GPIO request failures for Renesas rcar-gen3
I am trying to port U-Boot to a new product based on a Renesas RZ/G2M (rcar-gen3). We're have this working with Renesas' version from 2018.09, but I am trying to integrate it with U-Boot 2020.07-rc4
What's happening is that it seems like all GPIO are failing to be requested, so things like regulator-gpio fail, reset-gpios, etc. all return errors.
The dm tree and gpio status commands all appear to show gpio banks are enumerating, but since nothing can use the GPIO's it seems like the common thread is the gpio driver for the rcar3.
I was hoping someone might have some thoughts of things I could try or investigate. In order to properly set the voltage for the MMC card, I need "regulator-gpio" to operate correctly.
The gpio regulator node looks like:
vccq_sdhi0: regulator-vccq-sdhi0 { compatible = "regulator-gpio";
regulator-name = "SDHI0 VccQ"; regulator-min-microvolt = <1800000>; regulator-max-microvolt = <3300000>;
gpios = <&gpio6 30 GPIO_ACTIVE_HIGH>; gpios-states = <1>; states = <3300000 1>, <1800000 0>; regulator-always-on; };
Log Below with some debugging turned on.
U-Boot 2020.07-rc4-00060-g9cb895203a-dirty (Jun 18 2020 - 15:27:00 -0500)
CPU: Renesas Electronics R8A7796 rev 2.1 Model: Beacon Embedded Works RZ/G2M Development Kit DRAM: 3.9 GiB Bank #0: 0x048000000 - 0x0bfffffff, 1.9 GiB Bank #1: 0x600000000 - 0x67fffffff, 2 GiB
MMC: gpio_request_tail: dm_gpio_requestf failed gpio_request_tail: Node 'regulator-vccq-sdhi0', property 'gpios', failed to request GPIO index 0: -19 regulator gpio - not found! Error: -19gpio_request_tail: Node 'regulator-vccq-sdhi0', property 'enable-gpios', failed to request GPIO index 0: -2 gpio@e6055400: set_value: error: gpio gpio@e605540030 not reserved Can't set regulator-gpio : regulator-vccq-sdhi0 gpio to: 1 gpio_request_tail: Node 'regulator0', property 'gpio', failed to request GPIO index 0: -2 sd@ee100000: 0, sd@ee160000: 1 Loading Environment from MMC... gpio_request_tail: Node 'regulator1', property 'gpio', failed to request GPIO index 0: -2 OK In: serial@e6e88000 Out: serial@e6e88000 Err: serial@e6e88000 Net: gpio_request_tail: dm_gpio_requestf failed gpio_request_tail: Node 'ethernet-phy@0', property 'reset-gpios', failed to request GPIO index 0: -19 gpio@e6052000: set_value: error: gpio gpio@e605200010 not reserved gpio@e6052000: set_value: error: gpio gpio@e605200010 not reserved
Error: ethernet@e6800000 address not set. No ethernet found.
Hit any key to stop autoboot: 0 =>
Note that RZ/G2M is not supported by mainline U-Boot.
Also note that the GPIO driver and PFC drivers are working together, grep for sh_pfc_config_mux_for_gpio(), so unless both work and probed, the GPIO driver will likely not work.
Can you provide 'dm tree' output ?
I just sent a series [1] for review for porting the PFC, clock drivers and MMC over.
[1] - https://patchwork.ozlabs.org/project/uboot/patch/20200618211444.391556-2-afo...
It looks to me like the gpio driver looks for "rcar-gen3-gpio" which is included in the SoC's DTSI file. I looked in Renesas' upstream repo, but I didn't find anything unique in the gpio driver, but maybe there is something in the gpio driver I missed.
