[U-Boot] [PATCH v2] x86: Add congatec conga-QA3/E3845-4G (Bay Trail) support
This patch adds support for the congatec conga-QA3/E3845-4G eMMC8 SoM, installed on the congatec Qseven 2.0 evaluation carrier board (conga-QEVAL).
Its port is very similar to the MinnowboardMAX port and also uses the Intel FSP as described in doc/README.x86.
Currently supported are the following interfaces / devices: - UART (via Winbond legacy SuperIO chip on carrier board) - Ethernet (PCIe Intel I210 / E1000) - SPI including SPI NOR as boot-device - USB 2.0 - SATA via U-Boot SCSI IF - eMMC - Video (HDMI output @ 800x600) - PCIe
Not supported yet is: - I2C - USB 3.0
Signed-off-by: Stefan Roese sr@denx.de Cc: Simon Glass sjg@chromium.org Cc: Bin Meng bmeng.cn@gmail.com --- v2: - Rebased on u-boot-x86/master - Fixed spelling of Bay Trail in commit subject - Removed unreferenced CONFIG_WINBOND from config header - Moved Intel E1000 from config header to defconfig
arch/x86/Kconfig | 4 + arch/x86/dts/Makefile | 1 + arch/x86/dts/conga-qeval20-qa3-e3845.dts | 278 +++++++++++++++++++++ board/congatec/Kconfig | 29 +++ board/congatec/conga-qeval20-qa3-e3845/Kconfig | 28 +++ board/congatec/conga-qeval20-qa3-e3845/MAINTAINERS | 7 + board/congatec/conga-qeval20-qa3-e3845/Makefile | 7 + .../conga-qeval20-qa3-e3845/conga-qeval20-qa3.c | 31 +++ board/congatec/conga-qeval20-qa3-e3845/start.S | 9 + configs/conga-qeval20-qa3-e3845_defconfig | 47 ++++ include/configs/conga-qeval20-qa3-e3845.h | 65 +++++ 11 files changed, 506 insertions(+) create mode 100644 arch/x86/dts/conga-qeval20-qa3-e3845.dts create mode 100644 board/congatec/Kconfig create mode 100644 board/congatec/conga-qeval20-qa3-e3845/Kconfig create mode 100644 board/congatec/conga-qeval20-qa3-e3845/MAINTAINERS create mode 100644 board/congatec/conga-qeval20-qa3-e3845/Makefile create mode 100644 board/congatec/conga-qeval20-qa3-e3845/conga-qeval20-qa3.c create mode 100644 board/congatec/conga-qeval20-qa3-e3845/start.S create mode 100644 configs/conga-qeval20-qa3-e3845_defconfig create mode 100644 include/configs/conga-qeval20-qa3-e3845.h
diff --git a/arch/x86/Kconfig b/arch/x86/Kconfig index 0b30883..4ef27dc 100644 --- a/arch/x86/Kconfig +++ b/arch/x86/Kconfig @@ -8,6 +8,9 @@ choice prompt "Mainboard vendor" default VENDOR_EMULATION
+config VENDOR_CONGATEC + bool "congatec" + config VENDOR_COREBOOT bool "coreboot"
@@ -26,6 +29,7 @@ config VENDOR_INTEL endchoice
