/07_bad_align.dts | 12 + tools/binman/test/08_pack.dts | 30 + tools/binman/test/09_pack_extra.dts | 35 + tools/binman/test/10_pack_align_power2.dts | 12 + tools/binman/test/11_pack_align_size_power2.dts | 12 + tools/binman/test/12_pack_inv_align.dts | 13 + tools/binman/test/13_pack_inv_size_align.dts | 13 + tools/binman/test/14_pack_overlap.dts | 16 + tools/binman/test/15_pack_overflow.dts | 12 + tools/binman/test/16_pack_image_overflow.dts | 13 + tools/binman/test/17_pack_image_size.dts | 13 + tools/binman/test/18_pack_image_align.dts | 13 + tools/binman/test/19_pack_inv_image_align.dts | 14 + .../binman/test/20_pack_inv_image_align_power2.dts | 13 + tools/binman/test/21_image_pad.dts | 16 + tools/binman/test/22_image_name.dts | 21 + tools/binman/test/23_blob.dts | 12 + tools/binman/test/24_sorted.dts | 17 + tools/binman/test/25_pack_zero_size.dts | 15 + tools/binman/test/26_pack_u_boot_dtb.dts | 14 + tools/binman/test/27_pack_4gb_no_size.dts | 18 + tools/binman/test/28_pack_4gb_outside.dts | 19 + tools/binman/test/29_x86-rom.dts | 19 + tools/binman/test/30_x86-rom-me-no-desc.dts | 15 + tools/binman/test/31_x86-rom-me.dts | 18 + tools/binman/test/32_intel-vga.dts | 13 + tools/binman/test/33_x86-start16.dts | 13 + tools/binman/test/34_x86_ucode.dts | 29 + tools/binman/test/35_x86_single_ucode.dts | 26 + tools/binman/test/36_u_boot_img.dts | 11 + tools/binman/test/37_x86_no_ucode.dts | 20 + tools/binman/test/38_x86_ucode_missing_node.dts | 26 + tools/binman/test/39_x86_ucode_missing_node2.dts | 23 + tools/binman/test/40_x86_ucode_not_in_image.dts | 28 + tools/binman/test/41_unknown_pos_size.dts | 11 + tools/binman/test/42_intel-fsp.dts | 13 + tools/binman/test/43_intel-cmc.dts | 13 + tools/binman/test/u_boot_no_ucode_ptr | Bin 0 -> 4182 bytes tools/binman/test/u_boot_no_ucode_ptr.c | 15 + tools/binman/test/u_boot_ucode_ptr | Bin 0 -> 4175 bytes tools/binman/test/u_boot_ucode_ptr.c | 15 + tools/binman/test/u_boot_ucode_ptr.lds | 18 + 83 files changed, 3500 insertions(+), 47 deletions(-) create mode 100644 arch/arm/dts/sunxi-u-boot.dtsi create mode 100644 arch/x86/dts/u-boot.dtsi create mode 100644 tools/binman/.gitignore create mode 100644 tools/binman/README create mode 120000 tools/binman/binman create mode 100755 tools/binman/binman.py create mode 100644 tools/binman/cmdline.py create mode 100644 tools/binman/control.py create mode 100644 tools/binman/entry_test.py create mode 100644 tools/binman/etype/_testing.py create mode 100644 tools/binman/etype/blob.py create mode 100644 tools/binman/etype/entry.py create mode 100644 tools/binman/etype/intel_cmc.py create mode 100644 tools/binman/etype/intel_descriptor.py create mode 100644 tools/binman/etype/intel_fsp.py create mode 100644 tools/binman/etype/intel_me.py create mode 100644 tools/binman/etype/intel_mrc.py create mode 100644 tools/binman/etype/intel_vga.py create mode 100644 tools/binman/etype/u_boot.py create mode 100644 tools/binman/etype/u_boot_dtb.py create mode 100644 tools/binman/etype/u_boot_dtb_with_ucode.py create mode 100644 tools/binman/etype/u_boot_img.py create mode 100644 tools/binman/etype/u_boot_nodtb.py create mode 100644 tools/binman/etype/u_boot_spl.py create mode 100644 tools/binman/etype/u_boot_spl_bss_pad.py create mode 100644 tools/binman/etype/u_boot_spl_with_ucode_ptr.py create mode 100644 tools/binman/etype/u_boot_ucode.py create mode 100644 tools/binman/etype/u_boot_with_ucode_ptr.py create mode 100644 tools/binman/etype/x86_start16.py create mode 100644 tools/binman/etype/x86_start16_spl.py create mode 100644 tools/binman/fdt_test.py create mode 100644 tools/binman/func_test.py create mode 100644 tools/binman/image.py create mode 100644 tools/binman/test/01_invalid.dts create mode 100644 tools/binman/test/02_missing_node.dts create mode 100644 tools/binman/test/03_empty.dts create mode 100644 tools/binman/test/04_invalid_entry.dts create mode 100644 tools/binman/test/05_simple.dts create mode 100644 tools/binman/test/06_dual_image.dts create mode 100644 tools/binman/test/07_bad_align.dts create mode 100644 tools/binman/test/08_pack.dts create mode 100644 tools/binman/test/09_pack_extra.dts create mode 100644 tools/binman/test/10_pack_align_power2.dts create mode 100644 tools/binman/test/11_pack_align_size_power2.dts create mode 100644 tools/binman/test/12_pack_inv_align.dts create mode 100644 tools/binman/test/13_pack_inv_size_align.dts create mode 100644 tools/binman/test/14_pack_overlap.dts create mode 100644 tools/binman/test/15_pack_overflow.dts create mode 100644 tools/binman/test/16_pack_image_overflow.dts create mode 100644 tools/binman/test/17_pack_image_size.dts create mode 100644 tools/binman/test/18_pack_image_align.dts create mode 100644 tools/binman/test/19_pack_inv_image_align.dts create mode 100644 tools/binman/test/20_pack_inv_image_align_power2.dts create mode 100644 tools/binman/test/21_image_pad.dts create mode 100644 tools/binman/test/22_image_name.dts create mode 100644 tools/binman/test/23_blob.dts create mode 100644 tools/binman/test/24_sorted.dts create mode 100644 tools/binman/test/25_pack_zero_size.dts create mode 100644 tools/binman/test/26_pack_u_boot_dtb.dts create mode 100644 tools/binman/test/27_pack_4gb_no_size.dts create mode 100644 tools/binman/test/28_pack_4gb_outside.dts create mode 100644 tools/binman/test/29_x86-rom.dts create mode 100644 tools/binman/test/30_x86-rom-me-no-desc.dts create mode 100644 tools/binman/test/31_x86-rom-me.dts create mode 100644 tools/binman/test/32_intel-vga.dts create mode 100644 tools/binman/test/33_x86-start16.dts create mode 100644 tools/binman/test/34_x86_ucode.dts create mode 100644 tools/binman/test/35_x86_single_ucode.dts create mode 100644 tools/binman/test/36_u_boot_img.dts create mode 100644 tools/binman/test/37_x86_no_ucode.dts create mode 100644 tools/binman/test/38_x86_ucode_missing_node.dts create mode 100644 tools/binman/test/39_x86_ucode_missing_node2.dts create mode 100644 tools/binman/test/40_x86_ucode_not_in_image.dts create mode 100644 tools/binman/test/41_unknown_pos_size.dts create mode 100644 tools/binman/test/42_intel-fsp.dts create mode 100644 tools/binman/test/43_intel-cmc.dts create mode 100755 tools/binman/test/u_boot_no_ucode_ptr create mode 100644 tools/binman/test/u_boot_no_ucode_ptr.c create mode 100755 tools/binman/test/u_boot_ucode_ptr create mode 100644 tools/binman/test/u_boot_ucode_ptr.c create mode 100644 tools/binman/test/u_boot_ucode_ptr.lds
This adds the basic code for binman, including command parsing, processing of entries and generation of images.
So far no entry types are supported. These will be added in future commits as examples of how to add new types.
See the README for documentation.
Changes in v4: None Changes in v3: None Changes in v2: - Add test for code coverage - Fix the -b option - drop the unused __len__() method
tools/binman/.gitignore | 1 + tools/binman/README | 491 ++++++++++++++++++++++++++++++++++++++++++++ tools/binman/binman | 1 + tools/binman/binman.py | 116 +++++++++++ tools/binman/cmdline.py | 53 +++++ tools/binman/control.py | 118 +++++++++++ tools/binman/etype/entry.py | 190 +++++++++++++++++ tools/binman/fdt_test.py | 48 +++++ tools/binman/image.py | 229 +++++++++++++++++++++ 9 files changed, 1247 insertions(+) create mode 100644 tools/binman/.gitignore create mode 100644 tools/binman/README create mode 120000 tools/binman/binman create mode 100755 tools/binman/binman.py create mode 100644 tools/binman/cmdline.py create mode 100644 tools/binman/control.py create mode 100644 tools/binman/etype/entry.py create mode 100644 tools/binman/fdt_test.py create mode 100644 tools/binman/image.py
diff --git a/tools/binman/.gitignore b/tools/binman/.gitignore new file mode 100644 index 0000000..0d20b64 --- /dev/null +++ b/tools/binman/.gitignore @@ -0,0 +1 @@ +*.pyc diff --git a/tools/binman/README b/tools/binman/README new file mode 100644 index 0000000..c73fb3c --- /dev/null +++ b/tools/binman/README @@ -0,0 +1,491 @@ +# Copyright (c) 2016 Google, Inc +# +# SPDX-License-Identifier: GPL-2.0+ +# + +Introduction +------------ + +Firmware often consists of several components which must be packaged together. +For example, we may have SPL, U-Boot, a device tree and an environment area +grouped together and placed in MMC flash. When the system starts, it must be +able to find these pieces. + +So far U-Boot has not provided a way to handle creating such images in a +general way. Each SoC does what it needs to build an image, often packing or +concatenating images in the U-Boot build system. + +Binman aims to provide a mechanism for building images, from simple +SPL + U-Boot combinations, to more complex arrangements with many parts. + + +What it does +------------ + +Binman reads your board's device tree and finds a node which describes the +required image layout. It uses this to work out what to place where. The +output file normally contains the device tree, so it is in principle possible +to read an image and extract its constituent parts. + + +Features +-------- + +So far binman is pretty simple. It supports binary blobs, such as 'u-boot', +'spl' and 'fdt'. It supports empty entries (such as setting to 0xff). It can +place entries at a fixed location in the image, or fit them together with +suitable padding and alignment. It provides a way to process binaries before +they are included, by adding a Python plug-in. The device tree is available +to U-Boot at run-time so that the images can be interpreted. + +Binman does not yet update the device tree with the final location of +everything when it is done. A simple C structure could be generated for +constrained environments like SPL (using dtoc) but this is also not +implemented. + +Binman can also support incorporating filesystems in the image if required. +For example x86 platforms may use CBFS in some cases. + +Binman is intended for use with U-Boot but is designed to be general enough +to be useful in other image-packaging situations. + + +Motivation +---------- + +Packaging of firmware is quite a different task from building the various +parts. In many cases the various binaries which go into the image come from +separate build systems. For example, ARM Trusted Firmware is used on ARMv8 +devices but is not built in the U-Boot tree. If a Linux kernel is included +in the firmware image, it is built elsewhere. + +It is of course possible to add more and more build rules to the U-Boot +build system to cover these cases. It can shell out to other Makefiles and +build scripts. But it seems better to create a clear divide between building +software and packaging it. + +At present this is handled by manual instructions, different for each board, +on how to create images that will boot. By turning these instructions into a +standard format, we can support making valid images for any board without +manual effort, lots of READMEs, etc. + +Benefits: +- Each binary can have its own build system and tool chain without creating +any dependencies between them +- Avoids the need for a single-shot build: individual parts can be updated +and brought in as needed +- Provides for a standard image description available in the build and at +run-time +- SoC-specific image-signing tools can be accomodated +- Avoids cluttering the U-Boot build system with image-building code +- The image description is automatically available at run-time in U-Boot, +SPL. It can be made available to other software also +- The image description is easily readable (it's a text file in device-tree +format) and permits flexible packing of binaries + + +Terminology +----------- + +Binman uses the following terms: + +- image - an output file containing a firmware image +- binary - an input binary that goes into the image + + +Relationship to FIT +------------------- + +FIT is U-Boot's official image format. It supports multiple binaries with +load / execution addresses, compression. It also supports verification +through hashing and RSA signatures. + +FIT was originally designed to support booting a Linux kernel (with an +optional ramdisk) and device tree chosen from various options in the FIT. +Now that U-Boot supports configuration via device tree, it is possible to +load U-Boot from a FIT, with the device tree chosen by SPL. + +Binman considers FIT to be one of the binaries it can place in the image. + +Where possible it is best to put as much as possible in the FIT, with binman +used to deal with cases not covered by FIT. Examples include initial +execution (since FIT itself does not have an executable header) and dealing +with device boundaries, such as the read-only/read-write separation in SPI +flash. + +For U-Boot, binman should not be used to create ad-hoc images in place of +FIT. + + +Relationship to mkimage +----------------------- + +The mkimage tool provides a means to create a FIT. Traditionally it has +needed an image description file: a device tree, like binman, but in a +different format. More recently it has started to support a '-f auto' mode +which can generate that automatically. + +More relevant to binman, mkimage also permits creation of many SoC-specific +image types. These can be listed by running 'mkimage -T list'. Examples +include 'rksd', the Rockchip SD/MMC boot format. The mkimage tool is often +called from the U-Boot build system for this reason. + +Binman considers the output files created by mkimage to be binary blobs +which it can place in an image. Binman does not replace the mkimage tool or +this purpose. It would be possible in some situtions to create a new entry +type for the images in mkimage, but this would not add functionality. It +seems better to use the mkiamge tool to generate binaries and avoid blurring +the boundaries between building input files (mkimage) and packaging then +into a final image (binman). + + +Example use of binman in U-Boot +------------------------------- + +Binman aims to replace some of the ad-hoc image creation in the U-Boot +build system. + +Consider sunxi. It has the following steps: + +1. It uses a custom mksunxiboot tool to build an SPL image called +sunxi-spl.bin. This should probably move into mkimage. + +2. It uses mkimage to package U-Boot into a legacy image file (so that it can +hold the load and execution address) called u-boot.img. + +3. It builds a final output image called u-boot-sunxi-with-spl.bin which +consists of sunxi-spl.bin, some padding and u-boot.img. + +Binman is intended to replace the last step. The U-Boot build system builds +u-boot.bin and sunxi-spl.bin. Binman can then take over creation of +sunxi-spl.bin (by calling mksunxiboot, or hopefully one day mkimage). In any +case, it would then create the image from the component parts. + +This simplifies the U-Boot Makefile somewhat, since various pieces of logic +can be replaced by a call to binman. + + +Example use of binman for x86 +----------------------------- + +In most cases x86 images have a lot of binary blobs, 'black-box' code +provided by Intel which must be run for the platform to work. Typically +these blobs are not relocatable and must be placed at fixed areas in the +firmare image. + +Currently this is handled by ifdtool, which places microcode, FSP, MRC, VGA +BIOS, reference code and Intel ME binaries into a u-boot.rom file. + +Binman is intended to replace all of this, with ifdtool left to handle only +the configuration of the Intel-format descriptor. + + +Running binman +-------------- + +Type: + + binman -b <board_name> + +to build an image for a board. The board name is the same name used when +configuring U-Boot (e.g. for sandbox_defconfig the board name is 'sandbox'). +Binman assumes that the input files for the build are in ../b/<board_name>. + +Or you can specify this explicitly: + + binman -I <build_path> + +where <build_path> is the build directory containing the output of the U-Boot +build. + +(Future work will make this more configurable) + +In either case, binman picks up the device tree file (u-boot.dtb) and looks +for its instructions in the 'binman' node. + +Binman has a few other options which you can see by running 'binman -h'. + + +Image description format +------------------------ + +The binman node is called 'binman'. An example image description is shown +below: + + binman { + filename = "u-boot-sunxi-with-spl.bin"; + pad-byte = <0xff>; + blob { + filename = "spl/sunxi-spl.bin"; + }; + u-boot { + pos = <CONFIG_SPL_PAD_TO>; + }; + }; + + +This requests binman to create an image file called u-boot-sunxi-with-spl.bin +consisting of a specially formatted SPL (spl/sunxi-spl.bin, built by the +normal U-Boot Makefile), some 0xff padding, and a U-Boot legacy image. The +padding comes from the fact that the second binary is placed at +CONFIG_SPL_PAD_TO. If that line were omitted then the U-Boot binary would +immediately follow the SPL binary. + +The binman node describes an image. The sub-nodes describe entries in the +image. Each entry represents a region within the overall image. The name of +the entry (blob, u-boot) tells binman what to put there. For 'blob' we must +provide a filename. For 'u-boot', binman knows that this means 'u-boot.bin'. + +Entries are normally placed into the image sequentially, one after the other. +The image size is the total size of all entries. As you can see, you can +specify the start position of an entry using the 'pos' property. + +Note that due to a device tree requirement, all entries must have a unique +name. If you want to put the same binary in the image multiple times, you can +use any unique name, with the 'type' property providing the type. + +The attributes supported for entries are described below. + +pos: + This sets the position of an entry within the image. The first byte + of the image is normally at position 0. If 'pos' is not provided, + binman sets it to the end of the previous region, or the start of + the image's entry area (normally 0) if there is no previous region. + +align: + This sets the alignment of the entry. The entry position is adjusted + so that the entry starts on an aligned boundary within the image. For + example 'align = <16>' means that the entry will start on a 16-byte + boundary. Alignment shold be a power of 2. If 'align' is not + provided, no alignment is performed. + +size: + This sets the size of the entry. The contents will be padded out to + this size. If this is not provided, it will be set to the size of the + contents. + +pad-before: + Padding before the contents of the entry. Normally this is 0, meaning + that the contents start at the beginning of the entry. This can be + offset the entry contents a little. Defaults to 0. + +pad-after: + Padding after the contents of the entry. Normally this is 0, meaning + that the entry ends at the last byte of content (unless adjusted by + other properties). This allows room to be created in the image for + this entry to expand later. Defaults to 0. + +align-size: + This sets the alignment of the entry size. For example, to ensure + that the size of an entry is a multiple of 64 bytes, set this to 64. + If 'align-size' is not provided, no alignment is performed. + +align-end: + This sets the alignment of the end of an entry. Some entries require + that they end on an alignment boundary, regardless of where they + start. If 'align-end' is not provided, no alignment is performed. + + Note: This is not yet implemented in binman. + +filename: + For 'blob' types this provides the filename containing the binary to + put into the entry. If binman knows about the entry type (like + u-boot-bin), then there is no need to specify this. + +type: + Sets the type of an entry. This defaults to the entry name, but it is + possible to use any name, and then add (for example) 'type = "u-boot"' + to specify the type. + + +The attributes supported for images are described below. Several are similar +to those for entries. + +size: + Sets the image size in bytes, for example 'size = <0x100000>' for a + 1MB image. + +align-size: + This sets the alignment of the image size. For example, to ensure + that the image ends on a 512-byte boundary, use 'align-size = <512>'. + If 'align-size' is not provided, no alignment is performed. + +pad-before: + This sets the padding before the image entries. The first entry will + be positionad after the padding. This defaults to 0. + +pad-after: + This sets the padding after the image entries. The padding will be + placed after the last entry. This defaults to 0. + +pad-byte: + This specifies the pad byte to use when padding in the image. It + defaults to 0. To use 0xff, you would add 'pad-byte = <0xff>'. + +filename: + This specifies the image filename. It defaults to 'image.bin'. + +sort-by-pos: + This causes binman to reorder the entries as needed to make sure they + are in increasing positional order. This can be used when your entry + order may not match the positional order. A common situation is where + the 'pos' properties are set by CONFIG options, so their ordering is + not known a priori. + + This is a boolean property so needs no value. To enable it, add a + line 'sort-by-pos;' to your description. + +multiple-images: + Normally only a single image is generated. To create more than one + image, put this property in the binman node. For example, this will + create image1.bin containing u-boot.bin, and image2.bin containing + both spl/u-boot-spl.bin and u-boot.bin: + + binman { + multiple-images; + image1 { + u-boot { + }; + }; + + image2 { + spl { + }; + u-boot { + }; + }; + }; + +end-at-4gb: + For x86 machines the ROM positions start just before 4GB and extend + up so that the image finished at the 4GB boundary. This boolean + option can be enabled to support this. The image size must be + provided so that binman knows when the image should start. For an + 8MB ROM, the position of the first entry would be 0xfff80000 with + this option, instead of 0 without this option. + + +Examples of the above options can be found in the tests. See the +tools/binman/test directory. + + +Order of image creation +----------------------- + +Image creation proceeds in the following order, for each entry in the image. + +1. GetEntryContents() - the contents of each entry are obtained, normally by +reading from a file. This calls the Entry.ObtainContents() to read the +contents. The default version of Entry.ObtainContents() calls +Entry.GetDefaultFilename() and then reads that file. So a common mechanism +to select a file to read is to override that function in the subclass. The +functions must return True when they have read the contents. Binman will +retry calling the functions a few times if False is returned, allowing +dependencies between the contents of different entries. + +2. GetEntryPositions() - calls Entry.GetPositions() for each entry. This can +return a dict containing entries that need updating. The key should be the +entry name and the value is a tuple (pos, size). This allows an entry to +provide the position and size for other entries. The default implementation +of GetEntryPositions() returns {}. + +3. PackEntries() - calls Entry.Pack() which figures out the position and +size of an entry. The 'current' image position is passed in, and the function +returns the position immediately after the entry being packed. The default +implementation of Pack() is usually sufficient. + +4. CheckSize() - checks that the contents of all the entries fits within +the image size. If the image does not have a defined size, the size is set +large enough to hold all the entries. + +5. CheckEntries() - checks that the entries do not overlap, nor extend +outside the image. + +6. ProcessEntryContents() - this calls Entry.ProcessContents() on each entry. +The default implementatoin does nothing. This can be overriden to adjust the +contents of an entry in some way. For example, it would be possible to create +an entry containing a hash of the contents of some other entries. At this +stage the position and size of entries should not be adjusted. + +7. BuildImage() - builds the image and writes it to a file. This is the final +step. + + +Advanced Features / Technical docs +---------------------------------- + +The behaviour of entries is defined by the Entry class. All other entries are +a subclass of this. An important subclass is Entry_blob which takes binary +data from a file and places it in the entry. In fact most entry types are +subclasses of Entry_blob. + +Each entry type is a separate file in the tools/binman/etype directory. Each +file contains a class called Entry_<type> where <type> is the entry type. +New entry types can be supported by adding new files in that directory. +These will automatically be detected by binman when needed. + +Entry properties are documented in entry.py. The entry subclasses are free +to change the values of properties to support special behaviour. For example, +when Entry_blob loads a file, it sets content_size to the size of the file. +Entry classes can adjust other entries. For example, an entry that knows +where other entries should be positioned can set up those entries' positions +so they don't need to be set in the binman decription. It can also adjust +entry contents. + +Most of the time such essoteric behaviour is not needed, but it can be +essential for complex images. + + +History / Credits +----------------- + +Binman takes a lot of inspiration from a Chrome OS tool called +'cros_bundle_firmware', which I wrote some years ago. That tool was based on +a reasonably simple and sound design but has expanded greatly over the +years. In particular its handling of x86 images is convoluted. + +Quite a few lessons have been learned which are hopefully be applied here. + + +Design notes +------------ + +On the face of it, a tool to create firmware images should be fairly simple: +just find all the input binaries and place them at the right place in the +image. The difficulty comes from the wide variety of input types (simple +flat binaries containing code, packaged data with various headers), packing +requirments (alignment, spacing, device boundaries) and other required +features such as hierarchical images. + +The design challenge is to make it easy to create simple images, while +allowing the more complex cases to be supported. For example, for most +images we don't much care exactly where each binary ends up, so we should +not have to specify that unnecessarily. + +New entry types should aim to provide simple usage where possible. If new +core features are needed, they can be added in the Entry base class. + + +To do +----- + +Some ideas: +- Fill out the device tree to include the final position and size of each + entry (since the input file may not always specify these) +- Use of-platdata to make the information available to code that is unable + to use device tree (such as a very small SPL image) +- Write an image map to a text file +- Allow easy building of images by specifying just the board name +- Produce a full Python binding for libfdt (for upstream) +- Add an option to decode an image into the constituent binaries +- Suppoort hierarchical images (packing of binaries into another binary + which is then placed in the image) +- Support building an image for a board (-b) more completely, with a + configurable build directory +- Consider making binman work with buildman, although if it is used in the + Makefile, this will be automatic +- Implement align-end + +-- +Simon Glass sjg@chromium.org +7/7/2016 diff --git a/tools/binman/binman b/tools/binman/binman new file mode 120000 index 0000000..979b7e4 --- /dev/null +++ b/tools/binman/binman @@ -0,0 +1 @@ +binman.py \ No newline at end of file diff --git a/tools/binman/binman.py b/tools/binman/binman.py new file mode 100755 index 0000000..b117b4c --- /dev/null +++ b/tools/binman/binman.py @@ -0,0 +1,116 @@ +#!