[U-Boot] [PATCH] usb: CONFIG_USB_FASTBOOT prefix replacement for consistency
FASTBOOT is defined both by CONFIG_USB_FUNCTION_FASTBOOT AND CONFIG_CMD_FASTBOOT, so it doesn't make much sense to have a CONFIG_USB_FASTBOOT prefix for fastboot-specific options, especially given that other config options for fastboot use the CONFIG_FASTBOOT prefix.
This replaces the CONFIG_USB_FASTBOOT prefix with CONFIG_FASTBOOT, for consistency.
Signed-off-by: Paul Kocialkowski contact@paulk.fr --- README | 4 ++-- doc/README.android-fastboot | 4 ++-- drivers/usb/gadget/f_fastboot.c | 8 ++++---- include/configs/am335x_evm.h | 4 ++-- include/configs/bav335x.h | 4 ++-- include/configs/dra7xx_evm.h | 4 ++-- include/configs/nitrogen6x.h | 4 ++-- include/configs/omap3_beagle.h | 4 ++-- 8 files changed, 18 insertions(+), 18 deletions(-)
diff --git a/README b/README index ab171f9..c871e7c 100644 --- a/README +++ b/README @@ -1730,12 +1730,12 @@ The following options need to be configured: This enables support for booting images which use the Android image format header.
- CONFIG_USB_FASTBOOT_BUF_ADDR + CONFIG_FASTBOOT_BUF_ADDR The fastboot protocol requires a large memory buffer for downloads. Define this to the starting RAM address to use for downloaded images.
- CONFIG_USB_FASTBOOT_BUF_SIZE + CONFIG_FASTBOOT_BUF_SIZE The fastboot protocol requires a large memory buffer for downloads. This buffer should be as large as possible for a platform. Define this to the size available RAM for fastboot. diff --git a/doc/README.android-fastboot b/doc/README.android-fastboot index 92f2897..ce12bc5 100644 --- a/doc/README.android-fastboot +++ b/doc/README.android-fastboot @@ -47,8 +47,8 @@ CONFIG_CMD_FASTBOOT and CONFIG_ANDROID_BOOT_IMAGE.
The fastboot protocol requires a large memory buffer for downloads. This buffer should be as large as possible for a platform. The location of the -buffer and size are set with CONFIG_USB_FASTBOOT_BUF_ADDR and -CONFIG_USB_FASTBOOT_BUF_SIZE. +buffer and size are set with CONFIG_FASTBOOT_BUF_ADDR and +CONFIG_FASTBOOT_BUF_SIZE.
Fastboot partition aliases can also be defined for devices where GPT limitations prevent user-friendly partition names such as "boot", "system" diff --git a/drivers/usb/gadget/f_fastboot.c b/drivers/usb/gadget/f_fastboot.c index 60c846d..ca01a01 100644 --- a/drivers/usb/gadget/f_fastboot.c +++ b/drivers/usb/gadget/f_fastboot.c @@ -380,7 +380,7 @@ static void cb_getvar(struct usb_ep *ep, struct usb_request *req) !strcmp_l1("max-download-size", cmd)) { char str_num[12];
- sprintf(str_num, "0x%08x", CONFIG_USB_FASTBOOT_BUF_SIZE); + sprintf(str_num, "0x%08x", CONFIG_FASTBOOT_BUF_SIZE); strncat(response, str_num, chars_left); } else if (!strcmp_l1("serialno", cmd)) { s = getenv("serial#"); @@ -430,7 +430,7 @@ static void rx_handler_dl_image(struct usb_ep *ep, struct usb_request *req) if (buffer_size < transfer_size) transfer_size = buffer_size;
- memcpy((void *)CONFIG_USB_FASTBOOT_BUF_ADDR + download_bytes, + memcpy((void *)CONFIG_FASTBOOT_BUF_ADDR + download_bytes, buffer, transfer_size);
pre_dot_num = download_bytes / BYTES_PER_DOT; @@ -483,7 +483,7 @@ static void cb_download(struct usb_ep *ep, struct usb_request *req)
