[PATCH v3 00/10] Add support for SUNIV and F1C100s.
This patch set aims to add support for the SUNIV and F1C100s. Support has been in linux for a while now, but not in u-boot.
This patchset contains: - CPU specific initialization code - SUNIV dram driver - SUNIV clock driver adaption - SUNIV gpio driver adaption - SUNIV uart driver adaption - F1C100s basic support
The SUNIV seems to be similar to sun6i and sun4i, so we use code from both platforms. We also add suniv to the cpu dircetory as it uses arm926ejs.
Icenowy Zheng (9): arm: arm926ej-s: start.S: port save_boot_params support from armv7 code arm: arm926ej-s: Add sunxi code ARM: sunxi: Add clock and uart to sunxi headers sunxi: Add F1C100s DRAM initial support sunxi: board: Add support for SUNIV configs: sunxi: Add common SUNIV header mach-sunxi: Add support for SUNIV architecture ARM: dts: suniv: Add device tree files and bindings for F1C100s configs: sunxi: Add support for Lichee Pi Nano
Jesse Taube (1): mach-sunxi: Move timer code to mach folder
Kconfig | 8 +- arch/arm/cpu/arm926ejs/Makefile | 1 + arch/arm/cpu/arm926ejs/cpu.c | 13 + arch/arm/cpu/arm926ejs/start.S | 19 + arch/arm/cpu/arm926ejs/sunxi/Makefile | 5 + arch/arm/cpu/arm926ejs/sunxi/config.mk | 6 + arch/arm/cpu/arm926ejs/sunxi/fel_utils.S | 33 ++ arch/arm/cpu/arm926ejs/sunxi/u-boot-spl.lds | 48 ++ arch/arm/cpu/armv7/sunxi/Makefile | 1 - arch/arm/dts/Makefile | 2 + arch/arm/dts/suniv-f1c100s-licheepi-nano.dts | 26 ++ arch/arm/dts/suniv-f1c100s.dtsi | 144 ++++++ arch/arm/dts/sunxi-u-boot.dtsi | 2 + arch/arm/include/asm/arch-sunxi/clock.h | 2 +- arch/arm/include/asm/arch-sunxi/clock_sun6i.h | 13 + arch/arm/include/asm/arch-sunxi/cpu_sun4i.h | 6 + arch/arm/include/asm/arch-sunxi/dram.h | 2 + arch/arm/include/asm/arch-sunxi/dram_suniv.h | 46 ++ arch/arm/include/asm/arch-sunxi/gpio.h | 1 + arch/arm/mach-sunxi/Kconfig | 14 +- arch/arm/mach-sunxi/Makefile | 5 + arch/arm/mach-sunxi/board.c | 28 +- arch/arm/mach-sunxi/clock.c | 3 +- arch/arm/mach-sunxi/clock_sun6i.c | 89 ++-- arch/arm/mach-sunxi/cpu_info.c | 2 + arch/arm/mach-sunxi/dram_helpers.c | 4 + arch/arm/mach-sunxi/dram_suniv.c | 420 ++++++++++++++++++ .../{cpu/armv7/sunxi => mach-sunxi}/timer.c | 7 +- board/sunxi/board.c | 4 +- boot/Kconfig | 7 +- configs/licheepi_nano_defconfig | 11 + include/configs/suniv.h | 14 + include/configs/sunxi-common.h | 57 ++- include/dt-bindings/clock/suniv-ccu-f1c100s.h | 70 +++ include/dt-bindings/reset/suniv-ccu-f1c100s.h | 38 ++ 35 files changed, 1091 insertions(+), 60 deletions(-) create mode 100644 arch/arm/cpu/arm926ejs/sunxi/Makefile create mode 100644 arch/arm/cpu/arm926ejs/sunxi/config.mk create mode 100644 arch/arm/cpu/arm926ejs/sunxi/fel_utils.S create mode 100644 arch/arm/cpu/arm926ejs/sunxi/u-boot-spl.lds create mode 100644 arch/arm/dts/suniv-f1c100s-licheepi-nano.dts create mode 100644 arch/arm/dts/suniv-f1c100s.dtsi create mode 100644 arch/arm/include/asm/arch-sunxi/dram_suniv.h create mode 100644 arch/arm/mach-sunxi/dram_suniv.c rename arch/arm/{cpu/armv7/sunxi => mach-sunxi}/timer.c (97%) create mode 100644 configs/licheepi_nano_defconfig create mode 100644 include/configs/suniv.h create mode 100644 include/dt-bindings/clock/suniv-ccu-f1c100s.h create mode 100644 include/dt-bindings/reset/suniv-ccu-f1c100s.h
The ARMv7 start code has support for saving some boot params at the entry point, which is used by some SoCs to return to BROM.
Port this to ARM926EJ-S start code.
Signed-off-by: Icenowy Zheng icenowy@aosc.io Reviewed-by: Andre Przywara andre.przywara@arm.com Signed-off-by: Jesse Taube Mr.Bossman075@gmail.com --- V1->V2: * Nothing done V2->V3: * Nothing done --- arch/arm/cpu/arm926ejs/start.S | 19 +++++++++++++++++++ 1 file changed, 19 insertions(+)
diff --git a/arch/arm/cpu/arm926ejs/start.S b/arch/arm/cpu/arm926ejs/start.S index 0afcc47aad..aca7793c57 100644 --- a/arch/arm/cpu/arm926ejs/start.S +++ b/arch/arm/cpu/arm926ejs/start.S @@ -17,6 +17,7 @@ #include <asm-offsets.h> #include <config.h> #include <common.h> +#include <linux/linkage.h>
/* ************************************************************************* @@ -32,8 +33,13 @@ */
.globl reset + .globl save_boot_params_ret + .type save_boot_params_ret,%function
reset: + /* Allow the board to save important registers */ + b save_boot_params +save_boot_params_ret: /* * set the cpu to SVC32 mode */ @@ -110,3 +116,16 @@ flush_dcache: #endif mov pc, lr /* back to my caller */ #endif /* CONFIG_IS_ENABLED(SKIP_LOWLEVEL_INIT) */ + +/************************************************************************* + * + * void save_boot_params(u32 r0, u32 r1, u32 r2, u32 r3) + * __attribute__((weak)); + * + * Stack pointer is not yet initialized at this moment + * Don't save anything to stack even if compiled with -O0 + * + *************************************************************************/ +WEAK(save_boot_params) + b save_boot_params_ret /* back to my caller */ +ENDPROC(save_boot_params)
Both armv7 and arm926ejs use this timer code so move it to mach-sunxi.
Signed-off-by: Jesse Taube Mr.Bossman075@gmail.com --- V1->V2: * New commit V2->V3: * Remove timer.o from armv7 Makefile --- arch/arm/cpu/armv7/sunxi/Makefile | 1 - arch/arm/mach-sunxi/Makefile | 3 +++ arch/arm/{cpu/armv7/sunxi => mach-sunxi}/timer.c | 7 ++++--- 3 files changed, 7 insertions(+), 4 deletions(-) rename arch/arm/{cpu/armv7/sunxi => mach-sunxi}/timer.c (97%)
diff --git a/arch/arm/cpu/armv7/sunxi/Makefile b/arch/arm/cpu/armv7/sunxi/Makefile index ad11be7863..3e975b366c 100644 --- a/arch/arm/cpu/armv7/sunxi/Makefile +++ b/arch/arm/cpu/armv7/sunxi/Makefile @@ -5,7 +5,6 @@ # Based on some other Makefile # (C) Copyright 2000-2003 # Wolfgang Denk, DENX Software Engineering, wd@denx.de. -obj-y += timer.o
obj-$(CONFIG_MACH_SUN6I) += tzpc.o obj-$(CONFIG_MACH_SUN8I_H3) += tzpc.o diff --git a/arch/arm/mach-sunxi/Makefile b/arch/arm/mach-sunxi/Makefile index 5d3fd70f74..b1adb75e17 100644 --- a/arch/arm/mach-sunxi/Makefile +++ b/arch/arm/mach-sunxi/Makefile @@ -25,6 +25,9 @@ obj-$(CONFIG_MACH_SUN8I) += clock_sun6i.o endif obj-$(CONFIG_MACH_SUN9I) += clock_sun9i.o gtbus_sun9i.o obj-$(CONFIG_SUN50I_GEN_H6) += clock_sun50i_h6.o +ifndef CONFIG_ARM64 +obj-y += timer.o +endif
ifdef CONFIG_SPL_BUILD obj-$(CONFIG_DRAM_SUN4I) += dram_sun4i.o diff --git a/arch/arm/cpu/armv7/sunxi/timer.c b/arch/arm/mach-sunxi/timer.c similarity index 97% rename from arch/arm/cpu/armv7/sunxi/timer.c rename to arch/arm/mach-sunxi/timer.c index b758599636..fc9d419a25 100644 --- a/arch/arm/cpu/armv7/sunxi/timer.c +++ b/arch/arm/mach-sunxi/timer.c @@ -51,6 +51,7 @@ int timer_init(void) struct sunxi_timer_reg *timers = (struct sunxi_timer_reg *)SUNXI_TIMER_BASE; struct sunxi_timer *timer = &timers->timer[TIMER_NUM]; + writel(TIMER_LOAD_VAL, &timer->inter); writel(TIMER_MODE | TIMER_DIV | TIMER_SRC | TIMER_RELOAD | TIMER_EN, &timer->ctl); @@ -58,15 +59,14 @@ int timer_init(void) return 0; }
-/* timer without interrupts */ static ulong get_timer_masked(void) { /* current tick value */ ulong now = TICKS_TO_HZ(read_timer());
- if (now >= gd->arch.lastinc) /* normal (non rollover) */ + if (now >= gd->arch.lastinc) { /* normal (non rollover) */ gd->arch.tbl += (now - gd->arch.lastinc); - else { + } else { /* rollover */ gd->arch.tbl += (TICKS_TO_HZ(TIMER_LOAD_VAL) - gd->arch.lastinc) + now; @@ -76,6 +76,7 @@ static ulong get_timer_masked(void) return gd->arch.tbl; }
+/* timer without interrupts */ ulong get_timer(ulong base) { return get_timer_masked() - base;
On Sat, 29 Jan 2022 10:23:01 -0500 Jesse Taube mr.bossman075@gmail.com wrote:
Thanks, Andre
V1->V2:
- New commit
V2->V3:
- Remove timer.o from armv7 Makefile
- writel(TIMER_LOAD_VAL, &timer->inter); writel(TIMER_MODE | TIMER_DIV | TIMER_SRC | TIMER_RELOAD | TIMER_EN, &timer->ctl);
- if (now >= gd->arch.lastinc) { /* normal (non rollover) */ gd->arch.tbl += (now - gd->arch.lastinc);
- else {
- } else { /* rollover */ gd->arch.tbl += (TICKS_TO_HZ(TIMER_LOAD_VAL) - gd->arch.lastinc) + now;
Some Allwinner SoCs use ARM926EJ-S core.
Add Allwinner/sunXi specific code to ARM926EJ-S CPU dircetory.
