[PATCH v2 0/3] Add StarFive JH7110 PCIe drvier support
This patchset needs to apply after patchset in [1]. These PCIe series patches are based on the JH7110 RISC-V SoC and VisionFive V2 board.
[1] https://patchwork.ozlabs.org/project/uboot/cover/20230303032432.7837-1-yanho...
The PCIe driver depends on gpio, pinctrl, clk and reset driver to do init. The PCIe dts configuation includes all these setting.
The PCIe drivers codes has been tested on the VisionFive V2 boards. The test devices includes M.2 NVMe SSD and Realtek 8169 Ethernet adapter.
previous patch version
v1: https://patchwork.ozlabs.org/project/uboot/cover/20230223105240.15180-1-mind...
changes v1->v2 1. remove clock commit. The pcie clocks change has been includeded in [1]. 2. Using GENMASK marco1 in patch1. 3. remove the syscon dts node in patch3. The syscon dts dts node has been included in [1].
The JH7110 minimal system patchset upstream is in progress. PCIe driver patches is based on this patchset.
The JH7110 minimal system patchset details are listed in [1].
For more JH7110 and visionFive v2 information and support, you can visit RVspace wiki[2].
Mason Huo (3): starfive: pci: Add StarFive JH7110 pcie driver configs: starfive-jh7110: Add support for PCIe host driver riscv: dts: starfive: Enable PCIe host controller
.../dts/jh7110-starfive-visionfive-2.dtsi | 99 ++++ arch/riscv/dts/jh7110.dtsi | 75 +++ configs/starfive_visionfive2_defconfig | 9 + drivers/pci/Kconfig | 11 + drivers/pci/Makefile | 1 + drivers/pci/pcie_starfive_jh7110.c | 478 ++++++++++++++++++ 6 files changed, 673 insertions(+) create mode 100644 drivers/pci/pcie_starfive_jh7110.c
base-commit: b0eda49bc9b00503366f2ec431be0178caf9e9b5 prerequisite-patch-id: a84452ba131408ff842b65ae19a3a05f64b3ff60 prerequisite-patch-id: bb320a2102f46d2b2d08b4467cbcdb92050767b8 prerequisite-patch-id: ef5e9d61f7392c7d2e5321aa8a10996ca8eae5fc prerequisite-patch-id: 26dfdb401d680ecd9449acf09131cf4790e987b7 prerequisite-patch-id: a0cfa5d8cdb49bbe9d4739afa90991f882950881 prerequisite-patch-id: a0509f01172e24b3d163f4701496b0349435bdc0 prerequisite-patch-id: d834ece14ffb525b8c3e661e78736692f33fca9b prerequisite-patch-id: aa95c1c047d0b7dae469586873a42932d613411d prerequisite-patch-id: ebc26ed3f97f7babc0fc805152acb578f5eff922 prerequisite-patch-id: 81a83d6fc1e71ce190f9151577deb0c5cd382a20 prerequisite-patch-id: ff5bd799e4cb905fef6cf1cd0ce757980e1d34b7 prerequisite-patch-id: a341d4e8a8e25cb711309123939235fcb3c10c1a prerequisite-patch-id: 749e4eafb431857ee2bec4ac8e78a682f6a57588 prerequisite-patch-id: 04cd7779c7464c7be683cd2718baee8c6554791d prerequisite-patch-id: 25cb7c602018ec89abce43d8835926ac3356f5db prerequisite-patch-id: cf1af96990b01e1025ec50d0b49c79f92f64f352 prerequisite-patch-id: cc5878da5f03e7e1d2c15e88537fd2a93bf47e53
Add pcie driver for StarFive JH7110, the driver depends on starfive gpio, pinctrl, clk and reset driver to do init.
Several devices are tested: a) M.2 NVMe SSD b) Realtek 8169 Ethernet adapter.
Signed-off-by: Mason Huo mason.huo@starfivetech.com Signed-off-by: Minda Chen minda.chen@starfivetech.com --- drivers/pci/Kconfig | 11 + drivers/pci/Makefile | 1 + drivers/pci/pcie_starfive_jh7110.c | 478 +++++++++++++++++++++++++++++ 3 files changed, 490 insertions(+) create mode 100644 drivers/pci/pcie_starfive_jh7110.c
diff --git a/drivers/pci/Kconfig b/drivers/pci/Kconfig index ef328d2652..e7b0ff5bc3 100644 --- a/drivers/pci/Kconfig +++ b/drivers/pci/Kconfig @@ -374,4 +374,15 @@ config PCIE_UNIPHIER Say Y here if you want to enable PCIe controller support on UniPhier SoCs.
+config PCIE_STARFIVE_JH7110 + bool "Enable Starfive JH7110 PCIe driver" + depends on STARFIVE_JH7110 + depends on PINCTRL_STARFIVE_JH7110 + depends on CLK_JH7110 + depends on RESET_JH7110 + default y + help + Say Y here if you want to enable PCIe controller support on + StarFive JH7110 SoC. + endif diff --git a/drivers/pci/Makefile b/drivers/pci/Makefile index 49506e7ba5..bbe3323bb5 100644 --- a/drivers/pci/Makefile +++ b/drivers/pci/Makefile @@ -49,3 +49,4 @@ obj-$(CONFIG_PCI_OCTEONTX) += pci_octeontx.o obj-$(CONFIG_PCIE_OCTEON) += pcie_octeon.o obj-$(CONFIG_PCIE_DW_SIFIVE) += pcie_dw_sifive.o obj-$(CONFIG_PCIE_UNIPHIER) += pcie_uniphier.o +obj-$(CONFIG_PCIE_STARFIVE_JH7110) += pcie_starfive_jh7110.o diff --git a/drivers/pci/pcie_starfive_jh7110.c b/drivers/pci/pcie_starfive_jh7110.c new file mode 100644 index 0000000000..5ccef1ef02 --- /dev/null +++ b/drivers/pci/pcie_starfive_jh7110.c @@ -0,0 +1,478 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * StarFive PLDA PCIe host controller driver + * + * Copyright (c) 2023 Starfive, Inc. + * Author: Mason Huo mason.huo@starfivetech.com + * + */ + +#include <common.h> +#include <clk.h> +#include <dm.h> +#include <generic-phy.h> +#include <pci.h> +#include <power-domain.h> +#include <regmap.h> +#include <reset.h> +#include <syscon.h> +#include <asm/global_data.h> +#include <asm/io.h> +#include <asm-generic/gpio.h> +#include <dm/device_compat.h> +#include <dm/pinctrl.h> +#include <linux/delay.h> +#include <linux/iopoll.h> +#include <power/regulator.h> + +DECLARE_GLOBAL_DATA_PTR; + +#define GEN_SETTINGS 0x80 +#define PCIE_PCI_IDS 0x9C +#define PCIE_WINROM 0xFC +#define PMSG_SUPPORT_RX 0x3F0 +#define PCI_MISC 0xB4 + +#define PLDA_EP_ENABLE 0 +#define PLDA_RP_ENABLE 1 + +#define IDS_REVISION_ID 0x02 +#define IDS_PCI_TO_PCI_BRIDGE 0x060400 +#define IDS_CLASS_CODE_SHIFT 8 + +#define PREF_MEM_WIN_64_SUPPORT BIT(3) +#define PMSG_LTR_SUPPORT BIT(2) +#define PLDA_FUNCTION_DIS BIT(15) +#define PLDA_FUNC_NUM 4 +#define PLDA_PHY_FUNC_SHIFT 9 + +#define XR3PCI_ATR_AXI4_SLV0 0x800 +#define XR3PCI_ATR_SRC_ADDR_LOW 0x0 +#define XR3PCI_ATR_SRC_ADDR_HIGH 0x4 +#define XR3PCI_ATR_TRSL_ADDR_LOW 0x8 +#define XR3PCI_ATR_TRSL_ADDR_HIGH 0xc +#define XR3PCI_ATR_TRSL_PARAM 0x10 +#define XR3PCI_ATR_TABLE_OFFSET 0x20 +#define XR3PCI_ATR_MAX_TABLE_NUM 8 + +#define XR3PCI_ATR_SRC_WIN_SIZE_SHIFT 1 +#define XR3PCI_ATR_SRC_ADDR_MASK GENMASK(31, 12) +#define XR3PCI_ATR_TRSL_ADDR_MASK GENMASK(31, 12) +#define XR3_PCI_ECAM_SIZE 28 +#define XR3PCI_ATR_TRSL_DIR BIT(22) +/* IDs used in the XR3PCI_ATR_TRSL_PARAM */ +#define XR3PCI_ATR_TRSLID_PCIE_MEMORY 0x0 +#define XR3PCI_ATR_TRSLID_PCIE_CONFIG 0x1 + +#define ECAM_BUS_SHIFT 20 +#define ECAM_DEV_SHIFT 15 +#define ECAM_FUNC_SHIFT 12 +/* Secondary bus number offset in config space */ +#define PCI_SECONDARY_BUS 0x19 + +/* system control */ +#define STG_SYSCON_K_RP_NEP_MASK BIT(8) +#define STG_SYSCON_AXI4_SLVL_ARFUNC_MASK GENMASK(22, 8) +#define STG_SYSCON_AXI4_SLVL_ARFUNC_SHIFT 8 +#define STG_SYSCON_AXI4_SLVL_AWFUNC_MASK GENMASK(14, 0) +#define STG_SYSCON_CLKREQ_MASK BIT(22) +#define STG_SYSCON_CKREF_SRC_SHIFT 18 +#define STG_SYSCON_CKREF_SRC_MASK GENMASK(19, 18) + +struct starfive_pcie { + struct udevice *dev; + + void __iomem *reg_base; + void __iomem *cfg_base; + + struct regmap *regmap; + u32 stg_arfun; + u32 stg_awfun; + u32 stg_rp_nep; + + struct clk_bulk clks; + struct reset_ctl_bulk rsts; + + int atr_table_num; + int first_busno; +}; + +static int starfive_pcie_addr_valid(pci_dev_t bdf, int first_busno) +{ + if ((PCI_BUS(bdf) == first_busno) && (PCI_DEV(bdf) > 0)) + return 0; + if ((PCI_BUS(bdf) == first_busno + 1) && (PCI_DEV(bdf) > 0)) + return 0; + + return 1; +} + +static int starfive_pcie_off_conf(pci_dev_t bdf, uint offset) +{ + unsigned int bus = PCI_BUS(bdf); + unsigned int dev = PCI_DEV(bdf); + unsigned int func = PCI_FUNC(bdf); + + return (bus << ECAM_BUS_SHIFT) | (dev << ECAM_DEV_SHIFT) | + (func << ECAM_FUNC_SHIFT) | offset; +} + +static bool starfive_pcie_hide_rc_bar(pci_dev_t bdf, int offset) +{ + /* Only root port 1 is in use */ + if ((PCI_BUS(bdf) == 0) && + (offset == PCI_BASE_ADDRESS_0 || offset == PCI_BASE_ADDRESS_1)) + return true; + + return false; +} + +static int starfive_pcie_conf_address(const struct udevice *udev, pci_dev_t bdf, + uint offset, void **paddr) +{ + struct starfive_pcie *priv = dev_get_priv(udev); + int where = starfive_pcie_off_conf(bdf, offset); + + if (!starfive_pcie_addr_valid(bdf, priv->first_busno)) + return -EINVAL; + + *paddr = (void *)(priv->cfg_base + where); + return 0; +} + +static int starfive_pcie_config_read(const struct udevice *udev, pci_dev_t bdf, + uint offset, ulong *valuep, + enum pci_size_t size) +{ + /* Make sure the LAST TLP is finished, before reading vendor ID. */ + if (offset == PCI_VENDOR_ID) + mdelay(20); + + return pci_generic_mmap_read_config(udev, starfive_pcie_conf_address, + bdf, offset, valuep, size); +} + +int starfive_pcie_config_write(struct udevice *udev, pci_dev_t bdf, + uint offset, ulong value, + enum pci_size_t size) +{ + if (starfive_pcie_hide_rc_bar(bdf, offset)) + return 0; + + return pci_generic_mmap_write_config(udev, starfive_pcie_conf_address, + bdf, offset, value, size); +} + +static int starfive_pcie_set_atr_entry(struct starfive_pcie *priv, phys_addr_t src_addr, + phys_addr_t trsl_addr, size_t window_size, + int trsl_param) +{ + void __iomem *base = + priv->reg_base + XR3PCI_ATR_AXI4_SLV0; + + /* Support AXI4 Slave 0 Address Translation Tables 0-7. */ + if (priv->atr_table_num >= XR3PCI_ATR_MAX_TABLE_NUM) { + dev_err(priv->dev, "ATR table number %d exceeds max num\n", + priv->atr_table_num); + return -EINVAL; + } + base += XR3PCI_ATR_TABLE_OFFSET * priv->atr_table_num; + priv->atr_table_num++; + + /* X3PCI_ATR_SRC_ADDR_LOW: + * - bit 0: enable entry, + * - bits 1-6: ATR window size: total size in bytes: 2^(ATR_WSIZE + 1) + * - bits 7-11: reserved + * - bits 12-31: start of source address + */ + writel((lower_32_bits(src_addr) & XR3PCI_ATR_SRC_ADDR_MASK) | + (fls(window_size) - 1) << XR3PCI_ATR_SRC_WIN_SIZE_SHIFT | 1, + base + XR3PCI_ATR_SRC_ADDR_LOW); + writel(upper_32_bits(src_addr), base + XR3PCI_ATR_SRC_ADDR_HIGH); + writel((lower_32_bits(trsl_addr) & XR3PCI_ATR_TRSL_ADDR_MASK), + base + XR3PCI_ATR_TRSL_ADDR_LOW); + writel(upper_32_bits(trsl_addr), base + XR3PCI_ATR_TRSL_ADDR_HIGH); + writel(trsl_param, base + XR3PCI_ATR_TRSL_PARAM); + + dev_dbg(priv->dev, "ATR entry: 0x%010llx %s 0x%010llx [0x%010llx] (param: 0x%06x)\n", + src_addr, (trsl_param & XR3PCI_ATR_TRSL_DIR) ? "<-" : "->", + trsl_addr, (u64)window_size, trsl_param); + return 0; +} + +static int starfive_pcie_atr_init(struct starfive_pcie *priv) +{ + struct udevice *ctlr = pci_get_controller(priv->dev); + struct pci_controller *hose = dev_get_uclass_priv(ctlr); + int i, ret; + + /* As the two host bridges in JH7110 soc have the same default + * address translation table, this cause the second root port can't + * access it's host bridge config space correctly. + * To workaround, config the ATR of host bridge config space by SW. + */ + + ret = starfive_pcie_set_atr_entry(priv, + (phys_addr_t)priv->cfg_base, + 0, + 1 << XR3_PCI_ECAM_SIZE, + XR3PCI_ATR_TRSLID_PCIE_CONFIG); + if (ret) + return ret; + + for (i = 0; i < hose->region_count; i++) { + if (hose->regions[i].flags == PCI_REGION_SYS_MEMORY) + continue; + + /* Only support identity mappings. */ + if (hose->regions[i].bus_start != + hose->regions[i].phys_start) + return -EINVAL; + + ret = starfive_pcie_set_atr_entry(priv, + hose->regions[i].phys_start, + hose->regions[i].bus_start, + hose->regions[i].size, + XR3PCI_ATR_TRSLID_PCIE_MEMORY); + if (ret) + return ret; + } + + return 0; +} + +static int starfive_pcie_get_syscon(struct udevice *dev) +{ + struct starfive_pcie *priv = dev_get_priv(dev); + struct udevice *syscon; + struct ofnode_phandle_args syscfg_phandle; + u32 cells[4]; + int ret; + + /* get corresponding syscon phandle */ + ret = dev_read_phandle_with_args(dev, "starfive,stg-syscon", NULL, 0, 0, + &syscfg_phandle); + + if (ret < 0) { + dev_err(dev, "Can't get syscfg phandle: %d\n", ret); + return ret; + } + + ret = uclass_get_device_by_ofnode(UCLASS_SYSCON, syscfg_phandle.node, + &syscon); + if (ret) { + dev_err(dev, "Unable to find syscon device (%d)\n", ret); + return ret; + } + + priv->regmap = syscon_get_regmap(syscon); + if (!priv->regmap) { + dev_err(dev, "Unable to find regmap\n"); + return -ENODEV; + } + + /* get syscon register offset */ + ret = dev_read_u32_array(dev, "starfive,stg-syscon", + cells, ARRAY_SIZE(cells)); + if (ret) { + dev_err(dev, "Get syscon register err %d\n", ret); + return -EINVAL; + } + + dev_dbg(dev, "Get syscon values: %x, %x, %x\n", + cells[1], cells[2], cells[3]); + priv->stg_arfun = cells[1]; + priv->stg_awfun = cells[2]; + priv->stg_rp_nep = cells[3]; + + return 0; +} + +static int starfive_pcie_parse_dt(struct udevice *dev) +{ + struct starfive_pcie *priv = dev_get_priv(dev); + int ret; + + priv->reg_base = (void *)dev_read_addr_name(dev, "reg"); + if (priv->reg_base == (void __iomem *)FDT_ADDR_T_NONE) { + dev_err(dev, "Missing required reg address range\n"); + return -EINVAL; + } + + priv->cfg_base = (void *)dev_read_addr_name(dev, "config"); + if (priv->cfg_base == (void __iomem *)FDT_ADDR_T_NONE) { + dev_err(dev, "Missing required config address range"); + return -EINVAL; + } + + ret = starfive_pcie_get_syscon(dev); + if (ret) { + dev_err(dev, "Can't get syscon: %d\n", ret); + return ret; + } + + ret = reset_get_bulk(dev, &priv->rsts); + if (ret) { + dev_err(dev, "Can't get reset: %d\n", ret); + return ret; + } + + ret = clk_get_bulk(dev, &priv->clks); + if (ret) { + dev_err(dev, "Can't get clock: %d\n", ret); + return ret; + } + + return 0; +} + +static int starfive_pcie_init_port(struct udevice *dev) +{ + int ret, i; + unsigned int value; + struct starfive_pcie *priv = dev_get_priv(dev); + + ret = clk_enable_bulk(&priv->clks); + if (ret) { + dev_err(dev, "Failed to enable clks (ret=%d)\n", ret); + return ret; + } + + ret = reset_deassert_bulk(&priv->rsts); + if (ret) { + dev_err(dev, "Failed to deassert resets (ret=%d)\n", ret); + goto err_deassert_clk; + } + + ret = pinctrl_select_state(dev, "perst-active"); + if (ret) { + dev_err(dev, "Set perst-active pinctrl failed: %d\n", ret); + goto err_deassert_reset; + } + + /* Disable physical functions except #0 */ + for (i = 1; i < PLDA_FUNC_NUM; i++) { + regmap_update_bits(priv->regmap, + priv->stg_arfun, + STG_SYSCON_AXI4_SLVL_ARFUNC_MASK, + (i << PLDA_PHY_FUNC_SHIFT) << + STG_SYSCON_AXI4_SLVL_ARFUNC_SHIFT); + regmap_update_bits(priv->regmap, + priv->stg_awfun, + STG_SYSCON_AXI4_SLVL_AWFUNC_MASK, + i << PLDA_PHY_FUNC_SHIFT); + + value = readl(priv->reg_base + PCI_MISC); + value |= PLDA_FUNCTION_DIS; + writel(value, priv->reg_base + PCI_MISC); + } + + /* Disable physical functions */ + regmap_update_bits(priv->regmap, + priv->stg_arfun, + STG_SYSCON_AXI4_SLVL_ARFUNC_MASK, + 0); + regmap_update_bits(priv->regmap, + priv->stg_awfun, + STG_SYSCON_AXI4_SLVL_AWFUNC_MASK, + 0); + + /* Enable root port */ + value = readl(priv->reg_base + GEN_SETTINGS); + value |= PLDA_RP_ENABLE; + writel(value, priv->reg_base + GEN_SETTINGS); + + /* PCIe PCI Standard Configuration Identification Settings. */ + value = (IDS_PCI_TO_PCI_BRIDGE << IDS_CLASS_CODE_SHIFT) | IDS_REVISION_ID; + writel(value, priv->reg_base + PCIE_PCI_IDS); + + /* The LTR message forwarding of PCIe Message Reception was set by core + * as default, but the forward id & addr are also need to be reset. + * If we do not disable LTR message forwarding here, or set a legal + * forwarding address, the kernel will get stuck after this driver probe. + * To workaround, disable the LTR message forwarding support on + * PCIe Message Reception. + */ + value = readl(priv->reg_base + PMSG_SUPPORT_RX); + value &= ~PMSG_LTR_SUPPORT; + writel(value, priv->reg_base + PMSG_SUPPORT_RX); + + /* Prefetchable memory window 64-bit addressing support */ + value = readl(priv->reg_base + PCIE_WINROM); + value |= PREF_MEM_WIN_64_SUPPORT; + writel(value, priv->reg_base + PCIE_WINROM); + + starfive_pcie_atr_init(priv); + + /* Ensure that PERST has been asserted for at least 300 ms */ + mdelay(300); + ret = pinctrl_select_state(dev, "perst-default"); + if (ret) { + dev_err(dev, "Set perst-default pinctrl failed: %d\n", ret); + return ret; + } + + return 0; + +err_deassert_clk: + clk_disable_bulk(&priv->clks); +err_deassert_reset: + reset_assert_bulk(&priv->rsts); + return ret; +} + +static int starfive_pcie_probe(struct udevice *dev) +{ + struct starfive_pcie *priv = dev_get_priv(dev); + int ret; + + priv->atr_table_num = 0; + priv->dev = dev; + priv->first_busno = dev_seq(dev); + + ret = starfive_pcie_parse_dt(dev); + if (ret) + return ret; + + regmap_update_bits(priv->regmap, + priv->stg_rp_nep, + STG_SYSCON_K_RP_NEP_MASK, + STG_SYSCON_K_RP_NEP_MASK); + + regmap_update_bits(priv->regmap, + priv->stg_awfun, + STG_SYSCON_CKREF_SRC_MASK, + 2 << STG_SYSCON_CKREF_SRC_SHIFT); + + regmap_update_bits(priv->regmap, + priv->stg_awfun, + STG_SYSCON_CLKREQ_MASK, + STG_SYSCON_CLKREQ_MASK); + + ret = starfive_pcie_init_port(dev); + if (ret) + return ret; + + dev_err(dev, "Starfive PCIe bus probed.\n"); + + return 0; +} + +static const struct dm_pci_ops starfive_pcie_ops = { + .read_config = starfive_pcie_config_read, + .write_config = starfive_pcie_config_write, +}; + +static const struct udevice_id starfive_pcie_ids[] = { + { .compatible = "starfive,jh7110-pcie" }, + { } +}; + +U_BOOT_DRIVER(starfive_pcie_drv) = { + .name = "starfive_7110_pcie", + .id = UCLASS_PCI, + .of_match = starfive_pcie_ids, + .ops = &starfive_pcie_ops, + .probe = starfive_pcie_probe, + .priv_auto = sizeof(struct starfive_pcie), +};
Hello! See few comments below.
- bool "Enable Starfive JH7110 PCIe driver"
- depends on STARFIVE_JH7110
- depends on PINCTRL_STARFIVE_JH7110
- depends on CLK_JH7110
- depends on RESET_JH7110
- default y
- help
- StarFive PLDA PCIe host controller driver
- Copyright (c) 2023 Starfive, Inc.
- Author: Mason Huo mason.huo@starfivetech.com
Please do not duplicate standard PCI macros and constants. In U-Boot they are already available in include/pci_ids.h header file.
Please do not implement duplicate PCIe ECAM code. U-Boot and also Linux kernel already provides PCIE_ECAM_OFFSET() macro.
Unused.
- struct udevice *dev;
- void __iomem *reg_base;
- void __iomem *cfg_base;
- struct regmap *regmap;
- u32 stg_arfun;
- u32 stg_awfun;
- u32 stg_rp_nep;
- struct clk_bulk clks;
- struct reset_ctl_bulk rsts;
- int atr_table_num;
- int first_busno;
- if ((PCI_BUS(bdf) == first_busno) && (PCI_DEV(bdf) > 0))
- if ((PCI_BUS(bdf) == first_busno + 1) && (PCI_DEV(bdf) > 0))
If fisrt_busno is the bus of the root port then first_busno+1 does not have to bus of the PCIe device on the other end of the link from the root port. See for example pci_mvebu.c how this logic is handled. You probably want to also limit access to non-zero function of root port unless you have multifunction root-port device.
- return 1;
- unsigned int bus = PCI_BUS(bdf);
- unsigned int dev = PCI_DEV(bdf);
- unsigned int func = PCI_FUNC(bdf);
- return (bus << ECAM_BUS_SHIFT) | (dev << ECAM_DEV_SHIFT) |
- /* Only root port 1 is in use */
- if ((PCI_BUS(bdf) == 0) &&
This looks like an incorrect check for the bus of he root port. See for example pci_mvebu.c where logic should be correct.
I guess you wanted to use: PCI_BUS(bdf)-dev_seq(udev)
return true;
- return false;
- struct starfive_pcie *priv = dev_get_priv(udev);
- int where = starfive_pcie_off_conf(bdf, offset);
- if (!starfive_pcie_addr_valid(bdf, priv->first_busno))
return -EINVAL;
Is this check needed? Does it mean that ECAM returns bogus information for disconnected devices, that it needs to be manually filtered? (Which is against PCIe spec).
- *paddr = (void *)(priv->cfg_base + where);
- /* Make sure the LAST TLP is finished, before reading vendor ID. */
- if (offset == PCI_VENDOR_ID)
mdelay(20);
This looks strange. There is some bug / errata that reading vendor id from ECAM does not work correctly?
- return pci_generic_mmap_read_config(udev, starfive_pcie_conf_address,
- if (starfive_pcie_hide_rc_bar(bdf, offset))
Why you are ignoring writes to some offset, but not ignoring reads? And ignoring results in no-error (return value 0)?
- return pci_generic_mmap_write_config(udev, starfive_pcie_conf_address,
int trsl_param)
- void __iomem *base =
- /* Support AXI4 Slave 0 Address Translation Tables 0-7. */
- if (priv->atr_table_num >= XR3PCI_ATR_MAX_TABLE_NUM) {
return -EINVAL;
- base += XR3PCI_ATR_TABLE_OFFSET * priv->atr_table_num;
- priv->atr_table_num++;
- /* X3PCI_ATR_SRC_ADDR_LOW:
- writel((lower_32_bits(src_addr) & XR3PCI_ATR_SRC_ADDR_MASK) |
- writel(upper_32_bits(src_addr), base + XR3PCI_ATR_SRC_ADDR_HIGH);
- writel((lower_32_bits(trsl_addr) & XR3PCI_ATR_TRSL_ADDR_MASK),
- writel(upper_32_bits(trsl_addr), base + XR3PCI_ATR_TRSL_ADDR_HIGH);
- writel(trsl_param, base + XR3PCI_ATR_TRSL_PARAM);
- dev_dbg(priv->dev, "ATR entry: 0x%010llx %s 0x%010llx [0x%010llx] (param: 0x%06x)\n",
- struct udevice *ctlr = pci_get_controller(priv->dev);
- struct pci_controller *hose = dev_get_uclass_priv(ctlr);
- int i, ret;
- /* As the two host bridges in JH7110 soc have the same default
- ret = starfive_pcie_set_atr_entry(priv,
0,
- if (ret)
return ret;
- for (i = 0; i < hose->region_count; i++) {
continue;
return -EINVAL;
if (ret)
return ret;
- struct starfive_pcie *priv = dev_get_priv(dev);
- struct udevice *syscon;
- struct ofnode_phandle_args syscfg_phandle;
- u32 cells[4];
- int ret;
- /* get corresponding syscon phandle */
- ret = dev_read_phandle_with_args(dev, "starfive,stg-syscon", NULL, 0, 0,
&syscfg_phandle);
- if (ret < 0) {
return ret;
- ret = uclass_get_device_by_ofnode(UCLASS_SYSCON, syscfg_phandle.node,
&syscon);
- if (ret) {
return ret;
- priv->regmap = syscon_get_regmap(syscon);
- if (!priv->regmap) {
return -ENODEV;
- /* get syscon register offset */
- ret = dev_read_u32_array(dev, "starfive,stg-syscon",
- if (ret) {
return -EINVAL;
- dev_dbg(dev, "Get syscon values: %x, %x, %x\n",
- priv->stg_arfun = cells[1];
- priv->stg_awfun = cells[2];
- priv->stg_rp_nep = cells[3];
- int ret;
- priv->reg_base = (void *)dev_read_addr_name(dev, "reg");
- if (priv->reg_base == (void __iomem *)FDT_ADDR_T_NONE) {
return -EINVAL;
- priv->cfg_base = (void *)dev_read_addr_name(dev, "config");
- if (priv->cfg_base == (void __iomem *)FDT_ADDR_T_NONE) {
return -EINVAL;
- ret = starfive_pcie_get_syscon(dev);
- if (ret) {
return ret;
- ret = reset_get_bulk(dev, &priv->rsts);
- if (ret) {
return ret;
- ret = clk_get_bulk(dev, &priv->clks);
- if (ret) {
return ret;
- int ret, i;
- unsigned int value;
- ret = clk_enable_bulk(&priv->clks);
- if (ret) {
return ret;
- ret = reset_deassert_bulk(&priv->rsts);
- if (ret) {
- ret = pinctrl_select_state(dev, "perst-active");
- if (ret) {
- /* Disable physical functions except #0 */
- for (i = 1; i < PLDA_FUNC_NUM; i++) {
priv->stg_arfun,
priv->stg_awfun,
- /* Disable physical functions */
- regmap_update_bits(priv->regmap,
priv->stg_arfun,
0);
priv->stg_awfun,
0);
- /* Enable root port */
- value = readl(priv->reg_base + GEN_SETTINGS);
- value |= PLDA_RP_ENABLE;
- writel(value, priv->reg_base + GEN_SETTINGS);
- /* PCIe PCI Standard Configuration Identification Settings. */
- value = (IDS_PCI_TO_PCI_BRIDGE << IDS_CLASS_CODE_SHIFT) | IDS_REVISION_ID;
- writel(value, priv->reg_base + PCIE_PCI_IDS);
- /* The LTR message forwarding of PCIe Message Reception was set by core
- value = readl(priv->reg_base + PMSG_SUPPORT_RX);
- value &= ~PMSG_LTR_SUPPORT;
- writel(value, priv->reg_base + PMSG_SUPPORT_RX);
- /* Prefetchable memory window 64-bit addressing support */
- value = readl(priv->reg_base + PCIE_WINROM);
- value |= PREF_MEM_WIN_64_SUPPORT;
- writel(value, priv->reg_base + PCIE_WINROM);
- starfive_pcie_atr_init(priv);
- /* Ensure that PERST has been asserted for at least 300 ms */
- mdelay(300);
- ret = pinctrl_select_state(dev, "perst-default");
- if (ret) {
return ret;
+err_deassert_clk:
- clk_disable_bulk(&priv->clks);
- reset_assert_bulk(&priv->rsts);
- return ret;
- int ret;
- priv->atr_table_num = 0;
- priv->dev = dev;
- priv->first_busno = dev_seq(dev);
- ret = starfive_pcie_parse_dt(dev);
- if (ret)
return ret;
priv->stg_rp_nep,
priv->stg_awfun,
priv->stg_awfun,
- ret = starfive_pcie_init_port(dev);
- if (ret)
return ret;
- dev_err(dev, "Starfive PCIe bus probed.\n");
- .read_config = starfive_pcie_config_read,
- .write_config = starfive_pcie_config_write,
- { .compatible = "starfive,jh7110-pcie" },
- .name = "starfive_7110_pcie",
- .id = UCLASS_PCI,
- .of_match = starfive_pcie_ids,
- .ops = &starfive_pcie_ops,
- .probe = starfive_pcie_probe,
- .priv_auto = sizeof(struct starfive_pcie),
2.17.1
- default y
- help
ok
Unused.
ok
- u32 stg_arfun;
- u32 stg_awfun;
- u32 stg_rp_nep;
- int first_busno;
root port limitation can follow the pci_mvebu.c
- return 1;
I guess you wanted to use: PCI_BUS(bdf)-dev_seq(udev) [1] This is a work around method. Our PCIe support 64bit. But the config
space is 16KB. If no limitation here, uboot will set high 32 bit base address to 0xfffffff after init. But this will make kernel pcie failed. This value will be not cleared. While kernel read the base address first. kernel pcie can not work. And our IC we can not reset the PCIe to clear this value. I dont know how to fix it expcept this method.
return true;
- return false;
return -EINVAL;
I found nvme device can not work if the non-zero function of root port without limitation. But I will try to fix it. Maybe I can remove this.
mdelay(20);
I will remove this. It is not a errata of reading the vendor ID.
