[U-Boot] [PATCH] at91: move cpu name define to arm/arch/ cpu header
Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD plagnioj@jcrosoft.com --- include/asm-arm/arch-at91/at91cap9.h | 5 +++++ include/asm-arm/arch-at91/at91sam9260.h | 9 +++++++++ include/asm-arm/arch-at91/at91sam9261.h | 4 ++++ include/asm-arm/arch-at91/at91sam9263.h | 4 ++++ include/asm-arm/arch-at91/at91sam9rl.h | 5 +++++ include/configs/at91cap9adk.h | 1 - include/configs/at91sam9260ek.h | 2 -- include/configs/at91sam9261ek.h | 1 - include/configs/at91sam9263ek.h | 1 - include/configs/at91sam9rlek.h | 1 - include/configs/pm9263.h | 2 -- 11 files changed, 27 insertions(+), 8 deletions(-)
diff --git a/include/asm-arm/arch-at91/at91cap9.h b/include/asm-arm/arch-at91/at91cap9.h index 0b52228..b128ac5 100644 --- a/include/asm-arm/arch-at91/at91cap9.h +++ b/include/asm-arm/arch-at91/at91cap9.h @@ -134,4 +134,9 @@
#define CONFIG_DRAM_BASE AT91_CHIPSELECT_6
+/* + * Cpu Name + */ +#define AT91_CPU_NAME "AT91CAP9" + #endif diff --git a/include/asm-arm/arch-at91/at91sam9260.h b/include/asm-arm/arch-at91/at91sam9260.h index 920a7f3..707d7bc 100644 --- a/include/asm-arm/arch-at91/at91sam9260.h +++ b/include/asm-arm/arch-at91/at91sam9260.h @@ -121,4 +121,13 @@ #define AT91SAM9XE_FLASH_BASE 0x00200000 /* Internal FLASH base address */ #define AT91SAM9XE_SRAM_BASE 0x00300000 /* Internal SRAM base address */
+/* + * Cpu Name + */ +#if defined(CONFIG_AT91SAM9260) +#define AT91_CPU_NAME "AT91SAM9260" +#if defined(CONFIG_AT91SAM9G20) +#define AT91_CPU_NAME "AT91SAM9G20" +#endif + #endif diff --git a/include/asm-arm/arch-at91/at91sam9261.h b/include/asm-arm/arch-at91/at91sam9261.h index 752d81d..b303e07 100644 --- a/include/asm-arm/arch-at91/at91sam9261.h +++ b/include/asm-arm/arch-at91/at91sam9261.h @@ -101,5 +101,9 @@ #define AT91SAM9261_UHP_BASE 0x00500000 /* USB Host controller */ #define AT91SAM9261_LCDC_BASE 0x00600000 /* LDC controller */
+/* + * Cpu Name + */ +#define AT91_CPU_NAME "AT91SAM9261"
#endif diff --git a/include/asm-arm/arch-at91/at91sam9263.h b/include/asm-arm/arch-at91/at91sam9263.h index 07b265f..966a683 100644 --- a/include/asm-arm/arch-at91/at91sam9263.h +++ b/include/asm-arm/arch-at91/at91sam9263.h @@ -124,5 +124,9 @@ #define AT91SAM9263_DMAC_BASE 0x00800000 /* DMA Controller */ #define AT91SAM9263_UHP_BASE 0x00a00000 /* USB Host controller */
+/* + * Cpu Name + */ +#define AT91_CPU_NAME "AT91SAM9263"
#endif diff --git a/include/asm-arm/arch-at91/at91sam9rl.h b/include/asm-arm/arch-at91/at91sam9rl.h index 215bbc8..4dd8037 100644 --- a/include/asm-arm/arch-at91/at91sam9rl.h +++ b/include/asm-arm/arch-at91/at91sam9rl.h @@ -112,4 +112,9 @@ #define AT91SAM9RL_LCDC_BASE 0x00500000 /* LCD Controller */ #define AT91SAM9RL_UDPHS_BASE 0x00600000 /* USB Device HS controller */
+/* + * Cpu Name + */ +#define AT91_CPU_NAME "AT91SAM9RL" + #endif diff --git a/include/configs/at91cap9adk.h b/include/configs/at91cap9adk.h index b2e6d7d..526cd60 100644 --- a/include/configs/at91cap9adk.h +++ b/include/configs/at91cap9adk.h @@ -28,7 +28,6 @@ #define __CONFIG_H
/* ARM asynchronous clock */ -#define AT91_CPU_NAME "AT91CAP9" #define AT91_MAIN_CLOCK 12000000 /* 12 MHz crystal */ #define CONFIG_SYS_HZ 1000
diff --git a/include/configs/at91sam9260ek.h b/include/configs/at91sam9260ek.h index e46c9d6..1828c63 100644 --- a/include/configs/at91sam9260ek.h +++ b/include/configs/at91sam9260ek.h @@ -34,10 +34,8 @@ #define CONFIG_ARM926EJS 1 /* This is an ARM926EJS Core */
