[U-Boot] [PATCH] sf: Poll both the read status and flag status
Poll both the Read status and Flag status registers for sucessful erase and program operations for the Micron devices with E_FSR flag set in params table.
Signed-off-by: Siva Durga Prasad Paladugu sivadur@xilinx.com --- drivers/mtd/spi/sf_ops.c | 32 +++++++++++++++++++++++++------- 1 file changed, 25 insertions(+), 7 deletions(-)
diff --git a/drivers/mtd/spi/sf_ops.c b/drivers/mtd/spi/sf_ops.c index 34bc54e..38592f5 100644 --- a/drivers/mtd/spi/sf_ops.c +++ b/drivers/mtd/spi/sf_ops.c @@ -154,21 +154,17 @@ static void spi_flash_dual_flash(struct spi_flash *flash, u32 *addr) } #endif
-int spi_flash_cmd_wait_ready(struct spi_flash *flash, unsigned long timeout) +static int spi_flash_poll_status(struct spi_slave *spi, unsigned long timeout, + u8 cmd, u8 poll_bit) { - struct spi_slave *spi = flash->spi; unsigned long timebase; unsigned long flags = SPI_XFER_BEGIN; int ret; u8 status; u8 check_status = 0x0; - u8 poll_bit = STATUS_WIP; - u8 cmd = flash->poll_cmd;
- if (cmd == CMD_FLAG_STATUS) { - poll_bit = STATUS_PEC; + if (cmd == CMD_FLAG_STATUS) check_status = poll_bit; - }
#ifdef CONFIG_SF_DUAL_FLASH if (spi->flags & SPI_XFER_U_PAGE) @@ -204,6 +200,28 @@ int spi_flash_cmd_wait_ready(struct spi_flash *flash, unsigned long timeout) return -1; }
+int spi_flash_cmd_wait_ready(struct spi_flash *flash, unsigned long timeout) +{ + struct spi_slave *spi = flash->spi; + int ret; + u8 poll_bit = STATUS_WIP; + u8 cmd = CMD_READ_STATUS; + + ret = spi_flash_poll_status(spi, timeout, cmd, poll_bit); + if (ret < 0) + return ret; + + if (flash->poll_cmd == CMD_FLAG_STATUS) { + poll_bit = STATUS_PEC; + cmd = CMD_FLAG_STATUS; + ret = spi_flash_poll_status(spi, timeout, cmd, poll_bit); + if (ret < 0) + return ret; + } + + return 0; +} + int spi_flash_write_common(struct spi_flash *flash, const u8 *cmd, size_t cmd_len, const void *buf, size_t buf_len) {
Hi Siva Durga Prasad,
On 11 March 2015 at 14:47, Siva Durga Prasad Paladugu siva.durga.paladugu@xilinx.com wrote:
There is hw DIE transition from 256 to 512 and 1G, Did you test these?
int ret;
if (ret < 0)
return ret;
if (ret < 0)
return ret;
int spi_flash_write_common(struct spi_flash *flash, const u8 *cmd, size_t cmd_len, const void *buf, size_t buf_len) { -- 2.1.1
thanks!
int ret;
if (ret < 0)
return ret;
if (ret < 0)
return ret;
Applied to u-boot-spi/master
thanks!
Jagan Teki
