[U-Boot] [PATCH v2] cmd: remove NET and CMD_NET dependency for CMD_PXE
It allows to use sysboot command on board which have no NET support.
Currently, sysboot command can't be used if CMD_NET and NET flags are not set, while sysboot allows to load extlinux.conf file from local filesystem, so it doesn't need to depend of CMD_NET and NET flags.
Extract sysboot command's code outside pxe.c and create a new sysboot.c file. As sysboot and pxe commands are sharing piece of code, put this common code into a new file pxe_utils.c.
Take the opportunity to move from_env() from pxe.c to nvedit.c. Fix some checkpatch issues.
Signed-off-by: Patrice Chotard patrice.chotard@st.com
Changes in v2: - split out sysboot code from pxe.c file and create a sysboot.c file
Kconfig | 1 + cmd/Kconfig | 6 + cmd/Makefile | 3 +- cmd/nvedit.c | 17 + cmd/pxe.c | 1719 ++--------------------------------------------- cmd/pxe_utils.c | 1463 ++++++++++++++++++++++++++++++++++++++++ cmd/pxe_utils.h | 43 ++ cmd/sysboot.c | 134 ++++ include/env.h | 10 + 9 files changed, 1724 insertions(+), 1672 deletions(-) create mode 100644 cmd/pxe_utils.c create mode 100644 cmd/pxe_utils.h create mode 100644 cmd/sysboot.c
diff --git a/Kconfig b/Kconfig index 66b059f749..98cf53ec78 100644 --- a/Kconfig +++ b/Kconfig @@ -88,6 +88,7 @@ config DISTRO_DEFAULTS select CMD_PART if PARTITIONS select CMD_PING if CMD_NET select CMD_PXE if NET + select CMD_SYSBOOT select ENV_VARS_UBOOT_CONFIG select HUSH_PARSER select SUPPORT_RAW_INITRD diff --git a/cmd/Kconfig b/cmd/Kconfig index 82b5d300d2..492d7396f6 100644 --- a/cmd/Kconfig +++ b/cmd/Kconfig @@ -1665,6 +1665,12 @@ config CMD_SOUND sound init - set up sound system sound play - play a sound
+config CMD_SYSBOOT + bool "sysboot" + select MENU + help + Boot image via local extlinux.conf file + config CMD_QFW bool "qfw" select QFW diff --git a/cmd/Makefile b/cmd/Makefile index 2d723ea0f0..b55f936cf0 100644 --- a/cmd/Makefile +++ b/cmd/Makefile @@ -108,7 +108,7 @@ ifdef CONFIG_PCI obj-$(CONFIG_CMD_PCI) += pci.o endif obj-$(CONFIG_CMD_PINMUX) += pinmux.o -obj-$(CONFIG_CMD_PXE) += pxe.o +obj-$(CONFIG_CMD_PXE) += pxe.o pxe_utils.o obj-$(CONFIG_CMD_WOL) += wol.o obj-$(CONFIG_CMD_QFW) += qfw.o obj-$(CONFIG_CMD_READ) += read.o @@ -163,6 +163,7 @@ obj-$(CONFIG_CMD_DFU) += dfu.o obj-$(CONFIG_CMD_GPT) += gpt.o obj-$(CONFIG_CMD_ETHSW) += ethsw.o obj-$(CONFIG_CMD_AXI) += axi.o +obj-$(CONFIG_CMD_SYSBOOT) += sysboot.o pxe_utils.o
# Power obj-$(CONFIG_CMD_PMIC) += pmic.o diff --git a/cmd/nvedit.c b/cmd/nvedit.c index 1cb0bc1460..68b293a6f3 100644 --- a/cmd/nvedit.c +++ b/cmd/nvedit.c @@ -680,6 +680,23 @@ char *env_get(const char *name) return NULL; }
+/* + * Like env_get, but prints an error if envvar isn't defined in the + * environment. It always returns what env_get does, so it can be used in + * place of env_get without changing error handling otherwise. + */ +char *from_env(const char *envvar) +{ + char *ret; + + ret = env_get(envvar); + + if (!ret) + printf("missing environment variable: %s\n", envvar); + + return ret; +} + /* * Look up variable from environment for restricted C runtime env. */ diff --git a/cmd/pxe.c b/cmd/pxe.c index 2059975446..2dfdc60566 100644 --- a/cmd/pxe.c +++ b/cmd/pxe.c @@ -6,22 +6,9 @@
#include <common.h> #include <command.h> -#include <env.h> -#include <malloc.h> -#include <mapmem.h> -#include <lcd.h> -#include <linux/string.h> -#include <linux/ctype.h> -#include <errno.h> -#include <linux/list.h> -#include <fs.h> -#include <splash.h> -#include <asm/io.h> +#include "pxe_utils.h"
-#include "menu.h" -#include "cli.h" - -#define MAX_TFTP_PATH_LEN 127 +#ifdef CONFIG_CMD_NET
const char *pxe_default_paths[] = { #ifdef CONFIG_SYS_SOC @@ -35,102 +22,6 @@ const char *pxe_default_paths[] = { NULL };
-static bool is_pxe; - -/* - * Like env_get, but prints an error if envvar isn't defined in the - * environment. It always returns what env_get does, so it can be used in - * place of env_get without changing error handling otherwise. - */ -static char *from_env(const char *envvar) -{ - char *ret; - - ret = env_get(envvar); - - if (!ret) - printf("missing environment variable: %s\n", envvar); - - return ret; -} - -#ifdef CONFIG_CMD_NET -/* - * Convert an ethaddr from the environment to the format used by pxelinux - * filenames based on mac addresses. Convert's ':' to '-', and adds "01-" to - * the beginning of the ethernet address to indicate a hardware type of - * Ethernet. Also converts uppercase hex characters into lowercase, to match - * pxelinux's behavior. - * - * Returns 1 for success, -ENOENT if 'ethaddr' is undefined in the - * environment, or some other value < 0 on error. - */ -static int format_mac_pxe(char *outbuf, size_t outbuf_len) -{ - uchar ethaddr[6]; - - if (outbuf_len < 21) { - printf("outbuf is too small (%zd < 21)\n", outbuf_len); - - return -EINVAL; - } - - if (!eth_env_get_enetaddr_by_index("eth", eth_get_dev_index(), ethaddr)) - return -ENOENT; - - sprintf(outbuf, "01-%02x-%02x-%02x-%02x-%02x-%02x", - ethaddr[0], ethaddr[1], ethaddr[2], - ethaddr[3], ethaddr[4], ethaddr[5]); - - return 1; -} -#endif - -/* - * Returns the directory the file specified in the bootfile env variable is - * in. If bootfile isn't defined in the environment, return NULL, which should - * be interpreted as "don't prepend anything to paths". - */ -static int get_bootfile_path(const char *file_path, char *bootfile_path, - size_t bootfile_path_size) -{ - char *bootfile, *last_slash; - size_t path_len = 0; - - /* Only syslinux allows absolute paths */ - if (file_path[0] == '/' && !is_pxe) - goto ret; - - bootfile = from_env("bootfile"); - - if (!bootfile) - goto ret; - - last_slash = strrchr(bootfile, '/'); - - if (last_slash == NULL) - goto ret; - - path_len = (last_slash - bootfile) + 1; - - if (bootfile_path_size < path_len) { - printf("bootfile_path too small. (%zd < %zd)\n", - bootfile_path_size, path_len); - - return -1; - } - - strncpy(bootfile_path, bootfile, path_len); - - ret: - bootfile_path[path_len] = '\0'; - - return 1; -} - -static int (*do_getfile)(cmd_tbl_t *cmdtp, const char *file_path, char *file_addr); - -#ifdef CONFIG_CMD_NET static int do_get_tftp(cmd_tbl_t *cmdtp, const char *file_path, char *file_addr) { char *tftp_argv[] = {"tftp", NULL, NULL, NULL}; @@ -143,218 +34,6 @@ static int do_get_tftp(cmd_tbl_t *cmdtp, const char *file_path, char *file_addr)
return 1; } -#endif - -static char *fs_argv[5]; - -static int do_get_ext2(cmd_tbl_t *cmdtp, const char *file_path, char *file_addr) -{ -#ifdef CONFIG_CMD_EXT2 - fs_argv[0] = "ext2load"; - fs_argv[3] = file_addr; - fs_argv[4] = (void *)file_path; - - if (!do_ext2load(cmdtp, 0, 5, fs_argv)) - return 1; -#endif - return -ENOENT; -} - -static int do_get_fat(cmd_tbl_t *cmdtp, const char *file_path, char *file_addr) -{ -#ifdef CONFIG_CMD_FAT - fs_argv[0] = "fatload"; - fs_argv[3] = file_addr; - fs_argv[4] = (void *)file_path; - - if (!do_fat_fsload(cmdtp, 0, 5, fs_argv)) - return 1; -#endif - return -ENOENT; -} - -static int do_get_any(cmd_tbl_t *cmdtp, const char *file_path, char *file_addr) -{ -#ifdef CONFIG_CMD_FS_GENERIC - fs_argv[0] = "load"; - fs_argv[3] = file_addr; - fs_argv[4] = (void *)file_path; - - if (!do_load(cmdtp, 0, 5, fs_argv, FS_TYPE_ANY)) - return 1; -#endif - return -ENOENT; -} - -/* - * As in pxelinux, paths to files referenced from files we retrieve are - * relative to the location of bootfile. get_relfile takes such a path and - * joins it with the bootfile path to get the full path to the target file. If - * the bootfile path is NULL, we use file_path as is. - * - * Returns 1 for success, or < 0 on error. - */ -static int get_relfile(cmd_tbl_t *cmdtp, const char *file_path, - unsigned long file_addr) -{ - size_t path_len; - char relfile[MAX_TFTP_PATH_LEN+1]; - char addr_buf[18]; - int err; - - err = get_bootfile_path(file_path, relfile, sizeof(relfile)); - - if (err < 0) - return err; - - path_len = strlen(file_path); - path_len += strlen(relfile); - - if (path_len > MAX_TFTP_PATH_LEN) { - printf("Base path too long (%s%s)\n", - relfile, - file_path); - - return -ENAMETOOLONG; - } - - strcat(relfile, file_path); - - printf("Retrieving file: %s\n", relfile); - - sprintf(addr_buf, "%lx", file_addr); - - return do_getfile(cmdtp, relfile, addr_buf); -} - -/* - * Retrieve the file at 'file_path' to the locate given by 'file_addr'. If - * 'bootfile' was specified in the environment, the path to bootfile will be - * prepended to 'file_path' and the resulting path will be used. - * - * Returns 1 on success, or < 0 for error. - */ -static int get_pxe_file(cmd_tbl_t *cmdtp, const char *file_path, - unsigned long file_addr) -{ - unsigned long config_file_size; - char *tftp_filesize; - int err; - char *buf; - - err = get_relfile(cmdtp, file_path, file_addr); - - if (err < 0) - return err; - - /* - * the file comes without a NUL byte at the end, so find out its size - * and add the NUL byte. - */ - tftp_filesize = from_env("filesize"); - - if (!tftp_filesize) - return -ENOENT; - - if (strict_strtoul(tftp_filesize, 16, &config_file_size) < 0) - return -EINVAL; - - buf = map_sysmem(file_addr + config_file_size, 1); - *buf = '\0'; - unmap_sysmem(buf); - - return 1; -} - -#ifdef CONFIG_CMD_NET - -#define PXELINUX_DIR "pxelinux.cfg/" - -/* - * Retrieves a file in the 'pxelinux.cfg' folder. Since this uses get_pxe_file - * to do the hard work, the location of the 'pxelinux.cfg' folder is generated - * from the bootfile path, as described above. - * - * Returns 1 on success or < 0 on error. - */ -static int get_pxelinux_path(cmd_tbl_t *cmdtp, const char *file, - unsigned long pxefile_addr_r) -{ - size_t base_len = strlen(PXELINUX_DIR); - char path[MAX_TFTP_PATH_LEN+1]; - - if (base_len + strlen(file) > MAX_TFTP_PATH_LEN) { - printf("path (%s%s) too long, skipping\n", - PXELINUX_DIR, file); - return -ENAMETOOLONG; - } - - sprintf(path, PXELINUX_DIR "%s", file); - - return get_pxe_file(cmdtp, path, pxefile_addr_r); -} - -/* - * Looks for a pxe file with a name based on the pxeuuid environment variable. - * - * Returns 1 on success or < 0 on error. - */ -static int pxe_uuid_path(cmd_tbl_t *cmdtp, unsigned long pxefile_addr_r) -{ - char *uuid_str; - - uuid_str = from_env("pxeuuid"); - - if (!uuid_str) - return -ENOENT; - - return get_pxelinux_path(cmdtp, uuid_str, pxefile_addr_r); -} - -/* - * Looks for a pxe file with a name based on the 'ethaddr' environment - * variable. - * - * Returns 1 on success or < 0 on error. - */ -static int pxe_mac_path(cmd_tbl_t *cmdtp, unsigned long pxefile_addr_r) -{ - char mac_str[21]; - int err; - - err = format_mac_pxe(mac_str, sizeof(mac_str)); - - if (err < 0) - return err; - - return get_pxelinux_path(cmdtp, mac_str, pxefile_addr_r); -} - -/* - * Looks for pxe files with names based on our IP address. See pxelinux - * documentation for details on what these file names look like. We match - * that exactly. - * - * Returns 1 on success or < 0 on error. - */ -static int pxe_ipaddr_paths(cmd_tbl_t *cmdtp, unsigned long pxefile_addr_r) -{ - char ip_addr[9]; - int mask_pos, err; - - sprintf(ip_addr, "%08X", ntohl(net_ip.s_addr)); - - for (mask_pos = 7; mask_pos >= 0; mask_pos--) { - err = get_pxelinux_path(cmdtp, ip_addr, pxefile_addr_r); - - if (err > 0) - return err; - - ip_addr[mask_pos] = '\0'; - } - - return -ENOENT; -}
/* * Entry point for the 'pxe get' command. @@ -417,1292 +96,77 @@ do_pxe_get(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[])
return 1; } -#endif - -/* - * Wrapper to make it easier to store the file at file_path in the location - * specified by envaddr_name. file_path will be joined to the bootfile path, - * if any is specified. - * - * Returns 1 on success or < 0 on error. - */ -static int get_relfile_envaddr(cmd_tbl_t *cmdtp, const char *file_path, const char *envaddr_name) -{ - unsigned long file_addr; - char *envaddr; - - envaddr = from_env(envaddr_name); - - if (!envaddr) - return -ENOENT; - - if (strict_strtoul(envaddr, 16, &file_addr) < 0) - return -EINVAL; - - return get_relfile(cmdtp, file_path, file_addr); -} - -/* - * A note on the pxe file parser. - * - * We're parsing files that use syslinux grammar, which has a few quirks. - * String literals must be recognized based on context - there is no - * quoting or escaping support. There's also nothing to explicitly indicate - * when a label section completes. We deal with that by ending a label - * section whenever we see a line that doesn't include. - * - * As with the syslinux family, this same file format could be reused in the - * future for non pxe purposes. The only action it takes during parsing that - * would throw this off is handling of include files. It assumes we're using - * pxe, and does a tftp download of a file listed as an include file in the - * middle of the parsing operation. That could be handled by refactoring it to - * take a 'include file getter' function. - */ - -/* - * Describes a single label given in a pxe file. - * - * Create these with the 'label_create' function given below. - * - * name - the name of the menu as given on the 'menu label' line. - * kernel - the path to the kernel file to use for this label. - * append - kernel command line to use when booting this label - * initrd - path to the initrd to use for this label. - * attempted - 0 if we haven't tried to boot this label, 1 if we have. - * localboot - 1 if this label specified 'localboot', 0 otherwise. - * list - lets these form a list, which a pxe_menu struct will hold. - */ -struct pxe_label { - char num[4]; - char *name; - char *menu; - char *kernel; - char *config; - char *append; - char *initrd; - char *fdt; - char *fdtdir; - int ipappend; - int attempted; - int localboot; - int localboot_val; - struct list_head list; -}; - -/* - * Describes a pxe menu as given via pxe files. - * - * title - the name of the menu as given by a 'menu title' line. - * default_label - the name of the default label, if any. - * bmp - the bmp file name which is displayed in background - * timeout - time in tenths of a second to wait for a user key-press before - * booting the default label. - * prompt - if 0, don't prompt for a choice unless the timeout period is - * interrupted. If 1, always prompt for a choice regardless of - * timeout. - * labels - a list of labels defined for the menu. - */ -struct pxe_menu { - char *title; - char *default_label; - char *bmp; - int timeout; - int prompt; - struct list_head labels; -};
/* - * Allocates memory for and initializes a pxe_label. This uses malloc, so the - * result must be free()'d to reclaim the memory. + * Boots a system using a pxe file * - * Returns NULL if malloc fails. + * Returns 0 on success, 1 on error. */ -static struct pxe_label *label_create(void) +static int +do_pxe_boot(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) { - struct pxe_label *label; - - label = malloc(sizeof(struct pxe_label)); - - if (!label) - return NULL; + unsigned long pxefile_addr_r; + struct pxe_menu *cfg; + char *pxefile_addr_str;
- memset(label, 0, sizeof(struct pxe_label)); + do_getfile = do_get_tftp;
- return label; -} + if (argc == 1) { + pxefile_addr_str = from_env("pxefile_addr_r"); + if (!pxefile_addr_str) + return 1;
-/* - * Free the memory used by a pxe_label, including that used by its name, - * kernel, append and initrd members, if they're non NULL. - * - * So - be sure to only use dynamically allocated memory for the members of - * the pxe_label struct, unless you want to clean it up first. These are - * currently only created by the pxe file parsing code. - */ -static void label_destroy(struct pxe_label *label) -{ - if (label->name) - free(label->name); + } else if (argc == 2) { + pxefile_addr_str = argv[1]; + } else { + return CMD_RET_USAGE; + }
- if (label->kernel) - free(label->kernel); + if (strict_strtoul(pxefile_addr_str, 16, &pxefile_addr_r) < 0) { + printf("Invalid pxefile address: %s\n", pxefile_addr_str); + return 1; + }
- if (label->config) - free(label->config); + cfg = parse_pxefile(cmdtp, pxefile_addr_r);
- if (label->append) - free(label->append); + if (!cfg) { + printf("Error parsing config file\n"); + return 1; + }
- if (label->initrd) - free(label->initrd); + handle_pxe_menu(cmdtp, cfg);
- if (label->fdt) - free(label->fdt); + destroy_pxe_menu(cfg);
- if (label->fdtdir) - free(label->fdtdir); + copy_filename(net_boot_file_name, "", sizeof(net_boot_file_name));
- free(label); + return 0; }
-/* - * Print a label and its string members if they're defined. - * - * This is passed as a callback to the menu code for displaying each - * menu entry. - */ -static void label_print(void *data) -{ - struct pxe_label *label = data; - const char *c = label->menu ? label->menu : label->name; - - printf("%s:\t%s\n", label->num, c); -} +static cmd_tbl_t cmd_pxe_sub[] = { + U_BOOT_CMD_MKENT(get, 1, 1, do_pxe_get, "", ""), + U_BOOT_CMD_MKENT(boot, 2, 1, do_pxe_boot, "", "") +};
-/* - * Boot a label that specified 'localboot'. This requires that the 'localcmd' - * environment variable is defined. Its contents will be executed as U-Boot - * command. If the label specified an 'append' line, its contents will be - * used to overwrite the contents of the 'bootargs' environment variable prior - * to running 'localcmd'. - * - * Returns 1 on success or < 0 on error. - */ -static int label_localboot(struct pxe_label *label) +static int do_pxe(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) { - char *localcmd; + cmd_tbl_t *cp;
- localcmd = from_env("localcmd"); + if (argc < 2) + return CMD_RET_USAGE;
- if (!localcmd) - return -ENOENT; + is_pxe = true;
- if (label->append) { - char bootargs[CONFIG_SYS_CBSIZE]; + /* drop initial "pxe" arg */ + argc--; + argv++;
- cli_simple_process_macros(label->append, bootargs); - env_set("bootargs", bootargs); - } + cp = find_cmd_tbl(argv[0], cmd_pxe_sub, ARRAY_SIZE(cmd_pxe_sub));
- debug("running: %s\n", localcmd); + if (cp) + return cp->cmd(cmdtp, flag, argc, argv);