=> dm tree Class Index Probed Driver Name ----------------------------------------------------------- root 0 [ + ] root_driver root_driver clk 0 [ ] fixed_rate_clock |-- audio_clk_a clk 1 [ ] fixed_rate_clock |-- audio_clk_b clk 2 [ ] fixed_rate_clock |-- audio_clk_c clk 3 [ ] fixed_rate_clock |-- can clk 4 [ + ] fixed_rate_clock |-- extal clk 5 [ + ] fixed_rate_clock |-- extalr clk 6 [ ] fixed_rate_clock |-- pcie_bus firmware 0 [ ] psci |-- psci clk 7 [ ] fixed_rate_clock |-- scif simple_bus 0 [ + ] generic_simple_bus |-- soc gpio 0 [ ] rcar-gpio | |-- gpio@e6050000 gpio 1 [ ] rcar-gpio | |-- gpio@e6051000 gpio 2 [ + ] rcar-gpio | |-- gpio@e6052000 gpio 3 [ ] rcar-gpio | |-- gpio@e6053000 gpio 4 [ ] rcar-gpio | |-- gpio@e6054000 gpio 5 [ ] rcar-gpio | |-- gpio@e6055000 gpio 6 [ + ] rcar-gpio | |-- gpio@e6055400 gpio 7 [ ] rcar-gpio | |-- gpio@e6055800 clk 8 [ + ] clk_r8a774a1 | |-- clock-controller@e6150000 i2c 0 [ ] i2c_rcar | |-- i2c@e6500000 i2c 1 [ ] i2c_rcar | |-- i2c@e6510000 i2c 2 [ ] i2c_rcar | |-- i2c@e66d8000 i2c 3 [ ] i2c_rcar | |-- i2c@e66e0000 eth 0 [ ] ravb | |-- ethernet@e6800000 serial 0 [ ] serial_sh | |-- serial@e6e60000 serial 1 [ + ] serial_sh | |-- serial@e6e88000 serial 2 [ ] serial_sh | |-- serial@e6f30000 usb 0 [ ] ehci_generic | |-- usb@ee080100 usb 1 [ ] ehci_generic | |-- usb@ee0a0100 phy 0 [ ] rcar-gen3-phy | |-- usb-phy@ee080200 phy 1 [ ] rcar-gen3-phy | |-- usb-phy@ee0a0200 mmc 0 [ + ] renesas-sdhi | |-- sd@ee100000 blk 0 [ ] mmc_blk | | `-- sd@ee100000.blk mmc 1 [ + ] renesas-sdhi | |-- sd@ee160000 blk 1 [ + ] mmc_blk | | `-- sd@ee160000.blk pci 0 [ ] rcar_gen3_pcie | |-- pcie@fe000000 pci 1 [ ] rcar_gen3_pcie | `-- pcie@ee800000 clk 9 [ ] fixed_rate_clock |-- usb3s0 clk 10 [ ] fixed_rate_clock |-- usb_extal clk 11 [ ] fixed_rate_clock |-- osc_32k regulator 0 [ + ] fixed regulator |-- regulator0 regulator 1 [ + ] fixed regulator |-- regulator1 regulator 2 [ ] fixed regulator |-- regulator_audio regulator 3 [ ] fixed regulator |-- regulator-lcd regulator 4 [ ] fixed regulator |-- regulator-lcd-reset regulator 5 [ ] fixed regulator |-- regulator_camera regulator 6 [ + ] gpio regulator |-- regulator-vccq-sdhi0 clk 12 [ ] fixed_rate_clock |-- x302-clock clk 13 [ ] fixed_rate_clock `-- x304-clock =>
I already submitted the board device tree stuff to the Linux community and I am waiting for feedback to finalize it before attempting to post here. If it's helpful, I can post the rest of my series with the board device tree and board files instead of waiting.
Isn't the PFC driver missing here ?
That was it. Thank you!
I'll have to fix the pfc and submit patch V2 to fix that.
I appreciate your quick response. It's working now
adam
On 6/18/20 11:46 PM, Adam Ford wrote: [...]
That's good to hear.
Adam Ford
