[U-Boot] [PATCH/resend] arm: rmobile: Add support PFC of Renesas SH73A0
From: Nobuhiro Iwamatsu nobuhiro.iwamatsu.yj@renesas.com
Renesas SH73A0 has GPIO based PFC. This privode framework of PFC. The code included in this base from linux kernel.
Signed-off-by: Nobuhiro Iwamatsu nobuhiro.iwamatsu.yj@renesas.com Signed-off-by: Nobuhiro Iwamatsu iwamatsu@nigauri.org --- arch/arm/cpu/armv7/rmobile/Makefile | 1 + arch/arm/cpu/armv7/rmobile/pfc-sh73a0.c | 2807 ++++++++++++++++++++++++++++++ arch/arm/include/asm/arch-rmobile/gpio.h | 9 + 3 files changed, 2817 insertions(+) create mode 100644 arch/arm/cpu/armv7/rmobile/pfc-sh73a0.c create mode 100644 arch/arm/include/asm/arch-rmobile/gpio.h
diff --git a/arch/arm/cpu/armv7/rmobile/Makefile b/arch/arm/cpu/armv7/rmobile/Makefile index 77eca4b..a522872 100644 --- a/arch/arm/cpu/armv7/rmobile/Makefile +++ b/arch/arm/cpu/armv7/rmobile/Makefile @@ -31,6 +31,7 @@ COBJS-y += timer.o
COBJS-$(CONFIG_DISPLAY_BOARDINFO) += board.o COBJS-$(CONFIG_SH73A0) += cpu_info-sh73a0.o +COBJS-$(CONFIG_SH73A0) += pfc-sh73a0.o
COBJS := $(COBJS-y) SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) diff --git a/arch/arm/cpu/armv7/rmobile/pfc-sh73a0.c b/arch/arm/cpu/armv7/rmobile/pfc-sh73a0.c new file mode 100644 index 0000000..55dab7c --- /dev/null +++ b/arch/arm/cpu/armv7/rmobile/pfc-sh73a0.c @@ -0,0 +1,2807 @@ +/* + * sh73a0 processor support - PFC hardware block + * + * Copyright (C) 2010 Renesas Solutions Corp. + * Copyright (C) 2010 NISHIMOTO Hiroki + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; version 2 of the + * License. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA 02110-1301 USA + */ + +#include <common.h> +#include <sh_pfc.h> +#include <asm/arch/sh73a0-gpio.h> + +#define CPU_ALL_PORT(fn, pfx, sfx) \ + PORT_10(fn, pfx, sfx), PORT_10(fn, pfx##1, sfx), \ + PORT_10(fn, pfx##2, sfx), PORT_10(fn, pfx##3, sfx), \ + PORT_10(fn, pfx##4, sfx), PORT_10(fn, pfx##5, sfx), \ + PORT_10(fn, pfx##6, sfx), PORT_10(fn, pfx##7, sfx), \ + PORT_10(fn, pfx##8, sfx), PORT_10(fn, pfx##9, sfx), \ + PORT_10(fn, pfx##10, sfx), \ + PORT_1(fn, pfx##110, sfx), PORT_1(fn, pfx##111, sfx), \ + PORT_1(fn, pfx##112, sfx), PORT_1(fn, pfx##113, sfx), \ + PORT_1(fn, pfx##114, sfx), PORT_1(fn, pfx##115, sfx), \ + PORT_1(fn, pfx##116, sfx), PORT_1(fn, pfx##117, sfx), \ + PORT_1(fn, pfx##118, sfx), \ + PORT_1(fn, pfx##128, sfx), PORT_1(fn, pfx##129, sfx), \ + PORT_10(fn, pfx##13, sfx), PORT_10(fn, pfx##14, sfx), \ + PORT_10(fn, pfx##15, sfx), \ + PORT_1(fn, pfx##160, sfx), PORT_1(fn, pfx##161, sfx), \ + PORT_1(fn, pfx##162, sfx), PORT_1(fn, pfx##163, sfx), \ + PORT_1(fn, pfx##164, sfx), \ + PORT_1(fn, pfx##192, sfx), PORT_1(fn, pfx##193, sfx), \ + PORT_1(fn, pfx##194, sfx), PORT_1(fn, pfx##195, sfx), \ + PORT_1(fn, pfx##196, sfx), PORT_1(fn, pfx##197, sfx), \ + PORT_1(fn, pfx##198, sfx), PORT_1(fn, pfx##199, sfx), \ + PORT_10(fn, pfx##20, sfx), PORT_10(fn, pfx##21, sfx), \ + PORT_10(fn, pfx##22, sfx), PORT_10(fn, pfx##23, sfx), \ + PORT_10(fn, pfx##24, sfx), PORT_10(fn, pfx##25, sfx), \ + PORT_10(fn, pfx##26, sfx), PORT_10(fn, pfx##27, sfx), \ + PORT_1(fn, pfx##280, sfx), PORT_1(fn, pfx##281, sfx), \ + PORT_1(fn, pfx##282, sfx), \ + PORT_1(fn, pfx##288, sfx), PORT_1(fn, pfx##289, sfx), \ + PORT_10(fn, pfx##29, sfx), PORT_10(fn, pfx##30, sfx) + +enum { + PINMUX_RESERVED = 0, + + PINMUX_DATA_BEGIN, + PORT_ALL(DATA), /* PORT0_DATA -> PORT309_DATA */ + PINMUX_DATA_END, + + PINMUX_INPUT_BEGIN, + PORT_ALL(IN), /* PORT0_IN -> PORT309_IN */ + PINMUX_INPUT_END, + + PINMUX_INPUT_PULLUP_BEGIN, + PORT_ALL(IN_PU), /* PORT0_IN_PU -> PORT309_IN_PU */ + PINMUX_INPUT_PULLUP_END, + + PINMUX_INPUT_PULLDOWN_BEGIN, + PORT_ALL(IN_PD), /* PORT0_IN_PD -> PORT309_IN_PD */ + PINMUX_INPUT_PULLDOWN_END, + + PINMUX_OUTPUT_BEGIN, + PORT_ALL(OUT), /* PORT0_OUT -> PORT309_OUT */ + PINMUX_OUTPUT_END, + + PINMUX_FUNCTION_BEGIN, + PORT_ALL(FN_IN), /* PORT0_FN_IN -> PORT309_FN_IN */ + PORT_ALL(FN_OUT), /* PORT0_FN_OUT -> PORT309_FN_OUT */ + PORT_ALL(FN0), /* PORT0_FN0 -> PORT309_FN0 */ + PORT_ALL(FN1), /* PORT0_FN1 -> PORT309_FN1 */ + PORT_ALL(FN2), /* PORT0_FN2 -> PORT309_FN2 */ + PORT_ALL(FN3), /* PORT0_FN3 -> PORT309_FN3 */ + PORT_ALL(FN4), /* PORT0_FN4 -> PORT309_FN4 */ + PORT_ALL(FN5), /* PORT0_FN5 -> PORT309_FN5 */ + PORT_ALL(FN6), /* PORT0_FN6 -> PORT309_FN6 */ + PORT_ALL(FN7), /* PORT0_FN7 -> PORT309_FN7 */ + + MSEL2CR_MSEL19_0, MSEL2CR_MSEL19_1, + MSEL2CR_MSEL18_0, MSEL2CR_MSEL18_1, + MSEL2CR_MSEL17_0, MSEL2CR_MSEL17_1, + MSEL2CR_MSEL16_0, MSEL2CR_MSEL16_1, + MSEL2CR_MSEL14_0, MSEL2CR_MSEL14_1, + MSEL2CR_MSEL13_0, MSEL2CR_MSEL13_1, + MSEL2CR_MSEL12_0, MSEL2CR_MSEL12_1, + MSEL2CR_MSEL11_0, MSEL2CR_MSEL11_1, + MSEL2CR_MSEL10_0, MSEL2CR_MSEL10_1, + MSEL2CR_MSEL9_0, MSEL2CR_MSEL9_1, + MSEL2CR_MSEL8_0, MSEL2CR_MSEL8_1, + MSEL2CR_MSEL7_0, MSEL2CR_MSEL7_1, + MSEL2CR_MSEL6_0, MSEL2CR_MSEL6_1, + MSEL2CR_MSEL4_0, MSEL2CR_MSEL4_1, + MSEL2CR_MSEL5_0, MSEL2CR_MSEL5_1, + MSEL2CR_MSEL3_0, MSEL2CR_MSEL3_1, + MSEL2CR_MSEL2_0, MSEL2CR_MSEL2_1, + MSEL2CR_MSEL1_0, MSEL2CR_MSEL1_1, + MSEL2CR_MSEL0_0, MSEL2CR_MSEL0_1, + MSEL3CR_MSEL28_0, MSEL3CR_MSEL28_1, + MSEL3CR_MSEL15_0, MSEL3CR_MSEL15_1, + MSEL3CR_MSEL11_0, MSEL3CR_MSEL11_1, + MSEL3CR_MSEL9_0, MSEL3CR_MSEL9_1, + MSEL3CR_MSEL6_0, MSEL3CR_MSEL6_1, + MSEL3CR_MSEL2_0, MSEL3CR_MSEL2_1, + MSEL4CR_MSEL29_0, MSEL4CR_MSEL29_1, + MSEL4CR_MSEL27_0, MSEL4CR_MSEL27_1, + MSEL4CR_MSEL26_0, MSEL4CR_MSEL26_1, + MSEL4CR_MSEL22_0, MSEL4CR_MSEL22_1, + MSEL4CR_MSEL21_0, MSEL4CR_MSEL21_1, + MSEL4CR_MSEL20_0, MSEL4CR_MSEL20_1, + MSEL4CR_MSEL19_0, MSEL4CR_MSEL19_1, + MSEL4CR_MSEL15_0, MSEL4CR_MSEL15_1, + MSEL4CR_MSEL13_0, MSEL4CR_MSEL13_1, + MSEL4CR_MSEL12_0, MSEL4CR_MSEL12_1, + MSEL4CR_MSEL11_0, MSEL4CR_MSEL11_1, + MSEL4CR_MSEL10_0, MSEL4CR_MSEL10_1, + MSEL4CR_MSEL9_0, MSEL4CR_MSEL9_1, + MSEL4CR_MSEL8_0, MSEL4CR_MSEL8_1, + MSEL4CR_MSEL7_0, MSEL4CR_MSEL7_1, + MSEL4CR_MSEL4_0, MSEL4CR_MSEL4_1, + MSEL4CR_MSEL1_0, MSEL4CR_MSEL1_1, + PINMUX_FUNCTION_END, + + PINMUX_MARK_BEGIN, + /* Hardware manual Table 25-1 (Function 0-7) */ + VBUS_0_MARK, + GPI0_MARK, + GPI1_MARK, + GPI2_MARK, + GPI3_MARK, + GPI4_MARK, + GPI5_MARK, + GPI6_MARK, + GPI7_MARK, + SCIFA7_RXD_MARK, + SCIFA7_CTS__MARK, + GPO7_MARK, MFG0_OUT2_MARK, + GPO6_MARK, MFG1_OUT2_MARK, + GPO5_MARK, SCIFA0_SCK_MARK, FSICOSLDT3_MARK, PORT16_VIO_CKOR_MARK, + SCIFA0_TXD_MARK, + SCIFA7_TXD_MARK, + SCIFA7_RTS__MARK, PORT19_VIO_CKO2_MARK, + GPO0_MARK, + GPO1_MARK, + GPO2_MARK, STATUS0_MARK, + GPO3_MARK, STATUS1_MARK, + GPO4_MARK, STATUS2_MARK, + VINT_MARK, + TCKON_MARK, + XDVFS1_MARK, PORT27_I2C_SCL2_MARK, PORT27_I2C_SCL3_MARK, \ + MFG0_OUT1_MARK, PORT27_IROUT_MARK, + XDVFS2_MARK, PORT28_I2C_SDA2_MARK, PORT28_I2C_SDA3_MARK, \ + PORT28_TPU1TO1_MARK, + SIM_RST_MARK, PORT29_TPU1TO1_MARK, + SIM_CLK_MARK, PORT30_VIO_CKOR_MARK, + SIM_D_MARK, PORT31_IROUT_MARK, + SCIFA4_TXD_MARK, + SCIFA4_RXD_MARK, XWUP_MARK, + SCIFA4_RTS__MARK, + SCIFA4_CTS__MARK, + FSIBOBT_MARK, FSIBIBT_MARK, + FSIBOLR_MARK, FSIBILR_MARK, + FSIBOSLD_MARK, + FSIBISLD_MARK, + VACK_MARK, + XTAL1L_MARK, + SCIFA0_RTS__MARK, FSICOSLDT2_MARK, + SCIFA0_RXD_MARK, + SCIFA0_CTS__MARK, FSICOSLDT1_MARK, + FSICOBT_MARK, FSICIBT_MARK, FSIDOBT_MARK, FSIDIBT_MARK, + FSICOLR_MARK, FSICILR_MARK, FSIDOLR_MARK, FSIDILR_MARK, + FSICOSLD_MARK, PORT47_FSICSPDIF_MARK, + FSICISLD_MARK, FSIDISLD_MARK, + FSIACK_MARK, PORT49_IRDA_OUT_MARK, PORT49_IROUT_MARK, FSIAOMC_MARK, + FSIAOLR_MARK, BBIF2_TSYNC2_MARK, TPU2TO2_MARK, FSIAILR_MARK, + + FSIAOBT_MARK, BBIF2_TSCK2_MARK, TPU2TO3_MARK, FSIAIBT_MARK, + FSIAOSLD_MARK, BBIF2_TXD2_MARK, + FSIASPDIF_MARK, PORT53_IRDA_IN_MARK, TPU3TO3_MARK, FSIBSPDIF_MARK, \ + PORT53_FSICSPDIF_MARK, + FSIBCK_MARK, PORT54_IRDA_FIRSEL_MARK, TPU3TO2_MARK, FSIBOMC_MARK, \ + FSICCK_MARK, FSICOMC_MARK, + FSIAISLD_MARK, TPU0TO0_MARK, + A0_MARK, BS__MARK, + A12_MARK, PORT58_KEYOUT7_MARK, TPU4TO2_MARK, + A13_MARK, PORT59_KEYOUT6_MARK, TPU0TO1_MARK, + A14_MARK, KEYOUT5_MARK, + A15_MARK, KEYOUT4_MARK, + A16_MARK, KEYOUT3_MARK, MSIOF0_SS1_MARK, + A17_MARK, KEYOUT2_MARK, MSIOF0_TSYNC_MARK, + A18_MARK, KEYOUT1_MARK, MSIOF0_TSCK_MARK, + A19_MARK, KEYOUT0_MARK, MSIOF0_TXD_MARK, + A20_MARK, KEYIN0_MARK, MSIOF0_RSCK_MARK, + A21_MARK, KEYIN1_MARK, MSIOF0_RSYNC_MARK, + A22_MARK, KEYIN2_MARK, MSIOF0_MCK0_MARK, + A23_MARK, KEYIN3_MARK, MSIOF0_MCK1_MARK, + A24_MARK, KEYIN4_MARK, MSIOF0_RXD_MARK, + A25_MARK, KEYIN5_MARK, MSIOF0_SS2_MARK, + A26_MARK, KEYIN6_MARK, + KEYIN7_MARK, + D0_NAF0_MARK, + D1_NAF1_MARK, + D2_NAF2_MARK, + D3_NAF3_MARK, + D4_NAF4_MARK, + D5_NAF5_MARK, + D6_NAF6_MARK, + D7_NAF7_MARK, + D8_NAF8_MARK, + D9_NAF9_MARK, + D10_NAF10_MARK, + D11_NAF11_MARK, + D12_NAF12_MARK, + D13_NAF13_MARK, + D14_NAF14_MARK, + D15_NAF15_MARK, + CS4__MARK, + CS5A__MARK, PORT91_RDWR_MARK, + CS5B__MARK, FCE1__MARK, + CS6B__MARK, DACK0_MARK, + FCE0__MARK, CS6A__MARK, + WAIT__MARK, DREQ0_MARK, + RD__FSC_MARK, + WE0__FWE_MARK, RDWR_FWE_MARK, + WE1__MARK, + FRB_MARK, + CKO_MARK, + NBRSTOUT__MARK, + NBRST__MARK, + BBIF2_TXD_MARK, + BBIF2_RXD_MARK, + BBIF2_SYNC_MARK, + BBIF2_SCK_MARK, + SCIFA3_CTS__MARK, MFG3_IN2_MARK, + SCIFA3_RXD_MARK, MFG3_IN1_MARK, + BBIF1_SS2_MARK, SCIFA3_RTS__MARK, MFG3_OUT1_MARK, + SCIFA3_TXD_MARK, + HSI_RX_DATA_MARK, BBIF1_RXD_MARK, + HSI_TX_WAKE_MARK, BBIF1_TSCK_MARK, + HSI_TX_DATA_MARK, BBIF1_TSYNC_MARK, + HSI_TX_READY_MARK, BBIF1_TXD_MARK, + HSI_RX_READY_MARK, BBIF1_RSCK_MARK, PORT115_I2C_SCL2_MARK, \ + PORT115_I2C_SCL3_MARK, + HSI_RX_WAKE_MARK, BBIF1_RSYNC_MARK, PORT116_I2C_SDA2_MARK, \ + PORT116_I2C_SDA3_MARK, + HSI_RX_FLAG_MARK, BBIF1_SS1_MARK, BBIF1_FLOW_MARK, + HSI_TX_FLAG_MARK, + VIO_VD_MARK, PORT128_LCD2VSYN_MARK, VIO2_VD_MARK, LCD2D0_MARK, + + VIO_HD_MARK, PORT129_LCD2HSYN_MARK, PORT129_LCD2CS__MARK, \ + VIO2_HD_MARK, LCD2D1_MARK, + VIO_D0_MARK, PORT130_MSIOF2_RXD_MARK, LCD2D10_MARK, + VIO_D1_MARK, PORT131_KEYOUT6_MARK, PORT131_MSIOF2_SS1_MARK, \ + PORT131_KEYOUT11_MARK, LCD2D11_MARK, + VIO_D2_MARK, PORT132_KEYOUT7_MARK, PORT132_MSIOF2_SS2_MARK, \ + PORT132_KEYOUT10_MARK, LCD2D12_MARK, + VIO_D3_MARK, MSIOF2_TSYNC_MARK, LCD2D13_MARK, + VIO_D4_MARK, MSIOF2_TXD_MARK, LCD2D14_MARK, + VIO_D5_MARK, MSIOF2_TSCK_MARK, LCD2D15_MARK, + VIO_D6_MARK, PORT136_KEYOUT8_MARK, LCD2D16_MARK, + VIO_D7_MARK, PORT137_KEYOUT9_MARK, LCD2D17_MARK, + VIO_D8_MARK, PORT138_KEYOUT8_MARK, VIO2_D0_MARK, LCD2D6_MARK, + VIO_D9_MARK, PORT139_KEYOUT9_MARK, VIO2_D1_MARK, LCD2D7_MARK, + VIO_D10_MARK, TPU0TO2_MARK, VIO2_D2_MARK, LCD2D8_MARK, + VIO_D11_MARK, TPU0TO3_MARK, VIO2_D3_MARK, LCD2D9_MARK, + VIO_D12_MARK, PORT142_KEYOUT10_MARK, VIO2_D4_MARK, LCD2D2_MARK, + VIO_D13_MARK, PORT143_KEYOUT11_MARK, PORT143_KEYOUT6_MARK, \ + VIO2_D5_MARK, LCD2D3_MARK, + VIO_D14_MARK, PORT144_KEYOUT7_MARK, VIO2_D6_MARK, LCD2D4_MARK, + VIO_D15_MARK, TPU1TO3_MARK, PORT145_LCD2DISP_MARK, \ + PORT145_LCD2RS_MARK, VIO2_D7_MARK, LCD2D5_MARK, + VIO_CLK_MARK, LCD2DCK_MARK, PORT146_LCD2WR__MARK, VIO2_CLK_MARK, \ + LCD2D18_MARK, + VIO_FIELD_MARK, LCD2RD__MARK, VIO2_FIELD_MARK, LCD2D19_MARK, + VIO_CKO_MARK, + A27_MARK, PORT149_RDWR_MARK, MFG0_IN1_MARK, PORT149_KEYOUT9_MARK, + MFG0_IN2_MARK, + TS_SPSYNC3_MARK, MSIOF2_RSCK_MARK, + TS_SDAT3_MARK, MSIOF2_RSYNC_MARK, + TPU1TO2_MARK, TS_SDEN3_MARK, PORT153_MSIOF2_SS1_MARK, + SCIFA2_TXD1_MARK, MSIOF2_MCK0_MARK, + SCIFA2_RXD1_MARK, MSIOF2_MCK1_MARK, + SCIFA2_RTS1__MARK, PORT156_MSIOF2_SS2_MARK, + SCIFA2_CTS1__MARK, PORT157_MSIOF2_RXD_MARK, + DINT__MARK, SCIFA2_SCK1_MARK, TS_SCK3_MARK, + PORT159_SCIFB_SCK_MARK, PORT159_SCIFA5_SCK_MARK, NMI_MARK, + PORT160_SCIFB_TXD_MARK, PORT160_SCIFA5_TXD_MARK, + PORT161_SCIFB_CTS__MARK, PORT161_SCIFA5_CTS__MARK, + PORT162_SCIFB_RXD_MARK, PORT162_SCIFA5_RXD_MARK, + PORT163_SCIFB_RTS__MARK, PORT163_SCIFA5_RTS__MARK, TPU3TO0_MARK, + LCDD0_MARK, + LCDD1_MARK, PORT193_SCIFA5_CTS__MARK, BBIF2_TSYNC1_MARK, + LCDD2_MARK, PORT194_SCIFA5_RTS__MARK, BBIF2_TSCK1_MARK, + LCDD3_MARK, PORT195_SCIFA5_RXD_MARK, BBIF2_TXD1_MARK, + LCDD4_MARK, PORT196_SCIFA5_TXD_MARK, + LCDD5_MARK, PORT197_SCIFA5_SCK_MARK, MFG2_OUT2_MARK, TPU2TO1_MARK, + LCDD6_MARK, + LCDD7_MARK, TPU4TO1_MARK, MFG4_OUT2_MARK, + LCDD8_MARK, D16_MARK, + LCDD9_MARK, D17_MARK, + LCDD10_MARK, D18_MARK, + LCDD11_MARK, D19_MARK, + LCDD12_MARK, D20_MARK, + LCDD13_MARK, D21_MARK, + LCDD14_MARK, D22_MARK, + LCDD15_MARK, PORT207_MSIOF0L_SS1_MARK, D23_MARK, + LCDD16_MARK, PORT208_MSIOF0L_SS2_MARK, D24_MARK, + LCDD17_MARK, D25_MARK, + LCDD18_MARK, DREQ2_MARK, PORT210_MSIOF0L_SS1_MARK, D26_MARK, + LCDD19_MARK, PORT211_MSIOF0L_SS2_MARK, D27_MARK, + LCDD20_MARK, TS_SPSYNC1_MARK, MSIOF0L_MCK0_MARK, D28_MARK, + LCDD21_MARK, TS_SDAT1_MARK, MSIOF0L_MCK1_MARK, D29_MARK, + LCDD22_MARK, TS_SDEN1_MARK, MSIOF0L_RSCK_MARK, D30_MARK, + LCDD23_MARK, TS_SCK1_MARK, MSIOF0L_RSYNC_MARK, D31_MARK, + LCDDCK_MARK, LCDWR__MARK, + LCDRD__MARK, DACK2_MARK, PORT217_LCD2RS_MARK, MSIOF0L_TSYNC_MARK, \ + VIO2_FIELD3_MARK, PORT217_LCD2DISP_MARK, + LCDHSYN_MARK, LCDCS__MARK, LCDCS2__MARK, DACK3_MARK, \ + PORT218_VIO_CKOR_MARK, + LCDDISP_MARK, LCDRS_MARK, PORT219_LCD2WR__MARK, DREQ3_MARK, \ + MSIOF0L_TSCK_MARK, VIO2_CLK3_MARK, LCD2DCK_2_MARK, + LCDVSYN_MARK, LCDVSYN2_MARK, + LCDLCLK_MARK, DREQ1_MARK, PORT221_LCD2CS__MARK, PWEN_MARK, \ + MSIOF0L_RXD_MARK, VIO2_HD3_MARK, PORT221_LCD2HSYN_MARK, + LCDDON_MARK, LCDDON2_MARK, DACK1_MARK, OVCN_MARK, MSIOF0L_TXD_MARK, \ + VIO2_VD3_MARK, PORT222_LCD2VSYN_MARK, + + SCIFA1_TXD_MARK, OVCN2_MARK, + EXTLP_MARK, SCIFA1_SCK_MARK, PORT226_VIO_CKO2_MARK, + SCIFA1_RTS__MARK, IDIN_MARK, + SCIFA1_RXD_MARK, + SCIFA1_CTS__MARK, MFG1_IN1_MARK, + MSIOF1_TXD_MARK, SCIFA2_TXD2_MARK, + MSIOF1_TSYNC_MARK, SCIFA2_CTS2__MARK, + MSIOF1_TSCK_MARK, SCIFA2_SCK2_MARK, + MSIOF1_RXD_MARK, SCIFA2_RXD2_MARK, + MSIOF1_RSCK_MARK, SCIFA2_RTS2__MARK, VIO2_CLK2_MARK, LCD2D20_MARK, + MSIOF1_RSYNC_MARK, MFG1_IN2_MARK, VIO2_VD2_MARK, LCD2D21_MARK, + MSIOF1_MCK0_MARK, PORT236_I2C_SDA2_MARK, + MSIOF1_MCK1_MARK, PORT237_I2C_SCL2_MARK, + MSIOF1_SS1_MARK, VIO2_FIELD2_MARK, LCD2D22_MARK, + MSIOF1_SS2_MARK, VIO2_HD2_MARK, LCD2D23_MARK, + SCIFA6_TXD_MARK, + PORT241_IRDA_OUT_MARK, PORT241_IROUT_MARK, MFG4_OUT1_MARK, TPU4TO0_MARK, + PORT242_IRDA_IN_MARK, MFG4_IN2_MARK, + PORT243_IRDA_FIRSEL_MARK, PORT243_VIO_CKO2_MARK, + PORT244_SCIFA5_CTS__MARK, MFG2_IN1_MARK, PORT244_SCIFB_CTS__MARK, \ + MSIOF2R_RXD_MARK, + PORT245_SCIFA5_RTS__MARK, MFG2_IN2_MARK, PORT245_SCIFB_RTS__MARK, \ + MSIOF2R_TXD_MARK, + PORT246_SCIFA5_RXD_MARK, MFG1_OUT1_MARK, PORT246_SCIFB_RXD_MARK, \ + TPU1TO0_MARK, + PORT247_SCIFA5_TXD_MARK, MFG3_OUT2_MARK, PORT247_SCIFB_TXD_MARK, \ + TPU3TO1_MARK, + PORT248_SCIFA5_SCK_MARK, MFG2_OUT1_MARK, PORT248_SCIFB_SCK_MARK, \ + TPU2TO0_MARK, PORT248_I2C_SCL3_MARK, MSIOF2R_TSCK_MARK, + PORT249_IROUT_MARK, MFG4_IN1_MARK, PORT249_I2C_SDA3_MARK, \ + MSIOF2R_TSYNC_MARK, + SDHICLK0_MARK, + SDHICD0_MARK, + SDHID0_0_MARK, + SDHID0_1_MARK, + SDHID0_2_MARK, + SDHID0_3_MARK, + SDHICMD0_MARK, + SDHIWP0_MARK, + SDHICLK1_MARK, + SDHID1_0_MARK, TS_SPSYNC2_MARK, + SDHID1_1_MARK, TS_SDAT2_MARK, + SDHID1_2_MARK, TS_SDEN2_MARK, + SDHID1_3_MARK, TS_SCK2_MARK, + SDHICMD1_MARK, + SDHICLK2_MARK, + SDHID2_0_MARK, TS_SPSYNC4_MARK, + SDHID2_1_MARK, TS_SDAT4_MARK, + SDHID2_2_MARK, TS_SDEN4_MARK, + SDHID2_3_MARK, TS_SCK4_MARK, + SDHICMD2_MARK, + MMCCLK0_MARK, + MMCD0_0_MARK, + MMCD0_1_MARK, + MMCD0_2_MARK, + MMCD0_3_MARK, + MMCD0_4_MARK, TS_SPSYNC5_MARK, + MMCD0_5_MARK, TS_SDAT5_MARK, + MMCD0_6_MARK, TS_SDEN5_MARK, + MMCD0_7_MARK, TS_SCK5_MARK, + MMCCMD0_MARK, + RESETOUTS__MARK, EXTAL2OUT_MARK, + MCP_WAIT__MCP_FRB_MARK, + MCP_CKO_MARK, MMCCLK1_MARK, + MCP_D15_MCP_NAF15_MARK, + MCP_D14_MCP_NAF14_MARK, + MCP_D13_MCP_NAF13_MARK, + MCP_D12_MCP_NAF12_MARK, + MCP_D11_MCP_NAF11_MARK, + MCP_D10_MCP_NAF10_MARK, + MCP_D9_MCP_NAF9_MARK, + MCP_D8_MCP_NAF8_MARK, MMCCMD1_MARK, + MCP_D7_MCP_NAF7_MARK, MMCD1_7_MARK, + + MCP_D6_MCP_NAF6_MARK, MMCD1_6_MARK, + MCP_D5_MCP_NAF5_MARK, MMCD1_5_MARK, + MCP_D4_MCP_NAF4_MARK, MMCD1_4_MARK, + MCP_D3_MCP_NAF3_MARK, MMCD1_3_MARK, + MCP_D2_MCP_NAF2_MARK, MMCD1_2_MARK, + MCP_D1_MCP_NAF1_MARK, MMCD1_1_MARK, + MCP_D0_MCP_NAF0_MARK, MMCD1_0_MARK, + MCP_NBRSTOUT__MARK, + MCP_WE0__MCP_FWE_MARK, MCP_RDWR_MCP_FWE_MARK, + + /* MSEL2 special cases */ + TSIF2_TS_XX1_MARK, + TSIF2_TS_XX2_MARK, + TSIF2_TS_XX3_MARK, + TSIF2_TS_XX4_MARK, + TSIF2_TS_XX5_MARK, + TSIF1_TS_XX1_MARK, + TSIF1_TS_XX2_MARK, + TSIF1_TS_XX3_MARK, + TSIF1_TS_XX4_MARK, + TSIF1_TS_XX5_MARK, + TSIF0_TS_XX1_MARK, + TSIF0_TS_XX2_MARK, + TSIF0_TS_XX3_MARK, + TSIF0_TS_XX4_MARK, + TSIF0_TS_XX5_MARK, + MST1_TS_XX1_MARK, + MST1_TS_XX2_MARK, + MST1_TS_XX3_MARK, + MST1_TS_XX4_MARK, + MST1_TS_XX5_MARK, + MST0_TS_XX1_MARK, + MST0_TS_XX2_MARK, + MST0_TS_XX3_MARK, + MST0_TS_XX4_MARK, + MST0_TS_XX5_MARK, + + /* MSEL3 special cases */ + SDHI0_VCCQ_MC0_ON_MARK, + SDHI0_VCCQ_MC0_OFF_MARK, + DEBUG_MON_VIO_MARK, + DEBUG_MON_LCDD_MARK, + LCDC_LCDC0_MARK, + LCDC_LCDC1_MARK, + + /* MSEL4 special cases */ + IRQ9_MEM_INT_MARK, + IRQ9_MCP_INT_MARK, + A11_MARK, + KEYOUT8_MARK, + TPU4TO3_MARK, + RESETA_N_PU_ON_MARK, + RESETA_N_PU_OFF_MARK, + EDBGREQ_PD_MARK, + EDBGREQ_PU_MARK, + + /* Functions with pull-ups */ + KEYIN0_PU_MARK, + KEYIN1_PU_MARK, + KEYIN2_PU_MARK, + KEYIN3_PU_MARK, + KEYIN4_PU_MARK, + KEYIN5_PU_MARK, + KEYIN6_PU_MARK, + KEYIN7_PU_MARK, + SDHICD0_PU_MARK, + SDHID0_0_PU_MARK, + SDHID0_1_PU_MARK, + SDHID0_2_PU_MARK, + SDHID0_3_PU_MARK, + SDHICMD0_PU_MARK, + SDHIWP0_PU_MARK, + SDHID1_0_PU_MARK, + SDHID1_1_PU_MARK, + SDHID1_2_PU_MARK, + SDHID1_3_PU_MARK, + SDHICMD1_PU_MARK, + SDHID2_0_PU_MARK, + SDHID2_1_PU_MARK, + SDHID2_2_PU_MARK, + SDHID2_3_PU_MARK, + SDHICMD2_PU_MARK, + MMCCMD0_PU_MARK, + MMCCMD1_PU_MARK, + MMCD0_0_PU_MARK, + MMCD0_1_PU_MARK, + MMCD0_2_PU_MARK, + MMCD0_3_PU_MARK, + MMCD0_4_PU_MARK, + MMCD0_5_PU_MARK, + MMCD0_6_PU_MARK, + MMCD0_7_PU_MARK, + FSIBISLD_PU_MARK, + FSIACK_PU_MARK, + FSIAILR_PU_MARK, + FSIAIBT_PU_MARK, + FSIAISLD_PU_MARK, + + PINMUX_MARK_END, +}; + +static unsigned short pinmux_data[] = { + /* specify valid pin states for each pin in GPIO mode */ + + /* Table 25-1 (I/O and Pull U/D) */ + PORT_DATA_I_PD(0), + PORT_DATA_I_PU(1), + PORT_DATA_I_PU(2), + PORT_DATA_I_PU(3), + PORT_DATA_I_PU(4), + PORT_DATA_I_PU(5), + PORT_DATA_I_PU(6), + PORT_DATA_I_PU(7), + PORT_DATA_I_PU(8), + PORT_DATA_I_PD(9), + PORT_DATA_I_PD(10), + PORT_DATA_I_PU_PD(11), + PORT_DATA_IO_PU_PD(12), + PORT_DATA_IO_PU_PD(13), + PORT_DATA_IO_PU_PD(14), + PORT_DATA_IO_PU_PD(15), + PORT_DATA_IO_PD(16), + PORT_DATA_IO_PD(17), + PORT_DATA_IO_PU(18), + PORT_DATA_IO_PU(19), + PORT_DATA_O(20), + PORT_DATA_O(21), + PORT_DATA_O(22), + PORT_DATA_O(23), + PORT_DATA_O(24), + PORT_DATA_I_PD(25), + PORT_DATA_I_PD(26), + PORT_DATA_IO_PU(27), + PORT_DATA_IO_PU(28), + PORT_DATA_IO_PD(29), + PORT_DATA_IO_PD(30), + PORT_DATA_IO_PU(31), + PORT_DATA_IO_PD(32), + PORT_DATA_I_PU_PD(33), + PORT_DATA_IO_PD(34), + PORT_DATA_I_PU_PD(35), + PORT_DATA_IO_PD(36), + PORT_DATA_IO(37), + PORT_DATA_O(38), + PORT_DATA_I_PU(39), + PORT_DATA_I_PU_PD(40), + PORT_DATA_O(41), + PORT_DATA_IO_PD(42), + PORT_DATA_IO_PU_PD(43), + PORT_DATA_IO_PU_PD(44), + PORT_DATA_IO_PD(45), + PORT_DATA_IO_PD(46), + PORT_DATA_IO_PD(47), + PORT_DATA_I_PD(48), + PORT_DATA_IO_PU_PD(49), + PORT_DATA_IO_PD(50), + + PORT_DATA_IO_PD(51), + PORT_DATA_O(52), + PORT_DATA_IO_PU_PD(53), + PORT_DATA_IO_PU_PD(54), + PORT_DATA_IO_PD(55), + PORT_DATA_I_PU_PD(56), + PORT_DATA_IO(57), + PORT_DATA_IO(58), + PORT_DATA_IO(59), + PORT_DATA_IO(60), + PORT_DATA_IO(61), + PORT_DATA_IO_PD(62), + PORT_DATA_IO_PD(63), + PORT_DATA_IO_PU_PD(64), + PORT_DATA_IO_PD(65), + PORT_DATA_IO_PU_PD(66), + PORT_DATA_IO_PU_PD(67), + PORT_DATA_IO_PU_PD(68), + PORT_DATA_IO_PU_PD(69), + PORT_DATA_IO_PU_PD(70), + PORT_DATA_IO_PU_PD(71), + PORT_DATA_IO_PU_PD(72), + PORT_DATA_I_PU_PD(73), + PORT_DATA_IO_PU(74), + PORT_DATA_IO_PU(75), + PORT_DATA_IO_PU(76), + PORT_DATA_IO_PU(77), + PORT_DATA_IO_PU(78), + PORT_DATA_IO_PU(79), + PORT_DATA_IO_PU(80), + PORT_DATA_IO_PU(81), + PORT_DATA_IO_PU(82), + PORT_DATA_IO_PU(83), + PORT_DATA_IO_PU(84), + PORT_DATA_IO_PU(85), + PORT_DATA_IO_PU(86), + PORT_DATA_IO_PU(87), + PORT_DATA_IO_PU(88), + PORT_DATA_IO_PU(89), + PORT_DATA_O(90), + PORT_DATA_IO_PU(91), + PORT_DATA_O(92), + PORT_DATA_IO_PU(93), + PORT_DATA_O(94), + PORT_DATA_I_PU_PD(95), + PORT_DATA_IO(96), + PORT_DATA_IO(97), + PORT_DATA_IO(98), + PORT_DATA_I_PU(99), + PORT_DATA_O(100), + PORT_DATA_O(101), + PORT_DATA_I_PU(102), + PORT_DATA_IO_PD(103), + PORT_DATA_I_PU_PD(104), + PORT_DATA_I_PD(105), + PORT_DATA_I_PD(106), + PORT_DATA_I_PU_PD(107), + PORT_DATA_I_PU_PD(108), + PORT_DATA_IO_PD(109), + PORT_DATA_IO_PD(110), + PORT_DATA_IO_PU_PD(111), + PORT_DATA_IO_PU_PD(112), + PORT_DATA_IO_PU_PD(113), + PORT_DATA_IO_PD(114), + PORT_DATA_IO_PU(115), + PORT_DATA_IO_PU(116), + PORT_DATA_IO_PU_PD(117), + PORT_DATA_IO_PU_PD(118), + PORT_DATA_IO_PD(128), + + PORT_DATA_IO_PD(129), + PORT_DATA_IO_PU_PD(130), + PORT_DATA_IO_PD(131), + PORT_DATA_IO_PD(132), + PORT_DATA_IO_PD(133), + PORT_DATA_IO_PU_PD(134), + PORT_DATA_IO_PU_PD(135), + PORT_DATA_IO_PU_PD(136), + PORT_DATA_IO_PU_PD(137), + PORT_DATA_IO_PD(138), + PORT_DATA_IO_PD(139), + PORT_DATA_IO_PD(140), + PORT_DATA_IO_PD(141), + PORT_DATA_IO_PD(142), + PORT_DATA_IO_PD(143), + PORT_DATA_IO_PU_PD(144), + PORT_DATA_IO_PD(145), + PORT_DATA_IO_PU_PD(146), + PORT_DATA_IO_PU_PD(147), + PORT_DATA_IO_PU_PD(148), + PORT_DATA_IO_PU_PD(149), + PORT_DATA_I_PU_PD(150), + PORT_DATA_IO_PU_PD(151), + PORT_DATA_IO_PU_PD(152), + PORT_DATA_IO_PD(153), + PORT_DATA_IO_PD(154), + PORT_DATA_I_PU_PD(155), + PORT_DATA_IO_PU_PD(156), + PORT_DATA_I_PD(157), + PORT_DATA_IO_PD(158), + PORT_DATA_IO_PU_PD(159), + PORT_DATA_IO_PU_PD(160), + PORT_DATA_I_PU_PD(161), + PORT_DATA_I_PU_PD(162), + PORT_DATA_IO_PU_PD(163), + PORT_DATA_I_PU_PD(164), + PORT_DATA_IO_PD(192), + PORT_DATA_IO_PU_PD(193), + PORT_DATA_IO_PD(194), + PORT_DATA_IO_PU_PD(195), + PORT_DATA_IO_PD(196), + PORT_DATA_IO_PD(197), + PORT_DATA_IO_PD(198), + PORT_DATA_IO_PD(199), + PORT_DATA_IO_PU_PD(200), + PORT_DATA_IO_PU_PD(201), + PORT_DATA_IO_PU_PD(202), + PORT_DATA_IO_PU_PD(203), + PORT_DATA_IO_PU_PD(204), + PORT_DATA_IO_PU_PD(205), + PORT_DATA_IO_PU_PD(206), + PORT_DATA_IO_PD(207), + PORT_DATA_IO_PD(208), + PORT_DATA_IO_PD(209), + PORT_DATA_IO_PD(210), + PORT_DATA_IO_PD(211), + PORT_DATA_IO_PD(212), + PORT_DATA_IO_PD(213), + PORT_DATA_IO_PU_PD(214), + PORT_DATA_IO_PU_PD(215), + PORT_DATA_IO_PD(216), + PORT_DATA_IO_PD(217), + PORT_DATA_O(218), + PORT_DATA_IO_PD(219), + PORT_DATA_IO_PD(220), + PORT_DATA_IO_PU_PD(221), + PORT_DATA_IO_PU_PD(222), + PORT_DATA_I_PU_PD(223), + PORT_DATA_I_PU_PD(224), + + PORT_DATA_IO_PU_PD(225), + PORT_DATA_O(226), + PORT_DATA_IO_PU_PD(227), + PORT_DATA_I_PU_PD(228), + PORT_DATA_I_PD(229), + PORT_DATA_IO(230), + PORT_DATA_IO_PU_PD(231), + PORT_DATA_IO_PU_PD(232), + PORT_DATA_I_PU_PD(233), + PORT_DATA_IO_PU_PD(234), + PORT_DATA_IO_PU_PD(235), + PORT_DATA_IO_PU_PD(236), + PORT_DATA_IO_PD(237), + PORT_DATA_IO_PU_PD(238), + PORT_DATA_IO_PU_PD(239), + PORT_DATA_IO_PU_PD(240), + PORT_DATA_O(241), + PORT_DATA_I_PD(242), + PORT_DATA_IO_PU_PD(243), + PORT_DATA_IO_PU_PD(244), + PORT_DATA_IO_PU_PD(245), + PORT_DATA_IO_PU_PD(246), + PORT_DATA_IO_PU_PD(247), + PORT_DATA_IO_PU_PD(248), + PORT_DATA_IO_PU_PD(249), + PORT_DATA_IO_PU_PD(250), + PORT_DATA_IO_PU_PD(251), + PORT_DATA_IO_PU_PD(252), + PORT_DATA_IO_PU_PD(253), + PORT_DATA_IO_PU_PD(254), + PORT_DATA_IO_PU_PD(255), + PORT_DATA_IO_PU_PD(256), + PORT_DATA_IO_PU_PD(257), + PORT_DATA_IO_PU_PD(258), + PORT_DATA_IO_PU_PD(259), + PORT_DATA_IO_PU_PD(260), + PORT_DATA_IO_PU_PD(261), + PORT_DATA_IO_PU_PD(262), + PORT_DATA_IO_PU_PD(263), + PORT_DATA_IO_PU_PD(264), + PORT_DATA_IO_PU_PD(265), + PORT_DATA_IO_PU_PD(266), + PORT_DATA_IO_PU_PD(267), + PORT_DATA_IO_PU_PD(268), + PORT_DATA_IO_PU_PD(269), + PORT_DATA_IO_PU_PD(270), + PORT_DATA_IO_PU_PD(271), + PORT_DATA_IO_PU_PD(272), + PORT_DATA_IO_PU_PD(273), + PORT_DATA_IO_PU_PD(274), + PORT_DATA_IO_PU_PD(275), + PORT_DATA_IO_PU_PD(276), + PORT_DATA_IO_PU_PD(277), + PORT_DATA_IO_PU_PD(278), + PORT_DATA_IO_PU_PD(279), + PORT_DATA_IO_PU_PD(280), + PORT_DATA_O(281), + PORT_DATA_O(282), + PORT_DATA_I_PU(288), + PORT_DATA_IO_PU_PD(289), + PORT_DATA_IO_PU_PD(290), + PORT_DATA_IO_PU_PD(291), + PORT_DATA_IO_PU_PD(292), + PORT_DATA_IO_PU_PD(293), + PORT_DATA_IO_PU_PD(294), + PORT_DATA_IO_PU_PD(295), + PORT_DATA_IO_PU_PD(296), + PORT_DATA_IO_PU_PD(297), + PORT_DATA_IO_PU_PD(298), + + PORT_DATA_IO_PU_PD(299), + PORT_DATA_IO_PU_PD(300), + PORT_DATA_IO_PU_PD(301), + PORT_DATA_IO_PU_PD(302), + PORT_DATA_IO_PU_PD(303), + PORT_DATA_IO_PU_PD(304), + PORT_DATA_IO_PU_PD(305), + PORT_DATA_O(306), + PORT_DATA_O(307), + PORT_DATA_I_PU(308), + PORT_DATA_O(309), + + /* Table 