[PATCH] test/py: memtest: Add tests for mtest command
Add the following memory tests: memtest_negative - To test mtest command by providing incorrect inputs memtest_ddr - To test memory write-read-comparision for DDR memory
Signed-off-by: Love Kumar love.kumar@amd.com --- test/py/tests/test_memtest.py | 68 +++++++++++++++++++++++++++++++++++ 1 file changed, 68 insertions(+) create mode 100644 test/py/tests/test_memtest.py
diff --git a/test/py/tests/test_memtest.py b/test/py/tests/test_memtest.py new file mode 100644 index 000000000000..0618d96f1bed --- /dev/null +++ b/test/py/tests/test_memtest.py @@ -0,0 +1,68 @@ +# SPDX-License-Identifier: GPL-2.0 +# (C) Copyright 2023, Advanced Micro Devices, Inc. + +import pytest + +""" +Note: This test relies on boardenv_* containing configuration values to define +the memory test parameters such as start address, memory size, pattern, +iterations and timeout. This test will be automatically skipped without this. + +For example: + +# Setup env__memtest to set the start address of the memory range, size of the +# memory range to test from starting address, pattern to be written to memory, +# number of test iterations, and expected time to complete the test of mtest +# command. start address, size, and pattern parameters value should be in hex +# and rest of the params value should be integer. +env__memtest = { + 'start_addr': 0x0, + 'size': 0x1000, + 'pattern': 0x0, + 'iteration': 16, + 'timeout': 50000, +} +""" + +def get_memtest_env(u_boot_console): + f = u_boot_console.config.env.get("env__memtest", None) + if not f: + pytest.skip("memtest is not enabled!") + else: + start = f.get("start_addr", 0x0) + size = f.get("size", 0x1000) + pattern = f.get("pattern", 0x0) + iteration = f.get("iteration", 2) + timeout = f.get("timeout", 50000) + end = hex(int(start) + int(size)) + return start, end, pattern, iteration, timeout + +@pytest.mark.buildconfigspec("cmd_memtest") +def test_memtest_negative(u_boot_console): + """Negative testcase where end address is smaller than starting address and + pattern is invalid.""" + start, end, pattern, iteration, timeout = get_memtest_env(u_boot_console) + expected_response = "Refusing to do empty test" + response = u_boot_console.run_command( + f"mtest 2000 1000 {pattern} {hex(iteration)}" + ) + assert expected_response in response + output = u_boot_console.run_command("echo $?") + assert not output.endswith("0") + u_boot_console.run_command(f"mtest {start} {end} 'xyz' {hex(iteration)}") + output = u_boot_console.run_command("echo $?") + assert not output.endswith("0") + +@pytest.mark.buildconfigspec("cmd_memtest") +def test_memtest_ddr(u_boot_console): + """Test that md reads memory as expected, and that memory can be modified + using the mw command.""" + start, end, pattern, iteration, timeout = get_memtest_env(u_boot_console) + expected_response = f"Tested {str(iteration)} iteration(s) with 0 errors." + with u_boot_console.temporary_timeout(timeout): + response = u_boot_console.run_command( + f"mtest {start} {end} {pattern} {hex(iteration)}" + ) + assert expected_response in response + output = u_boot_console.run_command("echo $?") + assert output.endswith("0")
Love Kumar
