[PATCH v4 0/6] Add support for ECDSA image signing (with test)
## Purpose and intent
The purpose of this series is to enable ECDSA as an alternative to RSA for FIT signing. As new chips have built-in support for ECDSA verified boot, it makes sense to stick to one signing algorithm, instead of resorting to RSA for u-boot images.
The focus of this series is signing an existing FIT image:
mkimage -F some-existing.fit --signing-key some/key.pem
Signing while assembling a FIT is not a tested use case. # Implementation
## Code organization
Unlike the RSA path, which mixes host and firmware code in the same, source files, this series keeps a very clear distinction. ecdsa-libcrypto.c is intended to be used for host code and only for host code. There is more opportunity for code reuse this way.
## Signing
There is one major difference from the RSA path. The 'key-name-hint' property is ignored in the ECDSA path. There are two reasons: (1) The intent of 'key-name-hint' is not clear (2) Initial implementation is much easier to review
There is an intentional side-effect. The RSA path takes 'key-name-hint' to decide which key file to read from disk. In the context of "which fdt node describes my signing key", this makes sense. On the other hand, 'key-name-hint' is also used as the basename of where the key is on the filesystem. This leads to some funny search paths, such as
"some/dir/(null).key" So I am using the -K option to mkimage as the _full_ path to the key file. It doesn't have to be named .key, it doesn't have to be named .crt, and it doesn't have to exist in a particular directory (as is the case for the RSA path). I understand and recognize that this discrepancy must be resolved, but resolving it right now would make the initial implementation much harder and longer.
# Testing
test/py/tests/test_fit_ecdsa.py is implemented withe the goal to check that the signing is done correctly, and that the signature is encoded in the proper raw format. Verification is done with pyCryptodomex, so this test will catch both coding errors and openssl bugs. This is the only scope of testing proposed here.
# Things not yet resolved: - is mkimage '-k' supposed to be a directory or file path I'm hoping I can postpone answering this question pending further discussion.
Changes since v3: - Don't use 'log_msg_ret()', as it's not available host-side
Changes since v1 and v2: - Added lots of function comments - Replaced hardcoded error numbers with more meaningful errno numbers - Changed some error paths to use 'return log_msg_ret'
Alexandru Gagniuc (6): lib: Rename rsa-checksum.c to hash-checksum.c lib/rsa: Make fdt_add_bignum() available outside of RSA code lib: Add support for ECDSA image signing doc: signature.txt: Document devicetree format for ECDSA keys test/py: Add pycryptodomex to list of required pakages test/py: ecdsa: Add test for mkimage ECDSA signing
common/image-fit-sig.c | 2 +- common/image-sig.c | 13 +- doc/uImage.FIT/signature.txt | 7 +- include/image.h | 5 +- include/u-boot/ecdsa.h | 94 ++++++ include/u-boot/fdt-libcrypto.h | 27 ++ .../{rsa-checksum.h => hash-checksum.h} | 0 lib/Makefile | 1 + lib/crypto/pkcs7_verify.c | 2 +- lib/crypto/x509_public_key.c | 2 +- lib/ecdsa/ecdsa-libcrypto.c | 306 ++++++++++++++++++ lib/fdt-libcrypto.c | 72 +++++ lib/{rsa/rsa-checksum.c => hash-checksum.c} | 3 +- lib/rsa/Makefile | 2 +- lib/rsa/rsa-sign.c | 65 +--- test/py/requirements.txt | 1 + test/py/tests/test_fit_ecdsa.py | 111 +++++++ tools/Makefile | 7 +- 18 files changed, 645 insertions(+), 75 deletions(-) create mode 100644 include/u-boot/ecdsa.h create mode 100644 include/u-boot/fdt-libcrypto.h rename include/u-boot/{rsa-checksum.h => hash-checksum.h} (100%) create mode 100644 lib/ecdsa/ecdsa-libcrypto.c create mode 100644 lib/fdt-libcrypto.c rename lib/{rsa/rsa-checksum.c => hash-checksum.c} (96%) create mode 100644 test/py/tests/test_fit_ecdsa.py
rsa-checksum.c sontains the hash_calculate() implementations. Despite the "rsa-" file prefix, this function is useful for other algorithms.
To prevent confusion, move this file to lib/crypto, and rename it to hash-checksum.c, to give it a more "generic" feel.
Signed-off-by: Alexandru Gagniuc mr.nuke.me@gmail.com --- common/image-fit-sig.c | 2 +- common/image-sig.c | 2 +- include/image.h | 2 +- include/u-boot/{rsa-checksum.h => hash-checksum.h} | 0 lib/Makefile | 1 + lib/crypto/pkcs7_verify.c | 2 +- lib/crypto/x509_public_key.c | 2 +- lib/{rsa/rsa-checksum.c => hash-checksum.c} | 3 ++- lib/rsa/Makefile | 2 +- tools/Makefile | 3 ++- 10 files changed, 11 insertions(+), 8 deletions(-) rename include/u-boot/{rsa-checksum.h => hash-checksum.h} (100%) rename lib/{rsa/rsa-checksum.c => hash-checksum.c} (96%)