Why you are ignoring writes to some offset, but not ignoring reads? And ignoring results in no-error (return value 0)? The same as [1]
int trsl_param)
return -EINVAL;
- int i, ret;
0,
- if (ret)
return ret;
continue;
return -EINVAL;
if (ret)
return ret;
- u32 cells[4];
- int ret;
&syscfg_phandle);
- if (ret < 0) {
return ret;
&syscon);
- if (ret) {
return ret;
return -ENODEV;
- if (ret) {
return -EINVAL;
- int ret;
return -EINVAL;
return -EINVAL;
- if (ret) {
return ret;
- if (ret) {
return ret;
- if (ret) {
return ret;
- int ret, i;
- if (ret) {
return ret;
- if (ret) {
- if (ret) {
priv->stg_arfun,
priv->stg_awfun,
priv->stg_arfun,
0);
priv->stg_awfun,
0);
- mdelay(300);
- if (ret) {
return ret;
+err_deassert_clk:
- return ret;
- int ret;
- priv->dev = dev;
- if (ret)
return ret;
priv->stg_rp_nep,
priv->stg_awfun,
priv->stg_awfun,
- if (ret)
return ret;
- .id = UCLASS_PCI,
2.17.1
- default y
- help
ok
Unused.
ok
- u32 stg_arfun;
- u32 stg_awfun;
- u32 stg_rp_nep;
- int first_busno;
It can follow, but question is why it should follow pci_mvebu.c. Marvell PCIe controller does not use ECAM, instead it uses Intel PCI conf1 mechanism and moreover it contains HW bugs which are workarounded in that filter code.
- return 1;
I just do not understand. BAR configures PCIe MEM space mapping and it is fully independent of the PCIe config space. I do not see reason for limitation.
Well, this sounds like a bug in kernel, which should be fixed or at least reported.
And if in the u-boot is workaround for particular kernel bug then it should be properly documented with information in which kernel version was bug fixed. Otherwise u-boot code stay in non-maintenanceble state.
return true;
- return false;
return -EINVAL;
So you have multifunction root port device (if you are talking about non-zero function)? And what does it mean that NVMe device cannot work? Can you connect your device to second function of root port if it works?
mdelay(20);
But this does not explain why is result ignored. I'm just lost what is aim or expected result here.
int trsl_param)
return -EINVAL;
- int i, ret;
0,
- if (ret)
return ret;
continue;
return -EINVAL;
if (ret)
return ret;
- u32 cells[4];
- int ret;
&syscfg_phandle);
- if (ret < 0) {
return ret;
&syscon);
- if (ret) {
return ret;
return -ENODEV;
- if (ret) {
return -EINVAL;
- int ret;
return -EINVAL;
return -EINVAL;
- if (ret) {
return ret;
- if (ret) {
return ret;
- if (ret) {
return ret;
- int ret, i;
- if (ret) {
return ret;
- if (ret) {
- if (ret) {
priv->stg_arfun,
priv->stg_awfun,
priv->stg_arfun,
0);
priv->stg_awfun,
0);
- mdelay(300);
- if (ret) {
return ret;
+err_deassert_clk:
- return ret;
- int ret;
- priv->dev = dev;
- if (ret)
return ret;
priv->stg_rp_nep,
priv->stg_awfun,
priv->stg_awfun,
- if (ret)
return ret;
- .id = UCLASS_PCI,
2.17.1
- default y
- help
ok
Unused.
ok
- u32 stg_arfun;
- u32 stg_awfun;
- u32 stg_rp_nep;
- int first_busno;
starfive_pcie_addr_valid limit the access the non-zero device.
The limitaion reason is list below For PCIe bus of JH7110 SoC limitation, The PCIe host bridge of just support one device.
(The simple topic graph) ================ JH7110 SoC ================== [Processor] | (Root Complex) | ------------------------------ [Host Bridge Domain 0000] | (Bus 0) | [Bus 0 Device 0] | ================ JH7110 SoC ================== | (BUS 1) | [BUS 1 Device 0]
To avoid access non-zero device config space, add this limitation.
And I can see designware PCIe code (pcie_dw_common.c) have the same code logic(pcie_dw_addr_valid).
- return 1;
I am not sure whether it is a kernel issue. For this are workaround codes, I will remove this function (starfive_pcie_hide_rc_bar) in next version. Remove this codes uboot PCIe still can work.
return true;
- return false;
return -EINVAL;
Please ignore this reply. I have replied wrong message. I am sorry about this It is not 'non-zero function'. I should said 'non-zero device'. The check reason see starfive_pcie_addr_valid reply.
Please ignore previous reply. And the test NVMe devices do not support multi-function.
mdelay(20);
Since it is a workaround codes for booting kernel, (Writing root port base0 and base 1 register cause kernel PCIe driver can not work, So just limtation writing base0 and bas1). I will remove starfive_pcie_hide_rc_bar as previous said.
int trsl_param)
return -EINVAL;
- int i, ret;
0,
- if (ret)
return ret;
continue;
return -EINVAL;
if (ret)
return ret;
- u32 cells[4];
- int ret;
&syscfg_phandle);
- if (ret < 0) {
return ret;
&syscon);
- if (ret) {
return ret;
return -ENODEV;
- if (ret) {
return -EINVAL;
- int ret;
return -EINVAL;
return -EINVAL;
- if (ret) {
return ret;
- if (ret) {
return ret;
- if (ret) {
return ret;
- int ret, i;
- if (ret) {
return ret;
- if (ret) {
- if (ret) {
priv->stg_arfun,
priv->stg_awfun,
priv->stg_arfun,
0);
priv->stg_awfun,
0);
- mdelay(300);
- if (ret) {
return ret;
+err_deassert_clk:
- return ret;
- int ret;
- priv->dev = dev;
- if (ret)
return ret;
priv->stg_rp_nep,
priv->stg_awfun,
priv->stg_awfun,
- if (ret)
return ret;
- .id = UCLASS_PCI,
2.17.1
- default y
- help
ok
Unused.
ok
- u32 stg_arfun;
- u32 stg_awfun;
- u32 stg_rp_nep;
- int first_busno;
Ok. The hierarchy is quite standard. But question is why you need to do explicit filtering in the driver? ECAM should correctly work also when you ask non-existent device (e.g. by returning all-ones).
Is the driver working fine also without filtering?
In mvebu is explicit filtering because of HW bug which cause that HW ignores device number. And so device 0 is aliased to device 2, 3, 4... So to prevent kernel to see tons of non-existent devices, mvebu driver has to filter access.
But normally any special logic should not be needed unless there is a HW bug. HW just normally returns to kernel that there is no other device.
mvebu driver is not something useful for taking as a template driver for building a new driver because it contains tons of code for workarounding real HW issues without which other kernel (and userspace) PCIe parts do not work.
- return 1;
If everything is working fine then I do not see reason for having it there.
return true;
- return false;
return -EINVAL;
mdelay(20);
int trsl_param)
return -EINVAL;
- int i, ret;
0,
- if (ret)
return ret;
continue;
return -EINVAL;
if (ret)
return ret;
- u32 cells[4];
- int ret;
&syscfg_phandle);
- if (ret < 0) {
return ret;
&syscon);
- if (ret) {
return ret;
return -ENODEV;
- if (ret) {
return -EINVAL;
- int ret;
return -EINVAL;
return -EINVAL;
- if (ret) {
return ret;
- if (ret) {
return ret;
- if (ret) {
return ret;
- int ret, i;
- if (ret) {
return ret;
- if (ret) {
- if (ret) {
priv->stg_arfun,
priv->stg_awfun,
priv->stg_arfun,
0);
priv->stg_awfun,
0);
- mdelay(300);
- if (ret) {
return ret;
+err_deassert_clk:
- return ret;
- int ret;
- priv->dev = dev;
- if (ret)
return ret;
priv->stg_rp_nep,
priv->stg_awfun,
priv->stg_awfun,
- if (ret)
return ret;
- .id = UCLASS_PCI,
2.17.1
- default y
- help
ok
Unused.
ok
- u32 stg_arfun;
- u32 stg_awfun;
- u32 stg_rp_nep;
- int first_busno;
Uboot PCIe can not work well. If without filtering, uboot get duplicate devices. device 0 is aliased to device 2, 3, 4...31
- return 1;
return true;
- return false;
return -EINVAL;
mdelay(20);
int trsl_param)
return -EINVAL;
- int i, ret;
0,
- if (ret)
return ret;
continue;
return -EINVAL;
if (ret)
return ret;
- u32 cells[4];
- int ret;
&syscfg_phandle);
- if (ret < 0) {
return ret;
&syscon);
- if (ret) {
return ret;
return -ENODEV;
- if (ret) {
return -EINVAL;
- int ret;
return -EINVAL;
return -EINVAL;
- if (ret) {
return ret;
- if (ret) {
return ret;
- if (ret) {
return ret;
- int ret, i;
- if (ret) {
return ret;
- if (ret) {
- if (ret) {
priv->stg_arfun,
priv->stg_awfun,
priv->stg_arfun,
0);
priv->stg_awfun,
0);
- mdelay(300);
- if (ret) {
return ret;
+err_deassert_clk:
- return ret;
- int ret;
- priv->dev = dev;
- if (ret)
return ret;
priv->stg_rp_nep,
priv->stg_awfun,
priv->stg_awfun,
- if (ret)
return ret;
- .id = UCLASS_PCI,
2.17.1
On Wednesday 08 March 2023 13:48:31 Minda Chen wrote: > From: Mason Huo mason.huo@starfivetech.com > > Add pcie driver for StarFive JH7110, the driver depends on > starfive gpio, pinctrl, clk and reset driver to do init. > > Several devices are tested: > a) M.2 NVMe SSD > b) Realtek 8169 Ethernet adapter. > > Signed-off-by: Mason Huo mason.huo@starfivetech.com > Signed-off-by: Minda Chen minda.chen@starfivetech.com > --- > drivers/pci/Kconfig | 11 + > drivers/pci/Makefile | 1 + > drivers/pci/pcie_starfive_jh7110.c | 478 +++++++++++++++++++++++++++++ > 3 files changed, 490 insertions(+) > create mode 100644 drivers/pci/pcie_starfive_jh7110.c > > diff --git a/drivers/pci/Kconfig b/drivers/pci/Kconfig > index ef328d2652..e7b0ff5bc3 100644 > --- a/drivers/pci/Kconfig > +++ b/drivers/pci/Kconfig > @@ -374,4 +374,15 @@ config PCIE_UNIPHIER > Say Y here if you want to enable PCIe controller support on > UniPhier SoCs. > > +config PCIE_STARFIVE_JH7110 > + bool "Enable Starfive JH7110 PCIe driver" > + depends on STARFIVE_JH7110 > + depends on PINCTRL_STARFIVE_JH7110 > + depends on CLK_JH7110 > + depends on RESET_JH7110 > + default y > + help > + Say Y here if you want to enable PCIe controller support on > + StarFive JH7110 SoC. > + > endif > diff --git a/drivers/pci/Makefile b/drivers/pci/Makefile > index 49506e7ba5..bbe3323bb5 100644 > --- a/drivers/pci/Makefile > +++ b/drivers/pci/Makefile > @@ -49,3 +49,4 @@ obj-$(CONFIG_PCI_OCTEONTX) += pci_octeontx.o > obj-$(CONFIG_PCIE_OCTEON) += pcie_octeon.o > obj-$(CONFIG_PCIE_DW_SIFIVE) += pcie_dw_sifive.o > obj-$(CONFIG_PCIE_UNIPHIER) += pcie_uniphier.o > +obj-$(CONFIG_PCIE_STARFIVE_JH7110) += pcie_starfive_jh7110.o > diff --git a/drivers/pci/pcie_starfive_jh7110.c b/drivers/pci/pcie_starfive_jh7110.c > new file mode 100644 > index 0000000000..5ccef1ef02 > --- /dev/null > +++ b/drivers/pci/pcie_starfive_jh7110.c > @@ -0,0 +1,478 @@ > +// SPDX-License-Identifier: GPL-2.0+ > +/* > + * StarFive PLDA PCIe host controller driver > + * > + * Copyright (c) 2023 Starfive, Inc. > + * Author: Mason Huo mason.huo@starfivetech.com > + * > + */ > + > +#include <common.h> > +#include <clk.h> > +#include <dm.h> > +#include <generic-phy.h> > +#include <pci.h> > +#include <power-domain.h> > +#include <regmap.h> > +#include <reset.h> > +#include <syscon.h> > +#include <asm/global_data.h> > +#include <asm/io.h> > +#include <asm-generic/gpio.h> > +#include <dm/device_compat.h> > +#include <dm/pinctrl.h> > +#include <linux/delay.h> > +#include <linux/iopoll.h> > +#include <power/regulator.h> > + > +DECLARE_GLOBAL_DATA_PTR; > + > +#define GEN_SETTINGS 0x80 > +#define PCIE_PCI_IDS 0x9C > +#define PCIE_WINROM 0xFC > +#define PMSG_SUPPORT_RX 0x3F0 > +#define PCI_MISC 0xB4 > + > +#define PLDA_EP_ENABLE 0 > +#define PLDA_RP_ENABLE 1 > + > +#define IDS_REVISION_ID 0x02 > +#define IDS_PCI_TO_PCI_BRIDGE 0x060400 > +#define IDS_CLASS_CODE_SHIFT 8
ok
> +#define PREF_MEM_WIN_64_SUPPORT BIT(3) > +#define PMSG_LTR_SUPPORT BIT(2) > +#define PLDA_FUNCTION_DIS BIT(15) > +#define PLDA_FUNC_NUM 4 > +#define PLDA_PHY_FUNC_SHIFT 9 > + > +#define XR3PCI_ATR_AXI4_SLV0 0x800 > +#define XR3PCI_ATR_SRC_ADDR_LOW 0x0 > +#define XR3PCI_ATR_SRC_ADDR_HIGH 0x4 > +#define XR3PCI_ATR_TRSL_ADDR_LOW 0x8 > +#define XR3PCI_ATR_TRSL_ADDR_HIGH 0xc > +#define XR3PCI_ATR_TRSL_PARAM 0x10 > +#define XR3PCI_ATR_TABLE_OFFSET 0x20 > +#define XR3PCI_ATR_MAX_TABLE_NUM 8 > + > +#define XR3PCI_ATR_SRC_WIN_SIZE_SHIFT 1 > +#define XR3PCI_ATR_SRC_ADDR_MASK GENMASK(31, 12) > +#define XR3PCI_ATR_TRSL_ADDR_MASK GENMASK(31, 12) > +#define XR3_PCI_ECAM_SIZE 28 > +#define XR3PCI_ATR_TRSL_DIR BIT(22) > +/* IDs used in the XR3PCI_ATR_TRSL_PARAM */ > +#define XR3PCI_ATR_TRSLID_PCIE_MEMORY 0x0 > +#define XR3PCI_ATR_TRSLID_PCIE_CONFIG 0x1 > + > +#define ECAM_BUS_SHIFT 20 > +#define ECAM_DEV_SHIFT 15 > +#define ECAM_FUNC_SHIFT 12
> +/* Secondary bus number offset in config space */ > +#define PCI_SECONDARY_BUS 0x19
Unused.
ok
> + > +/* system control */ > +#define STG_SYSCON_K_RP_NEP_MASK BIT(8) > +#define STG_SYSCON_AXI4_SLVL_ARFUNC_MASK GENMASK(22, 8) > +#define STG_SYSCON_AXI4_SLVL_ARFUNC_SHIFT 8 > +#define STG_SYSCON_AXI4_SLVL_AWFUNC_MASK GENMASK(14, 0) > +#define STG_SYSCON_CLKREQ_MASK BIT(22) > +#define STG_SYSCON_CKREF_SRC_SHIFT 18 > +#define STG_SYSCON_CKREF_SRC_MASK GENMASK(19, 18) > + > +struct starfive_pcie { > + struct udevice *dev; > + > + void __iomem *reg_base; > + void __iomem *cfg_base; > + > + struct regmap *regmap; > + u32 stg_arfun; > + u32 stg_awfun; > + u32 stg_rp_nep; > + > + struct clk_bulk clks; > + struct reset_ctl_bulk rsts; > + > + int atr_table_num; > + int first_busno; > +}; > + > +static int starfive_pcie_addr_valid(pci_dev_t bdf, int first_busno) > +{ > + if ((PCI_BUS(bdf) == first_busno) && (PCI_DEV(bdf) > 0)) > + return 0; > + if ((PCI_BUS(bdf) == first_busno + 1) && (PCI_DEV(bdf) > 0)) > + return 0;
Ok, so you are seeing same issue as on mvebu HW which I described above, right? And which bus is affected by this issue? Root (zero) bus? Or the bus behind it (1)?