Signed-off-by: Icenowy Zheng icenowy@aosc.io Reviewed-by: Andre Przywara andre.przywara@arm.com Signed-off-by: Jesse Taube Mr.Bossman075@gmail.com --- V1->V2: * Fix Copyright notice * Remove lowlevel_init * Remove replaced timer.c * Remove Read CP15 Control Register * Remove unused start.c V2->V3: * Add sdelay to arm926ejs/cpu.c --- arch/arm/cpu/arm926ejs/Makefile | 1 + arch/arm/cpu/arm926ejs/cpu.c | 13 ++++++ arch/arm/cpu/arm926ejs/sunxi/Makefile | 5 +++ arch/arm/cpu/arm926ejs/sunxi/config.mk | 6 +++ arch/arm/cpu/arm926ejs/sunxi/fel_utils.S | 33 ++++++++++++++ arch/arm/cpu/arm926ejs/sunxi/u-boot-spl.lds | 48 +++++++++++++++++++++ 6 files changed, 106 insertions(+) create mode 100644 arch/arm/cpu/arm926ejs/sunxi/Makefile create mode 100644 arch/arm/cpu/arm926ejs/sunxi/config.mk create mode 100644 arch/arm/cpu/arm926ejs/sunxi/fel_utils.S create mode 100644 arch/arm/cpu/arm926ejs/sunxi/u-boot-spl.lds
diff --git a/arch/arm/cpu/arm926ejs/Makefile b/arch/arm/cpu/arm926ejs/Makefile index b901b7c5c9..7f1436d76e 100644 --- a/arch/arm/cpu/arm926ejs/Makefile +++ b/arch/arm/cpu/arm926ejs/Makefile @@ -15,6 +15,7 @@ endif obj-$(CONFIG_MX27) += mx27/ obj-$(if $(filter mxs,$(SOC)),y) += mxs/ obj-$(if $(filter spear,$(SOC)),y) += spear/ +obj-$(CONFIG_ARCH_SUNXI) += sunxi/
# some files can only build in ARM or THUMB2, not THUMB1
diff --git a/arch/arm/cpu/arm926ejs/cpu.c b/arch/arm/cpu/arm926ejs/cpu.c index 93d7a02ed4..2ce413a7f8 100644 --- a/arch/arm/cpu/arm926ejs/cpu.c +++ b/arch/arm/cpu/arm926ejs/cpu.c @@ -21,6 +21,19 @@
static void cache_flush(void);
+/************************************************************ + * sdelay() - simple spin loop. Will be constant time as + * its generally used in bypass conditions only. This + * is necessary until timers are accessible. + * + * not inline to increase chances its in cache when called + *************************************************************/ +void sdelay(unsigned long loops) +{ + __asm__ volatile ("1:\n" "subs %0, %1, #1\n" + "bne 1b":"=r" (loops):"0"(loops)); +} + int cleanup_before_linux (void) { /* diff --git a/arch/arm/cpu/arm926ejs/sunxi/Makefile b/arch/arm/cpu/arm926ejs/sunxi/Makefile new file mode 100644 index 0000000000..7d8b959dcd --- /dev/null +++ b/arch/arm/cpu/arm926ejs/sunxi/Makefile @@ -0,0 +1,5 @@ +# SPDX-License-Identifier: GPL-2.0+ +# (C) Copyright 2012 Henrik Nordstrom henrik@henriknordstrom.net + +obj-y += fel_utils.o +CFLAGS_fel_utils.o := -marm diff --git a/arch/arm/cpu/arm926ejs/sunxi/config.mk b/arch/arm/cpu/arm926ejs/sunxi/config.mk new file mode 100644 index 0000000000..76ffec9df6 --- /dev/null +++ b/arch/arm/cpu/arm926ejs/sunxi/config.mk @@ -0,0 +1,6 @@ +# Build a combined spl + u-boot image +ifdef CONFIG_SPL +ifndef CONFIG_SPL_BUILD +ALL-y += u-boot-sunxi-with-spl.bin +endif +endif diff --git a/arch/arm/cpu/arm926ejs/sunxi/fel_utils.S b/arch/arm/cpu/arm926ejs/sunxi/fel_utils.S new file mode 100644 index 0000000000..08be7ed11a --- /dev/null +++ b/arch/arm/cpu/arm926ejs/sunxi/fel_utils.S @@ -0,0 +1,33 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * Utility functions for FEL mode. + * + * Copyright (c) 2015 Google, Inc + */ + +#include <asm-offsets.h> +#include <config.h> +#include <asm/system.h> +#include <linux/linkage.h> + +ENTRY(save_boot_params) + ldr r0, =fel_stash + str sp, [r0, #0] + str lr, [r0, #4] + mrs lr, cpsr @ Read CPSR + str lr, [r0, #8] + mrc p15, 0, lr, c1, c0, 0 @ Read CP15 SCTLR Register + str lr, [r0, #12] + b save_boot_params_ret +ENDPROC(save_boot_params) + +ENTRY(return_to_fel) + mov sp, r0 + mov lr, r1 + ldr r0, =fel_stash + ldr r1, [r0, #16] + mcr p15, 0, r1, c1, c0, 0 @ Write CP15 Control Register + ldr r1, [r0, #12] + msr cpsr, r1 @ Write CPSR + bx lr +ENDPROC(return_to_fel) diff --git a/arch/arm/cpu/arm926ejs/sunxi/u-boot-spl.lds b/arch/arm/cpu/arm926ejs/sunxi/u-boot-spl.lds new file mode 100644 index 0000000000..9a000ac5d3 --- /dev/null +++ b/arch/arm/cpu/arm926ejs/sunxi/u-boot-spl.lds @@ -0,0 +1,48 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * (C) Copyright 2018 + * Icenowy Zheng icenowy@aosc.io + * + * Based on arch/arm/cpu/armv7/sunxi/u-boot-spl.lds: + */ +MEMORY { .sram : ORIGIN = CONFIG_SPL_TEXT_BASE,\ + LENGTH = CONFIG_SPL_MAX_SIZE } +MEMORY { .sdram : ORIGIN = CONFIG_SPL_BSS_START_ADDR, \ + LENGTH = CONFIG_SPL_BSS_MAX_SIZE } + +OUTPUT_FORMAT("elf32-littlearm", "elf32-littlearm", "elf32-littlearm") +OUTPUT_ARCH(arm) +ENTRY(_start) +SECTIONS +{ + .text : + { + __start = .; + *(.vectors) + *(.text*) + } > .sram + + . = ALIGN(4); + .rodata : { *(SORT_BY_ALIGNMENT(.rodata*)) } >.sram + + . = ALIGN(4); + .data : { *(SORT_BY_ALIGNMENT(.data*)) } >.sram + + . = ALIGN(4); + .u_boot_list : { + KEEP(*(SORT(.u_boot_list*))); + } > .sram + + . = ALIGN(4); + __image_copy_end = .; + _end = .; + + .bss : + { + . = ALIGN(4); + __bss_start = .; + *(.bss*) + . = ALIGN(4); + __bss_end = .; + } > .sdram +}
This patch aims to add header files for the suniv. The header files included add support for uart, and clocks.
Signed-off-by: Icenowy Zheng icenowy@aosc.io Reviewed-by: Andre Przywara andre.przywara@arm.com Signed-off-by: Jesse Taube Mr.Bossman075@gmail.com --- V1->V2: * Change commit description and topic * Change PLL6_CFG_DEFAULT * Combine APB1_GATE ifdefs * Combine SUNXI_UART0_BASE ifdefs * Fix negative logic * Remove unused macros V2->V3: * Nothing done --- arch/arm/include/asm/arch-sunxi/clock.h | 2 +- arch/arm/include/asm/arch-sunxi/clock_sun6i.h | 13 +++++++++++++ arch/arm/include/asm/arch-sunxi/cpu_sun4i.h | 6 ++++++ arch/arm/include/asm/arch-sunxi/gpio.h | 1 + 4 files changed, 21 insertions(+), 1 deletion(-)
diff --git a/arch/arm/include/asm/arch-sunxi/clock.h b/arch/arm/include/asm/arch-sunxi/clock.h index cbbe5c7a1e..2cfd540742 100644 --- a/arch/arm/include/asm/arch-sunxi/clock.h +++ b/arch/arm/include/asm/arch-sunxi/clock.h @@ -19,7 +19,7 @@ #elif defined(CONFIG_SUN50I_GEN_H6) #include <asm/arch/clock_sun50i_h6.h> #elif defined(CONFIG_MACH_SUN6I) || defined(CONFIG_MACH_SUN8I) || \ - defined(CONFIG_MACH_SUN50I) + defined(CONFIG_MACH_SUN50I) || defined(CONFIG_MACH_SUNIV) #include <asm/arch/clock_sun6i.h> #elif defined(CONFIG_MACH_SUN9I) #include <asm/arch/clock_sun9i.h> diff --git a/arch/arm/include/asm/arch-sunxi/clock_sun6i.h b/arch/arm/include/asm/arch-sunxi/clock_sun6i.h index ee387127f3..7fcf340db6 100644 --- a/arch/arm/include/asm/arch-sunxi/clock_sun6i.h +++ b/arch/arm/include/asm/arch-sunxi/clock_sun6i.h @@ -226,7 +226,12 @@ struct sunxi_ccm_reg { #define CCM_PLL5_CTRL_SIGMA_DELTA_EN (0x1 << 24) #define CCM_PLL5_CTRL_EN (0x1 << 31)
+#ifdef CONFIG_MACH_SUNIV +/* suniv pll6 doesn't have postdiv 2, so k is set to 0 */ +#define PLL6_CFG_DEFAULT 0x90041801 +#else #define PLL6_CFG_DEFAULT 0x90041811 /* 600 MHz */ +#endif
#define CCM_PLL6_CTRL_N_SHIFT 8 #define CCM_PLL6_CTRL_N_MASK (0x1f << CCM_PLL6_CTRL_N_SHIFT) @@ -488,6 +493,14 @@ struct sunxi_ccm_reg { #define AHB_RESET_OFFSET_EPHY 2 #define AHB_RESET_OFFSET_LVDS 0
+/* apb1 reset */ +#ifdef CONFIG_MACH_SUNIV +#define APB1_GATE_UART_SHIFT (20) +#define APB1_GATE_TWI_SHIFT (16) +#define APB1_RESET_UART_SHIFT (20) +#define APB1_RESET_TWI_SHIFT (16) +#endif + /* apb2 reset */ #define APB2_RESET_UART_SHIFT (16) #define APB2_RESET_UART_MASK (0xff << APB2_RESET_UART_SHIFT) diff --git a/arch/arm/include/asm/arch-sunxi/cpu_sun4i.h b/arch/arm/include/asm/arch-sunxi/cpu_sun4i.h index d4c795d89c..b7b4564af3 100644 --- a/arch/arm/include/asm/arch-sunxi/cpu_sun4i.h +++ b/arch/arm/include/asm/arch-sunxi/cpu_sun4i.h @@ -129,9 +129,15 @@ defined(CONFIG_MACH_SUN50I) #define SUNXI_CPUCFG_BASE 0x01c25c00 #endif
+#ifndef CONFIG_MACH_SUNIV #define SUNXI_UART0_BASE 0x01c28000 #define SUNXI_UART1_BASE 0x01c28400 #define SUNXI_UART2_BASE 0x01c28800 +#else +#define SUNXI_UART0_BASE 0x01c25000 +#define SUNXI_UART1_BASE 0x01c25400 +#define SUNXI_UART2_BASE 0x01c25800 +#endif #define SUNXI_UART3_BASE 0x01c28c00 #define SUNXI_UART4_BASE 0x01c29000 #define SUNXI_UART5_BASE 0x01c29400 diff --git a/arch/arm/include/asm/arch-sunxi/gpio.h b/arch/arm/include/asm/arch-sunxi/gpio.h index f3ab1aea0e..ced69f7dd4 100644 --- a/arch/arm/include/asm/arch-sunxi/gpio.h +++ b/arch/arm/include/asm/arch-sunxi/gpio.h @@ -165,6 +165,7 @@ enum sunxi_gpio_number { #define SUNXI_GPD_LVDS0 3 #define SUNXI_GPD_PWM 2
+#define SUNIV_GPE_UART0 5 #define SUN8I_GPE_TWI2 3 #define SUN50I_GPE_TWI2 3
Add support for F1C100s internal dram controller.