diff --git a/common/image-fit-sig.c b/common/image-fit-sig.c index 5401d9411b..7fcbb47235 100644 --- a/common/image-fit-sig.c +++ b/common/image-fit-sig.c @@ -15,7 +15,7 @@ DECLARE_GLOBAL_DATA_PTR; #include <fdt_region.h> #include <image.h> #include <u-boot/rsa.h> -#include <u-boot/rsa-checksum.h> +#include <u-boot/hash-checksum.h>
#define IMAGE_MAX_HASHED_NODES 100
diff --git a/common/image-sig.c b/common/image-sig.c index f3c209ae8b..21dafe6b91 100644 --- a/common/image-sig.c +++ b/common/image-sig.c @@ -16,7 +16,7 @@ DECLARE_GLOBAL_DATA_PTR; #endif /* !USE_HOSTCC*/ #include <image.h> #include <u-boot/rsa.h> -#include <u-boot/rsa-checksum.h> +#include <u-boot/hash-checksum.h>
diff --git a/include/image.h b/include/image.h index 41473dbb9c..a55b11b3ae 100644 --- a/include/image.h +++ b/include/image.h @@ -1258,7 +1258,7 @@ struct image_region { };
#if IMAGE_ENABLE_VERIFY -# include <u-boot/rsa-checksum.h> +# include <u-boot/hash-checksum.h> #endif struct checksum_algo { const char *name; diff --git a/include/u-boot/rsa-checksum.h b/include/u-boot/hash-checksum.h similarity index 100% rename from include/u-boot/rsa-checksum.h rename to include/u-boot/hash-checksum.h diff --git a/lib/Makefile b/lib/Makefile index 851a80ef3b..cf64188ba5 100644 --- a/lib/Makefile +++ b/lib/Makefile @@ -60,6 +60,7 @@ endif obj-$(CONFIG_$(SPL_)ACPIGEN) += acpi/ obj-$(CONFIG_$(SPL_)MD5) += md5.o obj-$(CONFIG_$(SPL_)RSA) += rsa/ +obj-$(CONFIG_FIT_SIGNATURE) += hash-checksum.o obj-$(CONFIG_SHA1) += sha1.o obj-$(CONFIG_SHA256) += sha256.o obj-$(CONFIG_SHA512_ALGO) += sha512.o diff --git a/lib/crypto/pkcs7_verify.c b/lib/crypto/pkcs7_verify.c index 320ba49f79..3c411f651f 100644 --- a/lib/crypto/pkcs7_verify.c +++ b/lib/crypto/pkcs7_verify.c @@ -15,7 +15,7 @@ #include <linux/bitops.h> #include <linux/compat.h> #include <linux/asn1.h> -#include <u-boot/rsa-checksum.h> +#include <u-boot/hash-checksum.h> #include <crypto/public_key.h> #include <crypto/pkcs7_parser.h> #else diff --git a/lib/crypto/x509_public_key.c b/lib/crypto/x509_public_key.c index 91810a8640..d557ab27ae 100644 --- a/lib/crypto/x509_public_key.c +++ b/lib/crypto/x509_public_key.c @@ -19,7 +19,7 @@ #include <linux/kernel.h> #ifdef __UBOOT__ #include <crypto/x509_parser.h> -#include <u-boot/rsa-checksum.h> +#include <u-boot/hash-checksum.h> #else #include <linux/slab.h> #include <keys/asymmetric-subtype.h> diff --git a/lib/rsa/rsa-checksum.c b/lib/hash-checksum.c similarity index 96% rename from lib/rsa/rsa-checksum.c rename to lib/hash-checksum.c index e60debb7df..d732ecc38f 100644 --- a/lib/rsa/rsa-checksum.c +++ b/lib/hash-checksum.c @@ -13,7 +13,8 @@ #else #include "fdt_host.h" #endif -#include <u-boot/rsa.h> +#include <hash.h> +#include <image.h>
int hash_calculate(const char *name, const struct image_region region[], diff --git a/lib/rsa/Makefile b/lib/rsa/Makefile index 8b75d41f04..c9ac72c1e2 100644 --- a/lib/rsa/Makefile +++ b/lib/rsa/Makefile @@ -5,6 +5,6 @@ # (C) Copyright 2000-2007 # Wolfgang Denk, DENX Software Engineering, wd@denx.de.
-obj-$(CONFIG_$(SPL_TPL_)RSA_VERIFY) += rsa-verify.o rsa-checksum.o +obj-$(CONFIG_$(SPL_TPL_)RSA_VERIFY) += rsa-verify.o obj-$(CONFIG_$(SPL_TPL_)RSA_VERIFY_WITH_PKEY) += rsa-keyprop.o obj-$(CONFIG_RSA_SOFTWARE_EXP) += rsa-mod-exp.o diff --git a/tools/Makefile b/tools/Makefile index 253a6b9706..b1595ad814 100644 --- a/tools/Makefile +++ b/tools/Makefile @@ -67,7 +67,7 @@ LIBFDT_OBJS := $(addprefix libfdt/, fdt.o fdt_ro.o fdt_wip.o fdt_sw.o fdt_rw.o \ fdt_strerror.o fdt_empty_tree.o fdt_addresses.o fdt_overlay.o)
RSA_OBJS-$(CONFIG_FIT_SIGNATURE) := $(addprefix lib/rsa/, \ - rsa-sign.o rsa-verify.o rsa-checksum.o \ + rsa-sign.o rsa-verify.o \ rsa-mod-exp.o)
AES_OBJS-$(CONFIG_FIT_CIPHER) := $(addprefix lib/aes/, \ @@ -105,6 +105,7 @@ dumpimage-mkimage-objs := aisimage.o \ $(ROCKCHIP_OBS) \ socfpgaimage.o \ lib/crc16.o \ + lib/hash-checksum.o \ lib/sha1.o \ lib/sha256.o \ lib/sha512.o \
Today the file is moved in lib and not in lib/crypto...
change the comment or the file location.
compiled if CONFIG_FIT_SIGNATURE = y
but after used in mkimage even if CONFIG_FIT_SIGNATURE is not used...
(see after dumpimage-mkimage-objs)
it could be more simple to have :
obj-y += hash-checksum.o
or add a new config CONFIG_HASH (but we need to managed dependancy in Kconfig / Makefile)
lib/hash-checksum.o is required here...
Regards
Patrick
fdt_add_bignum() is useful for algorithms other than just RSA. To allow its use for ECDSA, move it to a common file under lib/.
The new file is suffixed with '-libcrypto' because it has a direct dependency on openssl. This is due to the use of the "BIGNUM *" type.