if (0 == download_size) { sprintf(response, "FAILdata invalid size"); - } else if (download_size > CONFIG_USB_FASTBOOT_BUF_SIZE) { + } else if (download_size > CONFIG_FASTBOOT_BUF_SIZE) { download_size = 0; sprintf(response, "FAILdata too large"); } else { @@ -544,7 +544,7 @@ static void cb_flash(struct usb_ep *ep, struct usb_request *req)
strcpy(response, "FAILno flash device defined"); #ifdef CONFIG_FASTBOOT_FLASH_MMC_DEV - fb_mmc_flash_write(cmd, (void *)CONFIG_USB_FASTBOOT_BUF_ADDR, + fb_mmc_flash_write(cmd, (void *)CONFIG_FASTBOOT_BUF_ADDR, download_bytes, response); #endif fastboot_tx_write_str(response); diff --git a/include/configs/am335x_evm.h b/include/configs/am335x_evm.h index abcdfda..633391b 100644 --- a/include/configs/am335x_evm.h +++ b/include/configs/am335x_evm.h @@ -301,8 +301,8 @@ #define CONFIG_USB_FUNCTION_FASTBOOT #define CONFIG_CMD_FASTBOOT #define CONFIG_ANDROID_BOOT_IMAGE -#define CONFIG_USB_FASTBOOT_BUF_ADDR CONFIG_SYS_LOAD_ADDR -#define CONFIG_USB_FASTBOOT_BUF_SIZE 0x07000000 +#define CONFIG_FASTBOOT_BUF_ADDR CONFIG_SYS_LOAD_ADDR +#define CONFIG_FASTBOOT_BUF_SIZE 0x07000000
/* To support eMMC booting */ #define CONFIG_STORAGE_EMMC diff --git a/include/configs/bav335x.h b/include/configs/bav335x.h index 31b75f2..fa32fa4 100644 --- a/include/configs/bav335x.h +++ b/include/configs/bav335x.h @@ -458,8 +458,8 @@ DEFAULT_LINUX_BOOT_ENV \ #define CONFIG_USB_FUNCTION_FASTBOOT #define CONFIG_CMD_FASTBOOT #define CONFIG_ANDROID_BOOT_IMAGE -#define CONFIG_USB_FASTBOOT_BUF_ADDR CONFIG_SYS_LOAD_ADDR -#define CONFIG_USB_FASTBOOT_BUF_SIZE 0x07000000 +#define CONFIG_FASTBOOT_BUF_ADDR CONFIG_SYS_LOAD_ADDR +#define CONFIG_FASTBOOT_BUF_SIZE 0x07000000
/* To support eMMC booting */ #define CONFIG_STORAGE_EMMC diff --git a/include/configs/dra7xx_evm.h b/include/configs/dra7xx_evm.h index 9dd5577..334721e 100644 --- a/include/configs/dra7xx_evm.h +++ b/include/configs/dra7xx_evm.h @@ -92,8 +92,8 @@ #define CONFIG_USB_FUNCTION_FASTBOOT #define CONFIG_CMD_FASTBOOT #define CONFIG_ANDROID_BOOT_IMAGE -#define CONFIG_USB_FASTBOOT_BUF_ADDR CONFIG_SYS_LOAD_ADDR -#define CONFIG_USB_FASTBOOT_BUF_SIZE 0x2F000000 +#define CONFIG_FASTBOOT_BUF_ADDR CONFIG_SYS_LOAD_ADDR +#define CONFIG_FASTBOOT_BUF_SIZE 0x2F000000 #define CONFIG_FASTBOOT_FLASH #define CONFIG_FASTBOOT_FLASH_MMC_DEV 1 #endif diff --git a/include/configs/nitrogen6x.h b/include/configs/nitrogen6x.h index 47239b1..3bb2e8f 100644 --- a/include/configs/nitrogen6x.h +++ b/include/configs/nitrogen6x.h @@ -349,7 +349,7 @@ #define CONFIG_USB_FUNCTION_FASTBOOT #define CONFIG_CMD_FASTBOOT #define CONFIG_ANDROID_BOOT_IMAGE -#define CONFIG_USB_FASTBOOT_BUF_ADDR CONFIG_SYS_LOAD_ADDR -#define CONFIG_USB_FASTBOOT_BUF_SIZE 0x07000000 +#define CONFIG_FASTBOOT_BUF_ADDR CONFIG_SYS_LOAD_ADDR +#define CONFIG_FASTBOOT_BUF_SIZE 0x07000000
#endif /* __CONFIG_H */ diff --git a/include/configs/omap3_beagle.h b/include/configs/omap3_beagle.h index 59c780e..804e307 100644 --- a/include/configs/omap3_beagle.h +++ b/include/configs/omap3_beagle.h @@ -75,8 +75,8 @@ #define CONFIG_USB_FUNCTION_FASTBOOT #define CONFIG_CMD_FASTBOOT #define CONFIG_ANDROID_BOOT_IMAGE -#define CONFIG_USB_FASTBOOT_BUF_ADDR CONFIG_SYS_LOAD_ADDR -#define CONFIG_USB_FASTBOOT_BUF_SIZE 0x07000000 +#define CONFIG_FASTBOOT_BUF_ADDR CONFIG_SYS_LOAD_ADDR +#define CONFIG_FASTBOOT_BUF_SIZE 0x07000000
/* USB EHCI */ #define CONFIG_CMD_USB
PaulK