Signed-off-by: Icenowy Zheng icenowy@aosc.io Signed-off-by: Jesse Taube Mr.Bossman075@gmail.com --- V1->V2: * Nothing done V2->V3: * Nothing done --- arch/arm/include/asm/arch-sunxi/dram.h | 2 + arch/arm/include/asm/arch-sunxi/dram_suniv.h | 46 ++ arch/arm/mach-sunxi/Makefile | 2 + arch/arm/mach-sunxi/dram_helpers.c | 4 + arch/arm/mach-sunxi/dram_suniv.c | 420 +++++++++++++++++++ 5 files changed, 474 insertions(+) create mode 100644 arch/arm/include/asm/arch-sunxi/dram_suniv.h create mode 100644 arch/arm/mach-sunxi/dram_suniv.c
diff --git a/arch/arm/include/asm/arch-sunxi/dram.h b/arch/arm/include/asm/arch-sunxi/dram.h index c3b3e1f512..682daae6b1 100644 --- a/arch/arm/include/asm/arch-sunxi/dram.h +++ b/arch/arm/include/asm/arch-sunxi/dram.h @@ -31,6 +31,8 @@ #include <asm/arch/dram_sun50i_h6.h> #elif defined(CONFIG_MACH_SUN50I_H616) #include <asm/arch/dram_sun50i_h616.h> +#elif defined(CONFIG_MACH_SUNIV) +#include <asm/arch/dram_suniv.h> #else #include <asm/arch/dram_sun4i.h> #endif diff --git a/arch/arm/include/asm/arch-sunxi/dram_suniv.h b/arch/arm/include/asm/arch-sunxi/dram_suniv.h new file mode 100644 index 0000000000..6f4c0512d6 --- /dev/null +++ b/arch/arm/include/asm/arch-sunxi/dram_suniv.h @@ -0,0 +1,46 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * suniv DRAM controller register definition + * + * Copyright (C) 2018 Icenowy Zheng icenowy@aosc.io + * + * Based on xboot's arch/arm32/mach-f1c100s/sys-dram.c, which is: + * + * Copyright(c) 2007-2018 Jianjun Jiang 8192542@qq.com + */ + +#define PIO_SDRAM_DRV (0x2c0) +#define PIO_SDRAM_PULL (0x2c4) + +#define DRAM_SCONR (0x00) +#define DRAM_STMG0R (0x04) +#define DRAM_STMG1R (0x08) +#define DRAM_SCTLR (0x0c) +#define DRAM_SREFR (0x10) +#define DRAM_SEXTMR (0x14) +#define DRAM_DDLYR (0x24) +#define DRAM_DADRR (0x28) +#define DRAM_DVALR (0x2c) +#define DRAM_DRPTR0 (0x30) +#define DRAM_DRPTR1 (0x34) +#define DRAM_DRPTR2 (0x38) +#define DRAM_DRPTR3 (0x3c) +#define DRAM_SEFR (0x40) +#define DRAM_MAE (0x44) +#define DRAM_ASPR (0x48) +#define DRAM_SDLY0 (0x4C) +#define DRAM_SDLY1 (0x50) +#define DRAM_SDLY2 (0x54) +#define DRAM_MCR0 (0x100) +#define DRAM_MCR1 (0x104) +#define DRAM_MCR2 (0x108) +#define DRAM_MCR3 (0x10c) +#define DRAM_MCR4 (0x110) +#define DRAM_MCR5 (0x114) +#define DRAM_MCR6 (0x118) +#define DRAM_MCR7 (0x11c) +#define DRAM_MCR8 (0x120) +#define DRAM_MCR9 (0x124) +#define DRAM_MCR10 (0x128) +#define DRAM_MCR11 (0x12c) +#define DRAM_BWCR (0x140) diff --git a/arch/arm/mach-sunxi/Makefile b/arch/arm/mach-sunxi/Makefile index b1adb75e17..58f807cb82 100644 --- a/arch/arm/mach-sunxi/Makefile +++ b/arch/arm/mach-sunxi/Makefile @@ -13,6 +13,7 @@ obj-y += dram_helpers.o obj-y += pinmux.o obj-$(CONFIG_SUN6I_PRCM) += prcm.o obj-$(CONFIG_AXP_PMIC_BUS) += pmic_bus.o +obj-$(CONFIG_MACH_SUNIV) += clock_sun6i.o obj-$(CONFIG_MACH_SUN4I) += clock_sun4i.o obj-$(CONFIG_MACH_SUN5I) += clock_sun4i.o obj-$(CONFIG_MACH_SUN6I) += clock_sun6i.o @@ -30,6 +31,7 @@ obj-y += timer.o endif
ifdef CONFIG_SPL_BUILD +obj-$(CONFIG_MACH_SUNIV) += dram_suniv.o obj-$(CONFIG_DRAM_SUN4I) += dram_sun4i.o obj-$(CONFIG_DRAM_SUN6I) += dram_sun6i.o obj-$(CONFIG_DRAM_SUN8I_A23) += dram_sun8i_a23.o diff --git a/arch/arm/mach-sunxi/dram_helpers.c b/arch/arm/mach-sunxi/dram_helpers.c index 520b597fcc..2c873192e6 100644 --- a/arch/arm/mach-sunxi/dram_helpers.c +++ b/arch/arm/mach-sunxi/dram_helpers.c @@ -26,7 +26,10 @@ void mctl_await_completion(u32 *reg, u32 mask, u32 val)
/* * Test if memory at offset offset matches memory at begin of DRAM + * + * Note: dsb() is not available on ARMv5 in Thumb mode */ +#ifndef CONFIG_MACH_SUNIV bool mctl_mem_matches(u32 offset) { /* Try to write different values to RAM at two addresses */ @@ -37,3 +40,4 @@ bool mctl_mem_matches(u32 offset) return readl(CONFIG_SYS_SDRAM_BASE) == readl((ulong)CONFIG_SYS_SDRAM_BASE + offset); } +#endif diff --git a/arch/arm/mach-sunxi/dram_suniv.c b/arch/arm/mach-sunxi/dram_suniv.c new file mode 100644 index 0000000000..56c2d557ff --- /dev/null +++ b/arch/arm/mach-sunxi/dram_suniv.c @@ -0,0 +1,420 @@ +// SPDX-License-Identifier: (GPL-2.0+) +/* + * suniv DRAM initialization + * + * Copyright (C) 2018 Icenowy Zheng icenowy@aosc.io + * + * Based on xboot's arch/arm32/mach-f1c100s/sys-dram.c, which is: + * + * Copyright(c) 2007-2018 Jianjun Jiang 8192542@qq.com + */ + +#include <common.h> +#include <asm/io.h> +#include <asm/arch/clock.h> +#include <asm/arch/dram.h> +#include <asm/arch/gpio.h> +#include <linux/bitops.h> +#include <linux/delay.h> +#include <hang.h> + +#define SDR_T_CAS (0x2) +#define SDR_T_RAS (0x8) +#define SDR_T_RCD (0x3) +#define SDR_T_RP (0x3) +#define SDR_T_WR (0x3) +#define SDR_T_RFC (0xd) +#define SDR_T_XSR (0xf9) +#define SDR_T_RC (0xb) +#define SDR_T_INIT (0x8) +#define SDR_T_INIT_REF (0x7) +#define SDR_T_WTR (0x2) +#define SDR_T_RRD (0x2) +#define SDR_T_XP (0x0) + +enum dram_type { + DRAM_TYPE_SDR = 0, + DRAM_TYPE_DDR = 1, + /* Not supported yet. */ + DRAM_TYPE_MDDR = 2, +}; + +struct dram_para { + u32 size; /* dram size (unit: MByte) */ + u32 clk; /* dram work clock (unit: MHz) */ + u32 access_mode; /* 0: interleave mode 1: sequence mode */ + u32 cs_num; /* dram chip count 1: one chip 2: two chip */ + u32 ddr8_remap; /* for 8bits data width DDR 0: normal 1: 8bits */ + enum dram_type sdr_ddr; + u32 bwidth; /* dram bus width */ + u32 col_width; /* column address width */ + u32 row_width; /* row address width */ + u32 bank_size; /* dram bank count */ + u32 cas; /* dram cas */ +}; + +struct dram_para suniv_dram_para = { + .size = 32, + .clk = 156, + .access_mode = 1, + .cs_num = 1, + .ddr8_remap = 0, + .sdr_ddr = DRAM_TYPE_DDR, + .bwidth = 16, + .col_width = 10, + .row_width = 13, + .bank_size = 4, + .cas = 0x3, +}; + +static int dram_initial(void) +{ + unsigned int time = 0xffffff; + + setbits_le32(SUNXI_DRAMC_BASE + DRAM_SCTLR, 0x1); + while ((readl(SUNXI_DRAMC_BASE + DRAM_SCTLR) & 0x1) && time--) { + if (time == 0) + return 0; + } + return 1; +} + +static int dram_delay_scan(void) +{ + unsigned int time = 0xffffff; + + setbits_le32(SUNXI_DRAMC_BASE + DRAM_DDLYR, 0x1); + while ((readl(SUNXI_DRAMC_BASE + DRAM_DDLYR) & 0x1) && time--) { + if (time == 0) + return 0; + } + return 1; +} + +static void dram_set_autofresh_cycle(u32 clk) +{ + u32 val = 0; + u32 row = 0; + u32 temp = 0; + + row = readl(SUNXI_DRAMC_BASE + DRAM_SCONR); + row &= 0x1e0; + row >>= 0x5; + + if (row == 0xc) { + if (clk >= 1000000) { + temp = clk + (clk >> 3) + (clk >> 4) + (clk >> 5); + while (temp >= (10000000 >> 6)) { + temp -= (10000000 >> 6); + val++; + } + } else { + val = (clk * 499) >> 6; + } + } else if (row == 0xb) { + if (clk >= 1000000) { + temp = clk + (clk >> 3) + (clk >> 4) + (clk >> 5); + while (temp >= (10000000 >> 7)) { + temp -= (10000000 >> 7); + val++; + } + } else { + val = (clk * 499) >> 5; + } + } + writel(val, SUNXI_DRAMC_BASE + DRAM_SREFR); +} + +static int dram_para_setup(struct dram_para *para) +{ + u32 val = 0; + + val = (para->ddr8_remap) | (0x1 << 1) | + ((para->bank_size >> 2) << 3) | + ((para->cs_num >> 1) << 4) | + ((para->row_width - 1) << 5) | + ((para->col_width - 1) << 9) | + ((para->sdr_ddr ? (para->bwidth >> 4) : (para->bwidth >> 5)) << 13) | + (para->access_mode << 15) | + (para->sdr_ddr << 16); + + writel(val, SUNXI_DRAMC_BASE + DRAM_SCONR); + setbits_le32(SUNXI_DRAMC_BASE + DRAM_SCTLR, 0x1 << 19); + return dram_initial(); +} + +static u32 dram_check_delay(u32 bwidth) +{ + u32 dsize; + int i, j; + u32 num = 0; + u32 dflag = 0; + + dsize = ((bwidth == 16) ? 