/usr/bin/python + +# Copyright (c) 2016 Google, Inc +# Written by Simon Glass sjg@chromium.org +# +# SPDX-License-Identifier: GPL-2.0+ +# +# Creates binary images from input files controlled by a description +# + +"""See README for more information""" + +import os +import sys +import traceback +import unittest + +# Bring in the patman and dtoc libraries +our_path = os.path.dirname(os.path.realpath(__file__)) +sys.path.append(os.path.join(our_path, '../patman')) +sys.path.append(os.path.join(our_path, '../dtoc')) + +# For testing of the Python libfdt module +# sys.path.append(os.path.join(our_path, '../../b/sandbox_spl/tools')) + +# Also allow entry-type modules to be brought in from the etype directory. +sys.path.append(os.path.join(our_path, 'etype')) + +import cmdline +import command +import control + +def RunTests(): + """Run the functional tests and any embedded doctests""" + import entry_test + import fdt_test + import func_test + import test + import doctest + + result = unittest.TestResult() + for module in []: + suite = doctest.DocTestSuite(module) + suite.run(result) + + sys.argv = [sys.argv[0]] + for module in (func_test.TestFunctional, fdt_test.TestFdt, + entry_test.TestEntry): + suite = unittest.TestLoader().loadTestsFromTestCase(module) + suite.run(result) + + print result + for test, err in result.errors: + print test.id(), err + for test, err in result.failures: + print err + +def RunTestCoverage(): + """Run the tests and check that we get 100% coverage""" + # This uses the build output from sandbox_spl to get _libfdt.so + cmd = ('PYTHONPATH=%s/sandbox_spl/tools coverage run ' + '--include "tools/binman/*.py" --omit "*test*,*binman.py" ' + 'tools/binman/binman.py -t' % options.build_dir) + os.system(cmd) + stdout = command.Output('coverage', 'report') + coverage = stdout.splitlines()[-1].split(' ')[-1] + if coverage != '100%': + print stdout + raise ValueError('Coverage error: %s, but should be 100%%' % coverage) + + +def RunBinman(options, args): + """Main entry point to binman once arguments are parsed + + Args: + options: Command-line options + args: Non-option arguments + """ + ret_code = 0 + + # For testing: This enables full exception traces. + #options.debug = True + + if not options.debug: + sys.tracebacklimit = 0 + + if options.test: + RunTests() + + elif options.test_coverage: + RunTestCoverage() + + elif options.full_help: + pager = os.getenv('PAGER') + if not pager: + pager = 'more' + fname = os.path.join(os.path.dirname(os.path.realpath(sys.argv[0])), + 'README') + command.Run(pager, fname) + + else: + try: + ret_code = control.Binman(options, args) + except Exception as e: + print e + if options.debug: + print + traceback.print_exc() + ret_code = 1 + return ret_code + + +if __name__ == "__main__": + (options, args) = cmdline.ParseArgs(sys.argv) + ret_code = RunBinman(options, args) + sys.exit(ret_code) diff --git a/tools/binman/cmdline.py b/tools/binman/cmdline.py new file mode 100644 index 0000000..233d5e1 --- /dev/null +++ b/tools/binman/cmdline.py @@ -0,0 +1,53 @@ +# Copyright (c) 2016 Google, Inc +# Written by Simon Glass sjg@chromium.org +# +# SPDX-License-Identifier: GPL-2.0+ +# +# Command-line parser for binman +# + +from optparse import OptionParser + +def ParseArgs(argv): + """Parse the binman command-line arguments + + Args: + argv: List of string arguments + Returns: + Tuple (options, args) with the command-line options and arugments. + options provides access to the options (e.g. option.debug) + args is a list of string arguments + """ + parser = OptionParser() + parser.add_option('-b', '--board', type='string', + help='Board name to build') + parser.add_option('-B', '--build-dir', type='string', default='b', + help='Directory containing the build output') + parser.add_option('-d', '--dt', type='string', + help='Configuration file (.dtb) to use') + parser.add_option('-D', '--debug', action='store_true', + help='Enabling debugging (provides a full traceback on error)') + parser.add_option('-I', '--indir', action='append', + help='Add a path to a directory to use for input files') + parser.add_option('-H', '--full-help', action='store_true', + default=False, help='Display the README file') + parser.add_option('-O', '--outdir', type='string', + action='store', help='Path to directory to use for intermediate and ' + 'output files') + parser.add_option('-p', '--preserve', action='store_true',\ + help='Preserve temporary output directory even if option -O is not ' + 'given') + parser.add_option('-t', '--test', action='store_true', + default=False, help='run tests') + parser.add_option('-T', '--test-coverage', action='store_true', + default=False, help='run tests and check for 100% coverage') + parser.add_option('-v', '--verbosity', default=1, + type='int', help='Control verbosity: 0=silent, 1=progress, 3=full, ' + '4=debug') + + parser.usage += """ + +Create images for a board from a set of binaries. It is controlled by a +description in the board device tree.""" + + return parser.parse_args(argv) diff --git a/tools/binman/control.py b/tools/binman/control.py new file mode 100644 index 0000000..e909678 --- /dev/null +++ b/tools/binman/control.py @@ -0,0 +1,118 @@ +# Copyright (c) 2016 Google, Inc +# Written by Simon Glass sjg@chromium.org +# +# SPDX-License-Identifier: GPL-2.0+ +# +# Creates binary images from input files controlled by a description +# + +from collections import OrderedDict +import os +import sys +import tools + +import command +import fdt_select +import fdt_util +from image import Image +import tout + +# List of images we plan to create +# Make this global so that it can be referenced from tests +images = OrderedDict() + +def _ReadImageDesc(binman_node): + """Read the image descriptions from the /binman node + + This normally produces a single Image object called 'image'. But if + multiple images are present, they will all be returned. + + Args: + binman_node: Node object of the /binman node + Returns: + OrderedDict of Image objects, each of which describes an image + """ + images = OrderedDict() + if 'multiple-images' in binman_node.props: + for node in binman_node.subnodes: + images[node.name] = Image(node.name, node) + else: + images['image'] = Image('image', binman_node) + return images + +def _FindBinmanNode(fdt): + """Find the 'binman' node in the device tree + + Args: + fdt: Fdt object to scan + Returns: + Node object of /binman node, or None if not found + """ + for node in fdt.GetRoot().subnodes: + if node.name == 'binman': + return node + return None + +def Binman(options, args): + """The main control code for binman + + This assumes that help and test options have already been dealt with. It + deals with the core task of building images. + + Args: + options: Command line options object + args: Command line arguments (list of strings) + """ + global images + + if options.full_help: + pager = os.getenv('PAGER') + if not pager: + pager = 'more' + fname = os.path.join(os.path.dirname(os.path.realpath(sys.argv[0])), + 'README') + command.Run(pager, fname) + return 0 + + # Try to figure out which device tree contains our image description + if options.dt: + dtb_fname = options.dt + else: + board = options.board + if not board: + raise ValueError('Must provide a board to process (use -b <board>)') + board_pathname = os.path.join(options.build_dir, board) + dtb_fname = os.path.join(board_pathname, 'u-boot.dtb') + if not options.indir: + options.indir = ['.'] + options.indir.append(board_pathname) + + try: + tout.Init(options.verbosity) + try: + tools.SetInputDirs(options.indir) + tools.PrepareOutputDir(options.outdir, options.preserve) + fdt = fdt_select.FdtScan(dtb_fname) + node = _FindBinmanNode(fdt) + if not node: + raise ValueError("Device tree '%s' does not have a 'binman' " + "node" % dtb_fname) + images = _ReadImageDesc(node) + for image in images.values(): + # Perform all steps for this image, including checking and + # writing it. This means that errors found with a later + # image will be reported after earlier images are already + # completed and written, but that does not seem important. + image.GetEntryContents() + image.GetEntryPositions() + image.PackEntries() + image.CheckSize() + image.CheckEntries() + image.ProcessEntryContents() + image.BuildImage() + finally: + tools.FinaliseOutputDir() + finally: + tout.Uninit() + + return 0 diff --git a/tools/binman/etype/entry.py b/tools/binman/etype/entry.py new file mode 100644 index 0000000..d313b35 --- /dev/null +++ b/tools/binman/etype/entry.py @@ -0,0 +1,190 @@ +# Copyright (c) 2016 Google, Inc +# +# SPDX-License-Identifier: GPL-2.0+ +# +# Base class for all entries +# + +import importlib + +import fdt_util +import tools + +modules = {} + +class Entry(object): + """An Entry in the image + + An entry corresponds to a single node in the device-tree description + of the image. Each entry ends up being a part of the final image. + Entries can be placed either right next to each other, or with padding + between them. The type of the entry determines the data that is in it. + + This class is not used by itself. All entry objects are subclasses of + Entry. + + Attributes: + image: The image containing this entry + node: The node that created this entry + pos: Absolute position of entry within the image, None if not known + size: Entry size in bytes, None if not known + contents_size: Size of contents in bytes, 0 by default + align: Entry start position alignment, or None + align_size: Entry size alignment, or None + align_end: Entry end position alignment, or None + pad_before: Number of pad bytes before the contents, 0 if none + pad_after: Number of pad bytes after the contents, 0 if none + data: Contents of entry (string of bytes) + """ + def __init__(self, image, etype, node, read_node=True): + self.image = image + self.etype = etype + self._node = node + self.pos = None + self.size = None + self.contents_size = 0 + self.align = None + self.align_size = None + self.align_end = None + self.pad_before = 0 + self.pad_after = 0 + self.pos_unset = False + if read_node: + self.ReadNode() + + @staticmethod + def Create(image, node, etype=None): + """Create a new entry for a node. + + Args: + image: Image object containing this node + node: Node object containing information about the entry to create + etype: Entry type to use, or None to work it out (used for tests) + + Returns: + A new Entry object of the correct type (a subclass of Entry) + """ + if not etype: + etype = fdt_util.GetString(node, 'type', node.name) + module_name = etype.replace('-', '_') + module = modules.get(module_name) + + # Import the module if we have not already done so. + if not module: + try: + module = importlib.import_module(module_name) + except ImportError: + raise ValueError("Unknown entry type '%s' in node '%s'" % + (etype, node.path)) + modules[module_name] = module + + # Call its constructor to get the object we want. + obj = getattr(module, 'Entry_%s' % module_name) + return obj(image, etype, node) + + def ReadNode(self): + """Read entry information from the node + + This reads all the fields we recognise from the node, ready for use. + """ + self.pos = fdt_util.GetInt(self._node, 'pos') + self.size = fdt_util.GetInt(self._node, 'size') + self.align = fdt_util.GetInt(self._node, 'align') + if tools.NotPowerOfTwo(self.align): + raise ValueError("Node '%s': Alignment %s must be a power of two" % + (self._node.path, self.align)) + self.pad_before = fdt_util.GetInt(self._node, 'pad-before', 0) + self.pad_after = fdt_util.GetInt(self._node, 'pad-after', 0) + self.align_size = fdt_util.GetInt(self._node, 'align-size') + if tools.NotPowerOfTwo(self.align_size): + raise ValueError("Node '%s': Alignment size %s must be a power " + "of two" % (self._node.path, self.align_size)) + self.align_end = fdt_util.GetInt(self._node, 'align-end') + self.pos_unset = fdt_util.GetBool(self._node, 'pos-unset') + + def ObtainContents(self): + """Figure out the contents of an entry. + + Returns: + True if the contents were found, False if another call is needed + after the other entries are processed. + """ + # No contents by default: subclasses can implement this + return True + + def Pack(self, pos): + """Figure out how to pack the entry into the image + + Most of the time the entries are not fully specified. There may be + an alignment but no size. In that case we take the size from the + contents of the entry. + + If an entry has no hard-coded position, it will be placed at @pos. + + Once this function is complete, both the position and size of the + entry will be know. + + Args: + Current image position pointer + + Returns: + New image position pointer (after this entry) + """ + if self.pos is None: + if self.pos_unset: + self.Raise('No position set with pos-unset: should another ' + 'entry provide this correct position?') + self.pos = tools.Align(pos, self.align) + needed = self.pad_before + self.contents_size + self.pad_after + needed = tools.Align(needed, self.align_size) + size = self.size + if not size: + size = needed + new_pos = self.pos + size + aligned_pos = tools.Align(new_pos, self.align_end) + if aligned_pos != new_pos: + size = aligned_pos - self.pos + new_pos = aligned_pos + + if not self.size: + self.size = size + + if self.size < needed: + self.Raise("Entry contents size is %#x (%d) but entry size is " + "%#x (%d)" % (needed, needed, self.size, self.size)) + # Check that the alignment is correct. It could be wrong if the + # and pos or size values were provided (i.e. not calculated), but + # conflict with the provided alignment values + if self.size != tools.Align(self.size, self.align_size): + self.Raise("Size %#x (%d) does not match align-size %#x (%d)" % + (self.size, self.size, self.align_size, self.align_size)) + if self.pos != tools.Align(self.pos, self.align): + self.Raise("Position %#x (%d) does not match align %#x (%d)" % + (self.pos, self.pos, self.align, self.align)) + + return new_pos + + def Raise(self, msg): + """Convenience function to raise an error referencing a node""" + raise ValueError("Node '%s': %s" % (self._node.path, msg)) + + def GetPath(self): + """Get the path of a node + + Returns: + Full path of the node for this entry + """ + return self._node.path + + def GetData(self): + return self.data + + def GetPositions(self): + return {} + + def SetPositionSize(self, pos, size): + self.pos = pos + self.size = size + + def ProcessContents(self): + pass diff --git a/tools/binman/fdt_test.py b/tools/binman/fdt_test.py new file mode 100644 index 0000000..1d9494e --- /dev/null +++ b/tools/binman/fdt_test.py @@ -0,0 +1,48 @@ +# +# Copyright (c) 2016 Google, Inc +# Written by Simon Glass sjg@chromium.org +# +# SPDX-License-Identifier: GPL-2.0+ +# +# Test for the fdt modules + +import os +import sys +import tempfile +import unittest + +from fdt_select import FdtScan +import fdt_util +import tools + +class TestFdt(unittest.TestCase): + @classmethod + def setUpClass(self): + self._binman_dir = os.path.dirname(os.path.realpath(sys.argv[0])) + self._indir = tempfile.mkdtemp(prefix='binmant.') + tools.PrepareOutputDir(self._indir, True) + + def TestFile(self, fname): + return os.path.join(self._binman_dir, 'test', fname) + + def GetCompiled(self, fname): + return fdt_util.EnsureCompiled(self.TestFile(fname)) + + def _DeleteProp(self, fdt): + node = fdt.GetNode('/microcode/update@0') + node.DeleteProp('data') + + def testFdtNormal(self): + fname = self.GetCompiled('34_x86_ucode.dts') + fdt = FdtScan(fname) + self._DeleteProp(fdt) + + def testFdtFallback(self): + fname = self.GetCompiled('34_x86_ucode.dts') + fdt = FdtScan(fname, True) + fdt.GetProp('/microcode/update@0', 'data') + self.assertEqual('fred', + fdt.GetProp('/microcode/update@0', 'none', default='fred')) + self.assertEqual('12345678 12345679', + fdt.GetProp('/microcode/update@0', 'data', typespec='x')) + self._DeleteProp(fdt) diff --git a/tools/binman/image.py b/tools/binman/image.py new file mode 100644 index 0000000..07fc930 --- /dev/null +++ b/tools/binman/image.py @@ -0,0 +1,229 @@ +# Copyright (c) 2016 Google, Inc +# Written by Simon Glass sjg@chromium.org +# +# SPDX-License-Identifier: GPL-2.0+ +# +# Class for an image, the output of binman +# + +from collections import OrderedDict +from operator import attrgetter + +import entry +from entry import Entry +import fdt_util +import tools + +class Image: + """A Image, representing an output from binman + + An image is comprised of a collection of entries each containing binary + data. The image size must be large enough to hold all of this data. + + This class implements the various operations needed for images. + + Atrtributes: + _node: Node object that contains the image definition in device tree + _name: Image name + _size: Image size in bytes, or None if not known yet + _align_size: Image size alignment, or None + _pad_before: Number of bytes before the first entry starts. This + effectively changes the place where entry position 0 starts + _pad_after: Number of bytes after the last entry ends. The last + entry will finish on or before this boundary + _pad_byte: Byte to use to pad the image where there is no entry + _filename: Output filename for image + _sort: True if entries should be sorted by position, False if they + must be in-order in the device tree description + _skip_at_start: Number of bytes before the first entry starts. These + effecively adjust the starting position of entries. For example, + if _pad_before is 16, then the first entry would start at 16. + An entry with pos = 20 would in fact be written at position 4 + in the image file. + _end_4gb: Indicates that the image ends at the 4GB boundary. This is + used for x86 images, which want to use positions such that a + memory address (like 0xff800000) is the first entry position. + This causes _skip_at_start to be set to the starting memory + address. + _entries: OrderedDict() of entries + """ + def __init__(self, name, node): + self._node = node + self._name = name + self._size = None + self._align_size = None + self._pad_before = 0 + self._pad_after = 0 + self._pad_byte = 0 + self._filename = '%s.bin' % self._name + self._sort = False + self._skip_at_start = 0 + self._end_4gb = False + self._entries = OrderedDict() + + self._ReadNode() + self._ReadEntries() + + def _ReadNode(self): + """Read properties from the image node""" + self._size = fdt_util.GetInt(self._node, 'size') + self._align_size = fdt_util.GetInt(self._node, 'align-size') + if tools.NotPowerOfTwo(self._align_size): + self._Raise("Alignment size %s must be a power of two" % + self._align_size) + self._pad_before = fdt_util.GetInt(self._node, 'pad-before', 0) + self._pad_after = fdt_util.GetInt(self._node, 'pad-after', 0) + self._pad_byte = fdt_util.GetInt(self._node, 'pad-byte', 0) + filename = fdt_util.GetString(self._node, 'filename') + if filename: + self._filename = filename + self._sort = fdt_util.GetBool(self._node, 'sort-by-pos') + self._end_4gb = fdt_util.GetBool(self._node, 'end-at-4gb') + if self._end_4gb and not self._size: + self._Raise("Image size must be provided when using end-at-4gb") + if self._end_4gb: + self._skip_at_start = 0x100000000 - self._size + + def CheckSize(self): + """Check that the image contents does not exceed its size, etc.""" + contents_size = 0 + for entry in self._entries.values(): + contents_size = max(contents_size, entry.pos + entry.size) + + contents_size -= self._skip_at_start + + size = self._size + if not size: + size = self._pad_before + contents_size + self._pad_after + size = tools.Align(size, self._align_size) + + if self._size and contents_size > self._size: + self._Raise("contents size %#x (%d) exceeds image size %#x (%d)" % + (contents_size, contents_size, self._size, self._size)) + if not self._size: + self._size = size + if self._size != tools.Align(self._size, self._align_size): + self._Raise("Size %#x (%d) does not match align-size %#x (%d)" % + (self._size, self._size, self._align_size, self._align_size)) + + def _Raise(self, msg): + """Raises an error for this image + + Args: + msg: Error message to use in the raise string + Raises: + ValueError() + """ + raise ValueError("Image '%s': %s" % (self._node.path, msg)) + + def _ReadEntries(self): + for node in self._node.subnodes: + self._entries[node.name] = Entry.Create(self, node) + + def FindEntryType(self, etype): + """Find an entry type in the image + + Args: + etype: Entry type to find + Returns: + entry matching that type, or None if not found + """ + for entry in self._entries.values(): + if entry.etype == etype: + return entry + return None + + def GetEntryContents(self): + """Call ObtainContents() for each entry + + This calls each entry's ObtainContents() a few times until they all + return True. We stop calling an entry's function once it returns + True. This allows the contents of one entry to depend on another. + + After 3 rounds we give up since it's likely an error. + """ + todo = self._entries.values() + for passnum in range(3): + next_todo = [] + for entry in todo: + if not entry.ObtainContents(): + next_todo.append(entry) + todo = next_todo + if not todo: + break + + def _SetEntryPosSize(self, name, pos, size): + """Set the position and size of an entry + + Args: + name: Entry name to update + pos: New position + size: New size + """ + entry = self._entries.get(name) + if not entry: + self._Raise("Unable to set pos/size for unknown entry '%s'" % name) + entry.SetPositionSize(self._skip_at_start + pos, size) + + def GetEntryPositions(self): + """Handle entries that want to set the position/size of other entries + + This calls each entry's GetPositions() method. If it returns a list + of entries to update, it updates them. + """ + for entry in self._entries.values(): + pos_dict = entry.GetPositions() + for name, info in pos_dict.iteritems(): + self._SetEntryPosSize(name, *info) + + def PackEntries(self): + """Pack all entries into the image""" + pos = self._skip_at_start + for entry in self._entries.values(): + pos = entry.Pack(pos) + + def _SortEntries(self): + """Sort entries by position""" + entries = sorted(self._entries.values(), key=lambda entry: entry.pos) + self._entries.clear() + for entry in entries: + self._entries[entry._node.name] = entry + + def CheckEntries(self): + """Check that entries do not overlap or extend outside the image""" + if self._sort: + self._SortEntries() + pos = 0 + prev_name = 'None' + for entry in self._entries.values(): + if (entry.pos < self._skip_at_start or + entry.pos >= self._skip_at_start + self._size): + entry.Raise("Position %#x (%d) is outside the image starting " + "at %#x (%d)" % + (entry.pos, entry.pos, self._skip_at_start, + self._skip_at_start)) + if entry.pos < pos: + entry.Raise("Position %#x (%d) overlaps with previous entry '%s' " + "ending at %#x (%d)" % + (entry.pos, entry.pos, prev_name, pos, pos)) + pos = entry.pos + entry.size + prev_name = entry.GetPath() + + def ProcessEntryContents(self): + """Call the ProcessContents() method for each entry + + This is intended to adjust the contents as needed by the entry type. + """ + for entry in self._entries.values(): + entry.ProcessContents() + + def BuildImage(self): + """Write the image to a file""" + fname = tools.GetOutputFilename(self._filename) + with open(fname, 'wb') as fd: + fd.write(chr(self._pad_byte) * self._size) + + for entry in self._entries.values(): + data = entry.GetData() + fd.seek(self._pad_before + entry.pos - self._skip_at_start) + fd.write(data)
Hi Simon,
- Fix the -b option
+Features +--------
then -> them?
