[U-Boot] [PATCH] env_sf: updated to the new environment code
Functions to store/retrieve the environment from a SPI flash was not updated to the new environment code. The non-redundant case was not working correctly, reporting ""Environment SPI flash not initialized" and the code was not compiled clean in the redundant case.
The patch fixes these issue and makes the code more coherent with other environment storage (nand, flash).
Signed-off-by: Stefano Babic sbabic@denx.de --- common/env_sf.c | 172 +++++++++++++++++++++++++------------------------------ 1 files changed, 77 insertions(+), 95 deletions(-)
diff --git a/common/env_sf.c b/common/env_sf.c index fb0c39b..a597b24 100644 --- a/common/env_sf.c +++ b/common/env_sf.c @@ -51,7 +51,7 @@ static ulong env_new_offset = CONFIG_ENV_OFFSET_REDUND;
#define ACTIVE_FLAG 1 #define OBSOLETE_FLAG 0 -#endif /* CONFIG_ENV_ADDR_REDUND */ +#endif /* CONFIG_ENV_OFFSET_REDUND */
DECLARE_GLOBAL_DATA_PTR;
@@ -69,13 +69,6 @@ uchar env_get_char_spec(int index) }
#if defined(CONFIG_ENV_OFFSET_REDUND) -void swap_env(void) -{ - ulong tmp_offset = env_offset; - - env_offset = env_new_offset; - env_new_offset = tmp_offset; -}
int saveenv(void) { @@ -89,8 +82,13 @@ int saveenv(void) char flag = OBSOLETE_FLAG, new_flag = ACTIVE_FLAG;
if (!env_flash) { - puts("Environment SPI flash not initialized\n"); - return 1; + env_flash = spi_flash_probe(CONFIG_ENV_SPI_BUS, + CONFIG_ENV_SPI_CS, + CONFIG_ENV_SPI_MAX_HZ, CONFIG_ENV_SPI_MODE); + if (!env_flash) { + set_default_env("!spi_flash_probe() failed"); + return 1; + } }
res = (char *)&env_new.data; @@ -102,6 +100,14 @@ int saveenv(void) env_new.crc = crc32(0, env_new.data, ENV_SIZE); env_new.flags = ACTIVE_FLAG;
+ if (gd->env_valid == 1) { + env_new_offset = CONFIG_ENV_OFFSET_REDUND; + env_offset = CONFIG_ENV_OFFSET; + } else { + env_new_offset = CONFIG_ENV_OFFSET; + env_offset = CONFIG_ENV_OFFSET_REDUND; + } + /* Is the sector larger than the env (i.e. embedded) */ if (CONFIG_ENV_SECT_SIZE > CONFIG_ENV_SIZE) { saved_size = CONFIG_ENV_SECT_SIZE - CONFIG_ENV_SIZE; @@ -130,27 +136,9 @@ int saveenv(void) goto done;
puts("Writing to SPI flash..."); - ret = spi_flash_write(env_flash, - env_new_offset + offsetof(env_t, data), - sizeof(env_new.data), env_new.data); - if (ret) - goto done; - - ret = spi_flash_write(env_flash, - env_new_offset + offsetof(env_t, crc), - sizeof(env_new.crc), &env_new.crc); - if (ret) - goto done;
- ret = spi_flash_write(env_flash, - env_offset + offsetof(env_t, flags), - sizeof(env_new.flags), &flag); - if (ret) - goto done; - - ret = spi_flash_write(env_flash, - env_new_offset + offsetof(env_t, flags), - sizeof(env_new.flags), &new_flag); + ret = spi_flash_write(env_flash, env_new_offset, + CONFIG_ENV_SIZE, &env_new); if (ret) goto done;
@@ -161,11 +149,18 @@ int saveenv(void) goto done; }
- swap_env(); + ret = spi_flash_write(env_flash, + env_offset + offsetof(env_t, flags), + sizeof(env_new.flags), &flag); + if (ret) + goto done;
- ret = 0; puts("done\n");
+ gd->env_valid = (gd->env_valid == 2 ? 1 : 2); + + printf("Valid environment: %d\n", gd->env_valid); + done: if (saved_buffer) free(saved_buffer); @@ -178,7 +173,7 @@ void env_relocate_spec(void) int crc1_ok = 0, crc2_ok = 0; env_t *tmp_env1 = NULL; env_t *tmp_env2 = NULL; - env_t ep; + env_t *ep = NULL; uchar flag1, flag2; /* current_env is set only in case both areas are valid! */ int current_env = 0; @@ -219,90 +214,57 @@ void env_relocate_spec(void) flag2 = tmp_env2->flags; }