4 : 2); + for (i = 0; i < dsize; i++) { + if (i == 0) + dflag = readl(SUNXI_DRAMC_BASE + DRAM_DRPTR0); + else if (i == 1) + dflag = readl(SUNXI_DRAMC_BASE + DRAM_DRPTR1); + else if (i == 2) + dflag = readl(SUNXI_DRAMC_BASE + DRAM_DRPTR2); + else if (i == 3) + dflag = readl(SUNXI_DRAMC_BASE + DRAM_DRPTR3); + + for (j = 0; j < 32; j++) { + if (dflag & 0x1) + num++; + dflag >>= 1; + } + } + return num; +} + +static int sdr_readpipe_scan(void) +{ + u32 k = 0; + + for (k = 0; k < 32; k++) + writel(k, CONFIG_SYS_SDRAM_BASE + 4 * k); + for (k = 0; k < 32; k++) { + if (readl(CONFIG_SYS_SDRAM_BASE + 4 * k) != k) + return 0; + } + return 1; +} + +static u32 sdr_readpipe_select(void) +{ + u32 value = 0; + u32 i = 0; + + for (i = 0; i < 8; i++) { + clrsetbits_le32(SUNXI_DRAMC_BASE + DRAM_SCTLR, + 0x7 << 6, i << 6); + if (sdr_readpipe_scan()) { + value = i; + return value; + } + } + return value; +} + +static u32 dram_check_type(struct dram_para *para) +{ + u32 times = 0; + int i; + + for (i = 0; i < 8; i++) { + clrsetbits_le32(SUNXI_DRAMC_BASE + DRAM_SCTLR, + 0x7 << 6, i << 6); + dram_delay_scan(); + if (readl(SUNXI_DRAMC_BASE + DRAM_DDLYR) & 0x30) + times++; + } + + if (times == 8) { + para->sdr_ddr = DRAM_TYPE_SDR; + return 0; + } + para->sdr_ddr = DRAM_TYPE_DDR; + return 1; +} + +static u32 dram_scan_readpipe(struct dram_para *para) +{ + u32 rp_best = 0, rp_val = 0; + u32 readpipe[8]; + int i; + + if (para->sdr_ddr == DRAM_TYPE_DDR) { + for (i = 0; i < 8; i++) { + clrsetbits_le32(SUNXI_DRAMC_BASE + DRAM_SCTLR, + 0x7 << 6, i << 6); + dram_delay_scan(); + readpipe[i] = 0; + if ((((readl(SUNXI_DRAMC_BASE + DRAM_DDLYR) >> 4) & 0x3) == 0x0) && + (((readl(SUNXI_DRAMC_BASE + DRAM_DDLYR) >> 4) & 0x1) == 0x0)) + readpipe[i] = dram_check_delay(para->bwidth); + if (rp_val < readpipe[i]) { + rp_val = readpipe[i]; + rp_best = i; + } + } + clrsetbits_le32(SUNXI_DRAMC_BASE + DRAM_SCTLR, + 0x7 << 6, rp_best << 6); + dram_delay_scan(); + } else { + clrbits_le32(SUNXI_DRAMC_BASE + DRAM_SCONR, + (0x1 << 16) | (0x3 << 13)); + rp_best = sdr_readpipe_select(); + clrsetbits_le32(SUNXI_DRAMC_BASE + DRAM_SCTLR, + 0x7 << 6, rp_best << 6); + } + return 0; +} + +static u32 dram_get_dram_size(struct dram_para *para) +{ + u32 colflag = 10, rowflag = 13; + u32 val1 = 0; + u32 count = 0; + u32 addr1, addr2; + int i; + + para->col_width = colflag; + para->row_width = rowflag; + dram_para_setup(para); + dram_scan_readpipe(para); + for (i = 0; i < 32; i++) { + *((u8 *)(CONFIG_SYS_SDRAM_BASE + 0x200 + i)) = 0x11; + *((u8 *)(CONFIG_SYS_SDRAM_BASE + 0x600 + i)) = 0x22; + } + for (i = 0; i < 32; i++) { + val1 = *((u8 *)(CONFIG_SYS_SDRAM_BASE + 0x200 + i)); + if (val1 == 0x22) + count++; + } + if (count == 32) + colflag = 9; + else + colflag = 10; + count = 0; + para->col_width = colflag; + para->row_width = rowflag; + dram_para_setup(para); + if (colflag == 10) { + addr1 = CONFIG_SYS_SDRAM_BASE + 0x400000; + addr2 = CONFIG_SYS_SDRAM_BASE + 0xc00000; + } else { + addr1 = CONFIG_SYS_SDRAM_BASE + 0x200000; + addr2 = CONFIG_SYS_SDRAM_BASE + 0x600000; + } + for (i = 0; i < 32; i++) { + *((u8 *)(addr1 + i)) = 0x33; + *((u8 *)(addr2 + i)) = 0x44; + } + for (i = 0; i < 32; i++) { + val1 = *((u8 *)(addr1 + i)); + if (val1 == 0x44) + count++; + } + if (count == 32) + rowflag = 12; + else + rowflag = 13; + para->col_width = colflag; + para->row_width = rowflag; + if (para->row_width != 13) + para->size = 16; + else if (para->col_width == 10) + para->size = 64; + else + para->size = 32; + dram_set_autofresh_cycle(para->clk); + para->access_mode = 0; + dram_para_setup(para); + + return 0; +} + +static void simple_dram_check(void) +{ + volatile u32 *dram = (u32 *)CONFIG_SYS_SDRAM_BASE; + int i; + + for (i = 0; i < 0x40; i++) + dram[i] = i; + + for (i = 0; i < 0x40; i++) { + if (dram[i] != i) { + printf("DRAM initialization failed: dram[0x%x] != 0x%x.", i, dram[i]); + hang(); + } + } + + for (i = 0; i < 0x10000; i += 0x40) + dram[i] = i; + + for (i = 0; i < 0x10000; i += 0x40) { + if (dram[i] != i) { + printf("DRAM initialization failed: dram[0x%x] != 0x%x.", i, dram[i]); + hang(); + } + } +} + +static void do_dram_init(struct dram_para *para) +{ + struct sunxi_ccm_reg * const ccm = + (struct sunxi_ccm_reg *)SUNXI_CCM_BASE; + u32 val; + u8 m; /* PLL_DDR clock factor */ + + sunxi_gpio_set_cfgpin(SUNXI_GPB(3), 0x7); + mdelay(5); + /* TODO: dig out what's them... some analog register? */ + if ((para->cas >> 3) & 0x1) + setbits_le32(SUNXI_PIO_BASE + 0x2c4, (0x1 << 23) | (0x20 << 17)); + + if (para->clk >= 144 && para->clk <= 180) + writel(0xaaa, SUNXI_PIO_BASE + 0x2c0); + if (para->clk >= 180) + writel(0xfff, SUNXI_PIO_BASE + 0x2c0); + + if (para->cas & BIT(4)) + writel(0xd1303333, &ccm->pll5_pattern_cfg); + else if (para->cas & BIT(5)) + writel(0xcce06666, &ccm->pll5_pattern_cfg); + else if (para->cas & BIT(6)) + writel(0xc8909999, &ccm->pll5_pattern_cfg); + else if (para->cas & BIT(7)) + writel(0xc440cccc, &ccm->pll5_pattern_cfg); + + if (para->clk <= 96) + m = 2; + else + m = 1; + + val = CCM_PLL5_CTRL_EN | CCM_PLL5_CTRL_UPD | + CCM_PLL5_CTRL_N((para->clk * 2) / (24 / m)) | + CCM_PLL5_CTRL_K(1) | CCM_PLL5_CTRL_M(m); + if (para->cas & GENMASK(7, 4)) + val |= CCM_PLL5_CTRL_SIGMA_DELTA_EN; + writel(val, &ccm->pll5_cfg); + setbits_le32(&ccm->pll5_cfg, CCM_PLL5_CTRL_UPD); + mctl_await_completion(&ccm->pll5_cfg, BIT(28), BIT(28)); + mdelay(5); + + setbits_le32(&ccm->ahb_gate0, (1 << AHB_GATE_OFFSET_MCTL)); + clrbits_le32(&ccm->ahb_reset0_cfg, (1 << AHB_RESET_OFFSET_MCTL)); + udelay(50); + setbits_le32(&ccm->ahb_reset0_cfg, (1 << AHB_RESET_OFFSET_MCTL)); + + clrsetbits_le32(SUNXI_PIO_BASE + 0x2c4, (1 << 16), + ((para->sdr_ddr == DRAM_TYPE_DDR) << 16)); + + val = (SDR_T_CAS << 0) | (SDR_T_RAS << 3) | (SDR_T_RCD << 7) | + (SDR_T_RP << 10) | (SDR_T_WR << 13) | (SDR_T_RFC << 15) | + (SDR_T_XSR << 19) | (SDR_T_RC << 28); + writel(val, SUNXI_DRAMC_BASE + DRAM_STMG0R); + val = (SDR_T_INIT << 0) | (SDR_T_INIT_REF << 16) | (SDR_T_WTR << 20) | + (SDR_T_RRD << 22) | (SDR_T_XP << 25); + writel(val, SUNXI_DRAMC_BASE + DRAM_STMG1R); + dram_para_setup(para); + dram_check_type(para); + + clrsetbits_le32(SUNXI_PIO_BASE + 0x2c4, (1 << 16), + ((para->sdr_ddr == DRAM_TYPE_DDR) << 16)); + + dram_set_autofresh_cycle(para->clk); + dram_scan_readpipe(para); + dram_get_dram_size(para); + simple_dram_check(); +} + +unsigned long sunxi_dram_init(void) +{ + do_dram_init(&suniv_dram_para); + + return suniv_dram_para.size * 1024 * 1024; +}
Generic Timer Extension is not available on SUNIV.
Signed-off-by: Icenowy Zheng icenowy@aosc.io Reviewed-by: Andre Przywara andre.przywara@arm.com Signed-off-by: Jesse Taube Mr.Bossman075@gmail.com --- V1->V2: * Nothing done V2->V3: * Nothing done --- board/sunxi/board.c | 4 ++-- 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/board/sunxi/board.c b/board/sunxi/board.c index 2790a0f9e8..59eb195c26 100644 --- a/board/sunxi/board.c +++ b/board/sunxi/board.c @@ -197,7 +197,7 @@ int board_init(void)
gd->bd->bi_boot_params = (PHYS_SDRAM_0 + 0x100);
-#ifndef CONFIG_ARM64 +#if !defined(CONFIG_ARM64) && !defined(CONFIG_MACH_SUNIV) asm volatile("mrc p15, 0, %0, c0, c1, 1" : "=r"(id_pfr1)); debug("id_pfr1: 0x%08x\n", id_pfr1); /* Generic Timer Extension available? */ @@ -224,7 +224,7 @@ int board_init(void) #endif } } -#endif /* !CONFIG_ARM64 */ +#endif /* !CONFIG_ARM64 && !CONFIG_MACH_SUNIV */
ret = axp_gpio_init(); if (ret)
Adds support for SUNIV and the F1C100s.
