[PATCH] configs: versal: Enable CONFIG_LTO for mini qspi/ospi
Adding a tiny bit more code for mini u-boot leads to a OCM image overflow. Fix this by enabling LTO for this board, so that such changes still can be made to the common U-Boot code.
Enable building mini u-boot image with LTO, which results in about 8KB reduction in size.
Signed-off-by: Michal Simek michal.simek@amd.com Signed-off-by: Venkatesh Yadav Abbarapu venkatesh.abbarapu@amd.com --- configs/xilinx_versal_mini_ospi_defconfig | 1 + configs/xilinx_versal_mini_qspi_defconfig | 1 + 2 files changed, 2 insertions(+)
diff --git a/configs/xilinx_versal_mini_ospi_defconfig b/configs/xilinx_versal_mini_ospi_defconfig index 72a123d965..7a110350c2 100644 --- a/configs/xilinx_versal_mini_ospi_defconfig +++ b/configs/xilinx_versal_mini_ospi_defconfig @@ -16,6 +16,7 @@ CONFIG_SYS_MEM_RSVD_FOR_MMU=y CONFIG_VERSAL_NO_DDR=y # CONFIG_PSCI_RESET is not set CONFIG_SYS_LOAD_ADDR=0x8000000 +CONFIG_LTO=y # CONFIG_EXPERT is not set CONFIG_REMAKE_ELF=y # CONFIG_AUTOBOOT is not set diff --git a/configs/xilinx_versal_mini_qspi_defconfig b/configs/xilinx_versal_mini_qspi_defconfig index d9fbac986c..58945a1cac 100644 --- a/configs/xilinx_versal_mini_qspi_defconfig +++ b/configs/xilinx_versal_mini_qspi_defconfig @@ -14,6 +14,7 @@ CONFIG_SYS_MEM_RSVD_FOR_MMU=y CONFIG_VERSAL_NO_DDR=y # CONFIG_PSCI_RESET is not set CONFIG_SYS_LOAD_ADDR=0x8000000 +CONFIG_LTO=y # CONFIG_EXPERT is not set CONFIG_REMAKE_ELF=y # CONFIG_AUTOBOOT is not set
Applied. M
Michal Simek