Signed-off-by: Alexandru Gagniuc mr.nuke.me@gmail.com --- include/u-boot/fdt-libcrypto.h | 27 +++++++++++++ lib/fdt-libcrypto.c | 72 ++++++++++++++++++++++++++++++++++ lib/rsa/rsa-sign.c | 65 +----------------------------- tools/Makefile | 1 + 4 files changed, 101 insertions(+), 64 deletions(-) create mode 100644 include/u-boot/fdt-libcrypto.h create mode 100644 lib/fdt-libcrypto.c
diff --git a/include/u-boot/fdt-libcrypto.h b/include/u-boot/fdt-libcrypto.h new file mode 100644 index 0000000000..5142f37039 --- /dev/null +++ b/include/u-boot/fdt-libcrypto.h @@ -0,0 +1,27 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * Copyright (c) 2020, Alexandru Gagniuc mr.nuke.me@gmail.com + * Copyright (c) 2013, Google Inc. + */ + +#ifndef _FDT_LIBCRYPTO_H +#define _FDT_LIBCRYPTO_H + +#include <openssl/bn.h> + +/** + * fdt_add_bignum() - Write a libcrypto BIGNUM as an FDT property + * + * Convert a libcrypto BIGNUM * into a big endian array of integers. + * + * @blob: FDT blob to modify + * @noffset: Offset of the FDT node + * @prop_name: What to call the property in the FDT + * @num: pointer to a libcrypto big number + * @num_bits: How big is 'num' in bits? + * @return 0 if all good all working, -ve on horror + */ +int fdt_add_bignum(void *blob, int noffset, const char *prop_name, + BIGNUM *num, int num_bits); + +#endif /* _FDT_LIBCRYPTO_H */ diff --git a/lib/fdt-libcrypto.c b/lib/fdt-libcrypto.c new file mode 100644 index 0000000000..ecb0344c8f --- /dev/null +++ b/lib/fdt-libcrypto.c @@ -0,0 +1,72 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (c) 2020, Alexandru Gagniuc mr.nuke.me@gmail.com + * Copyright (c) 2013, Google Inc. + */ + +#include <libfdt.h> +#include <u-boot/fdt-libcrypto.h> + +int fdt_add_bignum(void *blob, int noffset, const char *prop_name, + BIGNUM *num, int num_bits) +{ + int nwords = num_bits / 32; + int size; + uint32_t *buf, *ptr; + BIGNUM *tmp, *big2, *big32, *big2_32; + BN_CTX *ctx; + int ret; + + tmp = BN_new(); + big2 = BN_new(); + big32 = BN_new(); + big2_32 = BN_new(); + + /* + * Note: This code assumes that all of the above succeed, or all fail. + * In practice memory allocations generally do not fail (unless the + * process is killed), so it does not seem worth handling each of these + * as a separate case. Technicaly this could leak memory on failure, + * but a) it won't happen in practice, and b) it doesn't matter as we + * will immediately exit with a failure code. + */ + if (!tmp || !big2 || !big32 || !big2_32) { + fprintf(stderr, "Out of memory (bignum)\n"); + return -ENOMEM; + } + ctx = BN_CTX_new(); + if (!ctx) { + fprintf(stderr, "Out of memory (bignum context)\n"); + return -ENOMEM; + } + BN_set_word(big2, 2L); + BN_set_word(big32, 32L); + BN_exp(big2_32, big2, big32, ctx); /* B = 2^32 */ + + size = nwords * sizeof(uint32_t); + buf = malloc(size); + if (!buf) { + fprintf(stderr, "Out of memory (%d bytes)\n", size); + return -ENOMEM; + } + + /* Write out modulus as big endian array of integers */ + for (ptr = buf + nwords - 1; ptr >= buf; ptr--) { + BN_mod(tmp, num, big2_32, ctx); /* n = N mod B */ + *ptr = cpu_to_fdt32(BN_get_word(tmp)); + BN_rshift(num, num, 32); /* N = N/B */ + } + + /* + * We try signing with successively increasing size values, so this + * might fail several times + */ + ret = fdt_setprop(blob, noffset, prop_name, buf, size); + free(buf); + BN_free(tmp); + BN_free(big2); + BN_free(big32); + BN_free(big2_32); + + return ret ? -FDT_ERR_NOSPACE : 0; +} diff --git a/lib/rsa/rsa-sign.c b/lib/rsa/rsa-sign.c index 1f0d81bd7a..557c690a6d 100644 --- a/lib/rsa/rsa-sign.c +++ b/lib/rsa/rsa-sign.c @@ -9,6 +9,7 @@ #include <string.h> #include <image.h> #include <time.h> +#include <u-boot/fdt-libcrypto.h> #include <openssl/bn.h> #include <openssl/rsa.h> #include <openssl/pem.h> @@ -680,70 +681,6 @@ int rsa_get_params(RSA *key, uint64_t *exponent, uint32_t *n0_invp, return ret; }
-static int fdt_add_bignum(void *blob, int noffset, const char *prop_name, - BIGNUM *num, int num_bits) -{ - int nwords = num_bits / 32; - int size; - uint32_t *buf, *ptr; - BIGNUM *tmp, *big2, *big32, *big2_32; - BN_CTX *ctx; - int ret; - - tmp = BN_new(); - big2 = BN_new(); - big32 = BN_new(); - big2_32 = BN_new(); - - /* - * Note: This code assumes that all of the above succeed, or all fail. - * In practice memory allocations generally do not fail (unless the - * process is killed), so it does not seem worth handling each of these - * as a separate case. Technicaly this could leak memory on failure, - * but a) it won't happen in practice, and b) it doesn't matter as we - * will immediately exit with a failure code. - */ - if (!tmp || !big2 || !big32 || !big2_32) { - fprintf(stderr, "Out of memory (bignum)\n"); - return -ENOMEM; - } - ctx = BN_CTX_new(); - if (!ctx) { - fprintf(stderr, "Out of memory (bignum context)\n"); - return -ENOMEM; - } - BN_set_word(big2, 2L); - BN_set_word(big32, 32L); - BN_exp(big2_32, big2, big32, ctx); /* B = 2^32 */ - - size = nwords * sizeof(uint32_t); - buf = malloc(size); - if (!buf) { - fprintf(stderr, "Out of memory (%d bytes)\n", size); - return -ENOMEM; - } - - /* Write out modulus as big endian array of integers */ - for (ptr = buf + nwords - 1; ptr >= buf; ptr--) { - BN_mod(tmp, num, big2_32, ctx); /* n = N mod B */ - *ptr = cpu_to_fdt32(BN_get_word(tmp)); - BN_rshift(num, num, 32); /* N = N/B */ - } - - /* - * We try signing with successively increasing size values, so this - * might fail several times - */ - ret = fdt_setprop(blob, noffset, prop_name, buf, size); - free(buf); - BN_free(tmp); - BN_free(big2); - BN_free(big32); - BN_free(big2_32); - - return ret ? -FDT_ERR_NOSPACE : 0; -} - int rsa_add_verify_data(struct image_sign_info *info, void *keydest) { BIGNUM *modulus, *r_squared; diff --git a/tools/Makefile b/tools/Makefile index b1595ad814..af7698fd01 100644 --- a/tools/Makefile +++ b/tools/Makefile @@ -106,6 +106,7 @@ dumpimage-mkimage-objs := aisimage.o \ socfpgaimage.o \ lib/crc16.o \ lib/hash-checksum.o \ + lib/fdt-libcrypto.o \ lib/sha1.o \ lib/sha256.o \ lib/sha512.o \
This part cause compilation issue when CONFIG_FIT_SIGNATURE is not defined / when openssl is not used
fdt-libcrypto.c:(.text+0x2f): undefined reference to `BN_new' fdt-libcrypto.c:(.text+0x37): undefined reference to `BN_new' fdt-libcrypto.c:(.text+0x44): undefined reference to `BN_new' fdt-libcrypto.c:(.text+0x51): undefined reference to `BN_new' fdt-libcrypto.c:(.text+0x7d): undefined reference to `BN_CTX_new' fdt-libcrypto.c:(.text+0x9d): undefined reference to `BN_set_word' fdt-libcrypto.c:(.text+0xaf): undefined reference to `BN_set_word' fdt-libcrypto.c:(.text+0xc5): undefined reference to `BN_exp' fdt-libcrypto.c:(.text+0x135): undefined reference to `BN_div' fdt-libcrypto.c:(.text+0x13d): undefined reference to `BN_get_word' fdt-libcrypto.c:(.text+0x172): undefined reference to `BN_rshift' fdt-libcrypto.c:(.text+0x1a9): undefined reference to `BN_free' fdt-libcrypto.c:(.text+0x1b3): undefined reference to `BN_free' fdt-libcrypto.c:(.text+0x1bd): undefined reference to `BN_free' fdt-libcrypto.c:(.text+0x1c5): undefined reference to `BN_free'
libssl not always include in mkimage, see the lines:
# MXSImage needs LibSSL ifneq ($(CONFIG_MX23)$(CONFIG_MX28)$(CONFIG_ARMADA_38X)$(CONFIG_ARMADA_39X)$(CONFIG_FIT_SIGNATURE)$(CONFIG_FIT_CIPHER),) HOSTCFLAGS_kwbimage.o += \ $(shell pkg-config --cflags libssl libcrypto 2> /dev/null || echo "") HOSTLDLIBS_mkimage += \ $(shell pkg-config --libs libssl libcrypto 2> /dev/null || echo "-lssl -lcrypto")
=> I propose to add the added lib only when CONFIG_FIT_SIGNATURE is
activated by removing dumpimage-mkimage-objs udpate and with:
- FIT_SIG_OBJS-$(CONFIG_FIT_SIGNATURE) := common/image-sig.o common/image-fit-sig.o
+ FIT_SIG_OBJS-$(CONFIG_FIT_SIGNATURE) := common/image-sig.o common/image-fit-sig.o lib/fdt-libcrypto.o
Regards
Patrick
This makes a large number of platform tools fail to build such as j7200_evm_a72.
