[U-Boot-Users] [PATCH 13/30] lib_{arm, avr32, blackfin, generic, i386}/: Remove obsolete references to CONFIG_COMMANDS
Signed-off-by: Jon Loeliger jdl@freescale.com --- lib_arm/board.c | 8 ++++---- lib_avr32/board.c | 2 +- lib_blackfin/board.c | 6 +++--- lib_generic/crc32.c | 4 ++-- lib_i386/board.c | 17 ++++++++--------- 5 files changed, 18 insertions(+), 19 deletions(-)
diff --git a/lib_arm/board.c b/lib_arm/board.c index 69d4782..e175607 100644 --- a/lib_arm/board.c +++ b/lib_arm/board.c @@ -54,7 +54,7 @@
DECLARE_GLOBAL_DATA_PTR;
-#if (CONFIG_COMMANDS & CFG_CMD_NAND) || defined(CONFIG_CMD_NAND) +#if defined(CONFIG_CMD_NAND) void nand_init (void); #endif
@@ -296,7 +296,7 @@ void start_armboot (void) /* armboot_start is defined in the board-specific linker script */ mem_malloc_init (_armboot_start - CFG_MALLOC_LEN);
-#if (CONFIG_COMMANDS & CFG_CMD_NAND) || defined(CONFIG_CMD_NAND) +#if defined(CONFIG_CMD_NAND) puts ("NAND: "); nand_init(); /* go init the NAND */ #endif @@ -378,7 +378,7 @@ void start_armboot (void) if ((s = getenv ("loadaddr")) != NULL) { load_addr = simple_strtoul (s, NULL, 16); } -#if (CONFIG_COMMANDS & CFG_CMD_NET) || defined(CONFIG_CMD_NET) +#if defined(CONFIG_CMD_NET) if ((s = getenv ("bootfile")) != NULL) { copy_filename (BootFile, s, sizeof (BootFile)); } @@ -387,7 +387,7 @@ void start_armboot (void) #ifdef BOARD_LATE_INIT board_late_init (); #endif -#if (CONFIG_COMMANDS & CFG_CMD_NET) || defined(CONFIG_CMD_NET) +#if defined(CONFIG_CMD_NET) #if defined(CONFIG_NET_MULTI) puts ("Net: "); #endif diff --git a/lib_avr32/board.c b/lib_avr32/board.c index 822668c..8b9ca38 100644 --- a/lib_avr32/board.c +++ b/lib_avr32/board.c @@ -328,7 +328,7 @@ void board_init_r(gd_t *new_gd, ulong dest_addr) jumptable_init(); console_init_r();
-#if (CONFIG_COMMANDS & CFG_CMD_NET) || defined(CONFIG_CMD_NET) +#if defined(CONFIG_CMD_NET) #if defined(CONFIG_NET_MULTI) puts("Net: "); #endif diff --git a/lib_blackfin/board.c b/lib_blackfin/board.c index d359710..36a969e 100644 --- a/lib_blackfin/board.c +++ b/lib_blackfin/board.c @@ -297,7 +297,7 @@ void board_init_f(ulong bootflag) }
checkboard(); -#if defined(CONFIG_RTC_BF533) && ((CONFIG_COMMANDS & CFG_CMD_DATE) || defined(CONFIG_CMD_DATE)) +#if defined(CONFIG_RTC_BF533) && defined(CONFIG_CMD_DATE) rtc_init(); #endif timer_init(); @@ -391,13 +391,13 @@ void board_init_r(gd_t * id, ulong dest_addr) if ((s = getenv("loadaddr")) != NULL) { load_addr = simple_strtoul(s, NULL, 16); } -#if (CONFIG_COMMANDS & CFG_CMD_NET) || defined(CONFIG_CMD_NET) +#if defined(CONFIG_CMD_NET) if ((s = getenv("bootfile")) != NULL) { copy_filename(BootFile, s, sizeof(BootFile)); } #endif