+Type:
binman {
pad-byte = <0xff>;
blob {
u-boot {
+pos:
+align:
+size:
contents.
+pad-before:
+pad-after:
+align-size:
+align-end:
+filename:
u-boot.bin
+type:
+size:
1MB image.
+align-size:
+pad-before:
+pad-after:
+pad-byte:
+filename:
+sort-by-pos:
not known a priori.
+multiple-images:
binman {
multiple-images;
image1 {
u-boot {
image2 {
spl {
u-boot {
+end-at-4gb:
typo: esoteric
+To do +-----
- entry (since the input file may not always specify these)
- to use device tree (such as a very small SPL image)
- which is then placed in the image)
- configurable build directory
- Makefile, this will be automatic
Only reviewed the doc. Will do some testing.
[snip]
Regards, Bin
Add entries to support some standard U-Boot binaries, such as u-boot.bin, u-boot.dtb, etc. Also add some tests for these.
Changes in v4: None Changes in v3: None Changes in v2: None
tools/binman/entry_test.py | 27 + tools/binman/etype/_testing.py | 26 + tools/binman/etype/blob.py | 37 ++ tools/binman/etype/u_boot.py | 17 + tools/binman/etype/u_boot_dtb.py | 17 + tools/binman/etype/u_boot_nodtb.py | 17 + tools/binman/etype/u_boot_spl.py | 17 + tools/binman/func_test.py | 542 +++++++++++++++++++++ tools/binman/test/01_invalid.dts | 5 + tools/binman/test/02_missing_node.dts | 6 + tools/binman/test/03_empty.dts | 9 + tools/binman/test/04_invalid_entry.dts | 11 + tools/binman/test/05_simple.dts | 11 + tools/binman/test/06_dual_image.dts | 22 + tools/binman/test/07_bad_align.dts | 12 + tools/binman/test/08_pack.dts | 30 ++ tools/binman/test/09_pack_extra.dts | 35 ++ tools/binman/test/10_pack_align_power2.dts | 12 + tools/binman/test/11_pack_align_size_power2.dts | 12 + tools/binman/test/12_pack_inv_align.dts | 13 + tools/binman/test/13_pack_inv_size_align.dts | 13 + tools/binman/test/14_pack_overlap.dts | 16 + tools/binman/test/15_pack_overflow.dts | 12 + tools/binman/test/16_pack_image_overflow.dts | 13 + tools/binman/test/17_pack_image_size.dts | 13 + tools/binman/test/18_pack_image_align.dts | 13 + tools/binman/test/19_pack_inv_image_align.dts | 14 + .../binman/test/20_pack_inv_image_align_power2.dts | 13 + tools/binman/test/21_image_pad.dts | 16 + tools/binman/test/22_image_name.dts | 21 + tools/binman/test/23_blob.dts | 12 + tools/binman/test/24_sorted.dts | 17 + tools/binman/test/25_pack_zero_size.dts | 15 + tools/binman/test/26_pack_u_boot_dtb.dts | 14 + 34 files changed, 1080 insertions(+) create mode 100644 tools/binman/entry_test.py create mode 100644 tools/binman/etype/_testing.py create mode 100644 tools/binman/etype/blob.py create mode 100644 tools/binman/etype/u_boot.py create mode 100644 tools/binman/etype/u_boot_dtb.py create mode 100644 tools/binman/etype/u_boot_nodtb.py create mode 100644 tools/binman/etype/u_boot_spl.py create mode 100644 tools/binman/func_test.py create mode 100644 tools/binman/test/01_invalid.dts create mode 100644 tools/binman/test/02_missing_node.dts create mode 100644 tools/binman/test/03_empty.dts create mode 100644 tools/binman/test/04_invalid_entry.dts create mode 100644 tools/binman/test/05_simple.dts create mode 100644 tools/binman/test/06_dual_image.dts create mode 100644 tools/binman/test/07_bad_align.dts create mode 100644 tools/binman/test/08_pack.dts create mode 100644 tools/binman/test/09_pack_extra.dts create mode 100644 tools/binman/test/10_pack_align_power2.dts create mode 100644 tools/binman/test/11_pack_align_size_power2.dts create mode 100644 tools/binman/test/12_pack_inv_align.dts create mode 100644 tools/binman/test/13_pack_inv_size_align.dts create mode 100644 tools/binman/test/14_pack_overlap.dts create mode 100644 tools/binman/test/15_pack_overflow.dts create mode 100644 tools/binman/test/16_pack_image_overflow.dts create mode 100644 tools/binman/test/17_pack_image_size.dts create mode 100644 tools/binman/test/18_pack_image_align.dts create mode 100644 tools/binman/test/19_pack_inv_image_align.dts create mode 100644 tools/binman/test/20_pack_inv_image_align_power2.dts create mode 100644 tools/binman/test/21_image_pad.dts create mode 100644 tools/binman/test/22_image_name.dts create mode 100644 tools/binman/test/23_blob.dts create mode 100644 tools/binman/test/24_sorted.dts create mode 100644 tools/binman/test/25_pack_zero_size.dts create mode 100644 tools/binman/test/26_pack_u_boot_dtb.dts
diff --git a/tools/binman/entry_test.py b/tools/binman/entry_test.py new file mode 100644 index 0000000..8a9ae01 --- /dev/null +++ b/tools/binman/entry_test.py @@ -0,0 +1,27 @@ +# +# Copyright (c) 2016 Google, Inc +# Written by Simon Glass sjg@chromium.org +# +# SPDX-License-Identifier: GPL-2.0+ +# +# Test for the Entry class + +import collections +import unittest + +import entry + +class TestEntry(unittest.TestCase): + def testEntryContents(self): + """Test the Entry bass class""" + base_entry = entry.Entry(None, None, None, read_node=False) + self.assertEqual(True, base_entry.ObtainContents()) + + def testUnknownEntry(self): + """Test that unknown entry types are detected""" + Node = collections.namedtuple('Node', ['name', 'path']) + node = Node('invalid-name', 'invalid-path') + with self.assertRaises(ValueError) as e: + entry.Entry.Create(None, node, node.name) + self.assertIn("Unknown entry type 'invalid-name' in node " + "'invalid-path'", str(e.exception)) diff --git a/tools/binman/etype/_testing.py b/tools/binman/etype/_testing.py new file mode 100644 index 0000000..1783098 --- /dev/null +++ b/tools/binman/etype/_testing.py @@ -0,0 +1,26 @@ +# Copyright (c) 2016 Google, Inc +# Written by Simon Glass sjg@chromium.org +# +# SPDX-License-Identifier: GPL-2.0+ +# +# Entry-type module for testing purposes. Not used in real images. +# + +from entry import Entry +import fdt_util +import tools + +class Entry__testing(Entry): + def __init__(self, image, etype, node): + Entry.__init__(self, image, etype, node) + + def ObtainContents(self): + self.data = 'a' + self.contents_size = len(self.data) + return True + + def ReadContents(self): + return True + + def GetPositions(self): + return {'invalid-entry': [1, 2]} diff --git a/tools/binman/etype/blob.py b/tools/binman/etype/blob.py new file mode 100644 index 0000000..def2164 --- /dev/null +++ b/tools/binman/etype/blob.py @@ -0,0 +1,37 @@ +# Copyright (c) 2016 Google, Inc +# Written by Simon Glass sjg@chromium.org +# +# SPDX-License-Identifier: GPL-2.0+ +# +# Entry-type module for blobs, which are binary objects read from files +# + +from entry import Entry +import fdt_util +import tools + +class Entry_blob(Entry): + def __init__(self, image, etype, node): + Entry.__init__(self, image, etype, node) + self._filename = fdt_util.GetString(self._node, "filename", self.etype) + + def ObtainContents(self): + self._filename = self.GetDefaultFilename() + self._pathname = tools.GetInputFilename(self._filename) + self.ReadContents() + return True + + def ReadContents(self): + with open(self._pathname) as fd: + # We assume the data is small enough to fit into memory. If this + # is used for large filesystem image that might not be true. + # In that case, Image.BuildImage() could be adjusted to use a + # new Entry method which can read in chunks. Then we could copy + # the data in chunks and avoid reading it all at once. For now + # this seems like an unnecessary complication. + self.data = fd.read() + self.contents_size = len(self.data) + return True + + def GetDefaultFilename(self): + return self._filename diff --git a/tools/binman/etype/u_boot.py b/tools/binman/etype/u_boot.py new file mode 100644 index 0000000..1fcff73 --- /dev/null +++ b/tools/binman/etype/u_boot.py @@ -0,0 +1,17 @@ +# Copyright (c) 2016 Google, Inc +# Written by Simon Glass sjg@chromium.org +# +# SPDX-License-Identifier: GPL-2.0+ +# +# Entry-type module for U-Boot binary +# + +from entry import Entry +from blob import Entry_blob + +class Entry_u_boot(Entry_blob): + def __init__(self, image, etype, node): + Entry_blob.__init__(self, image, etype, node) + + def GetDefaultFilename(self): + return 'u-boot.bin' diff --git a/tools/binman/etype/u_boot_dtb.py b/tools/binman/etype/u_boot_dtb.py new file mode 100644 index 0000000..1122c95 --- /dev/null +++ b/tools/binman/etype/u_boot_dtb.py @@ -0,0 +1,17 @@ +# Copyright (c) 2016 Google, Inc +# Written by Simon Glass sjg@chromium.org +# +# SPDX-License-Identifier: GPL-2.0+ +# +# Entry-type module for U-Boot device tree +# + +from entry import Entry +from blob import Entry_blob + +class Entry_u_boot_dtb(Entry_blob): + def __init__(self, image, etype, node): + Entry_blob.__init__(self, image, etype, node) + + def GetDefaultFilename(self): + return 'u-boot.dtb' diff --git a/tools/binman/etype/u_boot_nodtb.py b/tools/binman/etype/u_boot_nodtb.py new file mode 100644 index 0000000..3721c3b --- /dev/null +++ b/tools/binman/etype/u_boot_nodtb.py @@ -0,0 +1,17 @@ +# Copyright (c) 2016 Google, Inc +# Written by Simon Glass sjg@chromium.org +# +# SPDX-License-Identifier: GPL-2.0+ +# +# Entry-type module for 'u-boot-nodtb.bin' +# + +from entry import Entry +from blob import Entry_blob + +class Entry_u_boot_nodtb(Entry_blob): + def __init__(self, image, etype, node): + Entry_blob.__init__(self, image, etype, node) + + def GetDefaultFilename(self): + return 'u-boot-nodtb.bin' diff --git a/tools/binman/etype/u_boot_spl.py b/tools/binman/etype/u_boot_spl.py new file mode 100644 index 0000000..68b0148 --- /dev/null +++ b/tools/binman/etype/u_boot_spl.py @@ -0,0 +1,17 @@ +# Copyright (c) 2016 Google, Inc +# Written by Simon Glass sjg@chromium.org +# +# SPDX-License-Identifier: GPL-2.0+ +# +# Entry-type module for spl/u-boot-spl.bin +# + +from entry import Entry +from blob import Entry_blob + +class Entry_u_boot_spl(Entry_blob): + def __init__(self, image, etype, node): + Entry_blob.__init__(self, image, etype, node) + + def GetDefaultFilename(self): + return 'spl/u-boot-spl.bin' diff --git a/tools/binman/func_test.py b/tools/binman/func_test.py new file mode 100644 index 0000000..bf6e9ed --- /dev/null +++ b/tools/binman/func_test.py @@ -0,0 +1,542 @@ +# +# Copyright (c) 2016 Google, Inc +# Written by Simon Glass sjg@chromium.org +# +# SPDX-License-Identifier: GPL-2.0+ +# +# To run a single test, change to this directory, and: +# +# python -m unittest func_test.TestFunctional.testHelp + +from optparse import OptionParser +import os +import shutil +import struct +import sys +import tempfile +import unittest + +import binman +import cmdline +import command +import control +import entry +import fdt_select +import fdt_util +import tools +import tout + +# Contents of test files, corresponding to different entry types +U_BOOT_DATA = '1234' +U_BOOT_IMG_DATA = 'img' +U_BOOT_SPL_DATA = '567' +BLOB_DATA = '89' +ME_DATA = '0abcd' +VGA_DATA = 'vga' +U_BOOT_DTB_DATA = 'udtb' +X86_START16_DATA = 'start16' +U_BOOT_NODTB_DATA = 'nodtb with microcode pointer somewhere in here' + +class TestFunctional(unittest.TestCase): + """Functional tests for binman + + Most of these use a sample .dts file to build an image and then check + that it looks correct. The sample files are in the test/ subdirectory + and are numbered. + + For each entry type a very small test file is created using fixed + string contents. This makes it easy to test that things look right, and + debug problems. + + In some cases a 'real' file must be used - these are also supplied in + the test/ diurectory. + """ + @classmethod + def setUpClass(self): + # Handle the case where argv[0] is 'python' + self._binman_dir = os.path.dirname(os.path.realpath(sys.argv[0])) + self._binman_pathname = os.path.join(self._binman_dir, 'binman') + + # Create a temporary directory for input files + self._indir = tempfile.mkdtemp(prefix='binmant.') + + # Create some test files + TestFunctional._MakeInputFile('u-boot.bin', U_BOOT_DATA) + TestFunctional._MakeInputFile('u-boot.img', U_BOOT_IMG_DATA) + TestFunctional._MakeInputFile('spl/u-boot-spl.bin', U_BOOT_SPL_DATA) + TestFunctional._MakeInputFile('blobfile', BLOB_DATA) + TestFunctional._MakeInputFile('u-boot.dtb', U_BOOT_DTB_DATA) + TestFunctional._MakeInputFile('u-boot-nodtb.bin', U_BOOT_NODTB_DATA) + self._output_setup = False + + @classmethod + def tearDownClass(self): + """Remove the temporary input directory and its contents""" + if self._indir: + shutil.rmtree(self._indir) + self._indir = None + + def setUp(self): + # Enable this to turn on debugging output + # tout.Init(tout.DEBUG) + command.test_result = None + + def tearDown(self): + """Remove the temporary output directory""" + tools._FinaliseForTest() + + def _RunBinman(self, *args, **kwargs): + """Run binman using the command line + + Args: + Arguments to pass, as a list of strings + kwargs: Arguments to pass to Command.RunPipe() + """ + result = command.RunPipe([[self._binman_pathname] + list(args)], + capture=True, capture_stderr=True, raise_on_error=False) + if result.return_code and kwargs.get('raise_on_error', True): + raise Exception("Error running '%s': %s" % (' '.join(args), + result.stdout + result.stderr)) + return result + + def _DoBinman(self, *args): + """Run binman using directly (in the same process) + + Args: + Arguments to pass, as a list of strings + Returns: + Return value (0 for success) + """ + (options, args) = cmdline.ParseArgs(list(args)) + options.pager = 'binman-invalid-pager' + options.build_dir = self._indir + + # For testing, you can force an increase in verbosity here + # options.verbosity = tout.DEBUG + return control.Binman(options, args) + + def _DoTestFile(self, fname): + """Run binman with a given test file + + Args: + fname: Device tree source filename to use (e.g. 05_simple.dts) + """ + return self._DoBinman('-p', '-I', self._indir, + '-d', self.TestFile(fname)) + + def _SetupDtb(self, fname, outfile='u-boot.dtb'): + if not self._output_setup: + tools.PrepareOutputDir(self._indir, True) + self._output_setup = True + dtb = fdt_util.EnsureCompiled(self.TestFile(fname)) + with open(dtb) as fd: + data = fd.read() + TestFunctional._MakeInputFile(outfile, data) + + def _DoReadFile(self, fname, use_real_dtb=False): + """Run binman and return the resulting image + + This runs binman with a given test file and then reads the resulting + output file. It is a shortcut function since most tests need to do + these steps. + + Raises an assertion failure if binman returns a non-zero exit code. + + Args: + fname: Device tree source filename to use (e.g. 05_simple.dts) + use_real_dtb: True to use the test file as the contents of + the u-boot-dtb entry. Normally this is not needed and the + test contents (the U_BOOT_DTB_DATA string) can be used. + But in some test we need the real contents. + """ + # Use the compiled test file as the u-boot-dtb input + if use_real_dtb: + self._SetupDtb(fname) + + try: + retcode = self._DoTestFile(fname) + self.assertEqual(0, retcode) + + # Find the (only) image, read it and return its contents + image = control.images['image'] + fname = tools.GetOutputFilename('image.bin') + self.assertTrue(os.path.exists(fname)) + with open(fname) as fd: + return fd.read() + finally: + # Put the test file back + if use_real_dtb: + TestFunctional._MakeInputFile('u-boot.dtb', U_BOOT_DTB_DATA) + + @classmethod + def _MakeInputFile(self, fname, contents): + """Create a new test input file, creating directories as needed + + Args: + fname: Filenaem to create + contents: File contents to write in to the file + Returns: + Full pathname of file created + """ + pathname = os.path.join(self._indir, fname) + dirname = os.path.dirname(pathname) + if dirname and not os.path.exists(dirname): + os.makedirs(dirname) + with open(pathname, 'wb') as fd: + fd.write(contents) + return pathname + + @classmethod + def TestFile(self, fname): + return os.path.join(self._binman_dir, 'test', fname) + + def AssertInList(self, grep_list, target): + """Assert that at least one of a list of things is in a target + + Args: + grep_list: List of strings to check + target: Target string + """ + for grep in grep_list: + if grep in target: + return + self.fail("Error: '%' not found in '%s'" % (grep_list, target)) + + def CheckNoGaps(self, entries): + """Check that all entries fit together without gaps + + Args: + entries: List of entries to check + """ + pos = 0 + for entry in entries.values(): + self.assertEqual(pos, entry.pos) + pos += entry.size + + def testRun(self): + """Test a basic run with valid args""" + result = self._RunBinman('-h') + + def testFullHelp(self): + """Test that the full help is displayed with -H""" + result = self._RunBinman('-H') + help_file = os.path.join(self._binman_dir, 'README') + self.assertEqual(len(result.stdout), os.path.getsize(help_file)) + self.assertEqual(0, len(result.stderr)) + self.assertEqual(0, result.return_code) + + def testFullHelpInternal(self): + """Test that the full help is displayed with -H""" + try: + command.test_result = command.CommandResult() + result = self._DoBinman('-H') + help_file = os.path.join(self._binman_dir, 'README') + finally: + command.test_result = None + + def testHelp(self): + """Test that the basic help is displayed with -h""" + result = self._RunBinman('-h') + self.assertTrue(len(result.stdout) > 200) + self.assertEqual(0, len(result.stderr)) + self.assertEqual(0, result.return_code) + + # Not yet available. + def testBoard(self): + """Test that we can run it with a specific board""" + self._SetupDtb('05_simple.dts', 'sandbox/u-boot.dtb') + TestFunctional._MakeInputFile('sandbox/u-boot.bin', U_BOOT_DATA) + result = self._DoBinman('-b', 'sandbox') + self.assertEqual(0, result) + + def testNeedBoard(self): + """Test that we get an error when no board ius supplied""" + with self.assertRaises(ValueError) as e: + result = self._DoBinman() + self.assertIn("Must provide a board to process (use -b <board>)", + str(e.exception)) + + def testMissingDt(self): + """Test that an invalid device tree file generates an error""" + with self.assertRaises(Exception) as e: + self._RunBinman('-d', 'missing_file') + # We get one error from libfdt, and a different one from fdtget. + self.AssertInList(["Couldn't open blob from 'missing_file'", + 'No such file or directory'], str(e.exception)) + + def testBrokenDt(self): + """Test that an invalid device tree source file generates an error + + Since this is a source file it should be compiled and the error + will come from the device-tree compiler (dtc). + """ + with self.assertRaises(Exception) as e: + self._RunBinman('-d', self.TestFile('01_invalid.dts')) + self.assertIn("FATAL ERROR: Unable to parse input tree", + str(e.exception)) + + def testMissingNode(self): + """Test that a device tree without a 'binman' node generates an error""" + with self.assertRaises(Exception) as e: + self._DoBinman('-d', self.TestFile('02_missing_node.dts')) + self.assertIn("does not have a 'binman' node", str(e.exception)) + + def testEmpty(self): + """Test that an empty binman node works OK (i.e. does nothing)""" + result = self._RunBinman('-d', self.TestFile('03_empty.dts')) + self.assertEqual(0, len(result.stderr)) + self.assertEqual(0, result.return_code) + + def testInvalidEntry(self): + """Test that an invalid entry is flagged""" + with self.assertRaises(Exception) as e: + result = self._RunBinman('-d', + self.TestFile('04_invalid_entry.dts')) + #print e.exception + self.assertIn("Unknown entry type 'not-a-valid-type' in node " + "'/binman/not-a-valid-type'", str(e.exception)) + + def testSimple(self): + """Test a simple binman with a single file""" + data = self._DoReadFile('05_simple.dts') + self.assertEqual(U_BOOT_DATA, data) + + def testDual(self): + """Test that we can handle creating two images + + This also tests image padding. + """ + retcode = self._DoTestFile('06_dual_image.dts') + self.assertEqual(0, retcode) + + image = control.images['image1'] + self.assertEqual(len(U_BOOT_DATA), image._size) + fname = tools.GetOutputFilename('image1.bin') + self.assertTrue(os.path.exists(fname)) + with open(fname) as fd: + data = fd.read() + self.assertEqual(U_BOOT_DATA, data) + + image = control.images['image2'] + self.assertEqual(3 + len(U_BOOT_DATA) + 5, image._size) + fname = tools.GetOutputFilename('image2.bin') + self.assertTrue(os.path.exists(fname)) + with open(fname) as fd: + data = fd.read() + self.assertEqual(U_BOOT_DATA, data[3:7]) + self.assertEqual(chr(0) * 3, data[:3]) + self.assertEqual(chr(0) * 5, data[7:]) + + def testBadAlign(self): + """Test that an invalid alignment value is detected""" + with self.assertRaises(ValueError) as e: + self._DoTestFile('07_bad_align.dts') + self.assertIn("Node '/binman/u-boot': Alignment 23 must be a power " + "of two", str(e.exception)) + + def testPackSimple(self): + """Test that packing works as expected""" + retcode = self._DoTestFile('08_pack.dts') + self.assertEqual(0, retcode) + self.assertIn('image', control.images) + image = control.images['image'] + entries = image._entries + self.assertEqual(5, len(entries)) + + # First u-boot + self.assertIn('u-boot', entries) + entry = entries['u-boot'] + self.assertEqual(0, entry.pos) + self.assertEqual(len(U_BOOT_DATA), entry.size) + + # Second u-boot, aligned to 16-byte boundary + self.assertIn('u-boot-align', entries) + entry = entries['u-boot-align'] + self.assertEqual(16, entry.pos) + self.assertEqual(len(U_BOOT_DATA), entry.size) + + # Third u-boot, size 23 bytes + self.assertIn('u-boot-size', entries) + entry = entries['u-boot-size'] + self.assertEqual(20, entry.pos) + self.assertEqual(len(U_BOOT_DATA), entry.contents_size) + self.assertEqual(23, entry.size) + + # Fourth u-boot, placed immediate after the above + self.assertIn('u-boot-next', entries) + entry = entries['u-boot-next'] + self.assertEqual(43, entry.pos) + self.assertEqual(len(U_BOOT_DATA), entry.size) + + # Fifth u-boot, placed at a fixed position + self.assertIn('u-boot-fixed', entries) + entry = entries['u-boot-fixed'] + self.assertEqual(61, entry.pos) + self.assertEqual(len(U_BOOT_DATA), entry.size) + + self.assertEqual(65, image._size) + + def testPackExtra(self): + """Test that extra packing feature works as expected""" + retcode = self._DoTestFile('09_pack_extra.dts') + + self.assertEqual(0, retcode) + self.assertIn('image', control.images) + image = control.images['image'] + entries = image._entries + self.assertEqual(5, len(entries)) + + # First u-boot with padding before and after + self.assertIn('u-boot', entries) + entry = entries['u-boot'] + self.assertEqual(0, entry.pos) + self.assertEqual(3, entry.pad_before) + self.assertEqual(3 + 5 + len(U_BOOT_DATA), entry.size) + + # Second u-boot has an aligned size, but it has no effect + self.assertIn('u-boot-align-size-nop', entries) + entry = entries['u-boot-align-size-nop'] + self.assertEqual(12, entry.pos) + self.assertEqual(4, entry.size) + + # Third u-boot has an aligned size too + self.assertIn('u-boot-align-size', entries) + entry = entries['u-boot-align-size'] + self.assertEqual(16, entry.pos) + self.assertEqual(32, entry.size) + + # Fourth u-boot has an aligned end + self.assertIn('u-boot-align-end', entries) + entry = entries['u-boot-align-end'] + self.assertEqual(48, entry.pos) + self.assertEqual(16, entry.size) + + # Fifth u-boot immediately afterwards + self.assertIn('u-boot-align-both', entries) + entry = entries['u-boot-align-both'] + self.assertEqual(64, entry.pos) + self.assertEqual(64, entry.size) + + self.CheckNoGaps(entries) + self.assertEqual(128, image._size) + + def testPackAlignPowerOf2(self): + """Test that invalid entry alignment is detected""" + with self.assertRaises(ValueError) as e: + self._DoTestFile('10_pack_align_power2.dts') + self.assertIn("Node '/binman/u-boot': Alignment 5 must be a power " + "of two", str(e.exception)) + + def testPackAlignSizePowerOf2(self): + """Test that invalid entry size alignment is detected""" + with self.assertRaises(ValueError) as e: + self._DoTestFile('11_pack_align_size_power2.dts') + self.assertIn("Node '/binman/u-boot': Alignment size 55 must be a " + "power of two", str(e.exception)) + + def testPackInvalidAlign(self): + """Test detection of an position that does not match its alignment""" + with self.assertRaises(ValueError) as e: + self._DoTestFile('12_pack_inv_align.dts') + self.assertIn("Node '/binman/u-boot': Position 0x5 (5) does not match " + "align 0x4 (4)", str(e.exception)) + + def testPackInvalidSizeAlign(self): + """Test that invalid entry size alignment is detected""" + with self.assertRaises(ValueError) as e: + self._DoTestFile('13_pack_inv_size_align.dts') + self.assertIn("Node '/binman/u-boot': Size 0x5 (5) does not match " + "align-size 0x4 (4)", str(e.exception)) + + def testPackOverlap(self): + """Test that overlapping regions are detected""" + with self.assertRaises(ValueError) as e: + self._DoTestFile('14_pack_overlap.dts') + self.assertIn("Node '/binman/u-boot-align': Position 0x3 (3) overlaps " + "with previous entry '/binman/u-boot' ending at 0x4 (4)", + str(e.exception)) + + def testPackEntryOverflow(self): + """Test that entries that overflow their size are detected""" + with self.assertRaises(ValueError) as e: + self._DoTestFile('15_pack_overflow.dts') + self.assertIn("Node '/binman/u-boot': Entry contents size is 0x4 (4) " + "but entry size is 0x3 (3)", str(e.exception)) + + def testPackImageOverflow(self): + """Test that entries which overflow the image size are detected""" + with self.assertRaises(ValueError) as e: + self._DoTestFile('16_pack_image_overflow.dts') + self.assertIn("Image '/binman': contents size 0x4 (4) exceeds image " + "size 0x3 (3)", str(e.exception)) + + def testPackImageSize(self): + """Test that the image size can be set""" + retcode = self._DoTestFile('17_pack_image_size.dts') + self.assertEqual(0, retcode) + self.assertIn('image', control.images) + image = control.images['image'] + self.assertEqual(7, image._size) + + def testPackImageSizeAlign(self): + """Test that image size alignemnt works as expected""" + retcode = self._DoTestFile('18_pack_image_align.dts') + self.assertEqual(0, retcode) + self.assertIn('image', control.images) + image = control.images['image'] + self.assertEqual(16, image._size) + + def testPackInvalidImageAlign(self): + """Test that invalid image alignment is detected""" + with self.assertRaises(ValueError) as e: + self._DoTestFile('19_pack_inv_image_align.dts') + self.assertIn("Image '/binman': Size 0x7 (7) does not match " + "align-size 0x8 (8)", str(e.exception)) + + def testPackAlignPowerOf2(self): + """Test that invalid image alignment is detected""" + with self.assertRaises(ValueError) as e: + self._DoTestFile('20_pack_inv_image_align_power2.dts') + self.assertIn("Image '/binman': Alignment size 131 must be a power of " + "two", str(e.exception)) + + def testImagePadByte(self): + """Test that the image pad byte can be specified""" + data = self._DoReadFile('21_image_pad.dts') + self.assertEqual(U_BOOT_SPL_DATA + (chr(0xff) * 9) + U_BOOT_DATA, data) + + def testImageName(self): + """Test that image files can be named""" + retcode = self._DoTestFile('22_image_name.dts') + self.assertEqual(0, retcode) + image = control.images['image1'] + fname = tools.GetOutputFilename('test-name') + self.assertTrue(os.path.exists(fname)) + + image = control.images['image2'] + fname = tools.GetOutputFilename('test-name.xx') + self.assertTrue(os.path.exists(fname)) + + def testBlobFilename(self): + """Test that generic blobs can be provided by filename""" + data = self._DoReadFile('23_blob.dts') + self.assertEqual(BLOB_DATA, data) + + def testPackSorted(self): + """Test that entries can be sorted""" + data = self._DoReadFile('24_sorted.dts') + self.assertEqual(chr(0) * 5 + U_BOOT_SPL_DATA + chr(0) * 2 + + U_BOOT_DATA, data) + + def testPackZeroPosition(self): + """Test that an entry at position 0 is not given a new position""" + with self.assertRaises(ValueError) as e: + self._DoTestFile('25_pack_zero_size.dts') + self.assertIn("Node '/binman/u-boot-spl': Position 0x0 (0) overlaps " + "with previous entry '/binman/u-boot' ending at 0x4 (4)", + str(e.exception)) + + def testPackUbootDtb(self): + """Test that a device tree can be added to U-Boot""" + data = self._DoReadFile('26_pack_u_boot_dtb.dts') + self.assertEqual(U_BOOT_NODTB_DATA + U_BOOT_DTB_DATA, data) diff --git a/tools/binman/test/01_invalid.dts b/tools/binman/test/01_invalid.dts new file mode 100644 index 0000000..7d00455 --- /dev/null +++ b/tools/binman/test/01_invalid.dts @@ -0,0 +1,5 @@ +/dts-v1/; + +/ { + #address-cells = <1>; + #size-cells = <1>; diff --git a/tools/binman/test/02_missing_node.dts b/tools/binman/test/02_missing_node.dts new file mode 100644 index 0000000..3a51ec2 --- /dev/null +++ b/tools/binman/test/02_missing_node.dts @@ -0,0 +1,6 @@ +/dts-v1/; + +/ { + #address-cells = <1>; + #size-cells = <1>; +}; diff --git a/tools/binman/test/03_empty.dts b/tools/binman/test/03_empty.dts new file mode 100644 index 0000000..493c9a0 --- /dev/null +++ b/tools/binman/test/03_empty.dts @@ -0,0 +1,9 @@ +/dts-v1/; + +/ { + #address-cells = <1>; + #size-cells = <1>; + + binman { + }; +}; diff --git a/tools/binman/test/04_invalid_entry.dts b/tools/binman/test/04_invalid_entry.dts new file mode 100644 index 0000000..b043455 --- /dev/null +++ b/tools/binman/test/04_invalid_entry.dts @@ -0,0 +1,11 @@ +/dts-v1/; + +/ { + #address-cells = <1>; + #size-cells = <1>; + + binman { + not-a-valid-type { + }; + }; +}; diff --git a/tools/binman/test/05_simple.dts b/tools/binman/test/05_simple.dts new file mode 100644 index 0000000..3771aa2 --- /dev/null +++ b/tools/binman/test/05_simple.dts @@ -0,0 +1,11 @@ +/dts-v1/; + +/ { + #address-cells = <1>; + #size-cells = <1>; + + binman { + u-boot { + }; + }; +}; diff --git a/tools/binman/test/06_dual_image.dts b/tools/binman/test/06_dual_image.dts new file mode 100644 index 0000000..78be16f --- /dev/null +++ b/tools/binman/test/06_dual_image.dts @@ -0,0 +1,22 @@ +/dts-v1/; + +/ { + #address-cells = <1>; + #size-cells = <1>; + + binman { + multiple-images; + image1 { + u-boot { + }; + }; + + image2 { + pad-before = <3>; + pad-after = <5>; + + u-boot { + }; + }; + }; +}; diff --git a/tools/binman/test/07_bad_align.dts b/tools/binman/test/07_bad_align.dts new file mode 100644 index 0000000..123bb13 --- /dev/null +++ b/tools/binman/test/07_bad_align.dts @@ -0,0 +1,12 @@ +/dts-v1/; + +/ { + #address-cells = <1>; + #size-cells = <1>; + + binman { + u-boot { + align = <23>; + }; + }; +}; diff --git a/tools/binman/test/08_pack.dts b/tools/binman/test/08_pack.dts new file mode 100644 index 0000000..dc63d99 --- /dev/null +++ b/tools/binman/test/08_pack.dts @@ -0,0 +1,30 @@ +/dts-v1/; + +/ { + #address-cells = <1>; + #size-cells = <1>; + + binman { + u-boot { + }; + + u-boot-align { + type = "u-boot"; + align = <16>; + }; + + u-boot-size { + type = "u-boot"; + size = <23>; + }; + + u-boot-next { + type = "u-boot"; + }; + + u-boot-fixed { + type = "u-boot"; + pos = <61>; + }; + }; +}; diff --git a/tools/binman/test/09_pack_extra.dts b/tools/binman/test/09_pack_extra.dts new file mode 100644 index 0000000..0765707 --- /dev/null +++ b/tools/binman/test/09_pack_extra.dts @@ -0,0 +1,35 @@ +/dts-v1/; + +/ { + #address-cells = <1>; + #size-cells = <1>; + + binman { + u-boot { + pad-before = <3>; + pad-after = <5>; + }; + + u-boot-align-size-nop { + type = "u-boot"; + align-size = <4>; + }; + + u-boot-align-size { + type = "u-boot"; + align = <16>; + align-size = <32>; + }; + + u-boot-align-end { + type = "u-boot"; + align-end = <64>; + }; + + u-boot-align-both { + type = "u-boot"; + align= <64>; + align-end = <128>; + }; + }; +}; diff --git a/tools/binman/test/10_pack_align_power2.dts b/tools/binman/test/10_pack_align_power2.dts new file mode 100644 index 0000000..8f6253a --- /dev/null +++ b/tools/binman/test/10_pack_align_power2.dts @@ -0,0 +1,12 @@ +/dts-v1/; + +/ { + #address-cells = <1>; + #size-cells = <1>; + + binman { + u-boot { + align = <5>; + }; + }; +}; diff --git a/tools/binman/test/11_pack_align_size_power2.dts b/tools/binman/test/11_pack_align_size_power2.dts new file mode 100644 index 0000000..04f7672 --- /dev/null +++ b/tools/binman/test/11_pack_align_size_power2.dts @@ -0,0 +1,12 @@ +/dts-v1/; + +/ { + #address-cells = <1>; + #size-cells = <1>; + + binman { + u-boot { + align-size = <55>; + }; + }; +}; diff --git a/tools/binman/test/12_pack_inv_align.dts b/tools/binman/test/12_pack_inv_align.dts new file mode 100644 index 0000000..1d9d80a --- /dev/null +++ b/tools/binman/test/12_pack_inv_align.dts @@ -0,0 +1,13 @@ +/dts-v1/; + +/ { + #address-cells = <1>; + #size-cells = <1>; + + binman { + u-boot { + pos = <5>; + align = <4>; + }; + }; +}; diff --git a/tools/binman/test/13_pack_inv_size_align.dts b/tools/binman/test/13_pack_inv_size_align.dts new file mode 100644 index 0000000..dfafa13 --- /dev/null +++ b/tools/binman/test/13_pack_inv_size_align.dts @@ -0,0 +1,13 @@ +/dts-v1/; + +/ { + #address-cells = <1>; + #size-cells = <1>; + + binman { + u-boot { + size = <5>; + align-size = <4>; + }; + }; +}; diff --git a/tools/binman/test/14_pack_overlap.dts b/tools/binman/test/14_pack_overlap.dts new file mode 100644 index 0000000..611cfd9 --- /dev/null +++ b/tools/binman/test/14_pack_overlap.dts @@ -0,0 +1,16 @@ +/dts-v1/; + +/ { + #address-cells = <1>; + #size-cells = <1>; + + binman { + u-boot { + }; + + u-boot-align { + type = "u-boot"; + pos = <3>; + }; + }; +}; diff --git a/tools/binman/test/15_pack_overflow.dts b/tools/binman/test/15_pack_overflow.dts new file mode 100644 index 0000000..6f65433 --- /dev/null +++ b/tools/binman/test/15_pack_overflow.dts @@ -0,0 +1,12 @@ +/dts-v1/; + +/ { + #address-cells = <1>; + #size-cells = <1>; + + binman { + u-boot { + size = <3>; + }; + }; +}; diff --git a/tools/binman/test/16_pack_image_overflow.dts b/tools/binman/test/16_pack_image_overflow.dts new file mode 100644 index 0000000..6ae66f3 --- /dev/null +++ b/tools/binman/test/16_pack_image_overflow.dts @@ -0,0 +1,13 @@ +/dts-v1/; + +/ { + #address-cells = <1>; + #size-cells = <1>; + + binman { + size = <3>; + + u-boot { + }; + }; +}; diff --git a/tools/binman/test/17_pack_image_size.dts b/tools/binman/test/17_pack_image_size.dts new file mode 100644 index 0000000..2360eb5 --- /dev/null +++ b/tools/binman/test/17_pack_image_size.dts @@ -0,0 +1,13 @@ +/dts-v1/; + +/ { + #address-cells = <1>; + #size-cells = <1>; + + binman { + size = <7>; + + u-boot { + }; + }; +}; diff --git a/tools/binman/test/18_pack_image_align.dts b/tools/binman/test/18_pack_image_align.dts new file mode 100644 index 0000000..16cd2a4 --- /dev/null +++ b/tools/binman/test/18_pack_image_align.dts @@ -0,0 +1,13 @@ +/dts-v1/; + +/ { + #address-cells = <1>; + #size-cells = <1>; + + binman { + align-size = <16>; + + u-boot { + }; + }; +}; diff --git a/tools/binman/test/19_pack_inv_image_align.dts b/tools/binman/test/19_pack_inv_image_align.dts new file mode 100644 index 0000000..e5ee87b --- /dev/null +++ b/tools/binman/test/19_pack_inv_image_align.dts @@ -0,0 +1,14 @@ +/dts-v1/; + +/ { + #address-cells = <1>; + #size-cells = <1>; + + binman { + size = <7>; + align-size = <8>; + + u-boot { + }; + }; +}; diff --git a/tools/binman/test/20_pack_inv_image_align_power2.dts b/tools/binman/test/20_pack_inv_image_align_power2.dts new file mode 100644 index 0000000..a428c4b --- /dev/null +++ b/tools/binman/test/20_pack_inv_image_align_power2.dts @@ -0,0 +1,13 @@ +/dts-v1/; + +/ { + #address-cells = <1>; + #size-cells = <1>; + + binman { + align-size = <131>; + + u-boot { + }; + }; +}; diff --git a/tools/binman/test/21_image_pad.dts b/tools/binman/test/21_image_pad.dts new file mode 100644 index 0000000..daf8385 --- /dev/null +++ b/tools/binman/test/21_image_pad.dts @@ -0,0 +1,16 @@ +/dts-v1/; + +/ { + #address-cells = <1>; + #size-cells = <1>; + + binman { + pad-byte = <0xff>; + u-boot-spl { + }; + + u-boot { + pos = <12>; + }; + }; +}; diff --git a/tools/binman/test/22_image_name.dts b/tools/binman/test/22_image_name.dts new file mode 100644 index 0000000..94fc069 --- /dev/null +++ b/tools/binman/test/22_image_name.dts @@ -0,0 +1,21 @@ +/dts-v1/; + +/ { + #address-cells = <1>; + #size-cells = <1>; + + binman { + multiple-images; + image1 { + filename = "test-name"; + u-boot { + }; + }; + + image2 { + filename = "test-name.xx"; + u-boot { + }; + }; + }; +}; diff --git a/tools/binman/test/23_blob.dts b/tools/binman/test/23_blob.dts new file mode 100644 index 0000000..7dcff69 --- /dev/null +++ b/tools/binman/test/23_blob.dts @@ -0,0 +1,12 @@ +/dts-v1/; + +/ { + #address-cells = <1>; + #size-cells = <1>; + + binman { + blob { + filename = "blobfile"; + }; + }; +}; diff --git a/tools/binman/test/24_sorted.dts b/tools/binman/test/24_sorted.dts new file mode 100644 index 0000000..9f4151c --- /dev/null +++ b/tools/binman/test/24_sorted.dts @@ -0,0 +1,17 @@ +/dts-v1/; + +/ { + #address-cells = <1>; + #size-cells = <1>; + + binman { + sort-by-pos; + u-boot { + pos = <10>; + }; + + u-boot-spl { + pos = <5>; + }; + }; +}; diff --git a/tools/binman/test/25_pack_zero_size.dts b/tools/binman/test/25_pack_zero_size.dts new file mode 100644 index 0000000..7d2baad --- /dev/null +++ b/tools/binman/test/25_pack_zero_size.dts @@ -0,0 +1,15 @@ +/dts-v1/; + +/ { + #address-cells = <1>; + #size-cells = <1>; + + binman { + u-boot { + }; + + u-boot-spl { + pos = <0>; + }; + }; +}; diff --git a/tools/binman/test/26_pack_u_boot_dtb.dts b/tools/binman/test/26_pack_u_boot_dtb.dts new file mode 100644 index 0000000..2707a73 --- /dev/null +++ b/tools/binman/test/26_pack_u_boot_dtb.dts @@ -0,0 +1,14 @@ +/dts-v1/; + +/ { + #address-cells = <1>; + #size-cells = <1>; + + binman { + u-boot-nodtb { + }; + + u-boot-dtb { + }; + }; +};
The structure of x86 ROMs is pretty complex. There are various binary blobs to place in the image. Microcode requires special handling so that it is available to very early code and can be used without any memory whatsoever.