mkimage supports rsa2048, and rsa4096 signatures. With newer silicon now supporting hardware-accelerated ECDSA, it makes sense to expand signing support to elliptic curves.
Implement host-side ECDSA signing and verification with libcrypto. Device-side implementation of signature verification is beyond the scope of this patch.
Signed-off-by: Alexandru Gagniuc mr.nuke.me@gmail.com --- common/image-sig.c | 11 +- include/image.h | 3 + include/u-boot/ecdsa.h | 94 +++++++++++ lib/ecdsa/ecdsa-libcrypto.c | 306 ++++++++++++++++++++++++++++++++++++ tools/Makefile | 3 + 5 files changed, 415 insertions(+), 2 deletions(-) create mode 100644 include/u-boot/ecdsa.h create mode 100644 lib/ecdsa/ecdsa-libcrypto.c
diff --git a/common/image-sig.c b/common/image-sig.c index 21dafe6b91..4b7d01f6c2 100644 --- a/common/image-sig.c +++ b/common/image-sig.c @@ -15,6 +15,7 @@ DECLARE_GLOBAL_DATA_PTR; #endif /* !USE_HOSTCC*/ #include <image.h> +#include <u-boot/ecdsa.h> #include <u-boot/rsa.h> #include <u-boot/hash-checksum.h>
@@ -82,8 +83,14 @@ struct crypto_algo crypto_algos[] = { .sign = rsa_sign, .add_verify_data = rsa_add_verify_data, .verify = rsa_verify, - } - + }, + { + .name = "ecdsa256", + .key_len = ECDSA256_BYTES, + .sign = ecdsa_sign, + .add_verify_data = ecdsa_add_verify_data, + .verify = ecdsa_verify, + }, };
struct padding_algo padding_algos[] = { diff --git a/include/image.h b/include/image.h index a55b11b3ae..6628173dca 100644 --- a/include/image.h +++ b/include/image.h @@ -1199,16 +1199,19 @@ int calculate_hash(const void *data, int data_len, const char *algo, # if defined(CONFIG_FIT_SIGNATURE) # define IMAGE_ENABLE_SIGN 1 # define IMAGE_ENABLE_VERIFY 1 +# define IMAGE_ENABLE_VERIFY_ECDSA 1 # define FIT_IMAGE_ENABLE_VERIFY 1 # include <openssl/evp.h> # else # define IMAGE_ENABLE_SIGN 0 # define IMAGE_ENABLE_VERIFY 0 +# define IMAGE_ENABLE_VERIFY_ECDSA 0 # define FIT_IMAGE_ENABLE_VERIFY 0 # endif #else # define IMAGE_ENABLE_SIGN 0 # define IMAGE_ENABLE_VERIFY CONFIG_IS_ENABLED(RSA_VERIFY) +# define IMAGE_ENABLE_VERIFY_ECDSA 0 # define FIT_IMAGE_ENABLE_VERIFY CONFIG_IS_ENABLED(FIT_SIGNATURE) #endif
diff --git a/include/u-boot/ecdsa.h b/include/u-boot/ecdsa.h new file mode 100644 index 0000000000..979690d966 --- /dev/null +++ b/include/u-boot/ecdsa.h @@ -0,0 +1,94 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * Copyright (c) 2020, Alexandru Gagniuc mr.nuke.me@gmail.com. + */ + +#ifndef _ECDSA_H +#define _ECDSA_H + +#include <errno.h> +#include <image.h> +#include <linux/kconfig.h> + +/** + * crypto_algo API impementation for ECDSA; + * @see "struct crypto_algo" + * @{ + */ +#if IMAGE_ENABLE_SIGN +/** + * sign() - calculate and return signature for given input data + * + * @info: Specifies key and FIT information + * @data: Pointer to the input data + * @data_len: Data length + * @sigp: Set to an allocated buffer holding the signature + * @sig_len: Set to length of the calculated hash + * + * This computes input data signature according to selected algorithm. + * Resulting signature value is placed in an allocated buffer, the + * pointer is returned as *sigp. The length of the calculated + * signature is returned via the sig_len pointer argument. The caller + * should free *sigp. + * + * @return: 0, on success, -ve on error + */ +int ecdsa_sign(struct image_sign_info *info, const struct image_region region[], + int region_count, uint8_t **sigp, uint *sig_len); + +/** + * add_verify_data() - Add verification information to FDT + * + * Add public key information to the FDT node, suitable for + * verification at run-time. The information added depends on the + * algorithm being used. I just copypasted this from rsa.h. + * + * @info: Specifies key and FIT information + * @keydest: Destination FDT blob for public key data + * @return: 0, on success, -ENOSPC if the keydest FDT blob ran out of space, + * other -ve value on error + */ +int ecdsa_add_verify_data(struct image_sign_info *info, void *keydest); +#else +static inline +int ecdsa_sign(struct image_sign_info *info, const struct image_region region[], + int region_count, uint8_t **sigp, uint *sig_len) +{ + return -ENXIO; +} + +static inline +int ecdsa_add_verify_data(struct image_sign_info *info, void *keydest) +{ + return -ENXIO; +} +#endif + +#if IMAGE_ENABLE_VERIFY_ECDSA +/** + * verify() - Verify a signature against some data + * + * @info: Specifies key and FIT information + * @data: Pointer to the input data + * @data_len: Data length + * @sig: Signature + * @sig_len: Number of bytes in signature + * @return 0 if verified, -ve on error + */ +int ecdsa_verify(struct image_sign_info *info, + const struct image_region region[], int region_count, + uint8_t *sig, uint sig_len); +#else +static inline +int ecdsa_verify(struct image_sign_info *info, + const struct image_region region[], int region_count, + uint8_t *sig, uint sig_len) +{ + return -ENXIO; +} +#endif +/** @} */ + +#define ECDSA256_BYTES (256 / 8) + +#endif diff --git a/lib/ecdsa/ecdsa-libcrypto.c b/lib/ecdsa/ecdsa-libcrypto.c new file mode 100644 index 0000000000..322880963f --- /dev/null +++ b/lib/ecdsa/ecdsa-libcrypto.c @@ -0,0 +1,306 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * ECDSA image signing implementation using libcrypto