> + > + return 1; > +} > + > +static int starfive_pcie_off_conf(pci_dev_t bdf, uint offset) > +{ > + unsigned int bus = PCI_BUS(bdf); > + unsigned int dev = PCI_DEV(bdf); > + unsigned int func = PCI_FUNC(bdf); > + > + return (bus << ECAM_BUS_SHIFT) | (dev << ECAM_DEV_SHIFT) | > + (func << ECAM_FUNC_SHIFT) | offset; > +} > + > +static bool starfive_pcie_hide_rc_bar(pci_dev_t bdf, int offset) > +{ > + /* Only root port 1 is in use */ > + if ((PCI_BUS(bdf) == 0) &&
> + (offset == PCI_BASE_ADDRESS_0 || offset == PCI_BASE_ADDRESS_1)) > + return true; > + > + return false; > +} > + > +static int starfive_pcie_conf_address(const struct udevice *udev, pci_dev_t bdf, > + uint offset, void **paddr) > +{ > + struct starfive_pcie *priv = dev_get_priv(udev); > + int where = starfive_pcie_off_conf(bdf, offset); > + > + if (!starfive_pcie_addr_valid(bdf, priv->first_busno)) > + return -EINVAL;
> + > + *paddr = (void *)(priv->cfg_base + where); > + return 0; > +} > + > +static int starfive_pcie_config_read(const struct udevice *udev, pci_dev_t bdf, > + uint offset, ulong *valuep, > + enum pci_size_t size) > +{ > + /* Make sure the LAST TLP is finished, before reading vendor ID. */ > + if (offset == PCI_VENDOR_ID) > + mdelay(20);
> + > + return pci_generic_mmap_read_config(udev, starfive_pcie_conf_address, > + bdf, offset, valuep, size); > +} > + > +int starfive_pcie_config_write(struct udevice *udev, pci_dev_t bdf, > + uint offset, ulong value, > + enum pci_size_t size) > +{ > + if (starfive_pcie_hide_rc_bar(bdf, offset)) > + return 0;
> + > + return pci_generic_mmap_write_config(udev, starfive_pcie_conf_address, > + bdf, offset, value, size); > +} > + > +static int starfive_pcie_set_atr_entry(struct starfive_pcie *priv, phys_addr_t src_addr, > + phys_addr_t trsl_addr, size_t window_size, > + int trsl_param) > +{ > + void __iomem *base = > + priv->reg_base + XR3PCI_ATR_AXI4_SLV0; > + > + /* Support AXI4 Slave 0 Address Translation Tables 0-7. */ > + if (priv->atr_table_num >= XR3PCI_ATR_MAX_TABLE_NUM) { > + dev_err(priv->dev, "ATR table number %d exceeds max num\n", > + priv->atr_table_num); > + return -EINVAL; > + } > + base += XR3PCI_ATR_TABLE_OFFSET * priv->atr_table_num; > + priv->atr_table_num++; > + > + /* X3PCI_ATR_SRC_ADDR_LOW: > + * - bit 0: enable entry, > + * - bits 1-6: ATR window size: total size in bytes: 2^(ATR_WSIZE + 1) > + * - bits 7-11: reserved > + * - bits 12-31: start of source address > + */ > + writel((lower_32_bits(src_addr) & XR3PCI_ATR_SRC_ADDR_MASK) | > + (fls(window_size) - 1) << XR3PCI_ATR_SRC_WIN_SIZE_SHIFT | 1, > + base + XR3PCI_ATR_SRC_ADDR_LOW); > + writel(upper_32_bits(src_addr), base + XR3PCI_ATR_SRC_ADDR_HIGH); > + writel((lower_32_bits(trsl_addr) & XR3PCI_ATR_TRSL_ADDR_MASK), > + base + XR3PCI_ATR_TRSL_ADDR_LOW); > + writel(upper_32_bits(trsl_addr), base + XR3PCI_ATR_TRSL_ADDR_HIGH); > + writel(trsl_param, base + XR3PCI_ATR_TRSL_PARAM); > + > + dev_dbg(priv->dev, "ATR entry: 0x%010llx %s 0x%010llx [0x%010llx] (param: 0x%06x)\n", > + src_addr, (trsl_param & XR3PCI_ATR_TRSL_DIR) ? "<-" : "->", > + trsl_addr, (u64)window_size, trsl_param); > + return 0; > +} > + > +static int starfive_pcie_atr_init(struct starfive_pcie *priv) > +{ > + struct udevice *ctlr = pci_get_controller(priv->dev); > + struct pci_controller *hose = dev_get_uclass_priv(ctlr); > + int i, ret; > + > + /* As the two host bridges in JH7110 soc have the same default > + * address translation table, this cause the second root port can't > + * access it's host bridge config space correctly. > + * To workaround, config the ATR of host bridge config space by SW. > + */ > + > + ret = starfive_pcie_set_atr_entry(priv, > + (phys_addr_t)priv->cfg_base, > + 0, > + 1 << XR3_PCI_ECAM_SIZE, > + XR3PCI_ATR_TRSLID_PCIE_CONFIG); > + if (ret) > + return ret; > + > + for (i = 0; i < hose->region_count; i++) { > + if (hose->regions[i].flags == PCI_REGION_SYS_MEMORY) > + continue; > + > + /* Only support identity mappings. */ > + if (hose->regions[i].bus_start != > + hose->regions[i].phys_start) > + return -EINVAL; > + > + ret = starfive_pcie_set_atr_entry(priv, > + hose->regions[i].phys_start, > + hose->regions[i].bus_start, > + hose->regions[i].size, > + XR3PCI_ATR_TRSLID_PCIE_MEMORY); > + if (ret) > + return ret; > + } > + > + return 0; > +} > + > +static int starfive_pcie_get_syscon(struct udevice *dev) > +{ > + struct starfive_pcie *priv = dev_get_priv(dev); > + struct udevice *syscon; > + struct ofnode_phandle_args syscfg_phandle; > + u32 cells[4]; > + int ret; > + > + /* get corresponding syscon phandle */ > + ret = dev_read_phandle_with_args(dev, "starfive,stg-syscon", NULL, 0, 0, > + &syscfg_phandle); > + > + if (ret < 0) { > + dev_err(dev, "Can't get syscfg phandle: %d\n", ret); > + return ret; > + } > + > + ret = uclass_get_device_by_ofnode(UCLASS_SYSCON, syscfg_phandle.node, > + &syscon); > + if (ret) { > + dev_err(dev, "Unable to find syscon device (%d)\n", ret); > + return ret; > + } > + > + priv->regmap = syscon_get_regmap(syscon); > + if (!priv->regmap) { > + dev_err(dev, "Unable to find regmap\n"); > + return -ENODEV; > + } > + > + /* get syscon register offset */ > + ret = dev_read_u32_array(dev, "starfive,stg-syscon", > + cells, ARRAY_SIZE(cells)); > + if (ret) { > + dev_err(dev, "Get syscon register err %d\n", ret); > + return -EINVAL; > + } > + > + dev_dbg(dev, "Get syscon values: %x, %x, %x\n", > + cells[1], cells[2], cells[3]); > + priv->stg_arfun = cells[1]; > + priv->stg_awfun = cells[2]; > + priv->stg_rp_nep = cells[3]; > + > + return 0; > +} > + > +static int starfive_pcie_parse_dt(struct udevice *dev) > +{ > + struct starfive_pcie *priv = dev_get_priv(dev); > + int ret; > + > + priv->reg_base = (void *)dev_read_addr_name(dev, "reg"); > + if (priv->reg_base == (void __iomem *)FDT_ADDR_T_NONE) { > + dev_err(dev, "Missing required reg address range\n"); > + return -EINVAL; > + } > + > + priv->cfg_base = (void *)dev_read_addr_name(dev, "config"); > + if (priv->cfg_base == (void __iomem *)FDT_ADDR_T_NONE) { > + dev_err(dev, "Missing required config address range"); > + return -EINVAL; > + } > + > + ret = starfive_pcie_get_syscon(dev); > + if (ret) { > + dev_err(dev, "Can't get syscon: %d\n", ret); > + return ret; > + } > + > + ret = reset_get_bulk(dev, &priv->rsts); > + if (ret) { > + dev_err(dev, "Can't get reset: %d\n", ret); > + return ret; > + } > + > + ret = clk_get_bulk(dev, &priv->clks); > + if (ret) { > + dev_err(dev, "Can't get clock: %d\n", ret); > + return ret; > + } > + > + return 0; > +} > + > +static int starfive_pcie_init_port(struct udevice *dev) > +{ > + int ret, i; > + unsigned int value; > + struct starfive_pcie *priv = dev_get_priv(dev); > + > + ret = clk_enable_bulk(&priv->clks); > + if (ret) { > + dev_err(dev, "Failed to enable clks (ret=%d)\n", ret); > + return ret; > + } > + > + ret = reset_deassert_bulk(&priv->rsts); > + if (ret) { > + dev_err(dev, "Failed to deassert resets (ret=%d)\n", ret); > + goto err_deassert_clk; > + } > + > + ret = pinctrl_select_state(dev, "perst-active"); > + if (ret) { > + dev_err(dev, "Set perst-active pinctrl failed: %d\n", ret); > + goto err_deassert_reset; > + } > + > + /* Disable physical functions except #0 */ > + for (i = 1; i < PLDA_FUNC_NUM; i++) { > + regmap_update_bits(priv->regmap, > + priv->stg_arfun, > + STG_SYSCON_AXI4_SLVL_ARFUNC_MASK, > + (i << PLDA_PHY_FUNC_SHIFT) << > + STG_SYSCON_AXI4_SLVL_ARFUNC_SHIFT); > + regmap_update_bits(priv->regmap, > + priv->stg_awfun, > + STG_SYSCON_AXI4_SLVL_AWFUNC_MASK, > + i << PLDA_PHY_FUNC_SHIFT); > + > + value = readl(priv->reg_base + PCI_MISC); > + value |= PLDA_FUNCTION_DIS; > + writel(value, priv->reg_base + PCI_MISC); > + } > + > + /* Disable physical functions */ > + regmap_update_bits(priv->regmap, > + priv->stg_arfun, > + STG_SYSCON_AXI4_SLVL_ARFUNC_MASK, > + 0); > + regmap_update_bits(priv->regmap, > + priv->stg_awfun, > + STG_SYSCON_AXI4_SLVL_AWFUNC_MASK, > + 0); > + > + /* Enable root port */ > + value = readl(priv->reg_base + GEN_SETTINGS); > + value |= PLDA_RP_ENABLE; > + writel(value, priv->reg_base + GEN_SETTINGS); > + > + /* PCIe PCI Standard Configuration Identification Settings. */ > + value = (IDS_PCI_TO_PCI_BRIDGE << IDS_CLASS_CODE_SHIFT) | IDS_REVISION_ID; > + writel(value, priv->reg_base + PCIE_PCI_IDS); > + > + /* The LTR message forwarding of PCIe Message Reception was set by core > + * as default, but the forward id & addr are also need to be reset. > + * If we do not disable LTR message forwarding here, or set a legal > + * forwarding address, the kernel will get stuck after this driver probe. > + * To workaround, disable the LTR message forwarding support on > + * PCIe Message Reception. > + */ > + value = readl(priv->reg_base + PMSG_SUPPORT_RX); > + value &= ~PMSG_LTR_SUPPORT; > + writel(value, priv->reg_base + PMSG_SUPPORT_RX); > + > + /* Prefetchable memory window 64-bit addressing support */ > + value = readl(priv->reg_base + PCIE_WINROM); > + value |= PREF_MEM_WIN_64_SUPPORT; > + writel(value, priv->reg_base + PCIE_WINROM); > + > + starfive_pcie_atr_init(priv); > + > + /* Ensure that PERST has been asserted for at least 300 ms */ > + mdelay(300); > + ret = pinctrl_select_state(dev, "perst-default"); > + if (ret) { > + dev_err(dev, "Set perst-default pinctrl failed: %d\n", ret); > + return ret; > + } > + > + return 0; > + > +err_deassert_clk: > + clk_disable_bulk(&priv->clks); > +err_deassert_reset: > + reset_assert_bulk(&priv->rsts); > + return ret; > +} > + > +static int starfive_pcie_probe(struct udevice *dev) > +{ > + struct starfive_pcie *priv = dev_get_priv(dev); > + int ret; > + > + priv->atr_table_num = 0; > + priv->dev = dev; > + priv->first_busno = dev_seq(dev); > + > + ret = starfive_pcie_parse_dt(dev); > + if (ret) > + return ret; > + > + regmap_update_bits(priv->regmap, > + priv->stg_rp_nep, > + STG_SYSCON_K_RP_NEP_MASK, > + STG_SYSCON_K_RP_NEP_MASK); > + > + regmap_update_bits(priv->regmap, > + priv->stg_awfun, > + STG_SYSCON_CKREF_SRC_MASK, > + 2 << STG_SYSCON_CKREF_SRC_SHIFT); > + > + regmap_update_bits(priv->regmap, > + priv->stg_awfun, > + STG_SYSCON_CLKREQ_MASK, > + STG_SYSCON_CLKREQ_MASK); > + > + ret = starfive_pcie_init_port(dev); > + if (ret) > + return ret; > + > + dev_err(dev, "Starfive PCIe bus probed.\n"); > + > + return 0; > +} > + > +static const struct dm_pci_ops starfive_pcie_ops = { > + .read_config = starfive_pcie_config_read, > + .write_config = starfive_pcie_config_write, > +}; > + > +static const struct udevice_id starfive_pcie_ids[] = { > + { .compatible = "starfive,jh7110-pcie" }, > + { } > +}; > + > +U_BOOT_DRIVER(starfive_pcie_drv) = { > + .name = "starfive_7110_pcie", > + .id = UCLASS_PCI, > + .of_match = starfive_pcie_ids, > + .ops = &starfive_pcie_ops, > + .probe = starfive_pcie_probe, > + .priv_auto = sizeof(struct starfive_pcie), > +}; > -- > 2.17.1 >
On 2023/3/8 15:31, Pali Rohár wrote: > Hello! See few comments below. > > On Wednesday 08 March 2023 13:48:31 Minda Chen wrote: >> From: Mason Huo mason.huo@starfivetech.com >> >> Add pcie driver for StarFive JH7110, the driver depends on >> starfive gpio, pinctrl, clk and reset driver to do init. >> >> Several devices are tested: >> a) M.2 NVMe SSD >> b) Realtek 8169 Ethernet adapter. >> >> Signed-off-by: Mason Huo mason.huo@starfivetech.com >> Signed-off-by: Minda Chen minda.chen@starfivetech.com >> --- >> drivers/pci/Kconfig | 11 + >> drivers/pci/Makefile | 1 + >> drivers/pci/pcie_starfive_jh7110.c | 478 +++++++++++++++++++++++++++++ >> 3 files changed, 490 insertions(+) >> create mode 100644 drivers/pci/pcie_starfive_jh7110.c >> >> diff --git a/drivers/pci/Kconfig b/drivers/pci/Kconfig >> index ef328d2652..e7b0ff5bc3 100644 >> --- a/drivers/pci/Kconfig >> +++ b/drivers/pci/Kconfig >> @@ -374,4 +374,15 @@ config PCIE_UNIPHIER >> Say Y here if you want to enable PCIe controller support on >> UniPhier SoCs. >> >> +config PCIE_STARFIVE_JH7110 >> + bool "Enable Starfive JH7110 PCIe driver" >> + depends on STARFIVE_JH7110 >> + depends on PINCTRL_STARFIVE_JH7110 >> + depends on CLK_JH7110 >> + depends on RESET_JH7110 >> + default y >> + help >> + Say Y here if you want to enable PCIe controller support on >> + StarFive JH7110 SoC. >> + >> endif >> diff --git a/drivers/pci/Makefile b/drivers/pci/Makefile >> index 49506e7ba5..bbe3323bb5 100644 >> --- a/drivers/pci/Makefile >> +++ b/drivers/pci/Makefile >> @@ -49,3 +49,4 @@ obj-$(CONFIG_PCI_OCTEONTX) += pci_octeontx.o >> obj-$(CONFIG_PCIE_OCTEON) += pcie_octeon.o >> obj-$(CONFIG_PCIE_DW_SIFIVE) += pcie_dw_sifive.o >> obj-$(CONFIG_PCIE_UNIPHIER) += pcie_uniphier.o >> +obj-$(CONFIG_PCIE_STARFIVE_JH7110) += pcie_starfive_jh7110.o >> diff --git a/drivers/pci/pcie_starfive_jh7110.c b/drivers/pci/pcie_starfive_jh7110.c >> new file mode 100644 >> index 0000000000..5ccef1ef02 >> --- /dev/null >> +++ b/drivers/pci/pcie_starfive_jh7110.c >> @@ -0,0 +1,478 @@ >> +// SPDX-License-Identifier: GPL-2.0+ >> +/* >> + * StarFive PLDA PCIe host controller driver >> + * >> + * Copyright (c) 2023 Starfive, Inc. >> + * Author: Mason Huo mason.huo@starfivetech.com >> + * >> + */ >> + >> +#include <common.h> >> +#include <clk.h> >> +#include <dm.h> >> +#include <generic-phy.h> >> +#include <pci.h> >> +#include <power-domain.h> >> +#include <regmap.h> >> +#include <reset.h> >> +#include <syscon.h> >> +#include <asm/global_data.h> >> +#include <asm/io.h> >> +#include <asm-generic/gpio.h> >> +#include <dm/device_compat.h> >> +#include <dm/pinctrl.h> >> +#include <linux/delay.h> >> +#include <linux/iopoll.h> >> +#include <power/regulator.h> >> + >> +DECLARE_GLOBAL_DATA_PTR; >> + >> +#define GEN_SETTINGS 0x80 >> +#define PCIE_PCI_IDS 0x9C >> +#define PCIE_WINROM 0xFC >> +#define PMSG_SUPPORT_RX 0x3F0 >> +#define PCI_MISC 0xB4 >> + >> +#define PLDA_EP_ENABLE 0 >> +#define PLDA_RP_ENABLE 1 >> + >> +#define IDS_REVISION_ID 0x02 >> +#define IDS_PCI_TO_PCI_BRIDGE 0x060400 >> +#define IDS_CLASS_CODE_SHIFT 8 > > Please do not duplicate standard PCI macros and constants. In U-Boot > they are already available in include/pci_ids.h header file. > ok >> +#define PREF_MEM_WIN_64_SUPPORT BIT(3) >> +#define PMSG_LTR_SUPPORT BIT(2) >> +#define PLDA_FUNCTION_DIS BIT(15) >> +#define PLDA_FUNC_NUM 4 >> +#define PLDA_PHY_FUNC_SHIFT 9 >> + >> +#define XR3PCI_ATR_AXI4_SLV0 0x800 >> +#define XR3PCI_ATR_SRC_ADDR_LOW 0x0 >> +#define XR3PCI_ATR_SRC_ADDR_HIGH 0x4 >> +#define XR3PCI_ATR_TRSL_ADDR_LOW 0x8 >> +#define XR3PCI_ATR_TRSL_ADDR_HIGH 0xc >> +#define XR3PCI_ATR_TRSL_PARAM 0x10 >> +#define XR3PCI_ATR_TABLE_OFFSET 0x20 >> +#define XR3PCI_ATR_MAX_TABLE_NUM 8 >> + >> +#define XR3PCI_ATR_SRC_WIN_SIZE_SHIFT 1 >> +#define XR3PCI_ATR_SRC_ADDR_MASK GENMASK(31, 12) >> +#define XR3PCI_ATR_TRSL_ADDR_MASK GENMASK(31, 12) >> +#define XR3_PCI_ECAM_SIZE 28 >> +#define XR3PCI_ATR_TRSL_DIR BIT(22) >> +/* IDs used in the XR3PCI_ATR_TRSL_PARAM */ >> +#define XR3PCI_ATR_TRSLID_PCIE_MEMORY 0x0 >> +#define XR3PCI_ATR_TRSLID_PCIE_CONFIG 0x1 >> + >> +#define ECAM_BUS_SHIFT 20 >> +#define ECAM_DEV_SHIFT 15 >> +#define ECAM_FUNC_SHIFT 12 > > Please do not implement duplicate PCIe ECAM code. U-Boot and also Linux > kernel already provides PCIE_ECAM_OFFSET() macro. > >> +/* Secondary bus number offset in config space */ >> +#define PCI_SECONDARY_BUS 0x19 > > Unused. > ok >> + >> +/* system control */ >> +#define STG_SYSCON_K_RP_NEP_MASK BIT(8) >> +#define STG_SYSCON_AXI4_SLVL_ARFUNC_MASK GENMASK(22, 8) >> +#define STG_SYSCON_AXI4_SLVL_ARFUNC_SHIFT 8 >> +#define STG_SYSCON_AXI4_SLVL_AWFUNC_MASK GENMASK(14, 0) >> +#define STG_SYSCON_CLKREQ_MASK BIT(22) >> +#define STG_SYSCON_CKREF_SRC_SHIFT 18 >> +#define STG_SYSCON_CKREF_SRC_MASK GENMASK(19, 18) >> + >> +struct starfive_pcie { >> + struct udevice *dev; >> + >> + void __iomem *reg_base; >> + void __iomem *cfg_base; >> + >> + struct regmap *regmap; >> + u32 stg_arfun; >> + u32 stg_awfun; >> + u32 stg_rp_nep; >> + >> + struct clk_bulk clks; >> + struct reset_ctl_bulk rsts; >> + >> + int atr_table_num; >> + int first_busno; >> +}; >> + >> +static int starfive_pcie_addr_valid(pci_dev_t bdf, int first_busno) >> +{ >> + if ((PCI_BUS(bdf) == first_busno) && (PCI_DEV(bdf) > 0)) >> + return 0; >> + if ((PCI_BUS(bdf) == first_busno + 1) && (PCI_DEV(bdf) > 0)) >> + return 0; > > If fisrt_busno is the bus of the root port then first_busno+1 does not > have to bus of the PCIe device on the other end of the link from the > root port. See for example pci_mvebu.c how this logic is handled. > You probably want to also limit access to non-zero function of root port > unless you have multifunction root-port device. > root port limitation can follow the pci_mvebu.c
bus 1.
