[U-Boot] [PATCH 1/2] mx28evk: Remove unneeded 'undef'
There is no need to undef an option that is not enabled by default.
Signed-off-by: Fabio Estevam fabio.estevam@freescale.com --- include/configs/mx28evk.h | 1 - 1 file changed, 1 deletion(-)
diff --git a/include/configs/mx28evk.h b/include/configs/mx28evk.h index 4e70617..b677e51 100644 --- a/include/configs/mx28evk.h +++ b/include/configs/mx28evk.h @@ -215,7 +215,6 @@ #define CONFIG_SF_DEFAULT_SPEED 24000000
/* (redundant) environemnt in SPI flash */ -#undef CONFIG_ENV_IS_IN_SPI_FLASH #ifdef CONFIG_ENV_IS_IN_SPI_FLASH #define CONFIG_SYS_REDUNDAND_ENVIRONMENT #define CONFIG_ENV_SIZE 0x1000 /* 4KB */
commit d92591a (mxs: Convert sys_proto.h prefixes to 'mxs') introduced a mxs_dram_init() function, which is not used anywhere.
Fix it, so that the following warning goes away:
mx28evk.c: In function ‘dram_init’: mx28evk.c:67:2: warning: implicit declaration of function ‘mx28_dram_init’ [-Wimplicit-function-declaration]
Signed-off-by: Fabio Estevam fabio.estevam@freescale.com --- arch/arm/include/asm/arch-mxs/sys_proto.h | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/arch/arm/include/asm/arch-mxs/sys_proto.h b/arch/arm/include/asm/arch-mxs/sys_proto.h index 9d1e599..4610363 100644 --- a/arch/arm/include/asm/arch-mxs/sys_proto.h +++ b/arch/arm/include/asm/arch-mxs/sys_proto.h @@ -69,6 +69,6 @@ struct mxs_spl_data { uint32_t mem_dram_size; };
-int mxs_dram_init(void); +int mx28_dram_init(void);
#endif /* __SYS_PROTO_H__ */
Dear Fabio Estevam,
Acked-by: Marek Vasut marex@denx.de
Best regards, Marek Vasut
Acked-by: Otavio Salvador otavio@ossystems.com.br
Hi Stefano,
Please discard this patch.
Otavio fixed it in another patch related to mx23 series.
Regards,
Fabio Estevam
Ops, sorry. Otavio based his patch on top of mine, so this one needs to be applied.
Thanks,
Fabio Estevam
It shouldn't matter; GIT will do a 3way merge and apply I think.
Applied to u-boot-imx, thanks.
Best regards, Stefano Babic
Dear Fabio Estevam,
Acked-by: Stefano Babic sbabic@denx.de
Regards, Stefano
Fabio Estevam
Otavio Salvador
Stefano Babic
