[RFC] dfu: remove UPDATE_TFTP
Using UPDATE_TFTP the firmware can be updated from tFTP by writing to NOR flash. The same is possible by defining a dfu command in CONFIG_PREBOOT.
The dfu command cannot only write to NOR but also to other devices. In README.dfutfp UPDATE_TFTP has been marked as deprecated. It is not used by any board.
Remove tFTP update via CONFIG_UPDATE_TFTP.
Signed-off-by: Heinrich Schuchardt xypron.glpk@gmx.de --- Currently Gitlab CI lacks a test for dfu tftp. I will try to set one up. When it is properly tested I will send a final patch series. But beforehand I would like to know if eliminating UPDATE_TFTP is ok.
Best regards
Heinrich --- README | 8 --- common/Kconfig | 17 ------ common/main.c | 3 - common/update.c | 147 +-------------------------------------------- doc/README.dfutftp | 3 - doc/README.update | 97 ------------------------------ 6 files changed, 2 insertions(+), 273 deletions(-) delete mode 100644 doc/README.update
diff --git a/README b/README index 2384966a39..c53f72cfa6 100644 --- a/README +++ b/README @@ -2104,14 +2104,6 @@ The following options need to be configured:
Please see board_init_f function.
-- Automatic software updates via TFTP server - CONFIG_UPDATE_TFTP - CONFIG_UPDATE_TFTP_CNT_MAX - CONFIG_UPDATE_TFTP_MSEC_MAX - - These options enable and control the auto-update feature; - for a more detailed description refer to doc/README.update. - - MTD Support (mtdparts command, UBI support) CONFIG_MTD_UBI_WL_THRESHOLD This parameter defines the maximum difference between the highest diff --git a/common/Kconfig b/common/Kconfig index 67b3818fde..ca42ba37b7 100644 --- a/common/Kconfig +++ b/common/Kconfig @@ -1014,23 +1014,6 @@ endmenu
menu "Update support"
-config UPDATE_TFTP - bool "Auto-update using fitImage via TFTP" - depends on FIT - help - This option allows performing update of NOR with data in fitImage - sent via TFTP boot. - -config UPDATE_TFTP_CNT_MAX - int "The number of connection retries during auto-update" - default 0 - depends on UPDATE_TFTP - -config UPDATE_TFTP_MSEC_MAX - int "Delay in mSec to wait for the TFTP server during auto-update" - default 100 - depends on UPDATE_TFTP - config ANDROID_AB bool "Android A/B updates" default n diff --git a/common/main.c b/common/main.c index 4b3cd302c3..62ab3344e5 100644 --- a/common/main.c +++ b/common/main.c @@ -50,9 +50,6 @@ void main_loop(void) if (IS_ENABLED(CONFIG_USE_PREBOOT)) run_preboot_environment_command();
- if (IS_ENABLED(CONFIG_UPDATE_TFTP)) - update_tftp(0UL, NULL, NULL); - s = bootdelay_process(); if (cli_process_fdt(&s)) cli_secure_boot_cmd(s); diff --git a/common/update.c b/common/update.c index c8dd346a09..caf74e63db 100644 --- a/common/update.c +++ b/common/update.c @@ -14,10 +14,6 @@ #error "CONFIG_FIT and CONFIG_OF_LIBFDT are required for auto-update feature" #endif
-#if defined(CONFIG_UPDATE_TFTP) && !defined(CONFIG_MTD_NOR_FLASH) -#error "CONFIG_UPDATE_TFTP and !CONFIG_MTD_NOR_FLASH needed for legacy behaviour" -#endif - #include <command.h> #include <env.h> #include <flash.h> @@ -26,7 +22,6 @@ #include <malloc.h> #include <dfu.h> #include <errno.h> -#include <mtd/cfi_flash.h>
/* env variable holding the location of the update file */ #define UPDATE_FILE_ENV "updatefile" @@ -46,10 +41,7 @@
extern ulong tftp_timeout_ms; extern int tftp_timeout_count_max; -#ifdef CONFIG_MTD_NOR_FLASH -extern flash_info_t flash_info[]; -static uchar *saved_prot_info; -#endif + static int update_load(char *filename, ulong msec_max, int cnt_max, ulong addr) { int size, rv; @@ -98,122 +90,6 @@ static int update_load(char *filename, ulong msec_max, int cnt_max, ulong addr) return rv; }