>> + >> + return 1; >> +} >> + >> +static int starfive_pcie_off_conf(pci_dev_t bdf, uint offset) >> +{ >> + unsigned int bus = PCI_BUS(bdf); >> + unsigned int dev = PCI_DEV(bdf); >> + unsigned int func = PCI_FUNC(bdf); >> + >> + return (bus << ECAM_BUS_SHIFT) | (dev << ECAM_DEV_SHIFT) | >> + (func << ECAM_FUNC_SHIFT) | offset; >> +} >> + >> +static bool starfive_pcie_hide_rc_bar(pci_dev_t bdf, int offset) >> +{ >> + /* Only root port 1 is in use */ >> + if ((PCI_BUS(bdf) == 0) && > > This looks like an incorrect check for the bus of he root port. > See for example pci_mvebu.c where logic should be correct. > > I guess you wanted to use: PCI_BUS(bdf)-dev_seq(udev) > [1] This is a work around method. Our PCIe support 64bit. But the config space is 16KB. If no limitation here, uboot will set high 32 bit base address to 0xfffffff after init.
>> + (offset == PCI_BASE_ADDRESS_0 || offset == PCI_BASE_ADDRESS_1)) >> + return true; >> + >> + return false; >> +} >> + >> +static int starfive_pcie_conf_address(const struct udevice *udev, pci_dev_t bdf, >> + uint offset, void **paddr) >> +{ >> + struct starfive_pcie *priv = dev_get_priv(udev); >> + int where = starfive_pcie_off_conf(bdf, offset); >> + >> + if (!starfive_pcie_addr_valid(bdf, priv->first_busno)) >> + return -EINVAL; > > Is this check needed? Does it mean that ECAM returns bogus information > for disconnected devices, that it needs to be manually filtered? (Which > is against PCIe spec). > I found nvme device can not work if the non-zero function of root port without limitation. But I will try to fix it. Maybe I can remove this.
>> + >> + *paddr = (void *)(priv->cfg_base + where); >> + return 0; >> +} >> + >> +static int starfive_pcie_config_read(const struct udevice *udev, pci_dev_t bdf, >> + uint offset, ulong *valuep, >> + enum pci_size_t size) >> +{ >> + /* Make sure the LAST TLP is finished, before reading vendor ID. */ >> + if (offset == PCI_VENDOR_ID) >> + mdelay(20); > > This looks strange. There is some bug / errata that reading vendor id > from ECAM does not work correctly? > I will remove this. It is not a errata of reading the vendor ID. >> + >> + return pci_generic_mmap_read_config(udev, starfive_pcie_conf_address, >> + bdf, offset, valuep, size); >> +} >> + >> +int starfive_pcie_config_write(struct udevice *udev, pci_dev_t bdf, >> + uint offset, ulong value, >> + enum pci_size_t size) >> +{ >> + if (starfive_pcie_hide_rc_bar(bdf, offset)) >> + return 0; > > Why you are ignoring writes to some offset, but not ignoring reads? And > ignoring results in no-error (return value 0)? >The same as [1]
>> + >> + return pci_generic_mmap_write_config(udev, starfive_pcie_conf_address, >> + bdf, offset, value, size); >> +} >> + >> +static int starfive_pcie_set_atr_entry(struct starfive_pcie *priv, phys_addr_t src_addr, >> + phys_addr_t trsl_addr, size_t window_size, >> + int trsl_param) >> +{ >> + void __iomem *base = >> + priv->reg_base + XR3PCI_ATR_AXI4_SLV0; >> + >> + /* Support AXI4 Slave 0 Address Translation Tables 0-7. */ >> + if (priv->atr_table_num >= XR3PCI_ATR_MAX_TABLE_NUM) { >> + dev_err(priv->dev, "ATR table number %d exceeds max num\n", >> + priv->atr_table_num); >> + return -EINVAL; >> + } >> + base += XR3PCI_ATR_TABLE_OFFSET * priv->atr_table_num; >> + priv->atr_table_num++; >> + >> + /* X3PCI_ATR_SRC_ADDR_LOW: >> + * - bit 0: enable entry, >> + * - bits 1-6: ATR window size: total size in bytes: 2^(ATR_WSIZE + 1) >> + * - bits 7-11: reserved >> + * - bits 12-31: start of source address >> + */ >> + writel((lower_32_bits(src_addr) & XR3PCI_ATR_SRC_ADDR_MASK) | >> + (fls(window_size) - 1) << XR3PCI_ATR_SRC_WIN_SIZE_SHIFT | 1, >> + base + XR3PCI_ATR_SRC_ADDR_LOW); >> + writel(upper_32_bits(src_addr), base + XR3PCI_ATR_SRC_ADDR_HIGH); >> + writel((lower_32_bits(trsl_addr) & XR3PCI_ATR_TRSL_ADDR_MASK), >> + base + XR3PCI_ATR_TRSL_ADDR_LOW); >> + writel(upper_32_bits(trsl_addr), base + XR3PCI_ATR_TRSL_ADDR_HIGH); >> + writel(trsl_param, base + XR3PCI_ATR_TRSL_PARAM); >> + >> + dev_dbg(priv->dev, "ATR entry: 0x%010llx %s 0x%010llx [0x%010llx] (param: 0x%06x)\n", >> + src_addr, (trsl_param & XR3PCI_ATR_TRSL_DIR) ? "<-" : "->", >> + trsl_addr, (u64)window_size, trsl_param); >> + return 0; >> +} >> + >> +static int starfive_pcie_atr_init(struct starfive_pcie *priv) >> +{ >> + struct udevice *ctlr = pci_get_controller(priv->dev); >> + struct pci_controller *hose = dev_get_uclass_priv(ctlr); >> + int i, ret; >> + >> + /* As the two host bridges in JH7110 soc have the same default >> + * address translation table, this cause the second root port can't >> + * access it's host bridge config space correctly. >> + * To workaround, config the ATR of host bridge config space by SW. >> + */ >> + >> + ret = starfive_pcie_set_atr_entry(priv, >> + (phys_addr_t)priv->cfg_base, >> + 0, >> + 1 << XR3_PCI_ECAM_SIZE, >> + XR3PCI_ATR_TRSLID_PCIE_CONFIG); >> + if (ret) >> + return ret; >> + >> + for (i = 0; i < hose->region_count; i++) { >> + if (hose->regions[i].flags == PCI_REGION_SYS_MEMORY) >> + continue; >> + >> + /* Only support identity mappings. */ >> + if (hose->regions[i].bus_start != >> + hose->regions[i].phys_start) >> + return -EINVAL; >> + >> + ret = starfive_pcie_set_atr_entry(priv, >> + hose->regions[i].phys_start, >> + hose->regions[i].bus_start, >> + hose->regions[i].size, >> + XR3PCI_ATR_TRSLID_PCIE_MEMORY); >> + if (ret) >> + return ret; >> + } >> + >> + return 0; >> +} >> + >> +static int starfive_pcie_get_syscon(struct udevice *dev) >> +{ >> + struct starfive_pcie *priv = dev_get_priv(dev); >> + struct udevice *syscon; >> + struct ofnode_phandle_args syscfg_phandle; >> + u32 cells[4]; >> + int ret; >> + >> + /* get corresponding syscon phandle */ >> + ret = dev_read_phandle_with_args(dev, "starfive,stg-syscon", NULL, 0, 0, >> + &syscfg_phandle); >> + >> + if (ret < 0) { >> + dev_err(dev, "Can't get syscfg phandle: %d\n", ret); >> + return ret; >> + } >> + >> + ret = uclass_get_device_by_ofnode(UCLASS_SYSCON, syscfg_phandle.node, >> + &syscon); >> + if (ret) { >> + dev_err(dev, "Unable to find syscon device (%d)\n", ret); >> + return ret; >> + } >> + >> + priv->regmap = syscon_get_regmap(syscon); >> + if (!priv->regmap) { >> + dev_err(dev, "Unable to find regmap\n"); >> + return -ENODEV; >> + } >> + >> + /* get syscon register offset */ >> + ret = dev_read_u32_array(dev, "starfive,stg-syscon", >> + cells, ARRAY_SIZE(cells)); >> + if (ret) { >> + dev_err(dev, "Get syscon register err %d\n", ret); >> + return -EINVAL; >> + } >> + >> + dev_dbg(dev, "Get syscon values: %x, %x, %x\n", >> + cells[1], cells[2], cells[3]); >> + priv->stg_arfun = cells[1]; >> + priv->stg_awfun = cells[2]; >> + priv->stg_rp_nep = cells[3]; >> + >> + return 0; >> +} >> + >> +static int starfive_pcie_parse_dt(struct udevice *dev) >> +{ >> + struct starfive_pcie *priv = dev_get_priv(dev); >> + int ret; >> + >> + priv->reg_base = (void *)dev_read_addr_name(dev, "reg"); >> + if (priv->reg_base == (void __iomem *)FDT_ADDR_T_NONE) { >> + dev_err(dev, "Missing required reg address range\n"); >> + return -EINVAL; >> + } >> + >> + priv->cfg_base = (void *)dev_read_addr_name(dev, "config"); >> + if (priv->cfg_base == (void __iomem *)FDT_ADDR_T_NONE) { >> + dev_err(dev, "Missing required config address range"); >> + return -EINVAL; >> + } >> + >> + ret = starfive_pcie_get_syscon(dev); >> + if (ret) { >> + dev_err(dev, "Can't get syscon: %d\n", ret); >> + return ret; >> + } >> + >> + ret = reset_get_bulk(dev, &priv->rsts); >> + if (ret) { >> + dev_err(dev, "Can't get reset: %d\n", ret); >> + return ret; >> + } >> + >> + ret = clk_get_bulk(dev, &priv->clks); >> + if (ret) { >> + dev_err(dev, "Can't get clock: %d\n", ret); >> + return ret; >> + } >> + >> + return 0; >> +} >> + >> +static int starfive_pcie_init_port(struct udevice *dev) >> +{ >> + int ret, i; >> + unsigned int value; >> + struct starfive_pcie *priv = dev_get_priv(dev); >> + >> + ret = clk_enable_bulk(&priv->clks); >> + if (ret) { >> + dev_err(dev, "Failed to enable clks (ret=%d)\n", ret); >> + return ret; >> + } >> + >> + ret = reset_deassert_bulk(&priv->rsts); >> + if (ret) { >> + dev_err(dev, "Failed to deassert resets (ret=%d)\n", ret); >> + goto err_deassert_clk; >> + } >> + >> + ret = pinctrl_select_state(dev, "perst-active"); >> + if (ret) { >> + dev_err(dev, "Set perst-active pinctrl failed: %d\n", ret); >> + goto err_deassert_reset; >> + } >> + >> + /* Disable physical functions except #0 */ >> + for (i = 1; i < PLDA_FUNC_NUM; i++) { >> + regmap_update_bits(priv->regmap, >> + priv->stg_arfun, >> + STG_SYSCON_AXI4_SLVL_ARFUNC_MASK, >> + (i << PLDA_PHY_FUNC_SHIFT) << >> + STG_SYSCON_AXI4_SLVL_ARFUNC_SHIFT); >> + regmap_update_bits(priv->regmap, >> + priv->stg_awfun, >> + STG_SYSCON_AXI4_SLVL_AWFUNC_MASK, >> + i << PLDA_PHY_FUNC_SHIFT); >> + >> + value = readl(priv->reg_base + PCI_MISC); >> + value |= PLDA_FUNCTION_DIS; >> + writel(value, priv->reg_base + PCI_MISC); >> + } >> + >> + /* Disable physical functions */ >> + regmap_update_bits(priv->regmap, >> + priv->stg_arfun, >> + STG_SYSCON_AXI4_SLVL_ARFUNC_MASK, >> + 0); >> + regmap_update_bits(priv->regmap, >> + priv->stg_awfun, >> + STG_SYSCON_AXI4_SLVL_AWFUNC_MASK, >> + 0); >> + >> + /* Enable root port */ >> + value = readl(priv->reg_base + GEN_SETTINGS); >> + value |= PLDA_RP_ENABLE; >> + writel(value, priv->reg_base + GEN_SETTINGS); >> + >> + /* PCIe PCI Standard Configuration Identification Settings. */ >> + value = (IDS_PCI_TO_PCI_BRIDGE << IDS_CLASS_CODE_SHIFT) | IDS_REVISION_ID; >> + writel(value, priv->reg_base + PCIE_PCI_IDS); >> + >> + /* The LTR message forwarding of PCIe Message Reception was set by core >> + * as default, but the forward id & addr are also need to be reset. >> + * If we do not disable LTR message forwarding here, or set a legal >> + * forwarding address, the kernel will get stuck after this driver probe. >> + * To workaround, disable the LTR message forwarding support on >> + * PCIe Message Reception. >> + */ >> + value = readl(priv->reg_base + PMSG_SUPPORT_RX); >> + value &= ~PMSG_LTR_SUPPORT; >> + writel(value, priv->reg_base + PMSG_SUPPORT_RX); >> + >> + /* Prefetchable memory window 64-bit addressing support */ >> + value = readl(priv->reg_base + PCIE_WINROM); >> + value |= PREF_MEM_WIN_64_SUPPORT; >> + writel(value, priv->reg_base + PCIE_WINROM); >> + >> + starfive_pcie_atr_init(priv); >> + >> + /* Ensure that PERST has been asserted for at least 300 ms */ >> + mdelay(300); >> + ret = pinctrl_select_state(dev, "perst-default"); >> + if (ret) { >> + dev_err(dev, "Set perst-default pinctrl failed: %d\n", ret); >> + return ret; >> + } >> + >> + return 0; >> + >> +err_deassert_clk: >> + clk_disable_bulk(&priv->clks); >> +err_deassert_reset: >> + reset_assert_bulk(&priv->rsts); >> + return ret; >> +} >> + >> +static int starfive_pcie_probe(struct udevice *dev) >> +{ >> + struct starfive_pcie *priv = dev_get_priv(dev); >> + int ret; >> + >> + priv->atr_table_num = 0; >> + priv->dev = dev; >> + priv->first_busno = dev_seq(dev); >> + >> + ret = starfive_pcie_parse_dt(dev); >> + if (ret) >> + return ret; >> + >> + regmap_update_bits(priv->regmap, >> + priv->stg_rp_nep, >> + STG_SYSCON_K_RP_NEP_MASK, >> + STG_SYSCON_K_RP_NEP_MASK); >> + >> + regmap_update_bits(priv->regmap, >> + priv->stg_awfun, >> + STG_SYSCON_CKREF_SRC_MASK, >> + 2 << STG_SYSCON_CKREF_SRC_SHIFT); >> + >> + regmap_update_bits(priv->regmap, >> + priv->stg_awfun, >> + STG_SYSCON_CLKREQ_MASK, >> + STG_SYSCON_CLKREQ_MASK); >> + >> + ret = starfive_pcie_init_port(dev); >> + if (ret) >> + return ret; >> + >> + dev_err(dev, "Starfive PCIe bus probed.