[PATCH v2] usb: ehci-mx6: Add i.MX93 support
i.MX93 uses the same USB IP as i.MX8MM. It can then reuse the ehci-mx6 driver.
Reviewed-by: Marek Vasut marex@denx.de Signed-off-by: Mathieu Othacehe othacehe@gnu.org --- drivers/usb/host/Kconfig | 6 +++--- drivers/usb/host/ehci-mx6.c | 2 +- 2 files changed, 4 insertions(+), 4 deletions(-)
diff --git a/drivers/usb/host/Kconfig b/drivers/usb/host/Kconfig index 0dd5736433c..f96027d7bd2 100644 --- a/drivers/usb/host/Kconfig +++ b/drivers/usb/host/Kconfig @@ -210,10 +210,10 @@ config USB_EHCI_MX6
config USB_EHCI_MX7 bool "Support for i.MX7 on-chip EHCI USB controller" - depends on ARCH_MX7 || IMX8M + depends on ARCH_MX7 || IMX8M || IMX93 select EHCI_HCD_INIT_AFTER_RESET if ARCH_MX7 - select PHY if IMX8M - select NOP_PHY if IMX8M + select PHY if IMX8M || IMX93 + select NOP_PHY if IMX8M || IMX93 default y ---help--- Enables support for the on-chip EHCI controller on i.MX7 SoCs. diff --git a/drivers/usb/host/ehci-mx6.c b/drivers/usb/host/ehci-mx6.c index a9ed5e7a0d5..a35fcca43a2 100644 --- a/drivers/usb/host/ehci-mx6.c +++ b/drivers/usb/host/ehci-mx6.c @@ -538,7 +538,7 @@ static int ehci_usb_phy_mode(struct udevice *dev) plat->init_type = USB_INIT_DEVICE; else plat->init_type = USB_INIT_HOST; - } else if (is_mx7() || is_imx8mm() || is_imx8mn()) { + } else if (is_mx7() || is_imx8mm() || is_imx8mn() || is_imx93()) { phy_status = (void __iomem *)(addr + USBNC_PHY_STATUS_OFFSET); val = readl(phy_status);
Reviewed-by: Fabio Estevam festevam@gmail.com
I assume you will add USB support to some i.MX93 boards later.
- depends on ARCH_MX7 || IMX8M || IMX93 select EHCI_HCD_INIT_AFTER_RESET if ARCH_MX7
- select PHY if IMX8M || IMX93
- select NOP_PHY if IMX8M || IMX93 default y ---help--- Enables support for the on-chip EHCI controller on i.MX7 SoCs.
- } else if (is_mx7() || is_imx8mm() || is_imx8mn() || is_imx93()) { phy_status = (void __iomem *)(addr + USBNC_PHY_STATUS_OFFSET); val = readl(phy_status);
Applied, thanks
Fabio Estevam
Mathieu Othacehe