25-1 (Function 0-7) */ + PINMUX_DATA(VBUS_0_MARK, PORT0_FN1), + PINMUX_DATA(GPI0_MARK, PORT1_FN1), + PINMUX_DATA(GPI1_MARK, PORT2_FN1), + PINMUX_DATA(GPI2_MARK, PORT3_FN1), + PINMUX_DATA(GPI3_MARK, PORT4_FN1), + PINMUX_DATA(GPI4_MARK, PORT5_FN1), + PINMUX_DATA(GPI5_MARK, PORT6_FN1), + PINMUX_DATA(GPI6_MARK, PORT7_FN1), + PINMUX_DATA(GPI7_MARK, PORT8_FN1), + PINMUX_DATA(SCIFA7_RXD_MARK, PORT12_FN2), + PINMUX_DATA(SCIFA7_CTS__MARK, PORT13_FN2), + PINMUX_DATA(GPO7_MARK, PORT14_FN1), \ + PINMUX_DATA(MFG0_OUT2_MARK, PORT14_FN4), + PINMUX_DATA(GPO6_MARK, PORT15_FN1), \ + PINMUX_DATA(MFG1_OUT2_MARK, PORT15_FN4), + PINMUX_DATA(GPO5_MARK, PORT16_FN1), \ + PINMUX_DATA(SCIFA0_SCK_MARK, PORT16_FN2), \ + PINMUX_DATA(FSICOSLDT3_MARK, PORT16_FN3), \ + PINMUX_DATA(PORT16_VIO_CKOR_MARK, PORT16_FN4), + PINMUX_DATA(SCIFA0_TXD_MARK, PORT17_FN2), + PINMUX_DATA(SCIFA7_TXD_MARK, PORT18_FN2), + PINMUX_DATA(SCIFA7_RTS__MARK, PORT19_FN2), \ + PINMUX_DATA(PORT19_VIO_CKO2_MARK, PORT19_FN3), + PINMUX_DATA(GPO0_MARK, PORT20_FN1), + PINMUX_DATA(GPO1_MARK, PORT21_FN1), + PINMUX_DATA(GPO2_MARK, PORT22_FN1), \ + PINMUX_DATA(STATUS0_MARK, PORT22_FN2), + PINMUX_DATA(GPO3_MARK, PORT23_FN1), \ + PINMUX_DATA(STATUS1_MARK, PORT23_FN2), + PINMUX_DATA(GPO4_MARK, PORT24_FN1), \ + PINMUX_DATA(STATUS2_MARK, PORT24_FN2), + PINMUX_DATA(VINT_MARK, PORT25_FN1), + PINMUX_DATA(TCKON_MARK, PORT26_FN1), + PINMUX_DATA(XDVFS1_MARK, PORT27_FN1), \ + PINMUX_DATA(PORT27_I2C_SCL2_MARK, PORT27_FN2, MSEL2CR_MSEL17_0, + MSEL2CR_MSEL16_1), \ + PINMUX_DATA(PORT27_I2C_SCL3_MARK, PORT27_FN3, MSEL2CR_MSEL19_0, + MSEL2CR_MSEL18_1), \ + PINMUX_DATA(MFG0_OUT1_MARK, PORT27_FN4), \ + PINMUX_DATA(PORT27_IROUT_MARK, PORT27_FN7), + PINMUX_DATA(XDVFS2_MARK, PORT28_FN1), \ + PINMUX_DATA(PORT28_I2C_SDA2_MARK, PORT28_FN2, MSEL2CR_MSEL17_0, + MSEL2CR_MSEL16_1), \ + PINMUX_DATA(PORT28_I2C_SDA3_MARK, PORT28_FN3, MSEL2CR_MSEL19_0, + MSEL2CR_MSEL18_1), \ + PINMUX_DATA(PORT28_TPU1TO1_MARK, PORT28_FN7), + PINMUX_DATA(SIM_RST_MARK, PORT29_FN1), \ + PINMUX_DATA(PORT29_TPU1TO1_MARK, PORT29_FN4), + PINMUX_DATA(SIM_CLK_MARK, PORT30_FN1), \ + PINMUX_DATA(PORT30_VIO_CKOR_MARK, PORT30_FN4), + PINMUX_DATA(SIM_D_MARK, PORT31_FN1), \ + PINMUX_DATA(PORT31_IROUT_MARK, PORT31_FN4), + PINMUX_DATA(SCIFA4_TXD_MARK, PORT32_FN2), + PINMUX_DATA(SCIFA4_RXD_MARK, PORT33_FN2), \ + PINMUX_DATA(XWUP_MARK, PORT33_FN3), + PINMUX_DATA(SCIFA4_RTS__MARK, PORT34_FN2), + PINMUX_DATA(SCIFA4_CTS__MARK, PORT35_FN2), + PINMUX_DATA(FSIBOBT_MARK, PORT36_FN1), \ + PINMUX_DATA(FSIBIBT_MARK, PORT36_FN2), + PINMUX_DATA(FSIBOLR_MARK, PORT37_FN1), \ + PINMUX_DATA(FSIBILR_MARK, PORT37_FN2), + PINMUX_DATA(FSIBOSLD_MARK, PORT38_FN1), + PINMUX_DATA(FSIBISLD_MARK, PORT39_FN1), + PINMUX_DATA(VACK_MARK, PORT40_FN1), + PINMUX_DATA(XTAL1L_MARK, PORT41_FN1), + PINMUX_DATA(SCIFA0_RTS__MARK, PORT42_FN2), \ + PINMUX_DATA(FSICOSLDT2_MARK, PORT42_FN3), + PINMUX_DATA(SCIFA0_RXD_MARK, PORT43_FN2), + PINMUX_DATA(SCIFA0_CTS__MARK, PORT44_FN2), \ + PINMUX_DATA(FSICOSLDT1_MARK, PORT44_FN3), + PINMUX_DATA(FSICOBT_MARK, PORT45_FN1), \ + PINMUX_DATA(FSICIBT_MARK, PORT45_FN2), \ + PINMUX_DATA(FSIDOBT_MARK, PORT45_FN3), \ + PINMUX_DATA(FSIDIBT_MARK, PORT45_FN4), + PINMUX_DATA(FSICOLR_MARK, PORT46_FN1), \ + PINMUX_DATA(FSICILR_MARK, PORT46_FN2), \ + PINMUX_DATA(FSIDOLR_MARK, PORT46_FN3), \ + PINMUX_DATA(FSIDILR_MARK, PORT46_FN4), + PINMUX_DATA(FSICOSLD_MARK, PORT47_FN1), \ + PINMUX_DATA(PORT47_FSICSPDIF_MARK, PORT47_FN2), + PINMUX_DATA(FSICISLD_MARK, PORT48_FN1), \ + PINMUX_DATA(FSIDISLD_MARK, PORT48_FN3), + PINMUX_DATA(FSIACK_MARK, PORT49_FN1), \ + PINMUX_DATA(PORT49_IRDA_OUT_MARK, PORT49_FN2, MSEL4CR_MSEL19_1), \ + PINMUX_DATA(PORT49_IROUT_MARK, PORT49_FN4), \ + PINMUX_DATA(FSIAOMC_MARK, PORT49_FN5), + PINMUX_DATA(FSIAOLR_MARK, PORT50_FN1), \ + PINMUX_DATA(BBIF2_TSYNC2_MARK, PORT50_FN2), \ + PINMUX_DATA(TPU2TO2_MARK, PORT50_FN3), \ + PINMUX_DATA(FSIAILR_MARK, PORT50_FN5), + + PINMUX_DATA(FSIAOBT_MARK, PORT51_FN1), \ + PINMUX_DATA(BBIF2_TSCK2_MARK, PORT51_FN2), \ + PINMUX_DATA(TPU2TO3_MARK, PORT51_FN3), \ + PINMUX_DATA(FSIAIBT_MARK, PORT51_FN5), + PINMUX_DATA(FSIAOSLD_MARK, PORT52_FN1), \ + PINMUX_DATA(BBIF2_TXD2_MARK, PORT52_FN2), + PINMUX_DATA(FSIASPDIF_MARK, PORT53_FN1), \ + PINMUX_DATA(PORT53_IRDA_IN_MARK, PORT53_FN2, MSEL4CR_MSEL19_1), \ + PINMUX_DATA(TPU3TO3_MARK, PORT53_FN3), \ + PINMUX_DATA(FSIBSPDIF_MARK, PORT53_FN5), \ + PINMUX_DATA(PORT53_FSICSPDIF_MARK, PORT53_FN6), + PINMUX_DATA(FSIBCK_MARK, PORT54_FN1), \ + PINMUX_DATA(PORT54_IRDA_FIRSEL_MARK, PORT54_FN2, MSEL4CR_MSEL19_1), \ + PINMUX_DATA(TPU3TO2_MARK, PORT54_FN3), \ + PINMUX_DATA(FSIBOMC_MARK, PORT54_FN5), \ + PINMUX_DATA(FSICCK_MARK, PORT54_FN6), \ + PINMUX_DATA(FSICOMC_MARK, PORT54_FN7), + PINMUX_DATA(FSIAISLD_MARK, PORT55_FN1), \ + PINMUX_DATA(TPU0TO0_MARK, PORT55_FN3), + PINMUX_DATA(A0_MARK, PORT57_FN1), \ + PINMUX_DATA(BS__MARK, PORT57_FN2), + PINMUX_DATA(A12_MARK, PORT58_FN1), \ + PINMUX_DATA(PORT58_KEYOUT7_MARK, PORT58_FN2), \ + PINMUX_DATA(TPU4TO2_MARK, PORT58_FN4), + PINMUX_DATA(A13_MARK, PORT59_FN1), \ + PINMUX_DATA(PORT59_KEYOUT6_MARK, PORT59_FN2), \ + PINMUX_DATA(TPU0TO1_MARK, PORT59_FN4), + PINMUX_DATA(A14_MARK, PORT60_FN1), \ + PINMUX_DATA(KEYOUT5_MARK, PORT60_FN2), + PINMUX_DATA(A15_MARK, PORT61_FN1), \ + PINMUX_DATA(KEYOUT4_MARK, PORT61_FN2), + PINMUX_DATA(A16_MARK, PORT62_FN1), \ + PINMUX_DATA(KEYOUT3_MARK, PORT62_FN2), \ + PINMUX_DATA(MSIOF0_SS1_MARK, PORT62_FN4, MSEL3CR_MSEL11_0), + PINMUX_DATA(A17_MARK, PORT63_FN1), \ + PINMUX_DATA(KEYOUT2_MARK, PORT63_FN2), \ + PINMUX_DATA(MSIOF0_TSYNC_MARK, PORT63_FN4, MSEL3CR_MSEL11_0), + PINMUX_DATA(A18_MARK, PORT64_FN1), \ + PINMUX_DATA(KEYOUT1_MARK, PORT64_FN2), \ + PINMUX_DATA(MSIOF0_TSCK_MARK, PORT64_FN4, MSEL3CR_MSEL11_0), + PINMUX_DATA(A19_MARK, PORT65_FN1), \ + PINMUX_DATA(KEYOUT0_MARK, PORT65_FN2), \ + PINMUX_DATA(MSIOF0_TXD_MARK, PORT65_FN4, MSEL3CR_MSEL11_0), + PINMUX_DATA(A20_MARK, PORT66_FN1), \ + PINMUX_DATA(KEYIN0_MARK, PORT66_FN2), \ + PINMUX_DATA(MSIOF0_RSCK_MARK, PORT66_FN4, MSEL3CR_MSEL11_0), + PINMUX_DATA(A21_MARK, PORT67_FN1), \ + PINMUX_DATA(KEYIN1_MARK, PORT67_FN2), \ + PINMUX_DATA(MSIOF0_RSYNC_MARK, PORT67_FN4, MSEL3CR_MSEL11_0), + PINMUX_DATA(A22_MARK, PORT68_FN1), \ + PINMUX_DATA(KEYIN2_MARK, PORT68_FN2), \ + PINMUX_DATA(MSIOF0_MCK0_MARK, PORT68_FN4, MSEL3CR_MSEL11_0), + PINMUX_DATA(A23_MARK, PORT69_FN1), \ + PINMUX_DATA(KEYIN3_MARK, PORT69_FN2), \ + PINMUX_DATA(MSIOF0_MCK1_MARK, PORT69_FN4, MSEL3CR_MSEL11_0), + PINMUX_DATA(A24_MARK, PORT70_FN1), \ + PINMUX_DATA(KEYIN4_MARK, PORT70_FN2), \ + PINMUX_DATA(MSIOF0_RXD_MARK, PORT70_FN4, MSEL3CR_MSEL11_0), + PINMUX_DATA(A25_MARK, PORT71_FN1), \ + PINMUX_DATA(KEYIN5_MARK, PORT71_FN2), \ + PINMUX_DATA(MSIOF0_SS2_MARK, PORT71_FN4, MSEL3CR_MSEL11_0), + PINMUX_DATA(A26_MARK, PORT72_FN1), \ + PINMUX_DATA(KEYIN6_MARK, PORT72_FN2), + PINMUX_DATA(KEYIN7_MARK, PORT73_FN2), + PINMUX_DATA(D0_NAF0_MARK, PORT74_FN1), + PINMUX_DATA(D1_NAF1_MARK, PORT75_FN1), + PINMUX_DATA(D2_NAF2_MARK, PORT76_FN1), + PINMUX_DATA(D3_NAF3_MARK, PORT77_FN1), + PINMUX_DATA(D4_NAF4_MARK, PORT78_FN1), + PINMUX_DATA(D5_NAF5_MARK, PORT79_FN1), + PINMUX_DATA(D6_NAF6_MARK, PORT80_FN1), + PINMUX_DATA(D7_NAF7_MARK, PORT81_FN1), + PINMUX_DATA(D8_NAF8_MARK, PORT82_FN1), + PINMUX_DATA(D9_NAF9_MARK, PORT83_FN1), + PINMUX_DATA(D10_NAF10_MARK, PORT84_FN1), + PINMUX_DATA(D11_NAF11_MARK, PORT85_FN1), + PINMUX_DATA(D12_NAF12_MARK, PORT86_FN1), + PINMUX_DATA(D13_NAF13_MARK, PORT87_FN1), + PINMUX_DATA(D14_NAF14_MARK, PORT88_FN1), + PINMUX_DATA(D15_NAF15_MARK, PORT89_FN1), + PINMUX_DATA(CS4__MARK, PORT90_FN1), + PINMUX_DATA(CS5A__MARK, PORT91_FN1), \ + PINMUX_DATA(PORT91_RDWR_MARK, PORT91_FN2), + PINMUX_DATA(CS5B__MARK, PORT92_FN1), \ + PINMUX_DATA(FCE1__MARK, PORT92_FN2), + PINMUX_DATA(CS6B__MARK, PORT93_FN1), \ + PINMUX_DATA(DACK0_MARK, PORT93_FN4), + PINMUX_DATA(FCE0__MARK, PORT94_FN1), \ + PINMUX_DATA(CS6A__MARK, PORT94_FN2), + PINMUX_DATA(WAIT__MARK, PORT95_FN1), \ + PINMUX_DATA(DREQ0_MARK, PORT95_FN2), + PINMUX_DATA(RD__FSC_MARK, PORT96_FN1), + PINMUX_DATA(WE0__FWE_MARK, PORT97_FN1), \ + PINMUX_DATA(RDWR_FWE_MARK, PORT97_FN2), + PINMUX_DATA(WE1__MARK, PORT98_FN1), + PINMUX_DATA(FRB_MARK, PORT99_FN1), + PINMUX_DATA(CKO_MARK, PORT100_FN1), + PINMUX_DATA(NBRSTOUT__MARK, PORT101_FN1), + PINMUX_DATA(NBRST__MARK, PORT102_FN1), + PINMUX_DATA(BBIF2_TXD_MARK, PORT103_FN3), + PINMUX_DATA(BBIF2_RXD_MARK, PORT104_FN3), + PINMUX_DATA(BBIF2_SYNC_MARK, PORT105_FN3), + PINMUX_DATA(BBIF2_SCK_MARK, PORT106_FN3), + PINMUX_DATA(SCIFA3_CTS__MARK, PORT107_FN3), \ + PINMUX_DATA(MFG3_IN2_MARK, PORT107_FN4), + PINMUX_DATA(SCIFA3_RXD_MARK, PORT108_FN3), \ + PINMUX_DATA(MFG3_IN1_MARK, PORT108_FN4), + PINMUX_DATA(BBIF1_SS2_MARK, PORT109_FN2), \ + PINMUX_DATA(SCIFA3_RTS__MARK, PORT109_FN3), \ + PINMUX_DATA(MFG3_OUT1_MARK, PORT109_FN4), + PINMUX_DATA(SCIFA3_TXD_MARK, PORT110_FN3), + PINMUX_DATA(HSI_RX_DATA_MARK, PORT111_FN1), \ + PINMUX_DATA(BBIF1_RXD_MARK, PORT111_FN3), + PINMUX_DATA(HSI_TX_WAKE_MARK, PORT112_FN1), \ + PINMUX_DATA(BBIF1_TSCK_MARK, PORT112_FN3), + PINMUX_DATA(HSI_TX_DATA_MARK, PORT113_FN1), \ + PINMUX_DATA(BBIF1_TSYNC_MARK, PORT113_FN3), + PINMUX_DATA(HSI_TX_READY_MARK, PORT114_FN1), \ + PINMUX_DATA(BBIF1_TXD_MARK, PORT114_FN3), + PINMUX_DATA(HSI_RX_READY_MARK, PORT115_FN1), \ + PINMUX_DATA(BBIF1_RSCK_MARK, PORT115_FN3), \ + PINMUX_DATA(PORT115_I2C_SCL2_MARK, PORT115_FN5, MSEL2CR_MSEL17_1), \ + PINMUX_DATA(PORT115_I2C_SCL3_MARK, PORT115_FN6, MSEL2CR_MSEL19_1), + PINMUX_DATA(HSI_RX_WAKE_MARK, PORT116_FN1), \ + PINMUX_DATA(BBIF1_RSYNC_MARK, PORT116_FN3), \ + PINMUX_DATA(PORT116_I2C_SDA2_MARK, PORT116_FN5, MSEL2CR_MSEL17_1), \ + PINMUX_DATA(PORT116_I2C_SDA3_MARK, PORT116_FN6, MSEL2CR_MSEL19_1), + PINMUX_DATA(HSI_RX_FLAG_MARK, PORT117_FN1), \ + PINMUX_DATA(BBIF1_SS1_MARK, PORT117_FN2), \ + PINMUX_DATA(BBIF1_FLOW_MARK, PORT117_FN3), + PINMUX_DATA(HSI_TX_FLAG_MARK, PORT118_FN1), + PINMUX_DATA(VIO_VD_MARK, PORT128_FN1), \ + PINMUX_DATA(PORT128_LCD2VSYN_MARK, PORT128_FN4, MSEL3CR_MSEL2_0), \ + PINMUX_DATA(VIO2_VD_MARK, PORT128_FN6, MSEL4CR_MSEL27_0), \ + PINMUX_DATA(LCD2D0_MARK, PORT128_FN7), + + PINMUX_DATA(VIO_HD_MARK, PORT129_FN1), \ + PINMUX_DATA(PORT129_LCD2HSYN_MARK, PORT129_FN4), \ + PINMUX_DATA(PORT129_LCD2CS__MARK, PORT129_FN5), \ + PINMUX_DATA(VIO2_HD_MARK, PORT129_FN6, MSEL4CR_MSEL27_0), \ + PINMUX_DATA(LCD2D1_MARK, PORT129_FN7), + PINMUX_DATA(VIO_D0_MARK, PORT130_FN1), \ + PINMUX_DATA(PORT130_MSIOF2_RXD_MARK, PORT130_FN3, MSEL4CR_MSEL11_0, + MSEL4CR_MSEL10_1), \ + PINMUX_DATA(LCD2D10_MARK, PORT130_FN7), + PINMUX_DATA(VIO_D1_MARK, PORT131_FN1), \ + PINMUX_DATA(PORT131_KEYOUT6_MARK, PORT131_FN2), \ + PINMUX_DATA(PORT131_MSIOF2_SS1_MARK, PORT131_FN3), \ + PINMUX_DATA(PORT131_KEYOUT11_MARK, PORT131_FN4), \ + PINMUX_DATA(LCD2D11_MARK, PORT131_FN7), + PINMUX_DATA(VIO_D2_MARK, PORT132_FN1), \ + PINMUX_DATA(PORT132_KEYOUT7_MARK, PORT132_FN2), \ + PINMUX_DATA(PORT132_MSIOF2_SS2_MARK, PORT132_FN3), \ + PINMUX_DATA(PORT132_KEYOUT10_MARK, PORT132_FN4), \ + PINMUX_DATA(LCD2D12_MARK, PORT132_FN7), + PINMUX_DATA(VIO_D3_MARK, PORT133_FN1), \ + PINMUX_DATA(MSIOF2_TSYNC_MARK, PORT133_FN3, MSEL4CR_MSEL11_0), \ + PINMUX_DATA(LCD2D13_MARK, PORT133_FN7), + PINMUX_DATA(VIO_D4_MARK, PORT134_FN1), \ + PINMUX_DATA(MSIOF2_TXD_MARK, PORT134_FN3, MSEL4CR_MSEL11_0), \ + PINMUX_DATA(LCD2D14_MARK, PORT134_FN7), + PINMUX_DATA(VIO_D5_MARK, PORT135_FN1), \ + PINMUX_DATA(MSIOF2_TSCK_MARK, PORT135_FN3, MSEL4CR_MSEL11_0), \ + PINMUX_DATA(LCD2D15_MARK, PORT135_FN7), + PINMUX_DATA(VIO_D6_MARK, PORT136_FN1), \ + PINMUX_DATA(PORT136_KEYOUT8_MARK, PORT136_FN2), \ + PINMUX_DATA(LCD2D16_MARK, PORT136_FN7), + PINMUX_DATA(VIO_D7_MARK, PORT137_FN1), \ + PINMUX_DATA(PORT137_KEYOUT9_MARK, PORT137_FN2), \ + PINMUX_DATA(LCD2D17_MARK, PORT137_FN7), + PINMUX_DATA(VIO_D8_MARK, PORT138_FN1), \ + PINMUX_DATA(PORT138_KEYOUT8_MARK, PORT138_FN2), \ + PINMUX_DATA(VIO2_D0_MARK, PORT138_FN6), \ + PINMUX_DATA(LCD2D6_MARK, PORT138_FN7), + PINMUX_DATA(VIO_D9_MARK, PORT139_FN1), \ + PINMUX_DATA(PORT139_KEYOUT9_MARK, PORT139_FN2), \ + PINMUX_DATA(VIO2_D1_MARK, PORT139_FN6), \ + PINMUX_DATA(LCD2D7_MARK, PORT139_FN7), + PINMUX_DATA(VIO_D10_MARK, PORT140_FN1), \ + PINMUX_DATA(TPU0TO2_MARK, PORT140_FN4), \ + PINMUX_DATA(VIO2_D2_MARK, PORT140_FN6), \ + PINMUX_DATA(LCD2D8_MARK, PORT140_FN7), + PINMUX_DATA(VIO_D11_MARK, PORT141_FN1), \ + PINMUX_DATA(TPU0TO3_MARK, PORT141_FN4), \ + PINMUX_DATA(VIO2_D3_MARK, PORT141_FN6), \ + PINMUX_DATA(LCD2D9_MARK, PORT141_FN7), + PINMUX_DATA(VIO_D12_MARK, PORT142_FN1), \ + PINMUX_DATA(PORT142_KEYOUT10_MARK, PORT142_FN2), \ + PINMUX_DATA(VIO2_D4_MARK, PORT142_FN6), \ + PINMUX_DATA(LCD2D2_MARK, PORT142_FN7), + PINMUX_DATA(VIO_D13_MARK, PORT143_FN1), \ + PINMUX_DATA(PORT143_KEYOUT11_MARK, PORT143_FN2), \ + PINMUX_DATA(PORT143_KEYOUT6_MARK, PORT143_FN3), \ + PINMUX_DATA(VIO2_D5_MARK, PORT143_FN6), \ + PINMUX_DATA(LCD2D3_MARK, PORT143_FN7), + PINMUX_DATA(VIO_D14_MARK, PORT144_FN1), \ + PINMUX_DATA(PORT144_KEYOUT7_MARK, PORT144_FN2), \ + PINMUX_DATA(VIO2_D6_MARK, PORT144_FN6), \ + PINMUX_DATA(LCD2D4_MARK, PORT144_FN7), + PINMUX_DATA(VIO_D15_MARK, PORT145_FN1), \ + PINMUX_DATA(TPU1TO3_MARK, PORT145_FN3), \ + PINMUX_DATA(PORT145_LCD2DISP_MARK, PORT145_FN4), \ + PINMUX_DATA(PORT145_LCD2RS_MARK, PORT145_FN5), \ + PINMUX_DATA(VIO2_D7_MARK, PORT145_FN6), \ + PINMUX_DATA(LCD2D5_MARK, PORT145_FN7), + PINMUX_DATA(VIO_CLK_MARK, PORT146_FN1), \ + PINMUX_DATA(LCD2DCK_MARK, PORT146_FN4), \ + PINMUX_DATA(PORT146_LCD2WR__MARK, PORT146_FN5), \ + PINMUX_DATA(VIO2_CLK_MARK, PORT146_FN6, MSEL4CR_MSEL27_0), \ + PINMUX_DATA(LCD2D18_MARK, PORT146_FN7), + PINMUX_DATA(VIO_FIELD_MARK, PORT147_FN1), \ + PINMUX_DATA(LCD2RD__MARK, PORT147_FN4), \ + PINMUX_DATA(VIO2_FIELD_MARK, PORT147_FN6, MSEL4CR_MSEL27_0), \ + PINMUX_DATA(LCD2D19_MARK, PORT147_FN7), + PINMUX_DATA(VIO_CKO_MARK, PORT148_FN1), + PINMUX_DATA(A27_MARK, PORT149_FN1), \ + PINMUX_DATA(PORT149_RDWR_MARK, PORT149_FN2), \ + PINMUX_DATA(MFG0_IN1_MARK, PORT149_FN3), \ + PINMUX_DATA(PORT149_KEYOUT9_MARK, PORT149_FN4), + PINMUX_DATA(MFG0_IN2_MARK, PORT150_FN3), + PINMUX_DATA(TS_SPSYNC3_MARK, PORT151_FN4), \ + PINMUX_DATA(MSIOF2_RSCK_MARK, PORT151_FN5), + PINMUX_DATA(TS_SDAT3_MARK, PORT152_FN4), \ + PINMUX_DATA(MSIOF2_RSYNC_MARK, PORT152_FN5), + PINMUX_DATA(TPU1TO2_MARK, PORT153_FN3), \ + PINMUX_DATA(TS_SDEN3_MARK, PORT153_FN4), \ + PINMUX_DATA(PORT153_MSIOF2_SS1_MARK, PORT153_FN5), + PINMUX_DATA(SCIFA2_TXD1_MARK, PORT154_FN2, MSEL3CR_MSEL9_0), \ + PINMUX_DATA(MSIOF2_MCK0_MARK, PORT154_FN5), + PINMUX_DATA(SCIFA2_RXD1_MARK, PORT155_FN2, MSEL3CR_MSEL9_0), \ + PINMUX_DATA(MSIOF2_MCK1_MARK, PORT155_FN5), + PINMUX_DATA(SCIFA2_RTS1__MARK, PORT156_FN2, MSEL3CR_MSEL9_0), \ + PINMUX_DATA(PORT156_MSIOF2_SS2_MARK, PORT156_FN5), + PINMUX_DATA(SCIFA2_CTS1__MARK, PORT157_FN2, MSEL3CR_MSEL9_0), \ + PINMUX_DATA(PORT157_MSIOF2_RXD_MARK, PORT157_FN5, MSEL4CR_MSEL11_0, + MSEL4CR_MSEL10_0), + PINMUX_DATA(DINT__MARK, PORT158_FN1), \ + PINMUX_DATA(SCIFA2_SCK1_MARK, PORT158_FN2, MSEL3CR_MSEL9_0), \ + PINMUX_DATA(TS_SCK3_MARK, PORT158_FN4), + PINMUX_DATA(PORT159_SCIFB_SCK_MARK, PORT159_FN1, MSEL4CR_MSEL22_0), \ + PINMUX_DATA(PORT159_SCIFA5_SCK_MARK, PORT159_FN2, MSEL4CR_MSEL21_1), \ + PINMUX_DATA(NMI_MARK, PORT159_FN3), + PINMUX_DATA(PORT160_SCIFB_TXD_MARK, PORT160_FN1, MSEL4CR_MSEL22_0), \ + PINMUX_DATA(PORT160_SCIFA5_TXD_MARK, PORT160_FN2, MSEL4CR_MSEL21_1), + PINMUX_DATA(PORT161_SCIFB_CTS__MARK, PORT161_FN1, MSEL4CR_MSEL22_0), \ + PINMUX_DATA(PORT161_SCIFA5_CTS__MARK, PORT161_FN2, MSEL4CR_MSEL21_1), + PINMUX_DATA(PORT162_SCIFB_RXD_MARK, PORT162_FN1, MSEL4CR_MSEL22_0), \ + PINMUX_DATA(PORT162_SCIFA5_RXD_MARK, PORT162_FN2, MSEL4CR_MSEL21_1), + PINMUX_DATA(PORT163_SCIFB_RTS__MARK, PORT163_FN1, MSEL4CR_MSEL22_0), \ + PINMUX_DATA(PORT163_SCIFA5_RTS__MARK, PORT163_FN2, MSEL4CR_MSEL21_1), \ + PINMUX_DATA(TPU3TO0_MARK, PORT163_FN5), + PINMUX_DATA(LCDD0_MARK, PORT192_FN1), + PINMUX_DATA(LCDD1_MARK, PORT193_FN1), \ + PINMUX_DATA(PORT193_SCIFA5_CTS__MARK, PORT193_FN3, MSEL4CR_MSEL21_0, + MSEL4CR_MSEL20_1), \ + PINMUX_DATA(BBIF2_TSYNC1_MARK, PORT193_FN5), + PINMUX_DATA(LCDD2_MARK, PORT194_FN1), \ + PINMUX_DATA(PORT194_SCIFA5_RTS__MARK, PORT194_FN3, MSEL4CR_MSEL21_0, + MSEL4CR_MSEL20_1), \ + PINMUX_DATA(BBIF2_TSCK1_MARK, PORT194_FN5), + PINMUX_DATA(LCDD3_MARK, PORT195_FN1), \ + PINMUX_DATA(PORT195_SCIFA5_RXD_MARK, PORT195_FN3, MSEL4CR_MSEL21_0, + MSEL4CR_MSEL20_1), \ + PINMUX_DATA(BBIF2_TXD1_MARK, PORT195_FN5), + PINMUX_DATA(LCDD4_MARK, PORT196_FN1), \ + PINMUX_DATA(PORT196_SCIFA5_TXD_MARK, PORT196_FN3, MSEL4CR_MSEL21_0, + MSEL4CR_MSEL20_1), + PINMUX_DATA(LCDD5_MARK, PORT197_FN1), \ + PINMUX_DATA(PORT197_SCIFA5_SCK_MARK, PORT197_FN3, MSEL4CR_MSEL21_0, + MSEL4CR_MSEL20_1), \ + PINMUX_DATA(MFG2_OUT2_MARK, PORT197_FN5), \ + PINMUX_DATA(TPU2TO1_MARK, PORT197_FN7), + PINMUX_DATA(LCDD6_MARK, PORT198_FN1), + PINMUX_DATA(LCDD7_MARK, PORT199_FN1), \ + PINMUX_DATA(TPU4TO1_MARK, PORT199_FN2), \ + PINMUX_DATA(MFG4_OUT2_MARK, PORT199_FN5), + PINMUX_DATA(LCDD8_MARK, PORT200_FN1), \ + PINMUX_DATA(D16_MARK, PORT200_FN6), + PINMUX_DATA(LCDD9_MARK, PORT201_FN1), \ + PINMUX_DATA(D17_MARK, PORT201_FN6), + PINMUX_DATA(LCDD10_MARK, PORT202_FN1), \ + PINMUX_DATA(D18_MARK, PORT202_FN6), + PINMUX_DATA(LCDD11_MARK, PORT203_FN1), \ + PINMUX_DATA(D19_MARK, PORT203_FN6), + PINMUX_DATA(LCDD12_MARK, PORT204_FN1), \ + PINMUX_DATA(D20_MARK, PORT204_FN6), + PINMUX_DATA(LCDD13_MARK, PORT205_FN1), \ + PINMUX_DATA(D21_MARK, PORT205_FN6), + PINMUX_DATA(LCDD14_MARK, PORT206_FN1), \ + PINMUX_DATA(D22_MARK, PORT206_FN6), + PINMUX_DATA(LCDD15_MARK, PORT207_FN1), \ + PINMUX_DATA(PORT207_MSIOF0L_SS1_MARK, PORT207_FN2, MSEL3CR_MSEL11_1), \ + PINMUX_DATA(D23_MARK, PORT207_FN6), + PINMUX_DATA(LCDD16_MARK, PORT208_FN1), \ + PINMUX_DATA(PORT208_MSIOF0L_SS2_MARK, PORT208_FN2, MSEL3CR_MSEL11_1), \ + PINMUX_DATA(D24_MARK, PORT208_FN6), + PINMUX_DATA(LCDD17_MARK, PORT209_FN1), \ + PINMUX_DATA(D25_MARK, PORT209_FN6), + PINMUX_DATA(LCDD18_MARK, PORT210_FN1), \ + PINMUX_DATA(DREQ2_MARK, PORT210_FN2), \ + PINMUX_DATA(PORT210_MSIOF0L_SS1_MARK, PORT210_FN5, MSEL3CR_MSEL11_1), \ + PINMUX_DATA(D26_MARK, PORT210_FN6), + PINMUX_DATA(LCDD19_MARK, PORT211_FN1), \ + PINMUX_DATA(PORT211_MSIOF0L_SS2_MARK, PORT211_FN5, MSEL3CR_MSEL11_1), \ + PINMUX_DATA(D27_MARK, PORT211_FN6), + PINMUX_DATA(LCDD20_MARK, PORT212_FN1), \ + PINMUX_DATA(TS_SPSYNC1_MARK, PORT212_FN2), \ + PINMUX_DATA(MSIOF0L_MCK0_MARK, PORT212_FN5, MSEL3CR_MSEL11_1), \ + PINMUX_DATA(D28_MARK, PORT212_FN6), + PINMUX_DATA(LCDD21_MARK, PORT213_FN1), \ + PINMUX_DATA(TS_SDAT1_MARK, PORT213_FN2), \ + PINMUX_DATA(MSIOF0L_MCK1_MARK, PORT213_FN5, MSEL3CR_MSEL11_1), \ + PINMUX_DATA(D29_MARK, PORT213_FN6), + PINMUX_DATA(LCDD22_MARK, PORT214_FN1), \ + PINMUX_DATA(TS_SDEN1_MARK, PORT214_FN2), \ + PINMUX_DATA(MSIOF0L_RSCK_MARK, PORT214_FN5, MSEL3CR_MSEL11_1), \ + PINMUX_DATA(D30_MARK, PORT214_FN6), + PINMUX_DATA(LCDD23_MARK, PORT215_FN1), \ + PINMUX_DATA(TS_SCK1_MARK, PORT215_FN2), \ + PINMUX_DATA(MSIOF0L_RSYNC_MARK, PORT215_FN5, MSEL3CR_MSEL11_1), \ + PINMUX_DATA(D31_MARK, PORT215_FN6), + PINMUX_DATA(LCDDCK_MARK, PORT216_FN1), \ + PINMUX_DATA(LCDWR__MARK, PORT216_FN2), + PINMUX_DATA(LCDRD__MARK, PORT217_FN1), \ + PINMUX_DATA(DACK2_MARK, PORT217_FN2), \ + PINMUX_DATA(PORT217_LCD2RS_MARK, PORT217_FN3), \ + PINMUX_DATA(MSIOF0L_TSYNC_MARK, PORT217_FN5, MSEL3CR_MSEL11_1), \ + PINMUX_DATA(VIO2_FIELD3_MARK, PORT217_FN6, MSEL4CR_MSEL27_1, + MSEL4CR_MSEL26_1), \ + PINMUX_DATA(PORT217_LCD2DISP_MARK, PORT217_FN7), + PINMUX_DATA(LCDHSYN_MARK, PORT218_FN1), \ + PINMUX_DATA(LCDCS__MARK, PORT218_FN2), \ + PINMUX_DATA(LCDCS2__MARK, PORT218_FN3), \ + PINMUX_DATA(DACK3_MARK, PORT218_FN4), \ + PINMUX_DATA(PORT218_VIO_CKOR_MARK, PORT218_FN5), + PINMUX_DATA(LCDDISP_MARK, PORT219_FN1), \ + PINMUX_DATA(LCDRS_MARK, PORT219_FN2), \ + PINMUX_DATA(PORT219_LCD2WR__MARK, PORT219_FN3), \ + PINMUX_DATA(DREQ3_MARK, PORT219_FN4), \ + PINMUX_DATA(MSIOF0L_TSCK_MARK, PORT219_FN5, MSEL3CR_MSEL11_1), \ + PINMUX_DATA(VIO2_CLK3_MARK, PORT219_FN6, MSEL4CR_MSEL27_1, + MSEL4CR_MSEL26_1), \ + PINMUX_DATA(LCD2DCK_2_MARK, PORT219_FN7), + PINMUX_DATA(LCDVSYN_MARK, PORT220_FN1), \ + PINMUX_DATA(LCDVSYN2_MARK, PORT220_FN2), + PINMUX_DATA(LCDLCLK_MARK, PORT221_FN1), \ + PINMUX_DATA(DREQ1_MARK, PORT221_FN2), \ + PINMUX_DATA(PORT221_LCD2CS__MARK, PORT221_FN3), \ + PINMUX_DATA(PWEN_MARK, PORT221_FN4), \ + PINMUX_DATA(MSIOF0L_RXD_MARK, PORT221_FN5, MSEL3CR_MSEL11_1), \ + PINMUX_DATA(VIO2_HD3_MARK, PORT221_FN6, MSEL4CR_MSEL27_1, + MSEL4CR_MSEL26_1), \ + PINMUX_DATA(PORT221_LCD2HSYN_MARK, PORT221_FN7), + PINMUX_DATA(LCDDON_MARK, PORT222_FN1), \ + PINMUX_DATA(LCDDON2_MARK, PORT222_FN2), \ + PINMUX_DATA(DACK1_MARK, PORT222_FN3), \ + PINMUX_DATA(OVCN_MARK, PORT222_FN4), \ + PINMUX_DATA(MSIOF0L_TXD_MARK, PORT222_FN5, MSEL3CR_MSEL11_1), \ + PINMUX_DATA(VIO2_VD3_MARK, PORT222_FN6, MSEL4CR_MSEL27_1, + MSEL4CR_MSEL26_1), \ + PINMUX_DATA(PORT222_LCD2VSYN_MARK, PORT222_FN7, MSEL3CR_MSEL2_1), + + PINMUX_DATA(SCIFA1_TXD_MARK, PORT225_FN2), \ + PINMUX_DATA(OVCN2_MARK, PORT225_FN4), + PINMUX_DATA(EXTLP_MARK, PORT226_FN1), \ + PINMUX_DATA(SCIFA1_SCK_MARK, PORT226_FN2), \ + PINMUX_DATA(PORT226_VIO_CKO2_MARK, PORT226_FN5), + PINMUX_DATA(SCIFA1_RTS__MARK, PORT227_FN2), \ + PINMUX_DATA(IDIN_MARK, PORT227_FN4), + PINMUX_DATA(SCIFA1_RXD_MARK, PORT228_FN2), + PINMUX_DATA(SCIFA1_CTS__MARK, PORT229_FN2), \ + PINMUX_DATA(MFG1_IN1_MARK, PORT229_FN3), + PINMUX_DATA(MSIOF1_TXD_MARK, PORT230_FN1), \ + PINMUX_DATA(SCIFA2_TXD2_MARK, PORT230_FN2, MSEL3CR_MSEL9_1), + PINMUX_DATA(MSIOF1_TSYNC_MARK, PORT231_FN1), \ + PINMUX_DATA(SCIFA2_CTS2__MARK, PORT231_FN2, MSEL3CR_MSEL9_1), + PINMUX_DATA(MSIOF1_TSCK_MARK, PORT232_FN1), \ + PINMUX_DATA(SCIFA2_SCK2_MARK, PORT232_FN2, MSEL3CR_MSEL9_1), + PINMUX_DATA(MSIOF1_RXD_MARK, PORT233_FN1), \ + PINMUX_DATA(SCIFA2_RXD2_MARK, PORT233_FN2, MSEL3CR_MSEL9_1), + PINMUX_DATA(MSIOF1_RSCK_MARK, PORT234_FN1), \ + PINMUX_DATA(SCIFA2_RTS2__MARK, PORT234_FN2, MSEL3CR_MSEL9_1), \ + PINMUX_DATA(VIO2_CLK2_MARK, PORT234_FN6, MSEL4CR_MSEL27_1, + MSEL4CR_MSEL26_0), \ + PINMUX_DATA(LCD2D20_MARK, PORT234_FN7), + PINMUX_DATA(MSIOF1_RSYNC_MARK, PORT235_FN1), \ + PINMUX_DATA(MFG1_IN2_MARK, PORT235_FN3), \ + PINMUX_DATA(VIO2_VD2_MARK, PORT235_FN6, MSEL4CR_MSEL27_1, + MSEL4CR_MSEL26_0), \ + PINMUX_DATA(LCD2D21_MARK, PORT235_FN7), + PINMUX_DATA(MSIOF1_MCK0_MARK, PORT236_FN1), \ + PINMUX_DATA(PORT236_I2C_SDA2_MARK, PORT236_FN2, MSEL2CR_MSEL17_0, + MSEL2CR_MSEL16_0), + PINMUX_DATA(MSIOF1_MCK1_MARK, PORT237_FN1), \ + PINMUX_DATA(PORT237_I2C_SCL2_MARK, PORT237_FN2, MSEL2CR_MSEL17_0, + MSEL2CR_MSEL16_0), + PINMUX_DATA(MSIOF1_SS1_MARK, PORT238_FN1), \ + PINMUX_DATA(VIO2_FIELD2_MARK, PORT238_FN6, MSEL4CR_MSEL27_1, + MSEL4CR_MSEL26_0), \ + PINMUX_DATA(LCD2D22_MARK, PORT238_FN7), + PINMUX_DATA(MSIOF1_SS2_MARK, PORT239_FN1), \ + PINMUX_DATA(VIO2_HD2_MARK, PORT239_FN6, MSEL4CR_MSEL27_1, + MSEL4CR_MSEL26_0), \ + PINMUX_DATA(LCD2D23_MARK, PORT239_FN7), + PINMUX_DATA(SCIFA6_TXD_MARK, PORT240_FN1), + PINMUX_DATA(PORT241_IRDA_OUT_MARK, PORT241_FN1, MSEL4CR_MSEL19_0), \ + PINMUX_DATA(PORT241_IROUT_MARK, PORT241_FN2), \ + PINMUX_DATA(MFG4_OUT1_MARK, PORT241_FN3), \ + PINMUX_DATA(TPU4TO0_MARK, PORT241_FN4), + PINMUX_DATA(PORT242_IRDA_IN_MARK, PORT242_FN1, MSEL4CR_MSEL19_0), \ + PINMUX_DATA(MFG4_IN2_MARK, PORT242_FN3), + PINMUX_DATA(PORT243_IRDA_FIRSEL_MARK, PORT243_FN1, MSEL4CR_MSEL19_0), \ + PINMUX_DATA(PORT243_VIO_CKO2_MARK, PORT243_FN2), + PINMUX_DATA(PORT244_SCIFA5_CTS__MARK, PORT244_FN1, MSEL4CR_MSEL21_0, + MSEL4CR_MSEL20_0), \ + PINMUX_DATA(MFG2_IN1_MARK, PORT244_FN2), \ + PINMUX_DATA(PORT244_SCIFB_CTS__MARK, PORT244_FN3, MSEL4CR_MSEL22_1), \ + PINMUX_DATA(MSIOF2R_RXD_MARK, PORT244_FN7, MSEL4CR_MSEL11_1), + PINMUX_DATA(PORT245_SCIFA5_RTS__MARK, PORT245_FN1, MSEL4CR_MSEL21_0, + MSEL4CR_MSEL20_0), \ + PINMUX_DATA(MFG2_IN2_MARK, PORT245_FN2), \ + PINMUX_DATA(PORT245_SCIFB_RTS__MARK, PORT245_FN3, MSEL4CR_MSEL22_1), \ + PINMUX_DATA(MSIOF2R_TXD_MARK, PORT245_FN7, MSEL4CR_MSEL11_1), + PINMUX_DATA(PORT246_SCIFA5_RXD_MARK, PORT246_FN1, MSEL4CR_MSEL21_0, + MSEL4CR_MSEL20_0), \ + PINMUX_DATA(MFG1_OUT1_MARK, PORT246_FN2), \ + PINMUX_DATA(PORT246_SCIFB_RXD_MARK, PORT246_FN3, MSEL4CR_MSEL22_1), \ + PINMUX_DATA(TPU1TO0_MARK, PORT246_FN4), + PINMUX_DATA(PORT247_SCIFA5_TXD_MARK, PORT247_FN1, MSEL4CR_MSEL21_0, + MSEL4CR_MSEL20_0), \ + PINMUX_DATA(MFG3_OUT2_MARK, PORT247_FN2), \ + PINMUX_DATA(PORT247_SCIFB_TXD_MARK, PORT247_FN3, MSEL4CR_MSEL22_1), \ + PINMUX_DATA(TPU3TO1_MARK, PORT247_FN4), + PINMUX_DATA(PORT248_SCIFA5_SCK_MARK, PORT248_FN1, MSEL4CR_MSEL21_0, + MSEL4CR_MSEL20_0), \ + PINMUX_DATA(MFG2_OUT1_MARK, PORT248_FN2), \ + PINMUX_DATA(PORT248_SCIFB_SCK_MARK, PORT248_FN3, MSEL4CR_MSEL22_1), \ + PINMUX_DATA(TPU2TO0_MARK, PORT248_FN4), \ + PINMUX_DATA(PORT248_I2C_SCL3_MARK, PORT248_FN5, MSEL2CR_MSEL19_0, + MSEL2CR_MSEL18_0), \ + PINMUX_DATA(MSIOF2R_TSCK_MARK, PORT248_FN7, MSEL4CR_MSEL11_1), + PINMUX_DATA(PORT249_IROUT_MARK, PORT249_FN1), \ + PINMUX_DATA(MFG4_IN1_MARK, PORT249_FN2), \ + PINMUX_DATA(PORT249_I2C_SDA3_MARK, PORT249_FN5, MSEL2CR_MSEL19_0, + MSEL2CR_MSEL18_0), \ + PINMUX_DATA(MSIOF2R_TSYNC_MARK, PORT249_FN7, MSEL4CR_MSEL11_1), + PINMUX_DATA(SDHICLK0_MARK, PORT250_FN1), + PINMUX_DATA(SDHICD0_MARK, PORT251_FN1), + PINMUX_DATA(SDHID0_0_MARK, PORT252_FN1), + PINMUX_DATA(SDHID0_1_MARK, PORT253_FN1), + PINMUX_DATA(SDHID0_2_MARK, PORT254_FN1), + PINMUX_DATA(SDHID0_3_MARK, PORT255_FN1), + PINMUX_DATA(SDHICMD0_MARK, PORT256_FN1), + PINMUX_DATA(SDHIWP0_MARK, PORT257_FN1), + PINMUX_DATA(SDHICLK1_MARK, PORT258_FN1), + PINMUX_DATA(SDHID1_0_MARK, PORT259_FN1), \ + PINMUX_DATA(TS_SPSYNC2_MARK, PORT259_FN3), + PINMUX_DATA(SDHID1_1_MARK, PORT260_FN1), \ + PINMUX_DATA(TS_SDAT2_MARK, PORT260_FN3), + PINMUX_DATA(SDHID1_2_MARK, PORT261_FN1), \ + PINMUX_DATA(TS_SDEN2_MARK, PORT261_FN3), + PINMUX_DATA(SDHID1_3_MARK, PORT262_FN1), \ + PINMUX_DATA(TS_SCK2_MARK, PORT262_FN3), + PINMUX_DATA(SDHICMD1_MARK, PORT263_FN1), + PINMUX_DATA(SDHICLK2_MARK, PORT264_FN1), + PINMUX_DATA(SDHID2_0_MARK, PORT265_FN1), \ + PINMUX_DATA(TS_SPSYNC4_MARK, PORT265_FN3), + PINMUX_DATA(SDHID2_1_MARK, PORT266_FN1), \ + PINMUX_DATA(TS_SDAT4_MARK, PORT266_FN3), + PINMUX_DATA(SDHID2_2_MARK, PORT267_FN1), \ + PINMUX_DATA(TS_SDEN4_MARK, PORT267_FN3), + PINMUX_DATA(SDHID2_3_MARK, PORT268_FN1), \ + PINMUX_DATA(TS_SCK4_MARK, PORT268_FN3), + PINMUX_DATA(SDHICMD2_MARK, PORT269_FN1), + PINMUX_DATA(MMCCLK0_MARK, PORT270_FN1, MSEL4CR_MSEL15_0), + PINMUX_DATA(MMCD0_0_MARK, PORT271_FN1, PORT271_IN_PU, + MSEL4CR_MSEL15_0), + PINMUX_DATA(MMCD0_1_MARK, PORT272_FN1, PORT272_IN_PU, + MSEL4CR_MSEL15_0), + PINMUX_DATA(MMCD0_2_MARK, PORT273_FN1, PORT273_IN_PU, + MSEL4CR_MSEL15_0), + PINMUX_DATA(MMCD0_3_MARK, PORT274_FN1, PORT274_IN_PU, + MSEL4CR_MSEL15_0), + PINMUX_DATA(MMCD0_4_MARK, PORT275_FN1, PORT275_IN_PU, + MSEL4CR_MSEL15_0), \ + PINMUX_DATA(TS_SPSYNC5_MARK, PORT275_FN3), + PINMUX_DATA(MMCD0_5_MARK, PORT276_FN1, PORT276_IN_PU, + MSEL4CR_MSEL15_0), \ + PINMUX_DATA(TS_SDAT5_MARK, PORT276_FN3), + PINMUX_DATA(MMCD0_6_MARK, PORT277_FN1, PORT277_IN_PU, + MSEL4CR_MSEL15_0), \ + PINMUX_DATA(TS_SDEN5_MARK, PORT277_FN3), + PINMUX_DATA(MMCD0_7_MARK, PORT278_FN1, PORT278_IN_PU, + MSEL4CR_MSEL15_0), \ + PINMUX_DATA(TS_SCK5_MARK, PORT278_FN3), + PINMUX_DATA(MMCCMD0_MARK, PORT279_FN1, PORT279_IN_PU, + MSEL4CR_MSEL15_0), + PINMUX_DATA(RESETOUTS__MARK, PORT281_FN1), \ + PINMUX_DATA(EXTAL2OUT_MARK, PORT281_FN2), + PINMUX_DATA(MCP_WAIT__MCP_FRB_MARK, PORT288_FN1), + PINMUX_DATA(MCP_CKO_MARK, PORT289_FN1), \ + PINMUX_DATA(MMCCLK1_MARK, PORT289_FN2, MSEL4CR_MSEL15_1), + PINMUX_DATA(MCP_D15_MCP_NAF15_MARK, PORT290_FN1), + PINMUX_DATA(MCP_D14_MCP_NAF14_MARK, PORT291_FN1), + PINMUX_DATA(MCP_D13_MCP_NAF13_MARK, PORT292_FN1), + PINMUX_DATA(MCP_D12_MCP_NAF12_MARK, PORT293_FN1), + PINMUX_DATA(MCP_D11_MCP_NAF11_MARK, PORT294_FN1), + PINMUX_DATA(MCP_D10_MCP_NAF10_MARK, PORT295_FN1), + PINMUX_DATA(MCP_D9_MCP_NAF9_MARK, PORT296_FN1), + PINMUX_DATA(MCP_D8_MCP_NAF8_MARK, PORT297_FN1), \ + PINMUX_DATA(MMCCMD1_MARK, PORT297_FN2, MSEL4CR_MSEL15_1), + PINMUX_DATA(MCP_D7_MCP_NAF7_MARK, PORT298_FN1), \ + PINMUX_DATA(MMCD1_7_MARK, PORT298_FN2, MSEL4CR_MSEL15_1), + + PINMUX_DATA(MCP_D6_MCP_NAF6_MARK, PORT299_FN1), \ + PINMUX_DATA(MMCD1_6_MARK, PORT299_FN2, MSEL4CR_MSEL15_1), + PINMUX_DATA(MCP_D5_MCP_NAF5_MARK, PORT300_FN1), \ + PINMUX_DATA(MMCD1_5_MARK, PORT300_FN2, MSEL4CR_MSEL15_1), + PINMUX_DATA(MCP_D4_MCP_NAF4_MARK, PORT301_FN1), \ + PINMUX_DATA(MMCD1_4_MARK, PORT301_FN2, MSEL4CR_MSEL15_1), + PINMUX_DATA(MCP_D3_MCP_NAF3_MARK, PORT302_FN1), \ + PINMUX_DATA(MMCD1_3_MARK, PORT302_FN2, MSEL4CR_MSEL15_1), + PINMUX_DATA(MCP_D2_MCP_NAF2_MARK, PORT303_FN1), \ + PINMUX_DATA(MMCD1_2_MARK, PORT303_FN2, MSEL4CR_MSEL15_1), + PINMUX_DATA(MCP_D1_MCP_NAF1_MARK, PORT304_FN1), \ + PINMUX_DATA(MMCD1_1_MARK, PORT304_FN2, MSEL4CR_MSEL15_1), + PINMUX_DATA(MCP_D0_MCP_NAF0_MARK, PORT305_FN1), \ + PINMUX_DATA(MMCD1_0_MARK, PORT305_FN2, MSEL4CR_MSEL15_1), + PINMUX_DATA(MCP_NBRSTOUT__MARK, PORT306_FN1), + PINMUX_DATA(MCP_WE0__MCP_FWE_MARK, PORT309_FN1), \ + PINMUX_DATA(MCP_RDWR_MCP_FWE_MARK, PORT309_FN2), + + /* MSEL2 special cases */ + PINMUX_DATA(TSIF2_TS_XX1_MARK, MSEL2CR_MSEL14_0, MSEL2CR_MSEL13_0, + MSEL2CR_MSEL12_0), + PINMUX_DATA(TSIF2_TS_XX2_MARK, MSEL2CR_MSEL14_0, MSEL2CR_MSEL13_0, + MSEL2CR_MSEL12_1), + PINMUX_DATA(TSIF2_TS_XX3_MARK, MSEL2CR_MSEL14_0, MSEL2CR_MSEL13_1, + MSEL2CR_MSEL12_0), + PINMUX_DATA(TSIF2_TS_XX4_MARK, MSEL2CR_MSEL14_0, MSEL2CR_MSEL13_1, + MSEL2CR_MSEL12_1), + PINMUX_DATA(TSIF2_TS_XX5_MARK, MSEL2CR_MSEL14_1, MSEL2CR_MSEL13_0, + MSEL2CR_MSEL12_0), + PINMUX_DATA(TSIF1_TS_XX1_MARK, MSEL2CR_MSEL11_0, MSEL2CR_MSEL10_0, + MSEL2CR_MSEL9_0), + PINMUX_DATA(TSIF1_TS_XX2_MARK, MSEL2CR_MSEL11_0, MSEL2CR_MSEL10_0, + MSEL2CR_MSEL9_1), + PINMUX_DATA(TSIF1_TS_XX3_MARK, MSEL2CR_MSEL11_0, MSEL2CR_MSEL10_1, + MSEL2CR_MSEL9_0), + PINMUX_DATA(TSIF1_TS_XX4_MARK, MSEL2CR_MSEL11_0, MSEL2CR_MSEL10_1, + MSEL2CR_MSEL9_1), + PINMUX_DATA(TSIF1_TS_XX5_MARK, MSEL2CR_MSEL11_1, MSEL2CR_MSEL10_0, + MSEL2CR_MSEL9_0), + PINMUX_DATA(TSIF0_TS_XX1_MARK, MSEL2CR_MSEL8_0, MSEL2CR_MSEL7_0, + MSEL2CR_MSEL6_0), + PINMUX_DATA(TSIF0_TS_XX2_MARK, MSEL2CR_MSEL8_0, MSEL2CR_MSEL7_0, + MSEL2CR_MSEL6_1), + PINMUX_DATA(TSIF0_TS_XX3_MARK, MSEL2CR_MSEL8_0, MSEL2CR_MSEL7_1, + MSEL2CR_MSEL6_0), + PINMUX_DATA(TSIF0_TS_XX4_MARK, MSEL2CR_MSEL8_0, MSEL2CR_MSEL7_1, + MSEL2CR_MSEL6_1), + PINMUX_DATA(TSIF0_TS_XX5_MARK, MSEL2CR_MSEL8_1, MSEL2CR_MSEL7_0, + MSEL2CR_MSEL6_0), + PINMUX_DATA(MST1_TS_XX1_MARK, MSEL2CR_MSEL5_0, MSEL2CR_MSEL4_0, + MSEL2CR_MSEL3_0), + PINMUX_DATA(MST1_TS_XX2_MARK, MSEL2CR_MSEL5_0, MSEL2CR_MSEL4_0, + MSEL2CR_MSEL3_1), + PINMUX_DATA(MST1_TS_XX3_MARK, MSEL2CR_MSEL5_0, MSEL2CR_MSEL4_1, + MSEL2CR_MSEL3_0), + PINMUX_DATA(MST1_TS_XX4_MARK, MSEL2CR_MSEL5_0, MSEL2CR_MSEL4_1, + MSEL2CR_MSEL3_1), + PINMUX_DATA(MST1_TS_XX5_MARK, MSEL2CR_MSEL5_1, MSEL2CR_MSEL4_0, + MSEL2CR_MSEL3_0), + PINMUX_DATA(MST0_TS_XX1_MARK, MSEL2CR_MSEL2_0, MSEL2CR_MSEL1_0, + MSEL2CR_MSEL0_0), + PINMUX_DATA(MST0_TS_XX2_MARK, MSEL2CR_MSEL2_0, MSEL2CR_MSEL1_0, + MSEL2CR_MSEL0_1), + PINMUX_DATA(MST0_TS_XX3_MARK, MSEL2CR_MSEL2_0, MSEL2CR_MSEL1_1, + MSEL2CR_MSEL0_0), + PINMUX_DATA(MST0_TS_XX4_MARK, MSEL2CR_MSEL2_0, MSEL2CR_MSEL1_1, + MSEL2CR_MSEL0_1), + PINMUX_DATA(MST0_TS_XX5_MARK, MSEL2CR_MSEL2_1, MSEL2CR_MSEL1_0, + MSEL2CR_MSEL0_0), + + /* MSEL3 special cases */ + PINMUX_DATA(SDHI0_VCCQ_MC0_ON_MARK, MSEL3CR_MSEL28_1), + PINMUX_DATA(SDHI0_VCCQ_MC0_OFF_MARK, MSEL3CR_MSEL28_0), + PINMUX_DATA(DEBUG_MON_VIO_MARK, MSEL3CR_MSEL15_0), + PINMUX_DATA(DEBUG_MON_LCDD_MARK, MSEL3CR_MSEL15_1), + PINMUX_DATA(LCDC_LCDC0_MARK, MSEL3CR_MSEL6_0), + PINMUX_DATA(LCDC_LCDC1_MARK, MSEL3CR_MSEL6_1), + + /* MSEL4 special cases */ + PINMUX_DATA(IRQ9_MEM_INT_MARK, MSEL4CR_MSEL29_0), + PINMUX_DATA(IRQ9_MCP_INT_MARK, MSEL4CR_MSEL29_1), + PINMUX_DATA(A11_MARK, MSEL4CR_MSEL13_0, MSEL4CR_MSEL12_0), + PINMUX_DATA(KEYOUT8_MARK, MSEL4CR_MSEL13_0, MSEL4CR_MSEL12_1), + PINMUX_DATA(TPU4TO3_MARK, MSEL4CR_MSEL13_1, MSEL4CR_MSEL12_0), + PINMUX_DATA(RESETA_N_PU_ON_MARK, MSEL4CR_MSEL4_0), + PINMUX_DATA(RESETA_N_PU_OFF_MARK, MSEL4CR_MSEL4_1), + PINMUX_DATA(EDBGREQ_PD_MARK, MSEL4CR_MSEL1_0), + PINMUX_DATA(EDBGREQ_PU_MARK, MSEL4CR_MSEL1_1), + + /* Functions with pull-ups */ + PINMUX_DATA(KEYIN0_PU_MARK, PORT66_FN2, PORT66_IN_PU), + PINMUX_DATA(KEYIN1_PU_MARK, PORT67_FN2, PORT67_IN_PU), + PINMUX_DATA(KEYIN2_PU_MARK, PORT68_FN2, PORT68_IN_PU), + PINMUX_DATA(KEYIN3_PU_MARK, PORT69_FN2, PORT69_IN_PU), + PINMUX_DATA(KEYIN4_PU_MARK, PORT70_FN2, PORT70_IN_PU), + PINMUX_DATA(KEYIN5_PU_MARK, PORT71_FN2, PORT71_IN_PU), + PINMUX_DATA(KEYIN6_PU_MARK, PORT72_FN2, PORT72_IN_PU), + PINMUX_DATA(KEYIN7_PU_MARK, PORT73_FN2, PORT73_IN_PU), + + PINMUX_DATA(SDHICD0_PU_MARK, PORT251_FN1, PORT251_IN_PU), + PINMUX_DATA(SDHID0_0_PU_MARK, PORT252_FN1, PORT252_IN_PU), + PINMUX_DATA(SDHID0_1_PU_MARK, PORT253_FN1, PORT253_IN_PU), + PINMUX_DATA(SDHID0_2_PU_MARK, PORT254_FN1, PORT254_IN_PU), + PINMUX_DATA(SDHID0_3_PU_MARK, PORT255_FN1, PORT255_IN_PU), + PINMUX_DATA(SDHICMD0_PU_MARK, PORT256_FN1, PORT256_IN_PU), + PINMUX_DATA(SDHIWP0_PU_MARK, PORT257_FN1, PORT256_IN_PU), + PINMUX_DATA(SDHID1_0_PU_MARK, PORT259_FN1, PORT259_IN_PU), + PINMUX_DATA(SDHID1_1_PU_MARK, PORT260_FN1, PORT260_IN_PU), + PINMUX_DATA(SDHID1_2_PU_MARK, PORT261_FN1, PORT261_IN_PU), + PINMUX_DATA(SDHID1_3_PU_MARK, PORT262_FN1, PORT262_IN_PU), + PINMUX_DATA(SDHICMD1_PU_MARK, PORT263_FN1, PORT263_IN_PU), + PINMUX_DATA(SDHID2_0_PU_MARK, PORT265_FN1, PORT265_IN_PU), + PINMUX_DATA(SDHID2_1_PU_MARK, PORT266_FN1, PORT266_IN_PU), + PINMUX_DATA(SDHID2_2_PU_MARK, PORT267_FN1, PORT267_IN_PU), + PINMUX_DATA(SDHID2_3_PU_MARK, PORT268_FN1, PORT268_IN_PU), + PINMUX_DATA(SDHICMD2_PU_MARK, PORT269_FN1, PORT269_IN_PU), + + PINMUX_DATA(MMCCMD0_PU_MARK, PORT279_FN1, PORT279_IN_PU, + MSEL4CR_MSEL15_0), + PINMUX_DATA(MMCCMD1_PU_MARK, PORT297_FN2, PORT297_IN_PU, + MSEL4CR_MSEL15_1), + + PINMUX_DATA(MMCD0_0_PU_MARK, + PORT271_FN1, PORT271_IN_PU, MSEL4CR_MSEL15_0), + PINMUX_DATA(MMCD0_1_PU_MARK, + PORT272_FN1, PORT272_IN_PU, MSEL4CR_MSEL15_0), + PINMUX_DATA(MMCD0_2_PU_MARK, + PORT273_FN1, PORT273_IN_PU, MSEL4CR_MSEL15_0), + PINMUX_DATA(MMCD0_3_PU_MARK, + PORT274_FN1, PORT274_IN_PU, MSEL4CR_MSEL15_0), + PINMUX_DATA(MMCD0_4_PU_MARK, + PORT275_FN1, PORT275_IN_PU, MSEL4CR_MSEL15_0), + PINMUX_DATA(MMCD0_5_PU_MARK, + PORT276_FN1, PORT276_IN_PU, MSEL4CR_MSEL15_0), + PINMUX_DATA(MMCD0_6_PU_MARK, + PORT277_FN1, PORT277_IN_PU, MSEL4CR_MSEL15_0), + PINMUX_DATA(MMCD0_7_PU_MARK, + PORT278_FN1, PORT278_IN_PU, MSEL4CR_MSEL15_0), + + PINMUX_DATA(FSIBISLD_PU_MARK, PORT39_FN1, PORT39_IN_PU), + PINMUX_DATA(FSIACK_PU_MARK, PORT49_FN1, PORT49_IN_PU), + PINMUX_DATA(FSIAILR_PU_MARK, PORT50_FN5, PORT50_IN_PU), + PINMUX_DATA(FSIAIBT_PU_MARK, PORT51_FN5, PORT51_IN_PU), + PINMUX_DATA(FSIAISLD_PU_MARK, PORT55_FN1, PORT55_IN_PU), +}; + +static struct pinmux_gpio pinmux_gpios[] = { + GPIO_PORT_ALL(), + + /* Table 25-1 (Functions 0-7) */ + GPIO_FN(VBUS_0), + GPIO_FN(GPI0), + GPIO_FN(GPI1), + GPIO_FN(GPI2), + GPIO_FN(GPI3), + GPIO_FN(GPI4), + GPIO_FN(GPI5), + GPIO_FN(GPI6), + GPIO_FN(GPI7), + GPIO_FN(SCIFA7_RXD), + GPIO_FN(SCIFA7_CTS_), + GPIO_FN(GPO7), \ + GPIO_FN(MFG0_OUT2), + GPIO_FN(GPO6), \ + GPIO_FN(MFG1_OUT2), + GPIO_FN(GPO5), \ + GPIO_FN(SCIFA0_SCK), \ + GPIO_FN(FSICOSLDT3), \ + GPIO_FN(PORT16_VIO_CKOR), + GPIO_FN(SCIFA0_TXD), + GPIO_FN(SCIFA7_TXD), + GPIO_FN(SCIFA7_RTS_), \ + GPIO_FN(PORT19_VIO_CKO2), + GPIO_FN(GPO0), + GPIO_FN(GPO1), + GPIO_FN(GPO2), \ + GPIO_FN(STATUS0), + GPIO_FN(GPO3), \ + GPIO_FN(STATUS1), + GPIO_FN(GPO4), \ + GPIO_FN(STATUS2), + GPIO_FN(VINT), + GPIO_FN(TCKON), + GPIO_FN(XDVFS1), \ + GPIO_FN(PORT27_I2C_SCL2), \ + GPIO_FN(PORT27_I2C_SCL3), \ + GPIO_FN(MFG0_OUT1), \ + GPIO_FN(PORT27_IROUT), + GPIO_FN(XDVFS2), \ + GPIO_FN(PORT28_I2C_SDA2), \ + GPIO_FN(PORT28_I2C_SDA3), \ + GPIO_FN(PORT28_TPU1TO1), + GPIO_FN(SIM_RST), \ + GPIO_FN(PORT29_TPU1TO1), + GPIO_FN(SIM_CLK), \ + GPIO_FN(PORT30_VIO_CKOR), + GPIO_FN(SIM_D), \ + GPIO_FN(PORT31_IROUT), + GPIO_FN(SCIFA4_TXD), + GPIO_FN(SCIFA4_RXD), \ + GPIO_FN(XWUP), + GPIO_FN(SCIFA4_RTS_), + GPIO_FN(SCIFA4_CTS_), + GPIO_FN(FSIBOBT), \ + GPIO_FN(FSIBIBT), + GPIO_FN(FSIBOLR), \ + GPIO_FN(FSIBILR), + GPIO_FN(FSIBOSLD), + GPIO_FN(FSIBISLD), + GPIO_FN(VACK), + GPIO_FN(XTAL1L), + GPIO_FN(SCIFA0_RTS_), \ + GPIO_FN(FSICOSLDT2), + GPIO_FN(SCIFA0_RXD), + GPIO_FN(SCIFA0_CTS_), \ + GPIO_FN(FSICOSLDT1), + GPIO_FN(FSICOBT), \ + GPIO_FN(FSICIBT), \ + GPIO_FN(FSIDOBT), \ + GPIO_FN(FSIDIBT), + GPIO_FN(FSICOLR), \ + GPIO_FN(FSICILR), \ + GPIO_FN(FSIDOLR), \ + GPIO_FN(FSIDILR), + GPIO_FN(FSICOSLD), \ + GPIO_FN(PORT47_FSICSPDIF), + GPIO_FN(FSICISLD), \ + GPIO_FN(FSIDISLD), + GPIO_FN(FSIACK), \ + GPIO_FN(PORT49_IRDA_OUT), \ + GPIO_FN(PORT49_IROUT), \ + GPIO_FN(FSIAOMC), + GPIO_FN(FSIAOLR), \ + GPIO_FN(BBIF2_TSYNC2), \ + GPIO_FN(TPU2TO2), \ + GPIO_FN(FSIAILR), + + GPIO_FN(FSIAOBT), \ + GPIO_FN(BBIF2_TSCK2), \ + GPIO_FN(TPU2TO3), \ + GPIO_FN(FSIAIBT), + GPIO_FN(FSIAOSLD), \ + GPIO_FN(BBIF2_TXD2), + GPIO_FN(FSIASPDIF), \ + GPIO_FN(PORT53_IRDA_IN), \ + GPIO_FN(TPU3TO3), \ + GPIO_FN(FSIBSPDIF), \ + GPIO_FN(PORT53_FSICSPDIF), + GPIO_FN(FSIBCK), \ + GPIO_FN(PORT54_IRDA_FIRSEL), \ + GPIO_FN(TPU3TO2), \ + GPIO_FN(FSIBOMC), \ + GPIO_FN(FSICCK), \ + GPIO_FN(FSICOMC), + GPIO_FN(FSIAISLD), \ + GPIO_FN(TPU0TO0), + GPIO_FN(A0), \ + GPIO_FN(BS_), + GPIO_FN(A12), \ + GPIO_FN(PORT58_KEYOUT7), \ + GPIO_FN(TPU4TO2), + GPIO_FN(A13), \ + GPIO_FN(PORT59_KEYOUT6), \ + GPIO_FN(TPU0TO1), + GPIO_FN(A14), \ + GPIO_FN(KEYOUT5), + GPIO_FN(A15), \ + GPIO_FN(KEYOUT4), + GPIO_FN(A16), \ + GPIO_FN(KEYOUT3), \ + GPIO_FN(MSIOF0_SS1), + GPIO_FN(A17), \ + GPIO_FN(KEYOUT2), \ + GPIO_FN(MSIOF0_TSYNC), + GPIO_FN(A18), \ + GPIO_FN(KEYOUT1), \ + GPIO_FN(MSIOF0_TSCK), + GPIO_FN(A19), \ + GPIO_FN(KEYOUT0), \ + GPIO_FN(MSIOF0_TXD), + GPIO_FN(A20), \ + GPIO_FN(KEYIN0), \ + GPIO_FN(MSIOF0_RSCK), + GPIO_FN(A21), \ + GPIO_FN(KEYIN1), \ + GPIO_FN(MSIOF0_RSYNC), + GPIO_FN(A22), \ + GPIO_FN(KEYIN2), \ + GPIO_FN(MSIOF0_MCK0), + GPIO_FN(A23), \ + GPIO_FN(KEYIN3), \ + GPIO_FN(MSIOF0_MCK1), + GPIO_FN(A24), \ + GPIO_FN(KEYIN4), \ + GPIO_FN(MSIOF0_RXD), + GPIO_FN(A25), \ + GPIO_FN(KEYIN5), \ + GPIO_FN(MSIOF0_SS2), + GPIO_FN(A26), \ + GPIO_FN(KEYIN6), + GPIO_FN(KEYIN7), + GPIO_FN(D0_NAF0), + GPIO_FN(D1_NAF1), + GPIO_FN(D2_NAF2), + GPIO_FN(D3_NAF3), + GPIO_FN(D4_NAF4), + GPIO_FN(D5_NAF5), + GPIO_FN(D6_NAF6), + GPIO_FN(D7_NAF7), + GPIO_FN(D8_NAF8), + GPIO_FN(D9_NAF9), + GPIO_FN(D10_NAF10), + GPIO_FN(D11_NAF11), + GPIO_FN(D12_NAF12), + GPIO_FN(D13_NAF13), + GPIO_FN(D14_NAF14), + GPIO_FN(D15_NAF15), + GPIO_FN(CS4_), + GPIO_FN(CS5A_), \ + GPIO_FN(PORT91_RDWR), + GPIO_FN(CS5B_), \ + GPIO_FN(FCE1_), + GPIO_FN(CS6B_), \ + GPIO_FN(DACK0), + GPIO_FN(FCE0_), \ + GPIO_FN(CS6A_), + GPIO_FN(WAIT_), \ + GPIO_FN(DREQ0), + GPIO_FN(RD__FSC), + GPIO_FN(WE0__FWE), \ + GPIO_FN(RDWR_FWE), + GPIO_FN(WE1_), + GPIO_FN(FRB), + GPIO_FN(CKO), + GPIO_FN(NBRSTOUT_), + GPIO_FN(NBRST_), + GPIO_FN(BBIF2_TXD), + GPIO_FN(BBIF2_RXD), + GPIO_FN(BBIF2_SYNC), + GPIO_FN(BBIF2_SCK), + GPIO_FN(SCIFA3_CTS_), \ + GPIO_FN(MFG3_IN2), + GPIO_FN(SCIFA3_RXD), \ + GPIO_FN(MFG3_IN1), + GPIO_FN(BBIF1_SS2), \ + GPIO_FN(SCIFA3_RTS_), \ + GPIO_FN(MFG3_OUT1), + GPIO_FN(SCIFA3_TXD), + GPIO_FN(HSI_RX_DATA), \ + GPIO_FN(BBIF1_RXD), + GPIO_FN(HSI_TX_WAKE), \ + GPIO_FN(BBIF1_TSCK), + GPIO_FN(HSI_TX_DATA), \ + GPIO_FN(BBIF1_TSYNC), + GPIO_FN(HSI_TX_READY), \ + GPIO_FN(BBIF1_TXD), + GPIO_FN(HSI_RX_READY), \ + GPIO_FN(BBIF1_RSCK), \ + GPIO_FN(PORT115_I2C_SCL2), \ + GPIO_FN(PORT115_I2C_SCL3), + GPIO_FN(HSI_RX_WAKE), \ + GPIO_FN(BBIF1_RSYNC), \ + GPIO_FN(PORT116_I2C_SDA2), \ + GPIO_FN(PORT116_I2C_SDA3), + GPIO_FN(HSI_RX_FLAG), \ + GPIO_FN(BBIF1_SS1), \ + GPIO_FN(BBIF1_FLOW), + GPIO_FN(HSI_TX_FLAG), + GPIO_FN(VIO_VD), \ + GPIO_FN(PORT128_LCD2VSYN), \ + GPIO_FN(VIO2_VD), \ + GPIO_FN(LCD2D0), + + GPIO_FN(VIO_HD), \ + GPIO_FN(PORT129_LCD2HSYN), \ + GPIO_FN(PORT129_LCD2CS_), \ + GPIO_FN(VIO2_HD), \ + GPIO_FN(LCD2D1), + GPIO_FN(VIO_D0), \ + GPIO_FN(PORT130_MSIOF2_RXD), \ + GPIO_FN(LCD2D10), + GPIO_FN(VIO_D1), \ + GPIO_FN(PORT131_KEYOUT6), \ + GPIO_FN(PORT131_MSIOF2_SS1), \ + GPIO_FN(PORT131_KEYOUT11), \ + GPIO_FN(LCD2D11), + GPIO_FN(VIO_D2), \ + GPIO_FN(PORT132_KEYOUT7), \ + GPIO_FN(PORT132_MSIOF2_SS2), \ + GPIO_FN(PORT132_KEYOUT10), \ + GPIO_FN(LCD2D12), + GPIO_FN(VIO_D3), \ + GPIO_FN(MSIOF2_TSYNC), \ + GPIO_FN(LCD2D13), + GPIO_FN(VIO_D4), \ + GPIO_FN(MSIOF2_TXD), \ + GPIO_FN(LCD2D14), + GPIO_FN(VIO_D5), \ + GPIO_FN(MSIOF2_TSCK), \ + GPIO_FN(LCD2D15), + GPIO_FN(VIO_D6), \ + GPIO_FN(PORT136_KEYOUT8), \ + GPIO_FN(LCD2D16), + GPIO_FN(VIO_D7), \ + GPIO_FN(PORT137_KEYOUT9), \ + GPIO_FN(LCD2D17), + GPIO_FN(VIO_D8), \ + GPIO_FN(PORT138_KEYOUT8), \ + GPIO_FN(VIO2_D0), \ + GPIO_FN(LCD2D6), + GPIO_FN(VIO_D9), \ + GPIO_FN(PORT139_KEYOUT9), \ + GPIO_FN(VIO2_D1), \ + GPIO_FN(LCD2D7), + GPIO_FN(VIO_D10), \ + GPIO_FN(TPU0TO2), \ + GPIO_FN(VIO2_D2), \ + GPIO_FN(LCD2D8), + GPIO_FN(VIO_D11), \ + GPIO_FN(TPU0TO3), \ + GPIO_FN(VIO2_D3), \ + GPIO_FN(LCD2D9), + GPIO_FN(VIO_D12), \ + GPIO_FN(PORT142_KEYOUT10), \ + GPIO_FN(VIO2_D4), \ + GPIO_FN(LCD2D2), + GPIO_FN(VIO_D13), \ + GPIO_FN(PORT143_KEYOUT11), \ + GPIO_FN(PORT143_KEYOUT6), \ + GPIO_FN(VIO2_D5), \ + GPIO_FN(LCD2D3), + GPIO_FN(VIO_D14), \ + GPIO_FN(PORT144_KEYOUT7), \ + GPIO_FN(VIO2_D6), \ + GPIO_FN(LCD2D4), + GPIO_FN(VIO_D15), \ + GPIO_FN(TPU1TO3), \ + GPIO_FN(PORT145_LCD2DISP), \ + GPIO_FN(PORT145_LCD2RS), \ + GPIO_FN(VIO2_D7), \ + GPIO_FN(LCD2D5), + GPIO_FN(VIO_CLK), \ + GPIO_FN(LCD2DCK), \ + GPIO_FN(PORT146_LCD2WR_), \ + GPIO_FN(VIO2_CLK), \ + GPIO_FN(LCD2D18), + GPIO_FN(VIO_FIELD), \ + GPIO_FN(LCD2RD_), \ + GPIO_FN(VIO2_FIELD), \ + GPIO_FN(LCD2D19), + GPIO_FN(VIO_CKO), + GPIO_FN(A27), \ + GPIO_FN(PORT149_RDWR), \ + GPIO_FN(MFG0_IN1), \ + GPIO_FN(PORT149_KEYOUT9), + GPIO_FN(MFG0_IN2), + GPIO_FN(TS_SPSYNC3), \ + GPIO_FN(MSIOF2_RSCK), + GPIO_FN(TS_SDAT3), \ + GPIO_FN(MSIOF2_RSYNC), + GPIO_FN(TPU1TO2), \ + GPIO_FN(TS_SDEN3), \ + GPIO_FN(PORT153_MSIOF2_SS1), + GPIO_FN(SCIFA2_TXD1), \ + GPIO_FN(MSIOF2_MCK0), + GPIO_FN(SCIFA2_RXD1), \ + GPIO_FN(MSIOF2_MCK1), + GPIO_FN(SCIFA2_RTS1_), \ + GPIO_FN(PORT156_MSIOF2_SS2), + GPIO_FN(SCIFA2_CTS1_), \ + GPIO_FN(PORT157_MSIOF2_RXD), + GPIO_FN(DINT_), \ + GPIO_FN(SCIFA2_SCK1), \ + GPIO_FN(TS_SCK3), + GPIO_FN(PORT159_SCIFB_SCK), \ + GPIO_FN(PORT159_SCIFA5_SCK), \ + GPIO_FN(NMI), + GPIO_FN(PORT160_SCIFB_TXD), \ + GPIO_FN(PORT160_SCIFA5_TXD), + GPIO_FN(PORT161_SCIFB_CTS_), \ + GPIO_FN(PORT161_SCIFA5_CTS_), + GPIO_FN(PORT162_SCIFB_RXD), \ + GPIO_FN(PORT162_SCIFA5_RXD), + GPIO_FN(PORT163_SCIFB_RTS_), \ + GPIO_FN(PORT163_SCIFA5_RTS_), \ + GPIO_FN(TPU3TO0), + GPIO_FN(LCDD0), + GPIO_FN(LCDD1), \ + GPIO_FN(PORT193_SCIFA5_CTS_), \ + GPIO_FN(BBIF2_TSYNC1), + GPIO_FN(LCDD2), \ + GPIO_FN(PORT194_SCIFA5_RTS_), \ + GPIO_FN(BBIF2_TSCK1), + GPIO_FN(LCDD3), \ + GPIO_FN(PORT195_SCIFA5_RXD), \ + GPIO_FN(BBIF2_TXD1), + GPIO_FN(LCDD4), \ + GPIO_FN(PORT196_SCIFA5_TXD), + GPIO_FN(LCDD5), \ + GPIO_FN(PORT197_SCIFA5_SCK), \ + GPIO_FN(MFG2_OUT2), \ + GPIO_FN(TPU2TO1), + GPIO_FN(LCDD6), + GPIO_FN(LCDD7), \ + GPIO_FN(TPU4TO1), \ + GPIO_FN(MFG4_OUT2), + GPIO_FN(LCDD8), \ + GPIO_FN(D16), + GPIO_FN(LCDD9), \ + GPIO_FN(D17), + GPIO_FN(LCDD10), \ + GPIO_FN(D18), + GPIO_FN(LCDD11), \ + GPIO_FN(D19), + GPIO_FN(LCDD12), \ + GPIO_FN(D20), + GPIO_FN(LCDD13), \ + GPIO_FN(D21), + GPIO_FN(LCDD14), \ + GPIO_FN(D22), + GPIO_FN(LCDD15), \ + GPIO_FN(PORT207_MSIOF0L_SS1), \ + GPIO_FN(D23), + GPIO_FN(LCDD16), \ + GPIO_FN(PORT208_MSIOF0L_SS2), \ + GPIO_FN(D24), + GPIO_FN(LCDD17), \ + GPIO_FN(D25), + GPIO_FN(LCDD18), \ + GPIO_FN(DREQ2), \ + GPIO_FN(PORT210_MSIOF0L_SS1), \ + GPIO_FN(D26), + GPIO_FN(LCDD19), \ + GPIO_FN(PORT211_MSIOF0L_SS2), \ + GPIO_FN(D27), + GPIO_FN(LCDD20), \ + GPIO_FN(TS_SPSYNC1), \ + GPIO_FN(MSIOF0L_MCK0), \ + GPIO_FN(D28), + GPIO_FN(LCDD21), \ + GPIO_FN(TS_SDAT1), \ + GPIO_FN(MSIOF0L_MCK1), \ + GPIO_FN(D29), + GPIO_FN(LCDD22), \ + GPIO_FN(TS_SDEN1), \ + GPIO_FN(MSIOF0L_RSCK), \ + GPIO_FN(D30), + GPIO_FN(LCDD23), \ + GPIO_FN(TS_SCK1), \ + GPIO_FN(MSIOF0L_RSYNC), \ + GPIO_FN(D31), + GPIO_FN(LCDDCK), \ + GPIO_FN(LCDWR_), + GPIO_FN(LCDRD_), \ + GPIO_FN(DACK2), \ + GPIO_FN(PORT217_LCD2RS), \ + GPIO_FN(MSIOF0L_TSYNC), \ + GPIO_FN(VIO2_FIELD3), \ + GPIO_FN(PORT217_LCD2DISP), + GPIO_FN(LCDHSYN), \ + GPIO_FN(LCDCS_), \ + GPIO_FN(LCDCS2_), \ + GPIO_FN(DACK3), \ + GPIO_FN(PORT218_VIO_CKOR), + GPIO_FN(LCDDISP), \ + GPIO_FN(LCDRS), \ + GPIO_FN(PORT219_LCD2WR_), \ + GPIO_FN(DREQ3), \ + GPIO_FN(MSIOF0L_TSCK), \ + GPIO_FN(VIO2_CLK3), \ + GPIO_FN(LCD2DCK_2), + GPIO_FN(LCDVSYN), \ + GPIO_FN(LCDVSYN2), + GPIO_FN(LCDLCLK), \ + GPIO_FN(DREQ1), \ + GPIO_FN(PORT221_LCD2CS_), \ + GPIO_FN(PWEN), \ + GPIO_FN(MSIOF0L_RXD), \ + GPIO_FN(VIO2_HD3), \ + GPIO_FN(PORT221_LCD2HSYN), + GPIO_FN(LCDDON), \ + GPIO_FN(LCDDON2), \ + GPIO_FN(DACK1), \ + GPIO_FN(OVCN), \ + GPIO_FN(MSIOF0L_TXD), \ + GPIO_FN(VIO2_VD3), \ + GPIO_FN(PORT222_LCD2VSYN), + + GPIO_FN(SCIFA1_TXD), \ + GPIO_FN(OVCN2), + GPIO_FN(EXTLP), \ + GPIO_FN(SCIFA1_SCK), \ + GPIO_FN(PORT226_VIO_CKO2), + GPIO_FN(SCIFA1_RTS_), \ + GPIO_FN(IDIN), + GPIO_FN(SCIFA1_RXD), + GPIO_FN(SCIFA1_CTS_), \ + GPIO_FN(MFG1_IN1), + GPIO_FN(MSIOF1_TXD), \ + GPIO_FN(SCIFA2_TXD2), + GPIO_FN(MSIOF1_TSYNC), \ + GPIO_FN(SCIFA2_CTS2_), + GPIO_FN(MSIOF1_TSCK), \ + GPIO_FN(SCIFA2_SCK2), + GPIO_FN(MSIOF1_RXD), \ + GPIO_FN(SCIFA2_RXD2), + GPIO_FN(MSIOF1_RSCK), \ + GPIO_FN(SCIFA2_RTS2_), \ + GPIO_FN(VIO2_CLK2), \ + GPIO_FN(LCD2D20), + GPIO_FN(MSIOF1_RSYNC), \ + GPIO_FN(MFG1_IN2), \ + GPIO_FN(VIO2_VD2), \ + GPIO_FN(LCD2D21), + GPIO_FN(MSIOF1_MCK0), \ + GPIO_FN(PORT236_I2C_SDA2), + GPIO_FN(MSIOF1_MCK1), \ + GPIO_FN(PORT237_I2C_SCL2), + GPIO_FN(MSIOF1_SS1), \ + GPIO_FN(VIO2_FIELD2), \ + GPIO_FN(LCD2D22), + GPIO_FN(MSIOF1_SS2), \ + GPIO_FN(VIO2_HD2), \ + GPIO_FN(LCD2D23), + GPIO_FN(SCIFA6_TXD), + GPIO_FN(PORT241_IRDA_OUT), \ + GPIO_FN(PORT241_IROUT), \ + GPIO_FN(MFG4_OUT1), \ + GPIO_FN(TPU4TO0), + GPIO_FN(PORT242_IRDA_IN), \ + GPIO_FN(MFG4_IN2), + GPIO_FN(PORT243_IRDA_FIRSEL), \ + GPIO_FN(PORT243_VIO_CKO2), + GPIO_FN(PORT244_SCIFA5_CTS_), \ + GPIO_FN(MFG2_IN1), \ + GPIO_FN(PORT244_SCIFB_CTS_), \ + GPIO_FN(MSIOF2R_RXD), + GPIO_FN(PORT245_SCIFA5_RTS_), \ + GPIO_FN(MFG2_IN2), \ + GPIO_FN(PORT245_SCIFB_RTS_), \ + GPIO_FN(MSIOF2R_TXD), + GPIO_FN(PORT246_SCIFA5_RXD), \ + GPIO_FN(MFG1_OUT1), \ + GPIO_FN(PORT246_SCIFB_RXD), \ + GPIO_FN(TPU1TO0), + GPIO_FN(PORT247_SCIFA5_TXD), \ + GPIO_FN(MFG3_OUT2), \ + GPIO_FN(PORT247_SCIFB_TXD), \ + GPIO_FN(TPU3TO1), + GPIO_FN(PORT248_SCIFA5_SCK), \ + GPIO_FN(MFG2_OUT1), \ + GPIO_FN(PORT248_SCIFB_SCK), \ + GPIO_FN(TPU2TO0), \ + GPIO_FN(PORT248_I2C_SCL3), \ + GPIO_FN(MSIOF2R_TSCK), + GPIO_FN(PORT249_IROUT), \ + GPIO_FN(MFG4_IN1), \ + GPIO_FN(PORT249_I2C_SDA3), \ + GPIO_FN(MSIOF2R_TSYNC), + GPIO_FN(SDHICLK0), + GPIO_FN(SDHICD0), + GPIO_FN(SDHID0_0), + GPIO_FN(SDHID0_1), + GPIO_FN(SDHID0_2), + GPIO_FN(SDHID0_3), + GPIO_FN(SDHICMD0), + GPIO_FN(SDHIWP0), + GPIO_FN(SDHICLK1), + GPIO_FN(SDHID1_0), \ + GPIO_FN(TS_SPSYNC2), + GPIO_FN(SDHID1_1), \ + GPIO_FN(TS_SDAT2), + GPIO_FN(SDHID1_2), \ + GPIO_FN(TS_SDEN2), + GPIO_FN(SDHID1_3), \ + GPIO_FN(TS_SCK2), + GPIO_FN(SDHICMD1), + GPIO_FN(SDHICLK2), + GPIO_FN(SDHID2_0), \ + GPIO_FN(TS_SPSYNC4), + GPIO_FN(SDHID2_1), \ + GPIO_FN(TS_SDAT4), + GPIO_FN(SDHID2_2), \ + GPIO_FN(TS_SDEN4), + GPIO_FN(SDHID2_3), \ + GPIO_FN(TS_SCK4), + GPIO_FN(SDHICMD2), + GPIO_FN(MMCCLK0), + GPIO_FN(MMCD0_0), + GPIO_FN(MMCD0_1), + GPIO_FN(MMCD0_2), + GPIO_FN(MMCD0_3), + GPIO_FN(MMCD0_4), \ + GPIO_FN(TS_SPSYNC5), + GPIO_FN(MMCD0_5), \ + GPIO_FN(TS_SDAT5), + GPIO_FN(MMCD0_6), \ + GPIO_FN(TS_SDEN5), + GPIO_FN(MMCD0_7), \ + GPIO_FN(TS_SCK5), + GPIO_FN(MMCCMD0), + GPIO_FN(RESETOUTS_), \ + GPIO_FN(EXTAL2OUT), + GPIO_FN(MCP_WAIT__MCP_FRB), + GPIO_FN(MCP_CKO), \ + GPIO_FN(MMCCLK1), + GPIO_FN(MCP_D15_MCP_NAF15), + GPIO_FN(MCP_D14_MCP_NAF14), + GPIO_FN(MCP_D13_MCP_NAF13), + GPIO_FN(MCP_D12_MCP_NAF12), + GPIO_FN(MCP_D11_MCP_NAF11), + GPIO_FN(MCP_D10_MCP_NAF10), + GPIO_FN(MCP_D9_MCP_NAF9), + GPIO_FN(MCP_D8_MCP_NAF8), \ + GPIO_FN(MMCCMD1), + GPIO_FN(MCP_D7_MCP_NAF7), \ + GPIO_FN(MMCD1_7), + + GPIO_FN(MCP_D6_MCP_NAF6), \ + GPIO_FN(MMCD1_6), + GPIO_FN(MCP_D5_MCP_NAF5), \ + GPIO_FN(MMCD1_5), + GPIO_FN(MCP_D4_MCP_NAF4), \ + GPIO_FN(MMCD1_4), + GPIO_FN(MCP_D3_MCP_NAF3), \ + GPIO_FN(MMCD1_3), + GPIO_FN(MCP_D2_MCP_NAF2), \ + GPIO_FN(MMCD1_2), + GPIO_FN(MCP_D1_MCP_NAF1), \ + GPIO_FN(MMCD1_1), + GPIO_FN(MCP_D0_MCP_NAF0), \ + GPIO_FN(MMCD1_0), + GPIO_FN(MCP_NBRSTOUT_), + GPIO_FN(MCP_WE0__MCP_FWE), \ + GPIO_FN(MCP_RDWR_MCP_FWE), + + /* MSEL2 special cases */ + GPIO_FN(TSIF2_TS_XX1), + GPIO_FN(TSIF2_TS_XX2), + GPIO_FN(TSIF2_TS_XX3), + GPIO_FN(TSIF2_TS_XX4), + GPIO_FN(TSIF2_TS_XX5), + GPIO_FN(TSIF1_TS_XX1), + GPIO_FN(TSIF1_TS_XX2), + GPIO_FN(TSIF1_TS_XX3), + GPIO_FN(TSIF1_TS_XX4), + GPIO_FN(TSIF1_TS_XX5), + GPIO_FN(TSIF0_TS_XX1), + GPIO_FN(TSIF0_TS_XX2), + GPIO_FN(TSIF0_TS_XX3), + GPIO_FN(TSIF0_TS_XX4), + GPIO_FN(TSIF0_TS_XX5), + GPIO_FN(MST1_TS_XX1), + GPIO_FN(MST1_TS_XX2), + GPIO_FN(MST1_TS_XX3), + GPIO_FN(MST1_TS_XX4), + GPIO_FN(MST1_TS_XX5), + GPIO_FN(MST0_TS_XX1), + GPIO_FN(MST0_TS_XX2), + GPIO_FN(MST0_TS_XX3), + GPIO_FN(MST0_TS_XX4), + GPIO_FN(MST0_TS_XX5), + + /* MSEL3 special cases */ + GPIO_FN(SDHI0_VCCQ_MC0_ON), + GPIO_FN(SDHI0_VCCQ_MC0_OFF), + GPIO_FN(DEBUG_MON_VIO), + GPIO_FN(DEBUG_MON_LCDD), + GPIO_FN(LCDC_LCDC0), + GPIO_FN(LCDC_LCDC1), + + /* MSEL4 special cases */ + GPIO_FN(IRQ9_MEM_INT), + GPIO_FN(IRQ9_MCP_INT), + GPIO_FN(A11), + GPIO_FN(KEYOUT8), + GPIO_FN(TPU4TO3), + GPIO_FN(RESETA_N_PU_ON), + GPIO_FN(RESETA_N_PU_OFF), + GPIO_FN(EDBGREQ_PD), + GPIO_FN(EDBGREQ_PU), + + /* Functions with pull-ups */ + GPIO_FN(KEYIN0_PU), + GPIO_FN(KEYIN1_PU), + GPIO_FN(KEYIN2_PU), + GPIO_FN(KEYIN3_PU), + GPIO_FN(KEYIN4_PU), + GPIO_FN(KEYIN5_PU), + GPIO_FN(KEYIN6_PU), + GPIO_FN(KEYIN7_PU), + GPIO_FN(SDHICD0_PU), + GPIO_FN(SDHID0_0_PU), + GPIO_FN(SDHID0_1_PU), + GPIO_FN(SDHID0_2_PU), + GPIO_FN(SDHID0_3_PU), + GPIO_FN(SDHICMD0_PU), + GPIO_FN(SDHIWP0_PU), + GPIO_FN(SDHID1_0_PU), + GPIO_FN(SDHID1_1_PU), + GPIO_FN(SDHID1_2_PU), + GPIO_FN(SDHID1_3_PU), + GPIO_FN(SDHICMD1_PU), + GPIO_FN(SDHID2_0_PU), + GPIO_FN(SDHID2_1_PU), + GPIO_FN(SDHID2_2_PU), + GPIO_FN(SDHID2_3_PU), + GPIO_FN(SDHICMD2_PU), + GPIO_FN(MMCCMD0_PU), + GPIO_FN(MMCCMD1_PU), + GPIO_FN(MMCD0_0_PU), + GPIO_FN(MMCD0_1_PU), + GPIO_FN(MMCD0_2_PU), + GPIO_FN(MMCD0_3_PU), + GPIO_FN(MMCD0_4_PU), + GPIO_FN(MMCD0_5_PU), + GPIO_FN(MMCD0_6_PU), + GPIO_FN(MMCD0_7_PU), + GPIO_FN(FSIACK_PU), + GPIO_FN(FSIAILR_PU), + GPIO_FN(FSIAIBT_PU), + GPIO_FN(FSIAISLD_PU), +}; + +static struct pinmux_cfg_reg pinmux_config_regs[] = { + PORTCR(0, 0xe6050000), /* PORT0CR */ + PORTCR(1, 0xe6050001), /* PORT1CR */ + PORTCR(2, 0xe6050002), /* PORT2CR */ + PORTCR(3, 0xe6050003), /* PORT3CR */ + PORTCR(4, 0xe6050004), /* PORT4CR */ + PORTCR(5, 0xe6050005), /* PORT5CR */ + PORTCR(6, 0xe6050006), /* PORT6CR */ + PORTCR(7, 0xe6050007), /* PORT7CR */ + PORTCR(8, 0xe6050008), /* PORT8CR */ + PORTCR(9, 0xe6050009), /* PORT9CR */ + + PORTCR(10, 0xe605000a), /* PORT10CR */ + PORTCR(11, 0xe605000b), /* PORT11CR */ + PORTCR(12, 0xe605000c), /* PORT12CR */ + PORTCR(13, 0xe605000d), /* PORT13CR */ + PORTCR(14, 0xe605000e), /* PORT14CR */ + PORTCR(15, 0xe605000f), /* PORT15CR */ + PORTCR(16, 0xe6050010), /* PORT16CR */ + PORTCR(17, 0xe6050011), /* PORT17CR */ + PORTCR(18, 0xe6050012), /* PORT18CR */ + PORTCR(19, 0xe6050013), /* PORT19CR */ + + PORTCR(20, 0xe6050014), /* PORT20CR */ + PORTCR(21, 0xe6050015), /* PORT21CR */ + PORTCR(22, 0xe6050016), /* PORT22CR */ + PORTCR(23, 0xe6050017), /* PORT23CR */ + PORTCR(24, 0xe6050018), /* PORT24CR */ + PORTCR(25, 0xe6050019), /* PORT25CR */ + PORTCR(26, 0xe605001a), /* PORT26CR */ + PORTCR(27, 0xe605001b), /* PORT27CR */ + PORTCR(28, 0xe605001c), /* PORT28CR */ + PORTCR(29, 0xe605001d), /* PORT29CR */ + + PORTCR(30, 0xe605001e), /* PORT30CR */ + PORTCR(31, 0xe605001f), /* PORT31CR */ + PORTCR(32, 0xe6051020), /* PORT32CR */ + PORTCR(33, 0xe6051021), /* PORT33CR */ + PORTCR(34, 0xe6051022), /* PORT34CR */ + PORTCR(35, 0xe6051023), /* PORT35CR */ + PORTCR(36, 0xe6051024), /* PORT36CR */ + PORTCR(37, 0xe6051025), /* PORT37CR */ + PORTCR(38, 0xe6051026), /* PORT38CR */ + PORTCR(39, 0xe6051027), /* PORT39CR */ + + PORTCR(40, 0xe6051028), /* PORT40CR */ + PORTCR(41, 0xe6051029), /* PORT41CR */ + PORTCR(42, 0xe605102a), /* PORT42CR */ + PORTCR(43, 0xe605102b), /* PORT43CR */ + PORTCR(44, 0xe605102c), /* PORT44CR */ + PORTCR(45, 0xe605102d), /* PORT45CR */ + PORTCR(46, 0xe605102e), /* PORT46CR */ + PORTCR(47, 0xe605102f), /* PORT47CR */ + PORTCR(48, 0xe6051030), /* PORT48CR */ + PORTCR(49, 0xe6051031), /* PORT49CR */ + + PORTCR(50, 0xe6051032), /* PORT50CR */ + PORTCR(51, 0xe6051033), /* PORT51CR */ + PORTCR(52, 0xe6051034), /* PORT52CR */ + PORTCR(53, 0xe6051035), /* PORT53CR */ + PORTCR(54, 0xe6051036), /* PORT54CR */ + PORTCR(55, 0xe6051037), /* PORT55CR */ + PORTCR(56, 0xe6051038), /* PORT56CR */ + PORTCR(57, 0xe6051039), /* PORT57CR */ + PORTCR(58, 0xe605103a), /* PORT58CR */ + PORTCR(59, 0xe605103b), /* PORT59CR */ + + PORTCR(60, 0xe605103c), /* PORT60CR */ + PORTCR(61, 0xe605103d), /* PORT61CR */ + PORTCR(62, 0xe605103e), /* PORT62CR */ + PORTCR(63, 0xe605103f), /* PORT63CR */ + PORTCR(64, 0xe6051040), /* PORT64CR */ + PORTCR(65, 0xe6051041), /* PORT65CR */ + PORTCR(66, 0xe6051042), /* PORT66CR */ + PORTCR(67, 0xe6051043), /* PORT67CR */ + PORTCR(68, 0xe6051044), /* PORT68CR */ + PORTCR(69, 0xe6051045), /* PORT69CR */ + + PORTCR(70, 0xe6051046), /* PORT70CR */ + PORTCR(71, 0xe6051047), /* PORT71CR */ + PORTCR(72, 0xe6051048), /* PORT72CR */ + PORTCR(73, 0xe6051049), /* PORT73CR */ + PORTCR(74, 0xe605104a), /* PORT74CR */ + PORTCR(75, 0xe605104b), /* PORT75CR */ + PORTCR(76, 0xe605104c), /* PORT76CR */ + PORTCR(77, 0xe605104d), /* PORT77CR */ + PORTCR(78, 0xe605104e), /* PORT78CR */ + PORTCR(79, 0xe605104f), /* PORT79CR */ + + PORTCR(80, 0xe6051050), /* PORT80CR */ + PORTCR(81, 0xe6051051), /* PORT81CR */ + PORTCR(82, 0xe6051052), /* PORT82CR */ + PORTCR(83, 0xe6051053), /* PORT83CR */ + PORTCR(84, 0xe6051054), /* PORT84CR */ + PORTCR(85, 0xe6051055), /* PORT85CR */ + PORTCR(86, 0xe6051056), /* PORT86CR */ + PORTCR(87, 0xe6051057), /* PORT87CR */ + PORTCR(88, 0xe6051058), /* PORT88CR */ + PORTCR(89, 0xe6051059), /* PORT89CR */ + + PORTCR(90, 0xe605105a), /* PORT90CR */ + PORTCR(91, 0xe605105b), /* PORT91CR */ + PORTCR(92, 0xe605105c), /* PORT92CR */ + PORTCR(93, 0xe605105d), /* PORT93CR */ + PORTCR(94, 0xe605105e), /* PORT94CR */ + PORTCR(95, 0xe605105f), /* PORT95CR */ + PORTCR(96, 0xe6052060), /* PORT96CR */ + PORTCR(97, 0xe6052061), /* PORT97CR */ + PORTCR(98, 0xe6052062), /* PORT98CR */ + PORTCR(99, 0xe6052063), /* PORT99CR */ + + PORTCR(100, 0xe6052064), /* PORT100CR */ + PORTCR(101, 0xe6052065), /* PORT101CR */ + PORTCR(102, 0xe6052066), /* PORT102CR */ + PORTCR(103, 0xe6052067), /* PORT103CR */ + PORTCR(104, 0xe6052068), /* PORT104CR */ + PORTCR(105, 0xe6052069), /* PORT105CR */ + PORTCR(106, 0xe605206a), /* PORT106CR */ + PORTCR(107, 0xe605206b), /* PORT107CR */ + PORTCR(108, 0xe605206c), /* PORT108CR */ + PORTCR(109, 0xe605206d), /* PORT109CR */ + + PORTCR(110, 0xe605206e), /* PORT110CR */ + PORTCR(111, 0xe605206f), /* PORT111CR */ + PORTCR(112, 0xe6052070), /* PORT112CR */ + PORTCR(113, 0xe6052071), /* PORT113CR */ + PORTCR(114, 0xe6052072), /* PORT114CR */ + PORTCR(115, 0xe6052073), /* PORT115CR */ + PORTCR(116, 0xe6052074), /* PORT116CR */ + PORTCR(117, 0xe6052075), /* PORT117CR */ + PORTCR(118, 0xe6052076), /* PORT118CR */ + + PORTCR(128, 0xe6052080), /* PORT128CR */ + PORTCR(129, 0xe6052081), /* PORT129CR */ + + PORTCR(130, 0xe6052082), /* PORT130CR */ + PORTCR(131, 0xe6052083), /* PORT131CR */ + PORTCR(132, 0xe6052084), /* PORT132CR */ + PORTCR(133, 0xe6052085), /* PORT133CR */ + PORTCR(134, 0xe6052086), /* PORT134CR */ + PORTCR(135, 0xe6052087), /* PORT135CR */ + PORTCR(136, 0xe6052088), /* PORT136CR */ + PORTCR(137, 0xe6052089), /* PORT137CR */ + PORTCR(138, 0xe605208a), /* PORT138CR */ + PORTCR(139, 0xe605208b), /* PORT139CR */ + + PORTCR(140, 0xe605208c), /* PORT140CR */ + PORTCR(141, 0xe605208d), /* PORT141CR */ + PORTCR(142, 0xe605208e), /* PORT142CR */ + PORTCR(143, 0xe605208f), /* PORT143CR */ + PORTCR(144, 0xe6052090), /* PORT144CR */ + PORTCR(145, 0xe6052091), /* PORT145CR */ + PORTCR(146, 0xe6052092), /* PORT146CR */ + PORTCR(147, 0xe6052093), /* PORT147CR */ + PORTCR(148, 0xe6052094), /* PORT148CR */ + PORTCR(149, 0xe6052095), /* PORT149CR */ + + PORTCR(150, 0xe6052096), /* PORT150CR */ + PORTCR(151, 0xe6052097), /* PORT151CR */ + PORTCR(152, 0xe6052098), /* PORT152CR */ + PORTCR(153, 0xe6052099), /* PORT153CR */ + PORTCR(154, 0xe605209a), /* PORT154CR */ + PORTCR(155, 0xe605209b), /* PORT155CR */ + PORTCR(156, 0xe605209c), /* PORT156CR */ + PORTCR(157, 0xe605209d), /* PORT157CR */ + PORTCR(158, 0xe605209e), /* PORT158CR */ + PORTCR(159, 0xe605209f), /* PORT159CR */ + + PORTCR(160, 0xe60520a0), /* PORT160CR */ + PORTCR(161, 0xe60520a1), /* PORT161CR */ + PORTCR(162, 0xe60520a2), /* PORT162CR */ + PORTCR(163, 0xe60520a3), /* PORT163CR */ + PORTCR(164, 0xe60520a4), /* PORT164CR */ + + PORTCR(192, 0xe60520c0), /* PORT192CR */ + PORTCR(193, 0xe60520c1), /* PORT193CR */ + PORTCR(194, 0xe60520c2), /* PORT194CR */ + PORTCR(195, 0xe60520c3), /* PORT195CR */ + PORTCR(196, 0xe60520c4), /* PORT196CR */ + PORTCR(197, 0xe60520c5), /* PORT197CR */ + PORTCR(198, 0xe60520c6), /* PORT198CR */ + PORTCR(199, 0xe60520c7), /* PORT199CR */ + + PORTCR(200, 0xe60520c8), /* PORT200CR */ + PORTCR(201, 0xe60520c9), /* PORT201CR */ + PORTCR(202, 0xe60520ca), /* PORT202CR */ + PORTCR(203, 0xe60520cb), /* PORT203CR */ + PORTCR(204, 0xe60520cc), /* PORT204CR */ + PORTCR(205, 0xe60520cd), /* PORT205CR */ + PORTCR(206, 0xe60520ce), /* PORT206CR */ + PORTCR(207, 0xe60520cf), /* PORT207CR */ + PORTCR(208, 0xe60520d0), /* PORT208CR */ + PORTCR(209, 0xe60520d1), /* PORT209CR */ + + PORTCR(210, 0xe60520d2), /* PORT210CR */ + PORTCR(211, 0xe60520d3), /* PORT211CR */ + PORTCR(212, 0xe60520d4), /* PORT212CR */ + PORTCR(213, 0xe60520d5), /* PORT213CR */ + PORTCR(214, 0xe60520d6), /* PORT214CR */ + PORTCR(215, 0xe60520d7), /* PORT215CR */ + PORTCR(216, 0xe60520d8), /* PORT216CR */ + PORTCR(217, 0xe60520d9), /* PORT217CR */ + PORTCR(218, 0xe60520da), /* PORT218CR */ + PORTCR(219, 0xe60520db), /* PORT219CR */ + + PORTCR(220, 0xe60520dc), /* PORT220CR */ + PORTCR(221, 0xe60520dd), /* PORT221CR */ + PORTCR(222, 0xe60520de), /* PORT222CR */ + PORTCR(223, 0xe60520df), /* PORT223CR */ + PORTCR(224, 0xe60530e0), /* PORT224CR */ + PORTCR(225, 0xe60530e1), /* PORT225CR */ + PORTCR(226, 0xe60530e2), /* PORT226CR */ + PORTCR(227, 0xe60530e3), /* PORT227CR */ + PORTCR(228, 0xe60530e4), /* PORT228CR */ + PORTCR(229, 0xe60530e5), /* PORT229CR */ + + PORTCR(230, 0xe60530e6), /* PORT230CR */ + PORTCR(231, 0xe60530e7), /* PORT231CR */ + PORTCR(232, 0xe60530e8), /* PORT232CR */ + PORTCR(233, 0xe60530e9), /* PORT233CR */ + PORTCR(234, 0xe60530ea), /* PORT234CR */ + PORTCR(235, 0xe60530eb), /* PORT235CR */ + PORTCR(236, 0xe60530ec), /* PORT236CR */ + PORTCR(237, 0xe60530ed), /* PORT237CR */ + PORTCR(238, 0xe60530ee), /* PORT238CR */ + PORTCR(239, 0xe60530ef), /* PORT239CR */ + + PORTCR(240, 0xe60530f0), /* PORT240CR */ + PORTCR(241, 0xe60530f1), /* PORT241CR */ + PORTCR(242, 0xe60530f2), /* PORT242CR */ + PORTCR(243, 0xe60530f3), /* PORT243CR */ + PORTCR(244, 0xe60530f4), /* PORT244CR */ + PORTCR(245, 0xe60530f5), /* PORT245CR */ + PORTCR(246, 0xe60530f6), /* PORT246CR */ + PORTCR(247, 0xe60530f7), /* PORT247CR */ + PORTCR(248, 0xe60530f8), /* PORT248CR */ + PORTCR(249, 0xe60530f9), /* PORT249CR */ + + PORTCR(250, 0xe60530fa), /* PORT250CR */ + PORTCR(251, 0xe60530fb), /* PORT251CR */ + PORTCR(252, 0xe60530fc), /* PORT252CR */ + PORTCR(253, 0xe60530fd), /* PORT253CR */ + PORTCR(254, 0xe60530fe), /* PORT254CR */ + PORTCR(255, 0xe60530ff), /* PORT255CR */ + PORTCR(256, 0xe6053100), /* PORT256CR */ + PORTCR(257, 0xe6053101), /* PORT257CR */ + PORTCR(258, 0xe6053102), /* PORT258CR */ + PORTCR(259, 0xe6053103), /* PORT259CR */ + + PORTCR(260, 0xe6053104), /* PORT260CR */ + PORTCR(261, 0xe6053105), /* PORT261CR */ + PORTCR(262, 0xe6053106), /* PORT262CR */ + PORTCR(263, 0xe6053107), /* PORT263CR */ + PORTCR(264, 0xe6053108), /* PORT264CR */ + PORTCR(265, 0xe6053109), /* PORT265CR */ + PORTCR(266, 0xe605310a), /* PORT266CR */ + PORTCR(267, 0xe605310b), /* PORT267CR */ + PORTCR(268, 0xe605310c), /* PORT268CR */ + PORTCR(269, 0xe605310d), /* PORT269CR */ + + PORTCR(270, 0xe605310e), /* PORT270CR */ + PORTCR(271, 0xe605310f), /* PORT271CR */ + PORTCR(272, 0xe6053110), /* PORT272CR */ + PORTCR(273, 0xe6053111), /* PORT273CR */ + PORTCR(274, 0xe6053112), /* PORT274CR */ + PORTCR(275, 0xe6053113), /* PORT275CR */ + PORTCR(276, 0xe6053114), /* PORT276CR */ + PORTCR(277, 0xe6053115), /* PORT277CR */ + PORTCR(278, 0xe6053116), /* PORT278CR */ + PORTCR(279, 0xe6053117), /* PORT279CR */ + + PORTCR(280, 0xe6053118), /* PORT280CR */ + PORTCR(281, 0xe6053119), /* PORT281CR */ + PORTCR(282, 0xe605311a), /* PORT282CR */ + + PORTCR(288, 0xe6052120), /* PORT288CR */ + PORTCR(289, 0xe6052121), /* PORT289CR */ + + PORTCR(290, 0xe6052122), /* PORT290CR */ + PORTCR(291, 0xe6052123), /* PORT291CR */ + PORTCR(292, 0xe6052124), /* PORT292CR */ + PORTCR(293, 0xe6052125), /* PORT293CR */ + PORTCR(294, 0xe6052126), /* PORT294CR */ + PORTCR(295, 0xe6052127), /* PORT295CR */ + PORTCR(296, 0xe6052128), /* PORT296CR */ + PORTCR(297, 0xe6052129), /* PORT297CR */ + PORTCR(298, 0xe605212a), /* PORT298CR */ + PORTCR(299, 0xe605212b), /* PORT299CR */ + + PORTCR(300, 0xe605212c), /* PORT300CR */ + PORTCR(301, 0xe605212d), /* PORT301CR */ + PORTCR(302, 0xe605212e), /* PORT302CR */ + PORTCR(303, 0xe605212f), /* PORT303CR */ + PORTCR(304, 0xe6052130), /* PORT304CR */ + PORTCR(305, 0xe6052131), /* PORT305CR */ + PORTCR(306, 0xe6052132), /* PORT306CR */ + PORTCR(307, 0xe6052133), /* PORT307CR */ + PORTCR(308, 0xe6052134), /* PORT308CR */ + PORTCR(309, 0xe6052135), /* PORT309CR */ + + { PINMUX_CFG_REG("MSEL2CR", 0xe605801c, 32, 1) { + 0, 0, + 0, 0, + 0, 0, + 0, 0, + 0, 0, + 0, 0, + 0, 0, + 0, 0, + 0, 0, + 0, 0, + 0, 0, + 0, 0, + MSEL2CR_MSEL19_0, MSEL2CR_MSEL19_1, + MSEL2CR_MSEL18_0, MSEL2CR_MSEL18_1, + MSEL2CR_MSEL17_0, MSEL2CR_MSEL17_1, + MSEL2CR_MSEL16_0, MSEL2CR_MSEL16_1, + 0, 0, + MSEL2CR_MSEL14_0, MSEL2CR_MSEL14_1, + MSEL2CR_MSEL13_0, MSEL2CR_MSEL13_1, + MSEL2CR_MSEL12_0, MSEL2CR_MSEL12_1, + MSEL2CR_MSEL11_0, MSEL2CR_MSEL11_1, + MSEL2CR_MSEL10_0, MSEL2CR_MSEL10_1, + MSEL2CR_MSEL9_0, MSEL2CR_MSEL9_1, + MSEL2CR_MSEL8_0, MSEL2CR_MSEL8_1, + MSEL2CR_MSEL7_0, MSEL2CR_MSEL7_1, + MSEL2CR_MSEL6_0, MSEL2CR_MSEL6_1, + MSEL2CR_MSEL5_0, MSEL2CR_MSEL5_1, + MSEL2CR_MSEL4_0, MSEL2CR_MSEL4_1, + MSEL2CR_MSEL3_0, MSEL2CR_MSEL3_1, + MSEL2CR_MSEL2_0, MSEL2CR_MSEL2_1, + MSEL2CR_MSEL1_0, MSEL2CR_MSEL1_1, + MSEL2CR_MSEL0_0, MSEL2CR_MSEL0_1, + } + }, + { PINMUX_CFG_REG("MSEL3CR", 0xe6058020, 32, 1) { + 0, 0, + 0, 0, + 0, 0, + MSEL3CR_MSEL28_0, MSEL3CR_MSEL28_1, + 0, 0, + 0, 0, + 0, 0, + 0, 0, + 0, 0, + 0, 0, + 0, 0, + 0, 0, + 0, 0, + 0, 0, + 0, 0, + 0, 0, + MSEL3CR_MSEL15_0, MSEL3CR_MSEL15_1, + 0, 0, + 0, 0, + 0, 0, + MSEL3CR_MSEL11_0, MSEL3CR_MSEL11_1, + 0, 0, + MSEL3CR_MSEL9_0, MSEL3CR_MSEL9_1, + 0, 0, + 0, 0, + MSEL3CR_MSEL6_0, MSEL3CR_MSEL6_1, + 0, 0, + 0, 0, + 0, 0, + MSEL3CR_MSEL2_0, MSEL3CR_MSEL2_1, + 0, 0, + 0, 0, + } + }, + { PINMUX_CFG_REG("MSEL4CR", 0xe6058024, 32, 1) { + 0, 0, + 0, 0, + MSEL4CR_MSEL29_0, MSEL4CR_MSEL29_1, + 0, 0, + MSEL4CR_MSEL27_0, MSEL4CR_MSEL27_1, + MSEL4CR_MSEL26_0, MSEL4CR_MSEL26_1, + 0, 0, + 0, 0, + 0, 0, + MSEL4CR_MSEL22_0, MSEL4CR_MSEL22_1, + MSEL4CR_MSEL21_0, MSEL4CR_MSEL21_1, + MSEL4CR_MSEL20_0, MSEL4CR_MSEL20_1, + MSEL4CR_MSEL19_0, MSEL4CR_MSEL19_1, + 0, 0, + 0, 0, + 0, 0, + MSEL4CR_MSEL15_0, MSEL4CR_MSEL15_1, + 0, 0, + MSEL4CR_MSEL13_0, MSEL4CR_MSEL13_1, + MSEL4CR_MSEL12_0, MSEL4CR_MSEL12_1, + MSEL4CR_MSEL11_0, MSEL4CR_MSEL11_1, + MSEL4CR_MSEL10_0, MSEL4CR_MSEL10_1, + MSEL4CR_MSEL9_0, MSEL4CR_MSEL9_1, + MSEL4CR_MSEL8_0, MSEL4CR_MSEL8_1, + MSEL4CR_MSEL7_0, MSEL4CR_MSEL7_1, + 0, 0, + 0, 0, + MSEL4CR_MSEL4_0, MSEL4CR_MSEL4_1, + 0, 0, + 0, 0, + MSEL4CR_MSEL1_0, MSEL4CR_MSEL1_1, + 0, 0, + } + }, + { }, +}; + +static struct pinmux_data_reg pinmux_data_regs[] = { + { PINMUX_DATA_REG("PORTL031_000DR", 0xe6054000, 32) { + PORT31_DATA, PORT30_DATA, PORT29_DATA, PORT28_DATA, + PORT27_DATA, PORT26_DATA, PORT25_DATA, PORT24_DATA, + PORT23_DATA, PORT22_DATA, PORT21_DATA, PORT20_DATA, + PORT19_DATA, PORT18_DATA, PORT17_DATA, PORT16_DATA, + PORT15_DATA, PORT14_DATA, PORT13_DATA, PORT12_DATA, + PORT11_DATA, PORT10_DATA, PORT9_DATA, PORT8_DATA, + PORT7_DATA, PORT6_DATA, PORT5_DATA, PORT4_DATA, + PORT3_DATA, PORT2_DATA, PORT1_DATA, PORT0_DATA } + }, + { PINMUX_DATA_REG("PORTD063_032DR", 0xe6055000, 32) { + PORT63_DATA, PORT62_DATA, PORT61_DATA, PORT60_DATA, + PORT59_DATA, PORT58_DATA, PORT57_DATA, PORT56_DATA, + PORT55_DATA, PORT54_DATA, PORT53_DATA, PORT52_DATA, + PORT51_DATA, PORT50_DATA, PORT49_DATA, PORT48_DATA, + PORT47_DATA, PORT46_DATA, PORT45_DATA, PORT44_DATA, + PORT43_DATA, PORT42_DATA, PORT41_DATA, PORT40_DATA, + PORT39_DATA, PORT38_DATA, PORT37_DATA, PORT36_DATA, + PORT35_DATA, PORT34_DATA, PORT33_DATA, PORT32_DATA } + }, + { PINMUX_DATA_REG("PORTD095_064DR", 0xe6055004, 32) { + PORT95_DATA, PORT94_DATA, PORT93_DATA, PORT92_DATA, + PORT91_DATA, PORT90_DATA, PORT89_DATA, PORT88_DATA, + PORT87_DATA, PORT86_DATA, PORT85_DATA, PORT84_DATA, + PORT83_DATA, PORT82_DATA, PORT81_DATA, PORT80_DATA, + PORT79_DATA, PORT78_DATA, PORT77_DATA, PORT76_DATA, + PORT75_DATA, PORT74_DATA, PORT73_DATA, PORT72_DATA, + PORT71_DATA, PORT70_DATA, PORT69_DATA, PORT68_DATA, + PORT67_DATA, PORT66_DATA, PORT65_DATA, PORT64_DATA } + }, + { PINMUX_DATA_REG("PORTR127_096DR", 0xe6056000, 32) { + 0, 0, 0, 0, + 0, 0, 0, 0, + 0, PORT118_DATA, PORT117_DATA, PORT116_DATA, + PORT115_DATA, PORT114_DATA, PORT113_DATA, PORT112_DATA, + PORT111_DATA, PORT110_DATA, PORT109_DATA, PORT108_DATA, + PORT107_DATA, PORT106_DATA, PORT105_DATA, PORT104_DATA, + PORT103_DATA, PORT102_DATA, PORT101_DATA, PORT100_DATA, + PORT99_DATA, PORT98_DATA, PORT97_DATA, PORT96_DATA } + }, + { PINMUX_DATA_REG("PORTR159_128DR", 0xe6056004, 32) { + PORT159_DATA, PORT158_DATA, PORT157_DATA, PORT156_DATA, + PORT155_DATA, PORT154_DATA, PORT153_DATA, PORT152_DATA, + PORT151_DATA, PORT150_DATA, PORT149_DATA, PORT148_DATA, + PORT147_DATA, PORT146_DATA, PORT145_DATA, PORT144_DATA, + PORT143_DATA, PORT142_DATA, PORT141_DATA, PORT140_DATA, + PORT139_DATA, PORT138_DATA, PORT137_DATA, PORT136_DATA, + PORT135_DATA, PORT134_DATA, PORT133_DATA, PORT132_DATA, + PORT131_DATA, PORT130_DATA, PORT129_DATA, PORT128_DATA } + }, + { PINMUX_DATA_REG("PORTR191_160DR", 0xe6056008, 32) { + 0, 0, 0, 0, + 0, 0, 0, 0, + 0, 0, 0, 0, + 0, 0, 0, 0, + 0, 0, 0, 0, + 0, 0, 0, 0, + 0, 0, 0, PORT164_DATA, + PORT163_DATA, PORT162_DATA, PORT161_DATA, PORT160_DATA } + }, + { PINMUX_DATA_REG("PORTR223_192DR", 0xe605600C, 32) { + PORT223_DATA, PORT222_DATA, PORT221_DATA, PORT220_DATA, + PORT219_DATA, PORT218_DATA, PORT217_DATA, PORT216_DATA, + PORT215_DATA, PORT214_DATA, PORT213_DATA, PORT212_DATA, + PORT211_DATA, PORT210_DATA, PORT209_DATA, PORT208_DATA, + PORT207_DATA, PORT206_DATA, PORT205_DATA, PORT204_DATA, + PORT203_DATA, PORT202_DATA, PORT201_DATA, PORT200_DATA, + PORT199_DATA, PORT198_DATA, PORT197_DATA, PORT196_DATA, + PORT195_DATA, PORT194_DATA, PORT193_DATA, PORT192_DATA } + }, + { PINMUX_DATA_REG("PORTU255_224DR", 0xe6057000, 32) { + PORT255_DATA, PORT254_DATA, PORT253_DATA, PORT252_DATA, + PORT251_DATA, PORT250_DATA, PORT249_DATA, PORT248_DATA, + PORT247_DATA, PORT246_DATA, PORT245_DATA, PORT244_DATA, + PORT243_DATA, PORT242_DATA, PORT241_DATA, PORT240_DATA, + PORT239_DATA, PORT238_DATA, PORT237_DATA, PORT236_DATA, + PORT235_DATA, PORT234_DATA, PORT233_DATA, PORT232_DATA, + PORT231_DATA, PORT230_DATA, PORT229_DATA, PORT228_DATA, + PORT227_DATA, PORT226_DATA, PORT225_DATA, PORT224_DATA } + }, + { PINMUX_DATA_REG("PORTU287_256DR", 0xe6057004, 32) { + 0, 0, 0, 0, + 0, PORT282_DATA, PORT281_DATA, PORT280_DATA, + PORT279_DATA, PORT278_DATA, PORT277_DATA, PORT276_DATA, + PORT275_DATA, PORT274_DATA, PORT273_DATA, PORT272_DATA, + PORT271_DATA, PORT270_DATA, PORT269_DATA, PORT268_DATA, + PORT267_DATA, PORT266_DATA, PORT265_DATA, PORT264_DATA, + PORT263_DATA, PORT262_DATA, PORT261_DATA, PORT260_DATA, + PORT259_DATA, PORT258_DATA, PORT257_DATA, PORT256_DATA } + }, + { PINMUX_DATA_REG("PORTR319_288DR", 0xe6056010, 32) { + 0, 0, 0, 0, + 0, 0, 0, 0, + 0, 0, PORT309_DATA, PORT308_DATA, + PORT307_DATA, PORT306_DATA, PORT305_DATA, PORT304_DATA, + PORT303_DATA, PORT302_DATA, PORT301_DATA, PORT300_DATA, + PORT299_DATA, PORT298_DATA, PORT297_DATA, PORT296_DATA, + PORT295_DATA, PORT294_DATA, PORT293_DATA, PORT292_DATA, + PORT291_DATA, PORT290_DATA, PORT289_DATA, PORT288_DATA } + }, + { }, +}; + +#if 0 +/* IRQ pins through INTCS with IRQ0->15 from 0x200 and IRQ16-31 from 0x3200 */ +#define EXT_IRQ16L(n) intcs_evt2irq(0x200 + ((n) << 5)) +#define EXT_IRQ16H(n) intcs_evt2irq(0x3200 + ((n - 16) << 5)) +#else +#define EXT_IRQ16L(n) (n) +#define EXT_IRQ16H(n) (n) +#endif + +static struct pinmux_irq pinmux_irqs[] = { + PINMUX_IRQ(EXT_IRQ16H(19), PORT9_FN0), + PINMUX_IRQ(EXT_IRQ16L(1), PORT10_FN0), + PINMUX_IRQ(EXT_IRQ16L(0), PORT11_FN0), + PINMUX_IRQ(EXT_IRQ16H(18), PORT13_FN0), + PINMUX_IRQ(EXT_IRQ16H(20), PORT14_FN0), + PINMUX_IRQ(EXT_IRQ16H(21), PORT15_FN0), + PINMUX_IRQ(EXT_IRQ16H(31), PORT26_FN0), + PINMUX_IRQ(EXT_IRQ16H(30), PORT27_FN0), + PINMUX_IRQ(EXT_IRQ16H(29), PORT28_FN0), + PINMUX_IRQ(EXT_IRQ16H(22), PORT40_FN0), + PINMUX_IRQ(EXT_IRQ16H(23), PORT53_FN0), + PINMUX_IRQ(EXT_IRQ16L(10), PORT54_FN0), + PINMUX_IRQ(EXT_IRQ16L(9), PORT56_FN0), + PINMUX_IRQ(EXT_IRQ16H(26), PORT115_FN0), + PINMUX_IRQ(EXT_IRQ16H(27), PORT116_FN0), + PINMUX_IRQ(EXT_IRQ16H(28), PORT117_FN0), + PINMUX_IRQ(EXT_IRQ16H(24), PORT118_FN0), + PINMUX_IRQ(EXT_IRQ16L(6), PORT147_FN0), + PINMUX_IRQ(EXT_IRQ16L(2), PORT149_FN0), + PINMUX_IRQ(EXT_IRQ16L(7), PORT150_FN0), + PINMUX_IRQ(EXT_IRQ16L(12), PORT156_FN0), + PINMUX_IRQ(EXT_IRQ16L(4), PORT159_FN0), + PINMUX_IRQ(EXT_IRQ16H(25), PORT164_FN0), + PINMUX_IRQ(EXT_IRQ16L(8), PORT223_FN0), + PINMUX_IRQ(EXT_IRQ16L(3), PORT224_FN0), + PINMUX_IRQ(EXT_IRQ16L(5), PORT227_FN0), + PINMUX_IRQ(EXT_IRQ16H(17), PORT234_FN0), + PINMUX_IRQ(EXT_IRQ16L(11), PORT238_FN0), + PINMUX_IRQ(EXT_IRQ16L(13), PORT239_FN0), + PINMUX_IRQ(EXT_IRQ16H(16), PORT249_FN0), + PINMUX_IRQ(EXT_IRQ16L(14), PORT251_FN0), + PINMUX_IRQ(EXT_IRQ16L(9), PORT308_FN0), +}; + +static struct pinmux_info sh73a0_pinmux_info = { + .name = "sh73a0_pfc", + .reserved_id = PINMUX_RESERVED, + .data = { PINMUX_DATA_BEGIN, PINMUX_DATA_END }, + .input = { PINMUX_INPUT_BEGIN, PINMUX_INPUT_END }, + .input_pu = { PINMUX_INPUT_PULLUP_BEGIN, PINMUX_INPUT_PULLUP_END }, + .input_pd = { PINMUX_INPUT_PULLDOWN_BEGIN, PINMUX_INPUT_PULLDOWN_END }, + .output = { PINMUX_OUTPUT_BEGIN, PINMUX_OUTPUT_END }, + .mark = { PINMUX_MARK_BEGIN, PINMUX_MARK_END }, + .function = { PINMUX_FUNCTION_BEGIN, PINMUX_FUNCTION_END }, + + .first_gpio = GPIO_PORT0, + .last_gpio = GPIO_FN_FSIAISLD_PU, + + .gpios = pinmux_gpios, + .cfg_regs = pinmux_config_regs, + .data_regs = pinmux_data_regs, + + .gpio_data = pinmux_data, + .gpio_data_size = ARRAY_SIZE(pinmux_data), + + .gpio_irq = pinmux_irqs, + .gpio_irq_size = ARRAY_SIZE(pinmux_irqs), +}; + +void sh73a0_pinmux_init(void) +{ + register_pinmux(&sh73a0_pinmux_info); +} diff --git a/arch/arm/include/asm/arch-rmobile/gpio.h b/arch/arm/include/asm/arch-rmobile/gpio.h new file mode 100644 index 0000000..8d3f10e --- /dev/null +++ b/arch/arm/include/asm/arch-rmobile/gpio.h @@ -0,0 +1,9 @@ +#ifndef __ASM_ARCH_GPIO_H +#define __ASM_ARCH_GPIO_H + +#if defined(CONFIG_SH73A0) +#include "sh73a0-gpio.h" +void sh73a0_pinmux_init(void); +#endif + +#endif /* __ASM_ARCH_GPIO_H */
Nobuhiro Iwamatsu
