[U-Boot] [U-boot] U-Boot 2009.03 booting problem
Hi All,
I am try to use the u-boot version 2009 for MPC8313ERB broad, when i load the u-boot.bin to board using JTAG and restart the board at that time its not booting properly . its generated following error what may be the problem.
U-Boot 2009.03 (Apr 22 2009 - 04:59:44) MPC83XX
Reset Status: Software Hard, External/Internal Soft, External/Internal Hard
CPU: e300c3, MPC8313E, Rev: 1.0 at 333.333 MHz, CSB: 166.667 MHz Board: Freescale MPC8313ERDB I2C: ready DRAM: 128 MB FLASH: 16 MB NAND: 256 MiB *** Warning - bad CRC, using default environment
In: serial Out: serial Err: serial Machine check in kernel mode. Caused by (from msr): regs 07f36df0 Unknown values in msr NIP: 07FE9474 XER: 00000000 LR: 07FE946C REGS: 07f36df0 TRAP: 0200 DAR: 00000000 MSR: 00003030 EE: 0 PR: 0 FP: 1 ME: 1 IR/DR: 11
GPR00: 0000007C 07F36EE0 07F36F4C FFFFFFFF FFFFFFFF 00000000 00000000 04AA7D46 GPR08: 07FBDE54 F001C048 00000090 07FEA3D0 07F36F4C 000080A0 07FFC000 09FB9000 GPR16: 00000080 00006101 20044000 00020052 FFFFFFFF FFFFFFFF 00000000 07FBC098 GPR24: 07FBCAD8 FFFF80A0 00000001 FE7FE000 00002000 00000000 07FFD5A4 07F36FBC Call backtrace: 07FE946C 07FE1784 07FBD968 07FBC5E8 machine check Resetting the board.
Regards Rudresh
On Thu, 9 Apr 2009 05:32:29 -0700 (PDT) rudresh rudresh.tk@lntemsys.com wrote:
Hi All,
can you turn on debugging and/or somehow find out what code is at or around the NIP address above?
Also, how, if any, is this board different from Freescale's MPC8313ERDB? earlier you state it is a custom board...
Kim
Kim Phillips
rudresh