- return run_command_list(localcmd, strlen(localcmd), 0); -} - -/* - * Boot according to the contents of a pxe_label. - * - * If we can't boot for any reason, we return. A successful boot never - * returns. - * - * The kernel will be stored in the location given by the 'kernel_addr_r' - * environment variable. - * - * If the label specifies an initrd file, it will be stored in the location - * given by the 'ramdisk_addr_r' environment variable. - * - * If the label specifies an 'append' line, its contents will overwrite that - * of the 'bootargs' environment variable. - */ -static int label_boot(cmd_tbl_t *cmdtp, struct pxe_label *label) -{ - char *bootm_argv[] = { "bootm", NULL, NULL, NULL, NULL }; - char initrd_str[28]; - char mac_str[29] = ""; - char ip_str[68] = ""; - char *fit_addr = NULL; - int bootm_argc = 2; - int len = 0; - ulong kernel_addr; - void *buf; - - label_print(label); - - label->attempted = 1; - - if (label->localboot) { - if (label->localboot_val >= 0) - label_localboot(label); - return 0; - } - - if (label->kernel == NULL) { - printf("No kernel given, skipping %s\n", - label->name); - return 1; - } - - if (label->initrd) { - if (get_relfile_envaddr(cmdtp, label->initrd, "ramdisk_addr_r") < 0) { - printf("Skipping %s for failure retrieving initrd\n", - label->name); - return 1; - } - - bootm_argv[2] = initrd_str; - strncpy(bootm_argv[2], env_get("ramdisk_addr_r"), 18); - strcat(bootm_argv[2], ":"); - strncat(bootm_argv[2], env_get("filesize"), 9); - } - - if (get_relfile_envaddr(cmdtp, label->kernel, "kernel_addr_r") < 0) { - printf("Skipping %s for failure retrieving kernel\n", - label->name); - return 1; - } - - if (label->ipappend & 0x1) { - sprintf(ip_str, " ip=%s:%s:%s:%s", - env_get("ipaddr"), env_get("serverip"), - env_get("gatewayip"), env_get("netmask")); - } - -#ifdef CONFIG_CMD_NET - if (label->ipappend & 0x2) { - int err; - strcpy(mac_str, " BOOTIF="); - err = format_mac_pxe(mac_str + 8, sizeof(mac_str) - 8); - if (err < 0) - mac_str[0] = '\0'; - } -#endif - - if ((label->ipappend & 0x3) || label->append) { - char bootargs[CONFIG_SYS_CBSIZE] = ""; - char finalbootargs[CONFIG_SYS_CBSIZE]; - - if (strlen(label->append ?: "") + - strlen(ip_str) + strlen(mac_str) + 1 > sizeof(bootargs)) { - printf("bootarg overflow %zd+%zd+%zd+1 > %zd\n", - strlen(label->append ?: ""), - strlen(ip_str), strlen(mac_str), - sizeof(bootargs)); - return 1; - } else { - if (label->append) - strncpy(bootargs, label->append, - sizeof(bootargs)); - strcat(bootargs, ip_str); - strcat(bootargs, mac_str); - - cli_simple_process_macros(bootargs, finalbootargs); - env_set("bootargs", finalbootargs); - printf("append: %s\n", finalbootargs); - } - } - - bootm_argv[1] = env_get("kernel_addr_r"); - /* for FIT, append the configuration identifier */ - if (label->config) { - int len = strlen(bootm_argv[1]) + strlen(label->config) + 1; - - fit_addr = malloc(len); - if (!fit_addr) { - printf("malloc fail (FIT address)\n"); - return 1; - } - snprintf(fit_addr, len, "%s%s", bootm_argv[1], label->config); - bootm_argv[1] = fit_addr; - } - - /* - * fdt usage is optional: - * It handles the following scenarios. All scenarios are exclusive - * - * Scenario 1: If fdt_addr_r specified and "fdt" label is defined in - * pxe file, retrieve fdt blob from server. Pass fdt_addr_r to bootm, - * and adjust argc appropriately. - * - * Scenario 2: If there is an fdt_addr specified, pass it along to - * bootm, and adjust argc appropriately. - * - * Scenario 3: fdt blob is not available. - */ - bootm_argv[3] = env_get("fdt_addr_r"); - - /* if fdt label is defined then get fdt from server */ - if (bootm_argv[3]) { - char *fdtfile = NULL; - char *fdtfilefree = NULL; - - if (label->fdt) { - fdtfile = label->fdt; - } else if (label->fdtdir) { - char *f1, *f2, *f3, *f4, *slash; - - f1 = env_get("fdtfile"); - if (f1) { - f2 = ""; - f3 = ""; - f4 = ""; - } else { - /* - * For complex cases where this code doesn't - * generate the correct filename, the board - * code should set $fdtfile during early boot, - * or the boot scripts should set $fdtfile - * before invoking "pxe" or "sysboot". - */ - f1 = env_get("soc"); - f2 = "-"; - f3 = env_get("board"); - f4 = ".dtb"; - } - - len = strlen(label->fdtdir); - if (!len) - slash = "./"; - else if (label->fdtdir[len - 1] != '/') - slash = "/"; - else - slash = ""; - - len = strlen(label->fdtdir) + strlen(slash) + - strlen(f1) + strlen(f2) + strlen(f3) + - strlen(f4) + 1; - fdtfilefree = malloc(len); - if (!fdtfilefree) { - printf("malloc fail (FDT filename)\n"); - goto cleanup; - } - - snprintf(fdtfilefree, len, "%s%s%s%s%s%s", - label->fdtdir, slash, f1, f2, f3, f4); - fdtfile = fdtfilefree; - } - - if (fdtfile) { - int err = get_relfile_envaddr(cmdtp, fdtfile, "fdt_addr_r"); - free(fdtfilefree); - if (err < 0) { - printf("Skipping %s for failure retrieving fdt\n", - label->name); - goto cleanup; - } - } else { - bootm_argv[3] = NULL; - } - } - - if (!bootm_argv[3]) - bootm_argv[3] = env_get("fdt_addr"); - - if (bootm_argv[3]) { - if (!bootm_argv[2]) - bootm_argv[2] = "-"; - bootm_argc = 4; - } - - kernel_addr = genimg_get_kernel_addr(bootm_argv[1]); - buf = map_sysmem(kernel_addr, 0); - /* Try bootm for legacy and FIT format image */ - if (genimg_get_format(buf) != IMAGE_FORMAT_INVALID) - do_bootm(cmdtp, 0, bootm_argc, bootm_argv); -#ifdef CONFIG_CMD_BOOTI - /* Try booting an AArch64 Linux kernel image */ - else - do_booti(cmdtp, 0, bootm_argc, bootm_argv); -#elif defined(CONFIG_CMD_BOOTZ) - /* Try booting a Image */ - else - do_bootz(cmdtp, 0, bootm_argc, bootm_argv); -#endif - unmap_sysmem(buf); - -cleanup: - if (fit_addr) - free(fit_addr); - return 1; -} - -/* - * Tokens for the pxe file parser. - */ -enum token_type { - T_EOL, - T_STRING, - T_EOF, - T_MENU, - T_TITLE, - T_TIMEOUT, - T_LABEL, - T_KERNEL, - T_LINUX, - T_APPEND, - T_INITRD, - T_LOCALBOOT, - T_DEFAULT, - T_PROMPT, - T_INCLUDE, - T_FDT, - T_FDTDIR, - T_ONTIMEOUT, - T_IPAPPEND, - T_BACKGROUND, - T_INVALID -}; - -/* - * A token - given by a value and a type. - */ -struct token { - char *val; - enum token_type type; -}; - -/* - * Keywords recognized. - */ -static const struct token keywords[] = { - {"menu", T_MENU}, - {"title", T_TITLE}, - {"timeout", T_TIMEOUT}, - {"default", T_DEFAULT}, - {"prompt", T_PROMPT}, - {"label", T_LABEL}, - {"kernel", T_KERNEL}, - {"linux", T_LINUX}, - {"localboot", T_LOCALBOOT}, - {"append", T_APPEND}, - {"initrd", T_INITRD}, - {"include", T_INCLUDE}, - {"devicetree", T_FDT}, - {"fdt", T_FDT}, - {"devicetreedir", T_FDTDIR}, - {"fdtdir", T_FDTDIR}, - {"ontimeout", T_ONTIMEOUT,}, - {"ipappend", T_IPAPPEND,}, - {"background", T_BACKGROUND,}, - {NULL, T_INVALID} -}; - -/* - * Since pxe(linux) files don't have a token to identify the start of a - * literal, we have to keep track of when we're in a state where a literal is - * expected vs when we're in a state a keyword is expected. - */ -enum lex_state { - L_NORMAL = 0, - L_KEYWORD, - L_SLITERAL -}; - -/* - * get_string retrieves a string from *p and stores it as a token in - * *t. - * - * get_string used for scanning both string literals and keywords. - * - * Characters from *p are copied into t-val until a character equal to - * delim is found, or a NUL byte is reached. If delim has the special value of - * ' ', any whitespace character will be used as a delimiter. - * - * If lower is unequal to 0, uppercase characters will be converted to - * lowercase in the result. This is useful to make keywords case - * insensitive. - * - * The location of *p is updated to point to the first character after the end - * of the token - the ending delimiter. - * - * On success, the new value of t->val is returned. Memory for t->val is - * allocated using malloc and must be free()'d to reclaim it. If insufficient - * memory is available, NULL is returned. - */ -static char *get_string(char **p, struct token *t, char delim, int lower) -{ - char *b, *e; - size_t len, i; - - /* - * b and e both start at the beginning of the input stream. - * - * e is incremented until we find the ending delimiter, or a NUL byte - * is reached. Then, we take e - b to find the length of the token. - */ - b = e = *p; - - while (*e) { - if ((delim == ' ' && isspace(*e)) || delim == *e) - break; - e++; - } - - len = e - b; - - /* - * Allocate memory to hold the string, and copy it in, converting - * characters to lowercase if lower is != 0. - */ - t->val = malloc(len + 1); - if (!t->val) - return NULL; - - for (i = 0; i < len; i++, b++) { - if (lower) - t->val[i] = tolower(*b); - else - t->val[i] = *b; - } - - t->val[len] = '\0'; - - /* - * Update *p so the caller knows where to continue scanning. - */ - *p = e; - - t->type = T_STRING; - - return t->val; -} - -/* - * Populate a keyword token with a type and value. - */ -static void get_keyword(struct token *t) -{ - int i; - - for (i = 0; keywords[i].val; i++) { - if (!strcmp(t->val, keywords[i].val)) { - t->type = keywords[i].type; - break; - } - } -} - -/* - * Get the next token. We have to keep track of which state we're in to know - * if we're looking to get a string literal or a keyword. - * - * *p is updated to point at the first character after the current token. - */ -static void get_token(char **p, struct token *t, enum lex_state state) -{ - char *c = *p; - - t->type = T_INVALID; - - /* eat non EOL whitespace */ - while (isblank(*c)) - c++; - - /* - * eat comments. note that string literals can't begin with #, but - * can contain a # after their first character. - */ - if (*c == '#') { - while (*c && *c != '\n') - c++; - } - - if (*c == '\n') { - t->type = T_EOL; - c++; - } else if (*c == '\0') { - t->type = T_EOF; - c++; - } else if (state == L_SLITERAL) { - get_string(&c, t, '\n', 0); - } else if (state == L_KEYWORD) { - /* - * when we expect a keyword, we first get the next string - * token delimited by whitespace, and then check if it - * matches a keyword in our keyword list. if it does, it's - * converted to a keyword token of the appropriate type, and - * if not, it remains a string token. - */ - get_string(&c, t, ' ', 1); - get_keyword(t); - } - - *p = c; -} - -/* - * Increment *c until we get to the end of the current line, or EOF. - */ -static void eol_or_eof(char **c) -{ - while (**c && **c != '\n') - (*c)++; -} - -/* - * All of these parse_* functions share some common behavior. - * - * They finish with *c pointing after the token they parse, and return 1 on - * success, or < 0 on error. - */ - -/* - * Parse a string literal and store a pointer it at *dst. String literals - * terminate at the end of the line. - */ -static int parse_sliteral(char **c, char **dst) -{ - struct token t; - char *s = *c; - - get_token(c, &t, L_SLITERAL); - - if (t.type != T_STRING) { - printf("Expected string literal: %.*s\n", (int)(*c - s), s); - return -EINVAL; - } - - *dst = t.val; - - return 1; -} - -/* - * Parse a base 10 (unsigned) integer and store it at *dst. - */ -static int parse_integer(char **c, int *dst) -{ - struct token t; - char *s = *c; - - get_token(c, &t, L_SLITERAL); - - if (t.type != T_STRING) { - printf("Expected string: %.*s\n", (int)(*c - s), s); - return -EINVAL; - } - - *dst = simple_strtol(t.val, NULL, 10); - - free(t.val); - - return 1; -} - -static int parse_pxefile_top(cmd_tbl_t *cmdtp, char *p, unsigned long base, - struct pxe_menu *cfg, int nest_level); - -/* - * Parse an include statement, and retrieve and parse the file it mentions. - * - * base should point to a location where it's safe to store the file, and - * nest_level should indicate how many nested includes have occurred. For this - * include, nest_level has already been incremented and doesn't need to be - * incremented here. - */ -static int handle_include(cmd_tbl_t *cmdtp, char **c, unsigned long base, - struct pxe_menu *cfg, int nest_level) -{ - char *include_path; - char *s = *c; - int err; - char *buf; - int ret; - - err = parse_sliteral(c, &include_path); - - if (err < 0) { - printf("Expected include path: %.*s\n", - (int)(*c - s), s); - return err; - } - - err = get_pxe_file(cmdtp, include_path, base); - - if (err < 0) { - printf("Couldn't retrieve %s\n", include_path); - return err; - } - - buf = map_sysmem(base, 0); - ret = parse_pxefile_top(cmdtp, buf, base, cfg, nest_level); - unmap_sysmem(buf); - - return ret; -} - -/* - * Parse lines that begin with 'menu'. - * - * base and nest are provided to handle the 'menu include' case. - * - * base should point to a location where it's safe to store the included file. - * - * nest_level should be 1 when parsing the top level pxe file, 2 when parsing - * a file it includes, 3 when parsing a file included by that file, and so on. - */ -static int parse_menu(cmd_tbl_t *cmdtp, char **c, struct pxe_menu *cfg, - unsigned long base, int nest_level) -{ - struct token t; - char *s = *c; - int err = 0; - - get_token(c, &t, L_KEYWORD); - - switch (t.type) { - case T_TITLE: - err = parse_sliteral(c, &cfg->title); - - break; - - case T_INCLUDE: - err = handle_include(cmdtp, c, base, cfg, - nest_level + 1); - break; - - case T_BACKGROUND: - err = parse_sliteral(c, &cfg->bmp); - break; - - default: - printf("Ignoring malformed menu command: %.*s\n", - (int)(*c - s), s); - } - - if (err < 0) - return err; - - eol_or_eof(c); - - return 1; -} - -/* - * Handles parsing a 'menu line' when we're parsing a label. - */ -static int parse_label_menu(char **c, struct pxe_menu *cfg, - struct pxe_label *label) -{ - struct token t; - char *s; - - s = *c; - - get_token(c, &t, L_KEYWORD); - - switch (t.type) { - case T_DEFAULT: - if (!cfg->default_label) - cfg->default_label = strdup(label->name); - - if (!cfg->default_label) - return -ENOMEM; - - break; - case T_LABEL: - parse_sliteral(c, &label->menu); - break; - default: - printf("Ignoring malformed menu command: %.*s\n", - (int)(*c - s), s); - } - - eol_or_eof(c); - - return 0; -} - -/* - * Handles parsing a 'kernel' label. - * expecting "filename" or "<fit_filename>#cfg" - */ -static int parse_label_kernel(char **c, struct pxe_label *label) -{ - char *s; - int err; - - err = parse_sliteral(c, &label->kernel); - if (err < 0) - return err; - - s = strstr(label->kernel, "#"); - if (!s) - return 1; - - label->config = malloc(strlen(s) + 1); - if (!label->config) - return -ENOMEM; - - strcpy(label->config, s); - *s = 0; - - return 1; -} - -/* - * Parses a label and adds it to the list of labels for a menu. - * - * A label ends when we either get to the end of a file, or - * get some input we otherwise don't have a handler defined - * for. - * - */ -static int parse_label(char **c, struct pxe_menu *cfg) -{ - struct token t; - int len; - char *s = *c; - struct pxe_label *label; - int err; - - label = label_create(); - if (!label) - return -ENOMEM; - - err = parse_sliteral(c, &label->name); - if (err < 0) { - printf("Expected label name: %.*s\n", (int)(*c - s), s); - label_destroy(label); - return -EINVAL; - } - - list_add_tail(&label->list, &cfg->labels); - - while (1) { - s = *c; - get_token(c, &t, L_KEYWORD); - - err = 0; - switch (t.type) { - case T_MENU: - err = parse_label_menu(c, cfg, label); - break; - - case T_KERNEL: - case T_LINUX: - err = parse_label_kernel(c, label); - break; - - case T_APPEND: - err = parse_sliteral(c, &label->append); - if (label->initrd) - break; - s = strstr(label->append, "initrd="); - if (!s) - break; - s += 7; - len = (int)(strchr(s, ' ') - s); - label->initrd = malloc(len + 1); - strncpy(label->initrd, s, len); - label->initrd[len] = '\0'; - - break; - - case T_INITRD: - if (!label->initrd) - err = parse_sliteral(c, &label->initrd); - break; - - case T_FDT: - if (!label->fdt) - err = parse_sliteral(c, &label->fdt); - break; - - case T_FDTDIR: - if (!label->fdtdir) - err = parse_sliteral(c, &label->fdtdir); - break; - - case T_LOCALBOOT: - label->localboot = 1; - err = parse_integer(c, &label->localboot_val); - break; - - case T_IPAPPEND: - err = parse_integer(c, &label->ipappend); - break; - - case T_EOL: - break; - - default: - /* - * put the token back! we don't want it - it's the end - * of a label and whatever token this is, it's - * something for the menu level context to handle. - */ - *c = s; - return 1; - } - - if (err < 0) - return err; - } -} - -/* - * This 16 comes from the limit pxelinux imposes on nested includes. - * - * There is no reason at all we couldn't do more, but some limit helps prevent - * infinite (until crash occurs) recursion if a file tries to include itself. - */ -#define MAX_NEST_LEVEL 16 - -/* - * Entry point for parsing a menu file. nest_level indicates how many times - * we've nested in includes. It will be 1 for the top level menu file. - * - * Returns 1 on success, < 0 on error. - */ -static int parse_pxefile_top(cmd_tbl_t *cmdtp, char *p, unsigned long base, - struct pxe_menu *cfg, int nest_level) -{ - struct token t; - char *s, *b, *label_name; - int err; - - b = p; - - if (nest_level > MAX_NEST_LEVEL) { - printf("Maximum nesting (%d) exceeded\n", MAX_NEST_LEVEL); - return -EMLINK; - } - - while (1) { - s = p; - - get_token(&p, &t, L_KEYWORD); - - err = 0; - switch (t.type) { - case T_MENU: - cfg->prompt = 1; - err = parse_menu(cmdtp, &p, cfg, - base + ALIGN(strlen(b) + 1, 4), - nest_level); - break; - - case T_TIMEOUT: - err = parse_integer(&p, &cfg->timeout); - break; - - case T_LABEL: - err = parse_label(&p, cfg); - break; - - case T_DEFAULT: - case T_ONTIMEOUT: - err = parse_sliteral(&p, &label_name); - - if (label_name) { - if (cfg->default_label) - free(cfg->default_label); - - cfg->default_label = label_name; - } - - break; - - case T_INCLUDE: - err = handle_include(cmdtp, &p, - base + ALIGN(strlen(b), 4), cfg, - nest_level + 1); - break; - - case T_PROMPT: - eol_or_eof(&p); - break; - - case T_EOL: - break; - - case T_EOF: - return 1; - - default: - printf("Ignoring unknown command: %.