-#ifdef CONFIG_MTD_NOR_FLASH -static int update_flash_protect(int prot, ulong addr_first, ulong addr_last) -{ - uchar *sp_info_ptr; - ulong s; - int i, bank, cnt; - flash_info_t *info; - - sp_info_ptr = NULL; - - if (prot == 0) { - saved_prot_info = - calloc(CONFIG_SYS_MAX_FLASH_BANKS * CONFIG_SYS_MAX_FLASH_SECT, 1); - if (!saved_prot_info) - return 1; - } - - for (bank = 0; bank < CONFIG_SYS_MAX_FLASH_BANKS; ++bank) { - cnt = 0; - info = &flash_info[bank]; - - /* Nothing to do if the bank doesn't exist */ - if (info->sector_count == 0) - return 0; - - /* Point to current bank protection information */ - sp_info_ptr = saved_prot_info + (bank * CONFIG_SYS_MAX_FLASH_SECT); - - /* - * Adjust addr_first or addr_last if we are on bank boundary. - * Address space between banks must be continuous for other - * flash functions (like flash_sect_erase or flash_write) to - * succeed. Banks must also be numbered in correct order, - * according to increasing addresses. - */ - if (addr_last > info->start[0] + info->size - 1) - addr_last = info->start[0] + info->size - 1; - if (addr_first < info->start[0]) - addr_first = info->start[0]; - - for (i = 0; i < info->sector_count; i++) { - /* Save current information about protected sectors */ - if (prot == 0) { - s = info->start[i]; - if ((s >= addr_first) && (s <= addr_last)) - sp_info_ptr[i] = info->protect[i]; - - } - - /* Protect/unprotect sectors */ - if (sp_info_ptr[i] == 1) { -#if defined(CONFIG_SYS_FLASH_PROTECTION) - if (flash_real_protect(info, i, prot)) - return 1; -#else - info->protect[i] = prot; -#endif - cnt++; - } - } - - if (cnt) { - printf("%sProtected %d sectors\n", - prot ? "": "Un-", cnt); - } - } - - if((prot == 1) && saved_prot_info) - free(saved_prot_info); - - return 0; -} -#endif - -static int update_flash(ulong addr_source, ulong addr_first, ulong size) -{ -#ifdef CONFIG_MTD_NOR_FLASH - ulong addr_last = addr_first + size - 1; - - /* round last address to the sector boundary */ - if (flash_sect_roundb(&addr_last) > 0) - return 1; - - if (addr_first >= addr_last) { - printf("Error: end address exceeds addressing space\n"); - return 1; - } - - /* remove protection on processed sectors */ - if (update_flash_protect(0, addr_first, addr_last) > 0) { - printf("Error: could not unprotect flash sectors\n"); - return 1; - } - - printf("Erasing 0x%08lx - 0x%08lx", addr_first, addr_last); - if (flash_sect_erase(addr_first, addr_last) > 0) { - printf("Error: could not erase flash\n"); - return 1; - } - - printf("Copying to flash..."); - if (flash_write((char *)addr_source, addr_first, size) > 0) { - printf("Error: could not copy to flash\n"); - return 1; - } - printf("done\n"); - - /* enable protection on processed sectors */ - if (update_flash_protect(1, addr_first, addr_last) > 0) { - printf("Error: could not protect flash sectors\n"); - return 1; - } -#endif - return 0; -} - static int update_fit_getparams(const void *fit, int noffset, ulong *addr, ulong *fladdr, ulong *size) { @@ -235,20 +111,9 @@ int update_tftp(ulong addr, char *interface, char *devstring) char *filename, *env_addr, *fit_image_name; ulong update_addr, update_fladdr, update_size; int images_noffset, ndepth, noffset; - bool update_tftp_dfu; int ret = 0; void *fit;
- if (interface == NULL && devstring == NULL) { - update_tftp_dfu = false; - } else if (interface && devstring) { - update_tftp_dfu = true; - } else { - pr_err("Interface: %s and devstring: %s not supported!\n", - interface, devstring); - return -EINVAL; - } - /* use already present image */ if (addr) goto got_update_file; @@ -315,15 +180,7 @@ got_update_file: goto next_node; }
