[U-Boot] [PATCH] davinci: remove config.mk file from the sources
To compile TI Davinci SoC support the identical config.mk file from the cpu directory shall be used.
Signed-off-by: Vladimir Zapolskiy vz@mleia.com --- arch/arm/cpu/arm926ejs/davinci/config.mk | 32 ------------------------------ 1 files changed, 0 insertions(+), 32 deletions(-) delete mode 100644 arch/arm/cpu/arm926ejs/davinci/config.mk
diff --git a/arch/arm/cpu/arm926ejs/davinci/config.mk b/arch/arm/cpu/arm926ejs/davinci/config.mk deleted file mode 100644 index 565adda..0000000 --- a/arch/arm/cpu/arm926ejs/davinci/config.mk +++ /dev/null @@ -1,32 +0,0 @@ -# -# (C) Copyright 2002 -# Gary Jennejohn, DENX Software Engineering, gj@denx.de -# -# See file CREDITS for list of people who contributed to this -# project. -# -# This program is free software; you can redistribute it and/or -# modify it under the terms of the GNU General Public License as -# published by the Free Software Foundation; either version 2 of -# the License, or (at your option) any later version. -# -# This program is distributed in the hope that it will be useful, -# but WITHOUT ANY WARRANTY; without even the implied warranty of -# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the -# GNU General Public License for more details. -# -# You should have received a copy of the GNU General Public License -# along with this program; if not, write to the Free Software -# Foundation, Inc., 59 Temple Place, Suite 330, Boston, -# MA 02111-1307 USA -# - -PLATFORM_RELFLAGS += -fno-common -ffixed-r8 -msoft-float - -PLATFORM_CPPFLAGS += -march=armv5te -# ========================================================================= -# -# Supply options according to compiler version -# -# ========================================================================= -PLATFORM_RELFLAGS +=$(call cc-option,-mshort-load-bytes,$(call cc-option,-malignment-traps,))
Vladimir Zapolskiy