Signed-off-by: Icenowy Zheng icenowy@aosc.io Reviewed-by: Andre Przywara andre.przywara@arm.com Signed-off-by: Jesse Taube Mr.Bossman075@gmail.com --- V1->V2: * Combine ifdefs * Fix indentation * Fix negative logic * Fix rebase artifacts * Remove CONFIG_SYS_LOAD_ADDR * Remove CONFIG_ENV_SECT_SIZE V2->V3: * Fix comment --- include/configs/suniv.h | 14 +++++++++ include/configs/sunxi-common.h | 57 +++++++++++++++++++++++++--------- 2 files changed, 56 insertions(+), 15 deletions(-) create mode 100644 include/configs/suniv.h
diff --git a/include/configs/suniv.h b/include/configs/suniv.h new file mode 100644 index 0000000000..6118cd5e1a --- /dev/null +++ b/include/configs/suniv.h @@ -0,0 +1,14 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * Configuration settings for new Allwinner F-series (suniv) CPU + */ + +#ifndef __CONFIG_H +#define __CONFIG_H + +/* + * Include common sunxi configuration where most the settings are + */ +#include <configs/sunxi-common.h> + +#endif /* __CONFIG_H */ diff --git a/include/configs/sunxi-common.h b/include/configs/sunxi-common.h index 01c3cfced2..4bab917c0b 100644 --- a/include/configs/sunxi-common.h +++ b/include/configs/sunxi-common.h @@ -22,7 +22,12 @@ /* Serial & console */ #define CONFIG_SYS_NS16550_SERIAL /* ns16550 reg in the low bits of cpu reg */ +#ifdef CONFIG_MACH_SUNIV +/* suniv doesn't have apb2 and uart is connected to apb1 */ +#define CONFIG_SYS_NS16550_CLK 100000000 +#else #define CONFIG_SYS_NS16550_CLK 24000000 +#endif #ifndef CONFIG_DM_SERIAL # define CONFIG_SYS_NS16550_REG_SIZE -4 # define CONFIG_SYS_NS16550_COM1 SUNXI_UART0_BASE @@ -49,6 +54,15 @@ * since it needs to fit in with the other values. By also #defining it * we get warnings if the Kconfig value mismatches. */ #define CONFIG_SPL_BSS_START_ADDR 0x2ff80000 +#elif defined(CONFIG_MACH_SUNIV) +#define SDRAM_OFFSET(x) 0x8##x +#define CONFIG_SYS_SDRAM_BASE 0x80000000 +/* Note SPL_STACK_R_ADDR is set through Kconfig, we include it here + * since it needs to fit in with the other values. By also #defining it + * we get warnings if the Kconfig value mismatches. + */ +#define CONFIG_SPL_STACK_R_ADDR 0x81e00000 +#define CONFIG_SPL_BSS_START_ADDR 0x81f80000 #else #define SDRAM_OFFSET(x) 0x4##x #define CONFIG_SYS_SDRAM_BASE 0x40000000 @@ -179,13 +193,40 @@ #define FDTOVERLAY_ADDR_R __stringify(SDRAM_OFFSET(FE00000)) #define RAMDISK_ADDR_R __stringify(SDRAM_OFFSET(FF00000))
+#elif defined(CONFIG_MACH_SUN8I_V3S) +/* + * 64M RAM minus 2MB heap + 16MB for u-boot, stack, fb, etc. + * 16M uncompressed kernel, 8M compressed kernel, 1M fdt, + * 1M script, 1M pxe, 1M dt overlay and the ramdisk at the end. + */ +#define BOOTM_SIZE __stringify(0x2e00000) +#define KERNEL_ADDR_R __stringify(SDRAM_OFFSET(1000000)) +#define FDT_ADDR_R __stringify(SDRAM_OFFSET(1800000)) +#define SCRIPT_ADDR_R __stringify(SDRAM_OFFSET(1900000)) +#define PXEFILE_ADDR_R __stringify(SDRAM_OFFSET(1A00000)) +#define FDTOVERLAY_ADDR_R __stringify(SDRAM_OFFSET(1B00000)) +#define RAMDISK_ADDR_R __stringify(SDRAM_OFFSET(1C00000)) + +#elif defined(CONFIG_MACH_SUNIV) +/* + * 32M RAM minus 1MB heap + 8MB for u-boot, stack, fb, etc. + * 8M uncompressed kernel, 4M compressed kernel, 512K fdt, + * 512K script, 512K pxe and the ramdisk at the end. + */ +#define BOOTM_SIZE __stringify(0x1700000) +#define KERNEL_ADDR_R __stringify(SDRAM_OFFSET(0500000)) +#define FDT_ADDR_R __stringify(SDRAM_OFFSET(0C00000)) +#define SCRIPT_ADDR_R __stringify(SDRAM_OFFSET(0C50000)) +#define PXEFILE_ADDR_R __stringify(SDRAM_OFFSET(0D00000)) +#define FDTOVERLAY_ADDR_R __stringify(SDRAM_OFFSET(0D50000)) +#define RAMDISK_ADDR_R __stringify(SDRAM_OFFSET(0D60000)) + #else /* * 160M RAM (256M minimum minus 64MB heap + 32MB for u-boot, stack, fb, etc. * 32M uncompressed kernel, 16M compressed kernel, 1M fdt, * 1M script, 1M pxe, 1M dt overlay and the ramdisk at the end. */ -#ifndef CONFIG_MACH_SUN8I_V3S #define BOOTM_SIZE __stringify(0xa000000) #define KERNEL_ADDR_R __stringify(SDRAM_OFFSET(2000000)) #define FDT_ADDR_R __stringify(SDRAM_OFFSET(3000000)) @@ -193,20 +234,6 @@ #define PXEFILE_ADDR_R __stringify(SDRAM_OFFSET(3200000)) #define FDTOVERLAY_ADDR_R __stringify(SDRAM_OFFSET(3300000)) #define RAMDISK_ADDR_R __stringify(SDRAM_OFFSET(3400000)) -#else -/* - * 64M RAM minus 2MB heap + 16MB for u-boot, stack, fb, etc. - * 16M uncompressed kernel, 8M compressed kernel, 1M fdt, - * 1M script, 1M pxe, 1M dt overlay and the ramdisk at the end. - */ -#define BOOTM_SIZE __stringify(0x2e00000) -#define KERNEL_ADDR_R __stringify(SDRAM_OFFSET(1000000)) -#define FDT_ADDR_R __stringify(SDRAM_OFFSET(1800000)) -#define SCRIPT_ADDR_R __stringify(SDRAM_OFFSET(1900000)) -#define PXEFILE_ADDR_R __stringify(SDRAM_OFFSET(1A00000)) -#define FDTOVERLAY_ADDR_R __stringify(SDRAM_OFFSET(1B00000)) -#define RAMDISK_ADDR_R __stringify(SDRAM_OFFSET(1C00000)) -#endif #endif
#define MEM_LAYOUT_ENV_SETTINGS \
Add support for the suniv architecture, which is newer ARM9 SoCs by Allwinner. The design of it seems to be a mixture of sun3i, sun4i and sun6i.
Signed-off-by: Icenowy Zheng icenowy@aosc.io Signed-off-by: Jesse Taube Mr.Bossman075@gmail.com --- V1->V2: * Remove change in s_init (sunxi: remove lowlevel_init) V2->V3: * Covert to if(IS_ENABLED) from ifdef * Remove busy loop * Remove depends on for SPL_SPI_SUNXI --- arch/arm/mach-sunxi/Kconfig | 14 ++++- arch/arm/mach-sunxi/board.c | 28 +++++++++- arch/arm/mach-sunxi/clock.c | 3 +- arch/arm/mach-sunxi/clock_sun6i.c | 89 +++++++++++++++++++++---------- arch/arm/mach-sunxi/cpu_info.c | 2 + 5 files changed, 104 insertions(+), 32 deletions(-)
diff --git a/arch/arm/mach-sunxi/Kconfig b/arch/arm/mach-sunxi/Kconfig index 4e49ad4f0c..11f295033f 100644 --- a/arch/arm/mach-sunxi/Kconfig +++ b/arch/arm/mach-sunxi/Kconfig @@ -1,7 +1,8 @@ if ARCH_SUNXI
config SPL_LDSCRIPT - default "arch/arm/cpu/armv7/sunxi/u-boot-spl.lds" if !ARM64 + default "arch/arm/cpu/arm926ejs/sunxi/u-boot-spl.lds" if MACH_SUNIV + default "arch/arm/cpu/armv7/sunxi/u-boot-spl.lds" if !ARM64 && !MACH_SUNIV
config IDENT_STRING default " Allwinner Technology" @@ -183,6 +184,12 @@ choice prompt "Sunxi SoC Variant" optional
+config MACH_SUNIV + bool "suniv (Allwinner F1C100s/F1C200s/F1C600/R6)" + select CPU_ARM926EJS + select SUNXI_GEN_SUN6I + select SUPPORT_SPL + config MACH_SUN4I bool "sun4i (Allwinner A10)" select CPU_V7A @@ -585,6 +592,7 @@ config DRAM_ODT_CORRECTION endif
config SYS_CLK_FREQ + default 408000000 if MACH_SUNIV default 1008000000 if MACH_SUN4I default 1008000000 if MACH_SUN5I default 1008000000 if MACH_SUN6I @@ -596,6 +604,7 @@ config SYS_CLK_FREQ default 1008000000 if MACH_SUN50I_H616
config SYS_CONFIG_NAME + default "suniv" if MACH_SUNIV default "sun4i" if MACH_SUN4I default "sun5i" if MACH_SUN5I default "sun6i" if MACH_SUN6I @@ -803,7 +812,7 @@ config VIDEO_SUNXI
config VIDEO_HDMI bool "HDMI output support" - depends on VIDEO_SUNXI && !MACH_SUN8I + depends on VIDEO_SUNXI && !MACH_SUN8I && !MACH_SUNIV default y ---help--- Say Y here to add support for outputting video over HDMI. @@ -1003,6 +1012,7 @@ config GMAC_TX_DELAY Set the GMAC Transmit Clock Delay Chain value.