# board-specific options below +source "board/congatec/Kconfig" source "board/coreboot/Kconfig" source "board/efi/Kconfig" source "board/emulation/Kconfig" diff --git a/arch/x86/dts/Makefile b/arch/x86/dts/Makefile index 84feb19..5ca065d 100644 --- a/arch/x86/dts/Makefile +++ b/arch/x86/dts/Makefile @@ -5,6 +5,7 @@ dtb-y += bayleybay.dtb \ chromebook_link.dtb \ chromebox_panther.dtb \ + conga-qeval20-qa3-e3845.dtb \ cougarcanyon2.dtb \ crownbay.dtb \ efi.dtb \ diff --git a/arch/x86/dts/conga-qeval20-qa3-e3845.dts b/arch/x86/dts/conga-qeval20-qa3-e3845.dts new file mode 100644 index 0000000..478dece --- /dev/null +++ b/arch/x86/dts/conga-qeval20-qa3-e3845.dts @@ -0,0 +1,278 @@ +/* + * Copyright (C) 2014, Bin Meng bmeng.cn@gmail.com + * Copyright (C) 2016 Stefan Roese sr@denx.de + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +/dts-v1/; + +#include <dt-bindings/gpio/x86-gpio.h> +#include <dt-bindings/interrupt-router/intel-irq.h> + +/include/ "skeleton.dtsi" +/include/ "serial.dtsi" +/include/ "rtc.dtsi" +/include/ "tsc_timer.dtsi" + +/ { + model = "congatec-QEVAL20-QA3-E3845"; + compatible = "congatec,qeval20-qa3-e3845", "intel,baytrail"; + + aliases { + serial0 = &serial; + spi0 = &spi; + }; + + config { + silent_console = <0>; + }; + + pch_pinctrl { + compatible = "intel,x86-pinctrl"; + }; + + chosen { + stdout-path = "/serial"; + }; + + cpus { + #address-cells = <1>; + #size-cells = <0>; + + cpu@0 { + device_type = "cpu"; + compatible = "intel,baytrail-cpu"; + reg = <0>; + intel,apic-id = <0>; + }; + + cpu@1 { + device_type = "cpu"; + compatible = "intel,baytrail-cpu"; + reg = <1>; + intel,apic-id = <2>; + }; + + cpu@2 { + device_type = "cpu"; + compatible = "intel,baytrail-cpu"; + reg = <2>; + intel,apic-id = <4>; + }; + + cpu@3 { + device_type = "cpu"; + compatible = "intel,baytrail-cpu"; + reg = <3>; + intel,apic-id = <6>; + }; + }; + + pci { + compatible = "intel,pci-baytrail", "pci-x86"; + #address-cells = <3>; + #size-cells = <2>; + u-boot,dm-pre-reloc; + ranges = <0x02000000 0x0 0x80000000 0x80000000 0 0x40000000 + 0x42000000 0x0 0xc0000000 0xc0000000 0 0x20000000 + 0x01000000 0x0 0x2000 0x2000 0 0xe000>; + + pch@1f,0 { + reg = <0x0000f800 0 0 0 0>; + compatible = "pci8086,0f1c", "intel,pch9"; + #address-cells = <1>; + #size-cells = <1>; + + irq-router { + compatible = "intel,irq-router"; + intel,pirq-config = "ibase"; + intel,ibase-offset = <0x50>; + intel,pirq-link = <8 8>; + intel,pirq-mask = <0xdee0>; + intel,pirq-routing = < + /* BayTrail PCI devices */ + PCI_BDF(0, 2, 0) INTA PIRQA + PCI_BDF(0, 3, 0) INTA PIRQA + PCI_BDF(0, 16, 0) INTA PIRQA + PCI_BDF(0, 17, 0) INTA PIRQA + PCI_BDF(0, 18, 0) INTA PIRQA + PCI_BDF(0, 19, 0) INTA PIRQA + PCI_BDF(0, 20, 0) INTA PIRQA + PCI_BDF(0, 21, 0) INTA PIRQA + PCI_BDF(0, 22, 0) INTA PIRQA + PCI_BDF(0, 23, 0) INTA PIRQA + PCI_BDF(0, 24, 0) INTA PIRQA + PCI_BDF(0, 24, 1) INTC PIRQC + PCI_BDF(0, 24, 2) INTD PIRQD + PCI_BDF(0, 24, 3) INTB PIRQB + PCI_BDF(0, 24, 4) INTA PIRQA + PCI_BDF(0, 24, 