backend + * + * The signature is a binary representation of the (R, S) points, padded to the + * key size. The signature will be (2 * key_size_bits) / 8 bytes. + * + * Deviations from behavior of RSA equivalent: + * - Verification uses private key. This is not technically required, but a + * limitation on how clumsy the openssl API is to use. + * - Handling of keys and key paths: + * - The '-K' key directory option must contain path to the key file, + * instead of the key directory. + * - No assumptions are made about the file extension of the key + * - The 'key-name-hint' property is only used for naming devicetree nodes, + * but is not used for looking up keys on the filesystem. + * + * Copyright (c) 2020,2021, Alexandru Gagniuc mr.nuke.me@gmail.com + */ + +#include <u-boot/ecdsa.h> +#include <u-boot/fdt-libcrypto.h> +#include <openssl/ssl.h> +#include <openssl/ec.h> +#include <openssl/bn.h> + +/* Image signing context for openssl-libcrypto */ +struct signer { + EVP_PKEY *evp_key; /* Pointer to EVP_PKEY object */ + EC_KEY *ecdsa_key; /* Pointer to EC_KEY object */ + void *hash; /* Pointer to hash used for verification */ + void *signature; /* Pointer to output signature. Do not free()!*/ +}; + +static int alloc_ctx(struct signer *ctx, const struct image_sign_info *info) +{ + memset(ctx, 0, sizeof(*ctx)); + + if (!OPENSSL_init_ssl(0, NULL)) { + fprintf(stderr, "Failure to init SSL library\n"); + return -1; + } + + ctx->hash = malloc(info->checksum->checksum_len); + ctx->signature = malloc(info->crypto->key_len * 2); + + if (!ctx->hash || !ctx->signature) + return -ENOMEM; + + return 0; +} + +static void free_ctx(struct signer *ctx) +{ + if (ctx->ecdsa_key) + EC_KEY_free(ctx->ecdsa_key); + + if (ctx->evp_key) + EVP_PKEY_free(ctx->evp_key); + + if (ctx->hash) + free(ctx->hash); +} + +/* + * Convert an ECDSA signature to raw format + * + * openssl DER-encodes 'binary' signatures. We want the signature in a raw + * (R, S) point pair. So we have to dance a bit. + */ +static void ecdsa_sig_encode_raw(void *buf, const ECDSA_SIG *sig, size_t order) +{ + int point_bytes = order; + const BIGNUM *r, *s; + uintptr_t s_buf; + + ECDSA_SIG_get0(sig, &r, &s); + s_buf = (uintptr_t)buf + point_bytes; + BN_bn2binpad(r, buf, point_bytes); + BN_bn2binpad(s, (void *)s_buf, point_bytes); +} + +/* Get a signature from a raw encoding */ +static ECDSA_SIG *ecdsa_sig_from_raw(void *buf, size_t order) +{ + int point_bytes = order; + uintptr_t s_buf; + ECDSA_SIG *sig; + BIGNUM *r, *s; + + sig = ECDSA_SIG_new(); + if (!sig) + return NULL; + + s_buf = (uintptr_t)buf + point_bytes; + r = BN_bin2bn(buf, point_bytes, NULL); + s = BN_bin2bn((void *)s_buf, point_bytes, NULL); + ECDSA_SIG_set0(sig, r, s); + + return sig; +} + +/* ECDSA key size in bytes */ +static size_t ecdsa_key_size_bytes(const EC_KEY *key) +{ + const EC_GROUP *group; + + group = EC_KEY_get0_group(key); + return EC_GROUP_order_bits(group) / 8; +} + +static int read_key(struct signer *ctx, const char *key_name) +{ + FILE *f = fopen(key_name, "r"); + + if (!f) { + fprintf(stderr, "Can not get key file '%s'\n", key_name); + return -ENOENT; + } + + ctx->evp_key = PEM_read_PrivateKey(f, NULL, NULL, NULL); + fclose(f); + if (!ctx->evp_key) { + fprintf(stderr, "Can not read key from '%s'\n", key_name); + return -EIO; + } + + if (EVP_PKEY_id(ctx->evp_key) != EVP_PKEY_EC) { + fprintf(stderr, "'%s' is not an ECDSA key\n", key_name); + return -EINVAL; + } + + ctx->ecdsa_key = EVP_PKEY_get1_EC_KEY(ctx->evp_key); + if (!ctx->ecdsa_key) + fprintf(stderr, "Can not extract ECDSA key\n"); + + return (ctx->ecdsa_key) ? 0 : -EINVAL; +} + +/* Prepare a 'signer' context that's ready to sign and verify. */ +static int prepare_ctx(struct signer *ctx, const struct image_sign_info *info) +{ + const char *kname = info->keydir; + int key_len_bytes, ret; + + ret = alloc_ctx(ctx, info); + if (ret) + return ret; + + ret = read_key(ctx, kname); + if (ret) + return ret; + + key_len_bytes = ecdsa_key_size_bytes(ctx->ecdsa_key); + if (key_len_bytes != info->crypto->key_len) { + fprintf(stderr, "Expected a %u-bit key, got %u-bit key\n", + info->crypto->key_len * 8, key_len_bytes * 8); + return -EINVAL; + } + + return 0; +} + +static int do_sign(struct signer *ctx, struct image_sign_info *info, + const struct image_region region[], int region_count) +{ + const struct checksum_algo *algo = info->checksum; + ECDSA_SIG *sig; + + algo->calculate(algo->name, region, region_count, ctx->hash); + sig = ECDSA_do_sign(ctx->hash, algo->checksum_len, ctx->ecdsa_key); + + ecdsa_sig_encode_raw(ctx->signature, sig, info->crypto->key_len); + + return 0; +} + +static int ecdsa_check_signature(struct signer *ctx, struct image_sign_info *info) +{ + ECDSA_SIG *sig; + int okay; + + sig = ecdsa_sig_from_raw(ctx->signature, info->crypto->key_len); + if (!sig) + return -ENOMEM; + + okay = ECDSA_do_verify(ctx->hash, info->checksum->checksum_len, + sig, ctx->ecdsa_key); + if (!okay) + fprintf(stderr, "WARNING: Signature is fake news!