[PATCH v2] USB: Fix NULLPTR dereference when serial# is unset
The current behaviour of this function will dereference a null pointer if the serial# environment variable is unset. This was discovered on a board where U-Boot did not have access to the first 256MB of ram, resulting in a board crash. In the event that U-Boot has full access to memory, it will still read from address 0, which is probably not optimal. This simple check is enough to fix it
Signed-off-by: Michael Ferolito michaelsunn101@gmail.com Cc: Marek Vasut marex@denx.de Cc: Heiko Schocher hs@denx.de Cc: Kyungmin Park kyungmin.park@samsung.com --- drivers/usb/gadget/g_dnl.c | 3 ++- 1 file changed, 2 insertions(+), 1 deletion(-)
diff --git a/drivers/usb/gadget/g_dnl.c b/drivers/usb/gadget/g_dnl.c index 631969b340..f2540eb6de 100644 --- a/drivers/usb/gadget/g_dnl.c +++ b/drivers/usb/gadget/g_dnl.c @@ -207,7 +207,8 @@ void g_dnl_clear_detach(void) static int on_serialno(const char *name, const char *value, enum env_op op, int flags) { - g_dnl_set_serialnumber((char *)value); + if (value) + g_dnl_set_serialnumber((char *)value); return 0; } U_BOOT_ENV_CALLBACK(serialno, on_serialno);
The subject tag is "usb: gadget: g_dnl:" instead of "USB:" , with that fixed:
Thanks
Hi Michael,
Thank you for the patch.
Agreed with Marek on this. Please add:
Reviewed-by: Mattijs Korpershoek mkorpershoek@baylibre.com
As well.
Marek, since this is gadget, can this go through my tree? In that case, Michael, I can fix up the subject when applying (to avoid you sending a v2)
Let me know if that works.
Thanks, Mattijs
Thanks
Hello Mattijs,
On 28.01.25 10:11, Mattijs Korpershoek wrote:
Hi Michael,
As well.
There is already a v4, see:
https://lists.denx.de/pipermail/u-boot/2025-January/578746.html
bye, Heiko
Hi Heiko,
On mar., janv. 28, 2025 at 10:17, Heiko Schocher hs@denx.de wrote:
Hello Mattijs,
Hi Michael,
As well.
Indeed. Seems I'm a bit slow today :)
Thanks for sharing the link.
bye, Heiko -- DENX Software Engineering GmbH, Managing Director: Erika Unter HRB 165235 Munich, Office: Kirchenstr.5, D-82194 Groebenzell, Germany Phone: +49-8142-66989-52 Fax: +49-8142-66989-80 Email: hs@denx.de
On 1/28/25 10:11 AM, Mattijs Korpershoek wrote:
Hi Michael,
As well.
Yes of course.
Heiko Schocher
Mattijs Korpershoek
Michael Ferolito