5) INTC PIRQC + PCI_BDF(0, 24, 6) INTD PIRQD + PCI_BDF(0, 24, 7) INTB PIRQB + PCI_BDF(0, 26, 0) INTA PIRQA + PCI_BDF(0, 27, 0) INTA PIRQA + PCI_BDF(0, 28, 0) INTA PIRQA + PCI_BDF(0, 28, 1) INTB PIRQB + PCI_BDF(0, 28, 2) INTC PIRQC + PCI_BDF(0, 28, 3) INTD PIRQD + PCI_BDF(0, 29, 0) INTA PIRQA + PCI_BDF(0, 30, 0) INTA PIRQA + PCI_BDF(0, 30, 1) INTD PIRQD + PCI_BDF(0, 30, 2) INTB PIRQB + PCI_BDF(0, 30, 3) INTC PIRQC + PCI_BDF(0, 30, 4) INTD PIRQD + PCI_BDF(0, 30, 5) INTB PIRQB + PCI_BDF(0, 31, 3) INTB PIRQB + + /* + * PCIe root ports downstream + * interrupts + */ + PCI_BDF(1, 0, 0) INTA PIRQA + PCI_BDF(1, 0, 0) INTB PIRQB + PCI_BDF(1, 0, 0) INTC PIRQC + PCI_BDF(1, 0, 0) INTD PIRQD + PCI_BDF(2, 0, 0) INTA PIRQB + PCI_BDF(2, 0, 0) INTB PIRQC + PCI_BDF(2, 0, 0) INTC PIRQD + PCI_BDF(2, 0, 0) INTD PIRQA + PCI_BDF(3, 0, 0) INTA PIRQC + PCI_BDF(3, 0, 0) INTB PIRQD + PCI_BDF(3, 0, 0) INTC PIRQA + PCI_BDF(3, 0, 0) INTD PIRQB + PCI_BDF(4, 0, 0) INTA PIRQD + PCI_BDF(4, 0, 0) INTB PIRQA + PCI_BDF(4, 0, 0) INTC PIRQB + PCI_BDF(4, 0, 0) INTD PIRQC + >; + }; + + spi: spi { + #address-cells = <1>; + #size-cells = <0>; + compatible = "intel,ich9-spi"; + spi-flash@0 { + #address-cells = <1>; + #size-cells = <1>; + reg = <0>; + compatible = "stmicro,n25q064a", + "spi-flash"; + memory-map = <0xff800000 0x00800000>; + rw-mrc-cache { + label = "rw-mrc-cache"; + reg = <0x006f0000 0x00010000>; + }; + }; + }; + + gpioa { + compatible = "intel,ich6-gpio"; + u-boot,dm-pre-reloc; + reg = <0 0x20>; + bank-name = "A"; + }; + + gpiob { + compatible = "intel,ich6-gpio"; + u-boot,dm-pre-reloc; + reg = <0x20 0x20>; + bank-name = "B"; + }; + + gpioc { + compatible = "intel,ich6-gpio"; + u-boot,dm-pre-reloc; + reg = <0x40 0x20>; + bank-name = "C"; + }; + + gpiod { + compatible = "intel,ich6-gpio"; + u-boot,dm-pre-reloc; + reg = <0x60 0x20>; + bank-name = "D"; + }; + + gpioe { + compatible = "intel,ich6-gpio"; + u-boot,dm-pre-reloc; + reg = <0x80 0x20>; + bank-name = "E"; + }; + + gpiof { + compatible = "intel,ich6-gpio"; + u-boot,dm-pre-reloc; + reg = <0xA0 0x20>; + bank-name = "F"; + }; + }; + }; + + fsp { + compatible = "intel,baytrail-fsp"; + fsp,mrc-init-tseg-size = <0>; + fsp,mrc-init-mmio-size = <0x800>; + fsp,mrc-init-spd-addr1 = <0xa0>; + fsp,mrc-init-spd-addr2 = <0xa2>; + fsp,emmc-boot-mode = <2>; + fsp,enable-sdio; + fsp,enable-sdcard; + fsp,enable-hsuart1; + fsp,enable-spi; + fsp,enable-sata; + fsp,sata-mode = <1>; + fsp,enable-lpe; + fsp,lpss-sio-enable-pci-mode; + fsp,enable-dma0; + fsp,enable-dma1; + fsp,enable-i2c0; + fsp,enable-i2c1; + fsp,enable-i2c2; + fsp,enable-i2c3; + fsp,enable-i2c4; + fsp,enable-i2c5; + fsp,enable-i2c6; + fsp,enable-pwm0; + fsp,enable-pwm1; + fsp,igd-dvmt50-pre-alloc = <2>; + fsp,aperture-size = <2>; + fsp,gtt-size = <2>; + fsp,scc-enable-pci-mode; + fsp,os-selection = <4>; + fsp,emmc45-ddr50-enabled; + fsp,emmc45-retune-timer-value = <8>; + fsp,enable-igd; + fsp,enable-memory-down; + fsp,memory-down-params { + compatible = "intel,baytrail-fsp-mdp"; + fsp,dram-speed = <2>; /* 2=1333MHz */ + fsp,dram-type = <1>; /* 1=DDR3L */ + fsp,dimm-0-enable; + fsp,dimm-1-enable; + fsp,dimm-width = <1>; /* 1=x16, 2=x32 */ + fsp,dimm-density = <2>; /* 2=4Gbit */ + fsp,dimm-bus-width = <3>; /* 3=64bits */ + fsp,dimm-sides = <0>; /* 0=1 ranks -> 0x2b */ + + /* These following values might need a re-visit */ + fsp,dimm-tcl = <8>; + fsp,dimm-trpt-rcd = <8>; + fsp,dimm-twr = <8>; + fsp,dimm-twtr = <4>; + fsp,dimm-trrd = <6>; + fsp,dimm-trtp = <4>; + fsp,dimm-tfaw = <22>; + }; + }; + + microcode { + update@0 { +#include "microcode/m0130673322.dtsi" + }; + update@1 { +#include "microcode/m0130679901.dtsi" + }; + }; +}; diff --git a/board/congatec/Kconfig b/board/congatec/Kconfig new file mode 100644 index 0000000..1dc306e --- /dev/null +++ b/board/congatec/Kconfig @@ -0,0 +1,29 @@ +# +# Copyright (C) 2015, Bin Meng bmeng.cn@gmail.com +# +# SPDX-License-Identifier: GPL-2.0+ +# + +if VENDOR_CONGATEC + +choice + prompt "Mainboard model" + optional + +config TARGET_CONGA_QEVAL20_QA3_E3845 + bool "congatec QEVAL 2.0 & conga-QA3/E3845" + help + This is the congatec Qseven 2.0 evaluation carrier board + (conga-QEVAL) equipped with the conga-QA3/E3845-4G SoM. + It contains an Atom E3845 with Ethernet, micro-SD, USB 2, + USB 3, SATA, serial console and HDMI 1.3 video out. + It requires some binary blobs - see README.x86 for details. + + Note that PCIE_ECAM_BASE is set up by the FSP so the value used + by U-Boot matches that value. + +endchoice + +source "board/congatec/conga-qeval20-qa3-e3845/Kconfig" + +endif diff --git a/board/congatec/conga-qeval20-qa3-e3845/Kconfig b/board/congatec/conga-qeval20-qa3-e3845/Kconfig new file mode 100644 index 0000000..9f31238 --- /dev/null +++ b/board/congatec/conga-qeval20-qa3-e3845/Kconfig @@ -0,0 +1,28 @@ +if TARGET_CONGA_QEVAL20_QA3_E3845 + +config SYS_BOARD + default "conga-qeval20-qa3-e3845" + +config SYS_VENDOR + default "congatec" + +config SYS_SOC + default "baytrail" + +config SYS_CONFIG_NAME + default "conga-qeval20-qa3-e3845" + +config SYS_TEXT_BASE + default 0xfff00000 if !EFI_STUB + default 0x01110000 if EFI_STUB + +config BOARD_SPECIFIC_OPTIONS # dummy + def_bool y + select X86_RESET_VECTOR if !EFI_STUB + select INTEL_BAYTRAIL + select BOARD_ROMSIZE_KB_8192 + +config PCIE_ECAM_BASE + default 0xe0000000 + +endif diff --git a/board/congatec/conga-qeval20-qa3-e3845/MAINTAINERS b/board/congatec/conga-qeval20-qa3-e3845/MAINTAINERS