\n"); + + ECDSA_SIG_free(sig); + return !okay; +} + +static int do_verify(struct signer *ctx, struct image_sign_info *info, + const struct image_region region[], int region_count, + uint8_t *raw_sig, uint sig_len) +{ + const struct checksum_algo *algo = info->checksum; + + if (sig_len != info->crypto->key_len * 2) { + fprintf(stderr, "Signature has wrong length\n"); + return -EINVAL; + } + + memcpy(ctx->signature, raw_sig, sig_len); + algo->calculate(algo->name, region, region_count, ctx->hash); + + return ecdsa_check_signature(ctx, info); +} + +int ecdsa_sign(struct image_sign_info *info, const struct image_region region[], + int region_count, uint8_t **sigp, uint *sig_len) +{ + struct signer ctx; + int ret; + + ret = prepare_ctx(&ctx, info); + if (ret >= 0) { + do_sign(&ctx, info, region, region_count); + *sigp = ctx.signature; + *sig_len = info->crypto->key_len * 2; + + ret = ecdsa_check_signature(&ctx, info); + } + + free_ctx(&ctx); + return ret; +} + +int ecdsa_verify(struct image_sign_info *info, + const struct image_region region[], int region_count, + uint8_t *sig, uint sig_len) +{ + struct signer ctx; + int ret; + + ret = prepare_ctx(&ctx, info); + if (ret >= 0) + ret = do_verify(&ctx, info, region, region_count, sig, sig_len); + + free_ctx(&ctx); + return ret; +} + +static int do_add(struct signer *ctx, void *fdt, const char *key_node_name) +{ + int signature_node, key_node, ret, key_bits; + const char *curve_name; + const EC_GROUP *group; + const EC_POINT *point; + BIGNUM *x, *y; + + signature_node = fdt_subnode_offset(fdt, 0, FIT_SIG_NODENAME); + if (signature_node < 0) { + fprintf(stderr, "Could not find 'signature node: %s\n", + fdt_strerror(signature_node)); + return signature_node; + } + + key_node = fdt_add_subnode(fdt, signature_node, key_node_name); + if (key_node < 0) { + fprintf(stderr, "Could not create '%s' node: %s\n", + key_node_name, fdt_strerror(key_node)); + return key_node; + } + + group = EC_KEY_get0_group(ctx->ecdsa_key); + key_bits = EC_GROUP_order_bits(group); + curve_name = OBJ_nid2sn(EC_GROUP_get_curve_name(group)); + /* Let 'x' and 'y' memory leak by not BN_free()'ing them. */ + x = BN_new(); + y = BN_new(); + point = EC_KEY_get0_public_key(ctx->ecdsa_key); + EC_POINT_get_affine_coordinates(group, point, x, y, NULL); + + ret = fdt_setprop_string(fdt, key_node, "ecdsa,curve", curve_name); + if (ret < 0) + return ret; + + ret = fdt_add_bignum(fdt, key_node, "ecdsa,x-point", x, key_bits); + if (ret < 0) + return ret; + + ret = fdt_add_bignum(fdt, key_node, "ecdsa,y-point", y, key_bits); + if (ret < 0) + return ret; + + return 0; +} + +int ecdsa_add_verify_data(struct image_sign_info *info, void *fdt) +{ + const char *fdt_key_name; + struct signer ctx; + int ret; + + fdt_key_name = info->keyname ? info->keyname : "default-key"; + ret = prepare_ctx(&ctx, info); + if (ret >= 0) + do_add(&ctx, fdt, fdt_key_name); + + free_ctx(&ctx); + return ret; +} diff --git a/tools/Makefile b/tools/Makefile index af7698fd01..a4f7b7e80c 100644 --- a/tools/Makefile +++ b/tools/Makefile @@ -70,6 +70,8 @@ RSA_OBJS-$(CONFIG_FIT_SIGNATURE) := $(addprefix lib/rsa/, \ rsa-sign.o rsa-verify.o \ rsa-mod-exp.o)
+ECDSA_OBJS-$(CONFIG_FIT_SIGNATURE) := $(addprefix lib/ecdsa/, ecdsa-libcrypto.o) + AES_OBJS-$(CONFIG_FIT_CIPHER) := $(addprefix lib/aes/, \ aes-encrypt.o aes-decrypt.o)
@@ -119,6 +121,7 @@ dumpimage-mkimage-objs := aisimage.o \ gpimage.o \ gpimage-common.o \ mtk_image.o \ + $(ECDSA_OBJS-y) \ $(RSA_OBJS-y) \ $(AES_OBJS-y)
Signed-off-by: Alexandru Gagniuc mr.nuke.me@gmail.com --- doc/uImage.FIT/signature.txt | 7 ++++++- 1 file changed, 6 insertions(+), 1 deletion(-)
diff --git a/doc/uImage.FIT/signature.txt b/doc/uImage.FIT/signature.txt index a3455889ed..0139295d33 100644 --- a/doc/uImage.FIT/signature.txt +++ b/doc/uImage.FIT/signature.txt @@ -142,7 +142,7 @@ public key in U-Boot's control FDT (using CONFIG_OF_CONTROL). Public keys should be stored as sub-nodes in a /signature node. Required properties are:
-- algo: Algorithm name (e.g. "sha1,rsa2048") +- algo: Algorithm name (e.g. "sha1,rsa2048" or "sha256,ecdsa256")
Optional properties are:
@@ -167,6 +167,11 @@ For RSA the following are mandatory: - rsa,r-squared: (2^num-bits)^2 as a big-endian multi-word integer - rsa,n0-inverse: -1 / modulus[0] mod 2^32
+For ECDSA the following are mandatory: +- ecdsa,curve: Name of ECDSA curve (e.g. "prime256v1") +- ecdsa,x-point: Public key X coordinate as a big-endian multi-word integer +- ecdsa,y-point: Public key Y coordinate as a big-endian multi-word integer + These parameters can be added to a binary device tree using parameter -K of the mkimage command::
We wish to use pycryptodomex to verify code paths involving ECDSA signatures. Add it to requirements.txt so that they get picked up automatically .gitlab and .azure tasks
Signed-off-by: Alexandru Gagniuc mr.nuke.me@gmail.com --- test/py/requirements.txt | 1 + 1 file changed, 1 insertion(+)
diff --git a/test/py/requirements.txt b/test/py/requirements.txt index cf251186f4..5a25a9d5d5 100644 --- a/test/py/requirements.txt +++ b/test/py/requirements.txt @@ -10,6 +10,7 @@ packaging==19.2 pbr==5.4.3 pluggy==0.13.0 py==1.8.0 +pycryptodomex==3.9.8 pyparsing==2.4.2 pytest==5.2.1 python-mimeparse==1.6.0
Add a test to make sure that the ECDSA signatures generated by mkimage can be verified successfully. pyCryptodomex was chosen as the crypto library because it integrates much better with python code. Using openssl would have been unnecessarily painful.