- if (!update_tftp_dfu) { - if (update_flash(update_addr, update_fladdr, - update_size)) { - printf("Error: can't flash update, aborting\n"); - ret = 1; - goto next_node; - } - } else if (fit_image_check_type(fit, noffset, - IH_TYPE_FIRMWARE)) { + if (fit_image_check_type(fit, noffset, IH_TYPE_FIRMWARE)) { ret = dfu_tftp_write(fit_image_name, update_addr, update_size, interface, devstring); if (ret) diff --git a/doc/README.dfutftp b/doc/README.dfutftp index a3341bbb61..b279f542a1 100644 --- a/doc/README.dfutftp +++ b/doc/README.dfutftp @@ -52,9 +52,6 @@ Environment variables
The "dfu tftp" command can be used in the "preboot" environment variable (when it is enabled by defining CONFIG_PREBOOT). -This is the preferable way of using this command in the early boot stage -as opposed to legacy update_tftp() function invocation. -
Beagle Bone Black (BBB) setup ----------------------------- diff --git a/doc/README.update b/doc/README.update deleted file mode 100644 index bf4379279e..0000000000 --- a/doc/README.update +++ /dev/null @@ -1,97 +0,0 @@ -Automatic software update from a TFTP server -============================================ - -Overview --------- - -This feature allows to automatically store software updates present on a TFTP -server in NOR Flash. In more detail: a TFTP transfer of a file given in -environment variable 'updatefile' from server 'serverip' is attempted during -boot. The update file should be a FIT file, and can contain one or more -updates. Each update in the update file has an address in NOR Flash where it -should be placed, updates are also protected with a SHA-1 checksum. If the -TFTP transfer is successful, the hash of each update is verified, and if the -verification is positive, the update is stored in Flash. - -The auto-update feature is enabled by the CONFIG_UPDATE_TFTP macro: - -#define CONFIG_UPDATE_TFTP 1 - - -Note that when enabling auto-update, Flash support must be turned on. Also, -one must enable FIT and LIBFDT support: - -#define CONFIG_FIT 1 -#define CONFIG_OF_LIBFDT 1 - -The auto-update feature uses the following configuration knobs: - -- CONFIG_UPDATE_LOAD_ADDR - - Normally, TFTP transfer of the update file is done to the address specified - in environment variable 'loadaddr'. If this variable is not present, the - transfer is made to the address given in CONFIG_UPDATE_LOAD_ADDR (0x100000 - by default). - -- CONFIG_UPDATE_TFTP_CNT_MAX - CONFIG_UPDATE_TFTP_MSEC_MAX - - These knobs control the timeouts during initial connection to the TFTP - server. Since a transfer is attempted during each boot, it is undesirable to - have a long delay when a TFTP server is not present. - CONFIG_UPDATE_TFTP_MSEC_MAX specifies the number of milliseconds to wait for - the server to respond to initial connection, and CONFIG_UPDATE_TFTP_CNT_MAX - gives the number of such connection retries. CONFIG_UPDATE_TFTP_CNT_MAX must - be non-negative and is 0 by default, CONFIG_UPDATE_TFTP_MSEC_MAX must be - positive and is 100 by default. - -Since the update file is in FIT format, it is created from an *.its file using -the mkimage tool. dtc tool with support for binary includes, e.g. in version -1.2.0 or later, must also be available on the system where the update file is -to be prepared. Refer to the doc/uImage.FIT/ directory for more details on FIT -images. - - -Example .its files ------------------- - -- doc/uImage.FIT/update_uboot.its - - A simple example that can be