[PATCH v2] treewide: Enable SPL_SEPARATE_BSS if SPL_BSS_START_ADDR is used
If .bss does not immediately follow the end of the image, then CONFIG_SPL_SEPARATE_BSS must be selected. Typically, the location of bss is specified by using CONFIG_SPL_BSS_START_ADDR in a linker script. On these arches, CONFIG_SPL_SEPARATE_BSS should be enabled. If there is an option to use an alternate boot script (e.g. CONFIG_SPL_LDSCRIPT is just a default), just imply. If there is not, select.
Signed-off-by: Sean Anderson sean.anderson@seco.com ---
Changes in v2: - Add "if SPL" to selects to avoid config error
arch/Kconfig | 2 ++ arch/arm/Kconfig | 6 ++++++ 2 files changed, 8 insertions(+)
diff --git a/arch/Kconfig b/arch/Kconfig index bc31e5ad50..8a63adcfd8 100644 --- a/arch/Kconfig +++ b/arch/Kconfig @@ -85,6 +85,7 @@ config MIPS select HAVE_ARCH_IOREMAP select HAVE_PRIVATE_LIBGCC select SUPPORT_OF_CONTROL + select SPL_SEPARATE_BSS if SPL
config NDS32 bool "NDS32 architecture" @@ -112,6 +113,7 @@ config RISCV select SUPPORT_OF_CONTROL select OF_CONTROL select DM + select SPL_SEPARATE_BSS if SPL imply DM_SERIAL imply DM_ETH imply DM_EVENT diff --git a/arch/arm/Kconfig b/arch/arm/Kconfig index f277929c99..92bd189c95 100644 --- a/arch/arm/Kconfig +++ b/arch/arm/Kconfig @@ -8,6 +8,7 @@ config ARM64 bool select PHYS_64BIT select SYS_CACHE_SHIFT_6 + imply SPL_SEPARATE_BSS
config ARM64_CRC32 bool "Enable support for CRC32 instruction" @@ -267,6 +268,7 @@ config CPU_ARM926EJS bool select SYS_CACHE_SHIFT_5 imply SYS_ARM_MMU + imply SPL_SEPARATE_BSS
config CPU_ARM946ES bool @@ -277,6 +279,7 @@ config CPU_ARM1136 bool select SYS_CACHE_SHIFT_5 imply SYS_ARM_MMU + imply SPL_SEPARATE_BSS
config CPU_ARM1176 bool @@ -624,6 +627,7 @@ config ARCH_ORION5X bool "Marvell Orion" select CPU_ARM926EJS select GPIO_EXTRA_HEADER + select SPL_SEPARATE_BSS if SPL
config TARGET_STV0991 bool "Support stv0991" @@ -814,6 +818,7 @@ config ARCH_OMAP2PLUS imply TI_SYSC if DM && OF_CONTROL imply FIT imply DM_EVENT + imply SPL_SEPARATE_BSS
config ARCH_MESON bool "Amlogic Meson" @@ -954,6 +959,7 @@ config ARCH_MX6 select SYS_FSL_SEC_LE imply MXC_GPIO imply SYS_THUMB_BUILD + imply SPL_SEPARATE_BSS
if ARCH_MX6 config SPL_LDSCRIPT
Sean Anderson