new file mode 100644 index 0000000..5a4d4dc --- /dev/null +++ b/board/congatec/conga-qeval20-qa3-e3845/MAINTAINERS @@ -0,0 +1,7 @@ +congatec EVAL20-QA3-E3845 +M: Stefan Roese sr@denx.de +S: Maintained +F: board/congatec/conga-qeval20-qa3-e3845 +F: include/configs/conga-qeval20-qa3-e3845.h +F: configs/conga-qeval20-qa3-e3845_defconfig +F: arch/x86/dts/conga-qeval20-qa3-e3845.dts diff --git a/board/congatec/conga-qeval20-qa3-e3845/Makefile b/board/congatec/conga-qeval20-qa3-e3845/Makefile new file mode 100644 index 0000000..23b8748 --- /dev/null +++ b/board/congatec/conga-qeval20-qa3-e3845/Makefile @@ -0,0 +1,7 @@ +# +# Copyright (C) 2015, Google, Inc +# +# SPDX-License-Identifier: GPL-2.0+ +# + +obj-y += conga-qeval20-qa3.o start.o diff --git a/board/congatec/conga-qeval20-qa3-e3845/conga-qeval20-qa3.c b/board/congatec/conga-qeval20-qa3-e3845/conga-qeval20-qa3.c new file mode 100644 index 0000000..6a946d5 --- /dev/null +++ b/board/congatec/conga-qeval20-qa3-e3845/conga-qeval20-qa3.c @@ -0,0 +1,31 @@ +/* + * Copyright (C) 2016 Stefan Roese sr@denx.de + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <winbond_w83627.h> +#include <asm/gpio.h> +#include <asm/ibmpc.h> +#include <asm/pnp_def.h> + +int board_early_init_f(void) +{ + /* + * The FSP enables the BayTrail internal legacy UART (again). + * Disable it again, so that the Winbond one can be used. + */ + setup_internal_uart(0); + + /* Enable the legacy UART in the Winbond W83627 Super IO chip */ + winbond_enable_serial(PNP_DEV(WINBOND_IO_PORT, W83627DHG_SP1), + UART0_BASE, UART0_IRQ); + + return 0; +} + +int arch_early_init_r(void) +{ + return 0; +} diff --git a/board/congatec/conga-qeval20-qa3-e3845/start.S b/board/congatec/conga-qeval20-qa3-e3845/start.S new file mode 100644 index 0000000..2c941a4 --- /dev/null +++ b/board/congatec/conga-qeval20-qa3-e3845/start.S @@ -0,0 +1,9 @@ +/* + * Copyright (C) 2015, Google, Inc + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +.globl early_board_init +early_board_init: + jmp early_board_init_ret diff --git a/configs/conga-qeval20-qa3-e3845_defconfig b/configs/conga-qeval20-qa3-e3845_defconfig new file mode 100644 index 0000000..24a927d --- /dev/null +++ b/configs/conga-qeval20-qa3-e3845_defconfig @@ -0,0 +1,47 @@ +CONFIG_X86=y +CONFIG_VENDOR_CONGATEC=y +CONFIG_TARGET_CONGA_QEVAL20_QA3_E3845=y +CONFIG_DEFAULT_DEVICE_TREE="conga-qeval20-qa3-e3845" +CONFIG_HAVE_INTEL_ME=y +CONFIG_ENABLE_MRC_CACHE=y +CONFIG_SMP=y +CONFIG_HAVE_VGA_BIOS=y +CONFIG_GENERATE_PIRQ_TABLE=y +CONFIG_GENERATE_MP_TABLE=y +CONFIG_FIT=y +CONFIG_FIT_SIGNATURE=y +CONFIG_BOOTSTAGE=y +CONFIG_BOOTSTAGE_REPORT=y +CONFIG_CMD_CPU=y +# CONFIG_CMD_IMLS is not set +# CONFIG_CMD_FLASH is