Add support for the various entry types that are currently needed, along with some tests.
Changes in v4: - Fix incorrect comments at the top of intel_*.py
tools/binman/etype/intel_descriptor.py | 55 +++++++++++ tools/binman/etype/intel_me.py | 17 ++++ tools/binman/etype/intel_mrc.py | 17 ++++ tools/binman/etype/intel_vga.py | 17 ++++ tools/binman/etype/u_boot_dtb_with_ucode.py | 72 ++++++++++++++ tools/binman/etype/u_boot_ucode.py | 77 +++++++++++++++ tools/binman/etype/u_boot_with_ucode_ptr.py | 73 ++++++++++++++ tools/binman/etype/x86_start16.py | 17 ++++ tools/binman/func_test.py | 145 ++++++++++++++++++++++++++++ tools/binman/test/27_pack_4gb_no_size.dts | 18 ++++ tools/binman/test/28_pack_4gb_outside.dts | 19 ++++ tools/binman/test/29_x86-rom.dts | 19 ++++ tools/binman/test/30_x86-rom-me-no-desc.dts | 15 +++ tools/binman/test/31_x86-rom-me.dts | 18 ++++ tools/binman/test/32_intel-vga.dts | 13 +++ tools/binman/test/33_x86-start16.dts | 13 +++ tools/binman/test/34_x86_ucode.dts | 29 ++++++ tools/binman/test/35_x86_single_ucode.dts | 26 +++++ tools/binman/test/u_boot_ucode_ptr | Bin 0 -> 4175 bytes tools/binman/test/u_boot_ucode_ptr.c | 15 +++ tools/binman/test/u_boot_ucode_ptr.lds | 18 ++++ 21 files changed, 693 insertions(+) create mode 100644 tools/binman/etype/intel_descriptor.py create mode 100644 tools/binman/etype/intel_me.py create mode 100644 tools/binman/etype/intel_mrc.py create mode 100644 tools/binman/etype/intel_vga.py create mode 100644 tools/binman/etype/u_boot_dtb_with_ucode.py create mode 100644 tools/binman/etype/u_boot_ucode.py create mode 100644 tools/binman/etype/u_boot_with_ucode_ptr.py create mode 100644 tools/binman/etype/x86_start16.py create mode 100644 tools/binman/test/27_pack_4gb_no_size.dts create mode 100644 tools/binman/test/28_pack_4gb_outside.dts create mode 100644 tools/binman/test/29_x86-rom.dts create mode 100644 tools/binman/test/30_x86-rom-me-no-desc.dts create mode 100644 tools/binman/test/31_x86-rom-me.dts create mode 100644 tools/binman/test/32_intel-vga.dts create mode 100644 tools/binman/test/33_x86-start16.dts create mode 100644 tools/binman/test/34_x86_ucode.dts create mode 100644 tools/binman/test/35_x86_single_ucode.dts create mode 100755 tools/binman/test/u_boot_ucode_ptr create mode 100644 tools/binman/test/u_boot_ucode_ptr.c create mode 100644 tools/binman/test/u_boot_ucode_ptr.lds
diff --git a/tools/binman/etype/intel_descriptor.py b/tools/binman/etype/intel_descriptor.py new file mode 100644 index 0000000..7f4ea0b --- /dev/null +++ b/tools/binman/etype/intel_descriptor.py @@ -0,0 +1,55 @@ +# Copyright (c) 2016 Google, Inc +# Written by Simon Glass sjg@chromium.org +# +# SPDX-License-Identifier: GPL-2.0+ +# +# Entry-type module for 'u-boot' +# + +import struct + +from entry import Entry +from blob import Entry_blob + +FD_SIGNATURE = struct.pack('<L', 0x0ff0a55a) +MAX_REGIONS = 5 + +(REGION_DESCRIPTOR, REGION_BIOS, REGION_ME, REGION_GBE, + REGION_PDATA) = range(5) + +class Region: + def __init__(self, data, frba, region_num): + pos = frba + region_num * 4 + val = struct.unpack('<L', data[pos:pos + 4])[0] + self.base = (val & 0xfff) << 12 + self.limit = ((val & 0x0fff0000) >> 4) | 0xfff + self.size = self.limit - self.base + 1 + +class Entry_intel_descriptor(Entry_blob): + """Intel flash descriptor block (4KB) + + This is placed at the start of flash and provides information about + the SPI flash regions. In particular it provides the base address and + size of the ME region, allowing us to place the ME binary in the right + place. + """ + def __init__(self, image, etype, node): + Entry_blob.__init__(self, image, etype, node) + self._regions = [] + + def GetDefaultFilename(self): + return 'descriptor.bin' + + def GetPositions(self): + pos = self.data.find(FD_SIGNATURE) + if pos == -1: + self.Raise('Cannot find FD signature') + flvalsig, flmap0, flmap1, flmap2 = struct.unpack('<LLLL', + self.data[pos:pos + 16]) + frba = ((flmap0 >> 16) & 0xff) << 4 + for i in range(MAX_REGIONS): + self._regions.append(Region(self.data, frba, i)) + + # Set the offset for ME only, for now, since the others are not used + return {'intel-me': [self._regions[REGION_ME].base, + self._regions[REGION_ME].size]} diff --git a/tools/binman/etype/intel_me.py b/tools/binman/etype/intel_me.py new file mode 100644 index 0000000..45ab50c --- /dev/null +++ b/tools/binman/etype/intel_me.py @@ -0,0 +1,17 @@ +# Copyright (c) 2016 Google, Inc +# Written by Simon Glass sjg@chromium.org +# +# SPDX-License-Identifier: GPL-2.0+ +# +# Entry-type module for Intel Management Engine binary blob +# + +from entry import Entry +from blob import Entry_blob + +class Entry_intel_me(Entry_blob): + def __init__(self, image, etype, node): + Entry_blob.__init__(self, image, etype, node) + + def GetDefaultFilename(self): + return 'me.bin' diff --git a/tools/binman/etype/intel_mrc.py b/tools/binman/etype/intel_mrc.py new file mode 100644 index 0000000..f6cedb7 --- /dev/null +++ b/tools/binman/etype/intel_mrc.py @@ -0,0 +1,17 @@ +# Copyright (c) 2016 Google, Inc +# Written by Simon Glass sjg@chromium.org +# +# SPDX-License-Identifier: GPL-2.0+ +# +# Entry-type module for Intel Memory Reference Code binary blob +# + +from entry import Entry +from blob import Entry_blob + +class Entry_intel_mrc(Entry_blob): + def __init__(self, image, etype, node): + Entry_blob.__init__(self, image, etype, node) + + def GetDefaultFilename(self): + return 'mrc.bin' diff --git a/tools/binman/etype/intel_vga.py b/tools/binman/etype/intel_vga.py new file mode 100644 index 0000000..d8f270b --- /dev/null +++ b/tools/binman/etype/intel_vga.py @@ -0,0 +1,17 @@ +# Copyright (c) 2016 Google, Inc +# Written by Simon Glass sjg@chromium.org +# +# SPDX-License-Identifier: GPL-2.0+ +# +# Entry-type module for x86 VGA ROM binary blob +# + +from entry import Entry +from blob import Entry_blob + +class Entry_intel_vga(Entry_blob): + def __init__(self, image, etype, node): + Entry_blob.__init__(self, image, etype, node) + + def GetDefaultFilename(self): + return 'vga.bin' diff --git a/tools/binman/etype/u_boot_dtb_with_ucode.py b/tools/binman/etype/u_boot_dtb_with_ucode.py new file mode 100644 index 0000000..8974241 --- /dev/null +++ b/tools/binman/etype/u_boot_dtb_with_ucode.py @@ -0,0 +1,72 @@ +# Copyright (c) 2016 Google, Inc +## Written by Simon Glass sjg@chromium.org + +# SPDX-License-Identifier: GPL-2.0+ +# +# Entry-type module for U-Boot device tree with the microcode removed +# + +import fdt_select +import fdt_util +from entry import Entry +from blob import Entry_blob +import tools + +class Entry_u_boot_dtb_with_ucode(Entry_blob): + """A U-Boot device tree file, with the microcode removed + + See Entry_u_boot_ucode for full details of the 3 entries involved in this + process. + """ + def __init__(self, image, etype, node): + Entry_blob.__init__(self, image, etype, node) + self.ucode_data = '' + self.collate = False + self.ucode_offset = None + self.ucode_size = None + + def GetDefaultFilename(self): + return 'u-boot.dtb' + + def ObtainContents(self): + Entry_blob.ObtainContents(self) + + # Create a new file to hold the copied device tree + dtb_name = 'u-boot-dtb-with-ucode.dtb' + fname = tools.GetOutputFilename(dtb_name) + with open(fname, 'wb') as fd: + fd.write(self.data) + + # Remove the microcode + fdt = fdt_select.FdtScan(fname) + fdt.Scan() + ucode = fdt.GetNode('/microcode') + if not ucode: + raise self.Raise("No /microcode node found in '%s'" % fname) + + # There's no need to collate it (move all microcode into one place) + # if we only have one chunk of microcode. + self.collate = len(ucode.subnodes) > 1 + for node in ucode.subnodes: + data_prop = node.props.get('data') + if data_prop: + self.ucode_data += ''.join(data_prop.bytes) + if not self.collate: + poffset = data_prop.GetOffset() + if poffset is None: + # We cannot obtain a property offset. Collate instead. + self.collate = True + else: + # Find the offset in the device tree of the ucode data + self.ucode_offset = poffset + 12 + self.ucode_size = len(data_prop.bytes) + if self.collate: + prop = node.DeleteProp('data') + if self.collate: + fdt.Pack() + fdt.Flush() + + # Make this file the contents of this entry + self._pathname = fname + self.ReadContents() + return True diff --git a/tools/binman/etype/u_boot_ucode.py b/tools/binman/etype/u_boot_ucode.py new file mode 100644 index 0000000..8d147d0 --- /dev/null +++ b/tools/binman/etype/u_boot_ucode.py @@ -0,0 +1,77 @@ +# Copyright (c) 2016 Google, Inc +# Written by Simon Glass sjg@chromium.org +# +# SPDX-License-Identifier: GPL-2.0+ +# +# Entry-type module for a U-Boot binary with an embedded microcode pointer +# + +from entry import Entry +from blob import Entry_blob +import tools + +class Entry_u_boot_ucode(Entry_blob): + """U-Boot microcode block + + U-Boot on x86 needs a single block of microcode. This is collected from + the various microcode update nodes in the device tree. It is also unable + to read the microcode from the device tree on platforms that use FSP + (Firmware Support Package) binaries, because the API requires that the + microcode is supplied before there is any SRAM available to use (i.e. + the FSP sets up the SRAM / cache-as-RAM but does so in the call that + requires the microcode!). To keep things simple, all x86 platforms handle + microcode the same way in U-Boot (even non-FSP platforms). This is that + a table is placed at _dt_ucode_base_size containing the base address and + size of the microcode. This is either passed to the FSP (for FSP + platforms), or used to set up the microcode (for non-FSP platforms). + This all happens in the build system since it is the only way to get + the microcode into a single blob and accessible without SRAM. + + There are two cases to handle. If there is only one microcode blob in + the device tree, then the ucode pointer it set to point to that. This + entry (u-boot-ucode) is empty. If there is more than one update, then + this entry holds the concatenation of all updates, and the device tree + entry (u-boot-dtb-with-ucode) is updated to remove the microcode. This + last step ensures that that the microcode appears in one contiguous + block in the image and is not unnecessarily duplicated in the device + tree. It is referred to as 'collation' here. + + Entry types that have a part to play in handling microcode: + + Entry_u_boot_with_ucode_ptr: + Contains u-boot-nodtb.bin (i.e. U-Boot without the device tree). + It updates it with the address and size of the microcode so that + U-Boot can find it early on start-up. + Entry_u_boot_dtb_with_ucode: + Contains u-boot.dtb. It stores the microcode in a + 'self.ucode_data' property, which is then read by this class to + obtain the microcode if needed. If collation is performed, it + removes the microcode from the device tree. + Entry_u_boot_ucode: + This class. If collation is enabled it reads the microcode from + the Entry_u_boot_dtb_with_ucode entry, and uses it as the + contents of this entry. + """ + def __init__(self, image, etype, node): + Entry_blob.__init__(self, image, etype, node) + + def ObtainContents(self): + # Get the microcode from the device tree entry + fdt_entry = self.image.FindEntryType('u-boot-dtb-with-ucode') + if not fdt_entry or not fdt_entry.ucode_data: + return False + if not fdt_entry.collate: + # This section can be empty + self.data = '' + return True + + # Write it out to a file + dtb_name = 'u-boot-ucode.bin' + fname = tools.GetOutputFilename(dtb_name) + with open(fname, 'wb') as fd: + fd.write(fdt_entry.ucode_data) + + self._pathname = fname + self.ReadContents() + + return True diff --git a/tools/binman/etype/u_boot_with_ucode_ptr.py b/tools/binman/etype/u_boot_with_ucode_ptr.py new file mode 100644 index 0000000..b647ea9 --- /dev/null +++ b/tools/binman/etype/u_boot_with_ucode_ptr.py @@ -0,0 +1,73 @@ +# Copyright (c) 2016 Google, Inc +# Written by Simon Glass sjg@chromium.org +# +# SPDX-License-Identifier: GPL-2.0+ +# +# Entry-type module for a U-Boot binary with an embedded microcode pointer +# + +import struct + +import command +from entry import Entry +from blob import Entry_blob +import tools + +class Entry_u_boot_with_ucode_ptr(Entry_blob): + """U-Boot with embedded microcode pointer + + See Entry_u_boot_ucode for full details of the 3 entries involved in this + process. + """ + def __init__(self, image, etype, node): + Entry_blob.__init__(self, image, etype, node) + self.elf_fname = 'u-boot' + + def GetDefaultFilename(self): + return 'u-boot-nodtb.bin' + + def ObtainContents(self): + return Entry_blob.ObtainContents(self) + + def ProcessContents(self): + # Get the position of the microcode + ucode_entry = self.image.FindEntryType('u-boot-ucode') + if not ucode_entry: + self.Raise('Cannot find microcode region u-boot-ucode') + + # Figure out where to put the microcode pointer + fname = tools.GetInputFilename(self.elf_fname) + args = [['nm', fname], ['grep', '-w', '_dt_ucode_base_size']] + out = (command.RunPipe(args, capture=True, raise_on_error=False). + stdout.splitlines()) + if len(out) != 1: + self.Raise('Cannot locate _dt_ucode_base_size symbol in u-boot') + target_pos = int(out[0].split()[0], 16) + + # Check that it is in the image. If it is not, then U-Boot is being + # linked incorrectly, or is being placed at the wrong position in the + # image. The image must be set up so that U-Boot is placed at the + # flash address to which it is linked. For example, if + # CONFIG_SYS_TEXT_BASE is 0xfff00000, and the ROM is 8MB, then + # the U-Boot region must start at position 7MB in the image. In this + # case the ROM starts at 0xff800000, so the position of the first + # entry in the image corresponds to that. + if target_pos < self.pos or target_pos >= self.pos + self.size: + self.Raise('Microcode pointer _dt_ucode_base_size at %08x is ' + 'outside the image ranging from %08x to %08x' % + (target_pos, self.pos, self.pos + self.size)) + + if ucode_entry.size: + pos, size = ucode_entry.pos, ucode_entry.size + else: + dtb_entry = self.image.FindEntryType('u-boot-dtb-with-ucode') + if not dtb_entry: + self.Raise('Cannot find microcode region u-boot-dtb-with-ucode') + pos = dtb_entry.pos + dtb_entry.ucode_offset + size = dtb_entry.ucode_size + + # Write the microcode position and size into the entry + pos_and_size = struct.pack('<2L', pos, size) + target_pos -= self.pos + self.data = (self.data[:target_pos] + pos_and_size + + self.data[target_pos + 8:]) diff --git a/tools/binman/etype/x86_start16.py b/tools/binman/etype/x86_start16.py new file mode 100644 index 0000000..a44ea68 --- /dev/null +++ b/tools/binman/etype/x86_start16.py @@ -0,0 +1,17 @@ +# Copyright (c) 2016 Google, Inc +# Written by Simon Glass sjg@chromium.org +# +# SPDX-License-Identifier: GPL-2.0+ +# +# Entry-type module for the 16-bit x86 start-up code for U-Boot +# + +from entry import Entry +from blob import Entry_blob + +class Entry_x86_start16(Entry_blob): + def __init__(self, image, etype, node): + Entry_blob.__init__(self, image, etype, node) + + def GetDefaultFilename(self): + return 'u-boot-x86-16bit.bin' diff --git a/tools/binman/func_test.py b/tools/binman/func_test.py index bf6e9ed..a32f640 100644 --- a/tools/binman/func_test.py +++ b/tools/binman/func_test.py @@ -65,10 +65,21 @@ class TestFunctional(unittest.TestCase): TestFunctional._MakeInputFile('u-boot.img', U_BOOT_IMG_DATA) TestFunctional._MakeInputFile('spl/u-boot-spl.bin', U_BOOT_SPL_DATA) TestFunctional._MakeInputFile('blobfile', BLOB_DATA) + TestFunctional._MakeInputFile('me.bin', ME_DATA) + TestFunctional._MakeInputFile('vga.bin', VGA_DATA) TestFunctional._MakeInputFile('u-boot.dtb', U_BOOT_DTB_DATA) + TestFunctional._MakeInputFile('u-boot-x86-16bit.bin', X86_START16_DATA) TestFunctional._MakeInputFile('u-boot-nodtb.bin', U_BOOT_NODTB_DATA) self._output_setup = False