used to create an update file for automatically - replacing U-Boot image on a system. - - Assuming that an U-Boot image u-boot.bin is present in the current working - directory, and that the address given in the 'load' property in the - 'update_uboot.its' file is where the U-Boot is stored in Flash, the - following command will create the actual update file 'update_uboot.itb': - - mkimage -f update_uboot.its update_uboot.itb - - Place 'update_uboot.itb' on a TFTP server, for example as - '/tftpboot/update_uboot.itb', and set the 'updatefile' variable - appropriately, for example in the U-Boot prompt: - - setenv updatefile /tftpboot/update_uboot.itb - saveenv - - Now, when the system boots up and the update TFTP server specified in the - 'serverip' environment variable is accessible, the new U-Boot image will be - automatically stored in Flash. - - NOTE: do make sure that the 'u-boot.bin' image used to create the update - file is a good, working image. Also make sure that the address in Flash - where the update will be placed is correct. Making mistake here and - attempting the auto-update can render the system unusable. - -- doc/uImage.FIT/update3.its - - An example containing three updates. It can be used to update Linux kernel, - ramdisk and FDT blob stored in Flash. The procedure for preparing the update - file is similar to the example above. - -TFTP update via DFU -------------------- - -- It is now possible to update firmware (bootloader, kernel, rootfs, etc.) via - TFTP by using DFU (Device Firmware Upgrade). More information can be found in - ./doc/README.dfutftp documentation entry. -- 2.27.0
Hi Heinrich,
Could you also write in the proper README the steps necessary to have the same functionality as with UPDATE_TFTP with dfu and preboot? I think that it would be good to have it written down in ./doc.
Best regards
Heinrich
CONFIG_UPDATE_TFTP
feature;
-config UPDATE_TFTP
- depends on FIT
- help
fitImage
sent via TFTP boot.
- default 0
auto-update"
- default 100
- ulong s;
- int i, bank, cnt;
- if (prot == 0) {
saved_prot_info =
return 1;
cnt = 0;
boundary.
for other
flash_write) to
order,
sectors */
if (prot == 0) {
s = info->start[i];
addr_last))
sp_info_ptr[i] =
info->protect[i]; -
prot))
return 1;
-#else
-#endif
cnt++;
if (cnt) {
prot ? "": "Un-",
cnt);
-} -#endif
return 1;
space\n");
return 1;
return 1;
return 1;
return 1;
- printf("done\n");
return 1;
-#endif
} else {
supported!\n",
return -EINVAL;
update_size)) {
aborting\n");
ret = 1;
goto next_node;
-Overview
specified
present, the
(0x100000
- by default).
TFTP
undesirable to
to wait for
must be
-Example .its files
automatically
working
- saveenv
in the
image will be
update
Flash
Linux kernel,
the update
be found in
-- 2.27.0
Lukasz Majewski
DENX Software Engineering GmbH, Managing Director: Wolfgang Denk HRB 165235 Munich, Office: Kirchenstr.5, D-82194 Groebenzell, Germany Phone: (+49)-8142-66989-59 Fax: (+49)-8142-66989-80 Email: lukma@denx.de
-----BEGIN PGP SIGNED MESSAGE----- Hash: SHA256
On 15.07.20 13:24, Lukasz Majewski wrote:
Hi Heinrich,
doc/README.dfutftp already describes the necessary steps as:
* enable CONFIG_DFU_TFTP * enable CONFIG_PREBOOT * put a string like "dfu tftp 0 mmc 0" into the "preboot" env variable
Do you want me to explicitly write that "dfu tftp 0 mtd 0" replaces the former auto-update functionality?
Best regards
Heinrich
Best regards
Heinrich
Hi Heinrich,
Hi Heinrich,
- enable CONFIG_DFU_TFTP
- enable CONFIG_PREBOOT
- put a string like "dfu tftp 0 mmc 0" into the "preboot" env variable
No, this is fine. Thanks.