- if (!crc1_ok && !crc2_ok) - goto err_crc; - else if (crc1_ok && !crc2_ok) { + if (!crc1_ok && !crc2_ok) { + free(tmp_env1); + free(tmp_env2); + set_default_env("!bad CRC"); + return; + } else if (crc1_ok && !crc2_ok) { gd->env_valid = 1; ep = tmp_env1; } else if (!crc1_ok && crc2_ok) { gd->env_valid = 1; - ep = tmp_env2; - swap_env(); } else if (flag1 == ACTIVE_FLAG && flag2 == OBSOLETE_FLAG) { gd->env_valid = 1; - ep = tmp_env1; } else if (flag1 == OBSOLETE_FLAG && flag2 == ACTIVE_FLAG) { - gd->env_valid = 1; - ep = tmp_env2; - swap_env(); + gd->env_valid = 2; } else if (flag1 == flag2) { gd->env_valid = 2; - ep = tmp_env1; - current_env = 1; } else if (flag1 == 0xFF) { gd->env_valid = 2; - ep = tmp_env1; - current_env = 1; } else { /* * this differs from code in env_flash.c, but I think a sane * default path is desirable. */ gd->env_valid = 2; - ep = tmp_env2; - swap_env(); - current_env = 2; }
- rc = env_import((char *)ep, 0); - if (!rc) { - error("Cannot import environment: errno = %d\n", errno); - goto out; - } + free(env_ptr);
- if (current_env == 1) { - if (flag2 != OBSOLETE_FLAG) { - flag2 = OBSOLETE_FLAG; - spi_flash_write(env_flash, - env_new_offset + offsetof(env_t, flags), - sizeof(env_new.flags), &flag2); - } - if (flag1 != ACTIVE_FLAG) { - flag1 = ACTIVE_FLAG; - spi_flash_write(env_flash, - env_offset + offsetof(env_t, flags), - sizeof(env_new.flags), &flag1); - } - } else if (current_env == 2) { - if (flag1 != OBSOLETE_FLAG) { - flag1 = OBSOLETE_FLAG; - spi_flash_write(env_flash, - env_new_offset + offsetof(env_t, flags), - sizeof(env_new.flags), &flag1); - } - if (flag2 != ACTIVE_FLAG) { - flag2 = ACTIVE_FLAG; - spi_flash_write(env_flash, - env_offset + offsetof(env_t, flags), - sizeof(env_new.flags), &flag2); - } - } - if (gd->env_valid == 2) { - puts("*** Warning - some problems detected " - "reading environment; recovered successfully\n\n"); + if (gd->env_valid == 1) + ep = tmp_env1; + else + ep = tmp_env2; + + ret = env_import((char *)ep, 0); + if (!ret) { + error("Cannot import environment: errno = %d\n", errno); + set_default_env("env_import failed"); } - if (tmp_env1) - free(tmp_env1); - if (tmp_env2) - free(tmp_env2); - return;
err_read: spi_flash_free(env_flash); env_flash = NULL; out: + if (tmp_env1) + free(tmp_env1); + if (tmp_env2) + free(tmp_env2); free(tmp_env1); free(tmp_env2); + + return; } #else int saveenv(void) @@ -311,10 +273,18 @@ int saveenv(void) char *saved_buffer = NULL; u32 sector = 1; int ret; + env_t env_new; + char *res; + ssize_t len;
/* Is the sector larger than the env (i.e. embedded) */ @@ -326,7 +296,8 @@ int saveenv(void) ret = 1; goto done; } - ret = spi_flash_read(env_flash, saved_offset, saved_size, saved_buffer); + ret = spi_flash_read(env_flash, saved_offset, + saved_size, saved_buffer); if (ret) goto done; } @@ -337,18 +308,29 @@ int saveenv(void) sector++; }
+ res = (char *)&env_new.data; + len = hexport('\0', &res, ENV_SIZE); + if (len < 0) { + error("Cannot export environment: errno = %d\n", errno); + goto done; + } + env_new.crc = crc32(0, env_new.data, ENV_SIZE); + puts("Erasing SPI flash..."); - ret = spi_flash_erase(env_flash, CONFIG_ENV_OFFSET, sector * CONFIG_ENV_SECT_SIZE); + ret = spi_flash_erase(env_flash, CONFIG_ENV_OFFSET, + sector * CONFIG_ENV_SECT_SIZE); if (ret) goto done;
puts("Writing to SPI flash..."); - ret = spi_flash_write(env_flash, CONFIG_ENV_OFFSET, CONFIG_ENV_SIZE, env_ptr); + ret = spi_flash_write(env_flash, CONFIG_ENV_OFFSET, + CONFIG_ENV_SIZE, &env_new); if (ret) goto done;
if (CONFIG_ENV_SECT_SIZE > CONFIG_ENV_SIZE) { - ret = spi_flash_write(env_flash, saved_offset, saved_size, saved_buffer); + ret = spi_flash_write(env_flash, saved_offset, + saved_size, saved_buffer); if (ret) goto done; }
Dear Stefano Babic,
Applied, thanks.
seems to introduce a bug. some Blackfin boards now show: Configuring for ip04 board... env_sf.c: In function ‘saveenv’: env_sf.c:275: warning: ‘ret’ may be used uninitialized in this function -mike
Mike Frysinger
Stefano Babic