*s\n", - (int)(p - s), s); - eol_or_eof(&p); - } - - if (err < 0) - return err; - } -} - -/* - * Free the memory used by a pxe_menu and its labels. - */ -static void destroy_pxe_menu(struct pxe_menu *cfg) -{ - struct list_head *pos, *n; - struct pxe_label *label; - - if (cfg->title) - free(cfg->title); - - if (cfg->default_label) - free(cfg->default_label); - - list_for_each_safe(pos, n, &cfg->labels) { - label = list_entry(pos, struct pxe_label, list); - - label_destroy(label); - } - - free(cfg); -} - -/* - * Entry point for parsing a pxe file. This is only used for the top level - * file. - * - * Returns NULL if there is an error, otherwise, returns a pointer to a - * pxe_menu struct populated with the results of parsing the pxe file (and any - * files it includes). The resulting pxe_menu struct can be free()'d by using - * the destroy_pxe_menu() function. - */ -static struct pxe_menu *parse_pxefile(cmd_tbl_t *cmdtp, unsigned long menucfg) -{ - struct pxe_menu *cfg; - char *buf; - int r; - - cfg = malloc(sizeof(struct pxe_menu)); - - if (!cfg) - return NULL; - - memset(cfg, 0, sizeof(struct pxe_menu)); - - INIT_LIST_HEAD(&cfg->labels); - - buf = map_sysmem(menucfg, 0); - r = parse_pxefile_top(cmdtp, buf, menucfg, cfg, 1); - unmap_sysmem(buf); - - if (r < 0) { - destroy_pxe_menu(cfg); - return NULL; - } - - return cfg; -} - -/* - * Converts a pxe_menu struct into a menu struct for use with U-Boot's generic - * menu code. - */ -static struct menu *pxe_menu_to_menu(struct pxe_menu *cfg) -{ - struct pxe_label *label; - struct list_head *pos; - struct menu *m; - int err; - int i = 1; - char *default_num = NULL; - - /* - * Create a menu and add items for all the labels. - */ - m = menu_create(cfg->title, DIV_ROUND_UP(cfg->timeout, 10), - cfg->prompt, label_print, NULL, NULL); - - if (!m) - return NULL; - - list_for_each(pos, &cfg->labels) { - label = list_entry(pos, struct pxe_label, list); - - sprintf(label->num, "%d", i++); - if (menu_item_add(m, label->num, label) != 1) { - menu_destroy(m); - return NULL; - } - if (cfg->default_label && - (strcmp(label->name, cfg->default_label) == 0)) - default_num = label->num; - - } - - /* - * After we've created items for each label in the menu, set the - * menu's default label if one was specified. - */ - if (default_num) { - err = menu_default_set(m, default_num); - if (err != 1) { - if (err != -ENOENT) { - menu_destroy(m); - return NULL; - } - - printf("Missing default: %s\n", cfg->default_label); - } - } - - return m; -} - -/* - * Try to boot any labels we have yet to attempt to boot. - */ -static void boot_unattempted_labels(cmd_tbl_t *cmdtp, struct pxe_menu *cfg) -{ - struct list_head *pos; - struct pxe_label *label; - - list_for_each(pos, &cfg->labels) { - label = list_entry(pos, struct pxe_label, list); - - if (!label->attempted) - label_boot(cmdtp, label); - } -} - -/* - * Boot the system as prescribed by a pxe_menu. - * - * Use the menu system to either get the user's choice or the default, based - * on config or user input. If there is no default or user's choice, - * attempted to boot labels in the order they were given in pxe files. - * If the default or user's choice fails to boot, attempt to boot other - * labels in the order they were given in pxe files. - * - * If this function returns, there weren't any labels that successfully - * booted, or the user interrupted the menu selection via ctrl+c. - */ -static void handle_pxe_menu(cmd_tbl_t *cmdtp, struct pxe_menu *cfg) -{ - void *choice; - struct menu *m; - int err; - -#ifdef CONFIG_CMD_BMP - /* display BMP if available */ - if (cfg->bmp) { - if (get_relfile(cmdtp, cfg->bmp, load_addr)) { - run_command("cls", 0); - bmp_display(load_addr, - BMP_ALIGN_CENTER, BMP_ALIGN_CENTER); - } else { - printf("Skipping background bmp %s for failure\n", - cfg->bmp); - } - } -#endif - - m = pxe_menu_to_menu(cfg); - if (!m) - return; - - err = menu_get_choice(m, &choice); - - menu_destroy(m); - - /* - * err == 1 means we got a choice back from menu_get_choice. - * - * err == -ENOENT if the menu was setup to select the default but no - * default was set. in that case, we should continue trying to boot - * labels that haven't been attempted yet. - * - * otherwise, the user interrupted or there was some other error and - * we give up. - */ - - if (err == 1) { - err = label_boot(cmdtp, choice); - if (!err) - return; - } else if (err != -ENOENT) { - return; - } - - boot_unattempted_labels(cmdtp, cfg); -} - -#ifdef CONFIG_CMD_NET -/* - * Boots a system using a pxe file - * - * Returns 0 on success, 1 on error. - */ -static int -do_pxe_boot(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) -{ - unsigned long pxefile_addr_r; - struct pxe_menu *cfg; - char *pxefile_addr_str; - - do_getfile = do_get_tftp; - - if (argc == 1) { - pxefile_addr_str = from_env("pxefile_addr_r"); - if (!pxefile_addr_str) - return 1; - - } else if (argc == 2) { - pxefile_addr_str = argv[1]; - } else { - return CMD_RET_USAGE; - } - - if (strict_strtoul(pxefile_addr_str, 16, &pxefile_addr_r) < 0) { - printf("Invalid pxefile address: %s\n", pxefile_addr_str); - return 1; - } - - cfg = parse_pxefile(cmdtp, pxefile_addr_r); - - if (cfg == NULL) { - printf("Error parsing config file\n"); - return 1; - } - - handle_pxe_menu(cmdtp, cfg); - - destroy_pxe_menu(cfg); - - copy_filename(net_boot_file_name, "", sizeof(net_boot_file_name)); - - return 0; -} - -static cmd_tbl_t cmd_pxe_sub[] = { - U_BOOT_CMD_MKENT(get, 1, 1, do_pxe_get, "", ""), - U_BOOT_CMD_MKENT(boot, 2, 1, do_pxe_boot, "", "") -}; - -static int do_pxe(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) -{ - cmd_tbl_t *cp; - - if (argc < 2) - return CMD_RET_USAGE; - - is_pxe = true; - - /* drop initial "pxe" arg */ - argc--; - argv++; - - cp = find_cmd_tbl(argv[0], cmd_pxe_sub, ARRAY_SIZE(cmd_pxe_sub)); - - if (cp) - return cp->cmd(cmdtp, flag, argc, argv); - - return CMD_RET_USAGE; + return CMD_RET_USAGE; }
U_BOOT_CMD( @@ -1712,90 +176,3 @@ U_BOOT_CMD( "boot [pxefile_addr_r] - boot from the pxe file at pxefile_addr_r\n" ); #endif - -/* - * Boots a system using a local disk syslinux/extlinux file - * - * Returns 0 on success, 1 on error. - */ -static int do_sysboot(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) -{ - unsigned long pxefile_addr_r; - struct pxe_menu *cfg; - char *pxefile_addr_str; - char *filename; - int prompt = 0; - - is_pxe = false; - - if (argc > 1 && strstr(argv[1], "-p")) { - prompt = 1; - argc--; - argv++; - } - - if (argc < 4) - return cmd_usage(cmdtp); - - if (argc < 5) { - pxefile_addr_str = from_env("pxefile_addr_r"); - if (!pxefile_addr_str) - return 1; - } else { - pxefile_addr_str = argv[4]; - } - - if (argc < 6) - filename = env_get("bootfile"); - else { - filename = argv[5]; - env_set("bootfile", filename); - } - - if (strstr(argv[3], "ext2")) - do_getfile = do_get_ext2; - else if (strstr(argv[3], "fat")) - do_getfile = do_get_fat; - else if (strstr(argv[3], "any")) - do_getfile = do_get_any; - else { - printf("Invalid filesystem: %s\n", argv[3]); - return 1; - } - fs_argv[1] = argv[1]; - fs_argv[2] = argv[2]; - - if (strict_strtoul(pxefile_addr_str, 16, &pxefile_addr_r) < 0) { - printf("Invalid pxefile address: %s\n", pxefile_addr_str); - return 1; - } - - if (get_pxe_file(cmdtp, filename, pxefile_addr_r) < 0) { - printf("Error reading config file\n"); - return 1; - } - - cfg = parse_pxefile(cmdtp, pxefile_addr_r); - - if (cfg == NULL) { - printf("Error parsing config file\n"); - return 1; - } - - if (prompt) - cfg->prompt = 1; - - handle_pxe_menu(cmdtp, cfg); - - destroy_pxe_menu(cfg); - - return 0; -} - -U_BOOT_CMD( - sysboot, 7, 1, do_sysboot, - "command to get and boot from syslinux files", - "[-p] <interface> <dev[:part]> <ext2|fat|any> [addr] [filename]\n" - " - load and parse syslinux menu file 'filename' from ext2, fat\n" - " or any filesystem on 'dev' on 'interface' to address 'addr'" -); diff --git a/cmd/pxe_utils.c b/cmd/pxe_utils.c new file mode 100644 index 0000000000..bbc931b208 --- /dev/null +++ b/cmd/pxe_utils.c @@ -0,0 +1,1463 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright 2010-2011 Calxeda, Inc. + * Copyright (c) 2014, NVIDIA CORPORATION. All rights reserved. + */ + +#include <common.h> +#include <command.h> +#include <env.h> +#include <malloc.h> +#include <mapmem.h> +#include <lcd.h> +#include <linux/string.h> +#include <linux/ctype.h> +#include <errno.h> +#include <linux/list.h> +#include <fs.h> + +#include <splash.h> +#include <asm/io.h> + +#include "menu.h" +#include "cli.h" +#include "pxe_utils.h" + +#define MAX_TFTP_PATH_LEN 127 + +bool is_pxe; + +int (*do_getfile)(cmd_tbl_t *cmdtp, const char *file_path, char *file_addr); + +/* + * Returns the directory the file specified in the bootfile env variable is + * in. If bootfile isn't defined in the environment, return NULL, which should + * be interpreted as "don't prepend anything to paths". + */ +static int get_bootfile_path(const char *file_path, char *bootfile_path, + size_t bootfile_path_size) +{ + char *bootfile, *last_slash; + size_t path_len = 0; + + /* Only syslinux allows absolute paths */ + if (file_path[0] == '/' && !is_pxe) + goto ret; + + bootfile = from_env("bootfile"); + + if (!bootfile) + goto ret; + + last_slash = strrchr(bootfile, '/'); + + if (!last_slash) + goto ret; + + path_len = (last_slash - bootfile) + 1; + + if (bootfile_path_size < path_len) { + printf("bootfile_path too small. (%zd < %zd)\n", + bootfile_path_size, path_len); + + return -1; + } + + strncpy(bootfile_path, bootfile, path_len); + + ret: + bootfile_path[path_len] = '\0'; + + return 1; +} + +/* + * As in pxelinux, paths to files referenced from files we retrieve are + * relative to the location of bootfile. get_relfile takes such a path and + * joins it with the bootfile path to get the full path to the target file. If + * the bootfile path is NULL, we use file_path as is. + * + * Returns 1 for success, or < 0 on error. + */ +static int get_relfile(cmd_tbl_t *cmdtp, const char *file_path, + unsigned long file_addr) +{ + size_t path_len; + char relfile[MAX_TFTP_PATH_LEN + 1]; + char addr_buf[18]; + int err; + + err = get_bootfile_path(file_path, relfile, sizeof(relfile)); + + if (err < 0) + return err; + + path_len = strlen(file_path); + path_len += strlen(relfile); + + if (path_len > MAX_TFTP_PATH_LEN) { + printf("Base path too long (%s%s)\n", relfile, file_path); + + return -ENAMETOOLONG; + } + + strcat(relfile, file_path); + + printf("Retrieving file: %s\n", relfile); + + sprintf(addr_buf, "%lx", file_addr); + + return do_getfile(cmdtp, relfile, addr_buf); +} + +/* + * Retrieve the file at 'file_path' to the locate given by 'file_addr'. If + * 'bootfile' was specified in the environment, the path to bootfile will be + * prepended to 'file_path' and the resulting path will be used. + * + * Returns 1 on success, or < 0 for error. + */ +int get_pxe_file(cmd_tbl_t *cmdtp, const char *file_path, + unsigned long file_addr) +{ + unsigned long config_file_size; + char *tftp_filesize; + int err; + char *buf; + + err = get_relfile(cmdtp, file_path, file_addr); + + if (err < 0) + return err; + + /* + * the file comes without a NUL byte at the end, so find out its size + * and add the NUL byte. + */ + tftp_filesize = from_env("filesize"); + + if (!tftp_filesize) + return -ENOENT; + + if (strict_strtoul(tftp_filesize, 16, &config_file_size) < 0) + return -EINVAL; + + buf = map_sysmem(file_addr + config_file_size, 1); + *buf = '\0'; + unmap_sysmem(buf); + + return 1; +} + +#ifdef CONFIG_CMD_NET + +#define PXELINUX_DIR "pxelinux.cfg/" + +/* + * Convert an ethaddr from the environment to the format used by pxelinux + * filenames based on mac addresses. Convert's ':' to '-', and adds "01-" to + * the beginning of the ethernet address to indicate a hardware type of + * Ethernet. Also converts uppercase hex characters into lowercase, to match + * pxelinux's behavior. + * + * Returns 1 for success, -ENOENT if 'ethaddr' is undefined in the + * environment, or some other value < 0 on error. + */ +static int format_mac_pxe(char *outbuf, size_t outbuf_len) +{ + uchar ethaddr[6]; + + if (outbuf_len < 21) { + printf("outbuf is too small (%zd < 21)\n", outbuf_len); + + return -EINVAL; + } + + if (!eth_env_get_enetaddr_by_index("eth", eth_get_dev_index(), ethaddr)) + return -ENOENT; + + sprintf(outbuf, "01-%02x-%02x-%02x-%02x-%02x-%02x", + ethaddr[0], ethaddr[1], ethaddr[2], + ethaddr[3], ethaddr[4], ethaddr[5]); + + return 1; +} + +/* + * Retrieves a file in the 'pxelinux.cfg' folder. Since this uses get_pxe_file + * to do the hard work, the location of the 'pxelinux.cfg' folder is generated + * from the bootfile path, as described above. + * + * Returns 1 on success or < 0 on error. + */ +int get_pxelinux_path(cmd_tbl_t *cmdtp, const char *file, + unsigned long pxefile_addr_r) +{ + size_t base_len = strlen(PXELINUX_DIR); + char path[MAX_TFTP_PATH_LEN + 1]; + + if (base_len + strlen(file) > MAX_TFTP_PATH_LEN) { + printf("path (%s%s) too long, skipping\n", PXELINUX_DIR, file); + return -ENAMETOOLONG; + } + + sprintf(path, PXELINUX_DIR "%s", file); + + return get_pxe_file(cmdtp, path, pxefile_addr_r); +} + +/* + * Looks for a pxe file with a name based on the pxeuuid environment variable. + * + * Returns 1 on success or < 0 on error. + */ +int pxe_uuid_path(cmd_tbl_t *cmdtp, unsigned long pxefile_addr_r) +{ + char *uuid_str; + + uuid_str = from_env("pxeuuid"); + + if (!uuid_str) + return -ENOENT; + + return get_pxelinux_path(cmdtp, uuid_str, pxefile_addr_r); +} + +/* + * Looks for a pxe file with a name based on the 'ethaddr' environment + * variable. + * + * Returns 1 on success or < 0 on error. + */ +int pxe_mac_path(cmd_tbl_t *cmdtp, unsigned long pxefile_addr_r) +{ + char mac_str[21]; + int err; + + err = format_mac_pxe(mac_str, sizeof(mac_str)); + + if (err < 0) + return err; + + return get_pxelinux_path(cmdtp, mac_str, pxefile_addr_r); +} + +/* + * Looks for pxe files with names based on our IP address. See pxelinux + * documentation for details on what these file names look like. We match + * that exactly. + * + * Returns 1 on success or < 0 on error. + */ +int pxe_ipaddr_paths(cmd_tbl_t *cmdtp, unsigned long pxefile_addr_r) +{ + char ip_addr[9]; + int mask_pos, err; + + sprintf(ip_addr, "%08X", ntohl(net_ip.s_addr)); + + for (mask_pos = 7; mask_pos >= 0; mask_pos--) { + err = get_pxelinux_path(cmdtp, ip_addr, pxefile_addr_r); + + if (err > 0) + return err; + + ip_addr[mask_pos] = '\0'; + } + + return -ENOENT; +} +#endif + +/* + * Wrapper to make it easier to store the file at file_path in the location + * specified by envaddr_name. file_path will be joined to the bootfile path, + * if any is specified. + * + * Returns 1 on success or < 0 on error. + */ +static int get_relfile_envaddr(cmd_tbl_t *cmdtp, const char *file_path, + const char *envaddr_name) +{ + unsigned long file_addr; + char *envaddr; + + envaddr = from_env(envaddr_name); + + if (!envaddr) + return -ENOENT; + + if (strict_strtoul(envaddr, 16, &file_addr) < 0) + return -EINVAL; + + return get_relfile(cmdtp, file_path, file_addr); +} + +/* + * A note on the pxe file parser. + * + * We're parsing files that use syslinux grammar, which has a few quirks. + * String literals must be recognized based on context - there is no + * quoting or escaping support. There's also nothing to explicitly indicate + * when a label section completes. We deal with that by ending a label + * section whenever we see a line that doesn't include. + * + * As with the syslinux family, this same file format could be reused in the + * future for non pxe purposes. The only action it takes during parsing that + * would throw this off is handling of include files. It assumes we're using + * pxe, and does a tftp download of a file listed as an include file in the + * middle of the parsing operation. That could be handled by refactoring it to + * take a 'include file getter' function. + */ + +/* + * Describes a single label given in a pxe file. + * + * Create these with the 'label_create' function given below. + * + * name - the name of the menu as given on the 'menu label' line. + * kernel - the path to the kernel file to use for this label. + * append - kernel command line to use when booting this label + * initrd - path to the initrd to use for this label. + * attempted - 0 if we haven't tried to boot this label, 1 if we have. + * localboot - 1 if this label specified 'localboot', 0 otherwise. + * list - lets these form a list, which a pxe_menu struct will hold. + */ +struct pxe_label { + char num[4]; + char *name; + char *menu; + char *kernel; + char *config; + char *append; + char *initrd; + char *fdt; + char *fdtdir; + int ipappend; + int attempted; + int localboot; + int localboot_val; + struct list_head list; +}; + +/* + * Allocates memory for and initializes a pxe_label. This uses malloc, so the + * result must be free()'d to reclaim the memory. + * + * Returns NULL if malloc fails. + */ +static struct pxe_label *label_create(void) +{ + struct pxe_label *label; + + label = malloc(sizeof(struct pxe_label)); + + if (!label) + return NULL; + + memset(label, 0, sizeof(struct pxe_label)); + + return label; +} + +/* + * Free the memory used by a pxe_label, including that used by its name, + * kernel, append and initrd members, if they're non NULL. + * + * So - be sure to only use dynamically allocated memory for the members of + * the pxe_label struct, unless you want to clean it up first. These are + * currently only created by the pxe file parsing code. + */ +static void label_destroy(struct pxe_label *label) +{ + if (label->name) + free(label->name); + + if (label->kernel) + free(label->kernel); + + if (label->config) + free(label->config); + + if (label->append) + free(label->append); + + if (label->initrd) + free(label->initrd); + + if (label->fdt) + free(label->fdt); + + if (label->fdtdir) + free(label->fdtdir); + + free(label); +} + +/* + * Print a label and its string members if they're defined. + * + * This is passed as a callback to the menu code for displaying each + * menu entry. + */ +static void label_print(void *data) +{ + struct pxe_label *label = data; + const char *c = label->menu ? label->menu : label->name; + + printf("%s:\t%s\n", label->num, c); +} + +/* + * Boot a label that specified 'localboot'. This requires that the 'localcmd' + * environment variable is defined. Its contents will be executed as U-Boot + * command. If the label specified an 'append' line, its contents will be + * used to overwrite the contents of the 'bootargs' environment variable prior + * to running 'localcmd'. + * + * Returns 1 on success or < 0 on error. + */ +static int label_localboot(struct pxe_label *label) +{ + char *localcmd; + + localcmd = from_env("localcmd"); + + if (!localcmd) + return -ENOENT; + + if (label->append) { + char bootargs[CONFIG_SYS_CBSIZE]; + + cli_simple_process_macros(label->append, bootargs); + env_set("bootargs", bootargs); + } + + debug("running: %s\n", localcmd); + + return run_command_list(localcmd, strlen(localcmd), 0); +} + +/* + * Boot according to the contents of a pxe_label. + * + * If we can't boot for any reason, we