[PATCH] tools: mxsboot: pre-fill buffer with 0xff, not 0
The tool works for me, with imx28 and NAND memory, but the resulting blocks are reported as bad, both by u-boot and the kernel.
This makes it impossible to erase from Linux (for an upgrade without console access, for example -- u-boot can "nand scrub" but linux can't).
pre-filling with 0xff creates a proper boot loader image, but no bad-block marker is there when written to flash.
Signed-off-by: Alessandro Rubini rubini@gnudd.com --- tools/mxsboot.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/tools/mxsboot.c b/tools/mxsboot.c index 04d86f87a8..8f4018aa56 100644 --- a/tools/mxsboot.c +++ b/tools/mxsboot.c @@ -478,7 +478,7 @@ static int mx28_create_nand_image(int infd, int outfd) goto err0; }
- memset(buf, 0, size); + memset(buf, 0xff, size);
fcb = mx28_nand_get_fcb(MAX_BOOTSTREAM_SIZE); if (!fcb) {
Hi Alessandro,
[Adding Marek and Rogan]
This makes sense:
Reviewed-by: Fabio Estevam festevam@gmail.com
Thanks
On 12/4/23 02:35, Fabio Estevam wrote:
Hi Alessandro,
Isn't there some kobs-ng or whatever tool it was to properly initialize the NAND on MXS ?
Hello.
I didn't know. I used what u-boot offers, which works for me without vendor tools -- and dare I say I trust u-boot tools more than vendor tools?.
The default environment even has the rule to reflash from any u-boot.nand you manage to put into RAM. The only issue is that u-boot.nand, as created, marks good blocks as bad by prefilling with zeores.
thanks /alessandro
On 12/4/23 09:09, Alessandro Rubini wrote:
Hello.
But what about the bad block markers , do they get erased when you write this U-Boot image into the NAND ?
I think the vendor tool somehow dealt with it (but it might have depended on some weird stuff in GPMI NAND), I don't think I ever used that tool myself.
The image includes OOB data, because the rom-mandated map is different from normal standards. If OOB is zeroed, blocks appear as bad (correctly!).
By memsetting to 0xff, before filling data structures and checksums, we get a binary that written with "nand write.raw" works properly (the rom is happy with the format and boots) but doesn't mark blocks as bad.
[actually, only the first half-a-meg is with-oob, the trailing part is not, and the image is partly written with "nand write.raw" and partly with "nand write". Hairy things based on hairy vendor choices in hw/rom]
But tools/mxsboot works fine, and saved my day (or more).
thanks /alessandro
Clearly my recollection of the MXS is not what it once was.
Thanks !
Applied to u-boot-imx next, thanks
Alessandro Rubini
Fabio Estevam