Best regards
Heinrich
Best regards
Heinrich
-----BEGIN PGP SIGNATURE-----
iQIzBAEBCAAdFiEEbcT5xx8ppvoGt20zxIHbvCwFGsQFAl8O7SYACgkQxIHbvCwF GsSp9RAAkNdFFkYpaSit5367azX56eAt4eiHyD1bqCEYJB1Z3+f3P0xM0NjD2B+T QNVHHNbE+fvEftCT5Sl28mZIhqTpqZnMv5TFAyj4c1NxEmHnBFoeQcNb9vqzNaX3 8txdrYV3Nx5fKZlFDa2NqX0/+2NMx4DjqnN2P71IaFrp98qQMR0b62OQOAR9CwNE YEW+usIRyE/cPHvvYMzKTS/8e/jJTRQXtFJvFjU3xh3/4s4/fbQCIbJZwMACsMrJ hYAoT0d2+VNWBEg/i0q/uUmUh5OuwnrSsYaI3MdqV5DpNHcsF6UTOhT6svE+MibV v4gMO7D2yfX7Zob6cLGU9hmnio32U0xx4jRhWNZtphuX1mI4psKtZp5k9FdRGjgn +hrbkjG1y8xbytFiw5quCk07E34x8AttHDDM76wF5wu7WrH0U4HBjoNucj9Q2S6j ZBD3IP/bOwpO3x32tpcFid+GaWy7NRTQ6OtOL4jF/Qgjk7F714wP1N5+cO4qB+kF QFaRw+4zOGo0W0DLD9WyexDuY7QyNDbfXYOE6ao/pXGfFfWCa2WJCt0JUv1TnH5L AbCqaNILWDZDJ0YBaPjJCqbeiikCG859nr/AgEPR8ns8jJ2i/2ditk9yUuha27Ub mLBjbhV9PYo+5K07xMkVis+DIIgCc3xOJtL8DoviiJMO0xLBKos= =IzXA -----END PGP SIGNATURE-----
Lukasz Majewski
On 15. 07. 20 15:23, Lukasz Majewski wrote:
Hi Heinrich,
Hi Heinrich,
I am curious if that command is really dfu tftp 0 mtd 0.
I have just tested it on zynqmp with copying images to ram and command is just dfu tftp ram 0. It means I think it would be worth to list options which are really used by different back ends because it is not fully clear from help how to exactly define it.
dfu tftp [<interface> <dev>] [<addr>] - device firmware upgrade via TFTP on device <dev>, attached to interface <interface> [<addr>] - address where FIT image has been stored
Thanks, Michal
Hi Heinrich,
Hi Heinrich,
- enable CONFIG_DFU_TFTP * enable CONFIG_PREBOOT * put a string
Lukasz was asking about the replacement of the update that was executed when running with CONFIG_UPDATE_TFTP=y. This function that I am removing could only write to NOR flash. The update defined via CONFIG_PREBOOT is much more flexible and can server other storage media.
The different accessible devices are described in doc/README.dfu. "ram" is one of them.
Best regards
Heinrich
Thanks, Michal
Hi Heinrich,
Hi Heinrich,
> Using UPDATE_TFTP the firmware can be updated from tFTP > by writing to NOR flash. The same is possible by defining > a dfu command in CONFIG_PREBOOT. > > The dfu command cannot only write to NOR but also to > other devices. In README.dfutfp UPDATE_TFTP has been > marked as deprecated.
I have really not a problem with removing it.
yes and link to README.dfutftp where only one options is listed as "dfu tftp 0 mmc 0" which is definitely only one option which you can use. Would be really good to list that options there and also retest them.
It means as the part of removal we should check if README.dfutftp is really up to date because I don't think it is clear how users should use it for different cases. (USB cases are described properly in README.dfu for different backends).
