[PATCH v2] cmd: bcb: select user(0) hwpart in __bcb_load()
For some blk operations, it's possible that a different hw partition gets selected via blk_dselect_hwpart(). In that case, only the region of the device covered by that partition is accessible.
This breaks "bcb load" which attempts to read the gpt and assumes it's on the user(0) hw partition:
=> bcb load 2 misc GUID Partition Table Header signature is wrong: 0xDE7B17AD07D9E5D6 != 0x5452415020494645 find_valid_gpt: *** ERROR: Invalid GPT *** GUID Partition Table Header signature is wrong: 0x0 != 0x5452415020494645 find_valid_gpt: *** ERROR: Invalid Backup GPT *** Error: mmc 2:misc read failed (-2)
Add a fail-safe in __bcb_load() to ensure we will always read from the user(0) hwpartition.
This fixes the following fastboot sequence:
$ fastboot erase mmc2boot1 # switch to hwpart1 $ fastboot reboot bootloader # switch to hwpart0, then reads GPT
Signed-off-by: Mattijs Korpershoek mkorpershoek@baylibre.com --- Changes in v2:
* Move hwpart selection into the bcb command instead of fb_mmc.c * Link to v1: https://lore.kernel.org/r/20221010-switch-hwpart-v1-0-52cbd34c72b7@baylibre.... --- cmd/bcb.c | 11 +++++++++++ 1 file changed, 11 insertions(+)
diff --git a/cmd/bcb.c b/cmd/bcb.c index 1622a90c97f0..02d0c70d87e2 100644 --- a/cmd/bcb.c +++ b/cmd/bcb.c @@ -14,6 +14,7 @@ #include <part.h> #include <malloc.h> #include <memalign.h> +#include <linux/err.h>
enum bcb_cmd { BCB_CMD_LOAD, @@ -128,6 +129,16 @@ static int __bcb_load(int devnum, const char *partp) goto err_read_fail; }
+ /* + * always select the USER mmc hwpart in case another + * blk operation selected a different hwpart + */ + ret = blk_dselect_hwpart(desc, 0); + if (IS_ERR_VALUE(ret)) { + ret = -ENODEV; + goto err_read_fail; + } + part = simple_strtoul(partp, &endp, 0); if (*endp == '\0') { ret = part_get_info(desc, part, &info);
--- base-commit: c4c32e359662aa95d9dbda2bd1272181bd9cb830 change-id: 20221011-usb-hwpart-599c278980b3
Changes in v2:
- Move hwpart selection into the bcb command instead of fb_mmc.c
- Link to v1: https://lore.kernel.org/r/20221010-switch-hwpart-v1-0-52cbd34c72b7@baylibre....
- ret = blk_dselect_hwpart(desc, 0);
- if (IS_ERR_VALUE(ret)) {
ret = -ENODEV;
goto err_read_fail;
- part = simple_strtoul(partp, &endp, 0); if (*endp == '\0') { ret = part_get_info(desc, part, &info);
Reviewed-by: Sean Anderson sean.anderson@seco.com
Signed-off-by: Mattijs Korpershoek mkorpershoek@baylibre.com Reviewed-by: Sean Anderson sean.anderson@seco.com
Mattijs Korpershoek
Sean Anderson