Signed-off-by: Alexandru Gagniuc mr.nuke.me@gmail.com --- test/py/tests/test_fit_ecdsa.py | 111 ++++++++++++++++++++++++++++++++ 1 file changed, 111 insertions(+) create mode 100644 test/py/tests/test_fit_ecdsa.py
diff --git a/test/py/tests/test_fit_ecdsa.py b/test/py/tests/test_fit_ecdsa.py new file mode 100644 index 0000000000..6cadb0cbb5 --- /dev/null +++ b/test/py/tests/test_fit_ecdsa.py @@ -0,0 +1,111 @@ +# SPDX-License-Identifier: GPL-2.0+ +# +# Copyright (c) 2020,2021 Alexandru Gagniuc mr.nuke.me@gmail.com + +""" +Test ECDSA signing of FIT images + +This test uses mkimage to sign an existing FIT image with an ECDSA key. The +signature is then extracted, and verified against pyCryptodome. +This test doesn't run the sandbox. It only checks the host tool 'mkimage' +""" + +import pytest +import u_boot_utils as util +from Cryptodome.Hash import SHA256 +from Cryptodome.PublicKey import ECC +from Cryptodome.Signature import DSS + +class SignableFitImage(object): + """ Helper to manipulate a FIT image on disk """ + def __init__(self, cons, file_name): + self.fit = file_name + self.cons = cons + self.signable_nodes = set() + + def __fdt_list(self, path): + return util.run_and_log(self.cons, f'fdtget -l {self.fit} {path}') + + def __fdt_set(self, node, **prop_value): + for prop, value in prop_value.items(): + util.run_and_log(self.cons, f'fdtput -ts {self.fit} {node} {prop} {value}') + + def __fdt_get_binary(self, node, prop): + numbers = util.run_and_log(self.cons, f'fdtget -tbi {self.fit} {node} {prop}') + + bignum = bytearray() + for little_num in numbers.split(): + bignum.append(int(little_num)) + + return bignum + + def find_signable_image_nodes(self): + for node in self.__fdt_list('/images').split(): + image = f'/images/{node}' + if 'signature' in self.__fdt_list(image): + self.signable_nodes.add(image) + + return self.signable_nodes + + def change_signature_algo_to_ecdsa(self): + for image in self.signable_nodes: + self.__fdt_set(f'{image}/signature', algo='sha256,ecdsa256') + + def sign(self, mkimage, key_file): + util.run_and_log(self.cons, [mkimage, '-F', self.fit, f'-k{key_file}']) + + def check_signatures(self, key): + for image in self.signable_nodes: + raw_sig = self.__fdt_get_binary(f'{image}/signature', 'value') + raw_bin = self.__fdt_get_binary(image, 'data') + + sha = SHA256.new(raw_bin) + verifier = DSS.new(key, 'fips-186-3') + verifier.verify(sha, bytes(raw_sig)) + + +@pytest.mark.buildconfigspec('fit_signature') +@pytest.mark.requiredtool('dtc') +@pytest.mark.requiredtool('fdtget') +@pytest.mark.requiredtool('fdtput') +def test_fit_ecdsa(u_boot_console): + """ Test that signatures generated by mkimage are legible. """ + def generate_ecdsa_key(): + return ECC.generate(curve='prime256v1') + + def assemble_fit_image(dest_fit, its, destdir): + dtc_args = f'-I dts -O dtb -i {destdir}' + util.run_and_log(cons, [mkimage, '-D', dtc_args, '-f', its, dest_fit]) + + def dtc(dts): + dtb = dts.replace('.dts', '.dtb') + util.run_and_log(cons, f'dtc {datadir}/{dts} -O dtb -o {tempdir}/{dtb}') + + cons = u_boot_console + mkimage = cons.config.build_dir + '/tools/mkimage' + datadir = cons.config.source_dir + '/test/py/tests/vboot/' + tempdir = cons.config.result_dir + key_file = f'{tempdir}/ecdsa-test-key.pem' + fit_file = f'{tempdir}/test.fit' + dtc('sandbox-kernel.dts') + + key = generate_ecdsa_key() + + # Create a fake kernel image -- zeroes will do just fine + with open(f'{tempdir}/test-kernel.bin', 'w') as fd: + fd.write(500 * chr(0)) + + # invokations of mkimage expect to read the key from disk + with open(key_file, 'w') as f: + f.write(key.export_key(format='PEM')) + + assemble_fit_image(fit_file, f'{datadir}/sign-images-sha256.its', tempdir) + + fit = SignableFitImage(cons, fit_file) + nodes = fit.find_signable_image_nodes() + if len(nodes) == 0: + raise ValueError('FIT image has no "/image" nodes with "signature"') + + fit.change_signature_algo_to_ecdsa() + fit.sign(mkimage, key_file) + fit.check_signatures(key)
Hi Alexandru,
## Purpose and intent > > The purpose of this series is to enable ECDSA as an alternative to RSA for FIT signing. As new chips have built-in support for ECDSA >
verified boot, it makes sense to stick to one signing algorithm, > instead of resorting to RSA for u-boot images. > > The focus of this series is signing an existing FIT image: > > mkimage -F some-existing.fit --signing-key some/key.pem > > Signing while assembling a FIT is not a tested use case. # > Implementation > > ## Code organization > > Unlike the RSA path, which mixes host and firmware code in the same, > source files, this series keeps a very clear distinction. > ecdsa-libcrypto.c is intended to be used for host code and only for > host code. There is more opportunity for code reuse this way. > > ## Signing > > There is one major difference from the RSA path. The 'key-name-hint' > property is ignored in the ECDSA path. There are two reasons: (1) The > intent of 'key-name-hint' is not clear (2) Initial implementation is > much easier to review > I found in doc/uImage.FIT/signature.txt the description
- key-name-hint: Name of key to use for signing. The keys will normally be in a single directory (parameter -k to mkimage). For a given key <name>, its private key is stored in <name>.key and the certificate is stored in <name>.crt.
