[PATCH 1/2] arm: mvebu: Remove timer.c
Since the move to CONFIG_TIMER with support for CONFIG_TIMER_EARLY, this platform specific init_timer() function is not needed any more. Let's remove it completely.
Signed-off-by: Stefan Roese sr@denx.de Cc: Michael Walle michael@walle.cc Cc: Pali Rohár pali@kernel.org --- arch/arm/mach-mvebu/Makefile | 5 ----- arch/arm/mach-mvebu/spl.c | 2 -- arch/arm/mach-mvebu/timer.c | 41 ------------------------------------ 3 files changed, 48 deletions(-) delete mode 100644 arch/arm/mach-mvebu/timer.c
diff --git a/arch/arm/mach-mvebu/Makefile b/arch/arm/mach-mvebu/Makefile index 103e64cf2047..406a9ee8f686 100644 --- a/arch/arm/mach-mvebu/Makefile +++ b/arch/arm/mach-mvebu/Makefile @@ -16,10 +16,6 @@ obj-y = dram.o obj-y += gpio.o obj-y += mbus.o
-ifndef CONFIG_TIMER -obj-y += timer.o -endif - else # CONFIG_ARCH_KIRKWOOD
obj-y = cpu.o @@ -97,7 +93,6 @@ $(obj)/kwbimage.cfg: $(src)/kwbimage.cfg.in include/autoconf.mk \ endif # CONFIG_SPL_BUILD obj-y += gpio.o obj-y += mbus.o -obj-y += timer.o obj-$(CONFIG_SPL_BUILD) += spl.o obj-$(CONFIG_SPL_BUILD) += lowlevel_spl.o
diff --git a/arch/arm/mach-mvebu/spl.c b/arch/arm/mach-mvebu/spl.c index ca2d5a59d773..424599286e5e 100644 --- a/arch/arm/mach-mvebu/spl.c +++ b/arch/arm/mach-mvebu/spl.c @@ -340,8 +340,6 @@ void board_init_f(ulong dummy)
preloader_console_init();
- timer_init(); - /* Armada 375 does not support SerDes and DDR3 init yet */ #if !defined(CONFIG_ARMADA_375) /* First init the serdes PHY's */ diff --git a/arch/arm/mach-mvebu/timer.c b/arch/arm/mach-mvebu/timer.c deleted file mode 100644 index 557a378776d7..000000000000 --- a/arch/arm/mach-mvebu/timer.c +++ /dev/null @@ -1,41 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0+ -/* - * Copyright (C) Marvell International Ltd. and its affiliates - * Written-by: Prafulla Wadaskar prafulla@marvell.com - * - * Copyright (C) 2015 Stefan Roese sr@denx.de - */ - -#include <common.h> -#include <init.h> -#include <asm/io.h> -#include <asm/arch/soc.h> -#include <linux/bitops.h> - -#define TIMER_LOAD_VAL 0xffffffff - -static int init_done __section(".data") = 0; - -/* - * Timer initialization - */ -int timer_init(void) -{ - /* Only init the timer once */ - if (init_done) - return 0; - init_done = 1; - - /* load value into timer */ - writel(TIMER_LOAD_VAL, MVEBU_TIMER_BASE + 0x10); - writel(TIMER_LOAD_VAL, MVEBU_TIMER_BASE + 0x14); - -#if defined(CONFIG_ARCH_MVEBU) - /* On Armada XP / 38x ..., the 25MHz clock source needs to be enabled */ - setbits_le32(MVEBU_TIMER_BASE + 0x00, BIT(11)); -#endif - /* enable timer in auto reload mode */ - setbits_le32(MVEBU_TIMER_BASE + 0x00, 0x3); - - return 0; -}
Move the code making sure that the timer is initialized only once into orion_timer_init(), which is called from timer_early_init() and from orion_timer_probe(). This way the timer is not re-initialized.
Signed-off-by: Stefan Roese sr@denx.de Cc: Michael Walle michael@walle.cc Cc: Pali Rohár pali@kernel.org --- drivers/timer/orion-timer.c | 10 +++++----- 1 file changed, 5 insertions(+), 5 deletions(-)
diff --git a/drivers/timer/orion-timer.c b/drivers/timer/orion-timer.c index cd63ea916237..d0eab3ce781d 100644 --- a/drivers/timer/orion-timer.c +++ b/drivers/timer/orion-timer.c @@ -28,6 +28,11 @@ static bool early_init_done __section(".data") = false; /* Common functions for early (boot) and DM based timer */ static void orion_timer_init(void *base, enum input_clock_type type) { + /* Only init the timer once */ + if (early_init_done) + return; + early_init_done = true; + writel(~0, base + TIMER0_VAL); writel(~0, base + TIMER0_RELOAD);
@@ -51,11 +56,6 @@ static uint64_t orion_timer_get_count(void *base) /* Early (e.g. bootstage etc) timer functions */ static void notrace timer_early_init(void) { - /* Only init the timer once */ - if (early_init_done) - return; - early_init_done = true; - if (IS_ENABLED(CONFIG_ARCH_MVEBU)) orion_timer_init((void *)MVEBU_TIMER_BASE, INPUT_CLOCK_25MHZ); else
Applied to u-boot-marvell/master
Thanks, Stefan
return;
- writel(~0, base + TIMER0_VAL); writel(~0, base + TIMER0_RELOAD);
return;
Viele Grüße, Stefan Roese
Thanks, Stefan
obj-y = cpu.o
- timer_init();
- Copyright (C) Marvell International Ltd. and its affiliates
- Written-by: Prafulla Wadaskar prafulla@marvell.com
- Copyright (C) 2015 Stefan Roese sr@denx.de
- Timer initialization
- if (init_done)
- init_done = 1;
-#endif
Stefan Roese
