RE: [U-Boot-Users] How to boot the U-boot in MPC8266ADS
U-Boot works great on my ADS board. (I ported it) I am using the following juper settings on the board:
S/W Option All set to 0 MODCHK0-3 set to 0101 PCIMODCK = 0 MODCK 1-3 = 001
SDRAM_CONF = 000 Boot Source = 0 PCI ARBITER = = PCI DLL = 1 PCI_CFG = 0
JP3 (Boot Source) on 2-3 (BCSR)
You could also try the MPC8260ADS version and see if it dowes the same (just make sure to disable the SDRAM initalization for the LocalBus since the 8266 doesnt have this)
-----Original Message----- From: Wilson Lo [mailto:kclwilson@yahoo.com.hk] Sent: Thursday, April 10, 2003 5:58 AM To: u-boot-users@lists.sourceforge.net Subject: [U-Boot-Users] How to boot the U-boot in MPC8266ADS
Hi, I download the U-boot from web. I tried to use it in MPC8266ADS, but it is failed. I found that the bootloader hangs in the function "board_init_f" when it running in "init sequence". It successes to pass the "checkboard" function (i see it in COM port). After that, it hangs.
I do not change any code and just compile and program the "u-boot" file in flash memory at "0xfff00000". Is there any hardware setup should be done ? I use the default setting to test. Do I need to change the setting ?
Wilson
_________________________________________________________ 我的驕傲(容祖兒),合久必婚(李克勤),下一站...天后(Twins)... Yahoo! 鈴聲下載 http://ringtone.yahoo.com.hk
------------------------------------------------------- This SF.net email is sponsored by: Etnus, makers of TotalView, The debugger for complex code. Debugging C/C++ programs can leave you feeling lost and disoriented. TotalView can help you find your way. Available on major UNIX and Linux platforms. Try it free. www.etnus.com _______________________________________________ U-Boot-Users mailing list U-Boot-Users@lists.sourceforge.net https://lists.sourceforge.net/lists/listinfo/u-boot-users
My h/w config is same to you suggestion. But the board still can't build up. I don't know if it is a compiler problem or not. Would you please send your image file (srec record) to me for test ? So that I can find the reason. Thanks for your help.
Wilson
--- Rune Torgersen runet@innovsys.com 的郵件內容:> U-Boot works great on my ADS board. (I ported it)
Wilson
Rune Torgersen
Wilson Lo