-#if (CONFIG_COMMANDS & CFG_CMD_NAND) || defined(CONFIG_CMD_NAND) +#if defined(CONFIG_CMD_NAND) puts("NAND: "); nand_init(); /* go init the NAND */ #endif diff --git a/lib_generic/crc32.c b/lib_generic/crc32.c index 84deba9..da23336 100644 --- a/lib_generic/crc32.c +++ b/lib_generic/crc32.c @@ -171,8 +171,8 @@ uLong ZEXPORT crc32(crc, buf, len) return crc ^ 0xffffffffL; }
-#if ((CONFIG_COMMANDS & CFG_CMD_JFFS2) || defined(CONFIG_CMD_JFFS2)) || \ - (((CONFIG_COMMANDS & CFG_CMD_NAND) || defined(CONFIG_CMD_NAND)) \ +#if defined(CONFIG_CMD_JFFS2) || \ + (defined(CONFIG_CMD_NAND) \ && !defined(CFG_NAND_LEGACY))
/* No ones complement version. JFFS2 (and other things ?) diff --git a/lib_i386/board.c b/lib_i386/board.c index 1efe81e..667d2da 100644 --- a/lib_i386/board.c +++ b/lib_i386/board.c @@ -313,14 +313,13 @@ void start_i386boot (void) misc_init_r(); #endif
-#if ((CONFIG_COMMANDS & CFG_CMD_PCMCIA) || defined(CONFIG_CMD_PCMCIA)) - && !((CONFIG_COMMANDS & CFG_CMD_IDE) || defined(CONFIG_CMD_IDE)) +#if defined(CONFIG_CMD_PCMCIA) && !defined(CONFIG_CMD_IDE) WATCHDOG_RESET(); puts ("PCMCIA:"); pcmcia_init(); #endif
-#if (CONFIG_COMMANDS & CFG_CMD_KGDB) || defined(CONFIG_CMD_KGDB) +#if defined(CONFIG_CMD_KGDB) WATCHDOG_RESET(); puts("KGDB: "); kgdb_init(); @@ -349,7 +348,7 @@ void start_i386boot (void) if ((s = getenv ("loadaddr")) != NULL) { load_addr = simple_strtoul (s, NULL, 16); } -#if (CONFIG_COMMANDS & CFG_CMD_NET) || defined(CONFIG_CMD_NET) +#if defined(CONFIG_CMD_NET) if ((s = getenv ("bootfile")) != NULL) { copy_filename (BootFile, s, sizeof (BootFile)); } @@ -357,25 +356,25 @@ void start_i386boot (void)
WATCHDOG_RESET();
-#if (CONFIG_COMMANDS & CFG_CMD_IDE) || defined(CONFIG_CMD_IDE) +#if defined(CONFIG_CMD_IDE) WATCHDOG_RESET(); puts("IDE: "); ide_init(); #endif /* CFG_CMD_IDE */
-#if (CONFIG_COMMANDS & CFG_CMD_SCSI) || defined(CONFIG_CMD_SCSI) +#if defined(CONFIG_CMD_SCSI) WATCHDOG_RESET(); puts("SCSI: "); scsi_init(); #endif
-#if (CONFIG_COMMANDS & CFG_CMD_DOC) || defined(CONFIG_CMD_DOC) +#if defined(CONFIG_CMD_DOC) WATCHDOG_RESET(); puts("DOC: "); doc_init(); #endif
-#if (CONFIG_COMMANDS & CFG_CMD_NET) || defined(CONFIG_CMD_NET) +#if defined(CONFIG_CMD_NET) #if defined(CONFIG_NET_MULTI) WATCHDOG_RESET(); puts("Net: "); @@ -383,7 +382,7 @@ void start_i386boot (void) eth_initialize(gd->bd); #endif
-#if ((CONFIG_COMMANDS & CFG_CMD_NET) || defined(CONFIG_CMD_NET)) && (0) +#if ( defined(CONFIG_CMD_NET)) && (0) WATCHDOG_RESET(); # ifdef DEBUG puts ("Reset Ethernet PHY\n");
Jon Loeliger
