[PATCH] rockchip: ringneck-px30: put STM32_RST line in input mode instead of output
From: Quentin Schulz quentin.schulz@theobroma-systems.com
The STM32_RST line is routed to the ATtiny microcontroller PA0/RESET/UPDI pin. By driving the PX30 SoC pin as GPIO output high, we prevent external UPDI to be used for flashing without first putting this pin as GPIO input, an extra step we could avoid in userspace.
There's an external hardware pull-up strong enough to keep the STM32_RST state high on ATtiny side but weak enough it can be overridden by external UPDI. This also means it is safe to use for the STM32 variant, where STM32_RST line will be in the same state as if output high was used.
The Q7 standard specifies that MFG_NC1 and MFG_NC2 (used for UPDI for Ringneck) pins should neither be driven by the carrierboard, nor have pull-up or pull-down resistors. This means this commit is safe to use regardless of the carrierboard this module would be connected to (provided it follows the Q7 standard).
Fixes: 6acdd63e8771 ("rockchip: ringneck-px30: always reset STM32 companion controller on boot") Cc: Quentin Schulz foss+uboot@0leil.net Signed-off-by: Quentin Schulz quentin.schulz@theobroma-systems.com --- board/theobroma-systems/ringneck_px30/ringneck-px30.c | 4 ++-- 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/board/theobroma-systems/ringneck_px30/ringneck-px30.c b/board/theobroma-systems/ringneck_px30/ringneck-px30.c index ff7e414303d..2ab1e7a12fa 100644 --- a/board/theobroma-systems/ringneck_px30/ringneck-px30.c +++ b/board/theobroma-systems/ringneck_px30/ringneck-px30.c @@ -76,9 +76,9 @@ void spl_board_init(void)
mdelay(1);
- ret = gpio_direction_output(STM32_RST, 1); + ret = gpio_direction_input(STM32_RST); if (ret) { - debug("Failed to configure STM32_RST as output high\n"); + debug("Failed to configure STM32_RST as input\n"); return; } }
--- base-commit: a4650bf65e4b7d3ef04c90ba8031374428e4a682 change-id: 20240209-ringneck-stm32-rst-input-ca1cdfa67ff5
Hi Quentin,
On 2024/2/9 21:18, Quentin Schulz wrote:
From: Quentin Schulzquentin.schulz@theobroma-systems.com
A little confuse here, this GPIO is an output for PX30, right?So the config is:
1. the PX30 SPL init STM32_RST as input, with hardware pull-up the keep STM32 work;
2. when need UPDI for flashing, need to set STM32_RST to output and trigger the reset in userspace?
This sounds like it should use output and pull-none for these GPIOs?
Thanks,
- Kever
Fixes: 6acdd63e8771 ("rockchip: ringneck-px30: always reset STM32 companion controller on boot") Cc: Quentin Schulzfoss+uboot@0leil.net Signed-off-by: Quentin Schulzquentin.schulz@theobroma-systems.com
mdelay(1);
- ret = gpio_direction_input(STM32_RST); if (ret) {
return; } }debug("Failed to configure STM32_RST as input\n");
Hi Kever,
On 2/18/24 02:14, Kever Yang wrote:
Hi Quentin,
- the PX30 SPL init STM32_RST as input, with hardware pull-up the keep
STM32 work;
The pin needs to be high for STM32, and high **but not driven** for ATtiny in order to allow flashing scripts to work.
- when need UPDI for flashing, need to set STM32_RST to output and
For STM32, STM32_RST needs to be driven low, then STM32_BOOT needs to be driven high, then STM32_RST needs to be high to deassert reset.
For ATtiny, STM32_RST needs to be NOT driven so that UPDI lines can be used to interact with the MCU. Note that we also have the ability to do bitbang UPDI on that STM32_RST pin but that's another topic (just explaining why it is routed while seemingly useless for ATtiny).
All the above is for entering the flashing mode.
However, in U-Boot we do NOT want to enter flashing mode, we want to exit it, c.f. https://lore.kernel.org/u-boot/20231103-ringneck-stm32-reset-v2-1-a0e5559f89...
An external HW pull-up is required because of glitches on the line when powering up/down. However, this is only done on newer versions of the PCB, so we need to tackle old versions.
The old versions do not have this external HW pull-up and the glitch may cause the MCU to enter its flashing mode. Therefore, we force it to exit the flashing mode by always hard resetting it into the normal runtime mode. This is what spl_board_init() does. STM32_RST and STM32_BOOT are controlled by our flashing script for the STM32 variant for the MCU, so the default state when entering the Linux kernel doesn't matter. For the ATtiny MCU variant, we do not handle those GPIOs as part of the flashing script, therefore the default state when entering the Linux kernel should be the expected value for which we can use UPDI to flash the ATtiny. For ATtiny, the reset line is shared between STM32_RST that goes to the SoC and the UPDI lines exposed over the Q7 header. If STM32_RST is driven by the SoC, the UPDI lines won't be able to interact with the MCU. Therefore it needs to be put into input mode, whether in U-Boot or in Linux userspace.
This would be a configuration for the Linux kernel DT, but we would still need some custom handling in U-Boot. What are you suggesting exactly with this?
Cheers, Quentin
Hi Kever,
On 2/19/24 10:50, Quentin Schulz wrote:
Hi Kever,
Hi Quentin,
keep STM32 work;
Can we have this in the next merge request for next please? Or maybe there's something I need to change here?
Cheers, Quentin
Hi Quentin,
On 2024/3/22 17:38, Quentin Schulz wrote:
Hi Kever,
Hi Kever,
Hi Quentin,
keep STM32 work;
I will merge this patch next time when I send the PR.
Reviewed-by: Kever Yang kever.yang@rock-chips.com
Thanks, - Kever
Cheers, Quentin
Kever Yang
Quentin Schulz
Quentin Schulz