+ # ELF file with a '_dt_ucode_base_size' symbol + with open(self.TestFile('u_boot_ucode_ptr')) as fd: + TestFunctional._MakeInputFile('u-boot', fd.read()) + + # Intel flash descriptor file + with open(self.TestFile('descriptor.bin')) as fd: + TestFunctional._MakeInputFile('descriptor.bin', fd.read()) + @classmethod def tearDownClass(self): """Remove the temporary input directory and its contents""" @@ -540,3 +551,137 @@ class TestFunctional(unittest.TestCase): """Test that a device tree can be added to U-Boot""" data = self._DoReadFile('26_pack_u_boot_dtb.dts') self.assertEqual(U_BOOT_NODTB_DATA + U_BOOT_DTB_DATA, data) + + def testPackX86RomNoSize(self): + """Test that the end-at-4gb property requires a size property""" + with self.assertRaises(ValueError) as e: + self._DoTestFile('27_pack_4gb_no_size.dts') + self.assertIn("Image '/binman': Image size must be provided when " + "using end-at-4gb", str(e.exception)) + + def testPackX86RomOutside(self): + """Test that the end-at-4gb property checks for position boundaries""" + with self.assertRaises(ValueError) as e: + self._DoTestFile('28_pack_4gb_outside.dts') + self.assertIn("Node '/binman/u-boot': Position 0x0 (0) is outside " + "the image starting at 0xfffffff0 (4294967280)", + str(e.exception)) + + def testPackX86Rom(self): + """Test that a basic x86 ROM can be created""" + data = self._DoReadFile('29_x86-rom.dts') + self.assertEqual(U_BOOT_DATA + chr(0) * 3 + U_BOOT_SPL_DATA + + chr(0) * 6, data) + + def testPackX86RomMeNoDesc(self): + """Test that an invalid Intel descriptor entry is detected""" + TestFunctional._MakeInputFile('descriptor.bin', '') + with self.assertRaises(ValueError) as e: + self._DoTestFile('31_x86-rom-me.dts') + self.assertIn("Node '/binman/intel-descriptor': Cannot find FD " + "signature", str(e.exception)) + + def testPackX86RomBadDesc(self): + """Test that the Intel requires a descriptor entry""" + with self.assertRaises(ValueError) as e: + self._DoTestFile('30_x86-rom-me-no-desc.dts') + self.assertIn("Node '/binman/intel-me': No position set with " + "pos-unset: should another entry provide this correct " + "position?", str(e.exception)) + + def testPackX86RomMe(self): + """Test that an x86 ROM with an ME region can be created""" + data = self._DoReadFile('31_x86-rom-me.dts') + self.assertEqual(ME_DATA, data[0x1000:0x1000 + len(ME_DATA)]) + + def testPackVga(self): + """Test that an image with a VGA binary can be created""" + data = self._DoReadFile('32_intel-vga.dts') + self.assertEqual(VGA_DATA, data[:len(VGA_DATA)]) + + def testPackStart16(self): + """Test that an image with an x86 start16 region can be created""" + data = self._DoReadFile('33_x86-start16.dts') + self.assertEqual(X86_START16_DATA, data[:len(X86_START16_DATA)]) + + def testPackUbootMicrocode(self): + """Test that x86 microcode can be handled correctly + + We expect to see the following in the image, in order: + u-boot-nodtb.bin with a microcode pointer inserted at the correct + place + u-boot.dtb with the microcode removed + the microcode + """ + data = self._DoReadFile('34_x86_ucode.dts', True) + + # Now check the device tree has no microcode + second = data[len(U_BOOT_NODTB_DATA):] + fname = tools.GetOutputFilename('test.dtb') + with open(fname, 'wb') as fd: + fd.write(second) + fdt = fdt_select.FdtScan(fname) + ucode = fdt.GetNode('/microcode') + self.assertTrue(ucode) + for node in ucode.subnodes: + self.assertFalse(node.props.get('data')) + + # Quick way to get the dtb length - see struct fdt_header: totalsize + # is the second word + fdt_len = struct.unpack('>L', second[4:8])[0] + + third = second[fdt_len:] + + # Check that the microcode appears immediately after the Fdt + # This matches the concatenation of the data properties in + # the /microcode/update@xxx nodes in x86_ucode.dts. + ucode_data = struct.pack('>4L', 0x12345678, 0x12345679, 0xabcd0000, + 0x78235609) + self.assertEqual(ucode_data, third[:len(ucode_data)]) + ucode_pos = len(U_BOOT_NODTB_DATA) + fdt_len + + # Check that the microcode pointer was inserted. It should match the + # expected position and size + pos_and_size = struct.pack('<2L', 0xfffffe00 + ucode_pos, + len(ucode_data)) + first = data[:len(U_BOOT_NODTB_DATA)] + self.assertEqual('nodtb with microcode' + pos_and_size + + ' somewhere in here', first) + + def _RunPackUbootSingleMicrocode(self, collate): + """Test that x86 microcode can be handled correctly + + We expect to see the following in the image, in order: + u-boot-nodtb.bin with a microcode pointer inserted at the correct + place + u-boot.dtb with the microcode + an empty microcode region + """ + # We need the libfdt library to run this test since only that allows + # finding the offset of a property. This is required by + # Entry_u_boot_dtb_with_ucode.ObtainContents(). + if not fdt_select.have_libfdt: + return + data = self._DoReadFile('35_x86_single_ucode.dts', True) + + second = data[len(U_BOOT_NODTB_DATA):] + + # Quick way to get the dtb length - see struct fdt_header: totalsize + # is the second word + fdt_len = struct.unpack('>L', second[4:8])[0] + + third = second[fdt_len:] + second = second[:fdt_len] + + if not collate: + ucode_data = struct.pack('>2L', 0x12345678, 0x12345679) + self.assertIn(ucode_data, second) + ucode_pos = second.find(ucode_data) + len(U_BOOT_NODTB_DATA) + + # Check that the microcode pointer was inserted. It should match the + # expected position and size + pos_and_size = struct.pack('<2L', 0xfffffe00 + ucode_pos, + len(ucode_data)) + first = data[:len(U_BOOT_NODTB_DATA)] + self.assertEqual('nodtb with microcode' + pos_and_size + + ' somewhere in here', first) diff --git a/tools/binman/test/27_pack_4gb_no_size.dts b/tools/binman/test/27_pack_4gb_no_size.dts new file mode 100644 index 0000000..e0b6519 --- /dev/null +++ b/tools/binman/test/27_pack_4gb_no_size.dts @@ -0,0 +1,18 @@ +/dts-v1/; + +/ { + #address-cells = <1>; + #size-cells = <1>; + + binman { + sort-by-pos; + end-at-4gb; + u-boot { + pos = <0xfffffff0>; + }; + + u-boot-spl { + pos = <0xfffffff7>; + }; + }; +}; diff --git a/tools/binman/test/28_pack_4gb_outside.dts b/tools/binman/test/28_pack_4gb_outside.dts new file mode 100644 index 0000000..ff468c7 --- /dev/null +++ b/tools/binman/test/28_pack_4gb_outside.dts @@ -0,0 +1,19 @@ +/dts-v1/; + +/ { + #address-cells = <1>; + #size-cells = <1>; + + binman { + sort-by-pos; + end-at-4gb; + size = <16>; + u-boot { + pos = <0>; + }; + + u-boot-spl { + pos = <0xfffffff7>; + }; + }; +}; diff --git a/tools/binman/test/29_x86-rom.dts b/tools/binman/test/29_x86-rom.dts new file mode 100644 index 0000000..075ede3 --- /dev/null +++ b/tools/binman/test/29_x86-rom.dts @@ -0,0 +1,19 @@ +/dts-v1/; + +/ { + #address-cells = <1>; + #size-cells = <1>; + + binman { + sort-by-pos; + end-at-4gb; + size = <16>; + u-boot { + pos = <0xfffffff0>; + }; + + u-boot-spl { + pos = <0xfffffff7>; + }; + }; +}; diff --git a/tools/binman/test/30_x86-rom-me-no-desc.dts b/tools/binman/test/30_x86-rom-me-no-desc.dts new file mode 100644 index 0000000..4578f66 --- /dev/null +++ b/tools/binman/test/30_x86-rom-me-no-desc.dts @@ -0,0 +1,15 @@ +/dts-v1/; + +/ { + #address-cells = <1>; + #size-cells = <1>; + + binman { + sort-by-pos; + end-at-4gb; + size = <16>; + intel-me { + pos-unset; + }; + }; +}; diff --git a/tools/binman/test/31_x86-rom-me.dts b/tools/binman/test/31_x86-rom-me.dts new file mode 100644 index 0000000..b484ab3 --- /dev/null +++ b/tools/binman/test/31_x86-rom-me.dts @@ -0,0 +1,18 @@ +/dts-v1/; + +/ { + #address-cells = <1>; + #size-cells = <1>; + + binman { + sort-by-pos; + end-at-4gb; + size = <0x800000>; + intel-descriptor { + }; + + intel-me { + pos-unset; + }; + }; +}; diff --git a/tools/binman/test/32_intel-vga.dts b/tools/binman/test/32_intel-vga.dts new file mode 100644 index 0000000..1790833 --- /dev/null +++ b/tools/binman/test/32_intel-vga.dts @@ -0,0 +1,13 @@ +/dts-v1/; + +/ { + #address-cells = <1>; + #size-cells = <1>; + + binman { + size = <16>; + + intel-vga { + }; + }; +}; diff --git a/tools/binman/test/33_x86-start16.dts b/tools/binman/test/33_x86-start16.dts new file mode 100644 index 0000000..2e279de --- /dev/null +++ b/tools/binman/test/33_x86-start16.dts @@ -0,0 +1,13 @@ +/dts-v1/; + +/ { + #address-cells = <1>; + #size-cells = <1>; + + binman { + size = <16>; + + x86-start16 { + }; + }; +}; diff --git a/tools/binman/test/34_x86_ucode.dts b/tools/binman/test/34_x86_ucode.dts new file mode 100644 index 0000000..64a6c2c --- /dev/null +++ b/tools/binman/test/34_x86_ucode.dts @@ -0,0 +1,29 @@ +/dts-v1/; + +/ { + #address-cells = <1>; + #size-cells = <1>; + + binman { + sort-by-pos; + end-at-4gb; + size = <0x200>; + u-boot-with-ucode-ptr { + }; + + u-boot-dtb-with-ucode { + }; + + u-boot-ucode { + }; + }; + + microcode { + update@0 { + data = <0x12345678 0x12345679>; + }; + update@1 { + data = <0xabcd0000 0x78235609>; + }; + }; +}; diff --git a/tools/binman/test/35_x86_single_ucode.dts b/tools/binman/test/35_x86_single_ucode.dts new file mode 100644 index 0000000..973e97f --- /dev/null +++ b/tools/binman/test/35_x86_single_ucode.dts @@ -0,0 +1,26 @@ +/dts-v1/; + +/ { + #address-cells = <1>; + #size-cells = <1>; + + binman { + sort-by-pos; + end-at-4gb; + size = <0x200>; + u-boot-with-ucode-ptr { + }; + + u-boot-dtb-with-ucode { + }; + + u-boot-ucode { + }; + }; + + microcode { + update@0 { + data = <0x12345678 0x12345679>; + }; + }; +}; diff --git a/tools/binman/test/u_boot_ucode_ptr b/tools/binman/test/u_boot_ucode_ptr new file mode 100755 index 0000000000000000000000000000000000000000..dbfb184cecfbcf55cf43ed4f4ac0ee90a7364d93 GIT binary patch literal 4175 zcmeHKze~eV5WfDv>Y%NqTOB%ds7Rl!MiB>>qFqFAD7b~B30kpv@e1VLh}je}Vs) zgM)i3QgG0CU(yE=7YE1p!Ew2t@9xWVH@o|LsZ@#-(v%@sqt7rjSl=(i5rZlmsZoxy zQ9SaF!jM>&I0rHVXMs3_>*wPh=u>4I0zc&NRXVJG0rgz2p&8H&Xa+O`ngPv#W<WEb z8PE)91~dczzyR*A5=(}qebAw|qP00Wx+^}sOy2XS&mWD8@+0oQG~%t+cBR&_15XAO zLu?77z7|AQ^SWt>h9TCMV?U7?UiPJBvzCKcpQta-m##SW0$~TeGpF8jNCaKqaY=Oj ze&6*ZKlNvnIWxzC`EXm}&a5V?u^%8<um|=meT89(@6%cSR#15x>_A>)8o(X9qLQXD z#1~o6OQFqqJIY{<8~_@#DLmzgZrQ+Xi@EVGZrnMRWWNeKSJ|ha`YAi9u{Z4aQjhnG z?c~ddtBklhOXCp#9(;g{)Q?Fq+c>PTU-d6wo4~YvUz*V$GtcEfbjfs-ZCgXv9QLkU KGKbO{NcskUZF7hK
literal 0 HcmV?d00001
diff --git a/tools/binman/test/u_boot_ucode_ptr.c b/tools/binman/test/u_boot_ucode_ptr.c new file mode 100644 index 0000000..434c9f4 --- /dev/null +++ b/tools/binman/test/u_boot_ucode_ptr.c @@ -0,0 +1,15 @@ +/* + * Copyright (c) 2016 Google, Inc + * + * SPDX-License-Identifier: GPL-2.0+ + * + * Simple program to create a _dt_ucode_base_size symbol which can be read + * by 'nm'. This is used by binman tests. + * + * Build with: + * cc -march=i386 -m32 -o u_boot_ucode_ptr -T u_boot_ucode_ptr.lds -nostdlib \ + u_boot_ucode_ptr.c + */ + +static unsigned long _dt_ucode_base_size[2] + __attribute__((section(".ucode"))) = {1, 2}; diff --git a/tools/binman/test/u_boot_ucode_ptr.lds b/tools/binman/test/u_boot_ucode_ptr.lds new file mode 100644 index 0000000..167debf --- /dev/null +++ b/tools/binman/test/u_boot_ucode_ptr.lds @@ -0,0 +1,18 @@ +/* + * Copyright (c) 2016 Google, Inc + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +OUTPUT_FORMAT("elf32-i386", "elf32-i386", "elf32-i386") +OUTPUT_ARCH(i386) +ENTRY(_start) + +SECTIONS +{ + . = 0xfffffdf0; + _start = .; + .ucode : { + *(.ucode) + } +}
Add an entry type for u-boot.img (a legacy U-Boot image) and a simple test.
Changes in v4: None Changes in v3: None Changes in v2: None
tools/binman/etype/u_boot_img.py | 17 +++++++++++++++++ tools/binman/func_test.py | 5 +++++ tools/binman/test/36_u_boot_img.dts | 11 +++++++++++ 3 files changed, 33 insertions(+) create mode 100644 tools/binman/etype/u_boot_img.py create mode 100644 tools/binman/test/36_u_boot_img.dts
diff --git a/tools/binman/etype/u_boot_img.py b/tools/binman/etype/u_boot_img.py new file mode 100644 index 0000000..744f1b4 --- /dev/null +++ b/tools/binman/etype/u_boot_img.py @@ -0,0 +1,17 @@ +# Copyright (c) 2016 Google, Inc +# Written by Simon Glass sjg@chromium.org +# +# SPDX-License-Identifier: GPL-2.0+ +# +# Entry-type module for U-Boot binary +# + +from entry import Entry +from blob import Entry_blob + +class Entry_u_boot_img(Entry_blob): + def __init__(self, image, etype, node): + Entry_blob.__init__(self, image, etype, node) + + def GetDefaultFilename(self): + return 'u-boot.img' diff --git a/tools/binman/func_test.py b/tools/binman/func_test.py index a32f640..e36d7bd 100644 --- a/tools/binman/func_test.py +++ b/tools/binman/func_test.py @@ -685,3 +685,8 @@ class TestFunctional(unittest.TestCase): first = data[:len(U_BOOT_NODTB_DATA)] self.assertEqual('nodtb with microcode' + pos_and_size + ' somewhere in here', first) + + def testUBootImg(self): + """Test that u-boot.img can be put in a file""" + data = self._DoReadFile('36_u_boot_img.dts') + self.assertEqual(U_BOOT_IMG_DATA, data) diff --git a/tools/binman/test/36_u_boot_img.dts b/tools/binman/test/36_u_boot_img.dts new file mode 100644 index 0000000..aa5a3fe --- /dev/null +++ b/tools/binman/test/36_u_boot_img.dts @@ -0,0 +1,11 @@ +/dts-v1/; + +/ { + #address-cells = <1>; + #size-cells = <1>; + + binman { + u-boot-img { + }; + }; +};
When building for 64-bit x86 we need an SPL binary in the ROM. Add support for this. Also increase entry test code coverage to 100%.