not set +CONFIG_CMD_GPIO=y +# CONFIG_CMD_SETEXPR is not set +# CONFIG_CMD_NFS is not set +CONFIG_CMD_BOOTSTAGE=y +CONFIG_OF_CONTROL=y +CONFIG_REGMAP=y +CONFIG_SYSCON=y +CONFIG_CPU=y +CONFIG_WINBOND_W83627=y +CONFIG_SPI_FLASH=y +CONFIG_SPI_FLASH_GIGADEVICE=y +CONFIG_SPI_FLASH_MACRONIX=y +CONFIG_SPI_FLASH_STMICRO=y +CONFIG_SPI_FLASH_WINBOND=y +CONFIG_DM_ETH=y +CONFIG_E1000=y +CONFIG_DM_PCI=y +CONFIG_DM_RTC=y +CONFIG_DEBUG_UART=y +CONFIG_DEBUG_UART_BASE=0x3f8 +CONFIG_DEBUG_UART_CLOCK=1843200 +CONFIG_SYS_NS16550=y +CONFIG_ICH_SPI=y +CONFIG_TIMER=y +CONFIG_USB=y +CONFIG_DM_USB=y +CONFIG_VIDEO_VESA=y +CONFIG_FRAMEBUFFER_SET_VESA_MODE=y +CONFIG_FRAMEBUFFER_VESA_MODE_114=y +CONFIG_USE_PRIVATE_LIBGCC=y diff --git a/include/configs/conga-qeval20-qa3-e3845.h b/include/configs/conga-qeval20-qa3-e3845.h new file mode 100644 index 0000000..556d44e --- /dev/null +++ b/include/configs/conga-qeval20-qa3-e3845.h @@ -0,0 +1,65 @@ +/* + * Copyright (C) 2016 Stefan Roese sr@denx.de + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +/* + * board/config.h - configuration options, board specific + */ + +#ifndef __CONFIG_H +#define __CONFIG_H + +#include <configs/x86-common.h> + +#define CONFIG_SYS_MONITOR_LEN (1 << 20) +#define CONFIG_BOARD_EARLY_INIT_F +#define CONFIG_ARCH_EARLY_INIT_R +#define CONFIG_ARCH_MISC_INIT + +#define CONFIG_PCI_PNP + +#define CONFIG_STD_DEVICES_SETTINGS "stdin=serial\0" \ + "stdout=serial\0" \ + "stderr=serial\0" + +#define CONFIG_SCSI_DEV_LIST \ + {PCI_VENDOR_ID_INTEL, PCI_DEVICE_ID_INTEL_VALLEYVIEW_SATA}, \ + {PCI_VENDOR_ID_INTEL, PCI_DEVICE_ID_INTEL_VALLEYVIEW_SATA_ALT} + +#define CONFIG_MMC +#define CONFIG_SDHCI +#define CONFIG_GENERIC_MMC +#define CONFIG_MMC_SDMA +#define CONFIG_CMD_MMC + +#undef CONFIG_USB_MAX_CONTROLLER_COUNT +#define CONFIG_USB_MAX_CONTROLLER_COUNT 1 + +#define VIDEO_IO_OFFSET 0 +#define CONFIG_X86EMU_RAW_IO +#define CONFIG_CMD_BMP + +#define CONFIG_ENV_SECT_SIZE 0x1000 +#define CONFIG_ENV_OFFSET 0x007fe000 + +#undef CONFIG_BOOTARGS +#undef CONFIG_BOOTCOMMAND + +#define CONFIG_BOOTARGS \ + "root=/dev/sda1 ro quiet" +#define CONFIG_BOOTCOMMAND \ + "load scsi 0:1 03000000 /boot/vmlinuz-4.2.0-26-generic;" \ + "load scsi 0:1 04000000 /boot/initrd.img-4.2.0-26-generic;" \ + "run boot" + +#undef CONFIG_EXTRA_ENV_SETTINGS +#define CONFIG_EXTRA_ENV_SETTINGS \ + "boot=zboot 03000000 0 04000000 ${filesize}\0" \ + "upd_uboot=tftp 100000 conga/u-boot.rom;" \ + "sf probe;sf update 100000 0 7fe000\0" + +#define CONFIG_PREBOOT + +#endif /* __CONFIG_H */
- USB 2.0
- eMMC
- PCIe
- I2C
- USB 3.0
v2:
- USB 2.0
- eMMC
- PCIe
- I2C
- USB 3.0
v2:
rebased on top of Simon's broadwell patch series, and applied to u-boot-x86, thanks!
Bin Meng
Stefan Roese
