[U-Boot-Users] Porting UBoot without UART
We're using some emulation box to develop our SoC. Somehow the UART will the last component available for firmware development. Without UART, it's very hard to debug UBoot. Can we "easily" drive a car without eyes?
But it's not impossible to do that. My first thought about porting UBoot under this circumstance is to disable the serial driver in UBoot and to redirect all printf to a fixed memory area, just as what a circular log buffer does. I'm wondering how much workload this will be. Is this kind of mechasim already existent in UBoot?
Thank you for your comments. -Shawn.
Provide our own console functions. See common/console.c and common/devices.c how it is initialized and used.
Best regards, ladis
Note thatt he "devices" are intialized pretty late in the boot sequence. Until then, all of the most of the important console messages have already beeen printed.
From the original post: "We're using some emulation box to develop our
SoC. Somehow the UART will the last component available for firmware development."
I don't think that is the situation that Shawn is describing. To me it sounded like he is starting firmware development before all of the functionality is delivered by the hardware engineers. I don't think that he is refering to initialization order. Shawn, could you please clarify?
Cheers, g.
Dear Grant,
You are right. Then Ladislav Michl suggested to use special console functions for output, which works, but misses most of the "interesting" startup messages which are printed long before the device funtions are installed.
Initialization order plays only a role here as a console device starts working too late. The native console port is the serial port.
On Fri, 25 Feb 2005 08:51:47 +0100, Wolfgang Denk wd@denx.de wrote:
Dear Grant,
Ahh, thank you. I had misunderstood what you were talking about.
So what needs to be modified to do this? Create new serial_putc, _getc, _init etc. functions that send messages to where he needs them?
Cheers, g.
Add a working serial port :-)
For what it's worth, I have recently completed a port of U-Boot to a custom board with no serial port in the design. It does, however, have a functioning ethernet port, which we set up to use as a netconsole. Sure, most of the informative boot up messages are missed, but to paraphrase Wolfgang, "get a BDI 2000"! ;)
Good Luck, Adam Kent
Both of you are right. I'm starting firmware development before all h/w components are ready. H/W folks are pushing to test some of components before UART is delivered.
Thanks, -Shawn.
Sounds like some percussive maintenance is needed about the ears of said H/W folks. :-P
g.
What a major mistake of design...
Easily yes, savely no ;-)
There is a log driver, yes.
But U-Boot really assumes that you have a working console port. Anything else is a major pain in the ...
participants (5)
Adam Kent
Grant Likely
Ladislav Michl
Shawn Jin
