[PULL] Please pull qcom-next-2024Apr04
Hi Tom,
Some new Qualcomm features for you:
* Ethernet, i2c, and USB support are now enabled by default * The clock driver gets some bug fixes and cleanup * Invalid FDTs are now properly detected in board_fdt_blob_setup(). * The pinctrl driver gains preparatory support for per-pin function muxes. * Support is added for two generations of Qualcomm HighSpeed USB PHY * A power domain driver is added for the Globall Distributed Switch Controllers on the GCC hardware block. * SDM845 gains USB host mode support. * OF_LIVE is enabled by default for Qualcomm platforms * Some U-Boot devicetree compatibility fixups are added during init to improve compatbility with upstream DT.
The following changes since commit b2511143fba4c0631446c968fb4c0d962b01d850:
qcom_defconfig: enable USB (2024-04-04 17:46:48 +0200)
git@source.denx.de:u-boot/custodians/u-boot-snapdragon.git tags/qcom-next-2024Apr04
for you to fetch changes up to b2511143fba4c0631446c968fb4c0d962b01d850:
Caleb Connolly