\n"); >> + >> + return 0; >> +} >> + >> +static const struct dm_pci_ops starfive_pcie_ops = { >> + .read_config = starfive_pcie_config_read, >> + .write_config = starfive_pcie_config_write, >> +}; >> + >> +static const struct udevice_id starfive_pcie_ids[] = { >> + { .compatible = "starfive,jh7110-pcie" }, >> + { } >> +}; >> + >> +U_BOOT_DRIVER(starfive_pcie_drv) = { >> + .name = "starfive_7110_pcie", >> + .id = UCLASS_PCI, >> + .of_match = starfive_pcie_ids, >> + .ops = &starfive_pcie_ops, >> + .probe = starfive_pcie_probe, >> + .priv_auto = sizeof(struct starfive_pcie), >> +}; >> -- >> 2.17.1 >>
On Friday 10 March 2023 18:36:44 Minda Chen wrote: > On 2023/3/8 15:31, Pali Rohár wrote: > > Hello! See few comments below. > > > > On Wednesday 08 March 2023 13:48:31 Minda Chen wrote: > >> From: Mason Huo mason.huo@starfivetech.com > >> > >> Add pcie driver for StarFive JH7110, the driver depends on > >> starfive gpio, pinctrl, clk and reset driver to do init. > >> > >> Several devices are tested: > >> a) M.2 NVMe SSD > >> b) Realtek 8169 Ethernet adapter. > >> > >> Signed-off-by: Mason Huo mason.huo@starfivetech.com > >> Signed-off-by: Minda Chen minda.chen@starfivetech.com > >> --- > >> drivers/pci/Kconfig | 11 + > >> drivers/pci/Makefile | 1 + > >> drivers/pci/pcie_starfive_jh7110.c | 478 +++++++++++++++++++++++++++++ > >> 3 files changed, 490 insertions(+) > >> create mode 100644 drivers/pci/pcie_starfive_jh7110.c > >> > >> diff --git a/drivers/pci/Kconfig b/drivers/pci/Kconfig > >> index ef328d2652..e7b0ff5bc3 100644 > >> --- a/drivers/pci/Kconfig > >> +++ b/drivers/pci/Kconfig > >> @@ -374,4 +374,15 @@ config PCIE_UNIPHIER > >> Say Y here if you want to enable PCIe controller support on > >> UniPhier SoCs. > >> > >> +config PCIE_STARFIVE_JH7110 > >> + bool "Enable Starfive JH7110 PCIe driver" > >> + depends on STARFIVE_JH7110 > >> + depends on PINCTRL_STARFIVE_JH7110 > >> + depends on CLK_JH7110 > >> + depends on RESET_JH7110 > >> + default y > >> + help > >> + Say Y here if you want to enable PCIe controller support on > >> + StarFive JH7110 SoC. > >> + > >> endif > >> diff --git a/drivers/pci/Makefile b/drivers/pci/Makefile > >> index 49506e7ba5..bbe3323bb5 100644 > >> --- a/drivers/pci/Makefile > >> +++ b/drivers/pci/Makefile > >> @@ -49,3 +49,4 @@ obj-$(CONFIG_PCI_OCTEONTX) += pci_octeontx.o > >> obj-$(CONFIG_PCIE_OCTEON) += pcie_octeon.o > >> obj-$(CONFIG_PCIE_DW_SIFIVE) += pcie_dw_sifive.o > >> obj-$(CONFIG_PCIE_UNIPHIER) += pcie_uniphier.o > >> +obj-$(CONFIG_PCIE_STARFIVE_JH7110) += pcie_starfive_jh7110.o > >> diff --git a/drivers/pci/pcie_starfive_jh7110.c b/drivers/pci/pcie_starfive_jh7110.c > >> new file mode 100644 > >> index 0000000000..5ccef1ef02 > >> --- /dev/null > >> +++ b/drivers/pci/pcie_starfive_jh7110.c > >> @@ -0,0 +1,478 @@ > >> +// SPDX-License-Identifier: GPL-2.0+ > >> +/* > >> + * StarFive PLDA PCIe host controller driver > >> + * > >> + * Copyright (c) 2023 Starfive, Inc. > >> + * Author: Mason Huo mason.huo@starfivetech.com > >> + * > >> + */ > >> + > >> +#include <common.h> > >> +#include <clk.h> > >> +#include <dm.h> > >> +#include <generic-phy.h> > >> +#include <pci.h> > >> +#include <power-domain.h> > >> +#include <regmap.h> > >> +#include <reset.h> > >> +#include <syscon.h> > >> +#include <asm/global_data.h> > >> +#include <asm/io.h> > >> +#include <asm-generic/gpio.h> > >> +#include <dm/device_compat.h> > >> +#include <dm/pinctrl.h> > >> +#include <linux/delay.h> > >> +#include <linux/iopoll.h> > >> +#include <power/regulator.h> > >> + > >> +DECLARE_GLOBAL_DATA_PTR; > >> + > >> +#define GEN_SETTINGS 0x80 > >> +#define PCIE_PCI_IDS 0x9C > >> +#define PCIE_WINROM 0xFC > >> +#define PMSG_SUPPORT_RX 0x3F0 > >> +#define PCI_MISC 0xB4 > >> + > >> +#define PLDA_EP_ENABLE 0 > >> +#define PLDA_RP_ENABLE 1 > >> + > >> +#define IDS_REVISION_ID 0x02 > >> +#define IDS_PCI_TO_PCI_BRIDGE 0x060400 > >> +#define IDS_CLASS_CODE_SHIFT 8 > > > > Please do not duplicate standard PCI macros and constants. In U-Boot > > they are already available in include/pci_ids.h header file. > > > ok > >> +#define PREF_MEM_WIN_64_SUPPORT BIT(3) > >> +#define PMSG_LTR_SUPPORT BIT(2) > >> +#define PLDA_FUNCTION_DIS BIT(15) > >> +#define PLDA_FUNC_NUM 4 > >> +#define PLDA_PHY_FUNC_SHIFT 9 > >> + > >> +#define XR3PCI_ATR_AXI4_SLV0 0x800 > >> +#define XR3PCI_ATR_SRC_ADDR_LOW 0x0 > >> +#define XR3PCI_ATR_SRC_ADDR_HIGH 0x4 > >> +#define XR3PCI_ATR_TRSL_ADDR_LOW 0x8 > >> +#define XR3PCI_ATR_TRSL_ADDR_HIGH 0xc > >> +#define XR3PCI_ATR_TRSL_PARAM 0x10 > >> +#define XR3PCI_ATR_TABLE_OFFSET 0x20 > >> +#define XR3PCI_ATR_MAX_TABLE_NUM 8 > >> + > >> +#define XR3PCI_ATR_SRC_WIN_SIZE_SHIFT 1 > >> +#define XR3PCI_ATR_SRC_ADDR_MASK GENMASK(31, 12) > >> +#define XR3PCI_ATR_TRSL_ADDR_MASK GENMASK(31, 12) > >> +#define XR3_PCI_ECAM_SIZE 28 > >> +#define XR3PCI_ATR_TRSL_DIR BIT(22) > >> +/* IDs used in the XR3PCI_ATR_TRSL_PARAM */ > >> +#define XR3PCI_ATR_TRSLID_PCIE_MEMORY 0x0 > >> +#define XR3PCI_ATR_TRSLID_PCIE_CONFIG 0x1 > >> + > >> +#define ECAM_BUS_SHIFT 20 > >> +#define ECAM_DEV_SHIFT 15 > >> +#define ECAM_FUNC_SHIFT 12 > > > > Please do not implement duplicate PCIe ECAM code. U-Boot and also Linux > > kernel already provides PCIE_ECAM_OFFSET() macro. > > > >> +/* Secondary bus number offset in config space */ > >> +#define PCI_SECONDARY_BUS 0x19 > > > > Unused. > > > ok > >> + > >> +/* system control */ > >> +#define STG_SYSCON_K_RP_NEP_MASK BIT(8) > >> +#define STG_SYSCON_AXI4_SLVL_ARFUNC_MASK GENMASK(22, 8) > >> +#define STG_SYSCON_AXI4_SLVL_ARFUNC_SHIFT 8 > >> +#define STG_SYSCON_AXI4_SLVL_AWFUNC_MASK GENMASK(14, 0) > >> +#define STG_SYSCON_CLKREQ_MASK BIT(22) > >> +#define STG_SYSCON_CKREF_SRC_SHIFT 18 > >> +#define STG_SYSCON_CKREF_SRC_MASK GENMASK(19, 18) > >> + > >> +struct starfive_pcie { > >> + struct udevice *dev; > >> + > >> + void __iomem *reg_base; > >> + void __iomem *cfg_base; > >> + > >> + struct regmap *regmap; > >> + u32 stg_arfun; > >> + u32 stg_awfun; > >> + u32 stg_rp_nep; > >> + > >> + struct clk_bulk clks; > >> + struct reset_ctl_bulk rsts; > >> + > >> + int atr_table_num; > >> + int first_busno; > >> +}; > >> + > >> +static int starfive_pcie_addr_valid(pci_dev_t bdf, int first_busno) > >> +{ > >> + if ((PCI_BUS(bdf) == first_busno) && (PCI_DEV(bdf) > 0)) > >> + return 0; > >> + if ((PCI_BUS(bdf) == first_busno + 1) && (PCI_DEV(bdf) > 0)) > >> + return 0; > > > > If fisrt_busno is the bus of the root port then first_busno+1 does not > > have to bus of the PCIe device on the other end of the link from the > > root port. See for example pci_mvebu.c how this logic is handled. > > You probably want to also limit access to non-zero function of root port > > unless you have multifunction root-port device. > > > root port limitation can follow the pci_mvebu.c
bus 1.
Ok, in this case filter out bus behind the root bus and describe this HW bug in code comment, so it would be clear why it is needed.
And anyway, could you report this ECAM bug to HW engineers, so they can fix it in new version of PCIe controller? Because this is violation of ECAM as described in the PCIe base standard.
> >> + > >> + return 1; > >> +} > >> + > >> +static int starfive_pcie_off_conf(pci_dev_t bdf, uint offset) > >> +{ > >> + unsigned int bus = PCI_BUS(bdf); > >> + unsigned int dev = PCI_DEV(bdf); > >> + unsigned int func = PCI_FUNC(bdf); > >> + > >> + return (bus << ECAM_BUS_SHIFT) | (dev << ECAM_DEV_SHIFT) | > >> + (func << ECAM_FUNC_SHIFT) | offset; > >> +} > >> + > >> +static bool starfive_pcie_hide_rc_bar(pci_dev_t bdf, int offset) > >> +{ > >> + /* Only root port 1 is in use */ > >> + if ((PCI_BUS(bdf) == 0) && > > > > This looks like an incorrect check for the bus of he root port. > > See for example pci_mvebu.c where logic should be correct. > > > > I guess you wanted to use: PCI_BUS(bdf)-dev_seq(udev) > > [1] This is a work around method. Our PCIe support 64bit. But the config > space is 16KB. If no limitation here, uboot will set high 32 bit base address to 0xfffffff after init.
> But this will make kernel pcie failed. This value will be not cleared. > While kernel read the base address first. kernel pcie can not work. > And our IC we can not reset the PCIe to clear this value. > I dont know how to fix it expcept this method.
Well, this sounds like a bug in kernel, which should be fixed or at least reported. > And if in the u-boot is workaround for particular kernel bug then it should be properly documented with information in which kernel version was bug fixed. Otherwise u-boot code stay in non-maintenanceble state.
> >> + (offset == PCI_BASE_ADDRESS_0 || offset == PCI_BASE_ADDRESS_1)) > >> + return true; > >> + > >> + return false; > >> +} > >> + > >> +static int starfive_pcie_conf_address(const struct udevice *udev, pci_dev_t bdf, > >> + uint offset, void **paddr) > >> +{ > >> + struct starfive_pcie *priv = dev_get_priv(udev); > >> + int where = starfive_pcie_off_conf(bdf, offset); > >> + > >> + if (!starfive_pcie_addr_valid(bdf, priv->first_busno)) > >> + return -EINVAL; > > > > Is this check needed? Does it mean that ECAM returns bogus information > > for disconnected devices, that it needs to be manually filtered? (Which > > is against PCIe spec). > > > I found nvme device can not work if the non-zero function of root port > without limitation. But I will try to fix it. Maybe I can remove this.