config SPL_STACK_R_ADDR + default 0x81e00000 if MACH_SUNIV default 0x4fe00000 if MACH_SUN4I default 0x4fe00000 if MACH_SUN5I default 0x4fe00000 if MACH_SUN6I diff --git a/arch/arm/mach-sunxi/board.c b/arch/arm/mach-sunxi/board.c index a60dc6b299..2aa30c62c5 100644 --- a/arch/arm/mach-sunxi/board.c +++ b/arch/arm/mach-sunxi/board.c @@ -87,7 +87,8 @@ static int gpio_init(void) sunxi_gpio_set_cfgpin(SUNXI_GPB(22), SUNXI_GPIO_INPUT); sunxi_gpio_set_cfgpin(SUNXI_GPB(23), SUNXI_GPIO_INPUT); #endif -#if defined(CONFIG_MACH_SUN8I) && !defined(CONFIG_MACH_SUN8I_R40) +#if (defined(CONFIG_MACH_SUN8I) && !defined(CONFIG_MACH_SUN8I_R40)) || \ + defined(CONFIG_MACH_SUNIV) sunxi_gpio_set_cfgpin(SUNXI_GPF(2), SUN8I_GPF_UART0); sunxi_gpio_set_cfgpin(SUNXI_GPF(4), SUN8I_GPF_UART0); #else @@ -95,6 +96,10 @@ static int gpio_init(void) sunxi_gpio_set_cfgpin(SUNXI_GPF(4), SUNXI_GPF_UART0); #endif sunxi_gpio_set_pull(SUNXI_GPF(4), 1); +#elif CONFIG_CONS_INDEX == 1 && defined(CONFIG_MACH_SUNIV) + sunxi_gpio_set_cfgpin(SUNXI_GPE(0), SUNIV_GPE_UART0); + sunxi_gpio_set_cfgpin(SUNXI_GPE(1), SUNIV_GPE_UART0); + sunxi_gpio_set_pull(SUNXI_GPE(1), SUNXI_GPIO_PULL_UP); #elif CONFIG_CONS_INDEX == 1 && (defined(CONFIG_MACH_SUN4I) || \ defined(CONFIG_MACH_SUN7I) || \ defined(CONFIG_MACH_SUN8I_R40)) @@ -271,10 +276,31 @@ unsigned long spl_mmc_get_uboot_raw_sector(struct mmc *mmc, return sector; }
+#ifndef CONFIG_MACH_SUNIV u32 spl_boot_device(void) { return sunxi_get_boot_device(); } +#else +/* + * suniv BROM do not pass the boot media type to SPL, so we try with the + * boot sequence in BROM: mmc0->spinor->fail. + */ +void board_boot_order(u32 *spl_boot_list) +{ + /* + * See the comments above in sunxi_get_boot_device() for information + * about FEL boot. + */ + if (!is_boot0_magic(SPL_ADDR + 4)) { + spl_boot_list[0] = BOOT_DEVICE_BOARD; + return; + } + + spl_boot_list[0] = BOOT_DEVICE_MMC1; + spl_boot_list[1] = BOOT_DEVICE_SPI; +} +#endif
__weak void sunxi_sram_init(void) { diff --git a/arch/arm/mach-sunxi/clock.c b/arch/arm/mach-sunxi/clock.c index de7e875298..da3a0eb058 100644 --- a/arch/arm/mach-sunxi/clock.c +++ b/arch/arm/mach-sunxi/clock.c @@ -35,7 +35,8 @@ int clock_init(void) }
/* These functions are shared between various SoCs so put them here. */ -#if defined CONFIG_SUNXI_GEN_SUN6I && !defined CONFIG_MACH_SUN9I +#if defined CONFIG_SUNXI_GEN_SUN6I && !defined CONFIG_MACH_SUN9I && \ + !defined CONFIG_MACH_SUNIV int clock_twi_onoff(int port, int state) { struct sunxi_ccm_reg *const ccm = diff --git a/arch/arm/mach-sunxi/clock_sun6i.c b/arch/arm/mach-sunxi/clock_sun6i.c index 8e84062bd7..56681fb2b6 100644 --- a/arch/arm/mach-sunxi/clock_sun6i.c +++ b/arch/arm/mach-sunxi/clock_sun6i.c @@ -23,7 +23,8 @@ void clock_init_safe(void) struct sunxi_ccm_reg * const ccm = (struct sunxi_ccm_reg *)SUNXI_CCM_BASE;
-#if !defined(CONFIG_MACH_SUNXI_H3_H5) && !defined(CONFIG_MACH_SUN50I) +#if !defined(CONFIG_MACH_SUNXI_H3_H5) && !defined(CONFIG_MACH_SUN50I) && \ + !defined(CONFIG_MACH_SUNIV) struct sunxi_prcm_reg * const prcm = (struct sunxi_prcm_reg *)SUNXI_PRCM_BASE;
@@ -49,9 +50,11 @@ void clock_init_safe(void)
writel(AHB1_ABP1_DIV_DEFAULT, &ccm->ahb1_apb1_div);
- writel(MBUS_CLK_DEFAULT, &ccm->mbus0_clk_cfg); - if (IS_ENABLED(CONFIG_MACH_SUN6I)) - writel(MBUS_CLK_DEFAULT, &ccm->mbus1_clk_cfg); + if (!IS_ENABLED(CONFIG_MACH_SUNIV)) { + writel(MBUS_CLK_DEFAULT, &ccm->mbus0_clk_cfg); + if (IS_ENABLED(CONFIG_MACH_SUN6I)) + writel(MBUS_CLK_DEFAULT, &ccm->mbus1_clk_cfg); + }
#if defined(CONFIG_MACH_SUN8I_R40) && defined(CONFIG_SUNXI_AHCI) setbits_le32(&ccm->sata_pll_cfg, CCM_SATA_PLL_DEFAULT); @@ -87,21 +90,38 @@ void clock_init_uart(void) struct sunxi_ccm_reg *const ccm = (struct sunxi_ccm_reg *)SUNXI_CCM_BASE;
- /* uart clock source is apb2 */ - writel(APB2_CLK_SRC_OSC24M| - APB2_CLK_RATE_N_1| - APB2_CLK_RATE_M(1), - &ccm->apb2_div); - - /* open the clock for uart */ - setbits_le32(&ccm->apb2_gate, - CLK_GATE_OPEN << (APB2_GATE_UART_SHIFT + - CONFIG_CONS_INDEX - 1)); - - /* deassert uart reset */ - setbits_le32(&ccm->apb2_reset_cfg, - 1 << (APB2_RESET_UART_SHIFT + - CONFIG_CONS_INDEX - 1)); + if (IS_ENABLED(CONFIG_MACH_SUNIV)) { + /* suniv doesn't have apb2, so uart clock source is apb1 */ + writel(PLL6_CFG_DEFAULT, &ccm->pll6_cfg); + while (!(readl(&ccm->pll6_cfg) & CCM_PLL6_CTRL_LOCK)) + ; + + /* open the clock for uart */ + setbits_le32(&ccm->apb1_gate, + CLK_GATE_OPEN << (APB1_GATE_UART_SHIFT + + CONFIG_CONS_INDEX - 1)); + + /* deassert uart reset */ + setbits_le32(&ccm->apb1_reset_cfg, + 1 << (APB1_RESET_UART_SHIFT + + CONFIG_CONS_INDEX - 1)); + } else { + /* uart clock source is apb2 */ + writel(APB2_CLK_SRC_OSC24M| + APB2_CLK_RATE_N_1| + APB2_CLK_RATE_M(1), + &ccm->apb2_div); + + /* open the clock for uart */ + setbits_le32(&ccm->apb2_gate, + CLK_GATE_OPEN << (APB2_GATE_UART_SHIFT + + CONFIG_CONS_INDEX - 1)); + + /* deassert uart reset */ + setbits_le32(&ccm->apb2_reset_cfg, + 1 << (APB2_RESET_UART_SHIFT + + CONFIG_CONS_INDEX - 1)); + } #else /* enable R_PIO and R_UART clocks, and de-assert resets */ prcm_apb0_enable(PRCM_APB0_GATE_PIO | PRCM_APB0_GATE_UART); @@ -125,10 +145,15 @@ void clock_set_pll1(unsigned int clk) }
/* Switch to 24MHz clock while changing PLL1 */ - writel(AXI_DIV_3 << AXI_DIV_SHIFT | - ATB_DIV_2 << ATB_DIV_SHIFT | - CPU_CLK_SRC_OSC24M << CPU_CLK_SRC_SHIFT, - &ccm->cpu_axi_cfg); + if (IS_ENABLED(CONFIG_MACH_SUNIV)) { + writel(CPU_CLK_SRC_OSC24M << CPU_CLK_SRC_SHIFT, + &ccm->cpu_axi_cfg); + } else { + writel(AXI_DIV_3 << AXI_DIV_SHIFT | + ATB_DIV_2 << ATB_DIV_SHIFT | + CPU_CLK_SRC_OSC24M << CPU_CLK_SRC_SHIFT, + &ccm->cpu_axi_cfg); + }
/* * sun6i: PLL1 rate = ((24000000 * n * k) >> 0) / m (p is ignored) @@ -140,10 +165,15 @@ void clock_set_pll1(unsigned int clk) sdelay(200);
/* Switch CPU to PLL1 */ - writel(AXI_DIV_3 << AXI_DIV_SHIFT | - ATB_DIV_2 << ATB_DIV_SHIFT | - CPU_CLK_SRC_PLL1 << CPU_CLK_SRC_SHIFT, - &ccm->cpu_axi_cfg); + if (IS_ENABLED(CONFIG_MACH_SUNIV)) { + writel(CPU_CLK_SRC_PLL1 << CPU_CLK_SRC_SHIFT, + &ccm->cpu_axi_cfg); + } else { + writel(AXI_DIV_3 << AXI_DIV_SHIFT | + ATB_DIV_2 << ATB_DIV_SHIFT | + CPU_CLK_SRC_PLL1 << CPU_CLK_SRC_SHIFT, + &ccm->cpu_axi_cfg); + } } #endif
@@ -317,7 +347,10 @@ unsigned int clock_get_pll6(void) uint32_t rval = readl(&ccm->pll6_cfg); int n = ((rval & CCM_PLL6_CTRL_N_MASK) >> CCM_PLL6_CTRL_N_SHIFT) + 1; int k = ((rval & CCM_PLL6_CTRL_K_MASK) >> CCM_PLL6_CTRL_K_SHIFT) + 1; - return 24000000 * n * k / 2; + if (IS_ENABLED(CONFIG_MACH_SUNIV)) + return 24000000 * n * k; + else + return 24000000 * n * k / 2; }
unsigned int clock_get_mipi_pll(void) diff --git a/arch/arm/mach-sunxi/cpu_info.c b/arch/arm/mach-sunxi/cpu_info.c index ba33ef2430..7eef178859 100644 --- a/arch/arm/mach-sunxi/cpu_info.c +++ b/arch/arm/mach-sunxi/cpu_info.c @@ -57,6 +57,8 @@ int print_cpuinfo(void) { #ifdef CONFIG_MACH_SUN4I puts("CPU: Allwinner A10 (SUN4I)\n"); +#elif defined CONFIG_MACH_SUNIV + puts("CPU: Allwinner F Series (SUNIV)\n"); #elif defined CONFIG_MACH_SUN5I u32 val = readl(SUNXI_SID_BASE + 0x08); switch ((val >> 12) & 0xf) {
On Sat, 29 Jan 2022 10:23:07 -0500 Jesse Taube mr.bossman075@gmail.com wrote:
Hey, many thanks for getting rid of those #ifdef's! There is one small thing below, but I will fix this up when committing.
V1->V2:
- Remove change in s_init (sunxi: remove lowlevel_init)
V2->V3:
- Covert to if(IS_ENABLED) from ifdef
- Remove busy loop
- Remove depends on for SPL_SPI_SUNXI
config SPL_LDSCRIPT
- default "arch/arm/cpu/arm926ejs/sunxi/u-boot-spl.lds" if MACH_SUNIV
- default "arch/arm/cpu/armv7/sunxi/u-boot-spl.lds" if !ARM64 && !MACH_SUNIV
+config MACH_SUNIV
- bool "suniv (Allwinner F1C100s/F1C200s/F1C600/R6)"
- select CPU_ARM926EJS
- select SUNXI_GEN_SUN6I
- select SUPPORT_SPL
config SYS_CLK_FREQ
- default 408000000 if MACH_SUNIV default 1008000000 if MACH_SUN4I default 1008000000 if MACH_SUN5I default 1008000000 if MACH_SUN6I
- default "suniv" if MACH_SUNIV default "sun4i" if MACH_SUN4I default "sun5i" if MACH_SUN5I default "sun6i" if MACH_SUN6I
- depends on VIDEO_SUNXI && !MACH_SUN8I && !MACH_SUNIV default y ---help--- Say Y here to add support for outputting video over HDMI.
