[U-Boot] [PATCH] ARM: hisilicon: hikey: Fix eMMC with latest ATF & U-Boot
ATF can leave the MMC IP in a state where U-Boot mmc driver can't enumerate the eMMC.
This patch provides a mmc0_reset_clk() function like we already so do sd card controller which resets the IP when entering U-Boot.
With this patch applied eMMC partitions are successfully enumerated again.
=> mmc dev 0 switch to partitions #0, OK mmc0(part 0) is current device => mmc part
Partition Map for MMC device 0 -- Partition Type: EFI
Part Start LBA End LBA Name Attributes Type GUID Partition GUID 1 0x00000800 0x00000fff "vrl" attrs: 0x0000000000000000 type: ebd0a0a2-b9e5-4433-87c0-68b6b72699c7 guid: 496847ab-56a1-4cd5-a1ad-47f4acf055c9 2 0x00001000 0x000017ff "vrl_backup" attrs: 0x0000000000000000 type: ebd0a0a2-b9e5-4433-87c0-68b6b72699c7 guid: 61a36fc1-8efb-4899-84d8-b61642efa723 3 0x00001800 0x00001fff "mcuimage" <snip>
Signed-off-by: Peter Griffin peter.griffin@linaro.org --- board/hisilicon/hikey/hikey.c | 39 +++++++++++++++++++++++++++++++++++++-- 1 file changed, 37 insertions(+), 2 deletions(-)
diff --git a/board/hisilicon/hikey/hikey.c b/board/hisilicon/hikey/hikey.c index 47bce4d..8405467 100644 --- a/board/hisilicon/hikey/hikey.c +++ b/board/hisilicon/hikey/hikey.c @@ -295,13 +295,47 @@ static void mmc1_reset_clk(void) data = readl(&peri_sc->rst0_stat); } while (!(data & PERI_RST0_MMC1));
- /* unreset mmc0 clock domain */ + /* unreset mmc1 clock domain */ writel(PERI_RST0_MMC1, &peri_sc->rst0_dis); do { data = readl(&peri_sc->rst0_stat); } while (data & PERI_RST0_MMC1); }
+static void mmc0_reset_clk(void) +{ + unsigned int data; + + /* disable mmc0 bus clock */ + hi6220_clk_disable(PERI_CLK0_MMC0, &peri_sc->clk0_dis); + + /* enable mmc0 bus clock */ + hi6220_clk_enable(PERI_CLK0_MMC0, &peri_sc->clk0_en); + + /* reset mmc0 clock domain */ + writel(PERI_RST0_MMC0, &peri_sc->rst0_en); + + /* bypass mmc0 clock phase */ + data = readl(&peri_sc->ctrl2); + data |= 3; + writel(data, &peri_sc->ctrl2); + + /* disable low power */ + data = readl(&peri_sc->ctrl13); + data |= 1 << 3; + writel(data, &peri_sc->ctrl13); + do { + data = readl(&peri_sc->rst0_stat); + } while (!(data & PERI_RST0_MMC0)); + + /* unreset mmc0 clock domain */ + writel(PERI_RST0_MMC0, &peri_sc->rst0_dis); + do { + data = readl(&peri_sc->rst0_stat); + } while (data & PERI_RST0_MMC0); +} + + /* PMU SSI is the IP that maps the external PMU hi6553 registers as IO */ static void hi6220_pmussi_init(void) { @@ -349,7 +383,8 @@ static int init_dwmmc(void)
#ifdef CONFIG_MMC_DW
- /* mmc0 clocks are already configured by ATF */ + /* mmc0 pll is already configured by ATF */ + mmc0_reset_clk(); ret = hi6220_pinmux_config(PERIPH_ID_SDMMC0); if (ret) printf("%s: Error configuring pinmux for eMMC (%d)\n"
<snip>
Peter Griffin