return. A successful boot never + * returns. + * + * The kernel will be stored in the location given by the 'kernel_addr_r' + * environment variable. + * + * If the label specifies an initrd file, it will be stored in the location + * given by the 'ramdisk_addr_r' environment variable. + * + * If the label specifies an 'append' line, its contents will overwrite that + * of the 'bootargs' environment variable. + */ +static int label_boot(cmd_tbl_t *cmdtp, struct pxe_label *label) +{ + char *bootm_argv[] = { "bootm", NULL, NULL, NULL, NULL }; + char initrd_str[28]; + char mac_str[29] = ""; + char ip_str[68] = ""; + char *fit_addr = NULL; + int bootm_argc = 2; + int len = 0; + ulong kernel_addr; + void *buf; + + label_print(label); + + label->attempted = 1; + + if (label->localboot) { + if (label->localboot_val >= 0) + label_localboot(label); + return 0; + } + + if (!label->kernel) { + printf("No kernel given, skipping %s\n", label->name); + return 1; + } + + if (label->initrd) { + if (get_relfile_envaddr(cmdtp, label->initrd, "ramdisk_addr_r") < 0) { + printf("Skipping %s for failure retrieving initrd\n", + label->name); + return 1; + } + + bootm_argv[2] = initrd_str; + strncpy(bootm_argv[2], env_get("ramdisk_addr_r"), 18); + strcat(bootm_argv[2], ":"); + strncat(bootm_argv[2], env_get("filesize"), 9); + } + + if (get_relfile_envaddr(cmdtp, label->kernel, "kernel_addr_r") < 0) { + printf("Skipping %s for failure retrieving kernel\n", + label->name); + return 1; + } + + if (label->ipappend & 0x1) { + sprintf(ip_str, " ip=%s:%s:%s:%s", + env_get("ipaddr"), env_get("serverip"), + env_get("gatewayip"), env_get("netmask")); + } + +#ifdef CONFIG_CMD_NET + if (label->ipappend & 0x2) { + int err; + + strcpy(mac_str, " BOOTIF="); + err = format_mac_pxe(mac_str + 8, sizeof(mac_str) - 8); + if (err < 0) + mac_str[0] = '\0'; + } +#endif + + if ((label->ipappend & 0x3) || label->append) { + char bootargs[CONFIG_SYS_CBSIZE] = ""; + char finalbootargs[CONFIG_SYS_CBSIZE]; + + if (strlen(label->append ?: "") + + strlen(ip_str) + strlen(mac_str) + 1 > sizeof(bootargs)) { + printf("bootarg overflow %zd+%zd+%zd+1 > %zd\n", + strlen(label->append ?: ""), + strlen(ip_str), strlen(mac_str), + sizeof(bootargs)); + return 1; + } + + if (label->append) + strncpy(bootargs, label->append, sizeof(bootargs)); + + strcat(bootargs, ip_str); + strcat(bootargs, mac_str); + + cli_simple_process_macros(bootargs, finalbootargs); + env_set("bootargs", finalbootargs); + printf("append: %s\n", finalbootargs); + } + + bootm_argv[1] = env_get("kernel_addr_r"); + /* for FIT, append the configuration identifier */ + if (label->config) { + int len = strlen(bootm_argv[1]) + strlen(label->config) + 1; + + fit_addr = malloc(len); + if (!fit_addr) { + printf("malloc fail (FIT address)\n"); + return 1; + } + snprintf(fit_addr, len, "%s%s", bootm_argv[1], label->config); + bootm_argv[1] = fit_addr; + } + + /* + * fdt usage is optional: + * It handles the following scenarios. All scenarios are exclusive + * + * Scenario 1: If fdt_addr_r specified and "fdt" label is defined in + * pxe file, retrieve fdt blob from server. Pass fdt_addr_r to bootm, + * and adjust argc appropriately. + * + * Scenario 2: If there is an fdt_addr specified, pass it along to + * bootm, and adjust argc appropriately. + * + * Scenario 3: fdt blob is not available. + */ + bootm_argv[3] = env_get("fdt_addr_r"); + + /* if fdt label is defined then get fdt from server */ + if (bootm_argv[3]) { + char *fdtfile = NULL; + char *fdtfilefree = NULL; + + if (label->fdt) { + fdtfile = label->fdt; + } else if (label->fdtdir) { + char *f1, *f2, *f3, *f4, *slash; + + f1 = env_get("fdtfile"); + if (f1) { + f2 = ""; + f3 = ""; + f4 = ""; + } else { + /* + * For complex cases where this code doesn't + * generate the correct filename, the board + * code should set $fdtfile during early boot, + * or the boot scripts should set $fdtfile + * before invoking "pxe" or "sysboot". + */ + f1 = env_get("soc"); + f2 = "-"; + f3 = env_get("board"); + f4 = ".dtb"; + } + + len = strlen(label->fdtdir); + if (!len) + slash = "./"; + else if (label->fdtdir[len - 1] != '/') + slash = "/"; + else + slash = ""; + + len = strlen(label->fdtdir) + strlen(slash) + + strlen(f1) + strlen(f2) + strlen(f3) + + strlen(f4) + 1; + fdtfilefree = malloc(len); + if (!fdtfilefree) { + printf("malloc fail (FDT filename)\n"); + goto cleanup; + } + + snprintf(fdtfilefree, len, "%s%s%s%s%s%s", + label->fdtdir, slash, f1, f2, f3, f4); + fdtfile = fdtfilefree; + } + + if (fdtfile) { + int err = get_relfile_envaddr(cmdtp, fdtfile, + "fdt_addr_r"); + + free(fdtfilefree); + if (err < 0) { + printf("Skipping %s for failure retrieving fdt\n", + label->name); + goto cleanup; + } + } else { + bootm_argv[3] = NULL; + } + } + + if (!bootm_argv[3]) + bootm_argv[3] = env_get("fdt_addr"); + + if (bootm_argv[3]) { + if (!bootm_argv[2]) + bootm_argv[2] = "-"; + bootm_argc = 4; + } + + kernel_addr = genimg_get_kernel_addr(bootm_argv[1]); + buf = map_sysmem(kernel_addr, 0); + /* Try bootm for legacy and FIT format image */ + if (genimg_get_format(buf) != IMAGE_FORMAT_INVALID) + do_bootm(cmdtp, 0, bootm_argc, bootm_argv); +#ifdef CONFIG_CMD_BOOTI + /* Try booting an AArch64 Linux kernel image */ + else + do_booti(cmdtp, 0, bootm_argc, bootm_argv); +#elif defined(CONFIG_CMD_BOOTZ) + /* Try booting a Image */ + else + do_bootz(cmdtp, 0, bootm_argc, bootm_argv); +#endif + unmap_sysmem(buf); + +cleanup: + if (fit_addr) + free(fit_addr); + return 1; +} + +/* + * Tokens for the pxe file parser. + */ +enum token_type { + T_EOL, + T_STRING, + T_EOF, + T_MENU, + T_TITLE, + T_TIMEOUT, + T_LABEL, + T_KERNEL, + T_LINUX, + T_APPEND, + T_INITRD, + T_LOCALBOOT, + T_DEFAULT, + T_PROMPT, + T_INCLUDE, + T_FDT, + T_FDTDIR, + T_ONTIMEOUT, + T_IPAPPEND, + T_BACKGROUND, + T_INVALID +}; + +/* + * A token - given by a value and a type. + */ +struct token { + char *val; + enum token_type type; +}; + +/* + * Keywords recognized. + */ +static const struct token keywords[] = { + {"menu", T_MENU}, + {"title", T_TITLE}, + {"timeout", T_TIMEOUT}, + {"default", T_DEFAULT}, + {"prompt", T_PROMPT}, + {"label", T_LABEL}, + {"kernel", T_KERNEL}, + {"linux", T_LINUX}, + {"localboot", T_LOCALBOOT}, + {"append", T_APPEND}, + {"initrd", T_INITRD}, + {"include", T_INCLUDE}, + {"devicetree", T_FDT}, + {"fdt", T_FDT}, + {"devicetreedir", T_FDTDIR}, + {"fdtdir", T_FDTDIR}, + {"ontimeout", T_ONTIMEOUT,}, + {"ipappend", T_IPAPPEND,}, + {"background", T_BACKGROUND,}, + {NULL, T_INVALID} +}; + +/* + * Since pxe(linux) files don't have a token to identify the start of a + * literal, we have to keep track of when we're in a state where a literal is + * expected vs when we're in a state a keyword is expected. + */ +enum lex_state { + L_NORMAL = 0, + L_KEYWORD, + L_SLITERAL +}; + +/* + * get_string retrieves a string from *p and stores it as a token in + * *t. + * + * get_string used for scanning both string literals and keywords. + * + * Characters from *p are copied into t-val until a character equal to + * delim is found, or a NUL byte is reached. If delim has the special value of + * ' ', any whitespace character will be used as a delimiter. + * + * If lower is unequal to 0, uppercase characters will be converted to + * lowercase in the result. This is useful to make keywords case + * insensitive. + * + * The location of *p is updated to point to the first character after the end + * of the token - the ending delimiter. + * + * On success, the new value of t->val is returned. Memory for t->val is + * allocated using malloc and must be free()'d to reclaim it. If insufficient + * memory is available, NULL is returned. + */ +static char *get_string(char **p, struct token *t, char delim, int lower) +{ + char *b, *e; + size_t len, i; + + /* + * b and e both start at the beginning of the input stream. + * + * e is incremented until we find the ending delimiter, or a NUL byte + * is reached. Then, we take e - b to find the length of the token. + */ + e = *p; + b = *p; + + while (*e) { + if ((delim == ' ' && isspace(*e)) || delim == *e) + break; + e++; + } + + len = e - b; + + /* + * Allocate memory to hold the string, and copy it in, converting + * characters to lowercase if lower is != 0. + */ + t->val = malloc(len + 1); + if (!t->val) + return NULL; + + for (i = 0; i < len; i++, b++) { + if (lower) + t->val[i] = tolower(*b); + else + t->val[i] = *b; + } + + t->val[len] = '\0'; + + /* + * Update *p so the caller knows where to continue scanning. + */ + *p = e; + + t->type = T_STRING; + + return t->val; +} + +/* + * Populate a keyword token with a type and value. + */ +static void get_keyword(struct token *t) +{ + int i; + + for (i = 0; keywords[i].val; i++) { + if (!strcmp(t->val, keywords[i].val)) { + t->type = keywords[i].type; + break; + } + } +} + +/* + * Get the next token. We have to keep track of which state we're in to know + * if we're looking to get a string literal or a keyword. + * + * *p is updated to point at the first character after the current token. + */ +static void get_token(char **p, struct token *t, enum lex_state state) +{ + char *c = *p; + + t->type = T_INVALID; + + /* eat non EOL whitespace */ + while (isblank(*c)) + c++; + + /* + * eat comments. note that string literals can't begin with #, but + * can contain a # after their first character. + */ + if (*c == '#') { + while (*c && *c != '\n') + c++; + } + + if (*c == '\n') { + t->type = T_EOL; + c++; + } else if (*c == '\0') { + t->type = T_EOF; + c++; + } else if (state == L_SLITERAL) { + get_string(&c, t, '\n', 0); + } else if (state == L_KEYWORD) { + /* + * when we expect a keyword, we first get the next string + * token delimited by whitespace, and then check if it + * matches a keyword in our keyword list. if it does, it's + * converted to a keyword token of the appropriate type, and + * if not, it remains a string token. + */ + get_string(&c, t, ' ', 1); + get_keyword(t); + } + + *p = c; +} + +/* + * Increment *c until we get to the end of the current line, or EOF. + */ +static void eol_or_eof(char **c) +{ + while (**c && **c != '\n') + (*c)++; +} + +/* + * All of these parse_* functions share some common behavior. + * + * They finish with *c pointing after the token they parse, and return 1 on + * success, or < 0 on error. + */ + +/* + * Parse a string literal and store a pointer it at *dst. String literals + * terminate at the end of the line. + */ +static int parse_sliteral(char **c, char **dst) +{ + struct token t; + char *s = *c; + + get_token(c, &t, L_SLITERAL); + + if (t.type != T_STRING) { + printf("Expected string literal: %.*s\n", (int)(*c - s), s); + return -EINVAL; + } + + *dst = t.val; + + return 1; +} + +/* + * Parse a base 10 (unsigned) integer and store it at *dst. + */ +static int parse_integer(char **c, int *dst) +{ + struct token t; + char *s = *c; + + get_token(c, &t, L_SLITERAL); + + if (t.type != T_STRING) { + printf("Expected string: %.*s\n", (int)(*c - s), s); + return -EINVAL; + } + + *dst = simple_strtol(t.val, NULL, 10); + + free(t.val); + + return 1; +} + +static int parse_pxefile_top(cmd_tbl_t *cmdtp, char *p, unsigned long base, + struct pxe_menu *cfg, int nest_level); + +/* + * Parse an include statement, and retrieve and parse the file it mentions. + * + * base should point to a location where it's safe to store the file, and + * nest_level should indicate how many nested includes have occurred. For this + * include, nest_level has already been incremented and doesn't need to be + * incremented here. + */ +static int handle_include(cmd_tbl_t *cmdtp, char **c, unsigned long base, + struct pxe_menu *cfg, int nest_level) +{ + char *include_path; + char *s = *c; + int err; + char *buf; + int ret; + + err = parse_sliteral(c, &include_path); + + if (err < 0) { + printf("Expected include path: %.*s\n", (int)(*c - s), s); + return err; + } + + err = get_pxe_file(cmdtp, include_path, base); + + if (err < 0) { + printf("Couldn't retrieve %s\n", include_path); + return err; + } + + buf = map_sysmem(base, 0); + ret = parse_pxefile_top(cmdtp, buf, base, cfg, nest_level); + unmap_sysmem(buf); + + return ret; +} + +/* + * Parse lines that begin with 'menu'. + * + * base and nest are provided to handle the 'menu include' case. + * + * base should point to a location where it's safe to store the included file. + * + * nest_level should be 1 when parsing the top level pxe file, 2 when parsing + * a file it includes, 3 when parsing a file included by that file, and so on. + */ +static int parse_menu(cmd_tbl_t *cmdtp, char **c, struct pxe_menu *cfg, + unsigned long base, int nest_level) +{ + struct token t; + char *s = *c; + int err = 0; + + get_token(c, &t, L_KEYWORD); + + switch (t.type) { + case T_TITLE: + err = parse_sliteral(c, &cfg->title); + + break; + + case T_INCLUDE: + err = handle_include(cmdtp, c, base, cfg, + nest_level + 1); + break; + + case T_BACKGROUND: + err = parse_sliteral(c, &cfg->bmp); + break; + + default: + printf("Ignoring malformed menu command: %.*s\n", + (int)(*c - s), s); + } + + if (err < 0) + return err; + + eol_or_eof(c); + + return 1; +} + +/* + * Handles parsing a 'menu line' when we're parsing a label. + */ +static int parse_label_menu(char **c, struct pxe_menu *cfg, + struct pxe_label *label) +{ + struct token t; + char *s; + + s = *c; + + get_token(c, &t, L_KEYWORD); + + switch (t.type) { + case T_DEFAULT: + if (!cfg->default_label) + cfg->default_label = strdup(label->name); + + if (!cfg->default_label) + return -ENOMEM; + + break; + case T_LABEL: + parse_sliteral(c, &label->menu); + break; + default: + printf("Ignoring malformed menu command: %.*s\n", + (int)(*c - s), s); + } + + eol_or_eof(c); + + return 0; +} + +/* + * Handles parsing a 'kernel' label. + * expecting "filename" or "<fit_filename>#cfg" + */ +static int parse_label_kernel(char **c, struct pxe_label *label) +{ + char *s; + int err; + + err = parse_sliteral(c, &label->kernel); + if (err < 0) + return err; + + s = strstr(label->kernel, "#"); + if (!s) + return 1; + + label->config = malloc(strlen(s) + 1); + if (!label->config) + return -ENOMEM; + + strcpy(label->config, s); + *s = 0; + + return 1; +} + +/* + * Parses a label and adds it to the list of labels for a menu. + * + * A label ends when we either get to the end of a file, or + * get some input we otherwise don't have a handler defined + * for. + * + */ +static int parse_label(char **c, struct pxe_menu *cfg) +{ + struct token t; + int len; + char *s = *c; + struct pxe_label *label; + int err; + + label = label_create(); + if (!label) + return -ENOMEM; + + err = parse_sliteral(c, &label->name); + if (err < 0) { + printf("Expected label name: %.*s\n", (int)(*c - s), s); + label_destroy(label); + return -EINVAL; + } + + list_add_tail(&label->list, &cfg->labels); + + while (1) { + s = *c; + get_token(c, &t, L_KEYWORD); + + err = 0; + switch (t.type) { + case T_MENU: + err = parse_label_menu(c, cfg, label); + break; + + case T_KERNEL: + case T_LINUX: + err = parse_label_kernel(c, label); + break; + + case T_APPEND: + err = parse_sliteral(c, &label->append); + if (label->initrd) + break; + s = strstr(label->append, "initrd="); + if (!s) + break; + s += 7; + len = (int)(strchr(s, ' ') - s); + label->initrd = malloc(len + 1); + strncpy(label->initrd, s, len); + label->initrd[len] = '\0'; + + break; + + case T_INITRD: + if (!label->initrd) + err = parse_sliteral(c, &label->initrd); + break; + + case T_FDT: + if (!label->fdt) + err = parse_sliteral(c, &label->fdt); + break; + + case T_FDTDIR: + if (!label->fdtdir) + err = parse_sliteral(c, &label->fdtdir); + break; + + case T_LOCALBOOT: + label->localboot = 1; + err = parse_integer(c, &label->localboot_val); + break; + + case T_IPAPPEND: + err = parse_integer(c, &label->ipappend); + break; + + case T_EOL: + break; + + default: + /* + * put the token back! we don't want it - it's the end + * of a label and whatever token this is, it's + * something for the menu level context to handle. + */ + *c = s; + return 1; + } + + if (err < 0) + return err; + } +} + +/* + * This 16 comes from the limit pxelinux imposes on nested includes. + * + * There is no reason at all we couldn't do more, but some limit helps prevent + * infinite (until crash occurs) recursion if a file tries to include itself. + */ +#define MAX_NEST_LEVEL 16 + +/* + * Entry point for parsing a menu file. nest_level indicates how many times + * we've nested in includes. It will be 1 for the top level menu file. + * + * Returns 1 on success, < 0 on error. + */ +static int parse_pxefile_top(cmd_tbl_t *cmdtp, char *p, unsigned long base, + struct pxe_menu *cfg, int nest_level) +{ + struct token t; + char *s, *b, *label_name; + int err; + + b = p; + + if (nest_level > MAX_NEST_LEVEL) { + printf("Maximum nesting (%d) exceeded\n", MAX_NEST_LEVEL); + return -EMLINK; + } + + while (1) { + s = p; + + get_token(&p, &t, L_KEYWORD); + + err = 0; + switch (t.type) { + case T_MENU: + cfg->prompt = 1; + err = parse_menu(cmdtp, &p, cfg, + base + ALIGN(strlen(b) + 1, 4), + nest_level); + break; + + case T_TIMEOUT: + err = parse_integer(&p, &cfg->timeout); + break; + + case T_LABEL: + err = parse_label(&p, cfg); + break; + + case T_DEFAULT: + case T_ONTIMEOUT: + err = parse_sliteral(&p, &label_name); + + if (label_name) { + if (cfg->default_label) + free(cfg->default_label); + + cfg->default_label = label_name; + } + + break; + + case T_INCLUDE: + err = handle_include(cmdtp, &p, + base + ALIGN(strlen(b), 4), cfg, + nest_level + 1); + break; + + case T_PROMPT: + eol_or_eof(&p); + break; + + case T_EOL: + break; + + case T_EOF: + return 1; + + default: + printf("Ignoring unknown command: %.