Thanks, Michal
Hi Heinrich,
> Hi Heinrich, > >> Using UPDATE_TFTP the firmware can be updated from tFTP >> by writing to NOR flash. The same is possible by defining >> a dfu command in CONFIG_PREBOOT. >> >> The dfu command cannot only write to NOR but also to >> other devices. In README.dfutfp UPDATE_TFTP has been >> marked as deprecated. > > Could you also write in the proper README the steps > necessary to have the same functionality as with > UPDATE_TFTP with dfu and preboot? I think that it would be > good to have it written down in ./doc. >
We will be able to have automated tests writing to the DFU "ram" and DFU "mtd" driver once the flash driver used by QEMU works properly. See
https://lists.denx.de/pipermail/u-boot/2020-July/420835.html mtd: cfi_flash: read device tree correctly
Best regards
Heinrich
Thanks, Michal
Hi Heinrich,
>> Hi Heinrich, >> >>> Using UPDATE_TFTP the firmware can be updated from tFTP >>> by writing to NOR flash. The same is possible by defining >>> a dfu command in CONFIG_PREBOOT. >>> >>> The dfu command cannot only write to NOR but also to >>> other devices. In README.dfutfp UPDATE_TFTP has been >>> marked as deprecated. >> >> Could you also write in the proper README the steps >> necessary to have the same functionality as with >> UPDATE_TFTP with dfu and preboot? I think that it would be >> good to have it written down in ./doc. >>
Do you plan to wire it with test/py framework and run it via travis/gitlab?
Thanks, Michal
Hi Heinrich,
Hi Heinrich,
One of my concerns regarding CONFIG_PREBOOT is that it depends on the "preboot" variable. What this means is that, if a user unsets this variable (accidentally or not), 'automatic firmware update' won't be executed. This can be a critical issue if the system administrator intends to *enforce* the update. (I know there are more issues regarding enforcement though.)
That is why I added UEFI capsule update hook in main_loop() as a compile-time option.
Thanks, -Takahiro Akashi
Best regards
Heinrich
Thanks, Michal
iQIzBAEBCAAdFiEEbcT5xx8ppvoGt20zxIHbvCwFGsQFAl8PFcUACgkQxIHbvCwF GsSwLQ//bU8AISZ5q4cgLcnAVPYnBPbVtoPXlyRROnX6XW3eDjq506Ah0Rk8UwYH lhLSM1m+bfJZzVtWUjymlRGjuaB1HLzcyd1PbfK0+50mMaVnFBV5PMU4ue6Ju+zT BukpUvtQ4KLpooo2QhjCz4/oXmur782RUJGq6hb7mDbk6R0+L8coqoiglLid5374 GdOQhgTAa8jWu0QxIBbdeOOrTSZz1kOBaShYffKXfBCaUfMOf/2T6sxDrSuTB8/N WTeKdbTAsx5BVEY8s9EaAy6a7kWf8mb/7LdooFUMQ2noNbdw/ucfiNCA+H2JNTK1 GjvzDgViWAF0A0sXu6c1fqFT+4xo2lpRvG0wXsz3zRwpggmlAVX5PPi7o4Xj2HVF 7HPBVxz4AjJ3YpOpyLm0rEVEXnwBdke/jy/2r0VRyn5QMFaqAMEkrA39/wHrjj6t 0s4EUeuy5IjMf51zUrTAE/J9xHowLwjldODRgwmWoEYShJRgZp+J0yr2nhGTwpyS 91ESrHzkok/5BPkYFYGulBeeJFDOBegA7N7xec5e6YsXrWEPDiOpS5I1AfbycceV lERhJpHIgPPjpaMgNcATKeti85o7veNe31IMoW758i5kbjQFOB8NlvtSSu97/2/K eB/dIrOdnzC+URaun+MEt0T4HYPYgEuGAsBPQJKYrTw0sFhJRkg= =JXjF -----END PGP SIGNATURE-----
On 7/16/20 3:52 AM, AKASHI Takahiro wrote:
On Wed, Jul 15, 2020 at 04:42:20PM +0200, Heinrich Schuchardt wrote: On 15.07.20 16:06, Michal Simek wrote:
Hi Heinrich,
You could also defeat the old tFTP auto-update by setting "serverip" to a reserved value like 240.0.0.0. So there is no new vulnerability introduced here.
Anyway no board uses the old tFTP auto-update while DFU is enabled in 273 config files and DFU_TFTP in 2.