- default 0x81e00000 if MACH_SUNIV default 0x4fe00000 if MACH_SUN4I default 0x4fe00000 if MACH_SUN5I default 0x4fe00000 if MACH_SUN6I
- defined(CONFIG_MACH_SUNIV) sunxi_gpio_set_cfgpin(SUNXI_GPF(2), SUN8I_GPF_UART0); sunxi_gpio_set_cfgpin(SUNXI_GPF(4), SUN8I_GPF_UART0);
- sunxi_gpio_set_cfgpin(SUNXI_GPE(0), SUNIV_GPE_UART0);
- sunxi_gpio_set_cfgpin(SUNXI_GPE(1), SUNIV_GPE_UART0);
- sunxi_gpio_set_pull(SUNXI_GPE(1), SUNXI_GPIO_PULL_UP);
- suniv BROM do not pass the boot media type to SPL, so we try with the
- boot sequence in BROM: mmc0->spinor->fail.
* about FEL boot.
- if (!is_boot0_magic(SPL_ADDR + 4)) {
return;
- spl_boot_list[0] = BOOT_DEVICE_MMC1;
- spl_boot_list[1] = BOOT_DEVICE_SPI;
+} +#endif
- !defined CONFIG_MACH_SUNIV
- !defined(CONFIG_MACH_SUNIV) struct sunxi_prcm_reg * const prcm = (struct sunxi_prcm_reg *)SUNXI_PRCM_BASE;
- if (!IS_ENABLED(CONFIG_MACH_SUNIV)) {
APB2_CLK_RATE_N_1|
APB2_CLK_RATE_M(1),
&ccm->apb2_div);
- if (IS_ENABLED(CONFIG_MACH_SUNIV)) {
Sorry, I meant to remove that part, too, not just the AHB1_ABP1_DIV_DEFAULT part. I will fix this up locally.
Cheers, Andre
- } else {
APB2_CLK_RATE_N_1|
APB2_CLK_RATE_M(1),
&ccm->apb2_div);
&ccm->cpu_axi_cfg);
&ccm->cpu_axi_cfg);
} else {
&ccm->cpu_axi_cfg);
- sun6i: PLL1 rate = ((24000000 * n * k) >> 0) / m (p is ignored)
&ccm->cpu_axi_cfg);
&ccm->cpu_axi_cfg);
- } else {
&ccm->cpu_axi_cfg);
} #endif
- else
- puts("CPU: Allwinner F Series (SUNIV)\n");
Add device tree files for suniv and Lichee Pi Nano it is a board based on F1C100s. dt-bindings/dts are synced with 5.16.0
Signed-off-by: Icenowy Zheng icenowy@aosc.io Signed-off-by: Jesse Taube Mr.Bossman075@gmail.com --- V1->V2: * Sync with Linux * Re-add MMC node V2->V3: * Add ifndef for mmc in sunxi-u-boot.dtsi * Direct copy of all files from linux * Squash dt-bindings here --- arch/arm/dts/Makefile | 2 + arch/arm/dts/suniv-f1c100s-licheepi-nano.dts | 26 ++++ arch/arm/dts/suniv-f1c100s.dtsi | 144 ++++++++++++++++++ arch/arm/dts/sunxi-u-boot.dtsi | 2 + include/dt-bindings/clock/suniv-ccu-f1c100s.h | 70 +++++++++ include/dt-bindings/reset/suniv-ccu-f1c100s.h | 38 +++++ 6 files changed, 282 insertions(+) create mode 100644 arch/arm/dts/suniv-f1c100s-licheepi-nano.dts create mode 100644 arch/arm/dts/suniv-f1c100s.dtsi create mode 100644 include/dt-bindings/clock/suniv-ccu-f1c100s.h create mode 100644 include/dt-bindings/reset/suniv-ccu-f1c100s.h
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index 453e2fd1a9..07030deeca 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -497,6 +497,8 @@ dtb-$(CONFIG_STM32H7) += stm32h743i-disco.dtb \ stm32h743i-eval.dtb \ stm32h750i-art-pi.dtb
+dtb-$(CONFIG_MACH_SUNIV) += \ + suniv-f1c100s-licheepi-nano.dtb dtb-$(CONFIG_MACH_SUN4I) += \ sun4i-a10-a1000.dtb \ sun4i-a10-ba10-tvbox.dtb \ diff --git a/arch/arm/dts/suniv-f1c100s-licheepi-nano.dts b/arch/arm/dts/suniv-f1c100s-licheepi-nano.dts new file mode 100644 index 0000000000..a1154e6c7c --- /dev/null +++ b/arch/arm/dts/suniv-f1c100s-licheepi-nano.dts @@ -0,0 +1,26 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR X11) +/* + * Copyright 2018 Icenowy Zheng icenowy@aosc.io + */ + +/dts-v1/; +#include "suniv-f1c100s.dtsi" + +/ { + model = "Lichee Pi Nano"; + compatible = "licheepi,licheepi-nano", "allwinner,suniv-f1c100s"; + + aliases { + serial0 = &uart0; + }; + + chosen { + stdout-path = "serial0:115200n8"; + }; +}; + +&uart0 { + pinctrl-names = "default"; + pinctrl-0 = <&uart0_pe_pins>; + status = "okay"; +}; diff --git a/arch/arm/dts/suniv-f1c100s.dtsi b/arch/arm/dts/suniv-f1c100s.dtsi new file mode 100644 index 0000000000..6100d3b75f --- /dev/null +++ b/arch/arm/dts/suniv-f1c100s.dtsi @@ -0,0 +1,144 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR X11) +/* + * Copyright 2018 Icenowy Zheng icenowy@aosc.io + * Copyright 2018 Mesih Kilinc mesihkilinc@gmail.com + */ + +/ { + #address-cells = <1>; + #size-cells = <1>; + interrupt-parent = <&intc>; + + clocks { + osc24M: clk-24M { + #clock-cells = <0>; + compatible = "fixed-clock"; + clock-frequency = <24000000>; + clock-output-names = "osc24M"; + }; + + osc32k: clk-32k { + #clock-cells = <0>; + compatible = "fixed-clock"; + clock-frequency = <32768>; + clock-output-names = "osc32k"; + }; + }; + + cpus { + cpu { + compatible = "arm,arm926ej-s"; + device_type = "cpu"; + }; + }; + + soc { + compatible = "simple-bus"; + #address-cells = <1>; + #size-cells = <1>; + ranges; + + sram-controller@1c00000 { + compatible = "allwinner,suniv-f1c100s-system-control", + "allwinner,sun4i-a10-system-control"; + reg = <0x01c00000 0x30>; + #address-cells = <1>; + #size-cells = <1>; + ranges; + + sram_d: sram@10000 { + compatible = "mmio-sram"; + reg = <0x00010000 0x1000>; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0 0x00010000 0x1000>; + + otg_sram: sram-section@0 { + compatible = "allwinner,suniv-f1c100s-sram-d", + "allwinner,sun4i-a10-sram-d"; + reg = <0x0000 0x1000>; + status = "disabled"; + }; + }; + }; + + ccu: clock@1c20000 { + compatible = "allwinner,suniv-f1c100s-ccu"; + reg = <0x01c20000 0x400>; + clocks = <&osc24M>, <&osc32k>; + clock-names = "hosc", "losc"; + #clock-cells = <1>; + #reset-cells = <1>; + }; + + intc: interrupt-controller@1c20400 { + compatible = "allwinner,suniv-f1c100s-ic"; + reg = <0x01c20400 0x400>; + interrupt-controller; + #interrupt-cells = <1>; + }; + + pio: pinctrl@1c20800 { + compatible = "allwinner,suniv-f1c100s-pinctrl"; + reg = <0x01c20800 0x400>; + interrupts = <38>, <39>, <40>; + clocks = <&ccu 37>, <&osc24M>, <&osc32k>; + clock-names = "apb", "hosc", "losc"; + gpio-controller; + interrupt-controller; + #interrupt-cells = <3>; + #gpio-cells = <3>; + + uart0_pe_pins: uart0-pe-pins { + pins = "PE0", "PE1"; + function = "uart0"; + }; + }; + + timer@1c20c00 { + compatible = "allwinner,suniv-f1c100s-timer"; + reg = <0x01c20c00 0x90>; + interrupts = <13>; + clocks = <&osc24M>; + }; + + wdt: watchdog@1c20ca0 { + compatible = "allwinner,suniv-f1c100s-wdt", + "allwinner,sun4i-a10-wdt"; + reg = <0x01c20ca0 0x20>; + }; + + uart0: serial@1c25000 { + compatible = "snps,dw-apb-uart"; + reg = <0x01c25000 0x400>; + interrupts = <1>; + reg-shift = <2>; + reg-io-width = <4>; + clocks = <&ccu 38>; + resets = <&ccu 24>; + status = "disabled"; + }; + + uart1: serial@1c25400 { + compatible = "snps,dw-apb-uart"; + reg = <0x01c25400 0x400>; + interrupts = <2>; + reg-shift = <2>; + reg-io-width = <4>; + clocks = <&ccu 39>; + resets = <&ccu 25>; + status = "disabled"; + }; + + uart2: serial@1c25800 { + compatible = "snps,dw-apb-uart"; + reg = <0x01c25800 0x400>; + interrupts = <3>; + reg-shift = <2>; + reg-io-width = <4>; + clocks = <&ccu 40>; + resets = <&ccu 26>; + status = "disabled"; + }; + }; +}; diff --git a/arch/arm/dts/sunxi-u-boot.dtsi b/arch/arm/dts/sunxi-u-boot.dtsi index f2d7361b84..0f573e6d7a 100644 --- a/arch/arm/dts/sunxi-u-boot.dtsi +++ b/arch/arm/dts/sunxi-u-boot.dtsi @@ -12,7 +12,9 @@