*s\n", + (int)(p - s), s); + eol_or_eof(&p); + } + + if (err < 0) + return err; + } +} + +/* + * Free the memory used by a pxe_menu and its labels. + */ +void destroy_pxe_menu(struct pxe_menu *cfg) +{ + struct list_head *pos, *n; + struct pxe_label *label; + + if (cfg->title) + free(cfg->title); + + if (cfg->default_label) + free(cfg->default_label); + + list_for_each_safe(pos, n, &cfg->labels) { + label = list_entry(pos, struct pxe_label, list); + + label_destroy(label); + } + + free(cfg); +} + +/* + * Entry point for parsing a pxe file. This is only used for the top level + * file. + * + * Returns NULL if there is an error, otherwise, returns a pointer to a + * pxe_menu struct populated with the results of parsing the pxe file (and any + * files it includes). The resulting pxe_menu struct can be free()'d by using + * the destroy_pxe_menu() function. + */ +struct pxe_menu *parse_pxefile(cmd_tbl_t *cmdtp, unsigned long menucfg) +{ + struct pxe_menu *cfg; + char *buf; + int r; + + cfg = malloc(sizeof(struct pxe_menu)); + + if (!cfg) + return NULL; + + memset(cfg, 0, sizeof(struct pxe_menu)); + + INIT_LIST_HEAD(&cfg->labels); + + buf = map_sysmem(menucfg, 0); + r = parse_pxefile_top(cmdtp, buf, menucfg, cfg, 1); + unmap_sysmem(buf); + + if (r < 0) { + destroy_pxe_menu(cfg); + return NULL; + } + + return cfg; +} + +/* + * Converts a pxe_menu struct into a menu struct for use with U-Boot's generic + * menu code. + */ +static struct menu *pxe_menu_to_menu(struct pxe_menu *cfg) +{ + struct pxe_label *label; + struct list_head *pos; + struct menu *m; + int err; + int i = 1; + char *default_num = NULL; + + /* + * Create a menu and add items for all the labels. + */ + m = menu_create(cfg->title, DIV_ROUND_UP(cfg->timeout, 10), + cfg->prompt, label_print, NULL, NULL); + + if (!m) + return NULL; + + list_for_each(pos, &cfg->labels) { + label = list_entry(pos, struct pxe_label, list); + + sprintf(label->num, "%d", i++); + if (menu_item_add(m, label->num, label) != 1) { + menu_destroy(m); + return NULL; + } + if (cfg->default_label && + (strcmp(label->name, cfg->default_label) == 0)) + default_num = label->num; + } + + /* + * After we've created items for each label in the menu, set the + * menu's default label if one was specified. + */ + if (default_num) { + err = menu_default_set(m, default_num); + if (err != 1) { + if (err != -ENOENT) { + menu_destroy(m); + return NULL; + } + + printf("Missing default: %s\n", cfg->default_label); + } + } + + return m; +} + +/* + * Try to boot any labels we have yet to attempt to boot. + */ +static void boot_unattempted_labels(cmd_tbl_t *cmdtp, struct pxe_menu *cfg) +{ + struct list_head *pos; + struct pxe_label *label; + + list_for_each(pos, &cfg->labels) { + label = list_entry(pos, struct pxe_label, list); + + if (!label->attempted) + label_boot(cmdtp, label); + } +} + +/* + * Boot the system as prescribed by a pxe_menu. + * + * Use the menu system to either get the user's choice or the default, based + * on config or user input. If there is no default or user's choice, + * attempted to boot labels in the order they were given in pxe files. + * If the default or user's choice fails to boot, attempt to boot other + * labels in the order they were given in pxe files. + * + * If this function returns, there weren't any labels that successfully + * booted, or the user interrupted the menu selection via ctrl+c. + */ +void handle_pxe_menu(cmd_tbl_t *cmdtp, struct pxe_menu *cfg) +{ + void *choice; + struct menu *m; + int err; + +#ifdef CONFIG_CMD_BMP + /* display BMP if available */ + if (cfg->bmp) { + if (get_relfile(cmdtp, cfg->bmp, load_addr)) { + run_command("cls", 0); + bmp_display(load_addr, + BMP_ALIGN_CENTER, BMP_ALIGN_CENTER); + } else { + printf("Skipping background bmp %s for failure\n", + cfg->bmp); + } + } +#endif + + m = pxe_menu_to_menu(cfg); + if (!m) + return; + + err = menu_get_choice(m, &choice); + + menu_destroy(m); + + /* + * err == 1 means we got a choice back from menu_get_choice. + * + * err == -ENOENT if the menu was setup to select the default but no + * default was set. in that case, we should continue trying to boot + * labels that haven't been attempted yet. + * + * otherwise, the user interrupted or there was some other error and + * we give up. + */ + + if (err == 1) { + err = label_boot(cmdtp, choice); + if (!err) + return; + } else if (err != -ENOENT) { + return; + } + + boot_unattempted_labels(cmdtp, cfg); +} diff --git a/cmd/pxe_utils.h b/cmd/pxe_utils.h new file mode 100644 index 0000000000..10be494c65 --- /dev/null +++ b/cmd/pxe_utils.h @@ -0,0 +1,43 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ + +#ifndef __PXE_UTILS_H +#define __PXE_UTILS_H + +/* + * Describes a pxe menu as given via pxe files. + * + * title - the name of the menu as given by a 'menu title' line. + * default_label - the name of the default label, if any. + * bmp - the bmp file name which is displayed in background + * timeout - time in tenths of a second to wait for a user key-press before + * booting the default label. + * prompt - if 0, don't prompt for a choice unless the timeout period is + * interrupted. If 1, always prompt for a choice regardless of + * timeout. + * labels - a list of labels defined for the menu. + */ +struct pxe_menu { + char *title; + char *default_label; + char *bmp; + int timeout; + int prompt; + struct list_head labels; +}; + +extern bool is_pxe; + +extern int (*do_getfile)(cmd_tbl_t *cmdtp, const char *file_path, + char *file_addr); +void destroy_pxe_menu(struct pxe_menu *cfg); +int get_pxe_file(cmd_tbl_t *cmdtp, const char *file_path, + unsigned long file_addr); +int get_pxelinux_path(cmd_tbl_t *cmdtp, const char *file, + unsigned long pxefile_addr_r); +void handle_pxe_menu(cmd_tbl_t *cmdtp, struct pxe_menu *cfg); +struct pxe_menu *parse_pxefile(cmd_tbl_t *cmdtp, unsigned long menucfg); +int pxe_ipaddr_paths(cmd_tbl_t *cmdtp, unsigned long pxefile_addr_r); +int pxe_mac_path(cmd_tbl_t *cmdtp, unsigned long pxefile_addr_r); +int pxe_uuid_path(cmd_tbl_t *cmdtp, unsigned long pxefile_addr_r); + +#endif /* __PXE_UTILS_H */ diff --git a/cmd/sysboot.c b/cmd/sysboot.c new file mode 100644 index 0000000000..793d67d2f5 --- /dev/null +++ b/cmd/sysboot.c @@ -0,0 +1,134 @@ +// SPDX-License-Identifier: GPL-2.0+ + +#include <common.h> +#include <command.h> +#include <env.h> +#include <fs.h> +#include "pxe_utils.h" + +static char *fs_argv[5]; + +static int do_get_ext2(cmd_tbl_t *cmdtp, const char *file_path, char *file_addr) +{ +#ifdef CONFIG_CMD_EXT2 + fs_argv[0] = "ext2load"; + fs_argv[3] = file_addr; + fs_argv[4] = (void *)file_path; + + if (!do_ext2load(cmdtp, 0, 5, fs_argv)) + return 1; +#endif + return -ENOENT; +} + +static int do_get_fat(cmd_tbl_t *cmdtp, const char *file_path, char *file_addr) +{ +#ifdef CONFIG_CMD_FAT + fs_argv[0] = "fatload"; + fs_argv[3] = file_addr; + fs_argv[4] = (void *)file_path; + + if (!do_fat_fsload(cmdtp, 0, 5, fs_argv)) + return 1; +#endif + return -ENOENT; +} + +static int do_get_any(cmd_tbl_t *cmdtp, const char *file_path, char *file_addr) +{ +#ifdef CONFIG_CMD_FS_GENERIC + fs_argv[0] = "load"; + fs_argv[3] = file_addr; + fs_argv[4] = (void *)file_path; + + if (!do_load(cmdtp, 0, 5, fs_argv, FS_TYPE_ANY)) + return 1; +#endif + return -ENOENT; +} + +/* + * Boots a system using a local disk syslinux/extlinux file + * + * Returns 0 on success, 1 on error. + */ +static int do_sysboot(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) +{ + unsigned long pxefile_addr_r; + struct pxe_menu *cfg; + char *pxefile_addr_str; + char *filename; + int prompt = 0; + + is_pxe = false; + + if (argc > 1 && strstr(argv[1], "-p")) { + prompt = 1; + argc--; + argv++; + } + + if (argc < 4) + return cmd_usage(cmdtp); + + if (argc < 5) { + pxefile_addr_str = from_env("pxefile_addr_r"); + if (!pxefile_addr_str) + return 1; + } else { + pxefile_addr_str = argv[4]; + } + + if (argc < 6) { + filename = env_get("bootfile"); + } else { + filename = argv[5]; + env_set("bootfile", filename); + } + + if (strstr(argv[3], "ext2")) { + do_getfile = do_get_ext2; + } else if (strstr(argv[3], "fat")) { + do_getfile = do_get_fat; + } else if (strstr(argv[3], "any")) { + do_getfile = do_get_any; + } else { + printf("Invalid filesystem: %s\n", argv[3]); + return 1; + } + fs_argv[1] = argv[1]; + fs_argv[2] = argv[2]; + + if (strict_strtoul(pxefile_addr_str, 16, &pxefile_addr_r) < 0) { + printf("Invalid pxefile address: %s\n", pxefile_addr_str); + return 1; + } + + if (get_pxe_file(cmdtp, filename, pxefile_addr_r) < 0) { + printf("Error reading config file\n"); + return 1; + } + + cfg = parse_pxefile(cmdtp, pxefile_addr_r); + + if (!cfg) { + printf("Error parsing config file\n"); + return 1; + } + + if (prompt) + cfg->prompt = 1; + + handle_pxe_menu(cmdtp, cfg); + + destroy_pxe_menu(cfg); + + return 0; +} + +U_BOOT_CMD(sysboot, 7, 1, do_sysboot, + "command to get and boot from syslinux files", + "[-p] <interface> <dev[:part]> <ext2|fat|any> [addr] [filename]\n" + " - load and parse syslinux menu file 'filename' from ext2, fat\n" + " or any filesystem on 'dev' on 'interface' to address 'addr'" +); diff --git a/include/env.h b/include/env.h index b72239f6a5..d6c2d751d6 100644 --- a/include/env.h +++ b/include/env.h @@ -113,6 +113,16 @@ int env_match(unsigned char *name, int index); */ char *env_get(const char *varname);
+/* + * Like env_get, but prints an error if envvar isn't defined in the + * environment. It always returns what env_get does, so it can be used in + * place of env_get without changing error handling otherwise. + * + * @varname: Variable to look up + * @return value of variable, or NULL if not found + */ +char *from_env(const char *envvar); + /** * env_get_f() - Look up the value of an environment variable (early) *
Hi Joe,
Just a gentle reminder to insure this patch will be reviewed and if possible merged for v2020.01 release.
Without this patch, all STM32 MCU boards without NET support can't use sysboot command to load linux image.
Thanks
Patrice
On 10/30/19 9:04 AM, Patrice Chotard wrote:
It allows to use sysboot command on board which have no NET support.
Currently, sysboot command can't be used if CMD_NET and NET flags are not set, while sysboot allows to load extlinux.conf file from local filesystem, so it doesn't need to depend of CMD_NET and NET flags.
Extract sysboot command's code outside pxe.c and create a new sysboot.c file. As sysboot and pxe commands are sharing piece of code, put this common code into a new file pxe_utils.c.
Take the opportunity to move from_env() from pxe.c to nvedit.c. Fix some checkpatch issues.
Signed-off-by: Patrice Chotard patrice.chotard@st.com
Changes in v2: - split out sysboot code from pxe.c file and create a sysboot.c file
Kconfig | 1 + cmd/Kconfig | 6 + cmd/Makefile | 3 +- cmd/nvedit.c | 17 + cmd/pxe.c | 1719 ++--------------------------------------------- cmd/pxe_utils.c | 1463 ++++++++++++++++++++++++++++++++++++++++ cmd/pxe_utils.h | 43 ++ cmd/sysboot.c | 134 ++++ include/env.h | 10 + 9 files changed, 1724 insertions(+), 1672 deletions(-) create mode 100644 cmd/pxe_utils.c create mode 100644 cmd/pxe_utils.h create mode 100644 cmd/sysboot.c
diff --git a/Kconfig b/Kconfig index 66b059f749..98cf53ec78 100644 --- a/Kconfig +++ b/Kconfig @@ -88,6 +88,7 @@ config DISTRO_DEFAULTS select CMD_PART if PARTITIONS select CMD_PING if CMD_NET select CMD_PXE if NET
- select CMD_SYSBOOT select ENV_VARS_UBOOT_CONFIG select HUSH_PARSER select SUPPORT_RAW_INITRD
diff --git a/cmd/Kconfig b/cmd/Kconfig index 82b5d300d2..492d7396f6 100644 --- a/cmd/Kconfig +++ b/cmd/Kconfig @@ -1665,6 +1665,12 @@ config CMD_SOUND sound init - set up sound system sound play - play a sound
+config CMD_SYSBOOT
- bool "sysboot"
- select MENU
- help
Boot image via local extlinux.conf file
config CMD_QFW bool "qfw" select QFW diff --git a/cmd/Makefile b/cmd/Makefile index 2d723ea0f0..b55f936cf0 100644 --- a/cmd/Makefile +++ b/cmd/Makefile @@ -108,7 +108,7 @@ ifdef CONFIG_PCI obj-$(CONFIG_CMD_PCI) += pci.o endif obj-$(CONFIG_CMD_PINMUX) += pinmux.o -obj-$(CONFIG_CMD_PXE) += pxe.o +obj-$(CONFIG_CMD_PXE) += pxe.o pxe_utils.o obj-$(CONFIG_CMD_WOL) += wol.o obj-$(CONFIG_CMD_QFW) += qfw.o obj-$(CONFIG_CMD_READ) += read.o @@ -163,6 +163,7 @@ obj-$(CONFIG_CMD_DFU) += dfu.o obj-$(CONFIG_CMD_GPT) += gpt.o obj-$(CONFIG_CMD_ETHSW) += ethsw.o obj-$(CONFIG_CMD_AXI) += axi.o +obj-$(CONFIG_CMD_SYSBOOT) += sysboot.o pxe_utils.o
# Power obj-$(CONFIG_CMD_PMIC) += pmic.o diff --git a/cmd/nvedit.c b/cmd/nvedit.c index 1cb0bc1460..68b293a6f3 100644 --- a/cmd/nvedit.c +++ b/cmd/nvedit.c @@ -680,6 +680,23 @@ char *env_get(const char *name) return NULL; }
- Like env_get, but prints an error if envvar isn't defined in the
- environment. It always returns what env_get does, so it can be used in
- place of env_get without changing error handling otherwise.
+char *from_env(const char *envvar) +{
- char *ret;
- ret = env_get(envvar);
- if (!ret)
printf("missing environment variable: %s\n", envvar);
- return ret;
- Look up variable from environment for restricted C runtime env.
*/ diff --git a/cmd/pxe.c b/cmd/pxe.c index 2059975446..2dfdc60566 100644 --- a/cmd/pxe.c +++ b/cmd/pxe.c @@ -6,22 +6,9 @@
#include <common.h> #include <command.h> -#include <env.h> -#include <malloc.h> -#include <mapmem.h> -#include <lcd.h> -#include <linux/string.h> -#include <linux/ctype.h> -#include <errno.h> -#include <linux/list.h> -#include <fs.h> -#include <splash.h> -#include <asm/io.h> +#include "pxe_utils.h"
-#include "menu.h" -#include "cli.h"
-#define MAX_TFTP_PATH_LEN 127 +#ifdef CONFIG_CMD_NET
const char *pxe_default_paths[] = { #ifdef CONFIG_SYS_SOC @@ -35,102 +22,6 @@ const char *pxe_default_paths[] = { NULL };
-static bool is_pxe;
-static char *from_env(const char *envvar) -{
- char *ret;
- if (!ret)
- return ret;
- Convert an ethaddr from the environment to the format used by pxelinux
- filenames based on mac addresses. Convert's ':' to '-', and adds "01-" to
- the beginning of the ethernet address to indicate a hardware type of
- Ethernet. Also converts uppercase hex characters into lowercase, to match
- pxelinux's behavior.
- Returns 1 for success, -ENOENT if 'ethaddr' is undefined in the
- environment, or some other value < 0 on error.
-static int format_mac_pxe(char *outbuf, size_t outbuf_len) -{
- uchar ethaddr[6];
- if (outbuf_len < 21) {
return -EINVAL;
- if (!eth_env_get_enetaddr_by_index("eth", eth_get_dev_index(), ethaddr))
return -ENOENT;
- sprintf(outbuf, "01-%02x-%02x-%02x-%02x-%02x-%02x",
- return 1;
-} -#endif
- Returns the directory the file specified in the bootfile env variable is
- in. If bootfile isn't defined in the environment, return NULL, which should
- be interpreted as "don't prepend anything to paths".
-static int get_bootfile_path(const char *file_path, char *bootfile_path,
- char *bootfile, *last_slash;
- size_t path_len = 0;
- /* Only syslinux allows absolute paths */
- if (file_path[0] == '/' && !is_pxe)
goto ret;
- bootfile = from_env("bootfile");
- if (!bootfile)
goto ret;
- last_slash = strrchr(bootfile, '/');
- if (last_slash == NULL)
goto ret;
- path_len = (last_slash - bootfile) + 1;
- if (bootfile_path_size < path_len) {
return -1;
- strncpy(bootfile_path, bootfile, path_len);
- ret:
- bootfile_path[path_len] = '\0';
- return 1;
-static int (*do_getfile)(cmd_tbl_t *cmdtp, const char *file_path, char *file_addr);
-#ifdef CONFIG_CMD_NET static int do_get_tftp(cmd_tbl_t *cmdtp, const char *file_path, char *file_addr) { char *tftp_argv[] = {"tftp", NULL, NULL, NULL}; @@ -143,218 +34,6 @@ static int do_get_tftp(cmd_tbl_t *cmdtp, const char *file_path, char *file_addr)
return 1; } -#endif
-static char *fs_argv[5];
-static int do_get_ext2(cmd_tbl_t *cmdtp, const char *file_path, char *file_addr) -{ -#ifdef CONFIG_CMD_EXT2
- fs_argv[0] = "ext2load";
- fs_argv[3] = file_addr;
- fs_argv[4] = (void *)file_path;
- if (!do_ext2load(cmdtp, 0, 5, fs_argv))
return 1;
-#endif
- return -ENOENT;
-static int do_get_fat(cmd_tbl_t *cmdtp, const char *file_path, char *file_addr) -{ -#ifdef CONFIG_CMD_FAT
- fs_argv[0] = "fatload";
- if (!do_fat_fsload(cmdtp, 0, 5, fs_argv))
return 1;
-#endif
- return -ENOENT;
-static int do_get_any(cmd_tbl_t *cmdtp, const char *file_path, char *file_addr) -{ -#ifdef CONFIG_CMD_FS_GENERIC
- fs_argv[0] = "load";
- if (!do_load(cmdtp, 0, 5, fs_argv, FS_TYPE_ANY))
return 1;
-#endif
- return -ENOENT;
- As in pxelinux, paths to files referenced from files we retrieve are
- relative to the location of bootfile. get_relfile takes such a path and
- joins it with the bootfile path to get the full path to the target file. If
- the bootfile path is NULL, we use file_path as is.
- Returns 1 for success, or < 0 on error.
-static int get_relfile(cmd_tbl_t *cmdtp, const char *file_path,
- unsigned long file_addr)
- size_t path_len;
- char relfile[MAX_TFTP_PATH_LEN+1];
- char addr_buf[18];
- int err;
- err = get_bootfile_path(file_path, relfile, sizeof(relfile));
- if (err < 0)
return err;
- path_len = strlen(file_path);
- path_len += strlen(relfile);
- if (path_len > MAX_TFTP_PATH_LEN) {
relfile,
file_path);
- strcat(relfile, file_path);
- printf("Retrieving file: %s\n", relfile);
- sprintf(addr_buf, "%lx", file_addr);
- return do_getfile(cmdtp, relfile, addr_buf);
- Retrieve the file at 'file_path' to the locate given by 'file_addr'. If
- 'bootfile' was specified in the environment, the path to bootfile will be
- prepended to 'file_path' and the resulting path will be used.
- Returns 1 on success, or < 0 for error.
-static int get_pxe_file(cmd_tbl_t *cmdtp, const char *file_path,
- unsigned long config_file_size;
- char *tftp_filesize;
- int err;
- char *buf;
- err = get_relfile(cmdtp, file_path, file_addr);
- if (err < 0)
return err;
- tftp_filesize = from_env("filesize");
- if (!tftp_filesize)
return -ENOENT;
- if (strict_strtoul(tftp_filesize, 16, &config_file_size) < 0)
return -EINVAL;
- buf = map_sysmem(file_addr + config_file_size, 1);
- *buf = '\0';
- return 1;
-#define PXELINUX_DIR "pxelinux.cfg/"
- Retrieves a file in the 'pxelinux.cfg' folder. Since this uses get_pxe_file
- to do the hard work, the location of the 'pxelinux.cfg' folder is generated
- from the bootfile path, as described above.
- Returns 1 on success or < 0 on error.
-static int get_pxelinux_path(cmd_tbl_t *cmdtp, const char *file,
- unsigned long pxefile_addr_r)
- size_t base_len = strlen(PXELINUX_DIR);
- char path[MAX_TFTP_PATH_LEN+1];
- if (base_len + strlen(file) > MAX_TFTP_PATH_LEN) {
- sprintf(path, PXELINUX_DIR "%s", file);
- return get_pxe_file(cmdtp, path, pxefile_addr_r);
- Looks for a pxe file with a name based on the pxeuuid environment variable.
-static int pxe_uuid_path(cmd_tbl_t *cmdtp, unsigned long pxefile_addr_r) -{
- char *uuid_str;
- uuid_str = from_env("pxeuuid");
- if (!uuid_str)
return -ENOENT;
- return get_pxelinux_path(cmdtp, uuid_str, pxefile_addr_r);
- Looks for a pxe file with a name based on the 'ethaddr' environment
- variable.