Best regards
Heinrich
Best regards
Heinrich
Thanks, Michal
Hi Heinrich,
On 15.07.20 13:24, Lukasz Majewski wrote: >>> Hi Heinrich, >>> >>>> Using UPDATE_TFTP the firmware can be updated from tFTP >>>> by writing to NOR flash. The same is possible by defining >>>> a dfu command in CONFIG_PREBOOT. >>>> >>>> The dfu command cannot only write to NOR but also to >>>> other devices. In README.dfutfp UPDATE_TFTP has been >>>> marked as deprecated. >>> >>> Could you also write in the proper README the steps >>> necessary to have the same functionality as with >>> UPDATE_TFTP with dfu and preboot? I think that it would be >>> good to have it written down in ./doc. >>>
? I'm not talking about tftp here, but about a potential issue in the current framework.
-Takahiro Akashi
Best regards
Heinrich
Best regards
Heinrich
Thanks, Michal
Heinrich,
This description is not accurate.
Best regards
Heinrich
CONFIG_UPDATE_TFTP
-config UPDATE_TFTP
- depends on FIT
- help
sent via TFTP boot.
NAK. If this configuration is removed, common/update.c won't be compiled in. There is a chain of dependency: DFU -> DFU_TFTP -> DFU_OVER_TFTP ->(implicitly) UPDATE_TFTP
- default 0
- default 100
- ulong s;
- int i, bank, cnt;
- if (prot == 0) {
saved_prot_info =
return 1;
cnt = 0;
if (prot == 0) {
s = info->start[i];
return 1;
-#else
-#endif
cnt++;
if (cnt) {
-} -#endif
return 1;
return 1;
return 1;
return 1;
return 1;
- printf("done\n");
return 1;
-#endif
} else {
return -EINVAL;
update_size)) {
ret = 1;
goto next_node;
There are still two places in which README.update file is referred to while you try to delete it.
-Overview
If you really want to delete this file, you must move the following text to somewhere else. Otherwise, FIT related information will be lost.
-Takahiro Akashi
- by default).
-Example .its files
- saveenv
-- 2.27.0
Am 16. Juli 2020 03:36:13 MESZ schrieb AKASHI Takahiro takahiro.akashi@linaro.org:
Heinrich,
NOR
CONFIG_PREBOOT.
In
used
by any board.
What are you missing?
up.
Best regards
Heinrich
CONFIG_UPDATE_TFTP
-config UPDATE_TFTP
- depends on FIT
- help
sent via TFTP boot.
No. In common/Makefile there are orginally two lines for update.o
obj-$(CONFIG_UPDATE_TFTP) += update.o obj-$(CONFIG_DFU_TFTP) += update.o
- default 0
- default 100
feature"
#endif
legacy behaviour"
-#endif
ulong addr)
return rv; }
addr_last)
- ulong s;
- int i, bank, cnt;
- if (prot == 0) {
saved_prot_info =
1);
return 1;
cnt = 0;
if (prot == 0) {
s = info->start[i];
return 1;
-#else
-#endif
cnt++;
if (cnt) {
-} -#endif
size)
return 1;
return 1;
return 1;
return 1;
return 1;
- printf("done\n");
return 1;
-#endif
*addr,
char *devstring)
} else {
return -EINVAL;
update_size)) {
ret = 1;
goto next_node;
variable
stage
Thanks for catching this.
-Overview
on a TFTP
in
attempted during
more
where it
If the
and if the
The text below is incorrect. You should not use any definition in a board include.
Dependencies should be in the Kconfig.
Best regards
Heinrich
-Takahiro Akashi
on. Also,
specified
present, the
(0x100000
- by default).
TFTP
undesirable to
to wait for
must be
file using
version
update file is
details on FIT
-images.
-Example .its files
automatically
working
the
the
'update_uboot.itb':
- saveenv
in the
image will be
update
Flash
and
Linux kernel,
the update
etc.) via
be found in
-- 2.27.0
AKASHI Takahiro
Lukasz Majewski
Michal Simek