/ { aliases { +#ifndef CONFIG_MACH_SUNIV mmc0 = &mmc0; +#endif #if CONFIG_MMC_SUNXI_SLOT_EXTRA == 2 mmc1 = &mmc2; #endif diff --git a/include/dt-bindings/clock/suniv-ccu-f1c100s.h b/include/dt-bindings/clock/suniv-ccu-f1c100s.h new file mode 100644 index 0000000000..f5ac155c9c --- /dev/null +++ b/include/dt-bindings/clock/suniv-ccu-f1c100s.h @@ -0,0 +1,70 @@ +/* SPDX-License-Identifier: (GPL-2.0+ OR MIT) + * + * Copyright (c) 2018 Icenowy Zheng icenowy@aosc.xyz + * + */ + +#ifndef _DT_BINDINGS_CLK_SUNIV_F1C100S_H_ +#define _DT_BINDINGS_CLK_SUNIV_F1C100S_H_ + +#define CLK_CPU 11 + +#define CLK_BUS_DMA 14 +#define CLK_BUS_MMC0 15 +#define CLK_BUS_MMC1 16 +#define CLK_BUS_DRAM 17 +#define CLK_BUS_SPI0 18 +#define CLK_BUS_SPI1 19 +#define CLK_BUS_OTG 20 +#define CLK_BUS_VE 21 +#define CLK_BUS_LCD 22 +#define CLK_BUS_DEINTERLACE 23 +#define CLK_BUS_CSI 24 +#define CLK_BUS_TVD 25 +#define CLK_BUS_TVE 26 +#define CLK_BUS_DE_BE 27 +#define CLK_BUS_DE_FE 28 +#define CLK_BUS_CODEC 29 +#define CLK_BUS_SPDIF 30 +#define CLK_BUS_IR 31 +#define CLK_BUS_RSB 32 +#define CLK_BUS_I2S0 33 +#define CLK_BUS_I2C0 34 +#define CLK_BUS_I2C1 35 +#define CLK_BUS_I2C2 36 +#define CLK_BUS_PIO 37 +#define CLK_BUS_UART0 38 +#define CLK_BUS_UART1 39 +#define CLK_BUS_UART2 40 + +#define CLK_MMC0 41 +#define CLK_MMC0_SAMPLE 42 +#define CLK_MMC0_OUTPUT 43 +#define CLK_MMC1 44 +#define CLK_MMC1_SAMPLE 45 +#define CLK_MMC1_OUTPUT 46 +#define CLK_I2S 47 +#define CLK_SPDIF 48 + +#define CLK_USB_PHY0 49 + +#define CLK_DRAM_VE 50 +#define CLK_DRAM_CSI 51 +#define CLK_DRAM_DEINTERLACE 52 +#define CLK_DRAM_TVD 53 +#define CLK_DRAM_DE_FE 54 +#define CLK_DRAM_DE_BE 55 + +#define CLK_DE_BE 56 +#define CLK_DE_FE 57 +#define CLK_TCON 58 +#define CLK_DEINTERLACE 59 +#define CLK_TVE2_CLK 60 +#define CLK_TVE1_CLK 61 +#define CLK_TVD 62 +#define CLK_CSI 63 +#define CLK_VE 64 +#define CLK_CODEC 65 +#define CLK_AVS 66 + +#endif diff --git a/include/dt-bindings/reset/suniv-ccu-f1c100s.h b/include/dt-bindings/reset/suniv-ccu-f1c100s.h new file mode 100644 index 0000000000..6a4b4385fe --- /dev/null +++ b/include/dt-bindings/reset/suniv-ccu-f1c100s.h @@ -0,0 +1,38 @@ +/* SPDX-License-Identifier: (GPL-2.0+ OR MIT) + * + * Copyright (C) 2018 Icenowy Zheng icenowy@aosc.xyz + * + */ + +#ifndef _DT_BINDINGS_RST_SUNIV_F1C100S_H_ +#define _DT_BINDINGS_RST_SUNIV_F1C100S_H_ + +#define RST_USB_PHY0 0 +#define RST_BUS_DMA 1 +#define RST_BUS_MMC0 2 +#define RST_BUS_MMC1 3 +#define RST_BUS_DRAM 4 +#define RST_BUS_SPI0 5 +#define RST_BUS_SPI1 6 +#define RST_BUS_OTG 7 +#define RST_BUS_VE 8 +#define RST_BUS_LCD 9 +#define RST_BUS_DEINTERLACE 10 +#define RST_BUS_CSI 11 +#define RST_BUS_TVD 12 +#define RST_BUS_TVE 13 +#define RST_BUS_DE_BE 14 +#define RST_BUS_DE_FE 15 +#define RST_BUS_CODEC 16 +#define RST_BUS_SPDIF 17 +#define RST_BUS_IR 18 +#define RST_BUS_RSB 19 +#define RST_BUS_I2S0 20 +#define RST_BUS_I2C0 21 +#define RST_BUS_I2C1 22 +#define RST_BUS_I2C2 23 +#define RST_BUS_UART0 24 +#define RST_BUS_UART1 25 +#define RST_BUS_UART2 26 + +#endif /* _DT_BINDINGS_RST_SUNIV_F1C100S_H_ */
On Sat, 29 Jan 2022 10:23:08 -0500 Jesse Taube mr.bossman075@gmail.com wrote:
Many thanks, that looks correct now. Confirmed that the files match exactly the Linux tree.
Cheers, Andre
V1->V2:
- Sync with Linux
- Re-add MMC node
V2->V3:
- Add ifndef for mmc in sunxi-u-boot.dtsi
- Direct copy of all files from linux
- Squash dt-bindings here
- suniv-f1c100s-licheepi-nano.dtb
- Copyright 2018 Icenowy Zheng icenowy@aosc.io
- model = "Lichee Pi Nano";
- compatible = "licheepi,licheepi-nano", "allwinner,suniv-f1c100s";
- aliases {
serial0 = &uart0;
- chosen {
+&uart0 {
- pinctrl-names = "default";
- pinctrl-0 = <&uart0_pe_pins>;
- status = "okay";
- Copyright 2018 Mesih Kilinc mesihkilinc@gmail.com
- #address-cells = <1>;
- #size-cells = <1>;
- interrupt-parent = <&intc>;
- clocks {
osc24M: clk-24M {
#clock-cells = <0>;
osc32k: clk-32k {
#clock-cells = <0>;
- cpus {
cpu {
- soc {
#size-cells = <1>;
ranges;
#size-cells = <1>;
ranges;
#size-cells = <1>;
#clock-cells = <1>;
#reset-cells = <1>;
gpio-controller;
#gpio-cells = <3>;
function = "uart0";
timer@1c20c00 {
interrupts = <13>;
clocks = <&osc24M>;
interrupts = <1>;
reg-shift = <2>;
reg-io-width = <4>;
clocks = <&ccu 38>;
resets = <&ccu 24>;
interrupts = <2>;
reg-shift = <2>;
reg-io-width = <4>;
clocks = <&ccu 39>;
resets = <&ccu 25>;
interrupts = <3>;
reg-shift = <2>;
reg-io-width = <4>;
clocks = <&ccu 40>;
resets = <&ccu 26>;
- Copyright (c) 2018 Icenowy Zheng icenowy@aosc.xyz
+#define CLK_CPU 11
- Copyright (C) 2018 Icenowy Zheng icenowy@aosc.xyz
The Lichee Pi Nano is a board based on the F1C100s. Add defconfigs for it.
Signed-off-by: Icenowy Zheng icenowy@aosc.io Signed-off-by: Jesse Taube Mr.Bossman075@gmail.com --- V1->V2: * Add SKIP_LOWLEVEL_INIT_ONLY * Remove spi defconfig V2->V3: * Move SYS_MALLOC_F_LEN to kconf and format it * Move SYS_LOAD_ADDR to kconf and format it * Move SYS_TEXT_BASE to kconf and format it
--- Kconfig | 8 +++++--- boot/Kconfig | 7 ++++--- configs/licheepi_nano_defconfig | 11 +++++++++++ 3 files changed, 20 insertions(+), 6 deletions(-) create mode 100644 configs/licheepi_nano_defconfig
diff --git a/Kconfig b/Kconfig index c46f4fce86..ef4e350ea8 100644 --- a/Kconfig +++ b/Kconfig @@ -246,9 +246,10 @@ config SYS_MALLOC_F_LEN config SYS_MALLOC_LEN hex "Define memory for Dynamic allocation" default 0x2000000 if ARCH_ROCKCHIP || ARCH_OMAP2PLUS || ARCH_MESON - default 0x4020000 if ARCH_SUNXI && !MACH_SUN8I_V3S default 0x200000 if ARCH_BMIPS || X86 - default 0x220000 if ARCH_SUNXI && MACH_SUN8I_V3S + default 0x120000 if MACH_SUNIV + default 0x220000 if MACH_SUN8I_V3S + default 0x4020000 if ARCH_SUNXI default 0x400000 help This defines memory to be allocated for Dynamic allocation @@ -391,8 +392,9 @@ config SYS_LOAD_ADDR hex "Address in memory to use by default" default 0x01000000 if ARCH_SOCFPGA default 0x02000000 if PPC || X86 + default 0x81000000 if MACH_SUNIV default 0x22000000 if MACH_SUN9I - default 0x42000000 if ARCH_SUNXI && !MACH_SUN9I + default 0x42000000 if ARCH_SUNXI default 0x82000000 if ARCH_KEYSTONE || ARCH_OMAP2PLUS || ARCH_K3 default 0x82000000 if ARCH_MX6 && (MX6SL || MX6SLL || MX6SX || MX6UL || MX6ULL) default 0x12000000 if ARCH_MX6 && !(MX6SL || MX6SLL || MX6SX || MX6UL || MX6ULL) diff --git a/boot/Kconfig b/boot/Kconfig index f1ce576ab2..d16acfe563 100644 --- a/boot/Kconfig +++ b/boot/Kconfig @@ -351,9 +351,10 @@ config SYS_TEXT_BASE depends on HAVE_SYS_TEXT_BASE default 0x0 if POSITION_INDEPENDENT default 0x80800000 if ARCH_OMAP2PLUS || ARCH_K3 - default 0x4a000000 if ARCH_SUNXI && !MACH_SUN9I && !MACH_SUN8I_V3S - default 0x2a000000 if ARCH_SUNXI && MACH_SUN9I - default 0x42e00000 if ARCH_SUNXI && MACH_SUN8I_V3S + default 0x81700000 if MACH_SUNIV + default 0x2a000000 if MACH_SUN9I + default 0x42e00000 if MACH_SUN8I_V3S + default 0x4a000000 if ARCH_SUNXI hex "Text Base" help The address in memory that U-Boot will be running from, initially. diff --git a/configs/licheepi_nano_defconfig b/configs/licheepi_nano_defconfig new file mode 100644 index 0000000000..ecec869d18 --- /dev/null +++ b/configs/licheepi_nano_defconfig @@ -0,0 +1,11 @@ +CONFIG_ARM=y +CONFIG_ARCH_SUNXI=y +CONFIG_MACH_SUNIV=y +CONFIG_SKIP_LOWLEVEL_INIT_ONLY=y +CONFIG_SPL_SKIP_LOWLEVEL_INIT_ONLY=y +CONFIG_DRAM_CLK=156 +CONFIG_SYS_DCACHE_OFF=y +CONFIG_DRAM_ZQ=0 +# CONFIG_VIDEO_SUNXI is not set +CONFIG_DEFAULT_DEVICE_TREE="suniv-f1c100s-licheepi-nano" +CONFIG_SPL=y
On Sat, 29 Jan 2022 10:23:09 -0500 Jesse Taube mr.bossman075@gmail.com wrote:
Looks very nice now, many thanks!
Cheers, Andre
V1->V2:
- Add SKIP_LOWLEVEL_INIT_ONLY
- Remove spi defconfig
V2->V3:
- Move SYS_MALLOC_F_LEN to kconf and format it
- Move SYS_LOAD_ADDR to kconf and format it
- Move SYS_TEXT_BASE to kconf and format it
- default 0x120000 if MACH_SUNIV
- default 0x220000 if MACH_SUN8I_V3S
- default 0x4020000 if ARCH_SUNXI default 0x400000 help This defines memory to be allocated for Dynamic allocation
- default 0x81000000 if MACH_SUNIV default 0x22000000 if MACH_SUN9I
- default 0x42000000 if ARCH_SUNXI default 0x82000000 if ARCH_KEYSTONE || ARCH_OMAP2PLUS || ARCH_K3 default 0x82000000 if ARCH_MX6 && (MX6SL || MX6SLL || MX6SX || MX6UL || MX6ULL) default 0x12000000 if ARCH_MX6 && !(MX6SL || MX6SLL || MX6SX || MX6UL || MX6ULL)
- default 0x81700000 if MACH_SUNIV
- default 0x2a000000 if MACH_SUN9I
- default 0x42e00000 if MACH_SUN8I_V3S
- default 0x4a000000 if ARCH_SUNXI hex "Text Base" help The address in memory that U-Boot will be running from, initially.
Andre Przywara
Jesse Taube