-static int pxe_mac_path(cmd_tbl_t *cmdtp, unsigned long pxefile_addr_r) -{
- char mac_str[21];
- int err;
- err = format_mac_pxe(mac_str, sizeof(mac_str));
- if (err < 0)
return err;
- return get_pxelinux_path(cmdtp, mac_str, pxefile_addr_r);
- Looks for pxe files with names based on our IP address. See pxelinux
- documentation for details on what these file names look like. We match
- that exactly.
-static int pxe_ipaddr_paths(cmd_tbl_t *cmdtp, unsigned long pxefile_addr_r) -{
- char ip_addr[9];
- int mask_pos, err;
- sprintf(ip_addr, "%08X", ntohl(net_ip.s_addr));
- for (mask_pos = 7; mask_pos >= 0; mask_pos--) {
if (err > 0)
return err;
- return -ENOENT;
- Entry point for the 'pxe get' command.
@@ -417,1292 +96,77 @@ do_pxe_get(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[])
return 1; } -#endif
- Wrapper to make it easier to store the file at file_path in the location
- specified by envaddr_name. file_path will be joined to the bootfile path,
- if any is specified.
-static int get_relfile_envaddr(cmd_tbl_t *cmdtp, const char *file_path, const char *envaddr_name) -{
- unsigned long file_addr;
- char *envaddr;
- envaddr = from_env(envaddr_name);
- if (!envaddr)
return -ENOENT;
- if (strict_strtoul(envaddr, 16, &file_addr) < 0)
return -EINVAL;
- return get_relfile(cmdtp, file_path, file_addr);
- A note on the pxe file parser.
- We're parsing files that use syslinux grammar, which has a few quirks.
- String literals must be recognized based on context - there is no
- quoting or escaping support. There's also nothing to explicitly indicate
- when a label section completes. We deal with that by ending a label
- section whenever we see a line that doesn't include.
- As with the syslinux family, this same file format could be reused in the
- future for non pxe purposes. The only action it takes during parsing that
- would throw this off is handling of include files. It assumes we're using
- pxe, and does a tftp download of a file listed as an include file in the
- middle of the parsing operation. That could be handled by refactoring it to
- take a 'include file getter' function.
- Describes a single label given in a pxe file.
- Create these with the 'label_create' function given below.
- name - the name of the menu as given on the 'menu label' line.
- kernel - the path to the kernel file to use for this label.
- append - kernel command line to use when booting this label
- initrd - path to the initrd to use for this label.
- attempted - 0 if we haven't tried to boot this label, 1 if we have.
- localboot - 1 if this label specified 'localboot', 0 otherwise.
- list - lets these form a list, which a pxe_menu struct will hold.
-struct pxe_label {
- char num[4];
- char *name;
- char *menu;
- char *kernel;
- char *config;
- char *append;
- char *initrd;
- char *fdt;
- char *fdtdir;
- int ipappend;
- int attempted;
- int localboot;
- int localboot_val;
- struct list_head list;
- Describes a pxe menu as given via pxe files.
- title - the name of the menu as given by a 'menu title' line.
- default_label - the name of the default label, if any.
- bmp - the bmp file name which is displayed in background
- timeout - time in tenths of a second to wait for a user key-press before
- prompt - if 0, don't prompt for a choice unless the timeout period is
timeout.
- labels - a list of labels defined for the menu.
-struct pxe_menu {
- char *title;
- char *default_label;
- char *bmp;
- int timeout;
- int prompt;
- struct list_head labels;
- Allocates memory for and initializes a pxe_label. This uses malloc, so the
- result must be free()'d to reclaim the memory.
- Boots a system using a pxe file
- Returns NULL if malloc fails.
- Returns 0 on success, 1 on error.
-static struct pxe_label *label_create(void) +static int +do_pxe_boot(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) {
- label = malloc(sizeof(struct pxe_label));
- if (!label)
return NULL;
- memset(label, 0, sizeof(struct pxe_label));
- return label;
- if (argc == 1) {
return 1;
- Free the memory used by a pxe_label, including that used by its name,
- kernel, append and initrd members, if they're non NULL.
- So - be sure to only use dynamically allocated memory for the members of
- the pxe_label struct, unless you want to clean it up first. These are
- currently only created by the pxe file parsing code.
-static void label_destroy(struct pxe_label *label) -{
- if (label->name)
free(label->name);
- } else {
- if (label->kernel)
return 1;
- if (label->config)
- if (label->append)
- if (!cfg) {
return 1;
- if (label->initrd)
- if (label->fdt)
free(label->fdt);
- if (label->fdtdir)
- free(label);
- Print a label and its string members if they're defined.
- This is passed as a callback to the menu code for displaying each
- menu entry.
-static void label_print(void *data) -{
- struct pxe_label *label = data;
- const char *c = label->menu ? label->menu : label->name;
- printf("%s:\t%s\n", label->num, c);
-} +static cmd_tbl_t cmd_pxe_sub[] = {
- Boot a label that specified 'localboot'. This requires that the 'localcmd'
- environment variable is defined. Its contents will be executed as U-Boot
- command. If the label specified an 'append' line, its contents will be
- used to overwrite the contents of the 'bootargs' environment variable prior
- to running 'localcmd'.
-static int label_localboot(struct pxe_label *label) +static int do_pxe(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) {
- char *localcmd;
- cmd_tbl_t *cp;
- localcmd = from_env("localcmd");
- if (argc < 2)
- if (!localcmd)
return -ENOENT;
- is_pxe = true;
- if (label->append) {
- argc--;
- argv++;
- debug("running: %s\n", localcmd);
- if (cp)
- return run_command_list(localcmd, strlen(localcmd), 0);
- Boot according to the contents of a pxe_label.
- If we can't boot for any reason, we return. A successful boot never
- returns.
- The kernel will be stored in the location given by the 'kernel_addr_r'
- environment variable.
- If the label specifies an initrd file, it will be stored in the location
- given by the 'ramdisk_addr_r' environment variable.
- If the label specifies an 'append' line, its contents will overwrite that
- of the 'bootargs' environment variable.
-static int label_boot(cmd_tbl_t *cmdtp, struct pxe_label *label) -{
- char *bootm_argv[] = { "bootm", NULL, NULL, NULL, NULL };
- char initrd_str[28];
- char mac_str[29] = "";
- char ip_str[68] = "";
- char *fit_addr = NULL;
- int bootm_argc = 2;
- int len = 0;
- ulong kernel_addr;
- void *buf;
- label_print(label);
- label->attempted = 1;
- if (label->localboot) {
- if (label->kernel == NULL) {
label->name);
return 1;
- if (label->initrd) {
label->name);
return 1;
- if (get_relfile_envaddr(cmdtp, label->kernel, "kernel_addr_r") < 0) {
label->name);
return 1;
- if (label->ipappend & 0x1) {
- if (label->ipappend & 0x2) {
int err;
if (err < 0)
mac_str[0] = '\0';
-#endif
- if ((label->ipappend & 0x3) || label->append) {
sizeof(bootargs));
return 1;
} else {
if (label->append)
sizeof(bootargs));
- bootm_argv[1] = env_get("kernel_addr_r");
- /* for FIT, append the configuration identifier */
- if (label->config) {
if (!fit_addr) {
return 1;
- bootm_argv[3] = env_get("fdt_addr_r");
- /* if fdt label is defined then get fdt from server */
- if (bootm_argv[3]) {
if (label->fdt) {
if (f1) {
f2 = "";
f3 = "";
f4 = "";
} else {
f2 = "-";
f4 = ".dtb";
if (!len)
slash = "./";
slash = "/";
else
slash = "";
strlen(f4) + 1;
if (!fdtfilefree) {
goto cleanup;
if (fdtfile) {
int err = get_relfile_envaddr(cmdtp, fdtfile, "fdt_addr_r");
free(fdtfilefree);
if (err < 0) {
label->name);
goto cleanup;
} else {
- if (!bootm_argv[3])
if (!bootm_argv[2])
bootm_argc = 4;
- kernel_addr = genimg_get_kernel_addr(bootm_argv[1]);
- buf = map_sysmem(kernel_addr, 0);
- /* Try bootm for legacy and FIT format image */
- if (genimg_get_format(buf) != IMAGE_FORMAT_INVALID)
-#ifdef CONFIG_CMD_BOOTI
- /* Try booting an AArch64 Linux kernel image */
- else
-#elif defined(CONFIG_CMD_BOOTZ)
- /* Try booting a Image */
- else
-#endif
- unmap_sysmem(buf);
-cleanup:
- if (fit_addr)
free(fit_addr);
- return 1;
- Tokens for the pxe file parser.
-enum token_type {
- T_EOL,
- T_STRING,
- T_EOF,
- T_MENU,
- T_TITLE,
- T_TIMEOUT,
- T_LABEL,
- T_KERNEL,
- T_LINUX,
- T_APPEND,
- T_INITRD,
- T_LOCALBOOT,
- T_DEFAULT,
- T_PROMPT,
- T_INCLUDE,
- T_FDT,
- T_FDTDIR,
- T_ONTIMEOUT,
- T_IPAPPEND,
- T_BACKGROUND,
- T_INVALID
- A token - given by a value and a type.
-struct token {
- char *val;
- enum token_type type;
- Keywords recognized.
-static const struct token keywords[] = {
- {"menu", T_MENU},
- {"title", T_TITLE},
- {"timeout", T_TIMEOUT},
- {"default", T_DEFAULT},
- {"prompt", T_PROMPT},
- {"label", T_LABEL},
- {"kernel", T_KERNEL},
- {"linux", T_LINUX},
- {"localboot", T_LOCALBOOT},
- {"append", T_APPEND},
- {"initrd", T_INITRD},
- {"include", T_INCLUDE},
- {"devicetree", T_FDT},
- {"fdt", T_FDT},
- {"devicetreedir", T_FDTDIR},
- {"fdtdir", T_FDTDIR},
- {"ontimeout", T_ONTIMEOUT,},
- {"ipappend", T_IPAPPEND,},
- {"background", T_BACKGROUND,},
- {NULL, T_INVALID}
- Since pxe(linux) files don't have a token to identify the start of a
- literal, we have to keep track of when we're in a state where a literal is
- expected vs when we're in a state a keyword is expected.
-enum lex_state {
- L_NORMAL = 0,
- L_KEYWORD,
- L_SLITERAL
- get_string retrieves a string from *p and stores it as a token in
- *t.
- get_string used for scanning both string literals and keywords.
- Characters from *p are copied into t-val until a character equal to
- delim is found, or a NUL byte is reached. If delim has the special value of
- ' ', any whitespace character will be used as a delimiter.
- If lower is unequal to 0, uppercase characters will be converted to
- lowercase in the result. This is useful to make keywords case
- insensitive.
- The location of *p is updated to point to the first character after the end
- of the token - the ending delimiter.
- On success, the new value of t->val is returned. Memory for t->val is
- allocated using malloc and must be free()'d to reclaim it. If insufficient
- memory is available, NULL is returned.
-static char *get_string(char **p, struct token *t, char delim, int lower) -{
- char *b, *e;
- size_t len, i;
- b = e = *p;
- while (*e) {
break;
e++;
- len = e - b;
- t->val = malloc(len + 1);
- if (!t->val)
return NULL;
- for (i = 0; i < len; i++, b++) {
if (lower)
else
t->val[i] = *b;
- t->val[len] = '\0';
- *p = e;
- t->type = T_STRING;
- return t->val;
- Populate a keyword token with a type and value.
-static void get_keyword(struct token *t) -{
- int i;
- for (i = 0; keywords[i].val; i++) {
break;
- Get the next token. We have to keep track of which state we're in to know
- if we're looking to get a string literal or a keyword.
- *p is updated to point at the first character after the current token.
-static void get_token(char **p, struct token *t, enum lex_state state) -{
- char *c = *p;
- t->type = T_INVALID;
- /* eat non EOL whitespace */
- while (isblank(*c))
c++;
- if (*c == '#') {
c++;
- if (*c == '\n') {
t->type = T_EOL;
c++;
- } else if (*c == '\0') {
t->type = T_EOF;
c++;
- } else if (state == L_SLITERAL) {
- } else if (state == L_KEYWORD) {
get_keyword(t);
- *p = c;
- Increment *c until we get to the end of the current line, or EOF.
-static void eol_or_eof(char **c) -{
- while (**c && **c != '\n')
(*c)++;
- All of these parse_* functions share some common behavior.
- They finish with *c pointing after the token they parse, and return 1 on
- success, or < 0 on error.
- Parse a string literal and store a pointer it at *dst. String literals
- terminate at the end of the line.
-static int parse_sliteral(char **c, char **dst) -{
- struct token t;
- char *s = *c;
- get_token(c, &t, L_SLITERAL);
- if (t.type != T_STRING) {
return -EINVAL;
- *dst = t.val;
- return 1;
- Parse a base 10 (unsigned) integer and store it at *dst.
-static int parse_integer(char **c, int *dst) -{
- struct token t;
- char *s = *c;
return -EINVAL;
- *dst = simple_strtol(t.val, NULL, 10);
- free(t.val);
- return 1;
-static int parse_pxefile_top(cmd_tbl_t *cmdtp, char *p, unsigned long base,
- struct pxe_menu *cfg, int nest_level);
- Parse an include statement, and retrieve and parse the file it mentions.
- base should point to a location where it's safe to store the file, and
- nest_level should indicate how many nested includes have occurred. For this
- include, nest_level has already been incremented and doesn't need to be
- incremented here.
-static int handle_include(cmd_tbl_t *cmdtp, char **c, unsigned long base,
- char *include_path;
- char *s = *c;
- int err;
- char *buf;
- int ret;
- err = parse_sliteral(c, &include_path);
- if (err < 0) {
(int)(*c - s), s);
return err;
- err = get_pxe_file(cmdtp, include_path, base);
- if (err < 0) {
return err;
- buf = map_sysmem(base, 0);
- ret = parse_pxefile_top(cmdtp, buf, base, cfg, nest_level);
- return ret;
- Parse lines that begin with 'menu'.
- base and nest are provided to handle the 'menu include' case.
- base should point to a location where it's safe to store the included file.
- nest_level should be 1 when parsing the top level pxe file, 2 when parsing
- a file it includes, 3 when parsing a file included by that file, and so on.
-static int parse_menu(cmd_tbl_t *cmdtp, char **c, struct pxe_menu *cfg,
- struct token t;
- char *s = *c;
- int err = 0;
- get_token(c, &t, L_KEYWORD);
- switch (t.type) {
- case T_TITLE:
break;
- case T_INCLUDE:
nest_level + 1);
break;
- case T_BACKGROUND:
break;
- default:
(int)(*c - s), s);
- if (err < 0)
return err;
- eol_or_eof(c);
- return 1;
- Handles parsing a 'menu line' when we're parsing a label.
-static int parse_label_menu(char **c, struct pxe_menu *cfg,
- struct token t;
- char *s;
- s = *c;
- switch (t.type) {
- case T_DEFAULT:
return -ENOMEM;
break;
- case T_LABEL:
break;
- default:
(int)(*c - s), s);
- eol_or_eof(c);
- Handles parsing a 'kernel' label.
- expecting "filename" or "<fit_filename>#cfg"
-static int parse_label_kernel(char **c, struct pxe_label *label) -{
- char *s;
- int err;
- err = parse_sliteral(c, &label->kernel);
- if (err < 0)
return err;
- s = strstr(label->kernel, "#");
- if (!s)
return 1;
- label->config = malloc(strlen(s) + 1);
- if (!label->config)
return -ENOMEM;
- strcpy(label->config, s);
- *s = 0;
- return 1;
- Parses a label and adds it to the list of labels for a menu.
- A label ends when we either get to the end of a file, or
- get some input we otherwise don't have a handler defined
- for.
-static int parse_label(char **c, struct pxe_menu *cfg) -{
- struct token t;
- int len;
- char *s = *c;
- struct pxe_label *label;
- int err;
- label = label_create();
- if (!label)
return -ENOMEM;
- err = parse_sliteral(c, &label->name);
- if (err < 0) {
return -EINVAL;
- list_add_tail(&label->list, &cfg->labels);
- while (1) {
s = *c;
err = 0;
switch (t.type) {
case T_MENU:
break;
case T_KERNEL:
case T_LINUX:
break;
case T_APPEND:
if (label->initrd)
break;
if (!s)
break;
s += 7;
break;
case T_INITRD:
if (!label->initrd)
break;
case T_FDT:
if (!label->fdt)
break;
case T_FDTDIR:
if (!label->fdtdir)
break;
case T_LOCALBOOT:
break;
case T_IPAPPEND:
break;
case T_EOL:
break;
default:
*c = s;
return 1;
if (err < 0)
return err;
- This 16 comes from the limit pxelinux imposes on nested includes.
- There is no reason at all we couldn't do more, but some limit helps prevent
- infinite (until crash occurs) recursion if a file tries to include itself.
-#define MAX_NEST_LEVEL 16
- Entry point for parsing a menu file. nest_level indicates how many times
- we've nested in includes. It will be 1 for the top level menu file.
- Returns 1 on success, < 0 on error.
- struct token t;
- char *s, *b, *label_name;
- int err;
- b = p;
- if (nest_level > MAX_NEST_LEVEL) {
return -EMLINK;
- while (1) {
s = p;
err = 0;
switch (t.type) {
case T_MENU:
cfg->prompt = 1;
nest_level);
break;
case T_TIMEOUT:
break;
case T_LABEL:
break;
case T_DEFAULT:
case T_ONTIMEOUT:
if (label_name) {
break;
case T_INCLUDE:
nest_level + 1);
break;
case T_PROMPT:
eol_or_eof(&p);
break;
case T_EOL:
break;
case T_EOF:
return 1;
default:
(int)(p - s), s);
eol_or_eof(&p);
if (err < 0)
return err;
- Free the memory used by a pxe_menu and its labels.
-static void destroy_pxe_menu(struct pxe_menu *cfg) -{
- struct list_head *pos, *n;
- if (cfg->title)
free(cfg->title);
- if (cfg->default_label)
- list_for_each_safe(pos, n, &cfg->labels) {
- free(cfg);
- Entry point for parsing a pxe file. This is only used for the top level
- file.
- Returns NULL if there is an error, otherwise, returns a pointer to a
- pxe_menu struct populated with the results of parsing the pxe file (and any
- files it includes). The resulting pxe_menu struct can be free()'d by using
- the destroy_pxe_menu() function.
-static struct pxe_menu *parse_pxefile(cmd_tbl_t *cmdtp, unsigned long menucfg) -{
- struct pxe_menu *cfg;
- char *buf;
- int r;
- cfg = malloc(sizeof(struct pxe_menu));
- if (!cfg)
return NULL;
- memset(cfg, 0, sizeof(struct pxe_menu));
- INIT_LIST_HEAD(&cfg->labels);
- buf = map_sysmem(menucfg, 0);
- r = parse_pxefile_top(cmdtp, buf, menucfg, cfg, 1);
- if (r < 0) {
return NULL;
- return cfg;
- Converts a pxe_menu struct into a menu struct for use with U-Boot's generic
- menu code.
-static struct menu *pxe_menu_to_menu(struct pxe_menu *cfg) -{
- struct list_head *pos;
- struct menu *m;
- int err;
- int i = 1;
- char *default_num = NULL;
- m = menu_create(cfg->title, DIV_ROUND_UP(cfg->timeout, 10),
- if (!m)
return NULL;
- list_for_each(pos, &cfg->labels) {
menu_destroy(m);
return NULL;
- if (default_num) {
if (err != 1) {
menu_destroy(m);
return NULL;
- return m;
- Try to boot any labels we have yet to attempt to boot.
-static void boot_unattempted_labels(cmd_tbl_t *cmdtp, struct pxe_menu *cfg) -{
- Boot the system as prescribed by a pxe_menu.
- Use the menu system to either get the user's choice or the default, based
- on config or user input. If there is no default or user's choice,
- attempted to boot labels in the order they were given in pxe files.
- If the default or user's choice fails to boot, attempt to boot other
- labels in the order they were given in pxe files.
- If this function returns, there weren't any labels that successfully
- booted, or the user interrupted the menu selection via ctrl+c.
-static void handle_pxe_menu(cmd_tbl_t *cmdtp, struct pxe_menu *cfg) -{
- void *choice;
- struct menu *m;
- int err;
-#ifdef CONFIG_CMD_BMP
- /* display BMP if available */
- if (cfg->bmp) {
} else {
cfg->bmp);
-#endif
- m = pxe_menu_to_menu(cfg);
- if (!m)
return;
- err = menu_get_choice(m, &choice);
- menu_destroy(m);
* we give up.