> >> + > >> + *paddr = (void *)(priv->cfg_base + where); > >> + return 0; > >> +} > >> + > >> +static int starfive_pcie_config_read(const struct udevice *udev, pci_dev_t bdf, > >> + uint offset, ulong *valuep, > >> + enum pci_size_t size) > >> +{ > >> + /* Make sure the LAST TLP is finished, before reading vendor ID. */ > >> + if (offset == PCI_VENDOR_ID) > >> + mdelay(20); > > > > This looks strange. There is some bug / errata that reading vendor id > > from ECAM does not work correctly? > > > I will remove this. It is not a errata of reading the vendor ID. > >> + > >> + return pci_generic_mmap_read_config(udev, starfive_pcie_conf_address, > >> + bdf, offset, valuep, size); > >> +} > >> + > >> +int starfive_pcie_config_write(struct udevice *udev, pci_dev_t bdf, > >> + uint offset, ulong value, > >> + enum pci_size_t size) > >> +{ > >> + if (starfive_pcie_hide_rc_bar(bdf, offset)) > >> + return 0; > > > > Why you are ignoring writes to some offset, but not ignoring reads? And > > ignoring results in no-error (return value 0)? > >The same as [1]
> >> + > >> + return pci_generic_mmap_write_config(udev, starfive_pcie_conf_address, > >> + bdf, offset, value, size); > >> +} > >> + > >> +static int starfive_pcie_set_atr_entry(struct starfive_pcie *priv, phys_addr_t src_addr, > >> + phys_addr_t trsl_addr, size_t window_size, > >> + int trsl_param) > >> +{ > >> + void __iomem *base = > >> + priv->reg_base + XR3PCI_ATR_AXI4_SLV0; > >> + > >> + /* Support AXI4 Slave 0 Address Translation Tables 0-7. */ > >> + if (priv->atr_table_num >= XR3PCI_ATR_MAX_TABLE_NUM) { > >> + dev_err(priv->dev, "ATR table number %d exceeds max num\n", > >> + priv->atr_table_num); > >> + return -EINVAL; > >> + } > >> + base += XR3PCI_ATR_TABLE_OFFSET * priv->atr_table_num; > >> + priv->atr_table_num++; > >> + > >> + /* X3PCI_ATR_SRC_ADDR_LOW: > >> + * - bit 0: enable entry, > >> + * - bits 1-6: ATR window size: total size in bytes: 2^(ATR_WSIZE + 1) > >> + * - bits 7-11: reserved > >> + * - bits 12-31: start of source address > >> + */ > >> + writel((lower_32_bits(src_addr) & XR3PCI_ATR_SRC_ADDR_MASK) | > >> + (fls(window_size) - 1) << XR3PCI_ATR_SRC_WIN_SIZE_SHIFT | 1, > >> + base + XR3PCI_ATR_SRC_ADDR_LOW); > >> + writel(upper_32_bits(src_addr), base + XR3PCI_ATR_SRC_ADDR_HIGH); > >> + writel((lower_32_bits(trsl_addr) & XR3PCI_ATR_TRSL_ADDR_MASK), > >> + base + XR3PCI_ATR_TRSL_ADDR_LOW); > >> + writel(upper_32_bits(trsl_addr), base + XR3PCI_ATR_TRSL_ADDR_HIGH); > >> + writel(trsl_param, base + XR3PCI_ATR_TRSL_PARAM); > >> + > >> + dev_dbg(priv->dev, "ATR entry: 0x%010llx %s 0x%010llx [0x%010llx] (param: 0x%06x)\n", > >> + src_addr, (trsl_param & XR3PCI_ATR_TRSL_DIR) ? "<-" : "->", > >> + trsl_addr, (u64)window_size, trsl_param); > >> + return 0; > >> +} > >> + > >> +static int starfive_pcie_atr_init(struct starfive_pcie *priv) > >> +{ > >> + struct udevice *ctlr = pci_get_controller(priv->dev); > >> + struct pci_controller *hose = dev_get_uclass_priv(ctlr); > >> + int i, ret; > >> + > >> + /* As the two host bridges in JH7110 soc have the same default > >> + * address translation table, this cause the second root port can't > >> + * access it's host bridge config space correctly. > >> + * To workaround, config the ATR of host bridge config space by SW. > >> + */ > >> + > >> + ret = starfive_pcie_set_atr_entry(priv, > >> + (phys_addr_t)priv->cfg_base, > >> + 0, > >> + 1 << XR3_PCI_ECAM_SIZE, > >> + XR3PCI_ATR_TRSLID_PCIE_CONFIG); > >> + if (ret) > >> + return ret; > >> + > >> + for (i = 0; i < hose->region_count; i++) { > >> + if (hose->regions[i].flags == PCI_REGION_SYS_MEMORY) > >> + continue; > >> + > >> + /* Only support identity mappings. */ > >> + if (hose->regions[i].bus_start != > >> + hose->regions[i].phys_start) > >> + return -EINVAL; > >> + > >> + ret = starfive_pcie_set_atr_entry(priv, > >> + hose->regions[i].phys_start, > >> + hose->regions[i].bus_start, > >> + hose->regions[i].size, > >> + XR3PCI_ATR_TRSLID_PCIE_MEMORY); > >> + if (ret) > >> + return ret; > >> + } > >> + > >> + return 0; > >> +} > >> + > >> +static int starfive_pcie_get_syscon(struct udevice *dev) > >> +{ > >> + struct starfive_pcie *priv = dev_get_priv(dev); > >> + struct udevice *syscon; > >> + struct ofnode_phandle_args syscfg_phandle; > >> + u32 cells[4]; > >> + int ret; > >> + > >> + /* get corresponding syscon phandle */ > >> + ret = dev_read_phandle_with_args(dev, "starfive,stg-syscon", NULL, 0, 0, > >> + &syscfg_phandle); > >> + > >> + if (ret < 0) { > >> + dev_err(dev, "Can't get syscfg phandle: %d\n", ret); > >> + return ret; > >> + } > >> + > >> + ret = uclass_get_device_by_ofnode(UCLASS_SYSCON, syscfg_phandle.node, > >> + &syscon); > >> + if (ret) { > >> + dev_err(dev, "Unable to find syscon device (%d)\n", ret); > >> + return ret; > >> + } > >> + > >> + priv->regmap = syscon_get_regmap(syscon); > >> + if (!priv->regmap) { > >> + dev_err(dev, "Unable to find regmap\n"); > >> + return -ENODEV; > >> + } > >> + > >> + /* get syscon register offset */ > >> + ret = dev_read_u32_array(dev, "starfive,stg-syscon", > >> + cells, ARRAY_SIZE(cells)); > >> + if (ret) { > >> + dev_err(dev, "Get syscon register err %d\n", ret); > >> + return -EINVAL; > >> + } > >> + > >> + dev_dbg(dev, "Get syscon values: %x, %x, %x\n", > >> + cells[1], cells[2], cells[3]); > >> + priv->stg_arfun = cells[1]; > >> + priv->stg_awfun = cells[2]; > >> + priv->stg_rp_nep = cells[3]; > >> + > >> + return 0; > >> +} > >> + > >> +static int starfive_pcie_parse_dt(struct udevice *dev) > >> +{ > >> + struct starfive_pcie *priv = dev_get_priv(dev); > >> + int ret; > >> + > >> + priv->reg_base = (void *)dev_read_addr_name(dev, "reg"); > >> + if (priv->reg_base == (void __iomem *)FDT_ADDR_T_NONE) { > >> + dev_err(dev, "Missing required reg address range\n"); > >> + return -EINVAL; > >> + } > >> + > >> + priv->cfg_base = (void *)dev_read_addr_name(dev, "config"); > >> + if (priv->cfg_base == (void __iomem *)FDT_ADDR_T_NONE) { > >> + dev_err(dev, "Missing required config address range"); > >> + return -EINVAL; > >> + } > >> + > >> + ret = starfive_pcie_get_syscon(dev); > >> + if (ret) { > >> + dev_err(dev, "Can't get syscon: %d\n", ret); > >> + return ret; > >> + } > >> + > >> + ret = reset_get_bulk(dev, &priv->rsts); > >> + if (ret) { > >> + dev_err(dev, "Can't get reset: %d\n", ret); > >> + return ret; > >> + } > >> + > >> + ret = clk_get_bulk(dev, &priv->clks); > >> + if (ret) { > >> + dev_err(dev, "Can't get clock: %d\n", ret); > >> + return ret; > >> + } > >> + > >> + return 0; > >> +} > >> + > >> +static int starfive_pcie_init_port(struct udevice *dev) > >> +{ > >> + int ret, i; > >> + unsigned int value; > >> + struct starfive_pcie *priv = dev_get_priv(dev); > >> + > >> + ret = clk_enable_bulk(&priv->clks); > >> + if (ret) { > >> + dev_err(dev, "Failed to enable clks (ret=%d)\n", ret); > >> + return ret; > >> + } > >> + > >> + ret = reset_deassert_bulk(&priv->rsts); > >> + if (ret) { > >> + dev_err(dev, "Failed to deassert resets (ret=%d)\n", ret); > >> + goto err_deassert_clk; > >> + } > >> + > >> + ret = pinctrl_select_state(dev, "perst-active"); > >> + if (ret) { > >> + dev_err(dev, "Set perst-active pinctrl failed: %d\n", ret); > >> + goto err_deassert_reset; > >> + } > >> + > >> + /* Disable physical functions except #0 */ > >> + for (i = 1; i < PLDA_FUNC_NUM; i++) { > >> + regmap_update_bits(priv->regmap, > >> + priv->stg_arfun, > >> + STG_SYSCON_AXI4_SLVL_ARFUNC_MASK, > >> + (i << PLDA_PHY_FUNC_SHIFT) << > >> + STG_SYSCON_AXI4_SLVL_ARFUNC_SHIFT); > >> + regmap_update_bits(priv->regmap, > >> + priv->stg_awfun, > >> + STG_SYSCON_AXI4_SLVL_AWFUNC_MASK, > >> + i << PLDA_PHY_FUNC_SHIFT); > >> + > >> + value = readl(priv->reg_base + PCI_MISC); > >> + value |= PLDA_FUNCTION_DIS; > >> + writel(value, priv->reg_base + PCI_MISC); > >> + } > >> + > >> + /* Disable physical functions */ > >> + regmap_update_bits(priv->regmap, > >> + priv->stg_arfun, > >> + STG_SYSCON_AXI4_SLVL_ARFUNC_MASK, > >> + 0); > >> + regmap_update_bits(priv->regmap, > >> + priv->stg_awfun, > >> + STG_SYSCON_AXI4_SLVL_AWFUNC_MASK, > >> + 0); > >> + > >> + /* Enable root port */ > >> + value = readl(priv->reg_base + GEN_SETTINGS); > >> + value |= PLDA_RP_ENABLE; > >> + writel(value, priv->reg_base + GEN_SETTINGS); > >> + > >> + /* PCIe PCI Standard Configuration Identification Settings. */ > >> + value = (IDS_PCI_TO_PCI_BRIDGE << IDS_CLASS_CODE_SHIFT) | IDS_REVISION_ID; > >> + writel(value, priv->reg_base + PCIE_PCI_IDS); > >> + > >> + /* The LTR message forwarding of PCIe Message Reception was set by core > >> + * as default, but the forward id & addr are also need to be reset. > >> + * If we do not disable LTR message forwarding here, or set a legal > >> + * forwarding address, the kernel will get stuck after this driver probe. > >> + * To workaround, disable the LTR message forwarding support on > >> + * PCIe Message Reception. > >> + */ > >> + value = readl(priv->reg_base + PMSG_SUPPORT_RX); > >> + value &= ~PMSG_LTR_SUPPORT; > >> + writel(value, priv->reg_base + PMSG_SUPPORT_RX); > >> + > >> + /* Prefetchable memory window 64-bit addressing support */ > >> + value = readl(priv->reg_base + PCIE_WINROM); > >> + value |= PREF_MEM_WIN_64_SUPPORT; > >> + writel(value, priv->reg_base + PCIE_WINROM); > >> + > >> + starfive_pcie_atr_init(priv); > >> + > >> + /* Ensure that PERST has been asserted for at least 300 ms */ > >> + mdelay(300); > >> + ret = pinctrl_select_state(dev, "perst-default"); > >> + if (ret) { > >> + dev_err(dev, "Set perst-default pinctrl failed: %d\n", ret); > >> + return ret; > >> + } > >> + > >> + return 0; > >> + > >> +err_deassert_clk: > >> + clk_disable_bulk(&priv->clks); > >> +err_deassert_reset: > >> + reset_assert_bulk(&priv->rsts); > >> + return ret; > >> +} > >> + > >> +static int starfive_pcie_probe(struct udevice *dev) > >> +{ > >> + struct starfive_pcie *priv = dev_get_priv(dev); > >> + int ret; > >> + > >> + priv->atr_table_num = 0; > >> + priv->dev = dev; > >> + priv->first_busno = dev_seq(dev); > >> + > >> + ret = starfive_pcie_parse_dt(dev); > >> + if (ret) > >> + return ret; > >> + > >> + regmap_update_bits(priv->regmap, > >> + priv->stg_rp_nep, > >> + STG_SYSCON_K_RP_NEP_MASK, > >> + STG_SYSCON_K_RP_NEP_MASK); > >> + > >> + regmap_update_bits(priv->regmap, > >> + priv->stg_awfun, > >> + STG_SYSCON_CKREF_SRC_MASK, > >> + 2 << STG_SYSCON_CKREF_SRC_SHIFT); > >> + > >> + regmap_update_bits(priv->regmap, > >> + priv->stg_awfun, > >> + STG_SYSCON_CLKREQ_MASK, > >> + STG_SYSCON_CLKREQ_MASK); > >> + > >> + ret = starfive_pcie_init_port(dev); > >> + if (ret) > >> + return ret; > >> + > >> + dev_err(dev, "Starfive PCIe bus probed.\n"); > >> + > >> + return 0; > >> +} > >> + > >> +static const struct dm_pci_ops starfive_pcie_ops = { > >> + .read_config = starfive_pcie_config_read, > >> + .write_config = starfive_pcie_config_write, > >> +}; > >> + > >> +static const struct udevice_id starfive_pcie_ids[] = { > >> + { .compatible = "starfive,jh7110-pcie" }, > >> + { } > >> +}; > >> + > >> +U_BOOT_DRIVER(starfive_pcie_drv) = { > >> + .name = "starfive_7110_pcie", > >> + .id = UCLASS_PCI, > >> + .of_match = starfive_pcie_ids, > >> + .ops = &starfive_pcie_ops, > >> + .probe = starfive_pcie_probe, > >> + .priv_auto = sizeof(struct starfive_pcie), > >> +}; > >> -- > >> 2.17.1 > >>
On Wed, Mar 8, 2023 at 1:49 PM Minda Chen minda.chen@starfivetech.com wrote:
Add pcie driver for StarFive JH7110, the driver depends on starfive gpio, pinctrl, clk and reset driver to do init.
Several devices are tested: a) M.2 NVMe SSD b) Realtek 8169 Ethernet adapter.
Signed-off-by: Mason Huo mason.huo@starfivetech.com Signed-off-by: Minda Chen minda.chen@starfivetech.com
drivers/pci/Kconfig | 11 + drivers/pci/Makefile | 1 + drivers/pci/pcie_starfive_jh7110.c | 478 +++++++++++++++++++++++++++++ 3 files changed, 490 insertions(+) create mode 100644 drivers/pci/pcie_starfive_jh7110.c
diff --git a/drivers/pci/Kconfig b/drivers/pci/Kconfig index ef328d2652..e7b0ff5bc3 100644 --- a/drivers/pci/Kconfig +++ b/drivers/pci/Kconfig @@ -374,4 +374,15 @@ config PCIE_UNIPHIER Say Y here if you want to enable PCIe controller support on UniPhier SoCs.
default y
help
endif diff --git a/drivers/pci/Makefile b/drivers/pci/Makefile index 49506e7ba5..bbe3323bb5 100644 --- a/drivers/pci/Makefile +++ b/drivers/pci/Makefile @@ -49,3 +49,4 @@ obj-$(CONFIG_PCI_OCTEONTX) += pci_octeontx.o obj-$(CONFIG_PCIE_OCTEON) += pcie_octeon.o obj-$(CONFIG_PCIE_DW_SIFIVE) += pcie_dw_sifive.o obj-$(CONFIG_PCIE_UNIPHIER) += pcie_uniphier.o +obj-$(CONFIG_PCIE_STARFIVE_JH7110) += pcie_starfive_jh7110.o diff --git a/drivers/pci/pcie_starfive_jh7110.c b/drivers/pci/pcie_starfive_jh7110.c new file mode 100644 index 0000000000..5ccef1ef02 --- /dev/null +++ b/drivers/pci/pcie_starfive_jh7110.c @@ -0,0 +1,478 @@ +// SPDX-License-Identifier: GPL-2.0+ +/*
- StarFive PLDA PCIe host controller driver
- Copyright (c) 2023 Starfive, Inc.
