[U-Boot] [PATCH] net: eepro100: Fix build warnings
When building katmai, it reports quite a lot
warning: cast to pointer from integer of different size [-Wint-to-pointer-cast]
Fix this by casting the dev->iobase with u_long.
Signed-off-by: Bin Meng bmeng.cn@gmail.com ---
drivers/net/eepro100.c | 8 ++++---- 1 file changed, 4 insertions(+), 4 deletions(-)
diff --git a/drivers/net/eepro100.c b/drivers/net/eepro100.c index f2cd32c..d4a6386 100644 --- a/drivers/net/eepro100.c +++ b/drivers/net/eepro100.c @@ -240,23 +240,23 @@ static void eepro100_halt (struct eth_device *dev);
static inline int INW (struct eth_device *dev, u_long addr) { - return le16_to_cpu (*(volatile u16 *) (addr + dev->iobase)); + return le16_to_cpu(*(volatile u16 *)(addr + (u_long)dev->iobase)); }
static inline void OUTW (struct eth_device *dev, int command, u_long addr) { - *(volatile u16 *) ((addr + dev->iobase)) = cpu_to_le16 (command); + *(volatile u16 *)((addr + (u_long)dev->iobase)) = cpu_to_le16(command); }
static inline void OUTL (struct eth_device *dev, int command, u_long addr) { - *(volatile u32 *) ((addr + dev->iobase)) = cpu_to_le32 (command); + *(volatile u32 *)((addr + (u_long)dev->iobase)) = cpu_to_le32(command); }
#if defined(CONFIG_MII) || defined(CONFIG_CMD_MII) static inline int INL (struct eth_device *dev, u_long addr) { - return le32_to_cpu (*(volatile u32 *) (addr + dev->iobase)); + return le32_to_cpu(*(volatile u32 *)(addr + (u_long)dev->iobase)); }
static int get_phyreg (struct eth_device *dev, unsigned char addr,
Signed-off-by: Bin Meng bmeng.cn@gmail.com Acked-by: Joe Hershberger joe.hershberger@ni.com
Bin Meng
Joe Hershberger