And i check the code and the result is a little different:
include/image.h:1000:#define FIT_KEY_HINT "key-name-hint"
common/image-fit-sig.c:89: info->keyname = fdt_getprop(fit, noffset, FIT_KEY_HINT, NULL);
lib/rsa/rsa-sign.c:742: ret = fdt_setprop_string(keydest, node, FIT_KEY_HINT, info->keyname);
tools/image-host.c: info->keyname = fdt_getprop(fit, noffset, FIT_KEY_HINT, NULL);
=> "keyname" provided the name oft he node in device tree for verify
lib/rsa/rsa-verify.c:518:
snprintf(name, sizeof(name), "key-%s", info->keyname); node = fdt_subnode_offset(blob, sig_node, name); ret = rsa_verify_with_keynode(info, hash, sig, sig_len, node);
=> "keyname" provide the name of the key provider (pem file or key prefix for engine ) in keydir directory
lib/rsa/rsa-sign.c:537: ret = rsa_get_priv_key(info->keydir, info->keyname, e, &rsa);
lib/rsa/rsa-sign.c:702: ret = rsa_get_pub_key(info->keydir, info->keyname, e, &rsa);
dir and namle are used to get crt or key file.
=> rsa_pem_get_priv_key = "%s/%s.key", keydir, name
=> rsa_pem_get_pub_key = "%s/%s.crt", keydir, name
so today the RSA features seens more compete based on openssl (with ENGINE and pkcs11 support for exmaple)
and keydir / keyname seens clear enought...
PS: I think the engine part could be shared between RSA and EDCSA part.
There is an intentional side-effect. The RSA path takes > 'key-name-hint' to decide which key file to read from disk. In the >
context of "which fdt node describes my signing key", this makes > sense. On the other hand, 'key-name-hint' is also used as the > basename of where the key is on the filesystem. This leads to some > funny search paths, such as > > "some/dir/(null).key" So I am using the -K option to mkimage as the > _full_ path to the key file. It doesn't have to be named .key, it > doesn't have to be named .crt, and it doesn't have to exist in a > particular directory (as is the case for the RSA path). I understand > and recognize that this discrepancy must be resolved, but resolving > it right now would make the initial implementation much harder and > longer. marex@denx.de
This new option -K with full path will be permanent added to mkimage
or it is a temporarily solution (for initial ECDSA implementation).
If it is permanent it should be also supported in RSA mode ?
=> for example: -K allow to override the "key-name-hint" value
Why you can't easily could use the existing -k option and "key-name-hint" to keep the current RSA behavior for EDCSA (even without ENGINE support)
For me, EDCSA part can rely on "key-name-hint" to chose the expected key file to read the pem from disk
info->keydir / params->keydir (from option -k)
info->keyname
perhaps : edcsa_get_priv_key() => "%s/%s.pem", keydir, keyname
in prepare_ctx() function
and in the test:
keyname = "ecdsa-test-key"
keydir = "${tempdir}"
or I miss something.....
key_file > > # Testing > > test/py/tests/test_fit_ecdsa.py is implemented withe
the goal to > check that the signing is done correctly, and that the signature is > encoded in the proper raw format. Verification is done with > pyCryptodomex, so this test will catch both coding errors and openssl > bugs. This is the only scope of testing proposed here. > > > # Things not yet resolved: - is mkimage '-k' supposed to be a > directory or file path I'm hoping I can postpone answering this > question pending further discussion.
Sorry to open debate.
I propose to change the test with previous proposal.
mkimage -F /local/home/frq07632/views/u-boot/build-sandbox/test.fit -k /local/home/frq07632/views/u-boot/build-sandbox/ecdsa-test-key.pem
=> -k use directory as RSA
with test/py/tests/vboot/sign-images-sha256.its fdt@1 { .... signature@1 { algo = "sha1,rsa2048"; - key-name-hint = "dev"; + key-name-hint = "ecdsa-test-key.pem";
Or change key_file = f'{tempdir}/ecdsa-test-key.pem'
to '{tempdir}/dev.pem' file (as: key-name-hint = "dev";)
Regards.
Patrick
On 1/28/21 10:40 AM, Patrick DELAUNAY wrote:
Hi Alexandru,
Hi Patrick
[snip]
You are correct that the ECDSA path does not use the "key-name-hint". And this deviates from what RSA does. This is intentional.
[snip]> so today the RSA features seens more compete based on openssl (with
The the common case with image signing is that one wants to sign an image with a key. keyname comes from the console, and keydir comes from the FIT image, which contradicts this simplicity.
Another issue is incorporating this into a bigger build system like yocto. Now mkimage would impose a specific directory structure for signing keys. This would not be ideal.
I don't see the benefit of using the engine, and it seems highly libcrypto specific. It would be a lot more code, with no useful functionality -- we can ecdsa sign with the simpler code.
[snip]
Yes and no. It is temporary in that we'd like to update the RSA path to be consistent with the ECDSA path. It's permanent in that we want to have the -'k' option to specify the key filename instead of the key dir. At least that's my understanding given the previous discussion with Simon.
[snip]
Sorry to open debate. I propose to change the test with previous proposal.
[snip]
This would go against us wanting to decouple the key filename from the key name. Consider haing several keys:
dev-key-frobnozzle.pem prov-key-frobnozzle-r1.pem prov-key-frobnozzle-r2.pem prov-key-frobnozzle-r3-after-hack-mitigation.pem
One might not want to expose those key names in the .its. The issue is, when the fit-image is created, the key filename must be known. But when the signing happens on a separate machine, the filename really isn't known.
So we should really use the "key-name-hint" as a hint rather than a filename or part of a filename.
Alex
Hi Alex,
Hi Alexandru,
Hi Patrick
[snip]
We need to join these two up though. We can't add a new way of doing things whenever we add a new algorithm.
It more likely requires a standard filename for keys...I wonder how this works in yocto at present?
The hope was that the same API could be used...is that possible?
[snip]
But we do need to either move RSA over (in the same patch series ) or use a different flag. I'm leaning towards a different flag, since if we are not changing RSA, it is just going to get confusing.
[snip]
[snip]
Yes it is just a hint. We must not rely on it. Its only purpose is to hopefully speed up verification since fewer signatures might need to be tried.
participants (5)
Alex G.
Alexandru Gagniuc
Patrick DELAUNAY