- Author: Mason Huo mason.huo@starfivetech.com
+#include <common.h> +#include <clk.h> +#include <dm.h> +#include <generic-phy.h> +#include <pci.h> +#include <power-domain.h> +#include <regmap.h> +#include <reset.h> +#include <syscon.h> +#include <asm/global_data.h> +#include <asm/io.h> +#include <asm-generic/gpio.h> +#include <dm/device_compat.h> +#include <dm/pinctrl.h> +#include <linux/delay.h> +#include <linux/iopoll.h> +#include <power/regulator.h>
+#define GEN_SETTINGS 0x80 +#define PCIE_PCI_IDS 0x9C +#define PCIE_WINROM 0xFC +#define PMSG_SUPPORT_RX 0x3F0 +#define PCI_MISC 0xB4
+#define PLDA_EP_ENABLE 0 +#define PLDA_RP_ENABLE 1
+#define IDS_REVISION_ID 0x02 +#define IDS_PCI_TO_PCI_BRIDGE 0x060400 +#define IDS_CLASS_CODE_SHIFT 8
+#define PREF_MEM_WIN_64_SUPPORT BIT(3) +#define PMSG_LTR_SUPPORT BIT(2) +#define PLDA_FUNCTION_DIS BIT(15) +#define PLDA_FUNC_NUM 4 +#define PLDA_PHY_FUNC_SHIFT 9
+#define XR3PCI_ATR_AXI4_SLV0 0x800 +#define XR3PCI_ATR_SRC_ADDR_LOW 0x0 +#define XR3PCI_ATR_SRC_ADDR_HIGH 0x4 +#define XR3PCI_ATR_TRSL_ADDR_LOW 0x8 +#define XR3PCI_ATR_TRSL_ADDR_HIGH 0xc +#define XR3PCI_ATR_TRSL_PARAM 0x10 +#define XR3PCI_ATR_TABLE_OFFSET 0x20 +#define XR3PCI_ATR_MAX_TABLE_NUM 8
+#define XR3PCI_ATR_SRC_WIN_SIZE_SHIFT 1 +#define XR3PCI_ATR_SRC_ADDR_MASK GENMASK(31, 12) +#define XR3PCI_ATR_TRSL_ADDR_MASK GENMASK(31, 12) +#define XR3_PCI_ECAM_SIZE 28 +#define XR3PCI_ATR_TRSL_DIR BIT(22) +/* IDs used in the XR3PCI_ATR_TRSL_PARAM */ +#define XR3PCI_ATR_TRSLID_PCIE_MEMORY 0x0 +#define XR3PCI_ATR_TRSLID_PCIE_CONFIG 0x1
+#define ECAM_BUS_SHIFT 20 +#define ECAM_DEV_SHIFT 15 +#define ECAM_FUNC_SHIFT 12 +/* Secondary bus number offset in config space */ +#define PCI_SECONDARY_BUS 0x19
+/* system control */ +#define STG_SYSCON_K_RP_NEP_MASK BIT(8) +#define STG_SYSCON_AXI4_SLVL_ARFUNC_MASK GENMASK(22, 8) +#define STG_SYSCON_AXI4_SLVL_ARFUNC_SHIFT 8 +#define STG_SYSCON_AXI4_SLVL_AWFUNC_MASK GENMASK(14, 0) +#define STG_SYSCON_CLKREQ_MASK BIT(22) +#define STG_SYSCON_CKREF_SRC_SHIFT 18 +#define STG_SYSCON_CKREF_SRC_MASK GENMASK(19, 18)
u32 stg_arfun;
u32 stg_awfun;
u32 stg_rp_nep;
int atr_table_num;
int first_busno;
+static int starfive_pcie_addr_valid(pci_dev_t bdf, int first_busno) +{
return 1;
+static int starfive_pcie_off_conf(pci_dev_t bdf, uint offset) +{
+static bool starfive_pcie_hide_rc_bar(pci_dev_t bdf, int offset) +{
return true;
return false;
return -EINVAL;
mdelay(20);
int trsl_param)
return -EINVAL;
+static int starfive_pcie_atr_init(struct starfive_pcie *priv) +{
int i, ret;
0,
if (ret)
return ret;
continue;
return -EINVAL;
if (ret)
return ret;
+static int starfive_pcie_get_syscon(struct udevice *dev) +{
u32 cells[4];
int ret;
&syscfg_phandle);
if (ret < 0) {
return ret;
&syscon);
if (ret) {
return ret;
return -ENODEV;
if (ret) {
return -EINVAL;
+static int starfive_pcie_parse_dt(struct udevice *dev) +{
int ret;
return -EINVAL;
return -EINVAL;
if (ret) {
return ret;
if (ret) {
return ret;
if (ret) {
return ret;
+static int starfive_pcie_init_port(struct udevice *dev) +{
int ret, i;
unsigned int value;
if (ret) {
return ret;
if (ret) {
if (ret) {
priv->stg_arfun,
priv->stg_awfun,
priv->stg_arfun,
0);
priv->stg_awfun,
0);
Wrong multi-line comment format.
mdelay(300);
if (ret) {
return ret;
+err_deassert_clk:
return ret;
+static int starfive_pcie_probe(struct udevice *dev) +{
int ret;
priv->dev = dev;
if (ret)
return ret;
priv->stg_rp_nep,
priv->stg_awfun,
priv->stg_awfun,
if (ret)
return ret;
Is this PCIe controller a StarFive IP? Or some 3rd party licensed IP? Is this compatible string approved by the DT community?
.id = UCLASS_PCI,
Regards, Bin
also add the nvme driver and rtl8169 support.
Signed-off-by: Mason Huo mason.huo@starfivetech.com Signed-off-by: Minda Chen minda.chen@starfivetech.com --- configs/starfive_visionfive2_defconfig | 9 +++++++++ 1 file changed, 9 insertions(+)
diff --git a/configs/starfive_visionfive2_defconfig b/configs/starfive_visionfive2_defconfig index 550d0ff3ab..98d23d9461 100644 --- a/configs/starfive_visionfive2_defconfig +++ b/configs/starfive_visionfive2_defconfig @@ -16,6 +16,7 @@ CONFIG_SPL=y CONFIG_SPL_SPI_FLASH_SUPPORT=y CONFIG_SPL_SPI=y CONFIG_SYS_LOAD_ADDR=0x82000000 +CONFIG_SYS_PCI_64BIT=y CONFIG_TARGET_STARFIVE_VISIONFIVE2=y CONFIG_SPL_OPENSBI_LOAD_ADDR=0x40000000 CONFIG_ARCH_RV64I=y @@ -50,8 +51,11 @@ CONFIG_SYS_CBSIZE=256 CONFIG_SYS_PBSIZE=276 CONFIG_SYS_BOOTM_LEN=0x4000000 CONFIG_CMD_MEMINFO=y +CONFIG_CMD_PCI=y CONFIG_CMD_TFTPPUT=y CONFIG_SYS_RELOC_GD_ENV_ADDR=y +CONFIG_REGMAP=y +CONFIG_SYSCON=y CONFIG_SPL_CLK_COMPOSITE_CCF=y CONFIG_CLK_COMPOSITE_CCF=y CONFIG_SPL_CLK_JH7110=y @@ -65,6 +69,11 @@ CONFIG_SPI_FLASH_EON=y CONFIG_SPI_FLASH_GIGADEVICE=y CONFIG_SPI_FLASH_ISSI=y CONFIG_SPI_FLASH_MACRONIX=y +CONFIG_RTL8169=y +CONFIG_NVME_PCI=y +CONFIG_PCI=y +CONFIG_DM_PCI_COMPAT=y +CONFIG_PCI_REGION_MULTI_ENTRY=y CONFIG_PINCTRL=y CONFIG_PINCONF=y CONFIG_SPL_PINCTRL=y
Enable and add pinctrl configuration for PCIe host controller. Also add JH7110 stg syscon configuration.
Signed-off-by: Mason Huo mason.huo@starfivetech.com Signed-off-by: Minda Chen minda.chen@starfivetech.com --- .../dts/jh7110-starfive-visionfive-2.dtsi | 99 +++++++++++++++++++ arch/riscv/dts/jh7110.dtsi | 75 ++++++++++++++ 2 files changed, 174 insertions(+)
diff --git a/arch/riscv/dts/jh7110-starfive-visionfive-2.dtsi b/arch/riscv/dts/jh7110-starfive-visionfive-2.dtsi index e669c2a26a..995f842a6b 100644 --- a/arch/riscv/dts/jh7110-starfive-visionfive-2.dtsi +++ b/arch/riscv/dts/jh7110-starfive-visionfive-2.dtsi @@ -178,6 +178,87 @@ slew-rate = <0>; }; }; + + pcie0_perst_default: pcie0_perst_default { + perst-pins { + pinmux = <GPIOMUX(26, GPOUT_HIGH, GPOEN_ENABLE, GPI_NONE)>; + drive-strength = <2>; + input-disable; + input-schmitt-disable; + slew-rate = <0>; + }; + }; + + pcie0_perst_active: pcie0_perst_active { + perst-pins { + pinmux = <GPIOMUX(26, GPOUT_LOW, GPOEN_ENABLE, GPI_NONE)>; + drive-strength = <2>; + input-disable; + input-schmitt-disable; + slew-rate = <0>; + }; + }; + + pcie0_wake_default: pcie0_wake_default { + wake-pins { + pinmux = <GPIOMUX(32, GPOUT_HIGH, GPOEN_ENABLE, GPI_NONE)>; + drive-strength = <2>; + input-enable; + input-schmitt-disable; + slew-rate = <0>; + }; + }; + + pcie0_clkreq_default: pcie0_clkreq_default { + clkreq-pins { + pinmux = <GPIOMUX(27, GPOUT_HIGH, GPOEN_ENABLE, GPI_NONE)>; + drive-strength = <2>; + input-enable; + input-schmitt-disable; + slew-rate = <0>; + }; + }; + + pcie1_perst_default: pcie1_perst_default { + perst-pins { + pinmux = <GPIOMUX(28, GPOUT_HIGH, GPOEN_ENABLE, GPI_NONE)>; + drive-strength = <2>; + input-disable; + input-schmitt-disable; + slew-rate = <0>; + }; + }; + + pcie1_perst_active: pcie1_perst_active { + perst-pins { + pinmux = <GPIOMUX(28, GPOUT_LOW, GPOEN_ENABLE, GPI_NONE)>; + drive-strength = <2>; + input-disable; + input-schmitt-disable; + slew-rate = <0>; + }; + }; + + pcie1_wake_default: pcie1_wake_default { + wake-pins { + pinmux = <GPIOMUX(21, GPOUT_HIGH, GPOEN_ENABLE, GPI_NONE)>; + drive-strength = <2>; + input-enable; + input-schmitt-disable; + slew-rate = <0>; + }; + }; + + pcie1_clkreq_default: pcie1_clkreq_default { + clkreq-pins { + pinmux = <GPIOMUX(29, GPOUT_HIGH, GPOEN_ENABLE, GPI_NONE)>; + drive-strength = <2>; + input-enable; + input-schmitt-disable; + slew-rate = <0>; + }; + }; + };
&mmc0 { @@ -234,6 +315,24 @@ }; };
+&pcie0 { + pinctrl-names = "perst-default", "perst-active", "wake-default", "clkreq-default"; + pinctrl-0 = <&pcie0_perst_default>; + pinctrl-1 = <&pcie0_perst_active>; + pinctrl-2 = <&pcie0_wake_default>; + pinctrl-3 = <&pcie0_clkreq_default>; + status = "disabled"; +}; + +&pcie1 { + pinctrl-names = "perst-default", "perst-active", "wake-default", "clkreq-default"; + pinctrl-0 = <&pcie1_perst_default>; + pinctrl-1 = <&pcie1_perst_active>; + pinctrl-2 = <&pcie1_wake_default>; + pinctrl-3 = <&pcie1_clkreq_default>; + status = "okay"; +}; + &syscrg { assigned-clocks = <&syscrg JH7110_SYSCLK_CPU_ROOT>, <&syscrg JH7110_SYSCLK_BUS_ROOT>, diff --git a/arch/riscv/dts/jh7110.dtsi b/arch/riscv/dts/jh7110.dtsi index d3e9f92987..e43296c9d5 100644 --- a/arch/riscv/dts/jh7110.dtsi +++ b/arch/riscv/dts/jh7110.dtsi @@ -578,5 +578,80 @@ gpio-controller; #gpio-cells = <2>; }; + + pcie0: pcie@2B000000 { + compatible = "starfive,jh7110-pcie"; + #address-cells = <3>; + #size-cells = <2>; + #interrupt-cells = <1>; + reg = <0x0 0x2B000000 0x0 0x1000000>, + <0x9 0x40000000 0x0 0x10000000>; + reg-names = "reg", "config"; + device_type = "pci"; + starfive,stg-syscon = <&stg_syscon 0xc0 0xc4 0x130>; + bus-range = <0x0 0xff>; + ranges = <0x82000000 0x0 0x30000000 0x0 0x30000000 0x0 0x08000000>, + <0xc3000000 0x9 0x00000000 0x9 0x00000000 0x0 0x40000000>; + msi-parent = <&plic>; + interrupts = <56>; + interrupt-controller; + interrupt-names = "msi"; + interrupt-parent = <&plic>; + interrupt-map-mask = <0x0 0x0 0x0 0x7>; + interrupt-map = <0x0 0x0 0x0 0x1 &plic 0x1>, + <0x0 0x0 0x0 0x2 &plic 0x2>, + <0x0 0x0 0x0 0x3 &plic 0x3>, + <0x0 0x0 0x0 0x4 &plic 0x4>; + resets = <&stgcrg JH7110_STGRST_PCIE0_MST0>, + <&stgcrg JH7110_STGRST_PCIE0_SLV0>, + <&stgcrg JH7110_STGRST_PCIE0_SLV>, + <&stgcrg JH7110_STGRST_PCIE0_BRG>, + <&stgcrg JH7110_STGRST_PCIE0_CORE>, + <&stgcrg JH7110_STGRST_PCIE0_APB>; + clocks = <&syscrg JH7110_SYSCLK_NOC_BUS_STG_AXI>, + <&stgcrg JH7110_STGCLK_PCIE0_TL>, + <&stgcrg JH7110_STGCLK_PCIE0_AXI>, + <&stgcrg JH7110_STGCLK_PCIE0_APB>; + clock-names = "noc_bus_stg_axi", "pcie0_tl", "pcie0_axi", "pcie0_apb"; + status = "disabled"; + }; + + pcie1: pcie@2C000000 { + compatible = "starfive,jh7110-pcie"; + #address-cells = <3>; + #size-cells = <2>; + #interrupt-cells = <1>; + reg = <0x0 0x2C000000 0x0 0x1000000>, + <0x9 0xc0000000 0x0 0x10000000>; + reg-names = "reg", "config"; + device_type = "pci"; + starfive,stg-syscon = <&stg_syscon 0x270 0x274 0x2e0>; + bus-range = <0x0 0xff>; + ranges = <0x82000000 0x0 0x38000000 0x0 0x38000000 0x0 0x08000000>, + <0xc3000000 0x9 0x80000000 0x9 0x80000000 0x0 0x40000000>; + msi-parent = <&plic>; + interrupts = <57>; + interrupt-controller; + interrupt-names = "msi"; + interrupt-parent = <&plic>; + interrupt-map-mask = <0x0 0x0 0x0 0x7>; + interrupt-map = <0x0 0x0 0x0 0x1 &plic 0x1>, + <0x0 0x0 0x0 0x2 &plic 0x2>, + <0x0 0x0 0x0 0x3 &plic 0x3>, + <0x0 0x0 0x0 0x4 &plic 0x4>; + resets = <&stgcrg JH7110_STGRST_PCIE1_MST0>, + <&stgcrg JH7110_STGRST_PCIE1_SLV0>, + <&stgcrg JH7110_STGRST_PCIE1_SLV>, + <&stgcrg JH7110_STGRST_PCIE1_BRG>, + <&stgcrg JH7110_STGRST_PCIE1_CORE>, + <&stgcrg JH7110_STGRST_PCIE1_APB>; + clocks = <&syscrg JH7110_SYSCLK_NOC_BUS_STG_AXI>, + <&stgcrg JH7110_STGCLK_PCIE1_TL>, + <&stgcrg JH7110_STGCLK_PCIE1_AXI>, + <&stgcrg JH7110_STGCLK_PCIE1_APB>; + clock-names = "noc_bus_stg_axi", "pcie1_tl", "pcie1_axi", "pcie1_apb"; + status = "disabled"; + }; + }; };
- pcie0_perst_default: pcie0_perst_default {
perst-pins {
input-disable;
slew-rate = <0>;
- pcie0_perst_active: pcie0_perst_active {
perst-pins {
input-disable;
slew-rate = <0>;
+&pcie0 {
- pinctrl-names = "perst-default", "perst-active", "wake-default", "clkreq-default";
- pinctrl-0 = <&pcie0_perst_default>;
- pinctrl-1 = <&pcie0_perst_active>;
- pinctrl-2 = <&pcie0_wake_default>;
- pinctrl-3 = <&pcie0_clkreq_default>;
- status = "disabled";
This is not correct declaration of PERST# signal. You should define in &pcie0 node "reset-gpios" property with plain gpio definition with active state.
"reset-gpios" is standard PCIe property for controlling PERST# signal over GPIO. Look for example into drivers/pci/pci-aardvark.c and arch/arm/dts/armada-3720-espressobin.dtsi files how it is used.
perst-pins {
input-disable;
slew-rate = <0>;
perst-pins {
input-disable;
slew-rate = <0>;
+&pcie0 {
OK, I will change this, thanks
Bin Meng
Minda Chen
Pali Rohár