tools/binman/etype/u_boot_spl_bss_pad.py | 26 +++++++++ tools/binman/etype/u_boot_spl_with_ucode_ptr.py | 28 +++++++++ tools/binman/etype/x86_start16_spl.py | 17 ++++++ tools/binman/func_test.py | 71 +++++++++++++++++++++++ tools/binman/test/37_x86_no_ucode.dts | 20 +++++++ tools/binman/test/38_x86_ucode_missing_node.dts | 26 +++++++++ tools/binman/test/39_x86_ucode_missing_node2.dts | 23 ++++++++ tools/binman/test/40_x86_ucode_not_in_image.dts | 28 +++++++++ tools/binman/test/41_unknown_pos_size.dts | 11 ++++ tools/binman/test/u_boot_no_ucode_ptr | Bin 0 -> 4182 bytes tools/binman/test/u_boot_no_ucode_ptr.c | 15 +++++ 11 files changed, 265 insertions(+) create mode 100644 tools/binman/etype/u_boot_spl_bss_pad.py create mode 100644 tools/binman/etype/u_boot_spl_with_ucode_ptr.py create mode 100644 tools/binman/etype/x86_start16_spl.py create mode 100644 tools/binman/test/37_x86_no_ucode.dts create mode 100644 tools/binman/test/38_x86_ucode_missing_node.dts create mode 100644 tools/binman/test/39_x86_ucode_missing_node2.dts create mode 100644 tools/binman/test/40_x86_ucode_not_in_image.dts create mode 100644 tools/binman/test/41_unknown_pos_size.dts create mode 100755 tools/binman/test/u_boot_no_ucode_ptr create mode 100644 tools/binman/test/u_boot_no_ucode_ptr.c
diff --git a/tools/binman/etype/u_boot_spl_bss_pad.py b/tools/binman/etype/u_boot_spl_bss_pad.py new file mode 100644 index 0000000..c005f28 --- /dev/null +++ b/tools/binman/etype/u_boot_spl_bss_pad.py @@ -0,0 +1,26 @@ +# Copyright (c) 2016 Google, Inc +# Written by Simon Glass sjg@chromium.org +# +# SPDX-License-Identifier: GPL-2.0+ +# +# Entry-type module for BSS padding for spl/u-boot-spl.bin. This padding +# can be added after the SPL binary to ensure that anything concatenated +# to it will appear to SPL to be at the end of BSS rather than the start. +# + +import command +from entry import Entry +from blob import Entry_blob +import tools + +class Entry_u_boot_spl_bss_pad(Entry_blob): + def __init__(self, image, etype, node): + Entry_blob.__init__(self, image, etype, node) + + def ObtainContents(self): + fname = tools.GetInputFilename('spl/u-boot-spl') + args = [['nm', fname], ['grep', '__bss_size']] + out = command.RunPipe(args, capture=True).stdout.splitlines() + bss_size = int(out[0].split()[0], 16) + self.data = chr(0) * bss_size + self.contents_size = bss_size diff --git a/tools/binman/etype/u_boot_spl_with_ucode_ptr.py b/tools/binman/etype/u_boot_spl_with_ucode_ptr.py new file mode 100644 index 0000000..764c282 --- /dev/null +++ b/tools/binman/etype/u_boot_spl_with_ucode_ptr.py @@ -0,0 +1,28 @@ +# Copyright (c) 2016 Google, Inc +# Written by Simon Glass sjg@chromium.org +# +# SPDX-License-Identifier: GPL-2.0+ +# +# Entry-type module for an SPL binary with an embedded microcode pointer +# + +import struct + +import command +from entry import Entry +from blob import Entry_blob +from u_boot_with_ucode_ptr import Entry_u_boot_with_ucode_ptr +import tools + +class Entry_u_boot_spl_with_ucode_ptr(Entry_u_boot_with_ucode_ptr): + """U-Boot SPL with embedded microcode pointer + + See Entry_u_boot_ucode for full details of the entries involved in this + process. + """ + def __init__(self, image, etype, node): + Entry_blob.__init__(self, image, etype, node) + self.elf_fname = 'spl/u-boot-spl' + + def GetDefaultFilename(self): + return 'spl/u-boot-spl.bin' diff --git a/tools/binman/etype/x86_start16_spl.py b/tools/binman/etype/x86_start16_spl.py new file mode 100644 index 0000000..3679a43 --- /dev/null +++ b/tools/binman/etype/x86_start16_spl.py @@ -0,0 +1,17 @@ +# Copyright (c) 2016 Google, Inc +# Written by Simon Glass sjg@chromium.org +# +# SPDX-License-Identifier: GPL-2.0+ +# +# Entry-type module for the 16-bit x86 start-up code for U-Boot SPL +# + +from entry import Entry +from blob import Entry_blob + +class Entry_x86_start16_spl(Entry_blob): + def __init__(self, image, etype, node): + Entry_blob.__init__(self, image, etype, node) + + def GetDefaultFilename(self): + return 'spl/u-boot-x86-16bit-spl.bin' diff --git a/tools/binman/func_test.py b/tools/binman/func_test.py index e36d7bd..3202947 100644 --- a/tools/binman/func_test.py +++ b/tools/binman/func_test.py @@ -686,7 +686,78 @@ class TestFunctional(unittest.TestCase): self.assertEqual('nodtb with microcode' + pos_and_size + ' somewhere in here', first)
+ def testPackUbootSingleMicrocode(self): + """Test that x86 microcode can be handled correctly with fdt_normal. + """ + self._RunPackUbootSingleMicrocode(False) + + def testPackUbootSingleMicrocodeFallback(self): + """Test that x86 microcode can be handled correctly with fdt_fallback. + + This only supports collating the microcode. + """ + try: + old_val = fdt_select.UseFallback(True) + self._RunPackUbootSingleMicrocode(True) + finally: + fdt_select.UseFallback(old_val) + def testUBootImg(self): """Test that u-boot.img can be put in a file""" data = self._DoReadFile('36_u_boot_img.dts') self.assertEqual(U_BOOT_IMG_DATA, data) + + def testNoMicrocode(self): + """Test that a missing microcode region is detected""" + with self.assertRaises(ValueError) as e: + self._DoReadFile('37_x86_no_ucode.dts', True) + self.assertIn("Node '/binman/u-boot-dtb-with-ucode': No /microcode " + "node found in ", str(e.exception)) + + def testMicrocodeWithoutNode(self): + """Test that a missing u-boot-dtb-with-ucode node is detected""" + with self.assertRaises(ValueError) as e: + self._DoReadFile('38_x86_ucode_missing_node.dts', True) + self.assertIn("Node '/binman/u-boot-with-ucode-ptr': Cannot find " + "microcode region u-boot-dtb-with-ucode", str(e.exception)) + + def testMicrocodeWithoutNode2(self): + """Test that a missing u-boot-ucode node is detected""" + with self.assertRaises(ValueError) as e: + self._DoReadFile('39_x86_ucode_missing_node2.dts', True) + self.assertIn("Node '/binman/u-boot-with-ucode-ptr': Cannot find " + "microcode region u-boot-ucode", str(e.exception)) + + def testMicrocodeWithoutPtrInElf(self): + """Test that a U-Boot binary without the microcode symbol is detected""" + # ELF file without a '_dt_ucode_base_size' symbol + if not fdt_select.have_libfdt: + return + try: + with open(self.TestFile('u_boot_no_ucode_ptr')) as fd: + TestFunctional._MakeInputFile('u-boot', fd.read()) + + with self.assertRaises(ValueError) as e: + self._RunPackUbootSingleMicrocode(False) + self.assertIn("Node '/binman/u-boot-with-ucode-ptr': Cannot locate " + "_dt_ucode_base_size symbol in u-boot", str(e.exception)) + + finally: + # Put the original file back + with open(self.TestFile('u_boot_ucode_ptr')) as fd: + TestFunctional._MakeInputFile('u-boot', fd.read()) + + def testMicrocodeNotInImage(self): + """Test that microcode must be placed within the image""" + with self.assertRaises(ValueError) as e: + self._DoReadFile('40_x86_ucode_not_in_image.dts', True) + self.assertIn("Node '/binman/u-boot-with-ucode-ptr': Microcode " + "pointer _dt_ucode_base_size at fffffe14 is outside the " + "image ranging from 00000000 to 0000002e", str(e.exception)) + + def testUnknownPosSize(self): + """Test that microcode must be placed within the image""" + with self.assertRaises(ValueError) as e: + self._DoReadFile('41_unknown_pos_size.dts', True) + self.assertIn("Image '/binman': Unable to set pos/size for unknown " + "entry 'invalid-entry'", str(e.exception)) diff --git a/tools/binman/test/37_x86_no_ucode.dts b/tools/binman/test/37_x86_no_ucode.dts new file mode 100644 index 0000000..9e12156 --- /dev/null +++ b/tools/binman/test/37_x86_no_ucode.dts @@ -0,0 +1,20 @@ +/dts-v1/; + +/ { + #address-cells = <1>; + #size-cells = <1>; + + binman { + sort-by-pos; + end-at-4gb; + size = <0x200>; + u-boot-with-ucode-ptr { + }; + + u-boot-dtb-with-ucode { + }; + + u-boot-ucode { + }; + }; +}; diff --git a/tools/binman/test/38_x86_ucode_missing_node.dts b/tools/binman/test/38_x86_ucode_missing_node.dts new file mode 100644 index 0000000..d6cf0d8 --- /dev/null +++ b/tools/binman/test/38_x86_ucode_missing_node.dts @@ -0,0 +1,26 @@ +/dts-v1/; + +/ { + #address-cells = <1>; + #size-cells = <1>; + + binman { + sort-by-pos; + end-at-4gb; + size = <0x200>; + u-boot-with-ucode-ptr { + }; + + u-boot-ucode { + }; + }; + + microcode { + update@0 { + data = <0x12345678 0x12345679>; + }; + update@1 { + data = <0xabcd0000 0x78235609>; + }; + }; +}; diff --git a/tools/binman/test/39_x86_ucode_missing_node2.dts b/tools/binman/test/39_x86_ucode_missing_node2.dts new file mode 100644 index 0000000..b7e26c5 --- /dev/null +++ b/tools/binman/test/39_x86_ucode_missing_node2.dts @@ -0,0 +1,23 @@ +/dts-v1/; + +/ { + #address-cells = <1>; + #size-cells = <1>; + + binman { + sort-by-pos; + end-at-4gb; + size = <0x200>; + u-boot-with-ucode-ptr { + }; + }; + + microcode { + update@0 { + data = <0x12345678 0x12345679>; + }; + update@1 { + data = <0xabcd0000 0x78235609>; + }; + }; +}; diff --git a/tools/binman/test/40_x86_ucode_not_in_image.dts b/tools/binman/test/40_x86_ucode_not_in_image.dts new file mode 100644 index 0000000..67d17d3 --- /dev/null +++ b/tools/binman/test/40_x86_ucode_not_in_image.dts @@ -0,0 +1,28 @@ +/dts-v1/; + +/ { + #address-cells = <1>; + #size-cells = <1>; + + binman { + sort-by-pos; + size = <0x200>; + u-boot-with-ucode-ptr { + }; + + u-boot-dtb-with-ucode { + }; + + u-boot-ucode { + }; + }; + + microcode { + update@0 { + data = <0x12345678 0x12345679>; + }; + update@1 { + data = <0xabcd0000 0x78235609>; + }; + }; +}; diff --git a/tools/binman/test/41_unknown_pos_size.dts b/tools/binman/test/41_unknown_pos_size.dts new file mode 100644 index 0000000..a8e7d8a --- /dev/null +++ b/tools/binman/test/41_unknown_pos_size.dts @@ -0,0 +1,11 @@ +/dts-v1/; + +/ { + #address-cells = <1>; + #size-cells = <1>; + + binman { + _testing { + }; + }; +}; diff --git a/tools/binman/test/u_boot_no_ucode_ptr b/tools/binman/test/u_boot_no_ucode_ptr new file mode 100755 index 0000000000000000000000000000000000000000..f72462f0be41a934d468481bf627d6c1ec9a8e1c GIT binary patch literal 4182 zcmeHKy-EW?5T5*Cv``}iEVQ^HMMSbDdWK+O6Euwq7AdTbT<(Ygb0^7OVG6bMF|2$8 zpFw;En;;05iM_7#<+2d5v9R2MkJ<U%oo}nTIXF5@Bod@0NhyLg`c%qheYX@xY_d2~ zpbVua@rie&6fxF02bhC1OPs;=i*XP1$+Hc>51hV9kJT?hJ(n9X3>XFs1BL;^fMLKe zU>GnA7zPXjhJk-z0Q*;tkz&+O8uWhlJbWr0zYHsC`1(-IehePl*#DA<*J^uKq2We> zj4WGJg<af^CRX{nY>SdDb~a)^k?3D_Wz%IXd$B&(ry!KRXa|vSqt1m_?06)iR_OU8 zT4A^A2a>P)v#fDuhJp8Cx5S>ApQ*-t5W&D4m^1gKRF3!4c|L2=dAsaDUTGS@9=oZN zrZL1<80e*?&UyRVV2vCIG~TA=ewpZ&4eYjfH}1ubyTF+3XR))wJ}tVRwr4fwh8=I} z@qDp8do$uXBd$)<SgrCAe1MC@kC)<YW3|P8-9L+IBF7Cw=>(xO`84NJ_C$;LPaVgT TQ=i-H`%b?z@X6`RW>3;L6WVxU
diff --git a/tools/binman/test/u_boot_no_ucode_ptr.c b/tools/binman/test/u_boot_no_ucode_ptr.c new file mode 100644 index 0000000..a17bb4c --- /dev/null +++ b/tools/binman/test/u_boot_no_ucode_ptr.c @@ -0,0 +1,15 @@ +/* + * Copyright (c) 2016 Google, Inc + * + * SPDX-License-Identifier: GPL-2.0+ + * + * Simple program to create a bad _dt_ucode_base_size symbol to create an + * error when it is used. This is used by binman tests. + * + * Build with: + * cc -march=i386 -m32 -o u_boot_no_ucode_ptr -T u_boot_ucode_ptr.lds \ + -nostdlib u_boot_no_ucode_ptr.c + */ + +static unsigned long not__dt_ucode_base_size[2] + __attribute__((section(".ucode"))) = {1, 2};
Add support for two more from the inexhaustible supply of x86 binary blob types.
Changes in v4: - Add new patch to support building x86 images with FSP/CMC
tools/binman/etype/intel_cmc.py | 17 +++++++++++++++++ tools/binman/etype/intel_fsp.py | 17 +++++++++++++++++ tools/binman/func_test.py | 14 ++++++++++++++ tools/binman/test/42_intel-fsp.dts | 13 +++++++++++++ tools/binman/test/43_intel-cmc.dts | 13 +++++++++++++ 5 files changed, 74 insertions(+) create mode 100644 tools/binman/etype/intel_cmc.py create mode 100644 tools/binman/etype/intel_fsp.py create mode 100644 tools/binman/test/42_intel-fsp.dts create mode 100644 tools/binman/test/43_intel-cmc.dts
diff --git a/tools/binman/etype/intel_cmc.py b/tools/binman/etype/intel_cmc.py new file mode 100644 index 0000000..9bce8ae --- /dev/null +++ b/tools/binman/etype/intel_cmc.py @@ -0,0 +1,17 @@ +# Copyright (c) 2016 Google, Inc +# Written by Simon Glass sjg@chromium.org +# +# SPDX-License-Identifier: GPL-2.0+ +# +# Entry-type module for Intel Chip Microcode binary blob +# + +from entry import Entry +from blob import Entry_blob + +class Entry_intel_cmc(Entry_blob): + def __init__(self, image, etype, node): + Entry_blob.__init__(self, image, etype, node) + + def GetDefaultFilename(self): + return 'cmc.bin' diff --git a/tools/binman/etype/intel_fsp.py b/tools/binman/etype/intel_fsp.py new file mode 100644 index 0000000..d75be5b --- /dev/null +++ b/tools/binman/etype/intel_fsp.py @@ -0,0 +1,17 @@ +# Copyright (c) 2016 Google, Inc +# Written by Simon Glass sjg@chromium.org +# +# SPDX-License-Identifier: GPL-2.0+ +# +# Entry-type module for Intel Firmware Support Package binary blob +# + +from entry import Entry +from blob import Entry_blob + +class Entry_intel_fsp(Entry_blob): + def __init__(self, image, etype, node): + Entry_blob.__init__(self, image, etype, node) + + def GetDefaultFilename(self): + return 'fsp.bin' diff --git a/tools/binman/func_test.py b/tools/binman/func_test.py index 3202947..fa30cce 100644 --- a/tools/binman/func_test.py +++ b/tools/binman/func_test.py @@ -36,6 +36,8 @@ VGA_DATA = 'vga' U_BOOT_DTB_DATA = 'udtb' X86_START16_DATA = 'start16' U_BOOT_NODTB_DATA = 'nodtb with microcode pointer somewhere in here' +FSP_DATA = 'fsp' +CMC_DATA = 'cmc'
class TestFunctional(unittest.TestCase): """Functional tests for binman @@ -70,6 +72,8 @@ class TestFunctional(unittest.TestCase): TestFunctional._MakeInputFile('u-boot.dtb', U_BOOT_DTB_DATA) TestFunctional._MakeInputFile('u-boot-x86-16bit.bin', X86_START16_DATA) TestFunctional._MakeInputFile('u-boot-nodtb.bin', U_BOOT_NODTB_DATA) + TestFunctional._MakeInputFile('fsp.bin', FSP_DATA) + TestFunctional._MakeInputFile('cmc.bin', CMC_DATA) self._output_setup = False
# ELF file with a '_dt_ucode_base_size' symbol @@ -761,3 +765,13 @@ class TestFunctional(unittest.TestCase): self._DoReadFile('41_unknown_pos_size.dts', True) self.assertIn("Image '/binman': Unable to set pos/size for unknown " "entry 'invalid-entry'", str(e.exception)) + + def testPackFsp(self): + """Test that an image with a FSP binary can be created""" + data = self._DoReadFile('42_intel-fsp.dts') + self.assertEqual(FSP_DATA, data[:len(FSP_DATA)]) + + def testPackCmc(self): + """Test that an image with a FSP binary can be created""" + data = self._DoReadFile('43_intel-cmc.dts') + self.assertEqual(CMC_DATA, data[:len(CMC_DATA)]) diff --git a/tools/binman/test/42_intel-fsp.dts b/tools/binman/test/42_intel-fsp.dts new file mode 100644 index 0000000..e0a1e76 --- /dev/null +++ b/tools/binman/test/42_intel-fsp.dts @@ -0,0 +1,13 @@ +/dts-v1/; + +/ { + #address-cells = <1>; + #size-cells = <1>; + + binman { + size = <16>; + + intel-fsp { + }; + }; +}; diff --git a/tools/binman/test/43_intel-cmc.dts b/tools/binman/test/43_intel-cmc.dts new file mode 100644 index 0000000..26c456d --- /dev/null +++ b/tools/binman/test/43_intel-cmc.dts @@ -0,0 +1,13 @@ +/dts-v1/; + +/ { + #address-cells = <1>; + #size-cells = <1>; + + binman { + size = <16>; + + intel-cmc { + }; + }; +};
Add a standard command definition for binman so that it can be used in makefiles.
Makefile | 6 ++++++ 1 file changed, 6 insertions(+)
diff --git a/Makefile b/Makefile index b5c9421..a5428a2 100644 --- a/Makefile +++ b/Makefile @@ -889,6 +889,12 @@ u-boot.ldr: u-boot $(LDR) -T $(CONFIG_CPU) -c $@ $< $(LDR_FLAGS) $(BOARD_SIZE_CHECK)
+# binman +# --------------------------------------------------------------------------- +quiet_cmd_binman = BINMAN $@ +cmd_binman = $(srctree)/tools/binman/binman -d u-boot.dtb -O . \ + -I . -I $(srctree)/board/$(BOARDDIR) $< + OBJCOPYFLAGS_u-boot.ldr.hex := -I binary -O ihex
OBJCOPYFLAGS_u-boot.ldr.srec := -I binary -O srec
It is sometimes useful to be able to reference configuration options in a device tree source file. Add the necessary includes so that this works.
scripts/Makefile.lib | 5 +++++ 1 file changed, 5 insertions(+)
diff --git a/scripts/Makefile.lib b/scripts/Makefile.lib index 2b31b1a..2539ba5 100644 --- a/scripts/Makefile.lib +++ b/scripts/Makefile.lib @@ -168,6 +168,11 @@ ld_flags = $(LDFLAGS) $(ldflags-y) dtc_cpp_flags = -Wp,-MD,$(depfile).pre.tmp -nostdinc \ -I$(srctree)/arch/$(ARCH)/dts \ -I$(srctree)/arch/$(ARCH)/dts/include \ + -Iinclude \ + -I$(srctree)/include \ + -I$(srctree)/arch/$(ARCH)/include \ + -include $(srctree)/include/linux/kconfig.h \ + -D__ASSEMBLY__ \ -undef -D__DTS__
# Finds the multi-part object the current object will be linked into
Hi Simon,
-Iinclude \
Is this needed? Should it be the same as -I$(srctree)/include?
Regards, Bin
Hi Bin,
On 2 November 2016 at 22:11, Bin Meng bmeng.cn@gmail.com wrote:
Hi Simon,
-Iinclude \
When build the current directory is the build directory, so 'include' refers to the include directory there.
For boards that need U-Boot-specific additions to the device tree, it is a minor annoyance to have to add these each time the tree is synced with upstream.
Add a means to include a file (e.g. u-boot.dtsi) automatically into the .dts file before it is compiled.
The file uses is the first one that exists in this list:
arch/<arch>/dts/<board.dts>-u-boot.dtsi arch/<arch>/dts/<soc>-u-boot.dtsi arch/<arch>/dts/<cpu>-u-boot.dtsi arch/<arch>/dts/<vendor>-u-boot.dtsi arch/<arch>/dts/u-boot.dtsi
Signed-off-by: Simon Glass sjg@chromium.org Suggested-by: Tom Rini trini@konsulko.com ---
Changes in v4: - Add an option to bring in an soc .dtsi file also - Fix up rule to #include on "/ {" rather than "/dts-v1/;" - Rename binman_dtsi variable to u-boot-dtsi
Changes in v3: - Add a new patch to automatically include a U-Boot .dtsi file
Changes in v2: None
scripts/Makefile.lib | 17 ++++++++++++++++- 1 file changed, 16 insertions(+), 1 deletion(-)
diff --git a/scripts/Makefile.lib b/scripts/Makefile.lib index 2539ba5..f6d7d34 100644 --- a/scripts/Makefile.lib +++ b/scripts/Makefile.lib @@ -164,6 +164,18 @@ cpp_flags = -Wp,-MD,$(depfile) $(NOSTDINC_FLAGS) $(UBOOTINCLUDE) \
+dts_dir = $(srctree)/arch/$(ARCH)/dts + +# Try these files in order to find the U-Boot-specific .dtsi include file +u-boot-dtsi_options = $(wildcard $(dts_dir)/$(basename $(notdir $<))-u-boot.dtsi) \ + $(wildcard $(dts_dir)/$(subst $",,$(CONFIG_SYS_SOC))-u-boot.dtsi) \ + $(wildcard $(dts_dir)/$(subst $",,$(CONFIG_SYS_CPU))-u-boot.dtsi) \ + $(wildcard $(dts_dir)/$(subst $",,$(CONFIG_SYS_VENDOR))-u-boot.dtsi) \ + $(wildcard $(dts_dir)/u-boot.dtsi) + +# We use the first match +u-boot-dtsi = $(firstword $(u-boot-dtsi_options)) + # Modified for U-Boot dtc_cpp_flags = -Wp,-MD,$(depfile).pre.tmp -nostdinc \ -I$(srctree)/arch/$(ARCH)/dts \ @@ -293,8 +305,11 @@ $(obj)/%.dtb.S: $(obj)/%.dtb
quiet_cmd_dtc = DTC $@ # Modified for U-Boot +# Bring in any U-Boot-specific include after the '/dts-v1/;' header cmd_dtc = mkdir -p $(dir ${dtc-tmp}) ; \ - $(CPP) $(dtc_cpp_flags) -x assembler-with-cpp -o $(dtc-tmp) $< ; \ + cat $< $(if $(u-boot-dtsi),\ + | sed 's%^/ {$$%#include "$(u-boot-dtsi)"\n&%') | \ + $(CPP) $(dtc_cpp_flags) -x assembler-with-cpp -o $(dtc-tmp) - ; \ $(DTC) -O dtb -o $@ -b 0 \ -i $(dir $<) $(DTC_FLAGS) \ -d $(depfile).dtc.tmp $(dtc-tmp) ; \
Move sunxi boards to use binman. This involves adding the image definition to the device tree and using it in the Makefile.
Changes in v4: - Remove RFC tag - Update sunxi rule to depend on u-boot.dtb - Use binman for all sunxi boards
Changes in v3: - Use a <dts>-u-boot.dtsi file for the binman changes
Changes in v2: None
Makefile | 6 ++---- arch/arm/dts/sunxi-u-boot.dtsi | 14 ++++++++++++++ 2 files changed, 16 insertions(+), 4 deletions(-) create mode 100644 arch/arm/dts/sunxi-u-boot.dtsi
diff --git a/Makefile b/Makefile index a5428a2..a5bbb24 100644 --- a/Makefile +++ b/Makefile @@ -1121,10 +1121,8 @@ u-boot-x86-16bit.bin: u-boot FORCE endif
ifneq ($(CONFIG_SUNXI),) -OBJCOPYFLAGS_u-boot-sunxi-with-spl.bin = -I binary -O binary \ - --pad-to=$(CONFIG_SPL_PAD_TO) --gap-fill=0xff -u-boot-sunxi-with-spl.bin: spl/sunxi-spl.bin u-boot.img FORCE - $(call if_changed,pad_cat) +u-boot-sunxi-with-spl.bin: spl/sunxi-spl.bin u-boot.img u-boot.dtb FORCE + $(call if_changed,binman) endif
ifneq ($(CONFIG_TEGRA),) diff --git a/arch/arm/dts/sunxi-u-boot.dtsi b/arch/arm/dts/sunxi-u-boot.dtsi new file mode 100644 index 0000000..5adfd9b --- /dev/null +++ b/arch/arm/dts/sunxi-u-boot.dtsi @@ -0,0 +1,14 @@ +#include <config.h> + +/ { + binman { + filename = "u-boot-sunxi-with-spl.bin"; + pad-byte = <0xff>; + blob { + filename = "spl/sunxi-spl.bin"; + }; + u-boot-img { + pos = <CONFIG_SPL_PAD_TO>; + }; + }; +};
Change x86 boards to use binman to produce the ROM. This involves adding the image definition to the device tree and using it in the Makefile. The existing ifdtool features are no-longer needed.
Note that the .dtsi file is common and is used for all x86 boards.