- if (err == 1) {
if (!err)
return;
- } else if (err != -ENOENT) {
return;
- boot_unattempted_labels(cmdtp, cfg);
-#ifdef CONFIG_CMD_NET -/*
-static int -do_pxe_boot(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) -{
- unsigned long pxefile_addr_r;
- char *pxefile_addr_str;
- do_getfile = do_get_tftp;
- if (argc == 1) {
return 1;
- } else if (argc == 2) {
pxefile_addr_str = argv[1];
- } else {
return CMD_RET_USAGE;
- if (strict_strtoul(pxefile_addr_str, 16, &pxefile_addr_r) < 0) {
return 1;
- cfg = parse_pxefile(cmdtp, pxefile_addr_r);
- if (cfg == NULL) {
return 1;
- handle_pxe_menu(cmdtp, cfg);
- destroy_pxe_menu(cfg);
- copy_filename(net_boot_file_name, "", sizeof(net_boot_file_name));
-static cmd_tbl_t cmd_pxe_sub[] = {
- U_BOOT_CMD_MKENT(get, 1, 1, do_pxe_get, "", ""),
- U_BOOT_CMD_MKENT(boot, 2, 1, do_pxe_boot, "", "")
-static int do_pxe(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) -{
- cmd_tbl_t *cp;
- if (argc < 2)
- is_pxe = true;
- /* drop initial "pxe" arg */
- argc--;
- argv++;
- cp = find_cmd_tbl(argv[0], cmd_pxe_sub, ARRAY_SIZE(cmd_pxe_sub));
- if (cp)
return cp->cmd(cmdtp, flag, argc, argv);
- return CMD_RET_USAGE;
U_BOOT_CMD( @@ -1712,90 +176,3 @@ U_BOOT_CMD( "boot [pxefile_addr_r] - boot from the pxe file at pxefile_addr_r\n" ); #endif
- Boots a system using a local disk syslinux/extlinux file
-static int do_sysboot(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) -{
- char *filename;
- int prompt = 0;
- is_pxe = false;
- if (argc > 1 && strstr(argv[1], "-p")) {
prompt = 1;
argc--;
argv++;
- if (argc < 4)
- if (argc < 5) {
return 1;
- } else {
- if (argc < 6)
- else {
filename = argv[5];
- if (strstr(argv[3], "ext2"))
- else if (strstr(argv[3], "fat"))
- else if (strstr(argv[3], "any"))
- else {
return 1;
- fs_argv[1] = argv[1];
- fs_argv[2] = argv[2];
return 1;
- if (get_pxe_file(cmdtp, filename, pxefile_addr_r) < 0) {
return 1;
return 1;
- if (prompt)
cfg->prompt = 1;
-U_BOOT_CMD(
- sysboot, 7, 1, do_sysboot,
- "command to get and boot from syslinux files",
- "[-p] <interface> <dev[:part]> <ext2|fat|any> [addr] [filename]\n"
- " - load and parse syslinux menu file 'filename' from ext2, fat\n"
- " or any filesystem on 'dev' on 'interface' to address 'addr'"
-); diff --git a/cmd/pxe_utils.c b/cmd/pxe_utils.c new file mode 100644 index 0000000000..bbc931b208 --- /dev/null +++ b/cmd/pxe_utils.c @@ -0,0 +1,1463 @@ +// SPDX-License-Identifier: GPL-2.0+ +/*
- Copyright 2010-2011 Calxeda, Inc.
- Copyright (c) 2014, NVIDIA CORPORATION. All rights reserved.
+#include <common.h> +#include <command.h> +#include <env.h> +#include <malloc.h> +#include <mapmem.h> +#include <lcd.h> +#include <linux/string.h> +#include <linux/ctype.h> +#include <errno.h> +#include <linux/list.h> +#include <fs.h>
+#include <splash.h> +#include <asm/io.h>
+#include "menu.h" +#include "cli.h" +#include "pxe_utils.h"
+#define MAX_TFTP_PATH_LEN 127
+bool is_pxe;
+int (*do_getfile)(cmd_tbl_t *cmdtp, const char *file_path, char *file_addr);
+static int get_bootfile_path(const char *file_path, char *bootfile_path,
size_t bootfile_path_size)
goto ret;
- if (!bootfile)
goto ret;
- if (!last_slash)
goto ret;
printf("bootfile_path too small. (%zd < %zd)\n",
bootfile_path_size, path_len);
return -1;
- ret:
- return 1;
+static int get_relfile(cmd_tbl_t *cmdtp, const char *file_path,
- size_t path_len;
- char relfile[MAX_TFTP_PATH_LEN + 1];
- int err;
- if (err < 0)
return err;
printf("Base path too long (%s%s)\n", relfile, file_path);
return -ENAMETOOLONG;
- int err;
- char *buf;
- if (err < 0)
return err;
* the file comes without a NUL byte at the end, so find out its size
* and add the NUL byte.
return -ENOENT;
return -EINVAL;
- *buf = '\0';
- return 1;
+#define PXELINUX_DIR "pxelinux.cfg/"
+static int format_mac_pxe(char *outbuf, size_t outbuf_len) +{
- uchar ethaddr[6];
printf("outbuf is too small (%zd < 21)\n", outbuf_len);
return -EINVAL;
return -ENOENT;
ethaddr[0], ethaddr[1], ethaddr[2],
ethaddr[3], ethaddr[4], ethaddr[5]);
- return 1;
- char path[MAX_TFTP_PATH_LEN + 1];
printf("path (%s%s) too long, skipping\n", PXELINUX_DIR, file);
+int pxe_uuid_path(cmd_tbl_t *cmdtp, unsigned long pxefile_addr_r) +{
- char *uuid_str;
- if (!uuid_str)
return -ENOENT;
- variable.
+int pxe_mac_path(cmd_tbl_t *cmdtp, unsigned long pxefile_addr_r) +{
- char mac_str[21];
- int err;
- if (err < 0)
return err;
- that exactly.
+int pxe_ipaddr_paths(cmd_tbl_t *cmdtp, unsigned long pxefile_addr_r) +{
- char ip_addr[9];
err = get_pxelinux_path(cmdtp, ip_addr, pxefile_addr_r);
if (err > 0)
return err;
ip_addr[mask_pos] = '\0';
- return -ENOENT;
+} +#endif
+static int get_relfile_envaddr(cmd_tbl_t *cmdtp, const char *file_path,
- char *envaddr;
- if (!envaddr)
return -ENOENT;
return -EINVAL;
+struct pxe_label {
- char num[4];
- char *name;
- char *menu;
- char *kernel;
- char *config;
- char *append;
- char *initrd;
- char *fdt;
- char *fdtdir;
- int ipappend;
- int attempted;
- int localboot;
+static struct pxe_label *label_create(void) +{
- if (!label)
return NULL;
- return label;
+static void label_destroy(struct pxe_label *label) +{
- if (label->name)
free(label->name);
free(label->kernel);
free(label->config);
free(label->append);
free(label->initrd);
- if (label->fdt)
free(label->fdt);
free(label->fdtdir);
- free(label);
- menu entry.
+static void label_print(void *data) +{
+static int label_localboot(struct pxe_label *label) +{
- char *localcmd;
- if (!localcmd)
return -ENOENT;
char bootargs[CONFIG_SYS_CBSIZE];
cli_simple_process_macros(label->append, bootargs);
env_set("bootargs", bootargs);
- returns.
+static int label_boot(cmd_tbl_t *cmdtp, struct pxe_label *label) +{
- int len = 0;
- void *buf;
if (label->localboot_val >= 0)
label_localboot(label);
- if (!label->kernel) {
printf("No kernel given, skipping %s\n", label->name);
return 1;
if (get_relfile_envaddr(cmdtp, label->initrd, "ramdisk_addr_r") < 0) {
printf("Skipping %s for failure retrieving initrd\n",
label->name);
return 1;
bootm_argv[2] = initrd_str;
strncpy(bootm_argv[2], env_get("ramdisk_addr_r"), 18);
strcat(bootm_argv[2], ":");
strncat(bootm_argv[2], env_get("filesize"), 9);
printf("Skipping %s for failure retrieving kernel\n",
label->name);
return 1;
sprintf(ip_str, " ip=%s:%s:%s:%s",
env_get("ipaddr"), env_get("serverip"),
env_get("gatewayip"), env_get("netmask"));
int err;
if (err < 0)
mac_str[0] = '\0';
sizeof(bootargs));
return 1;
if (label->append)
if (!fit_addr) {
return 1;
if (label->fdt) {
if (f1) {
f2 = "";
f3 = "";
f4 = "";
} else {
f2 = "-";
f4 = ".dtb";
if (!len)
slash = "./";
slash = "/";
else
slash = "";
strlen(f4) + 1;
if (!fdtfilefree) {
goto cleanup;
if (fdtfile) {
"fdt_addr_r");
free(fdtfilefree);
if (err < 0) {
label->name);
goto cleanup;
} else {
if (!bootm_argv[2])
bootm_argc = 4;
- else
- else
+cleanup:
- if (fit_addr)
free(fit_addr);
- return 1;
+enum token_type {
- T_EOL,
- T_STRING,
- T_EOF,
- T_MENU,
- T_TITLE,
- T_TIMEOUT,
- T_LABEL,
- T_KERNEL,
- T_LINUX,
- T_APPEND,
- T_INITRD,
- T_LOCALBOOT,
- T_DEFAULT,
- T_PROMPT,
- T_INCLUDE,
- T_FDT,
- T_FDTDIR,
- T_ONTIMEOUT,
- T_IPAPPEND,
- T_BACKGROUND,
- T_INVALID
+struct token {
- char *val;
- {"menu", T_MENU},
- {"fdt", T_FDT},
- {NULL, T_INVALID}
+enum lex_state {
- L_NORMAL = 0,
- L_KEYWORD,
- L_SLITERAL
- *t.
- insensitive.
- char *b, *e;
- size_t len, i;
- e = *p;
- b = *p;
- while (*e) {
break;
e++;
- len = e - b;
- if (!t->val)
return NULL;
if (lower)
else
t->val[i] = *b;
- *p = e;
- return t->val;
- int i;
break;
- char *c = *p;
c++;
- if (*c == '#') {
c++;
- if (*c == '\n') {
t->type = T_EOL;
c++;
t->type = T_EOF;
c++;
get_keyword(t);
- *p = c;
(*c)++;
- struct token t;
- char *s = *c;
return -EINVAL;
- *dst = t.val;
- return 1;
- struct token t;
- char *s = *c;
return -EINVAL;
- free(t.val);
- return 1;
- incremented here.
- char *s = *c;
- int err;
- char *buf;
- int ret;
- if (err < 0) {
return err;
- if (err < 0) {
return err;
- return ret;
- struct token t;
- char *s = *c;
- int err = 0;
- switch (t.type) {
- case T_TITLE:
break;
- case T_INCLUDE:
nest_level + 1);
break;
break;
- default:
(int)(*c - s), s);
- if (err < 0)
return err;
- eol_or_eof(c);
- return 1;
- struct token t;
- char *s;
- s = *c;
- switch (t.type) {
- case T_DEFAULT:
return -ENOMEM;
break;
- case T_LABEL:
break;
- default:
(int)(*c - s), s);
- eol_or_eof(c);
- char *s;
- int err;
- if (err < 0)
return err;
- if (!s)
return 1;
return -ENOMEM;
- *s = 0;
- return 1;
- for.
- struct token t;
- int len;
- char *s = *c;
- int err;
- if (!label)
return -ENOMEM;
- if (err < 0) {
return -EINVAL;
- while (1) {
s = *c;
err = 0;
switch (t.type) {
case T_MENU:
break;
case T_KERNEL:
case T_LINUX:
break;
case T_APPEND:
if (label->initrd)
break;
if (!s)
break;
s += 7;
break;
case T_INITRD:
if (!label->initrd)
break;
case T_FDT:
if (!label->fdt)
break;
case T_FDTDIR:
if (!label->fdtdir)
break;
case T_LOCALBOOT:
break;
case T_IPAPPEND:
break;
case T_EOL:
break;
default:
*c = s;
return 1;
if (err < 0)
return err;
- struct token t;
- int err;
- b = p;
return -EMLINK;
- while (1) {
s = p;
err = 0;
switch (t.type) {
case T_MENU:
cfg->prompt = 1;
nest_level);
break;
case T_TIMEOUT:
break;
case T_LABEL:
break;
case T_DEFAULT:
case T_ONTIMEOUT:
if (label_name) {
break;
case T_INCLUDE:
nest_level + 1);
break;
case T_PROMPT:
eol_or_eof(&p);
break;
case T_EOL:
break;
case T_EOF:
return 1;
default:
(int)(p - s), s);
eol_or_eof(&p);
if (err < 0)
return err;
- if (cfg->title)
free(cfg->title);
- free(cfg);
- file.
- char *buf;
- int r;
- if (!cfg)
return NULL;
- if (r < 0) {
return NULL;
- return cfg;
- menu code.
- struct menu *m;
- int err;
- int i = 1;
- if (!m)
return NULL;
menu_destroy(m);
return NULL;
if (err != 1) {
menu_destroy(m);
return NULL;
- return m;
- void *choice;
- struct menu *m;
- int err;
- if (cfg->bmp) {
} else {
cfg->bmp);
- if (!m)
return;
- menu_destroy(m);
* we give up.
- if (err == 1) {
if (!err)
return;
return;
timeout.
+struct pxe_menu {
- char *title;
- char *bmp;
- int timeout;
- int prompt;
char *file_addr);
return 1;
- return -ENOENT;
return 1;
- return -ENOENT;
return 1;
- return -ENOENT;
- char *filename;
- int prompt = 0;
- is_pxe = false;
prompt = 1;
argc--;
argv++;
- if (argc < 4)
- if (argc < 5) {
return 1;
- } else {
- if (argc < 6) {
- } else {
filename = argv[5];
- if (strstr(argv[3], "ext2")) {
- } else if (strstr(argv[3], "fat")) {
- } else if (strstr(argv[3], "any")) {
- } else {
return 1;
return 1;
return 1;
- if (!cfg) {
return 1;
- if (prompt)
cfg->prompt = 1;
- @varname: Variable to look up
- @return value of variable, or NULL if not found
- env_get_f() - Look up the value of an environment variable (early)
Hi Patrice,
This is a big patch. Is there a reason it isn't crafted into a more reviewable form? For instance, refactor some functions as needed in the same file so that the actual changes are apparent. Then in a subsequent patch move them to a separate file, then in a subsequent patch make use of them elsewhere. I don't have the bandwidth to deal with obtuse reviews.
Thanks, -Joe
On Wed, Oct 30, 2019 at 3:05 AM Patrice Chotard patrice.chotard@st.com wrote:
+config CMD_SYSBOOT
bool "sysboot"
select MENU
help
Please use a more similar name like env_get_verbose() if you really must print a message.
char *ret;
if (!ret)
return ret;
char *ret;
if (!ret)
return ret;
uchar ethaddr[6];
return -EINVAL;
return -ENOENT;
return 1;
-} -#endif
goto ret;
if (!bootfile)
goto ret;
goto ret;
return -1;
- ret:
return 1;
return 1;
} -#endif
return 1;
-#endif
return -ENOENT;
return 1;
-#endif
return -ENOENT;
return 1;
-#endif
return -ENOENT;
size_t path_len;
char addr_buf[18];
int err;
if (err < 0)
return err;
relfile,
file_path);
int err;
char *buf;
if (err < 0)
return err;
if (!tftp_filesize)
return -ENOENT;
return -EINVAL;
*buf = '\0';
unmap_sysmem(buf);
return 1;
char *uuid_str;
if (!uuid_str)
return -ENOENT;
- variable.
char mac_str[21];
int err;
if (err < 0)
return err;
- that exactly.
char ip_addr[9];
int mask_pos, err;
if (err > 0)
return err;
return -ENOENT;
return 1;
} -#endif
char *envaddr;
if (!envaddr)
return -ENOENT;
return -EINVAL;
-struct pxe_label {
char num[4];
char *name;
char *menu;
char *kernel;
char *config;
char *append;
char *initrd;
char *fdt;
char *fdtdir;
int ipappend;
int attempted;
int localboot;
int localboot_val;
timeout.
-struct pxe_menu {
char *title;
char *bmp;
int timeout;
int prompt;
if (!label)
return NULL;
return label;
if (argc == 1) {
return 1;
if (label->name)
free(label->name);
} else {
if (label->kernel)
return 1;
if (label->config)
if (label->append)
if (!cfg) {
return 1;
if (label->initrd)
if (label->fdt)
free(label->fdt);
if (label->fdtdir)
free(label);
- menu entry.
char *localcmd;
cmd_tbl_t *cp;
if (argc < 2)
if (!localcmd)
return -ENOENT;
is_pxe = true;
argc--;
argv++;
if (cp)
- returns.
int bootm_argc = 2;
int len = 0;
ulong kernel_addr;
void *buf;
label_print(label);
label->name);
return 1;
label->name);
return 1;
label->name);
return 1;
int err;
strcpy(mac_str, " BOOTIF=");
err = format_mac_pxe(mac_str + 8, sizeof(mac_str) - 8);
if (err < 0)
mac_str[0] = '\0';
-#endif
char bootargs[CONFIG_SYS_CBSIZE] = "";
char finalbootargs[CONFIG_SYS_CBSIZE];
if (strlen(label->append ?: "") +
strlen(ip_str) + strlen(mac_str) + 1 > sizeof(bootargs)) {
printf("bootarg overflow %zd+%zd+%zd+1 > %zd\n",
strlen(label->append ?: ""),
strlen(ip_str), strlen(mac_str),
sizeof(bootargs));
return 1;
} else {
if (label->append)
strncpy(bootargs, label->append,
sizeof(bootargs));
strcat(bootargs, ip_str);
strcat(bootargs, mac_str);
cli_simple_process_macros(bootargs, finalbootargs);
env_set("bootargs", finalbootargs);
printf("append: %s\n", finalbootargs);
int len = strlen(bootm_argv[1]) + strlen(label->config) + 1;
fit_addr = malloc(len);
if (!fit_addr) {
printf("malloc fail (FIT address)\n");
return 1;
snprintf(fit_addr, len, "%s%s", bootm_argv[1], label->config);
bootm_argv[1] = fit_addr;
* fdt usage is optional:
* It handles the following scenarios. All scenarios are exclusive
* Scenario 1: If fdt_addr_r specified and "fdt" label is defined in
* pxe file, retrieve fdt blob from server. Pass fdt_addr_r to bootm,
* and adjust argc appropriately.
* Scenario 2: If there is an fdt_addr specified, pass it along to
* bootm, and adjust argc appropriately.
* Scenario 3: fdt blob is not available.
char *fdtfile = NULL;
char *fdtfilefree = NULL;
if (label->fdt) {
fdtfile = label->fdt;
} else if (label->fdtdir) {
char *f1, *f2, *f3, *f4, *slash;
f1 = env_get("fdtfile");
if (f1) {
f2 = "";
f3 = "";
f4 = "";
} else {
* For complex cases where this code doesn't
* generate the correct filename, the board
* code should set $fdtfile during early boot,
* or the boot scripts should set $fdtfile
* before invoking "pxe" or "sysboot".
f1 = env_get("soc");
f2 = "-";
f3 = env_get("board");
f4 = ".dtb";
len = strlen(label->fdtdir);
if (!len)
slash = "./";
else if (label->fdtdir[len - 1] != '/')
slash = "/";
else
slash = "";
len = strlen(label->fdtdir) + strlen(slash) +
strlen(f1) + strlen(f2) + strlen(f3) +
strlen(f4) + 1;
fdtfilefree = malloc(len);
if (!fdtfilefree) {
printf("malloc fail (FDT filename)\n");
goto cleanup;
snprintf(fdtfilefree, len, "%s%s%s%s%s%s",
label->fdtdir, slash, f1, f2, f3, f4);
fdtfile = fdtfilefree;
if (fdtfile) {
free(fdtfilefree);
if (err < 0) {
printf("Skipping %s for failure retrieving fdt\n",
label->name);
goto cleanup;
} else {
bootm_argv[3] = NULL;
if (!bootm_argv[3])
bootm_argv[3] = env_get("fdt_addr");
if (!bootm_argv[2])
bootm_argv[2] = "-";
bootm_argc = 4;
do_bootm(cmdtp, 0, bootm_argc, bootm_argv);
else
do_booti(cmdtp, 0, bootm_argc, bootm_argv);
else
do_bootz(cmdtp, 0, bootm_argc, bootm_argv);
-#endif
unmap_sysmem(buf);
-cleanup:
if (fit_addr)
free(fit_addr);
return 1;
-enum token_type {
T_EOL,
T_STRING,
T_EOF,
T_MENU,
T_TITLE,
T_TIMEOUT,
T_LABEL,
T_KERNEL,
T_LINUX,
T_APPEND,
T_INITRD,
T_LOCALBOOT,
T_DEFAULT,
T_PROMPT,
T_INCLUDE,
T_FDT,
T_FDTDIR,
T_ONTIMEOUT,
T_IPAPPEND,
T_BACKGROUND,
T_INVALID
-struct token {
char *val;
{"menu", T_MENU},
{"title", T_TITLE},
{"label", T_LABEL},
{"linux", T_LINUX},
{"fdt", T_FDT},
{NULL, T_INVALID}
-enum lex_state {
L_NORMAL = 0,
L_KEYWORD,
L_SLITERAL
- *t.