#ifdef CONFIG_AT91SAM9G20EK -#define AT91_CPU_NAME "AT91SAM9G20" #define CONFIG_AT91SAM9G20 1 /* It's an Atmel AT91SAM9G20 SoC*/ #else -#define AT91_CPU_NAME "AT91SAM9260" #define CONFIG_AT91SAM9260 1 /* It's an Atmel AT91SAM9260 SoC*/ #endif
diff --git a/include/configs/at91sam9261ek.h b/include/configs/at91sam9261ek.h index fdaa71c..b84e361 100644 --- a/include/configs/at91sam9261ek.h +++ b/include/configs/at91sam9261ek.h @@ -28,7 +28,6 @@ #define __CONFIG_H
/* ARM asynchronous clock */ -#define AT91_CPU_NAME "AT91SAM9261" #define AT91_MAIN_CLOCK 18432000 /* 18.432 MHz crystal */ #define CONFIG_SYS_HZ 1000
diff --git a/include/configs/at91sam9263ek.h b/include/configs/at91sam9263ek.h index d03ecee..c212d11 100644 --- a/include/configs/at91sam9263ek.h +++ b/include/configs/at91sam9263ek.h @@ -28,7 +28,6 @@ #define __CONFIG_H
/* ARM asynchronous clock */ -#define AT91_CPU_NAME "AT91SAM9263" #define AT91_MAIN_CLOCK 16367660 /* 16.367 MHz crystal */ #define CONFIG_SYS_HZ 1000
diff --git a/include/configs/at91sam9rlek.h b/include/configs/at91sam9rlek.h index 846d165..c466823 100644 --- a/include/configs/at91sam9rlek.h +++ b/include/configs/at91sam9rlek.h @@ -28,7 +28,6 @@ #define __CONFIG_H
/* ARM asynchronous clock */ -#define AT91_CPU_NAME "AT91SAM9RL" #define AT91_MAIN_CLOCK 12000000 /* 12 MHz crystal */ #define CONFIG_SYS_HZ 1000
diff --git a/include/configs/pm9263.h b/include/configs/pm9263.h index 0db17b3..d60c417 100644 --- a/include/configs/pm9263.h +++ b/include/configs/pm9263.h @@ -29,8 +29,6 @@ #define __CONFIG_H
/* ARM asynchronous clock */ -#define AT91_CPU_NAME "AT91SAM9263" - #define CONFIG_DISPLAY_BOARDINFO
#define MASTER_PLL_DIV 15
Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD plagnioj@jcrosoft.com --- Fix a typo board/ronetix/pm9263/pm9263.c | 7 ------- cpu/arm926ejs/at91/cpu.c | 17 +++++++++++++++++ include/configs/pm9263.h | 1 + 3 files changed, 18 insertions(+), 7 deletions(-)
diff --git a/board/ronetix/pm9263/pm9263.c b/board/ronetix/pm9263/pm9263.c index d24ef9a..d2598a0 100644 --- a/board/ronetix/pm9263/pm9263.c +++ b/board/ronetix/pm9263/pm9263.c @@ -382,15 +382,8 @@ int board_eth_init(bd_t *bis) int checkboard (void) { char *ss; - char buf[32];
printf ("Board : Ronetix PM9263\n"); - printf ("Crystal frequency: %8s MHz\n", - strmhz(buf, get_main_clk_rate())); - printf ("CPU clock : %8s MHz\n", - strmhz(buf, get_cpu_clk_rate())); - printf ("Master clock : %8s MHz\n", - strmhz(buf, get_mck_clk_rate()));
switch (gd->fb_base) { case PHYS_PSRAM: diff --git a/cpu/arm926ejs/at91/cpu.c b/cpu/arm926ejs/at91/cpu.c index a9705cf..594103e 100644 --- a/cpu/arm926ejs/at91/cpu.c +++ b/cpu/arm926ejs/at91/cpu.c @@ -12,3 +12,20 @@ int arch_cpu_init(void) return at91_clock_init(0); #endif } + +#if defined(CONFIG_DISPLAY_CPUINFO) +int print_cpuinfo(void) +{ + char buf[32]; + + printf("CPU: %s\n", AT91_CPU_NAME); + printf("Crystal frequency: %8s MHz\n", + strmhz(buf, get_main_clk_rate())); + printf("CPU clock : %8s MHz\n", + strmhz(buf, get_cpu_clk_rate())); + printf("Master clock : %8s MHz\n", + strmhz(buf, get_mck_clk_rate())); + + return 0; +} +#endif diff --git a/include/configs/pm9263.h b/include/configs/pm9263.h index d60c417..f0dbe81 100644 --- a/include/configs/pm9263.h +++ b/include/configs/pm9263.h @@ -29,6 +29,7 @@ #define __CONFIG_H
/* ARM asynchronous clock */ +#define CONFIG_DISPLAY_CPUINFO #define CONFIG_DISPLAY_BOARDINFO