Changes in v4: - Remove RFC tag - Use binman for all x86 boards
Changes in v3: - Put the binman definition in u-boot.dtsi
Changes in v2: - Add automated test coverage - Put the binman definition in a common file for x86 - Various changes and improvements based on using this tool for a while
Makefile | 45 +++-------------------------------- arch/x86/dts/u-boot.dtsi | 62 ++++++++++++++++++++++++++++++++++++++++++++++++ 2 files changed, 65 insertions(+), 42 deletions(-) create mode 100644 arch/x86/dts/u-boot.dtsi
diff --git a/Makefile b/Makefile index a5bbb24..31c3146 100644 --- a/Makefile +++ b/Makefile @@ -1060,50 +1060,11 @@ endif
# x86 uses a large ROM. We fill it with 0xff, put the 16-bit stuff (including # reset vector) at the top, Intel ME descriptor at the bottom, and U-Boot in -# the middle. +# the middle. This is handled by binman based on an image description in the +# board's device tree. ifneq ($(CONFIG_X86_RESET_VECTOR),) rom: u-boot.rom FORCE
-IFDTOOL=$(objtree)/tools/ifdtool -IFDTOOL_FLAGS = -f 0:$(objtree)/u-boot.dtb -IFDTOOL_FLAGS += -m 0x$(shell $(NM) u-boot |grep _dt_ucode_base_size |cut -d' ' -f1) -IFDTOOL_FLAGS += -U $(CONFIG_SYS_TEXT_BASE):$(objtree)/u-boot-nodtb.bin -IFDTOOL_FLAGS += -w $(CONFIG_SYS_X86_START16):$(objtree)/u-boot-x86-16bit.bin -IFDTOOL_FLAGS += -C - -ifneq ($(CONFIG_HAVE_INTEL_ME),) -IFDTOOL_ME_FLAGS = -D $(srctree)/board/$(BOARDDIR)/descriptor.bin -IFDTOOL_ME_FLAGS += -i ME:$(srctree)/board/$(BOARDDIR)/me.bin -endif - -ifneq ($(CONFIG_HAVE_MRC),) -IFDTOOL_FLAGS += -w $(CONFIG_X86_MRC_ADDR):$(srctree)/board/$(BOARDDIR)/mrc.bin -endif - -ifneq ($(CONFIG_HAVE_FSP),) -IFDTOOL_FLAGS += -w $(CONFIG_FSP_ADDR):$(srctree)/board/$(BOARDDIR)/$(CONFIG_FSP_FILE) -endif - -ifneq ($(CONFIG_HAVE_CMC),) -IFDTOOL_FLAGS += -w $(CONFIG_CMC_ADDR):$(srctree)/board/$(BOARDDIR)/$(CONFIG_CMC_FILE) -endif - -ifneq ($(CONFIG_HAVE_VGA_BIOS),) -IFDTOOL_FLAGS += -w $(CONFIG_VGA_BIOS_ADDR):$(srctree)/board/$(BOARDDIR)/$(CONFIG_VGA_BIOS_FILE) -endif - -ifneq ($(CONFIG_HAVE_REFCODE),) -IFDTOOL_FLAGS += -w $(CONFIG_X86_REFCODE_ADDR):refcode.bin -endif - -quiet_cmd_ifdtool = IFDTOOL $@ -cmd_ifdtool = $(IFDTOOL) -c -r $(CONFIG_ROM_SIZE) u-boot.tmp; -ifneq ($(CONFIG_HAVE_INTEL_ME),) -cmd_ifdtool += $(IFDTOOL) $(IFDTOOL_ME_FLAGS) u-boot.tmp; -endif -cmd_ifdtool += $(IFDTOOL) $(IFDTOOL_FLAGS) u-boot.tmp; -cmd_ifdtool += mv u-boot.tmp $@ - refcode.bin: $(srctree)/board/$(BOARDDIR)/refcode.bin FORCE $(call if_changed,copy)
@@ -1113,7 +1074,7 @@ cmd_ldr = $(LD) $(LDFLAGS_$(@F)) \
u-boot.rom: u-boot-x86-16bit.bin u-boot.bin FORCE \ $(if $(CONFIG_HAVE_REFCODE),refcode.bin) - $(call if_changed,ifdtool) + $(call if_changed,binman)
OBJCOPYFLAGS_u-boot-x86-16bit.bin := -O binary -j .start16 -j .resetvec u-boot-x86-16bit.bin: u-boot FORCE diff --git a/arch/x86/dts/u-boot.dtsi b/arch/x86/dts/u-boot.dtsi new file mode 100644 index 0000000..724913f --- /dev/null +++ b/arch/x86/dts/u-boot.dtsi @@ -0,0 +1,62 @@ +/* + * Copyright (C) 2016 Google, Inc + * Written by Simon Glass sjg@chromium.org + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <config.h> + +#ifdef CONFIG_ROM_SIZE +/ { + binman { + filename = "u-boot.rom"; + end-at-4gb; + sort-by-pos; + pad-byte = <0xff>; + size = <CONFIG_ROM_SIZE>; +#ifdef CONFIG_HAVE_INTEL_ME + intel-descriptor { + }; + intel-me { + }; +#endif + u-boot-with-ucode-ptr { + pos = <CONFIG_SYS_TEXT_BASE>; + }; + u-boot-dtb-with-ucode { + }; + u-boot-ucode { + align = <16>; + }; +#ifdef CONFIG_HAVE_MRC + intel-mrc { + pos = <CONFIG_X86_MRC_ADDR>; + }; +#endif +#ifdef CONFIG_HAVE_FSP + intel-fsp { + pos = <CONFIG_FSP_ADDR>; + }; +#endif +#ifdef CONFIG_HAVE_CMC + intel-cmc { + pos = <CONFIG_CMC_ADDR>; + }; +#endif +#ifdef CONFIG_HAVE_VGA_BIOS + intel-vga { + pos = <CONFIG_VGA_BIOS_ADDR>; + }; +#endif +#ifdef CONFIG_HAVE_REFCODE + intel-refcode { + pos = <CONFIG_X86_REFCODE_ADDR>; + }; +#endif + x86-start16 { + pos = <CONFIG_SYS_X86_START16>; + }; + }; +}; +#endif
Hi Bin,
Changes in v4:
- Remove RFC tag
Changes in v3:
Changes in v2:
What do you think of this patch?
Hi Simon,
On Thu, Oct 13, 2016 at 8:04 AM, Simon Glass sjg@chromium.org wrote:
Hi Bin,
Changes in v4:
- Remove RFC tag
Changes in v3:
Changes in v2:
Sorry, I will try to look at this in a day or two.
Regards, Bin
Hi Bin,
On 12 October 2016 at 17:56, Bin Meng bmeng.cn@gmail.com wrote:
Hi Simon,
Hi Bin,
Changes in v4:
- Remove RFC tag
Changes in v3:
Changes in v2:
Did you get a chance to take a look at this?
Hi Simon,
On Fri, Oct 28, 2016 at 10:41 AM, Simon Glass sjg@chromium.org wrote:
Hi Bin,
Hi Simon,
Hi Bin,
Changes in v4:
- Remove RFC tag
Changes in v3:
Changes in v2:
Looks the python import error was caused by an incorrect installation of python. I will try to have a look tomorrow.
Regards, Bin
Hi Bin,
On 1 November 2016 at 04:07, Bin Meng bmeng.cn@gmail.com wrote:
Hi Simon,
Hi Bin,
Hi Simon,
Hi Bin,
Changes in v4:
- Remove RFC tag
Changes in v3:
Changes in v2:
OK, that's odd!
- Simon
Hi Simon,
On Wed, Nov 2, 2016 at 10:07 PM, Simon Glass sjg@chromium.org wrote:
Hi Bin,
Hi Simon,
Hi Bin,
Hi Simon,
Hi Bin,
Changes in v4:
- Remove RFC tag
Changes in v3:
Changes in v2:
OK, that's odd!
I am getting another error with fdtput
fdtput: invalid option -- 'd' Usage: write a property value to a device tree fdtput <options> <dt file> <node> <property> [<value>...] fdtput -c <options> <dt file> [<node>...]
The command line arguments are joined together into a single value. <type> s=string, i=int, u=unsigned, x=hex Optional modifier prefix: hh or b=byte, h=2 byte, l=4 byte (default)
My fdtput version is 1.4.0. I suspect I will need to update to latest version 1.4.2? This tool version requirement should be documented.
Regards, Bin
Hi Simon,
Changes in v4:
- Remove RFC tag
Changes in v3:
Changes in v2:
- Copyright (C) 2016 Google, Inc
- Written by Simon Glass sjg@chromium.org
binman {
end-at-4gb;
sort-by-pos;
pad-byte = <0xff>;
intel-descriptor {
intel-me {
This causes build error for QEMU.
BINMAN u-boot.rom Node '/binman/u-boot-dtb-with-ucode': No /microcode node found in './u-boot-dtb-with-ucode.dtb' make: *** [u-boot.rom] Error 1
u-boot-ucode {
align = <16>;
intel-mrc {
intel-fsp {
intel-cmc {
intel-vga {
intel-refcode {
x86-start16 {
+}; +#endif
Regards, Bin
Hi Bin,
Hi Simon,
Changes in v4:
- Remove RFC tag
Changes in v3:
Changes in v2:
binman {
end-at-4gb;
sort-by-pos;
pad-byte = <0xff>;
intel-descriptor {
intel-me {
OK, I've fixed that. It's because that board has no microcode, so I've made it optional.
Hi Simon
That sounds somewhat similar to the new OpenEmbedded Image Creator tool called WIC (e.g. see slide 27ff here https://www.yoctoproject.org/sites /default/files/yocto_devday_advanced_class_berlin_1.pdf).
Cheers
Marcel
On Thu, 2016-10-06 at 14:59 -0600, Simon Glass wrote:
This series introduces binman, a tool designed to create firmware images. It provides a way to bring together various binaries and place them in an image, at particular positions and with configurable alignment.
Packaging of firmware is quite a different task from building the various parts. In many cases the various binaries which go into the image come from separate build systems. For example, ARM Trusted Firmware is used on ARMv8 devices but is not built in the U-Boot tree. If a Linux kernel is included in the firmware image, it is built elsewhere.
It is of course possible to add more and more build rules to the U- Boot build system to cover these cases. It can shell out to other Makefiles and build scripts. But it seems better to create a clear divide between building software and packaging it.
U-Boot supports a very large number of boards. Many of these have their own specific rules for how an image should be put together so that it boots correctly. At present these rules are described by manual instructions, different for each board. By turning these instructions into a standard format, we can support making valid images for any board without manual effort, lots of READMEs, etc.
Images consist of a number of entries which are combined to make up the final image. The image is described in the device tree for the board, meaning that it can be accessed at run-time if desired.
Binman is an extensible tool. A set of standard entries is provides, but new entries can be created fairly easily. Entries can be as simple as providing the name of a file to include. They can also handle more complex requirements, such as adjusting the input file or reading header information from one entry to control the position of another.
U-Boot's mkimage builds FIT images and various other binaries. Binman augments this by allowing these binaries to be packed together. While FIT should be used where possible, it cannot be used everywhere. For example, many devices require executable code at a particular offset in the image. X86 machines require lots of binary blobs at particular places, and a microcode collection easily accessible at boot.
So far binman has enough functionality to be useful, so sunxi and x86 boards are switched over to use it, as examples.
The series is available at u-boot-dm/binman-working
Future work and missing features are documented in the README.
Changes in v4:
- Remove RFC tag
Changes in v3:
Changes in v2:
- Add test for code coverage
- Fix the -b option
while
- drop the unused __len__() method
Simon Glass (11): binman: Introduce binman, a tool for building binary images binman: Add basic entry types for U-Boot binman: Add support for building x86 ROMs binman: Add support for u-boot.img as an input binary binman: Add support for building x86 ROMs with SPL binman: Add support for building x86 images with FSP/CMC binman: Add a build rule for binman binman: Allow configuration options to be used in .dts files binman: Automatically include a U-Boot .dtsi file sunxi: Use binman for sunxi boards x86: Use binman all x86 boards
Makefile | 57 +- arch/arm/dts/sunxi-u-boot.dtsi | 14 + arch/x86/dts/u-boot.dtsi | 62 ++ scripts/Makefile.lib | 22 +- tools/binman/.gitignore | 1 + tools/binman/README | 491 +++++++++++++ tools/binman/binman | 1 + tools/binman/binman.py | 116 +++ tools/binman/cmdline.py | 53 ++ tools/binman/control.py | 118 ++++ tools/binman/entry_test.py | 27 + tools/binman/etype/_testing.py | 26 + tools/binman/etype/blob.py | 37 + tools/binman/etype/entry.py | 190 +++++ tools/binman/etype/intel_cmc.py | 17 + tools/binman/etype/intel_descriptor.py | 55 ++ tools/binman/etype/intel_fsp.py | 17 + tools/binman/etype/intel_me.py | 17 + tools/binman/etype/intel_mrc.py | 17 + tools/binman/etype/intel_vga.py | 17 + tools/binman/etype/u_boot.py | 17 + tools/binman/etype/u_boot_dtb.py | 17 + tools/binman/etype/u_boot_dtb_with_ucode.py | 72 ++ tools/binman/etype/u_boot_img.py | 17 + tools/binman/etype/u_boot_nodtb.py | 17 + tools/binman/etype/u_boot_spl.py | 17 + tools/binman/etype/u_boot_spl_bss_pad.py | 26 + tools/binman/etype/u_boot_spl_with_ucode_ptr.py | 28 + tools/binman/etype/u_boot_ucode.py | 77 ++ tools/binman/etype/u_boot_with_ucode_ptr.py | 73 ++ tools/binman/etype/x86_start16.py | 17 + tools/binman/etype/x86_start16_spl.py | 17 + tools/binman/fdt_test.py | 48 ++ tools/binman/func_test.py | 777 +++++++++++++++++++++ tools/binman/image.py | 229 ++++++ tools/binman/test/01_invalid.dts | 5 + tools/binman/test/02_missing_node.dts | 6 + tools/binman/test/03_empty.dts | 9 + tools/binman/test/04_invalid_entry.dts | 11 + tools/binman/test/05_simple.dts | 11 + tools/binman/test/06_dual_image.dts | 22 + tools/binman/test/07_bad_align.dts | 12 + tools/binman/test/08_pack.dts | 30 + tools/binman/test/09_pack_extra.dts | 35 + tools/binman/test/10_pack_align_power2.dts | 12 + tools/binman/test/11_pack_align_size_power2.dts | 12 + tools/binman/test/12_pack_inv_align.dts | 13 + tools/binman/test/13_pack_inv_size_align.dts | 13 + tools/binman/test/14_pack_overlap.dts | 16 + tools/binman/test/15_pack_overflow.dts | 12 + tools/binman/test/16_pack_image_overflow.dts | 13 + tools/binman/test/17_pack_image_size.dts | 13 + tools/binman/test/18_pack_image_align.dts | 13 + tools/binman/test/19_pack_inv_image_align.dts | 14 + .../binman/test/20_pack_inv_image_align_power2.dts | 13 + tools/binman/test/21_image_pad.dts | 16 + tools/binman/test/22_image_name.dts | 21 + tools/binman/test/23_blob.dts | 12 + tools/binman/test/24_sorted.dts | 17 + tools/binman/test/25_pack_zero_size.dts | 15 + tools/binman/test/26_pack_u_boot_dtb.dts | 14 + tools/binman/test/27_pack_4gb_no_size.dts | 18 + tools/binman/test/28_pack_4gb_outside.dts | 19 + tools/binman/test/29_x86-rom.dts | 19 + tools/binman/test/30_x86-rom-me-no-desc.dts | 15 + tools/binman/test/31_x86-rom-me.dts | 18 + tools/binman/test/32_intel-vga.dts | 13 + tools/binman/test/33_x86-start16.dts | 13 + tools/binman/test/34_x86_ucode.dts | 29 + tools/binman/test/35_x86_single_ucode.dts | 26 + tools/binman/test/36_u_boot_img.dts | 11 + tools/binman/test/37_x86_no_ucode.dts | 20 + tools/binman/test/38_x86_ucode_missing_node.dts | 26 + tools/binman/test/39_x86_ucode_missing_node2.dts | 23 + tools/binman/test/40_x86_ucode_not_in_image.dts | 28 + tools/binman/test/41_unknown_pos_size.dts | 11 + tools/binman/test/42_intel-fsp.dts | 13 + tools/binman/test/43_intel-cmc.dts | 13 + tools/binman/test/u_boot_no_ucode_ptr | Bin 0 -> 4182 bytes tools/binman/test/u_boot_no_ucode_ptr.c | 15 + tools/binman/test/u_boot_ucode_ptr | Bin 0 -> 4175 bytes tools/binman/test/u_boot_ucode_ptr.c | 15 + tools/binman/test/u_boot_ucode_ptr.lds | 18 + 83 files changed, 3500 insertions(+), 47 deletions(-) create mode 100644 arch/arm/dts/sunxi-u-boot.dtsi create mode 100644 arch/x86/dts/u-boot.dtsi create mode 100644 tools/binman/.gitignore create mode 100644 tools/binman/README create mode 120000 tools/binman/binman create mode 100755 tools/binman/binman.py create mode 100644 tools/binman/cmdline.py create mode 100644 tools/binman/control.py create mode 100644 tools/binman/entry_test.py create mode 100644 tools/binman/etype/_testing.py create mode 100644 tools/binman/etype/blob.py create mode 100644 tools/binman/etype/entry.py create mode 100644 tools/binman/etype/intel_cmc.py create mode 100644 tools/binman/etype/intel_descriptor.py create mode 100644 tools/binman/etype/intel_fsp.py create mode 100644 tools/binman/etype/intel_me.py create mode 100644 tools/binman/etype/intel_mrc.py create mode 100644 tools/binman/etype/intel_vga.py create mode 100644 tools/binman/etype/u_boot.py create mode 100644 tools/binman/etype/u_boot_dtb.py create mode 100644 tools/binman/etype/u_boot_dtb_with_ucode.py create mode 100644 tools/binman/etype/u_boot_img.py create mode 100644 tools/binman/etype/u_boot_nodtb.py create mode 100644 tools/binman/etype/u_boot_spl.py create mode 100644 tools/binman/etype/u_boot_spl_bss_pad.py create mode 100644 tools/binman/etype/u_boot_spl_with_ucode_ptr.py create mode 100644 tools/binman/etype/u_boot_ucode.py create mode 100644 tools/binman/etype/u_boot_with_ucode_ptr.py create mode 100644 tools/binman/etype/x86_start16.py create mode 100644 tools/binman/etype/x86_start16_spl.py create mode 100644 tools/binman/fdt_test.py create mode 100644 tools/binman/func_test.py create mode 100644 tools/binman/image.py create mode 100644 tools/binman/test/01_invalid.dts create mode 100644 tools/binman/test/02_missing_node.dts create mode 100644 tools/binman/test/03_empty.dts create mode 100644 tools/binman/test/04_invalid_entry.dts create mode 100644 tools/binman/test/05_simple.dts create mode 100644 tools/binman/test/06_dual_image.dts create mode 100644 tools/binman/test/07_bad_align.dts create mode 100644 tools/binman/test/08_pack.dts create mode 100644 tools/binman/test/09_pack_extra.dts create mode 100644 tools/binman/test/10_pack_align_power2.dts create mode 100644 tools/binman/test/11_pack_align_size_power2.dts create mode 100644 tools/binman/test/12_pack_inv_align.dts create mode 100644 tools/binman/test/13_pack_inv_size_align.dts create mode 100644 tools/binman/test/14_pack_overlap.dts create mode 100644 tools/binman/test/15_pack_overflow.dts create mode 100644 tools/binman/test/16_pack_image_overflow.dts create mode 100644 tools/binman/test/17_pack_image_size.dts create mode 100644 tools/binman/test/18_pack_image_align.dts create mode 100644 tools/binman/test/19_pack_inv_image_align.dts create mode 100644 tools/binman/test/20_pack_inv_image_align_power2.dts create mode 100644 tools/binman/test/21_image_pad.dts create mode 100644 tools/binman/test/22_image_name.dts create mode 100644 tools/binman/test/23_blob.dts create mode 100644 tools/binman/test/24_sorted.dts create mode 100644 tools/binman/test/25_pack_zero_size.dts create mode 100644 tools/binman/test/26_pack_u_boot_dtb.dts create mode 100644 tools/binman/test/27_pack_4gb_no_size.dts create mode 100644 tools/binman/test/28_pack_4gb_outside.dts create mode 100644 tools/binman/test/29_x86-rom.dts create mode 100644 tools/binman/test/30_x86-rom-me-no-desc.dts create mode 100644 tools/binman/test/31_x86-rom-me.dts create mode 100644 tools/binman/test/32_intel-vga.dts create mode 100644 tools/binman/test/33_x86-start16.dts create mode 100644 tools/binman/test/34_x86_ucode.dts create mode 100644 tools/binman/test/35_x86_single_ucode.dts create mode 100644 tools/binman/test/36_u_boot_img.dts create mode 100644 tools/binman/test/37_x86_no_ucode.dts create mode 100644 tools/binman/test/38_x86_ucode_missing_node.dts create mode 100644 tools/binman/test/39_x86_ucode_missing_node2.dts create mode 100644 tools/binman/test/40_x86_ucode_not_in_image.dts create mode 100644 tools/binman/test/41_unknown_pos_size.dts create mode 100644 tools/binman/test/42_intel-fsp.dts create mode 100644 tools/binman/test/43_intel-cmc.dts create mode 100755 tools/binman/test/u_boot_no_ucode_ptr create mode 100644 tools/binman/test/u_boot_no_ucode_ptr.c create mode 100755 tools/binman/test/u_boot_ucode_ptr create mode 100644 tools/binman/test/u_boot_ucode_ptr.c create mode 100644 tools/binman/test/u_boot_ucode_ptr.lds
Hi Marcel,
On 1 November 2016 at 16:19, Marcel Ziswiler marcel.ziswiler@toradex.com wrote:
Hi Simon
Thanks for the link. Yes there are definitely similarities, one operations on firmware images and one operates on disk images. I suppose that makes sense since with U-Boot we are mostly interested in generating a valid firmware binary, whereas OpenEmbedded is concerned with creating a disk image with various partitions, etc.
I suspect that the U-Boot image may end up providing one of the inputs into OpenEmbedded. However all the examples (on p35) refer to EFI so I'm not sure if that is too low-level for WIC?
Regards, Simon [...]
Bin Meng
Marcel Ziswiler