- insensitive.
char *b, *e;
size_t len, i;
* b and e both start at the beginning of the input stream.
* e is incremented until we find the ending delimiter, or a NUL byte
* is reached. Then, we take e - b to find the length of the token.
b = e = *p;
while (*e) {
if ((delim == ' ' && isspace(*e)) || delim == *e)
break;
e++;
len = e - b;
* Allocate memory to hold the string, and copy it in, converting
* characters to lowercase if lower is != 0.
if (!t->val)
return NULL;
if (lower)
t->val[i] = tolower(*b);
else
t->val[i] = *b;
t->val[len] = '\0';
* Update *p so the caller knows where to continue scanning.
*p = e;
t->type = T_STRING;
return t->val;
int i;
if (!strcmp(t->val, keywords[i].val)) {
t->type = keywords[i].type;
break;
char *c = *p;
while (isblank(*c))
c++;
* eat comments. note that string literals can't begin with #, but
* can contain a # after their first character.
if (*c == '#') {
while (*c && *c != '\n')
c++;
if (*c == '\n') {
t->type = T_EOL;
c++;
t->type = T_EOF;
c++;
get_string(&c, t, '\n', 0);
* when we expect a keyword, we first get the next string
* token delimited by whitespace, and then check if it
* matches a keyword in our keyword list. if it does, it's
* converted to a keyword token of the appropriate type, and
* if not, it remains a string token.
get_string(&c, t, ' ', 1);
get_keyword(t);
*p = c;
(*c)++;
struct token t;
char *s = *c;
printf("Expected string literal: %.*s\n", (int)(*c - s), s);
return -EINVAL;
*dst = t.val;
return 1;
struct token t;
char *s = *c;
printf("Expected string: %.*s\n", (int)(*c - s), s);
return -EINVAL;
free(t.val);
return 1;
- incremented here.
char *include_path;
char *s = *c;
int err;
char *buf;
int ret;
if (err < 0) {
printf("Expected include path: %.*s\n",
(int)(*c - s), s);
return err;
if (err < 0) {
printf("Couldn't retrieve %s\n", include_path);
return err;
unmap_sysmem(buf);
return ret;
unsigned long base, int nest_level)
struct token t;
char *s = *c;
int err = 0;
switch (t.type) {
case T_TITLE:
err = parse_sliteral(c, &cfg->title);
break;
case T_INCLUDE:
err = handle_include(cmdtp, c, base, cfg,
nest_level + 1);
break;
case T_BACKGROUND:
err = parse_sliteral(c, &cfg->bmp);
break;
default:
printf("Ignoring malformed menu command: %.*s\n",
(int)(*c - s), s);
if (err < 0)
return err;
eol_or_eof(c);
return 1;
struct token t;
char *s;
s = *c;
switch (t.type) {
case T_DEFAULT:
if (!cfg->default_label)
cfg->default_label = strdup(label->name);
return -ENOMEM;
break;
case T_LABEL:
parse_sliteral(c, &label->menu);
break;
default:
(int)(*c - s), s);
eol_or_eof(c);
char *s;
int err;
if (err < 0)
return err;
if (!s)
return 1;
if (!label->config)
return -ENOMEM;
*s = 0;
return 1;
- for.
struct token t;
int len;
char *s = *c;
int err;
if (!label)
return -ENOMEM;
if (err < 0) {
return -EINVAL;
while (1) {
s = *c;
err = 0;
switch (t.type) {
case T_MENU:
break;
case T_KERNEL:
case T_LINUX:
break;
case T_APPEND:
if (label->initrd)
break;
if (!s)
break;
s += 7;
break;
case T_INITRD:
if (!label->initrd)
break;
case T_FDT:
if (!label->fdt)
break;
case T_FDTDIR:
if (!label->fdtdir)
break;
case T_LOCALBOOT:
break;
case T_IPAPPEND:
break;
case T_EOL:
break;
default:
*c = s;
return 1;
if (err < 0)
return err;
struct token t;
int err;
b = p;
return -EMLINK;
while (1) {
s = p;
err = 0;
switch (t.type) {
case T_MENU:
cfg->prompt = 1;
nest_level);
break;
case T_TIMEOUT:
break;
case T_LABEL:
break;
case T_DEFAULT:
case T_ONTIMEOUT:
if (label_name) {
break;
case T_INCLUDE:
nest_level + 1);
break;
case T_PROMPT:
eol_or_eof(&p);
break;
case T_EOL:
break;
case T_EOF:
return 1;
default:
(int)(p - s), s);
eol_or_eof(&p);
if (err < 0)
return err;
if (cfg->title)
free(cfg->title);
free(cfg);
- file.
char *buf;
int r;
if (!cfg)
return NULL;
unmap_sysmem(buf);
if (r < 0) {
return NULL;
return cfg;
- menu code.
struct menu *m;
int err;
int i = 1;
if (!m)
return NULL;
menu_destroy(m);
return NULL;
if (default_num) {
if (err != 1) {
menu_destroy(m);
return NULL;
return m;
void *choice;
struct menu *m;
int err;
if (cfg->bmp) {
} else {
cfg->bmp);
-#endif
if (!m)
return;
menu_destroy(m);
* we give up.
if (err == 1) {
if (!err)
return;
return;
if (argc == 1) {
return 1;
} else {
return 1;
if (cfg == NULL) {
return 1;
cmd_tbl_t *cp;
if (argc < 2)
is_pxe = true;
argc--;
argv++;
if (cp)
char *filename;
int prompt = 0;
is_pxe = false;
prompt = 1;
argc--;
argv++;
if (argc < 4)
if (argc < 5) {
return 1;
} else {
if (argc < 6)
else {
filename = argv[5];
else {
return 1;
return 1;
return 1;
if (cfg == NULL) {
return 1;
if (prompt)
cfg->prompt = 1;
-U_BOOT_CMD(
+bool is_pxe;
goto ret;
if (!bootfile)
goto ret;
if (!last_slash)
goto ret;
return -1;
- ret:
return 1;
size_t path_len;
char addr_buf[18];
int err;
if (err < 0)
return err;
int err;
char *buf;
if (err < 0)
return err;
if (!tftp_filesize)
return -ENOENT;
return -EINVAL;
*buf = '\0';
unmap_sysmem(buf);
return 1;
uchar ethaddr[6];
return -EINVAL;
return -ENOENT;
return 1;
char *uuid_str;
if (!uuid_str)
return -ENOENT;
- variable.
char mac_str[21];
int err;
if (err < 0)
return err;
- that exactly.
char ip_addr[9];
int mask_pos, err;
if (err > 0)
return err;
return -ENOENT;
+} +#endif
char *envaddr;
if (!envaddr)
return -ENOENT;
return -EINVAL;
+struct pxe_label {
char num[4];
char *name;
char *menu;
char *kernel;
char *config;
char *append;
char *initrd;
char *fdt;
char *fdtdir;
int ipappend;
int attempted;
int localboot;
int localboot_val;
if (!label)
return NULL;
return label;
if (label->name)
free(label->name);
if (label->kernel)
if (label->config)
if (label->append)
if (label->initrd)
if (label->fdt)
free(label->fdt);
if (label->fdtdir)
free(label);
- menu entry.
char *localcmd;
if (!localcmd)
return -ENOENT;
- returns.
int bootm_argc = 2;
int len = 0;
ulong kernel_addr;
void *buf;
label_print(label);
return 1;
label->name);
return 1;
label->name);
return 1;
int err;
if (err < 0)
mac_str[0] = '\0';
sizeof(bootargs));
return 1;
if (label->append)
strncpy(bootargs, label->append, sizeof(bootargs));
if (!fit_addr) {
return 1;
if (label->fdt) {
if (f1) {
f2 = "";
f3 = "";
f4 = "";
} else {
f2 = "-";
f4 = ".dtb";
if (!len)
slash = "./";
slash = "/";
else
slash = "";
strlen(f4) + 1;
if (!fdtfilefree) {
goto cleanup;
if (fdtfile) {
"fdt_addr_r");
free(fdtfilefree);
if (err < 0) {
label->name);
goto cleanup;
} else {
if (!bootm_argv[3])
if (!bootm_argv[2])
bootm_argc = 4;
+#ifdef CONFIG_CMD_BOOTI
else
+#elif defined(CONFIG_CMD_BOOTZ)
else
unmap_sysmem(buf);
+cleanup:
if (fit_addr)
free(fit_addr);
return 1;
+enum token_type {
T_EOL,
T_STRING,
T_EOF,
T_MENU,
T_TITLE,
T_TIMEOUT,
T_LABEL,
T_KERNEL,
T_LINUX,
T_APPEND,
T_INITRD,
T_LOCALBOOT,
T_DEFAULT,
T_PROMPT,
T_INCLUDE,
T_FDT,
T_FDTDIR,
T_ONTIMEOUT,
T_IPAPPEND,
T_BACKGROUND,
T_INVALID
+struct token {
char *val;
+static const struct token keywords[] = {
{"menu", T_MENU},
{"title", T_TITLE},
{"label", T_LABEL},
{"linux", T_LINUX},
{"fdt", T_FDT},
{NULL, T_INVALID}
+enum lex_state {
L_NORMAL = 0,
L_KEYWORD,
L_SLITERAL
- *t.
- insensitive.
+static char *get_string(char **p, struct token *t, char delim, int lower) +{
char *b, *e;
size_t len, i;
e = *p;
b = *p;
while (*e) {
break;
e++;
len = e - b;
if (!t->val)
return NULL;
if (lower)
else
t->val[i] = *b;
t->val[len] = '\0';
*p = e;
t->type = T_STRING;
return t->val;
+static void get_keyword(struct token *t) +{
int i;
break;
+static void get_token(char **p, struct token *t, enum lex_state state) +{
char *c = *p;
while (isblank(*c))
c++;
if (*c == '#') {
c++;
if (*c == '\n') {
t->type = T_EOL;
c++;
t->type = T_EOF;
c++;
get_keyword(t);
*p = c;
+static void eol_or_eof(char **c) +{
(*c)++;
+static int parse_sliteral(char **c, char **dst) +{
struct token t;
char *s = *c;
return -EINVAL;
*dst = t.val;
return 1;
+static int parse_integer(char **c, int *dst) +{
struct token t;
char *s = *c;
return -EINVAL;
free(t.val);
return 1;
+static int parse_pxefile_top(cmd_tbl_t *cmdtp, char *p, unsigned long base,
- incremented here.
+static int handle_include(cmd_tbl_t *cmdtp, char **c, unsigned long base,
char *include_path;
char *s = *c;
int err;
char *buf;
int ret;
if (err < 0) {
printf("Expected include path: %.*s\n", (int)(*c - s), s);
return err;
if (err < 0) {
return err;
unmap_sysmem(buf);
return ret;
+static int parse_menu(cmd_tbl_t *cmdtp, char **c, struct pxe_menu *cfg,
struct token t;
char *s = *c;
int err = 0;
switch (t.type) {
case T_TITLE:
break;
case T_INCLUDE:
nest_level + 1);
break;
case T_BACKGROUND:
break;
default:
(int)(*c - s), s);
if (err < 0)
return err;
eol_or_eof(c);
return 1;
+static int parse_label_menu(char **c, struct pxe_menu *cfg,
struct token t;
char *s;
s = *c;
switch (t.type) {
case T_DEFAULT:
return -ENOMEM;
break;
case T_LABEL:
break;
default:
(int)(*c - s), s);
eol_or_eof(c);
+static int parse_label_kernel(char **c, struct pxe_label *label) +{
char *s;
int err;
if (err < 0)
return err;
if (!s)
return 1;
if (!label->config)
return -ENOMEM;
*s = 0;
return 1;
- for.
+static int parse_label(char **c, struct pxe_menu *cfg) +{
struct token t;
int len;
char *s = *c;
int err;
if (!label)
return -ENOMEM;
if (err < 0) {
printf("Expected label name: %.*s\n", (int)(*c - s), s);
label_destroy(label);
return -EINVAL;
while (1) {
s = *c;
err = 0;
switch (t.type) {
case T_MENU:
err = parse_label_menu(c, cfg, label);
break;
case T_KERNEL:
case T_LINUX:
err = parse_label_kernel(c, label);
break;
case T_APPEND:
err = parse_sliteral(c, &label->append);
if (label->initrd)
break;
s = strstr(label->append, "initrd=");
if (!s)
break;
s += 7;
len = (int)(strchr(s, ' ') - s);
label->initrd = malloc(len + 1);
strncpy(label->initrd, s, len);
label->initrd[len] = '\0';
break;
case T_INITRD:
if (!label->initrd)
err = parse_sliteral(c, &label->initrd);
break;
case T_FDT:
if (!label->fdt)
err = parse_sliteral(c, &label->fdt);
break;
case T_FDTDIR:
if (!label->fdtdir)
err = parse_sliteral(c, &label->fdtdir);
break;
case T_LOCALBOOT:
label->localboot = 1;
err = parse_integer(c, &label->localboot_val);
break;
case T_IPAPPEND:
err = parse_integer(c, &label->ipappend);
break;
case T_EOL:
break;
default:
* put the token back! we don't want it - it's the end
* of a label and whatever token this is, it's
* something for the menu level context to handle.
*c = s;
return 1;
if (err < 0)
return err;
+#define MAX_NEST_LEVEL 16
struct token t;
int err;
b = p;
printf("Maximum nesting (%d) exceeded\n", MAX_NEST_LEVEL);
return -EMLINK;
while (1) {
s = p;
get_token(&p, &t, L_KEYWORD);
err = 0;
switch (t.type) {
case T_MENU:
cfg->prompt = 1;
err = parse_menu(cmdtp, &p, cfg,
base + ALIGN(strlen(b) + 1, 4),
nest_level);
break;
case T_TIMEOUT:
err = parse_integer(&p, &cfg->timeout);
break;
case T_LABEL:
err = parse_label(&p, cfg);
break;
case T_DEFAULT:
case T_ONTIMEOUT:
err = parse_sliteral(&p, &label_name);
if (label_name) {
free(cfg->default_label);
cfg->default_label = label_name;
break;
case T_INCLUDE:
err = handle_include(cmdtp, &p,
base + ALIGN(strlen(b), 4), cfg,
nest_level + 1);
break;
case T_PROMPT:
eol_or_eof(&p);
break;
case T_EOL:
break;
case T_EOF:
return 1;
default:
printf("Ignoring unknown command: %.*s\n",
(int)(p - s), s);
eol_or_eof(&p);
if (err < 0)
return err;
+void destroy_pxe_menu(struct pxe_menu *cfg) +{
if (cfg->title)
free(cfg->title);
label = list_entry(pos, struct pxe_label, list);
free(cfg);
- file.
+struct pxe_menu *parse_pxefile(cmd_tbl_t *cmdtp, unsigned long menucfg) +{
char *buf;
int r;
if (!cfg)
return NULL;
unmap_sysmem(buf);
if (r < 0) {
return NULL;
return cfg;
- menu code.
+static struct menu *pxe_menu_to_menu(struct pxe_menu *cfg) +{
struct menu *m;
int err;
int i = 1;
* Create a menu and add items for all the labels.
cfg->prompt, label_print, NULL, NULL);
if (!m)
return NULL;
sprintf(label->num, "%d", i++);
if (menu_item_add(m, label->num, label) != 1) {
menu_destroy(m);
return NULL;
if (cfg->default_label &&
(strcmp(label->name, cfg->default_label) == 0))
default_num = label->num;
* After we've created items for each label in the menu, set the
* menu's default label if one was specified.
if (default_num) {
err = menu_default_set(m, default_num);
if (err != 1) {
menu_destroy(m);
return NULL;
printf("Missing default: %s\n", cfg->default_label);
return m;
+static void boot_unattempted_labels(cmd_tbl_t *cmdtp, struct pxe_menu *cfg) +{
if (!label->attempted)
label_boot(cmdtp, label);
+void handle_pxe_menu(cmd_tbl_t *cmdtp, struct pxe_menu *cfg) +{
void *choice;
struct menu *m;
int err;
+#ifdef CONFIG_CMD_BMP
if (cfg->bmp) {
if (get_relfile(cmdtp, cfg->bmp, load_addr)) {
run_command("cls", 0);
bmp_display(load_addr,
BMP_ALIGN_CENTER, BMP_ALIGN_CENTER);
} else {
printf("Skipping background bmp %s for failure\n",
cfg->bmp);
if (!m)
return;
menu_destroy(m);
* err == 1 means we got a choice back from menu_get_choice.
* err == -ENOENT if the menu was setup to select the default but no
* default was set. in that case, we should continue trying to boot
* labels that haven't been attempted yet.
* otherwise, the user interrupted or there was some other error and
* we give up.
if (err == 1) {
err = label_boot(cmdtp, choice);
if (!err)
return;
return;
+} diff --git a/cmd/pxe_utils.h b/cmd/pxe_utils.h new file mode 100644 index 0000000000..10be494c65 --- /dev/null +++ b/cmd/pxe_utils.h @@ -0,0 +1,43 @@ +/* SPDX-License-Identifier: GPL-2.0+ */
+#ifndef __PXE_UTILS_H +#define __PXE_UTILS_H
booting the default label.
interrupted. If 1, always prompt for a choice regardless of
timeout.
+struct pxe_menu {
char *title;
char *bmp;
int timeout;
int prompt;
+extern bool is_pxe;
+extern int (*do_getfile)(cmd_tbl_t *cmdtp, const char *file_path,
char *file_addr);
+void destroy_pxe_menu(struct pxe_menu *cfg); +int get_pxe_file(cmd_tbl_t *cmdtp, const char *file_path,
unsigned long file_addr);
+int get_pxelinux_path(cmd_tbl_t *cmdtp, const char *file,
unsigned long pxefile_addr_r);
+void handle_pxe_menu(cmd_tbl_t *cmdtp, struct pxe_menu *cfg); +struct pxe_menu *parse_pxefile(cmd_tbl_t *cmdtp, unsigned long menucfg); +int pxe_ipaddr_paths(cmd_tbl_t *cmdtp, unsigned long pxefile_addr_r); +int pxe_mac_path(cmd_tbl_t *cmdtp, unsigned long pxefile_addr_r); +int pxe_uuid_path(cmd_tbl_t *cmdtp, unsigned long pxefile_addr_r);
+#endif /* __PXE_UTILS_H */ diff --git a/cmd/sysboot.c b/cmd/sysboot.c new file mode 100644 index 0000000000..793d67d2f5 --- /dev/null +++ b/cmd/sysboot.c @@ -0,0 +1,134 @@ +// SPDX-License-Identifier: GPL-2.0+
+#include <common.h> +#include <command.h> +#include <env.h> +#include <fs.h> +#include "pxe_utils.h"
+static char *fs_argv[5];
+static int do_get_ext2(cmd_tbl_t *cmdtp, const char *file_path, char *file_addr) +{ +#ifdef CONFIG_CMD_EXT2
return 1;
return -ENOENT;
+static int do_get_fat(cmd_tbl_t *cmdtp, const char *file_path, char *file_addr) +{ +#ifdef CONFIG_CMD_FAT
return 1;
return -ENOENT;
+static int do_get_any(cmd_tbl_t *cmdtp, const char *file_path, char *file_addr) +{ +#ifdef CONFIG_CMD_FS_GENERIC
return 1;
return -ENOENT;
+static int do_sysboot(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) +{
char *filename;
int prompt = 0;
is_pxe = false;
prompt = 1;
argc--;
argv++;
if (argc < 4)
return cmd_usage(cmdtp);
if (argc < 5) {
pxefile_addr_str = from_env("pxefile_addr_r");
if (!pxefile_addr_str)
return 1;
} else {
pxefile_addr_str = argv[4];
if (argc < 6) {
filename = env_get("bootfile");
} else {
filename = argv[5];
env_set("bootfile", filename);
do_getfile = do_get_ext2;
do_getfile = do_get_fat;
do_getfile = do_get_any;
} else {
printf("Invalid filesystem: %s\n", argv[3]);
return 1;
printf("Invalid pxefile address: %s\n", pxefile_addr_str);
return 1;
printf("Error reading config file\n");
return 1;
if (!cfg) {
printf("Error parsing config file\n");
return 1;
if (prompt)
cfg->prompt = 1;
+U_BOOT_CMD(sysboot, 7, 1, do_sysboot,
+); diff --git a/include/env.h b/include/env.h index b72239f6a5..d6c2d751d6 100644 --- a/include/env.h +++ b/include/env.h @@ -113,6 +113,16 @@ int env_match(unsigned char *name, int index); */ char *env_get(const char *varname);
+char *from_env(const char *envvar);
-- 2.17.1
Joe Hershberger
Patrice CHOTARD
Patrice Chotard
